[MOAB-dev] BCAST_DELETE changes
David Thompson
dcthomp at sandia.gov
Mon Aug 11 18:45:25 CDT 2008
Hi all,
I ran into an issue where using the parallel reader with an invalid
filename in BCAST_DELETE mode would cause a hang. I have a patch
(attached) that fixes the issue for me but want to make sure it doesn't
cause trouble for anyone else before checking it in.
The patch also deletes a bit of what appears to be dead code in
resolve_shared_ents(). The code was apparently meant to detect the
maximum that a global ID could be but the results of the MPI_AllReduce
(which sums the number of entities across all processes) don't appear to
be used anywhere.
Any comments before I commit the change?
David
Index: parallel/MBParallelComm.cpp
--- parallel/MBParallelComm.cpp (revision 2036)
+++ parallel/MBParallelComm.cpp (working copy)
@@ -536,6 +536,9 @@
#else
MBErrorCode result = MB_SUCCESS;
+ if ( entities.size() == 0 )
+ return result;
int success;
MBRange whole_range;
int buff_size;
@@ -2406,18 +2409,6 @@
// get a crystal router
crystal_data *cd = procConfig.crystal_router();
- // get total number of entities; will overshoot highest global id, but
- // that's ok
- int num_total = 0, num_local;
- result = mbImpl->get_number_entities_by_dimension(0, 0, num_local);
- if (MB_SUCCESS != result) return result;
- int failure = MPI_Allreduce(&num_local, &num_total, 1,
- MPI_INT, MPI_SUM, procConfig.proc_comm());
- if (failure) {
- result = MB_FAILURE;
- RRA("Allreduce for total number of shared ents failed.");
// call gather-scatter to get shared ids & procs
gs_data *gsd;
assert(sizeof(ulong_) == sizeof(MBEntityHandle));
