[MOAB-dev] Re: Problems linking to MOAB
Tim Tautges
tautges at mcs.anl.gov
Mon Aug 11 16:29:49 CDT 2008
Please report/interact on MOAB through moab-dev at mcs.anl.gov, I'm on
vacation and can't help but someone else will. THanks.
- tim
Neil Hodge wrote:
> Tim:
> I am currently trying to link our code to MOAB, including libiMesh. The
> link line is
> mpCC_r -g -q64 -brtl -blpdata -bmaxdata:0x600000000 -L... -o
> diablo_debug ../objs_debug/diablo_lib_main.o\
> -L ../lib_debug -ldiablo
> -L/g/g22/hodge3/data/projects/diablo/itaps/Diablo_II/Build/DIABLO-aix_5_64_fed-UP/Libraries/METIS/metis-4.0/aix_5_64bit/
> -L/usr/apps/mdg/lib -L/usr/gapps/silo/4.5/aix_5_64_fed/lib
> -L/usr/local/tools/hdf5/hdf5-1.6.5/serial/lib
> -L/g/g22/hodge3/data/projects/diablo/itaps/Diablo_II/Build/DIABLO-aix_5_64_fed-UP/Libraries/PWSSMP/wssmp/aix_5_64bit
> -L/g/g22/hodge3/data/projects/diablo/itaps/Diablo_II/Build/DIABLO-aix_5_64_fed-UP/Libraries/HYPRE/hypre-2.0.0/aix_5_64_fed
> -L/g/g22/hodge3/data/projects/diablo/itaps/Diablo_II/Build/DIABLO-aix_5_64_fed-UP/Libraries/NASA
> -L/usr/local/lib
> -L/g/g22/hodge3/data/projects/diablo/itaps/Diablo_II/Libraries/ITAPS
> -L/usr/local/lib -lm -lblas -lxlf90 -lc -lmetis -lmili -lsilo
> -lhdf5_fortran -lhdf5 -lHYPRE -lvss_ibm -lpwsmp64 -llapack -liMesh_ibm
> -lMOAB_ibm
> I am getting the following error:
> ld: 0711-317 ERROR: Undefined symbol:
> .MBRange::subset_by_type(MBEntityType)
> Although, when I check libMOAB with nm and dump, subset_by_type is
> clearly there.
> I am trying this on AIX. Any thoughts?
> Thanks.
> Neil Hodge
> hodge3 at llnl.gov
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
