[MOAB-dev] r1786 - in MOAB/trunk/tools: iMesh/SIDL mbperf
tautges at mcs.anl.gov
Wed Apr 30 10:42:51 CDT 2008
Author: tautges
Date: 2008-04-30 10:42:51 -0500 (Wed, 30 Apr 2008)
New Revision: 1786
Modified:
MOAB/trunk/tools/iMesh/SIDL/Makefile.in
MOAB/trunk/tools/iMesh/SIDL/common.make.in
MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp
MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
Log:
- fixing SIDL includes so it finds MBCN_FCDefs.h (third time's a charm!)
- fixing various compiler warnings shown by gcc 4.3
Passes make and make check for out of source build.
Modified: MOAB/trunk/tools/iMesh/SIDL/Makefile.in
--- MOAB/trunk/tools/iMesh/SIDL/Makefile.in 2008-04-29 21:11:30 UTC (rev 1785)
+++ MOAB/trunk/tools/iMesh/SIDL/Makefile.in 2008-04-30 15:42:51 UTC (rev 1786)
@@ -14,7 +14,7 @@
SOURCE_FILES = $(SIDL_FILES) $(SERVER_FILES) iBase_SIDL_defs.h
DIST_FILES = $(SOURCE_FILES) testcxx.cpp \
mserver.make Cclient.make Fclient.make
-INCLUDES = -I$(BABEL_DIR)/include -Imserver -I$(top_srcdir)
+INCLUDES = -I$(BABEL_DIR)/include -Imserver
CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
Modified: MOAB/trunk/tools/iMesh/SIDL/common.make.in
--- MOAB/trunk/tools/iMesh/SIDL/common.make.in 2008-04-29 21:11:30 UTC (rev 1785)
+++ MOAB/trunk/tools/iMesh/SIDL/common.make.in 2008-04-30 15:42:51 UTC (rev 1786)
@@ -7,7 +7,8 @@
-I$(imesh_srcdir) \
-I$(imesh_builddir) \
-I$(sidl_srcdir) \
- -I$(top_srcdir)
+ -I$(top_srcdir) \
+ -I$(top_builddir)
imesh_srcdir = $(sidl_srcdir)/..
imesh_builddir = ../..
Modified: MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp
--- MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp 2008-04-29 21:11:30 UTC (rev 1785)
+++ MOAB/trunk/tools/iMesh/SIDL/testcxx.cpp 2008-04-30 15:42:51 UTC (rev 1786)
@@ -68,6 +68,7 @@
#include <iostream>
+#include <algorithm>
#include "iBase.hh"
#include "iMesh.hh"
Modified: MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
--- MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp 2008-04-29 21:11:30 UTC (rev 1785)
+++ MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp 2008-04-30 15:42:51 UTC (rev 1786)
@@ -224,13 +224,12 @@
// need some dimensions
int numv = nelem + 1;
int numv_sq = numv*numv;
- int num_verts = numv*numv*numv;
+ int sidl_vertices_size = numv*numv*numv;
#define VINDEX(i,j,k) (i + (j*numv) + (k*numv_sq))
// array to hold vertices created individually
sidl::array<Entity_Handle> sidl_vertices;
- int sidl_vertices_size = num_verts;
- CHECK_SIZE(sidl_vertices, num_verts);
+ CHECK_SIZE(sidl_vertices, sidl_vertices_size);
// temporary array to hold vertex positions for single vertex
sidl::array<double> tmp_coords;
@@ -241,7 +240,7 @@
// get direct pointer to coordinate array
double *coords_ptr = ARRAY_PTR(coords, double);
- for (int i = 0; i < num_verts; i++) {
+ for (int i = 0; i < sidl_vertices_size; i++) {
// temporary array to hold (single) vertices
sidl::array<Entity_Handle> tmp_vertices;
@@ -249,8 +248,8 @@
// create the vertex
dum_coords[0] = coords_ptr[i];
- dum_coords[1] = coords_ptr[num_verts+i];
- dum_coords[2] = coords_ptr[2*num_verts+i];
+ dum_coords[1] = coords_ptr[sidl_vertices_size+i];
+ dum_coords[2] = coords_ptr[2*sidl_vertices_size+i];
try {
mesh_arrmod.createVtxArr(1, iBase::StorageOrder_BLOCKED,
tmp_coords, tmp_coords_size,
