[MOAB-dev] r1785 - MOAB/branches/ghosting/parallel
tautges at mcs.anl.gov
Tue Apr 29 16:11:30 CDT 2008
Author: tautges
Date: 2008-04-29 16:11:30 -0500 (Tue, 29 Apr 2008)
New Revision: 1785
Modified:
MOAB/branches/ghosting/parallel/MBParallelComm.cpp
Log:
Couple more bug fixes for ghost exchange, should work now (at least for vertex-connected elements).
Modified: MOAB/branches/ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/ghosting/parallel/MBParallelComm.cpp 2008-04-29 19:25:05 UTC (rev 1784)
+++ MOAB/branches/ghosting/parallel/MBParallelComm.cpp 2008-04-29 21:11:30 UTC (rev 1785)
@@ -346,7 +346,7 @@
// remote range, if requested
int success;
if (store_remote_handles) {
- recv_buff.resize(final_ents.size());
+ recv_buff.resize(2*num_subranges(final_ents)*sizeof(MBEntityHandle) + sizeof(int));
success = MPI_Irecv(&recv_buff[0], recv_buff.size(), MPI_UNSIGNED_CHAR, to_proc,
MB_MESG_REMOTE_HANDLES, procConfig.proc_comm(),
@@ -409,7 +409,12 @@
sizeof(int);
send_buff.resize(range_size);
unsigned char *buff_ptr = &send_buff[0];
- PACK_RANGE(buff_ptr, recd_ents);
+// PACK_RANGE(buff, rng)
+ {int num_subs = num_subranges(recd_ents); PACK_INTS(buff_ptr, &num_subs, 1); PC(num_subs, "-subranged range"); \
+ for (MBRange::const_pair_iterator cit = recd_ents.const_pair_begin(); cit != recd_ents.const_pair_end(); cit++) { \
+ MBEntityHandle eh = (*cit).first; PACK_EH(buff_ptr, &eh, 1); \
+ eh = (*cit).second; PACK_EH(buff_ptr, &eh, 1);}; }
+// PACK_RANGE(buff_ptr, recd_ents);
int success = MPI_Isend(&send_buff[0], range_size, MPI_UNSIGNED_CHAR, from_proc,
MB_MESG_REMOTE_HANDLES, procConfig.proc_comm(), &send_req);
if (success != MPI_SUCCESS) {
@@ -585,7 +590,7 @@
result = pack_entities(orig_ents, rit, final_ents, buff_ptr,
buff_size, false, store_remote_handles, to_proc,
ent_types, all_ranges, verts_per_entity);
- RRA("Packing entities (count) failed.");
+ RRA("Packing entities (real) failed.");
#ifdef DEBUG_PACKING
std::cerr << "pack_entities buffer space: " << buff_ptr - &buff[0] << " bytes." << std::endl;
unsigned char *tmp_buff = buff_ptr;
@@ -595,7 +600,7 @@
result = pack_sets(orig_ents, rit, final_ents, buff_ptr, buff_size, false,
store_remote_handles, to_proc, set_range, set_ranges,
set_sizes, options_vec);
- RRA("Packing sets (count) failed.");
+ RRA("Packing sets (real) failed.");
std::cerr << "pack_sets buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -606,7 +611,7 @@
result = pack_adjacencies(orig_ents, rit, final_ents, buff_ptr,
buff_size, false,
store_remote_handles, to_proc);
- RRA("Packing adjs (count) failed.");
+ RRA("Packing adjs (real) failed.");
// tags
@@ -614,7 +619,7 @@
result = pack_tags(orig_ents, rit, final_ents, buff_ptr,
buff_size, false, store_remote_handles, to_proc, all_tags,
tag_ranges);
- RRA("Packing tags (count) failed.");
+ RRA("Packing tags (real) failed.");
std::cerr << "pack_tags buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -995,22 +1000,6 @@
MBErrorCode MBParallelComm::get_remote_handles(const bool store_remote_handles,
const MBRange &from_range,
- MBRange &to_range,
- int to_proc,
- const MBRange &new_ents)
- std::vector<MBEntityHandle> to_vector(from_range.size());
- MBErrorCode result =
- get_remote_handles(store_remote_handles, from_range, &to_vector[0],
- to_proc, new_ents);
- RRA("Trouble getting remote handles.");
- std::copy(to_vector.begin(), to_vector.end(), mb_range_inserter(to_range));
- return result;
-MBErrorCode MBParallelComm::get_remote_handles(const bool store_remote_handles,
- const MBRange &from_range,
MBEntityHandle *to_vec,
int to_proc,
@@ -1055,15 +1044,15 @@
for (rit = from_range.begin(), i = 0; rit != from_range.end(); rit++, i++) {
if (!to_vec[i]) {
result = mbImpl->tag_get_data(sharedhs_tag, &(*rit), 1, tmp_handles);
- RRA("Trouble getting sharedhs tag.");
- result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1, tmp_procs);
- RRA("Trouble getting sharedps tag.");
- for (int j = 0; j < MAX_SHARING_PROCS; j++)
- if (tmp_procs[j] == to_proc) {
- to_vec[i] = tmp_handles[j];
- break;
+ if (MB_SUCCESS == result) {
+ result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1, tmp_procs);
+ RRA("Trouble getting sharedps tag.");
+ for (int j = 0; j < MAX_SHARING_PROCS; j++)
+ if (tmp_procs[j] == to_proc) {
+ to_vec[i] = tmp_handles[j];
+ break;
if (!to_vec[i]) {
int j = new_ents.index(*rit);
if (-1 == j) {
@@ -1084,6 +1073,22 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_remote_handles(const bool store_remote_handles,
+ const MBRange &from_range,
+ MBRange &to_range,
+ int to_proc,
+ const MBRange &new_ents)
+ std::vector<MBEntityHandle> to_vector(from_range.size());
+ MBErrorCode result =
+ get_remote_handles(store_remote_handles, from_range, &to_vector[0],
+ to_proc, new_ents);
+ RRA("Trouble getting remote handles.");
+ std::copy(to_vector.begin(), to_vector.end(), mb_range_inserter(to_range));
+ return result;
MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
MBRange &entities,
@@ -1246,8 +1251,7 @@
else {
&remote_procs[0]);
- RRA("Couldn't get sharedps tag.");
- if (-1 != remote_procs[0]) {
&remote_handles[0]);
RRA("Couldn't get sharedhs tag.");
@@ -1329,8 +1333,7 @@
else {
result = mbImpl->tag_get_data(sharedps_tag, &local_ents[rit], 1,
&remote_procs[0]);
result = mbImpl->tag_get_data(sharedhs_tag, &local_ents[rit], 1,
@@ -1839,7 +1842,15 @@
result = get_remote_handles(store_remote_handles,
(*tr_it), (MBEntityHandle*)buff_ptr, to_proc,
whole_range);
- RR("Trouble getting remote handles for tagged entities.");
+#ifdef DEBUG_PACKING
+ if (MB_SUCCESS != result) {
+ std::cerr << "Trouble getting remote handles for tagged entities:" << std::endl;
+ (*tr_it).print(" ");
+#else
+ RRA("Trouble getting remote handles for tagged entities.");
+#endif
buff_ptr += (*tr_it).size() * sizeof(MBEntityHandle);
const size_t num_ent = tr_it->size();
@@ -1848,16 +1859,16 @@
var_len_values.resize( num_ent, 0 );
result = mbImpl->tag_get_data(*tag_it, *tr_it, &var_len_values[0],
&var_len_sizes[0] );
- RR("Failed to get variable-length tag data in pack_tags.");
+ RRA("Failed to get variable-length tag data in pack_tags.");
PACK_INTS(buff_ptr, &var_len_sizes[0], num_ent);
for (unsigned int i = 0; i < num_ent; ++i)
PACK_VOID(buff_ptr, var_len_values[i], var_len_sizes[i]);
else {
result = mbImpl->tag_get_data(*tag_it, *tr_it, buff_ptr);
- RR("Failed to get tag data in pack_tags.");
+ RRA("Failed to get tag data in pack_tags.");
buff_ptr += num_ent * tinfo->get_size();
- UPC(num_ent*tinfo->get_size(), " void");
+ PC(num_ent*tinfo->get_size(), " void");
tr_it++;
@@ -1936,8 +1947,8 @@
if (tag_size != tag_info->get_size() ||
tag_type != this_type ||
tag_data_type != tag_info->get_data_type() ||
- (def_val_ptr && !tag_info->default_value() ||
- !def_val_ptr && tag_info->default_value())) {
+ (def_val_ptr && !tag_info->default_value()) ||
+ (!def_val_ptr && tag_info->default_value())) {
RR("Didn't get correct tag info when unpacking tag.");
@@ -2827,8 +2838,8 @@
// pack-send; this also posts receives if store_remote_handles is true
- result = pack_send_entities(*vit, bridge_ents, true, true, store_remote_handles,
- ownerSBuffs[ind], ownerRBuffs[ind],
+ result = pack_send_entities(*vit, bridge_ents, false, true, store_remote_handles,
+ ownerSBuffs[ind], ownerRBuffs[MAX_SHARING_PROCS+ind],
sendReqs[ind], recv_reqs[MAX_SHARING_PROCS+ind],
sent_ents[ind]);
RRA("Failed to pack-send in ghost exchange.");
@@ -2845,7 +2856,12 @@
success = MPI_Waitany(2*MAX_SHARING_PROCS, &recv_reqs[0], &ind, &status);
if (MPI_SUCCESS != success) {
result = MB_FAILURE;
- RRA("Failed in waitany in ghost exchange.");
+ if (MPI_ERR_REQUEST == success) {
+ RRA("Failed in waitany in ghost exchange: MPI_ERR_REQUEST.");
+ else if (MPI_ERR_ARG == success) {
+ RRA("Failed in waitany in ghost exchange: MPI_ERR_ARG.");
// ok, received something; decrement incoming counter
@@ -2869,7 +2885,7 @@
break;
case MB_MESG_ENTS:
// incoming ghost entities; process
- result = recv_unpack_entities(*vit, store_remote_handles,
+ result = recv_unpack_entities(buffProcs[ind], store_remote_handles,
ghostRBuffs[ind], ghostSBuffs[ind],
sendReqs[ind], recd_ents[ind]);
RRA("Failed to recv-unpack message.");
@@ -2877,8 +2893,9 @@
case MB_MESG_REMOTE_HANDLES:
// incoming remote handles; use to set remote handles
buff_ptr = &ownerRBuffs[ind][0];
+ assert(ind >= MAX_SHARING_PROCS);
UNPACK_RANGE(buff_ptr, remote_range);
- result = set_remote_data(sent_ents[ind], remote_range, *vit);
+ result = set_remote_data(sent_ents[ind-MAX_SHARING_PROCS], remote_range, *vit);
RRA("Trouble setting remote data range on sent entities in ghost exchange.");
break;
