[MOAB-dev] r1780 - MOAB/trunk/tools/iMesh
tautges at mcs.anl.gov
Mon Apr 28 12:20:05 CDT 2008
Author: tautges
Date: 2008-04-28 12:20:04 -0500 (Mon, 28 Apr 2008)
New Revision: 1780
Added:
MOAB/trunk/tools/iMesh/iMesh_extensions.h
MOAB/trunk/tools/iMesh/iMesh_extensions_protos.h
Removed:
MOAB/trunk/tools/iMesh/iBase_FCDefs.h.in
Modified:
MOAB/trunk/tools/iMesh/Makefile.am
Log:
Forgot to add these and change the Makefile.am to include in distro.
Modified: MOAB/trunk/tools/iMesh/Makefile.am
--- MOAB/trunk/tools/iMesh/Makefile.am 2008-04-28 16:35:24 UTC (rev 1779)
+++ MOAB/trunk/tools/iMesh/Makefile.am 2008-04-28 17:20:04 UTC (rev 1780)
@@ -29,6 +29,8 @@
iMesh_MOAB.cpp
libiMesh_la_include_HEADERS = iMesh.h \
+ iMesh_extensions.h \
+ iMesh_extensions_protos.h \
iMesh_f.h \
iMesh_protos.h \
iBase.h \
Deleted: MOAB/trunk/tools/iMesh/iBase_FCDefs.h.in
--- MOAB/trunk/tools/iMesh/iBase_FCDefs.h.in 2008-04-28 16:35:24 UTC (rev 1779)
+++ MOAB/trunk/tools/iMesh/iBase_FCDefs.h.in 2008-04-28 17:20:04 UTC (rev 1780)
@@ -1,7 +0,0 @@
-/* Define to a macro mangling the given C identifier (in lower and upper
- case), which must not contain underscores, for linking with Fortran. */
-#undef FC_FUNC
-/* As FC_FUNC, but for C identifiers containing underscores. */
-#undef FC_FUNC_
Added: MOAB/trunk/tools/iMesh/iMesh_extensions.h
--- MOAB/trunk/tools/iMesh/iMesh_extensions.h (rev 0)
+++ MOAB/trunk/tools/iMesh/iMesh_extensions.h 2008-04-28 17:20:04 UTC (rev 1780)
@@ -0,0 +1,165 @@
+#ifndef IMESH_REC_CBIND_H__
+#define IMESH_REC_CBIND_H__
+#include "iMesh.h"
+#include "iMesh_extensions_protos.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+ /**\brief Get entities of specific type and/or topology in set or instance, recursive
+ * Get entities of specific type and/or topology in set or instance. If recursive
+ * is passed in non-zero, includes entities in owned sets. All
+ * entities of a given type or topology are requested by specifying
+ * iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively. Specified type
+ * or topology must be a value in the iBase_EntityType or iMesh_EntityTopology
+ * enumeration, respectively.
+ * \param instance iMesh instance handle
+ * \param entity_set_handle Entity set being queried
+ * \param entity_type Type of entities being requested
+ * \param entity_topology Topology of entities being requested
+ * \param recursive If non-zero, gets entities in owned sets too
+ * \param *entity_handles Pointer to array of entity handles returned
+ * from function
+ * \param *entity_handles_allocated Pointer to allocated size of
+ * entity_handles array
+ * \param *entity_handles_size Pointer to occupied size of entity_handles array
+ * \param *err Pointer to error type returned from function
+ void iMesh_getEntitiesRec(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_handle,
+ /*in*/ const int entity_type,
+ /*in*/ const int entity_topology,
+ /*in*/ const int recursive,
+ /*out*/ iBase_EntityHandle** entity_handles,
+ /*out*/ int* entity_handles_allocated,
+ /*out*/ int* entity_handles_size,
+ /*out*/ int *err);
+ /**\brief Get the number of entities with the specified type in the instance or set, recursive
+ * Get the number of entities with the specified type in the instance
+ * or set. If recursive is passed in non-zero, includes entities in owned sets.
+ * If entity set handle is zero, return information for instance,
+ * otherwise for set. Value of entity type must be from the
+ * iBase_EntityType enumeration. If iBase_ALL_TYPES is specified,
+ * total number of entities (excluding entity sets) is returned.
+ * \param entity_type Type of entity requested
+ * \param recursive If non-zero, includes entities in owned sets too
+ * \param num_type Pointer to number of entities, returned from function
+ void iMesh_getNumOfTypeRec(iMesh_Instance instance,
+ /*out*/ int *num_type,
+ /**\brief Get the number of entities with the specified topology in the instance or set
+ * Get the number of entities with the specified topology in the instance
+ * otherwise for set. Value of entity topology must be from the
+ * iMesh_EntityTopology enumeration. If iMesh_ALL_TOPOLOGIES is specified,
+ * \param entity_topology Topology of entity requested
+ * \param num_topo Pointer to number of entities, returned from function
+ void iMesh_getNumOfTopoRec(iMesh_Instance instance,
+ /*out*/ int *num_topo,
+ /**\brief Get entities with specified type, topology, tag(s) and (optionally) tag value(s)
+ * Get entities with the specified type, topology, tag(s), and optionally tag value(s).
+ * If tag values pointer is input as zero, entities with specified tag(s) are returned,
+ * regardless of their value.
+ * \param tag_handles Array of tag handles
+ * \param tag_vals Array of tag values (zero if values not requested)
+ * \param num_tags_vals Number of tags and optionally values
+ * from function
+ void iMesh_getEntsByTagsRec(iMesh_Instance instance,
+ /*in*/ const iBase_TagHandle *tag_handles,
+ /*in*/ const char * const *tag_vals,
+ /*in*/ const int num_tags_vals,
+ /**\brief Get entity sets with specified type, topology, tag(s) and (optionally) tag value(s)
+ * Get entity sets with the specified type, topology, tag(s), and optionally tag value(s).
+ * \param *set_handles Pointer to array of entity handles returned
+ * from function
+ * \param *set_handles_allocated Pointer to allocated size of
+ * set_handles array
+ * \param *set_handles_size Pointer to occupied size of entity_handles array
+ void iMesh_getEntSetsByTagsRec(iMesh_Instance instance,
+ /*out*/ iBase_EntityHandle** set_handles,
+ /*out*/ int* set_handles_allocated,
+ /*out*/ int* set_handles_size,
+ /**\brief Get MBCN type corresponding to iMesh topology value
+ * Get MBCN type corresponding to iMesh topology value. Required for input
+ * to MBCN canonical numbering functions, which are written in terms of
+ * MBCN entity types. Returns -1 for type if entity topology is out of
+ * bounds, or MBMAXTYPE if no corresponding MBCN type exists.
+ * \param imesh_entity_topology iMesh_EntityTopology value
+ * \param mbcn_type MBEntityType corresponding to entity topology
+ void iMesh_MBCNType(/*in*/ const int imesh_entity_topology,
+ /*out*/ int *mbcn_type);
+#ifdef __cplusplus
+#endif
+#endif
Added: MOAB/trunk/tools/iMesh/iMesh_extensions_protos.h
--- MOAB/trunk/tools/iMesh/iMesh_extensions_protos.h (rev 0)
+++ MOAB/trunk/tools/iMesh/iMesh_extensions_protos.h 2008-04-28 17:20:04 UTC (rev 1780)
@@ -0,0 +1,11 @@
+#include "MBCN_FCDefs.h"
+#ifdef FC_FUNC_
+#define iMesh_getEntitiesRec FC_FUNC_(imesh_getentitiesrec, IMESH_GETENTITIESREC)
+#define iMesh_getNumOfTypeRec FC_FUNC_(imesh_getnumoftyperec, IMESH_GETNUMOFTYPEREC)
+#define iMesh_getNumOfTopoRec FC_FUNC_(imesh_getnumoftoporec, IMESH_GETNUMOFTOPOREC)
+#define iMesh_getEntsByTagsRec FC_FUNC_(imesh_getentsbytagsrec, IMESH_GETENTSBYTAGSREC)
+#define iMesh_getEntSetsByTagsRec FC_FUNC_(imesh_getentsetsbytagsrec, IMESH_GETENTSETSBYTAGSREC)
+#define iMesh_MBCNType FC_FUNC_(imesh_mbcntype, IMESH_MBCNTYPE)
+#endif
