[MOAB-dev] r1776 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Apr 24 13:08:03 CDT 2008
Author: kraftche
Date: 2008-04-24 13:08:03 -0500 (Thu, 24 Apr 2008)
New Revision: 1776
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
Log:
kD-tree improvements:
o Avoid calls to box-element-overlap test when possible:  If the element is
  contained in the parent node then it must be in at least one leaf node.
  So if the element is entirely to one side of the split plane, then said
  leaf node is identified without needing the overlap test.  Reduces tree
  construction time for sphere of triangles by 38%.
o Fix bug in vertex-median consturction algorithm.
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2008-04-23 16:34:37 UTC (rev 1775)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2008-04-24 18:08:03 UTC (rev 1776)
@@ -727,28 +727,41 @@
     rval = moab->get_coords( &conn[0], count, coords[0].array() );
     if (MB_SUCCESS != rval) return rval;
-    bool lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen, left_dim );
-    bool ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,right_dim );
+    bool lo = false, ro = false;
+    for (int j = 0; j < count; ++j) {
+      if (coords[j][plane.norm] <= plane.coord)
+        lo = true;
+      if (coords[j][plane.norm] >= plane.coord)
+        ro = true;
-      // didn't intersect either - tolerance issue
-    while (!lo && !ro) {
-        // calculate a good tolerance
-      MBCartVect dim = box_max - box_min;
-      double max_dim;
-      if (dim[0] > dim[1] && dim[1] > dim[2])
-        max_dim = dim[0];
-      else if (dim[1] > dim[2])
-        max_dim = dim[1];
-      else
-        max_dim = dim[2];
-        // loop with increasing tolerance until we intersect something
-      double tol = std::numeric_limits<double>::epsilon();
+      // Triangle must be in at least one leaf.  If test against plain
+      // identified that leaf, then we're done.  If triangle is on both
+      // sides of plane, do more precise test to ensure that it is really
+      // in both.
+    if (lo && ro) {
+      lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen, left_dim );
+      ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,right_dim );
+        // didn't intersect either - tolerance issue
-        lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen,tol*max_dim+ left_dim );
-        ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,tol*max_dim+right_dim );
-        tol *= 10.0;
-        if (tol > 1e-3)
-          return MB_FAILURE;
+          // calculate a good tolerance
+        MBCartVect dim = box_max - box_min;
+        double max_dim;
+        if (dim[0] > dim[1] && dim[1] > dim[2])
+          max_dim = dim[0];
+        else if (dim[1] > dim[2])
+          max_dim = dim[1];
+        else
+          max_dim = dim[2];
+          // loop with increasing tolerance until we intersect something
+        double tol = std::numeric_limits<double>::epsilon();
+        while (!lo && !ro) {
+          lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen,tol*max_dim+ left_dim );
+          ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,tol*max_dim+right_dim );
+          tol *= 10.0;
+          if (tol > 1e-3)
+            return MB_FAILURE;
     if (lo && ro)
@@ -936,14 +949,15 @@
     citer = std::upper_bound( coords.begin(), coords.end(), box_min[axis] + eps );
     const size_t count = std::upper_bound( citer, coords.end(), box_max[axis] - eps ) - citer;
     size_t step;
-    if ((int)count < 2*num_planes) {
-      step = 1; num_planes = count - 1;
+    int np = num_planes;
+    if (count < 2*(size_t)num_planes) {
+      step = 1; np = count - 1;
     else {
       step = count / (num_planes + 1);
-    for (int p = 1; p <= num_planes; ++p) {
+    for (int p = 1; p <= np; ++p) {
       citer += step;
       MBAdaptiveKDTree::Plane plane = { *citer, axis };
@@ -1529,6 +1543,7 @@
       // We should now be at a leaf.
       // If it has some triangles, we're done.
       // If not, continue searching for another leaf.
+    tris.clear();
     rval = moab()->get_entities_by_type( node, MBTRI, tris );
     if (!tris.empty()) {
       double dist_sqr = HUGE_VAL;
