[MOAB-dev] r1774 - MOAB/trunk/tools/converter
Mark Miller
miller86 at llnl.gov
Wed Apr 23 10:19:33 CDT 2008
Hi Jason,
I don't think my MOAB trunk is pointing to the right
place. I don't see any of your recent updates appearing
in an svn status. Here is some info...
Subversion is a tool for version control.
For additional information, see http://subversion.tigris.org/
alderaan [~/itaps/MOAB_trunk/trunk] 1228% svn info
Path: .
URL: https://svn.mcs.anl.gov/repos/ITAPS/MOAB/trunk
Repository Root: https://svn.mcs.anl.gov/repos/ITAPS
Repository UUID: 6162379e-bd28-0410-9a7d-b7f4dcfcad3c
Revision: 1672
Node Kind: directory
Schedule: normal
Last Changed Author: kraftche
Last Changed Rev: 1672
Last Changed Date: 2008-03-18 08:43:32 -0700 (Tue, 18 Mar 2008)
Properties Last Updated: 2007-12-06 10:45:12 -0800 (Thu, 06 Dec 2007)
alderaan [~/itaps/MOAB_trunk/trunk] 1229% svn info tools/converter/convert.cpp
Path: tools/converter/convert.cpp
URL: https://svn.mcs.anl.gov/repos/ITAPS/MOAB/trunk/tools/converter/convert.cpp
Revision: 1672
Node Kind: file
Schedule: normal
Last Changed Author: tautges
Last Changed Rev: 1277
Last Changed Date: 2007-09-14 11:12:09 -0700 (Fri, 14 Sep 2007)
Text Last Updated: 2007-12-06 10:45:03 -0800 (Thu, 06 Dec 2007)
Properties Last Updated: 2007-12-06 10:45:03 -0800 (Thu, 06 Dec 2007)
Checksum: a9acbf0bedc79f53616585b1c4a6d100
kraftche at mcs.anl.gov wrote:
> Author: kraftche
> Date: 2008-04-23 09:15:53 -0500 (Wed, 23 Apr 2008)
> New Revision: 1774
> Modified:
> Log:
> Option to dump ACIS geometry needs to be passed to *reader*, not writer
> Modified: MOAB/trunk/tools/converter/convert.cpp
> --- MOAB/trunk/tools/converter/convert.cpp 2008-04-22 19:30:00 UTC (rev 1773)
> +++ MOAB/trunk/tools/converter/convert.cpp 2008-04-23 14:15:53 UTC (rev 1774)
> @@ -209,7 +209,7 @@
> switch ( argv[i-1][1] )
> case 'a':
> - write_opts.push_back( std::string("SAT_FILE=") + argv[i] );
> + read_opts.push_back( std::string("SAT_FILE=") + argv[i] );
> pval = true;
> break;
> case 'f': format = argv[i]; pval = true; break;
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
