[MOAB-dev] r1759 - MOAB/trunk
kraftche at mcs.anl.gov
Fri Apr 11 14:41:37 CDT 2008
Author: kraftche
Date: 2008-04-11 14:41:37 -0500 (Fri, 11 Apr 2008)
New Revision: 1759
Modified:
MOAB/trunk/ReadVtk.cpp
MOAB/trunk/WriteVtk.cpp
MOAB/trunk/WriteVtk.hpp
Log:
Fix handling of multivalue-tags in VTK files:
- be more permissive in reader: we are capable of reading any number of values
per entity for a scalar attribute, even though the spec says it should be
no more than 4.
- be more restritive in writer: by default, don't write tags that have the
number of values per entity something other than 1,2,3,4,or 9. Any such
tag does not map to a valid VTK attribute type.
- add option "STRICT" corresponding to the above default writer behavior
- add option "RELAXED" for which the writer will write tags with more than
4 values per entity as scalar data attributes even though the spec says
no more than 4. This is the previous MOAB behavior and will read successfully
into both MOAB and VTK5.
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp 2008-04-11 19:34:29 UTC (rev 1758)
+++ MOAB/trunk/ReadVtk.cpp 2008-04-11 19:41:37 UTC (rev 1759)
@@ -1005,7 +1005,7 @@
// VTK spec says cannot be greater than 4--do we care?
- if (size < 1 || size > 4)
+ if (size < 1) //|| size > 4)
readMeshIface->report_error(
"Scalar count out of range [1,4]"
Modified: MOAB/trunk/WriteVtk.cpp
--- MOAB/trunk/WriteVtk.cpp 2008-04-11 19:34:29 UTC (rev 1758)
+++ MOAB/trunk/WriteVtk.cpp 2008-04-11 19:41:37 UTC (rev 1759)
@@ -46,12 +46,13 @@
sprintf(stringvar, prefix, id)
const int DEFAULT_PRECISION = 10;
+const bool DEFAULT_STRICT = true;
MBWriterIface *WriteVtk::factory( MBInterface* iface )
{ return new WriteVtk( iface ); }
WriteVtk::WriteVtk(MBInterface *impl)
- : mbImpl(impl), writeTool(0), globalId(0)
+ : mbImpl(impl), writeTool(0), globalId(0), mStrict(DEFAULT_STRICT)
assert(impl != NULL);
@@ -86,6 +87,13 @@
if (MB_SUCCESS != opts.get_int_option( "PRECISION", precision ))
precision = DEFAULT_PRECISION;
+ if (MB_SUCCESS == opts.get_null_option( "STRICT" ))
+ mStrict = true;
+ else if (MB_SUCCESS == opts.get_null_option( "RELAXED" ))
+ mStrict = false;
+ else
+ mStrict = DEFAULT_STRICT;
// Get entities to write
MBRange nodes, elems;
rval = gather_mesh( output_list, num_sets, nodes, elems );
@@ -374,6 +382,29 @@
if (MB_VARIABLE_DATA_LENGTH == mbImpl->tag_get_size( *i, size ))
continue;
+ // If in strict mode, don't write tags that do not fit in any
+ // attribute type (SCALAR : 1 to 4 values, VECTOR : 3 values, TENSOR : 9 values)
+ if (mStrict) {
+ int count = 0;
+ switch (type) {
+ case MB_TYPE_INTEGER:
+ count = size/sizeof(int);
+ break;
+ case MB_TYPE_DOUBLE:
+ count = size/sizeof(double);
+ break;
+ case MB_TYPE_BIT:
+ case MB_TYPE_OPAQUE:
+ count = size;
+ break;
+ default:
+ return MB_TYPE_OUT_OF_RANGE;
+ if (count < 1 || (count > 4 && count != 9))
+ continue;
// Get subset of input entities that have the tag set
MBRange tagged;
for (MBEntityType type = low_type; type < high_type; ++type)
Modified: MOAB/trunk/WriteVtk.hpp
--- MOAB/trunk/WriteVtk.hpp 2008-04-11 19:34:29 UTC (rev 1758)
+++ MOAB/trunk/WriteVtk.hpp 2008-04-11 19:41:37 UTC (rev 1759)
@@ -84,6 +84,9 @@
MBInterface* mbImpl;
MBWriteUtilIface* writeTool;
MBTag globalId;
+ bool mStrict; // If true, do not write data that cannot fit in strict VTK file format.
#endif
