[MOAB-dev] r1749 - in MOAB/branches/ghosting: . parallel
tautges at mcs.anl.gov
Mon Apr 7 22:48:29 CDT 2008
Author: tautges
Date: 2008-04-07 22:48:29 -0500 (Mon, 07 Apr 2008)
New Revision: 1749
Modified:
MOAB/branches/ghosting/mbparallelcomm_test.cpp
MOAB/branches/ghosting/parallel/MBParallelComm.cpp
MOAB/branches/ghosting/parallel/WriteHDF5Parallel.cpp
Log:
- better testing of pack_buffer in mbparallelcomm_test (packing all file set ents, not just 3d ones)
- more debug messages for packing/unpacking
- fixed count += error in pack_tags
- removed compile warnings from WriteHDF5Parallel.cpp
Modified: MOAB/branches/ghosting/mbparallelcomm_test.cpp
--- MOAB/branches/ghosting/mbparallelcomm_test.cpp 2008-04-07 21:25:17 UTC (rev 1748)
+++ MOAB/branches/ghosting/mbparallelcomm_test.cpp 2008-04-08 03:48:29 UTC (rev 1749)
@@ -162,7 +162,7 @@
PRINT_LAST_ERROR
break;
default:
std::cerr << "Unrecognized option \"" << this_opt
<< "\"; skipping." << std::endl;
@@ -712,9 +712,11 @@
// get 3d entities and pack a buffer with them
MBRange ents, new_ents, whole_range;
- result = mbImpl->get_entities_by_dimension(0, 3, ents);
+ result = mbImpl->get_entities_by_handle(file_set, ents);
RRA("Getting 3d ents failed.");
+ ents.insert(file_set);
MBParallelComm *pcomm = new MBParallelComm(mbImpl);
std::vector<unsigned char> buff(1024);
int buff_size;
Modified: MOAB/branches/ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/ghosting/parallel/MBParallelComm.cpp 2008-04-07 21:25:17 UTC (rev 1748)
+++ MOAB/branches/ghosting/parallel/MBParallelComm.cpp 2008-04-08 03:48:29 UTC (rev 1749)
@@ -577,6 +577,7 @@
assert(0 <= buff_size);
buff.resize(buff_size);
+ int orig_buff_size = buff_size;
buff_size = 0;
buff_ptr = &buff[0];
@@ -585,12 +586,20 @@
buff_size, false, store_remote_handles, to_proc,
ent_types, all_ranges, verts_per_entity);
RRA("Packing entities (count) failed.");
+#ifdef DEBUG_PACKING
+ std::cerr << "pack_entities buffer space: " << buff_ptr - &buff[0] << " bytes." << std::endl;
+ unsigned char *tmp_buff = buff_ptr;
+#endif
// sets
result = pack_sets(orig_ents, rit, final_ents, buff_ptr, buff_size, false,
store_remote_handles, to_proc, set_range, set_ranges,
set_sizes, options_vec);
RRA("Packing sets (count) failed.");
+ std::cerr << "pack_sets buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
+ tmp_buff = buff_ptr;
+#endif
// adjacencies
if (adjacencies) {
@@ -606,8 +615,19 @@
buff_size, false, store_remote_handles, to_proc, all_tags,
tag_ranges);
RRA("Packing tags (count) failed.");
+ std::cerr << "pack_tags buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
+#endif
+ // original buffer size might be larger, because some
+ // ranges of local handles pack into more compact ranges of
+ // remote handles (because they're expressed using MBMAXTYPE plus
+ // index in new entity range, and that list of entities is likely
+ // to be compact)
+ assert(orig_buff_size >= buff_size);
return result;
@@ -618,16 +638,31 @@
if (myBuffer.capacity() == 0) return MB_FAILURE;
+#endif
MBErrorCode result = unpack_entities(buff_ptr, final_ents,
from_proc);
RRA("Unpacking entities failed.");
+ std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
+#endif
result = unpack_sets(buff_ptr, final_ents, store_remote_handles,
from_proc);
RRA("Unpacking sets failed.");
+ std::cerr << "unpack_sets buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
+#endif
result = unpack_tags(buff_ptr, final_ents, store_remote_handles,
from_proc);
RRA("Unpacking tags failed.");
+ std::cerr << "unpack_tags buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
+#endif
std::cerr << std::endl;
@@ -1394,8 +1429,7 @@
MBErrorCode result;
if (just_count) {
- // num of sets
- count += sizeof(int);
+ int ranges_size = 0, vecs_size = 0, tot_parch = 0;
for (; start_rit != entities.end(); start_rit++) {
set_range.insert(*start_rit);
@@ -1405,9 +1439,6 @@
RR("Failed to get meshset options.");
options_vec.push_back(options);
- // option
- count += sizeof(unsigned int);
if (options & MESHSET_SET) {
// range-based set; count the subranges
set_ranges.push_back(MBRange());
@@ -1415,7 +1446,8 @@
RRA("Failed to get set entities.");
// set range
- count += 2 * sizeof(MBEntityHandle) * num_subranges(*set_ranges.rbegin()) + sizeof(int);
+ ranges_size += 2 * sizeof(MBEntityHandle) * num_subranges(*set_ranges.rbegin()) +
+ sizeof(int);
else if (options & MESHSET_ORDERED) {
// just get the number of entities in the set
@@ -1425,7 +1457,7 @@
set_sizes.push_back(num_ents);
// set vec
- count += sizeof(MBEntityHandle) * num_ents + sizeof(int);
+ vecs_size += sizeof(MBEntityHandle) * num_ents + sizeof(int);
// get numbers of parents/children
@@ -1436,12 +1468,24 @@
result = mbImpl->num_parent_meshsets(*start_rit, &num_par);
RR("Failed to get num parents.");
- // set children, parents
- count += 2*sizeof(int) + (num_par + num_ch) * sizeof(MBEntityHandle);
+ tot_parch += num_ch + num_par;
+ // num of sets
+ count += sizeof(int);
+ // options
+ count += set_range.size() * sizeof(unsigned int);
+ // range, vector sizes
+ count += ranges_size + vecs_size;
+ // set children, parents
+ count += 2 * set_range.size() * sizeof(int) + tot_parch * sizeof(MBEntityHandle);
// set handles
- if (!set_range.empty())
+ if (!set_range.empty() && store_remote_handles)
count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(set_range);
whole_range.merge(set_range);
@@ -1639,7 +1683,7 @@
result = mbImpl->add_child_meshset(*rit, mem_ptr[i]);
RRA("Failed to add child to set in unpack.");
- mem_ptr += num_par;
+ mem_ptr += num_child;
@@ -1818,7 +1862,7 @@
tr_it++;
- count = buff_ptr - orig_buff_ptr;
+ count += buff_ptr - orig_buff_ptr;
if (debug_packing) std::cerr << std::endl << "Done packing tags." << std::endl;
Modified: MOAB/branches/ghosting/parallel/WriteHDF5Parallel.cpp
--- MOAB/branches/ghosting/parallel/WriteHDF5Parallel.cpp 2008-04-07 21:25:17 UTC (rev 1748)
+++ MOAB/branches/ghosting/parallel/WriteHDF5Parallel.cpp 2008-04-08 03:48:29 UTC (rev 1749)
@@ -1765,9 +1765,6 @@
MBErrorCode WriteHDF5Parallel::fix_remote_set_ids( RemoteSetData& data, long first_id )
const id_t id_diff = (id_t)(first_id - 1);
- id_t file_id;
- MBErrorCode rval;
MBRange::const_iterator i;
std::vector<id_t> ids(data.range.size());
std::vector<id_t>::iterator j = ids.begin();
