[MOAB-dev] r1742 - MOAB/trunk
kraftche at mcs.anl.gov
Fri Apr 4 10:05:29 CDT 2008
Author: kraftche
Date: 2008-04-04 10:05:29 -0500 (Fri, 04 Apr 2008)
New Revision: 1742
Modified:
MOAB/trunk/WriteHDF5.cpp
Log:
fix bug I checked in yesterday (broke writing fixed-length handle tags when I fixed variable-length) and eliminate compiler warning
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-04-03 20:29:19 UTC (rev 1741)
+++ MOAB/trunk/WriteHDF5.cpp 2008-04-04 15:05:29 UTC (rev 1742)
@@ -1652,6 +1652,8 @@
return MB_FAILURE;
if (mb_size != MB_VARIABLE_LENGTH)
return MB_FAILURE;
+ if (mb_data_type == MB_TYPE_HANDLE && hdf_type == 0)
+ hdf_type = id_type;
DEBUGOUT((std::string("Var Len Tag: ") + name + "\n").c_str());
@@ -1760,7 +1762,7 @@
CHK_MHDF_ERR_2(status, tables + 1);
offset_offset += count;
- assert( offset_offset == tag_data.offset + tag_data.range.size() );
+ assert( (unsigned long)offset_offset == tag_data.offset + tag_data.range.size() );
// flush data buffer
if (bytes) {
@@ -2306,7 +2308,6 @@
case MB_TYPE_HANDLE:
elem_size = sizeof(MBEntityHandle);
file_type = mhdf_ENTITY_ID;
- hdf_type = id_type;
break;
case MB_TYPE_OPAQUE:
default:
