[MOAB-dev] MOAB check for *AMD64-32* failed.
Nightly Test kraftche at cae.wisc.edu
Fri Apr 4 01:27:23 CDT 2008
HDF5-DIAG: Error detected in HDF5 library version: 1.6.5 thread 68532368.  Back trace follows.
  #000: ../../../src/H5D.c line 1146 in H5Dopen(): not found
    major(15): Dataset interface
    minor(48): Object not found
  #001: ../../../src/H5G.c line 2296 in H5G_find(): object not found
    major(10): Symbol table layer
  #002: ../../../src/H5G.c line 1495 in H5G_namei(): component not found
  #003: ../../../src/H5Gstab.c line 164 in H5G_stab_find(): not found
  #004: ../../../src/H5Gnode.c line 975 in H5G_node_found(): not found
creating... writing... HDF5-DIAG: Error detected in HDF5 library version: 1.6.5 thread 68532368.  Back trace follows.
  #000: ../../../src/H5Dio.c line 587 in H5Dwrite(): can't write data
    minor(25): Write failed
  #001: ../../../src/H5Dio.c line 941 in H5D_write(): unable to convert between src and dest data types
    minor(02): Feature is unsupported
  #002: ../../../src/H5T.c line 4199 in H5T_path_find(): no appropriate function for conversion path
    major(13): Datatype interface
    minor(29): Unable to initialize object
Failed to write "h5test.h5m"
Internal error calling H5Dwrite.
make[3]: *** [check-TESTS] Error 1
make[2]: *** [check-am] Error 2
make[1]: *** [check-recursive] Error 1
make: *** [check-recursive] Error 1
g for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... c++ -E
checking for g77... g77
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g77 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for g77 option to produce PIC... -fPIC
checking if g77 PIC flag -fPIC works... yes
checking if g77 static flag -static works... yes
checking if g77 supports -c -o file.o... yes
checking whether the g77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for gunzip... gunzip -c
checking for gzip... (cached) gunzip -c
checking for zcat... (cached) gunzip -c
checking if C++ compiler supports template specialization... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for sys/types.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for uint32_t... yes
checking for size_t... yes
checking for ptrdiff_t... yes
checking for deflate in -lz... yes
checking for SZ_Decompress in -lsz... no
checking if HDF5 support is enabled... yes
checking hdf5.h usability... yes
checking hdf5.h presence... yes
checking for hdf5.h... yes
checking for H5Fopen in -lhdf5... yes
checking if NetCDF support is enabled... yes
checking strstream.h usability... no
checking strstream.h presence... no
checking for strstream.h... no
checking sstream.h usability... no
checking sstream.h presence... no
checking for sstream.h... no
checking strstream usability... yes
checking strstream presence... yes
checking for strstream... yes
checking netcdf.h usability... yes
checking netcdf.h presence... yes
checking for netcdf.h... yes
checking for netcdf.hh... yes
checking for netcdf_c++ library... yes
checking if mbconvert is to be built... yes
checking if hexmodops is to be built... yes
checking if mbchaco is to be built... no
checking if mbperf is to be built... yes
checking if qvdual is to be built... no
checking if mbsize is to be built... yes
checking if mbskin is to be built... yes
checking if mbtagprop is to be built... yes
checking if spheredecomp is to be built... yes
checking if mbsurfplot is to be built... yes
checking if mbzoltan is to be built... no
checking if dagmc is to be built... yes
checking if iMesh support is to be built... no
configure: creating ./config.status
C:   cc  -g
C++: c++  -Wall -pipe -g
 /bin/sh ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating testdir.h
config.status: creating parallel/Makefile
config.status: creating mhdf/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating tools/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating MBVersion.h
config.status: MBVersion.h is unchanged
config.status: creating MBEntityHandle.h
config.status: MBEntityHandle.h is unchanged
config.status: creating tools/iMesh/iBase_FCDefs.h
config.status: tools/iMesh/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64-32'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/converter'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
Making all in size
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/size'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/size'
Making all in skin
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/skin'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/skin'
Making all in tagprop
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
Making all in spheredecomp
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
Making all in surfplot
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
Making all in dagmc
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../..     -Wall -pipe -g  -MT DagMC.lo -MD -MP -MF ".deps/DagMC.Tpo" -c -o DagMC.lo ../../../src/tools/dagmc/DagMC.cpp; \
	then mv -f ".deps/DagMC.Tpo" ".deps/DagMC.Plo"; else rm -f ".deps/DagMC.Tpo"; exit 1; fi
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../.. -Wall -pipe -g -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c ../../../src/tools/dagmc/DagMC.cpp -o DagMC.o
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -g    -o libdagmc.la -rpath /usr/local/lib  DagMC.lo   -lm
rm -fr  .libs/libdagmc.a .libs/libdagmc.la .libs/libdagmc.lai
ar cru .libs/libdagmc.a  DagMC.o
ranlib .libs/libdagmc.a
creating libdagmc.la
(cd .libs && rm -f libdagmc.la && ln -s ../libdagmc.la libdagmc.la)
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
Making all in doc
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doc'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doc'
Making all in doxygen
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doxygen'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doxygen'
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making check in .
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test internals_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test kd_tree_tool kd_tree_time
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I. -I. -I./tools/iMesh -I. -I../src/mhdf/include    -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g -MT tqdcfr-Tqdcfr.o -MD -MP -MF ".deps/tqdcfr-Tqdcfr.Tpo" -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo '../src/'`Tqdcfr.cpp; \
	then mv -f ".deps/tqdcfr-Tqdcfr.Tpo" ".deps/tqdcfr-Tqdcfr.Po"; else rm -f ".deps/tqdcfr-Tqdcfr.Tpo"; exit 1; fi
make[2]: `file_options_test' is up to date.
make[2]: `var_len_test' is up to date.
make[2]: `var_len_test_no_template' is up to date.
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I. -I. -I./tools/iMesh -I. -I../src/mhdf/include     -Wall -pipe -g -MT MBTest.o -MD -MP -MF ".deps/MBTest.Tpo" -c -o MBTest.o ../src/MBTest.cpp; \
	then mv -f ".deps/MBTest.Tpo" ".deps/MBTest.Po"; else rm -f ".deps/MBTest.Tpo"; exit 1; fi
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o homxform_test  homxform_test-HomXform.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o seq_man_test  TestTypeSequenceManager.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o internals_test  internals_test.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o geom_util_test  GeomUtilTests.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o scdseq_test  scdseq_test.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o tqdcfr  tqdcfr-Tqdcfr.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o test_adj  test_adj.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o seq_man_test TestTypeSequenceManager.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o internals_test internals_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o homxform_test homxform_test-HomXform.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o geom_util_test GeomUtilTests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o scdseq_test scdseq_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o test_adj test_adj.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o tqdcfr tqdcfr-Tqdcfr.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o xform_test  xform_test-MBAffineXform.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o xform_test xform_test-MBAffineXform.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o obb_test  OBBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o obb_test OBBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o vtk_test  VtkTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o vtk_test VtkTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o adaptive_kd_tree_tests  adaptive_kd_tree_tests.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o kd_tree_test  kd_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o kd_tree_test kd_tree_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o tag_test  TagTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o tag_test TagTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o kd_tree_tool  kd_tree_tool.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o mesh_set_test  Test_MBMeshSet.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o kd_tree_time  kd_tree_time.o ./libMOAB.la -lm
/bin/sh ./libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o moab_test  MBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o kd_tree_tool kd_tree_tool.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o mesh_set_test Test_MBMeshSet.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o kd_tree_time kd_tree_time.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -g -o moab_test MBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
MB TEST PROGRAM:
   mb_adjacent_vertex_test: Success
   mb_adjacencies_test: Success
   mb_vertex_coordinate_test: Success
   mb_vertex_tag_test: Success
   mb_bar_connectivity_test: Success
   mb_tri_connectivity_test: Success
   mb_quad_connectivity_test: Success
   mb_tet_connectivity_test: Success
   mb_temporary_test: Success
   mb_hex_connectivity_test: Success
   mb_mesh_sets_set_test: Success
   mb_mesh_sets_list_test: Success
   mb_mesh_set_parent_child_test: Success
   mb_tags_test: Success
   mb_dense_tag_test: Success
   mb_sparse_tag_test: Success
   mb_write_mesh_test: Success
   mb_delete_mesh_test: Success
   mb_meshset_tracking_test: Success
   mb_higher_order_test: Success
   mb_bit_tags_test: Success
   mb_entity_conversion_test: Success
   mb_forced_adjacencies_test: Success
   mb_canon_number_test: Success
   mb_poly_test: Success
   mb_range_test: Success
   mb_topo_util_test: Success
   mb_split_test: Success
   mb_range_seq_intersect_test: Success
   mb_proc_subset_test: Success
   mb_poly_adjacency_test: Success
   mb_memory_use_test: Success
   mb_merge_test: ---Starting Merge Tests---
---Testing:"test/cell1.gen"---
Loaded test/cell1.gen
---Testing:"test/cell2.gen"---
Loaded test/cell2.gen
num hexes = 28
fl = 68 rl = 0
nodes.size() = 72
---Success---
coin_nodes.size() = 13
TIME: 1196.79 seconds.
Success
   mb_stress_test:     Beginning Stress Test . . .
        Reading elements
        Read 256000 entities in 17.13 seconds
        at 14944.5 elements per second.
        Transforming and copying elements
        Transformed and created 256000 entities in 125.77 seconds
        Creating meshset
        Created meshset with 512000 entities in 0 seconds
        Writing 512K element file . . .
        Wrote file with 512000 entities in 238.4 seconds
        Total time: 381.31 seconds.
Success
MB TEST SUMMARY:
   Number Tests:           34
   Number Successful:      34
   Number Failed:          0
PASS: moab_test
All tests passed.
PASS: homxform_test
All tests passed.
PASS: scdseq_test
Usage: tqdcfr <cub_file_name>
Success.
Success.
PASS: tqdcfr
PASS: test_adj
Running test_basic ...
Running test_lower_bound ...
Running test_upper_bound ...
Running test_find ...
Running test_get_entities ...
Running test_insert_sequence_merge ...
Running test_insert_sequence_nomerge ...
Running test_remove_sequence ...
Running test_replace_subsequence ...
Running test_erase ...
Running test_find_free_handle ...
Running test_find_free_sequence ...
Running test_is_free_sequence ...
ALL TESTS PASSED
PASS: seq_man_test
3684 tests passed.
PASS: internals_test
PASS: geom_util_test
PASS: xform_test
PASS: obb_test
Testing edge2...
Testing edge3...
Testing tri3...
Testing tri6...
Testing quad4...
Testing quad8...
Testing polygon...
Testing tet4...
Testing tet10...
Testing hex8...
Testing hex20...
Testing wedge...
Testing pyramid...
Testing structured_points_2d...
Testing structured_grid_2d...
Testing rectilinear_grid_2d...
Testing structured_points_3d...
Testing structured_grid_3d...
Testing rectilinear_grid_3d...
Testing scalar_attrib_1_bit...
Testing scalar_attrib_1_uchar...
Testing scalar_attrib_1_char...
Testing scalar_attrib_1_ushort...
Testing scalar_attrib_1_short...
Testing scalar_attrib_1_uint...
Testing scalar_attrib_1_int...
Testing scalar_attrib_1_ulong...
Testing scalar_attrib_1_long...
Testing scalar_attrib_1_float...
Testing scalar_attrib_1_double...
Testing scalar_attrib_4_bit...
Testing scalar_attrib_4_uchar...
Testing scalar_attrib_4_char...
Testing scalar_attrib_4_ushort...
Testing scalar_attrib_4_short...
Testing scalar_attrib_4_uint...
Testing scalar_attrib_4_int...
Testing scalar_attrib_4_ulong...
Testing scalar_attrib_4_long...
Testing scalar_attrib_4_float...
Testing scalar_attrib_4_double...
Testing vector_attrib_bit...
Testing vector_attrib_uchar...
Testing vector_attrib_char...
Testing vector_attrib_ushort...
Testing vector_attrib_short...
Testing vector_attrib_uint...
Testing vector_attrib_int...
Testing vector_attrib_ulong...
Testing vector_attrib_long...
Testing vector_attrib_float...
Testing vector_attrib_double...
Testing tensor_attrib_uchar...
Testing tensor_attrib_char...
Testing tensor_attrib_ushort...
Testing tensor_attrib_short...
Testing tensor_attrib_uint...
Testing tensor_attrib_int...
Testing tensor_attrib_ulong...
Testing tensor_attrib_long...
Testing tensor_attrib_float...
Testing tensor_attrib_double...
Testing subset...
63 tests passed
PASS: vtk_test
PASS: adaptive_kd_tree_tests
PASS: file_options_test
PASS: kd_tree_test
Running test_valid_struct ...
Running test_inline ...
Running test_non_inline ...
Running test_resize_ii ...
Running test_resize_in ...
Running test_resize_ni ...
Running test_resize_nn ...
PASS: var_len_test
PASS: var_len_test_no_template
Running test_create_tag ...
Running test_invalid_tag_size ...
Running test_get_set_sparse_int ...
Running test_get_set_dense_int ...
Running test_get_set_dense_double ...
Running test_get_set_bit ...
Running test_get_by_tag ...
Running test_get_by_tag_value ...
Running test_mesh_value ...
Running test_get_pointers_sparse ...
Running test_get_pointers_dense ...
Running test_set_pointers_sparse ...
Running test_set_pointers_dense ...
Running test_get_entity_tags ...
Running test_delete_sparse_tag ...
Running test_delete_dense_tag ...
Running test_delete_mesh_tag ...
Running test_delete_sparse_data ...
Running test_delete_dense_data ...
Running test_delete_bit_data ...
Running test_create_variable_length_tag ...
Running test_get_set_variable_length_sparse ...
Running test_get_set_variable_length_dense ...
Running test_get_set_variable_length_mesh ...
Running regression_one_entity_by_var_tag ...
PASS: tag_test
Running test_add_entities_ordered ...
Running test_add_entities_set ...
Running test_add_entities_ordered_tracking ...
Running test_add_entities_set_tracking ...
Running test_remove_entities_ordered ...
Running test_remove_entities_set ...
Running test_remove_entities_ordered_tracking ...
Running test_remove_entities_set_tracking ...
Running test_entities_by_type_ordered ...
Running test_entities_by_type_set ...
Running test_entities_by_dim_ordered ...
Running test_entities_by_dim_set ...
Running test_subtract_set_set ...
Running test_subtract_set_ordered ...
Running test_subtract_ordered_set ...
Running test_subtract_ordered_ordered ...
Running test_subtract_set_set_tracking ...
Running test_subtract_set_ordered_tracking ...
Running test_subtract_ordered_set_tracking ...
Running test_subtract_ordered_ordered_tracking ...
Running test_itersect_set_set ...
Running test_itersect_set_ordered ...
Running test_itersect_ordered_set ...
Running test_itersect_ordered_ordered ...
Running test_itersect_set_set_tracking ...
Running test_itersect_set_ordered_tracking ...
Running test_itersect_ordered_set_tracking ...
Running test_itersect_ordered_ordered_tracking ...
Running test_unite_set_set ...
Running test_unite_set_ordered ...
Running test_unite_ordered_set ...
Running test_unite_ordered_ordered ...
Running test_unite_set_set_tracking ...
Running test_unite_set_ordered_tracking ...
Running test_unite_ordered_set_tracking ...
Running test_unite_ordered_ordered_tracking ...
Running test_contains_entities_ordered ...
Running test_contains_entities_set ...
Running test_clear_ordered ...
Running test_clear_set ...
Running test_clear_ordered_tracking ...
Running test_clear_set_tracking ...
ALL TESTS PASSED
PASS: mesh_set_test
All 18 tests passed
Making check in test
make[1]: Entering directory `/home/jason/moab/test/AMD64-32/test'
Making check in dual
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test/dual'
make  dual_test
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o dual_test  dual_test.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o dual_test dual_test.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
Usage: dual_test <mesh_file_name>
PASS: dual_test
All 1 tests passed
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test/dual'
Making check in h5file
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test/h5file'
make  h5test h5legacy h5varlen
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -I. -I../../../src/test/h5file -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../../../src/mhdf/include -I../..     -Wall -pipe -g -MT h5legacy.o -MD -MP -MF ".deps/h5legacy.Tpo" -c -o h5legacy.o ../../../src/test/h5file/h5legacy.cpp; \
	then mv -f ".deps/h5legacy.Tpo" ".deps/h5legacy.Po"; else rm -f ".deps/h5legacy.Tpo"; exit 1; fi
make[3]: `h5varlen' is up to date.
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o h5test  h5file_test.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o h5test h5file_test.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ../../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o h5legacy  h5legacy.o ../../libMOAB.la -lm
c++ -Wall -pipe -g -o h5legacy h5legacy.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
FAIL: h5test
Running test_moab_v3_poly_format ...
PASS: h5legacy
Running test_var_length_no_data ...
Running test_var_length_data ...
Running test_var_length_big_data ...
Running test_var_length_opaque ...
Running test_var_length_mesh_data ...
Running test_var_length_default_data ...
Running test_var_length_mesh_opaque ...
Running test_var_length_default_opaque ...
Running test_var_length_handle_tag ...
Running test_var_length_data_big ...
PASS: h5varlen
1 of 3 tests failed
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test/h5file'
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
