[MOAB-dev] r1740 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Apr 3 14:40:15 CDT 2008
Author: kraftche
Date: 2008-04-03 14:40:15 -0500 (Thu, 03 Apr 2008)
New Revision: 1740
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/test_geom.cc
Log:
correct fix for use of uninitialized values
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2008-04-03 14:30:57 UTC (rev 1739)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2008-04-03 19:40:15 UTC (rev 1740)
@@ -543,7 +543,6 @@
     // Check for on-boundary case
   diff = closest - point;
   if (diff%diff <= epsilon*epsilon) {
-    u = v = w = 2;
     return boundary_case( volume, result, u, v, w, facet, surface );
Modified: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc	2008-04-03 14:30:57 UTC (rev 1739)
+++ MOAB/trunk/tools/dagmc/test_geom.cc	2008-04-03 19:40:15 UTC (rev 1740)
@@ -447,7 +447,7 @@
   for (int i = 0; i < num_test; ++i) {
     int result;
-    double u, v, w;
+    double u = 2, v = 2, w = 2; // values greater than 1 should get ignored
     rval = dagmc.point_in_volume( vol,
                                   tests[i].coords[0],
                                   tests[i].coords[1],
