[MOAB-dev] r1734 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Wed Apr 2 13:50:34 CDT 2008
Author: tautges
Date: 2008-04-02 13:50:34 -0500 (Wed, 02 Apr 2008)
New Revision: 1734
Modified:
MOAB/trunk/parallel/gs.c
Log:
Fixed bug in indexing signed long array in transfer.
Modified: MOAB/trunk/parallel/gs.c
--- MOAB/trunk/parallel/gs.c 2008-04-02 14:41:07 UTC (rev 1733)
+++ MOAB/trunk/parallel/gs.c 2008-04-02 18:50:34 UTC (rev 1734)
@@ -429,7 +429,7 @@
for (j = 0; j < nlabels; j++)
nzl[j]=label[nlabels*i+j];
for (j = 0; j < nulabels; j++)
- nzul[j]=label[nulabels*i+j];
+ nzul[j]=ulabel[nulabels*i+j];
nzi++, nzl+= nlabels, nzul+=nulabels, nonzero.n++;
@@ -442,13 +442,13 @@
#endif
/* build list of unique labels w/ lowest associated index:
- (index in nonzero ^, primary (lowest) index in label, count, label) */
+ (index in nonzero ^, primary (lowest) index in label, count, label(s), ulabel(s)) */
tuple_list_init_max(&primary,3,nlabels,nulabels,0,nonzero.n);
uint i;
sint *nzi=nonzero.vi, *pi=primary.vi;
slong *nzl=nonzero.vl, *pl=primary.vl;
- slong *nzul=nonzero.vul, *pul=primary.vul;
+ ulong *nzul=nonzero.vul, *pul=primary.vul;
sint last=-1;
for(i=0;i<nonzero.n;++i,nzi+=1,nzl+=nlabels,nzul+=nulabels) {
if(nzl[0]==last) {
@@ -479,10 +479,10 @@
/* sort unique labels by primary index:
(nonzero index ^2, primary index ^1, count, label ^2) */
#ifndef USE_MPI
- tuple_list_sort(&primary,1,&buf);
+ tuple_list_sort(&primary,0,&buf);
buffer_free(&buf);
#else
- tuple_list_sort(&primary,1,&crystal->all->buf);
+ tuple_list_sort(&primary,0,&crystal->all->buf);
#endif
/* construct local condense map */
@@ -540,10 +540,10 @@
si[1] = pi1[0];
si[2] = pi2[1];
- sl[j] = pl2[j];
+ sl[j] = pl1[j];
- sul[j] = pul2[j];
- si+=3, sul+=nulabels, shared.n++;
+ sul[j] = pul1[j];
+ si+=3, sl+=nlabels, sul+=nulabels, shared.n++;
@@ -580,9 +580,10 @@
// don't store 1st slabel
sl++;
for (j = 0; j < nlabels-1; j++)
- *slabels++ = *sl;
+ slabels[j] = sl[j];
- *ulabels++ = *ul;
+ ulabels[j] = ul[j];
+ slabels+=nlabels-1, ulabels+=nulabels, sl+=nlabels-1, ul+=nulabels;
tuple_list_free(&shared);
