[MOAB-dev] r1295 - MOAB/trunk/tools/iMesh
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Sep 26 12:10:32 CDT 2007
Author: tautges
Date: 2007-09-26 12:10:31 -0500 (Wed, 26 Sep 2007)
New Revision: 1295
Modified:
   MOAB/trunk/tools/iMesh/iMesh.h
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Adding 2nd order adjacency function, added recently to itaps,
so far only C interface.
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h	2007-09-26 14:56:47 UTC (rev 1294)
+++ MOAB/trunk/tools/iMesh/iMesh.h	2007-09-26 17:10:31 UTC (rev 1295)
@@ -662,6 +662,38 @@
                           /*out*/ int* offset_size,
                           /*out*/ int *err);
+/**\brief Get "2nd order" adjacencies to an array of entities
+ * Get "2nd order" adjacencies to an array of entities, that is, from each
+ * entity, through other entities of a specified "bridge" dimension, to other
+ * entities of another specified "to" dimension.
+ * \param instance iMesh instance for this call
+ * \param entity_handles Entities from which adjacencies are requested
+ * \param entity_handles_size Number of entities whose adjacencies are requested
+ * \param bridge_dimension Bridge dimension for 2nd order adjacencies
+ * \param to_dimension Dimension of adjacent entities returned
+ * \param adj_entity_handles Adjacent entities
+ * \param adj_entity_handles_allocated Allocated size of returned array
+ * \param adj_entity_handles_size Occupied size of returned array
+ * \param offset Offset[i] is offset into adj_entity_handles of 2nd order
+ *        adjacencies of ith entity in entity_handles
+ * \param offset_allocated Allocated size of offset array
+ * \param offset_size Occupied size of offset array
+ * \param err
+  void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
+                              iBase_EntityHandle const* entity_handles,
+                              int entity_handles_size,
+                              int order_adjacent_key,
+                              int requested_entity_type,
+                              iBase_EntityHandle** adj_entity_handles,
+                              int* adj_entity_handles_allocated,
+                              int* adj_entity_handles_size,
+                              int** offset,
+                              int* offset_allocated,
+                              int* offset_size,
+                              int* err );
     /**\brief  Create an entity set
      * Create an entity set, either ordered (isList=1) or unordered
@@ -1920,6 +1952,28 @@
                        /*out*/ int* adj_entity_handles_size,
                        /*out*/ int *err);
+/**\brief Get "2nd order" adjacencies to an entity
+ * Get "2nd order" adjacencies to an entity, that is, from an entity, through
+ * other entities of a specified "bridge" dimension, to other entities of another
+ * specified "to" dimension.
+ * \param entity_handle Entity from which adjacencies are requested
+ * \param adjacent_entities Adjacent entities
+ * \param adjacent_entities_allocated Allocated size of returned array
+ * \param adjacent_entities_size Occupied size of returned array
+ * \param err
+  void iMesh_getEnt2ndAdj( iMesh_Instance instance,
+                           iBase_EntityHandle entity_handle,
+                           iBase_EntityHandle** adjacent_entities,
+                           int* adjacent_entities_allocated,
+                           int* adjacent_entities_size,
+                           int* err );
     /**\brief  Subtract contents of one entity set from another
      * Subtract contents of one entity set from another
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2007-09-26 14:56:47 UTC (rev 1294)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2007-09-26 17:10:31 UTC (rev 1295)
@@ -2,6 +2,7 @@
 #include "MBCore.hpp"
 #include "MBRange.hpp"
 #include "MBCN.hpp"
+#include "MeshTopoUtil.hpp"
 #include <iostream>
 #define MIN(a,b) (a < b ? a : b)
@@ -1024,6 +1025,62 @@
   RETURN(iBase_SUCCESS);
+void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
+                            int** offset,
+                            int* offset_size,
+                            int* err )
+  MBErrorCode result = MB_SUCCESS;
+  CHECK_SIZE(*offset, *offset_allocated, entity_handles_size+1,
+             int, iBase_MEMORY_ALLOCATION_FAILED);
+  const MBEntityHandle* entity_iter = (const MBEntityHandle*)entity_handles;
+  const MBEntityHandle* const entity_end = entity_iter + entity_handles_size;
+  int* off_iter = *offset;
+  int prev_off = 0;
+  std::vector<MBEntityHandle> all_adj_ents;
+  MeshTopoUtil mtu(MBI);
+  for ( ; entity_iter != entity_end; ++entity_iter)
+    *off_iter = prev_off;
+    off_iter++;
+    MBRange adj_ents;
+    result = mtu.get_bridge_adjacencies( *entity_iter,
+                                         order_adjacent_key,
+                                         requested_entity_type, adj_ents );
+    if (MB_SUCCESS != result) {
+      iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
+      RETURN(iBase_ERROR_MAP[result]);
+    std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
+    prev_off += adj_ents.size();
+  CHECK_SIZE(*adj_entity_handles, *adj_entity_handles_allocated,
+             (int)all_adj_ents.size(),
+             iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+  memcpy(*adj_entity_handles, &all_adj_ents[0],
+         sizeof(MBEntityHandle)*all_adj_ents.size() );
+  *adj_entity_handles_size = all_adj_ents.size();
+  *offset_size = entity_handles_size+1;
+  RETURN(iBase_SUCCESS);
 void iMesh_createEntSet(iMesh_Instance instance,
                        /*in*/ const int isList,
                        /*out*/ iBase_EntitySetHandle* entity_set_created, int *err)
@@ -2427,6 +2484,27 @@
                      &offset_size, err);
+void iMesh_getEnt2ndAdj( iMesh_Instance instance,
+                         iBase_EntityHandle** adj_entities,
+                         int* adj_entities_allocated,
+                         int* adj_entities_size,
+                         int* err )
+  int offsets[2];
+  int *offsets_ptr = offsets;
+  int offset_size, offset_allocated = 2;
+  iMesh_getEntArr2ndAdj(instance,
+                        &entity_handle, 1, order_adjacent_key,
+                        adj_entities, adj_entities_allocated,
+                        adj_entities_size, &offsets_ptr, &offset_allocated,
+                        &offset_size, err);
 void iMesh_subtract(iMesh_Instance instance,
                    /*in*/ const iBase_EntitySetHandle entity_set_1,
                    /*in*/ const iBase_EntitySetHandle entity_set_2,
