[MOAB-dev] r1292 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov
Tue Sep 25 18:48:35 CDT 2007
Author: kraftche
Date: 2007-09-25 18:48:35 -0500 (Tue, 25 Sep 2007)
New Revision: 1292
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
o Remove unnecessary 'static' qualifier.
o Move some static function variables to class member variables
o Provide single-surface version of DagMC::surface_sense so that
we don't do unnecessary array allocations when we only need the
value for one surface (all but one of the callers of the function.)
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2007-09-25 23:32:39 UTC (rev 1291)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2007-09-25 23:48:35 UTC (rev 1292)
@@ -55,6 +55,10 @@
geomTag = get_tag( GEOM_DIMENSION_TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER );
obbTag = get_tag( MB_OBB_TREE_TAG_NAME, sizeof(MBEntityHandle), MB_TAG_DENSE, MB_TYPE_HANDLE );
+ // get sense of surfaces wrt volumes
+ senseTag = get_tag( "GEOM_SENSE_2", 2*sizeof(MBEntityHandle), MB_TAG_DENSE, MB_TYPE_HANDLE );
MBErrorCode DagMC::ray_fire(const MBEntityHandle vol, const MBEntityHandle last_surf_hit,
@@ -77,8 +81,8 @@
MBErrorCode rval;
// delcare some stuff static so we don't need to re-created
// it for every call
- static std::vector<double> distances;
- static std::vector<MBEntityHandle> surfaces;
+ std::vector<double> &distances = distList;
+ std::vector<MBEntityHandle> &surfaces = surfList;
// do ray fire
@@ -263,8 +267,8 @@
return rval;
// Allocate space to store vertices
- static MBCartVect coords_static[4];
- static std::vector<MBCartVect> coords_dynamic;
+ MBCartVect coords_static[4];
+ std::vector<MBCartVect> coords_dynamic;
MBCartVect* coords = coords_static;
if ((unsigned)len > (sizeof(coords_static)/sizeof(coords_static[0]))) {
coords_dynamic.resize(len);
@@ -393,7 +397,7 @@
// Get triangles at closest point
- static std::vector<MBEntityHandle> tris, surfs;
+ std::vector<MBEntityHandle> &tris = triList, &surfs = surfList;
tris.clear();
surfs.clear();
rval = obbTree.sphere_intersect_triangles( closest.array(), epsilon, root, tris, &surfs );
@@ -410,7 +414,7 @@
rval = moab_instance()->get_coords( conn, len, coords[0].array() );
if (MB_SUCCESS != rval) return rval;
- rval = surface_sense( volume, 1, &surfs.front(), &sense );
+ rval = surface_sense( volume, surfs.front(), sense );
// get triangle normal
@@ -441,7 +445,7 @@
@@ -621,12 +625,8 @@
const MBEntityHandle* surfaces,
int* senses_out )
- // get sense of surfaces wrt volumes
- static const MBTag tag = get_tag( "GEOM_SENSE_2", 2*sizeof(MBEntityHandle), MB_TAG_DENSE, MB_TYPE_HANDLE );
std::vector<MBEntityHandle> surf_volumes( 2*num_surfaces );
- MBErrorCode rval = moab_instance()->tag_get_data( tag, surfaces, num_surfaces, &surf_volumes[0] );
+ MBErrorCode rval = moab_instance()->tag_get_data( sense_tag(), surfaces, num_surfaces, &surf_volumes[0] );
const MBEntityHandle* end = surfaces + num_surfaces;
@@ -648,6 +648,26 @@
return MB_SUCCESS;
+// get sense of surface(s) wrt volume
+MBErrorCode DagMC::surface_sense( MBEntityHandle volume,
+ MBEntityHandle surface,
+ int& sense_out )
+ MBEntityHandle surf_volumes[2];
+ MBErrorCode rval = moab_instance()->tag_get_data( sense_tag(), &surface, 1, surf_volumes );
+ if (MB_SUCCESS != rval) return rval;
+ if (surf_volumes[0] == volume)
+ sense_out = (surf_volumes[1] != volume); // zero if both, otherwise 1
+ else if (surf_volumes[1] == volume)
+ sense_out = -1;
+ else
+ return MB_ENTITY_NOT_FOUND;
+ return MB_SUCCESS;
MBErrorCode DagMC::load_file_and_init(const char* cfile,
const int clen,
const char* ffile,
@@ -1193,7 +1213,7 @@
MBEntityHandle root = rootSets[surf - setOffset];
const double in_pt[] = { xxx, yyy, zzz };
- static std::vector<MBEntityHandle> facets;
+ std::vector<MBEntityHandle> &facets = triList;
facets.clear();
MBErrorCode rval = obbTree.closest_to_location( in_pt, root, tolerance(), facets );
assert(MB_SUCCESS == rval);
@@ -1411,7 +1431,7 @@
// skip any surfaces that are non-manifold in the volume
// because point containment code will get confused by them
int sense;
- rval = surface_sense( *i, 1, &*j, &sense );
+ rval = surface_sense( *i, *j, sense );
if (MB_SUCCESS != rval) {
std::cerr << "Surface/Volume sense data missing." << std::endl;
return rval;
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2007-09-25 23:32:39 UTC (rev 1291)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2007-09-25 23:48:35 UTC (rev 1292)
@@ -62,6 +62,10 @@
int* senses_out );
+ // Get the sense of surfaces wrt a volume. Sense values are:
+ // {-1 -> reversed, 0 -> both, 1 -> forward}
+ MBErrorCode surface_sense( MBEntityHandle volume, MBEntityHandle surface, int& sense_out );
// load mesh and initialize
MBErrorCode load_file_and_init(const char* cfile,
const int clen,
@@ -97,6 +101,8 @@
MBTag id_tag() {return idTag;}
MBTag name_tag() {return nameTag;}
+ MBTag sense_tag() { return senseTag; }
double distance_limit() {return distanceLimit;}
void distance_limit(double this_limit) {distanceLimit = this_limit;}
@@ -164,7 +170,7 @@
MBInterface *mbImpl;
MBOrientedBoxTreeTool obbTree;
- MBTag obbTag, geomTag, idTag, nameTag;
+ MBTag obbTag, geomTag, idTag, nameTag, senseTag;
Option options[4];
@@ -201,6 +207,10 @@
DagMC(MBInterface *mb_impl);
static DagMC *instance_;
+ // temporary storage so functions don't have to reallocate vectors
+ std::vector<MBEntityHandle> triList, surfList;
+ std::vector<double> distList;
inline char *DagMC::get_spec_reflect()
