[MOAB-dev] r1278 - MOAB/trunk
tautges at mcs.anl.gov
Fri Sep 14 14:38:37 CDT 2007
Author: tautges
Date: 2007-09-14 14:38:37 -0500 (Fri, 14 Sep 2007)
New Revision: 1278
Modified:
MOAB/trunk/ReadNCDF.cpp
Log:
Changed to put stuff read from the file into the set (just blocks were
set as children of the read set).
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2007-09-14 18:12:09 UTC (rev 1277)
+++ MOAB/trunk/ReadNCDF.cpp 2007-09-14 19:38:37 UTC (rev 1278)
@@ -600,7 +600,17 @@
- return MB_SUCCESS;
+ // loaded successfully; add these nodes to loading set
+ int ierr = 0;
+ MBEntityHandle end_handle = CREATE_HANDLE(MBVERTEX,
+ ID_FROM_HANDLE(node_handle)+
+ numberNodes_loading-1,
+ ierr);
+ if (0 != ierr) return MB_FAILURE;
+ MBErrorCode result = mdbImpl->add_entities(mCurrentMeshHandle,
+ MBRange(node_handle, end_handle));
+ return result;
MBErrorCode ReadNCDF::read_block_headers(const int *blocks_to_load,
@@ -725,13 +735,13 @@
// that were read before.
//get all the blocks of mCurrentMeshHandle
- std::vector< MBEntityHandle > child_meshsets;
- if(mdbImpl->get_child_meshsets( mCurrentMeshHandle, child_meshsets ) != MB_SUCCESS )
+ MBRange child_meshsets;
+ if(mdbImpl->get_entities_by_type(mCurrentMeshHandle, MBENTITYSET, child_meshsets ) != MB_SUCCESS )
return MB_FAILURE;
MBTag tag_handle;
- std::vector<MBEntityHandle>::iterator iter, end_iter;
+ MBRange::iterator iter, end_iter;
//get the block id offset
int id_offset = 0;
@@ -872,7 +882,7 @@
return MB_FAILURE;
//add the meshset to the mCurrentMeshHandle
- if( mdbImpl->add_parent_child( mCurrentMeshHandle, ms_handle ) != MB_SUCCESS )
+ if( mdbImpl->add_entities( mCurrentMeshHandle, &ms_handle, 1 ) != MB_SUCCESS )
return MB_FAILURE;
// just a check because the following code won't work if this case fails
@@ -913,6 +923,9 @@
if( mdbImpl->tag_set_data( mGlobalIdTag, &ms_handle, 1, &block_id ) != MB_SUCCESS )
return MB_FAILURE;
+ // success; add new elements to file set
+ if (mdbImpl->add_entities( mCurrentMeshHandle, new_range) != MB_SUCCESS)
+ return MB_FAILURE;
delete [] temp_string;
@@ -1064,11 +1077,12 @@
// Maybe there is already a nodesets meshset here we can append to
- std::vector<MBEntityHandle> child_meshsets;
- if( mdbImpl->get_child_meshsets( mCurrentMeshHandle, child_meshsets ) != MB_SUCCESS )
+ if( mdbImpl->get_entities_by_handle( mCurrentMeshHandle,
+ child_meshsets ) != MB_SUCCESS )
return MB_FAILURE;
iter = child_meshsets.begin();
end_iter = child_meshsets.end();
@@ -1126,7 +1140,7 @@
if( mdbImpl->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ns_handle ) != MB_SUCCESS)
return MB_FAILURE;
- if( mdbImpl->add_parent_child( mCurrentMeshHandle, ns_handle ) != MB_SUCCESS )
+ if( mdbImpl->add_entities( mCurrentMeshHandle, &ns_handle, 1 ) != MB_SUCCESS )
return MB_FAILURE;
// set a tag signifying dirichlet bc
@@ -1213,11 +1227,12 @@
return MB_FAILURE;
// Maybe there is already a sidesets meshset here we can append to
+ if( mdbImpl->get_entities_by_type( mCurrentMeshHandle, MBENTITYSET,
return MB_FAILURE;
int i;
char *temp_string = new char[max_str_length+1];
@@ -1308,7 +1323,7 @@
return MB_FAILURE;
if( mdbImpl->tag_set_data(mGlobalIdTag, &ss_handle, 1, &sideset_id ) != MB_SUCCESS)
return MB_FAILURE;
- if( mdbImpl->add_parent_child( mCurrentMeshHandle, ss_handle ) != MB_SUCCESS )
+ if( mdbImpl->add_entities( mCurrentMeshHandle, &ss_handle, 1 ) != MB_SUCCESS )
return MB_FAILURE;
if (!reverse_entities.empty()) {
