[MOAB-dev] r1276 - MOAB/trunk
kraftche at mcs.anl.gov
Fri Sep 14 12:33:37 CDT 2007
Author: kraftche
Date: 2007-09-14 12:33:37 -0500 (Fri, 14 Sep 2007)
New Revision: 1276
Modified:
MOAB/trunk/MBCore.cpp
Log:
remove more static function variables
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-09-14 16:05:59 UTC (rev 1275)
+++ MOAB/trunk/MBCore.cpp 2007-09-14 17:33:37 UTC (rev 1276)
@@ -302,7 +302,7 @@
const MBEntityID id,
MBEntityHandle& handle) const
- static int err;
+ int err;
handle = CREATE_HANDLE(type, id, err);
//check to see if handle exists
@@ -934,9 +934,6 @@
// WARNING: This is very dependent on the ordering of the MBEntityType enum
MBEntityType type = TYPE_FROM_HANDLE(entity_handle);
- static std::vector<MBEntityHandle> tmp;
- tmp.clear();
MBEntitySequence* seq = 0;
if (type < MBVERTEX || type > MBENTITYSET)
@@ -946,16 +943,20 @@
if (seq == 0 || status != MB_SUCCESS || !seq->is_valid_entity(entity_handle))
return (status != MB_SUCCESS ? status : MB_ENTITY_NOT_FOUND);
- status = static_cast<ElementEntitySequence*>(seq)->get_connectivity(entity_handle, tmp);
+ const MBEntityHandle* old_conn;
+ int len;
+ status = static_cast<ElementEntitySequence*>(seq)->get_connectivity(entity_handle, old_conn, len);
if (status != MB_SUCCESS) return status;
+ aEntityFactory->notify_change_connectivity(
+ entity_handle, old_conn, connect, num_connect);
status = static_cast<ElementEntitySequence*>(seq)->set_connectivity(entity_handle,
- if (status != MB_SUCCESS) return status;
+ if (status != MB_SUCCESS)
+ entity_handle, connect, old_conn, num_connect);
- aEntityFactory->notify_change_connectivity(
- entity_handle, &tmp[0], connect, num_connect);
return status;
