[MOAB-dev] r1269 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Sep 12 17:48:13 CDT 2007
Author: kraftche
Date: 2007-09-12 17:48:12 -0500 (Wed, 12 Sep 2007)
New Revision: 1269
Modified:
MOAB/trunk/MBTest.cpp
Log:
add test case the demonstrates flaw in MBCore::get_entities_by_type_and_tag with a non-zero input meshset
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2007-09-11 22:38:58 UTC (rev 1268)
+++ MOAB/trunk/MBTest.cpp 2007-09-12 22:48:12 UTC (rev 1269)
@@ -2815,6 +2815,38 @@
if( entities.size() != times) //should get as many hexes as you perviously marked
return MB_FAILURE;
+ // test fetch by tag value again, this time limiting the results
+ // to the contents of an entity set
+ MBEntityHandle meshset;
+ result = MB->create_meshset( MESHSET_SET, meshset );
+ if (MB_SUCCESS != result)
+ return result;
+ result = MB->add_entities( meshset, test_range );
+ return result;
+ //fetch the hex entities of type--MBHEX, tag-"junk_tag", and tag value -- 3489
+ entities.clear();
+ result = MB->get_entities_by_type_and_tag(meshset, MBHEX, &junk_tag,
+ &ptr_data, 1, entities );
+ return result;
+ if( entities.size() != times) //should get as many hexes as you perviously marked
+ return MB_FAILURE;
+ //fetch the hex entities of type--MBHEX, tag-"stale_bits", and tag value -- 0x5
+ entities.clear();
+ result = MB->get_entities_by_type_and_tag(meshset, MBHEX, &stale_bits,
+ &ptr_bits, 1, entities );
+ return result;
result = MB->tag_delete(stale_bits);
return result;
