[MOAB-dev] r1267 - in MOAB/trunk: . tools/qvdual
tautges at mcs.anl.gov
Tue Sep 11 17:36:39 CDT 2007
Author: tautges
Date: 2007-09-11 17:36:39 -0500 (Tue, 11 Sep 2007)
New Revision: 1267
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/tools/qvdual/moc_uiQVDual.cpp
MOAB/trunk/tools/qvdual/uiQVDual.h
MOAB/trunk/tools/qvdual/uiQVDual.ui.h
MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
MOAB/trunk/tools/qvdual/vtkMOABUtils.h
Log:
Various fixes for qvdual and hex mod operations in DualTool.
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/DualTool.cpp 2007-09-11 22:36:39 UTC (rev 1267)
@@ -2558,9 +2558,13 @@
MBEntityHandle quads[4], hexes[2];
std::vector<MBEntityHandle> connects[4], side_quads[2];
+ // get three quads (shared quad & 2 end quads), hexes, and quad
+ // connects
MBErrorCode result = fs_get_quads(odedge, quads, hexes, connects);
if (MB_SUCCESS != result) return result;
+ // adjust sense & rotation so they're aligned, together & wrt first
+ // hex
result = fs_check_quad_sense(hexes[0], quads[0], connects);
@@ -2615,25 +2619,40 @@
- // delete the interior entities
- result = mbImpl->delete_entities(adj_ents);
- if (MB_SUCCESS != result) return result;
- // re-build the two hexes
+ // before re-connecting two hexes, check for existing quad on 4th quad vertices;
+ // if there is a quad there, need to add explicit adjs to any adj hexes, since
+ // by definition there'll be another quad on those vertices
+ bool need_explicit = false;
+ MBRange adj_quads;
+ result = mbImpl->get_adjacencies(&connects[3][0], 4, 2, false, adj_quads);
+ if (MB_MULTIPLE_ENTITIES_FOUND == result || !adj_quads.empty()) {
+ // there's already a quad for these 4 vertices; by definition,
+ // we'll be creating equivalent entities, so that original quad
+ // needs explicit adj's to its bounding elements
+ need_explicit = true;
+ for (MBRange::iterator rit = adj_quads.begin(); rit != adj_quads.end();
+ rit++) {
+ MBRange adj_hexes;
+ result = mbImpl->get_adjacencies(&(*rit), 1, 3, false, adj_hexes); RR;
+ result = mbImpl->add_adjacencies(*rit, adj_hexes, false); RR;
+ // re-connect the two hexes
std::vector<MBEntityHandle> new_connect;
std::copy(connects[3].begin(), connects[3].end(), std::back_inserter(new_connect));
std::copy(connects[2].begin(), connects[2].end(), std::back_inserter(new_connect));
- result = mbImpl->create_element(MBHEX, &new_connect[0], 8, hexes[0]);
+ result = mbImpl->set_connectivity(hexes[0], &new_connect[0], 8);
new_connect.clear();
std::copy(connects[0].begin(), connects[0].end(), std::back_inserter(new_connect));
- result = mbImpl->create_element(MBHEX, &new_connect[0], 8, hexes[1]);
+ result = mbImpl->set_connectivity(hexes[1], &new_connect[0], 8);
- // test for equiv entities from the side quads, and make explicit adjacencies
- // if there are any
+ // test for equiv entities from the side quads, and make explicit
+ // adjacencies if there are any
MeshTopoUtil mtu(mbImpl);
for (int j = 0; j < 2; j++) {
for (int i = 0; i < 4; i++) {
@@ -2644,12 +2663,20 @@
- // check for and fix any explicit adjacencies on either end quad
- if (mtu.equivalent_entities(quads[0]))
- mbImpl->add_adjacencies(quads[0], &hexes[1], 1, false);
- if (mtu.equivalent_entities(quads[2]))
- mbImpl->add_adjacencies(quads[2], &hexes[0], 1, false);
+ // remove hexes we want to keep
+ adj_ents.erase(hexes[0]);
+ adj_ents.erase(hexes[1]);
+ // delete the other interior entities
+ result = mbImpl->delete_entities(adj_ents);
+ if (MB_SUCCESS != result) return result;
+ MBEntityHandle new_quad;
+ result = mbImpl->create_element(MBQUAD, &connects[3][0], 4, new_quad); RR;
+ if (need_explicit) {
+ result = mbImpl->add_adjacencies(new_quad, hexes, 2, false); RR;
if (debug_ap) ((MBCore*)mbImpl)->check_adjacencies();
// now update the dual
@@ -2666,67 +2693,18 @@
// where the fourth is really the 4 vertices originally shared by the 2 hexes
// before the face shrink on them
- // get all verts in quads 0 and 2
- MBRange outside_verts, all_verts;
- std::copy(connects[0].begin(), connects[0].end(), mb_range_inserter(outside_verts));
- std::copy(connects[2].begin(), connects[2].end(), mb_range_inserter(outside_verts));
- // get all verts in all hexes by getting bridge adjacencies from inner quad;
- // only need to do 2 verts, since that covers all the hexes
- MeshTopoUtil mtu(mbImpl);
- MBErrorCode result = mtu.get_bridge_adjacencies(connects[1][0], 3, 0, all_verts);
- result = mtu.get_bridge_adjacencies(connects[1][2], 3, 0, all_verts);
- for (int i = 0; i < 4; i++)
- all_verts.erase(connects[1][i]);
- // outside 4 verts are just difference
- all_verts = all_verts.subtract(outside_verts);
- if (all_verts.size() != 4) return MB_FAILURE;
- std::copy(all_verts.begin(), all_verts.end(), std::back_inserter(connects[3]));
- // now align with other quads
- // first get them in the right sequence by verifying shared edges
- if (0 == mtu.common_entity(connects[3][0], connects[3][1], 1)) {
- MBEntityHandle dum = connects[3][1];
- connects[3][1] = connects[3][2];
- connects[3][2] = dum;
- if (0 == mtu.common_entity(connects[3][1], connects[3][2], 1)) {
- MBEntityHandle dum = connects[3][2];
- connects[3][2] = connects[3][3];
- connects[3][3] = dum;
- assert(0 != mtu.common_entity(connects[3][0], connects[3][1], 1) &&
- 0 == mtu.common_entity(connects[3][0], connects[3][2], 1));
- // now get offset, sense
- int index = -1, sense = 0;
+ // vertex on 4th quad is in quad adj to other 3 verts
- if (0 != mtu.common_entity(connects[0][0], connects[3][i], 1)) {
- index = i;
- if (0 != mtu.common_entity(connects[0][1], connects[3][(i+1)%4], 1))
- sense = 1;
- else if (0 != mtu.common_entity(connects[0][1], connects[3][(i+4-1)%4], 1))
- sense = -1;
- break;
+ MBRange start_verts, tmp_verts, quads;
+ for (int j = 0; j < 3; j++) start_verts.insert(connects[j][i]);
+ MBErrorCode result = mbImpl->get_adjacencies(start_verts, 2, false, quads);
+ assert(quads.size() == 1);
+ result = mbImpl->get_adjacencies(&(*quads.begin()), 1, 0, false, tmp_verts); RR;
+ tmp_verts = tmp_verts.subtract(start_verts);
+ assert(1 == tmp_verts.size());
+ connects[3].push_back(*tmp_verts.begin());
- assert(index != -1 && sense != 0);
- if (sense == -1) {
- MBEntityHandle dumh = connects[3][0];
- connects[3][0] = connects[3][2];
- connects[3][2] = dumh;
- index = (index + 2)%4;
- if (index != 0) {
- std::vector<MBEntityHandle> tmpc;
- tmpc.push_back(connects[3][(index+i)%4]);
- connects[3].swap(tmpc);
// now get the side quads
@@ -2734,7 +2712,7 @@
dum_ents.insert(connects[1][i]);
dum_ents.insert(connects[1][(i+1)%4]);
dum_ents.insert(connects[3][i]);
- result = mbImpl->get_adjacencies(dum_ents, 3, false, hexes);
+ MBErrorCode result = mbImpl->get_adjacencies(dum_ents, 3, false, hexes);
assert(1 == hexes.size());
Modified: MOAB/trunk/tools/qvdual/moc_uiQVDual.cpp
--- MOAB/trunk/tools/qvdual/moc_uiQVDual.cpp 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/tools/qvdual/moc_uiQVDual.cpp 2007-09-11 22:36:39 UTC (rev 1267)
@@ -1,7 +1,7 @@
** uiQVDual meta object code from reading C++ file 'uiQVDual.h'
-** Created: Wed Aug 22 09:12:40 2007
+** Created: Mon Sep 10 16:49:21 2007
** by: The Qt MOC ($Id: qt/moc_yacc.cpp 3.3.7 edited Oct 19 16:22 $)
** WARNING! All changes made in this file will be lost!
Modified: MOAB/trunk/tools/qvdual/uiQVDual.h
--- MOAB/trunk/tools/qvdual/uiQVDual.h 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/tools/qvdual/uiQVDual.h 2007-09-11 22:36:39 UTC (rev 1267)
@@ -1,7 +1,7 @@
** Form interface generated from reading ui file 'uiQVDual.ui'
-** Created: Wed Aug 8 03:15:38 2007
+** Created: Mon Sep 10 16:49:13 2007
** by: The User Interface Compiler ($Id: qt/main.cpp 3.3.7 edited Aug 31 2005 $)
Modified: MOAB/trunk/tools/qvdual/uiQVDual.ui.h
--- MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-09-11 22:36:39 UTC (rev 1267)
@@ -106,12 +106,13 @@
resetDisplay();
- DualTool(vtkMOABUtils::mbImpl).delete_whole_dual();
+ DualTool dt(vtkMOABUtils::mbImpl);
+ dt.delete_whole_dual();
computeDual = false;
vtkMOABUtils::assign_global_ids();
vtkMOABUtils::mbImpl->write_mesh(filename.ascii());
redrawDisplay();
@@ -1039,28 +1040,17 @@
bool save_compute = computeDual;
if (NULL != vtkMOABUtils::drawDual) {
- MBRange sheets;
- vtkMOABUtils::drawDual->reset_drawn_sheets(&sheets);
+ vtkMOABUtils::drawDual->reset_drawn_sheets();
vtkMOABUtils::reset_drawing_data();
- if (NULL != vtkWidget) {
- delete vtkWidget;
- vtkWidget = NULL;
computeDual = save_compute;
void uiQVDual::redrawDisplay()
- //resetDisplay();
- //this->init();
vtkMOABUtils::update_display();
this->updateMesh();
Modified: MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
--- MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx 2007-09-11 22:36:39 UTC (rev 1267)
@@ -137,6 +137,15 @@
vtkMOABUtils::mbImpl = impl;
+ MBErrorCode result = create_tags();
+ make_properties();
+ return result;
+MBErrorCode vtkMOABUtils::create_tags()
MBErrorCode result = vtkMOABUtils::mbImpl->tag_get_handle(vtkCellTagName, vtkCellTag);
if (MB_TAG_NOT_FOUND == result) {
int def_val = -1;
@@ -179,9 +188,7 @@
vtkPointAllocatedTag, &def_val);
- make_properties();
- return result;
+ return MB_SUCCESS;
void vtkMOABUtils::make_properties()
@@ -1106,7 +1113,7 @@
NULL, 0, &mesh_actor);
if (MB_SUCCESS != result) {
- std::cerr << "Failed to set actor for mesh in vtkMOABReader::Execute()." << std::endl;
+ std::cerr << "Failed to set actor for mesh in vtkMOABUtils::update_display()." << std::endl;
return;
@@ -1179,23 +1186,6 @@
//! get rid of all the vtk drawing stuff
void vtkMOABUtils::reset_drawing_data()
- if (NULL != myRen) {
- myRen->Delete();
- myRen = NULL;
- //! the default property
- if (NULL != topProperty) {
- topProperty->Delete();
- topProperty = NULL;
- //! the highlight property
- if (NULL != highlightProperty) {
- highlightProperty->Delete();
- highlightProperty = NULL;
actorProperties.clear();
//! map between props (actor2d's and actors) and sets they represent (0 if no set,
@@ -1213,11 +1203,6 @@
topParentAssy = NULL;
- if (NULL != lookupTable) {
- lookupTable->Delete();
- lookupTable = NULL;
if (NULL != drawDual) {
delete drawDual;
drawDual = NULL;
@@ -1234,24 +1219,31 @@
MBErrorCode result = mbImpl->tag_delete(vtkTopContainsTag);
if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result)
std::cout << "Trouble deleting tag." << std::endl;
+ vtkTopContainsTag = NULL;
//! tag indicating whether a given set is in top parent assy
result = mbImpl->tag_delete(vtkTopParentTag);
+ vtkTopParentTag = NULL;
result = mbImpl->tag_delete(vtkCellTag);
+ vtkCellTag = NULL;
result = mbImpl->tag_delete(vtkSetActorTag);
+ vtkSetActorTag = NULL;
result = mbImpl->tag_delete(vtkSetPropAssemblyTag);
+ vtkSetPropAssemblyTag = NULL;
result = mbImpl->tag_delete(vtkPointAllocatedTag);
+ vtkPointAllocatedTag = NULL;
+ create_tags();
void vtkMOABUtils::assign_global_ids()
Modified: MOAB/trunk/tools/qvdual/vtkMOABUtils.h
--- MOAB/trunk/tools/qvdual/vtkMOABUtils.h 2007-08-31 16:38:22 UTC (rev 1266)
+++ MOAB/trunk/tools/qvdual/vtkMOABUtils.h 2007-09-11 22:36:39 UTC (rev 1267)
@@ -246,6 +246,8 @@
//! debug parameter
static bool debug;
+ static MBErrorCode create_tags();
private:
//! private constructor so nobody can construct one
vtkMOABUtils();
