[MOAB-dev] r1349 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Oct 31 12:43:34 CDT 2007
Author: tautges
Date: 2007-10-31 12:43:34 -0500 (Wed, 31 Oct 2007)
New Revision: 1349
Modified:
   MOAB/trunk/EntitySequence.cpp
   MOAB/trunk/EntitySequence.hpp
   MOAB/trunk/EntitySequenceManager.cpp
   MOAB/trunk/EntitySequenceManager.hpp
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MeshSetSequence.cpp
   MOAB/trunk/MeshSetSequence.hpp
Log:
Saving some work on changing entity handles, will pick up again after
Jason's dense tag modification work gets committed.  Shouldn't affect
any working apps.
Modified: MOAB/trunk/EntitySequence.cpp
--- MOAB/trunk/EntitySequence.cpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/EntitySequence.cpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -53,7 +53,6 @@
   mLastDeletedIndex = -1;
 MBEntitySequence::~MBEntitySequence()
@@ -129,6 +128,11 @@
   return new_handle;
+MBErrorCode VertexEntitySequence::allocate_handle(MBEntityHandle handle)
+  return MB_FAILURE;
 void VertexEntitySequence::free_handle(MBEntityHandle handle)
@@ -302,6 +306,11 @@
   return new_handle;
+MBErrorCode ElementEntitySequence::allocate_handle(MBEntityHandle handle)
 void ElementEntitySequence::free_handle(MBEntityHandle handle)
   if(!is_valid_entity(handle))
Modified: MOAB/trunk/EntitySequence.hpp
--- MOAB/trunk/EntitySequence.hpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/EntitySequence.hpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -103,6 +103,9 @@
 protected:
+    //! allocate the handle passed in, effectively creating the entity
+  virtual MBErrorCode allocate_handle(MBEntityHandle handle) = 0;
   EntitySequenceManager* mSequenceManager;
   //!id to 1st element in EntitySequence
@@ -162,6 +165,11 @@
   virtual void get_memory_use( unsigned long& used, unsigned long& allocated ) const;
   virtual unsigned long get_memory_use( MBEntityHandle handle ) const;
+protected:
+  virtual MBErrorCode allocate_handle(MBEntityHandle handle);
 private:
   // coordinate arrays x,y,z
@@ -218,6 +226,9 @@
 protected:
   unsigned short mNodesPerElement;
   MBEntityHandle* mElements;
Modified: MOAB/trunk/EntitySequenceManager.cpp
--- MOAB/trunk/EntitySequenceManager.cpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/EntitySequenceManager.cpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -382,6 +382,11 @@
   return MB_SUCCESS;
+//MBErrorCode EntitySequenceManager::allocate_handle( MBEntityHandle handle, unsigned flags )
+//  return MB_FAILURE;
 MBErrorCode EntitySequenceManager::allocate_mesh_set( MBEntityHandle handle, unsigned flags )
   std::map<MBEntityHandle, MBEntitySequence*>::iterator seq_itr;
Modified: MOAB/trunk/EntitySequenceManager.hpp
--- MOAB/trunk/EntitySequenceManager.hpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/EntitySequenceManager.hpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -108,6 +108,12 @@
                              const double coords[3],
                              MBEntityHandle& vertex );
+  //! creates a vertex in the database with specified id
+  MBErrorCode create_vertex( const unsigned processor_id,
+                             const unsigned entity_id,
+                             const double coords[3],
+                             MBEntityHandle& vertex ) {return MB_FAILURE;}
   //! creates an element in the database
   MBErrorCode create_element( MBEntityType type,
@@ -115,6 +121,14 @@
                               const unsigned num_vertices,
                               MBEntityHandle& element);
+  //! creates an element in the database with specified id
+  MBErrorCode create_element( MBEntityType type,
+                              const unsigned processor_id,
+                              const MBEntityHandle *conn_array,
+                              const unsigned num_vertices,
+                              MBEntityHandle& element) {return MB_FAILURE;}
   MBErrorCode create_mesh_set( unsigned proc_id,
                                unsigned flags,
                                MBEntityHandle& h );
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/MBCore.cpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -2324,13 +2324,32 @@
                               MBEntityHandle *entities,
                               int num_entities)
-  if (0 == meshset) return false;
+  return false;
+    // if a regular entity set, we're simply changing contents of this set
+  if (0 != meshset) {
-  MBMeshSet* set = get_mesh_set( sequence_manager(), meshset );
-  if (set)
-    return set->replace_entities( meshset, entities, num_entities, a_entity_factory() );
-  else
-    return false;
+    MBMeshSet* set = get_mesh_set( sequence_manager(), meshset );
+    if (set)
+      return set->replace_entities( meshset, entities, num_entities, a_entity_factory() );
+    else
+      return false;
+    // otherwise, we're actually changing an entity's handle
+    // in preparation, get all the non-tracking sets
+  MBRange tmp_sets, all_sets;
+  MBErrorCode result = get_entities_by_type(0, MBENTITYSET, tmp_sets);
+  if (MB_SUCCESS != result) return result;
+  unsigned int option;
+  for (MBRange::iterator rit = tmp_sets.begin(); rit != tmp_sets.end(); rit++)
+    if (MB_SUCCESS == get_meshset_options(*rit, option) &&
+        !(option & MESHSET_TRACK_OWNER))
+      all_sets.insert(*rit);
+    // now replace each entity
+  double coords[3];
 MBErrorCode MBCore::get_parent_meshsets(const MBEntityHandle meshset,
Modified: MOAB/trunk/MeshSetSequence.cpp
--- MOAB/trunk/MeshSetSequence.cpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/MeshSetSequence.cpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -83,8 +83,7 @@
   return 0;
-MBErrorCode MeshSetSequence::add_meshset( MBEntityHandle handle, unsigned flags )
+MBErrorCode MeshSetSequence::add_meshset(MBEntityHandle handle, unsigned flags)
   if (handle < get_start_handle() || handle > get_end_handle())
     return MB_INDEX_OUT_OF_RANGE;
@@ -115,17 +114,22 @@
     // initialze entity set
   allocate_set( flags, index );
   mNumEntities++;
   if (mNumEntities == mNumAllocated) {
     mSequenceManager->notify_full(this);
     std::vector<bool> empty;
     mFreeEntities.swap( empty);
   return MB_SUCCESS;
+MBErrorCode MeshSetSequence::allocate_handle(MBEntityHandle handle)
 MBEntityHandle MeshSetSequence::add_meshset( unsigned flags )
   if (mFirstFreeIndex == -1)
Modified: MOAB/trunk/MeshSetSequence.hpp
--- MOAB/trunk/MeshSetSequence.hpp	2007-10-30 19:14:57 UTC (rev 1348)
+++ MOAB/trunk/MeshSetSequence.hpp	2007-10-31 17:43:34 UTC (rev 1349)
@@ -67,6 +67,10 @@
   MBErrorCode is_valid() const;
+protected:
 private:
   void initialize( EntitySequenceManager* seq_man,
