[MOAB-dev] r1331 - MOAB/trunk
dcthomp at mcs.anl.gov
Wed Oct 24 14:41:42 CDT 2007
Author: dcthomp
Date: 2007-10-24 14:41:42 -0500 (Wed, 24 Oct 2007)
New Revision: 1331
Modified:
MOAB/trunk/MBOrientedBox.cpp
MOAB/trunk/MBOrientedBox.hpp
MOAB/trunk/MBOrientedBoxTreeTool.cpp
MOAB/trunk/configure.in
Log:
STYLE: s/covarience/covariance/g, whitespace cleanup
Modified: MOAB/trunk/MBOrientedBox.cpp
--- MOAB/trunk/MBOrientedBox.cpp 2007-10-24 19:38:38 UTC (rev 1330)
+++ MOAB/trunk/MBOrientedBox.cpp 2007-10-24 19:41:42 UTC (rev 1331)
@@ -300,7 +300,7 @@
return box_from_axes( result, instance, vertices );
-MBErrorCode MBOrientedBox::covarience_data_from_tris( CovarienceData& result,
+MBErrorCode MBOrientedBox::covariance_data_from_tris( CovarienceData& result,
MBInterface* instance,
const MBRange& elements )
@@ -354,7 +354,7 @@
// Get orientation data from elements
CovarienceData data;
- MBErrorCode rval = covarience_data_from_tris( data, instance, elements );
+ MBErrorCode rval = covariance_data_from_tris( data, instance, elements );
if (MB_SUCCESS != rval)
return rval;
@@ -365,10 +365,10 @@
return rval;
// Calculate box given points and orientation data
- return compute_from_covarience_data( result, instance, data, points );
+ return compute_from_covariance_data( result, instance, data, points );
-MBErrorCode MBOrientedBox::compute_from_covarience_data(
+MBErrorCode MBOrientedBox::compute_from_covariance_data(
MBOrientedBox& result,
CovarienceData& data,
@@ -413,7 +413,7 @@
#endif
-MBErrorCode MBOrientedBox::compute_from_covarience_data( MBOrientedBox& result,
+MBErrorCode MBOrientedBox::compute_from_covariance_data( MBOrientedBox& result,
MBInterface* moab_instance,
const CovarienceData* data,
unsigned data_length,
@@ -427,7 +427,7 @@
data_sum.area += data->area;
// Compute box from sum of structs
- return compute_from_covarience_data( result, moab_instance, data_sum, vertices );
+ return compute_from_covariance_data( result, moab_instance, data_sum, vertices );
Modified: MOAB/trunk/MBOrientedBox.hpp
--- MOAB/trunk/MBOrientedBox.hpp 2007-10-24 19:38:38 UTC (rev 1330)
+++ MOAB/trunk/MBOrientedBox.hpp 2007-10-24 19:41:42 UTC (rev 1331)
@@ -92,25 +92,25 @@
const MBRange& elements );
/** Structure to hold temporary accumulated triangle data for
- * caculating box orietation. See box_from_covarience_data
- * to see how this is used to calculate the final covarience matrix
+ * caculating box orietation. See box_from_covariance_data
+ * to see how this is used to calculate the final covariance matrix
* and resulting box orientation.
struct CovarienceData {
- MBMatrix3 matrix; //!< Running sum for covarience matrix
+ MBMatrix3 matrix; //!< Running sum for covariance matrix
MBCartVect center; //!< Sum of triangle centroids weighted by 2*triangle area
double area; //!< 2x the sum of the triangle areas
/** Calculate a CovarienceData struct from a list of triangles */
- static MBErrorCode covarience_data_from_tris( CovarienceData& result,
+ static MBErrorCode covariance_data_from_tris( CovarienceData& result,
/** Calculate an MBOrientedBox given an arrray of CovarienceData and
* the list of vertices the box is to bound.
- static MBErrorCode compute_from_covarience_data( MBOrientedBox& result,
+ static MBErrorCode compute_from_covariance_data( MBOrientedBox& result,
const CovarienceData* orient_array,
unsigned orient_array_length,
@@ -145,7 +145,7 @@
/** Calculate an MBOrientedBox given a CovarienceData struct and
* the list of points the box is to bound.
CovarienceData& orientation_data,
const MBRange& vertices );
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp 2007-10-24 19:38:38 UTC (rev 1330)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp 2007-10-24 19:41:42 UTC (rev 1331)
@@ -143,7 +143,7 @@
data.push_back( SetData() );
SetData& set_data = data.back();
set_data.handle = *i;
- rval = MBOrientedBox::covarience_data_from_tris( set_data.box_data, instance, elements );
+ rval = MBOrientedBox::covariance_data_from_tris( set_data.box_data, instance, elements );
return rval;
@@ -342,7 +342,7 @@
return rval;
- rval = MBOrientedBox::compute_from_covarience_data( box, instance, &data[0], data.size(), points );
+ rval = MBOrientedBox::compute_from_covariance_data( box, instance, &data[0], data.size(), points );
return rval;
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2007-10-24 19:38:38 UTC (rev 1330)
+++ MOAB/trunk/configure.in 2007-10-24 19:41:42 UTC (rev 1331)
@@ -562,9 +562,9 @@
SNL_CHECK_LIB_LIST([vtkmetaio], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
SNL_CHECK_LIB_LIST([vtkIO], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
SNL_CHECK_LIB_LIST([vtkRendering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
SNL_CHECK_LIB_LIST([vtkHybrid], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ SNL_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
# Make sure we found at least vtkCommon and vtkRendering
if ! echo "x $vtk_libs" | grep lvtkCommon >/dev/null; then
