[MOAB-dev] r1317 - MOAB/trunk/cmake
dcthomp at mcs.anl.gov
Sat Oct 20 00:40:30 CDT 2007
Author: dcthomp
Date: 2007-10-20 00:40:29 -0500 (Sat, 20 Oct 2007)
New Revision: 1317
Modified:
MOAB/trunk/cmake/FindCGM.cmake
Log:
COMP: Given the CGM toplevel build/source, properly compute
the include_directories required...
Modified: MOAB/trunk/cmake/FindCGM.cmake
--- MOAB/trunk/cmake/FindCGM.cmake 2007-10-20 00:02:19 UTC (rev 1316)
+++ MOAB/trunk/cmake/FindCGM.cmake 2007-10-20 05:40:29 UTC (rev 1317)
@@ -79,9 +79,16 @@
endif ( NOT CGM_LIBRARIES )
if ( CGM_SOURCE_DIR AND CGM_BINARY_DIR AND NOT CGM_INCLUDE_DIRECTORIES )
+ set( cubit_geom_SOURCE_DIR "${CGM_SOURCE_DIR}/geom" )
+ set( cubit_geom_BINARY_DIR "${CGM_BINARY_DIR}/geom" )
+ set( cubit_util_SOURCE_DIR "${CGM_SOURCE_DIR}/util" )
+ set( cubit_util_BINARY_DIR "${CGM_BINARY_DIR}/util" )
+ set( cgma_init_SOURCE_DIR "${CGM_SOURCE_DIR}/init" )
+ set( cgma_init_BINARY_DIR "${CGM_BINARY_DIR}/init" )
set( CGM_INCLUDE_DIRECTORIES
- "${CGM_SOURCE_DIR}/util"
- "${CGM_SOURCE_DIR}/geom"
+ "${cubit_util_SOURCE_DIR}"
+ "${cubit_util_BINARY_DIR}"
+ "${cubit_geom_SOURCE_DIR}"
"${cubit_geom_SOURCE_DIR}/ACIS"
"${cubit_geom_SOURCE_DIR}/Cholla"
"${cubit_geom_SOURCE_DIR}/facet"
@@ -90,8 +97,9 @@
"${cubit_geom_SOURCE_DIR}/parallel"
"${cubit_geom_SOURCE_DIR}/SolidWorks"
"${cubit_geom_SOURCE_DIR}/virtual"
- "${CGM_BINARY_DIR}/util"
- "${CGM_BINARY_DIR}/geom"
+ "${cubit_geom_BINARY_DIR}"
+ "${cgma_init_SOURCE_DIR}"
+ "${cgma_init_BINARY_DIR}"
CACHE PATH "Paths to util/CubitUtilConfigure.h.in, util/CubitUtilConfigure.h, geom/CubitGeomConfigure.h.in, AND geom/CubitGeomConfigure.h files." FORCE
endif ( CGM_SOURCE_DIR AND CGM_BINARY_DIR AND NOT CGM_INCLUDE_DIRECTORIES )
