[MOAB-dev] r1311 - in MOAB/trunk: . parallel tools/dagmc
tautges at mcs.anl.gov
Fri Oct 12 14:02:11 CDT 2007
Author: tautges
Date: 2007-10-12 14:02:11 -0500 (Fri, 12 Oct 2007)
New Revision: 1311
Modified:
MOAB/trunk/DenseTagCollections.cpp
MOAB/trunk/DenseTagCollections.hpp
MOAB/trunk/FileOptions.cpp
MOAB/trunk/FileOptions.hpp
MOAB/trunk/MBSkinner.cpp
MOAB/trunk/MBSkinner.hpp
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/mbparallelcomm_test.cpp
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/ReadParallel.cpp
MOAB/trunk/parallel/ReadParallel.hpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
Various fixes and enhancements to parallel reading, including using
arbitrary specified partition & values.
Passes make check, except for dagmc check, which I probably broke
yesterday.
MBSkinner.cpp: added option to create vertex-element adjacencies if
they're not there, to speed up skin finding.
ReadNCDF.cpp: now handles case where there isn't a node number map
(which cubit doesn't generate).
mbparallelcomm_test.cpp:
- added option to input tag name and optional value(s) to determine
partition. This allows one to partition on GEOM_DIMENSION tag, for
example. This option is enabled using the PARTITION_VAL=<ints> option
substring, where <ints> is a comma-separated list of ints or int
ranges (e.g. 1-6).
DenseTagCollections.cpp: changed get_entities_by_type_and_tag to only
check values on a DensePage if that page has been allocated
FileOptions: added get_ints_list function
parallel/MBParallelComm.cpp: added debugging output; allow skinner to
create vert-element adjs when resolving shared entities; added another
function to check for global ids, based only on whether the tag exists
yet.
parallel/ReadParallel.cpp: moved functionality to create global ids
for vertices here from ReadNCDF. Now, when using a BCAST or
BCAST_DELETE mode, and global ids haven't been found in the file set
read in, they're created before the bcast. Added code to parse the
PARTITION_VALS option, which allowed me to remove the special case
processing for the PARTITION_TAG.
DagMC.hpp: fixing dimensioning of options vector
Modified: MOAB/trunk/DenseTagCollections.cpp
--- MOAB/trunk/DenseTagCollections.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/DenseTagCollections.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -197,25 +197,27 @@
const void* value,
MBRange &entities)
- void* test_data = malloc(mBytesPerFlag);
// for now, return if default value is requested
if (mDefaultValue && !memcmp(value,mDefaultValue,mBytesPerFlag))
return MB_FAILURE;
- int dum = 0;
+ // iterate over dense pages
+ std::vector<DensePage>::iterator page_it;
+ const std::vector<DensePage>::iterator end = mDensePages[type].end();
+ int dum =0;
MBEntityHandle handle = CREATE_HANDLE(type, MB_START_ID, dum);
- MBEntityHandle end_handle = handle + mDensePages[type].size() * DensePage::mPageSize;
MBRange::iterator insert_iter = entities.begin();
- for(; handle < end_handle; handle++)
+ for(page_it = mDensePages[type].begin(); page_it != end;
+ ++page_it, handle += DensePage::mPageSize)
- MBErrorCode result = get_data(handle, test_data);
- if(result == MB_SUCCESS && !memcmp(test_data, value, mBytesPerFlag))
- insert_iter = entities.insert(insert_iter, handle, handle);
+ if (page_it->has_data()) {
+ for (int i = 1; i <= DensePage::mPageSize; i++) {
+ if (!page_it->memcmp(i, mBytesPerFlag, value))
+ entities.insert(handle+i-1);
- free(test_data);
return MB_SUCCESS;
Modified: MOAB/trunk/DenseTagCollections.hpp
--- MOAB/trunk/DenseTagCollections.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/DenseTagCollections.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -19,6 +19,12 @@
* File : DenseTagCollections.hpp
* Creator: Clinton Stimpson
* Date : 10-28-2002
+ * DenseTagSuperCollection: contains a vector of DensePageGroup objects
+ * DensePageGroup: vector of vectors of DensePage objects, one vector per
+ * entity type, blocking possible handles in the type
+ * DensePage: block of values corresponding to a block of handles of a given
+ * type; may or may not have data allocated
#ifndef DENSE_TAG_COLLECTIONS_HPP
@@ -69,6 +75,8 @@
//! return whether has data or not
bool has_data() const { return mByteArray != 0; }
+ //! do a memcmp on one of the values in this page
+ bool memcmp(int offset, int num_bytes_per_flag, const void *data);
//!std::auto_ptr-style behavior
DensePage( const DensePage& other )
@@ -108,6 +116,15 @@
return MB_SUCCESS;
+//! do a memcmp on one of the values in this page
+inline bool DensePage::memcmp(int offset, int num_bytes_per_flag, const void *data)
+ // if no memory has been allocated, get the default value
+ assert(mByteArray);
+ return ::memcmp(mByteArray + offset*num_bytes_per_flag, data, num_bytes_per_flag);
/*! set the bytes in a page
takes byte offset into the page
takes how many bytes to set
Modified: MOAB/trunk/FileOptions.cpp
--- MOAB/trunk/FileOptions.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/FileOptions.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -129,6 +129,49 @@
return MB_SUCCESS;
+MBErrorCode FileOptions::get_ints_option( const char* name,
+ std::vector<int>& values) const
+ const char* s;
+ MBErrorCode rval = get_option( name, s );
+ if (MB_SUCCESS != rval)
+ return rval;
+ // empty string
+ if (strempty(s))
+ return MB_TYPE_OUT_OF_RANGE;
+ // parse values
+ while (!strempty(s)) {
+ char* endptr;
+ long int sval = strtol( s, &endptr, 0 );
+#define EATSPACE(a) while ((!strcmp(a, " ") || \
+ !strcmp(a, ",")) && !strempty(a)) a++;
+ EATSPACE(endptr);
+ long int eval = sval;
+ if (!strcmp(endptr, "-")) {
+ endptr++;
+ s = endptr;
+ eval = strtol(s, &endptr, 0);
+ EATSPACE(endptr);
+ // check for overflow (parsing long int, returning int)
+ int value = sval;
+ if (sval != (long int)value)
+ value = eval;
+ if (eval != (long int)value)
+ for (int i = sval; i <= eval; i++)
+ values.push_back(i);
+ return MB_SUCCESS;
MBErrorCode FileOptions::get_real_option ( const char* name, double& value ) const
const char* s;
Modified: MOAB/trunk/FileOptions.hpp
--- MOAB/trunk/FileOptions.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/FileOptions.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -116,10 +116,11 @@
MBErrorCode match_option( const char* name, const char* const* values, int& index ) const;
- /**\brief Check for option for which the value is an ID list
+ /**\brief Check for option for which the value is a list of ints
- * Check for and remove an ID list option. The value is expected to
- * be a comma-separated list of ID ranges, where an ID range can be
+ * Check for and remove an options which is an int list. The value is
+ * expected to
+ * be a comma-separated list of int ranges, where an int range can be
* either a single integer value or a range of integer values separated
* by a dash ('-').
@@ -130,7 +131,7 @@
* - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list
* - MB_ENTITY_NOT_FOUND if option is not found.
- //MBErrorCode get_id_list_option( const char* name, std::vector<unsigned>& value, bool remove = true );
+ MBErrorCode get_ints_option( const char* name, std::vector<int>& values) const;
/** number of options */
inline unsigned size() const
Modified: MOAB/trunk/MBSkinner.cpp
--- MOAB/trunk/MBSkinner.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/MBSkinner.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -52,7 +52,7 @@
-void MBSkinner::initialize(const bool use_adjs)
+void MBSkinner::initialize()
// go through and mark all the target dimension entities
// that already exist as not deleteable
@@ -64,40 +64,33 @@
void* null_ptr = NULL;
MBErrorCode result;
- if(mAdjTag == 0 && !use_adjs)
- result = thisMB->tag_create("skinner adj", sizeof(void*), MB_TAG_DENSE, mAdjTag, &null_ptr);
- assert(MB_SUCCESS == result);
+ result = thisMB->tag_create("skinner adj", sizeof(void*), MB_TAG_DENSE, mAdjTag, &null_ptr);
+ assert(MB_SUCCESS == result);
- if(mDeletableMBTag == 0 && !use_adjs) {
+ if(mDeletableMBTag == 0) {
result = thisMB->tag_create("skinner deletable", 1, MB_TAG_BIT, mDeletableMBTag, NULL);
MBRange entities;
- // only need to mark entities if we're not using adjacencies
- if (!use_adjs) {
- // go through each type at this dimension
- for(type = target_ent_types.first; type <= target_ent_types.second; ++type)
+ // go through each type at this dimension
+ for(type = target_ent_types.first; type <= target_ent_types.second; ++type)
+ // get the entities of this type in the MB
+ thisMB->get_entities_by_type(0, type, entities);
+ // go through each entity of this type in the MB
+ // and set its deletable tag to NO
+ MBRange::iterator iter, end_iter;
+ end_iter = entities.end();
+ for(iter = entities.begin(); iter != end_iter; ++iter)
- // get the entities of this type in the MB
- thisMB->get_entities_by_type(0, type, entities);
- // go through each entity of this type in the MB
- // and set its deletable tag to NO
- MBRange::iterator iter, end_iter;
- end_iter = entities.end();
- for(iter = entities.begin(); iter != end_iter; ++iter)
- unsigned char bit = 0x1;
- result = thisMB->tag_set_data(mDeletableMBTag, &(*iter), 1, &bit);
- // add adjacency information too
- add_adjacency(*iter);
+ unsigned char bit = 0x1;
+ result = thisMB->tag_set_data(mDeletableMBTag, &(*iter), 1, &bit);
+ // add adjacency information too
+ add_adjacency(*iter);
@@ -231,8 +224,9 @@
MBErrorCode MBSkinner::find_skin(const MBRange &source_entities,
- MBRange &forward_target_entities,
- MBRange &reverse_target_entities)
+ MBRange &forward_target_entities,
+ MBRange &reverse_target_entities,
+ bool create_vert_elem_adjs)
if(source_entities.empty())
return MB_FAILURE;
@@ -248,11 +242,14 @@
MBCore *this_core = dynamic_cast<MBCore*>(thisMB);
bool use_adjs = false;
+ if (!this_core->a_entity_factory()->vert_elem_adjacencies() &&
+ create_vert_elem_adjs)
+ this_core->a_entity_factory()->create_vert_elem_adjacencies();
if (this_core->a_entity_factory()->vert_elem_adjacencies())
use_adjs = true;
- // initialize
- initialize(use_adjs);
+ else initialize();
MBRange::const_iterator iter, end_iter;
end_iter = source_entities.end();
@@ -867,18 +864,25 @@
// get skin entities of prescribed dimension
MBErrorCode MBSkinner::find_skin(const MBRange &entities,
int dim,
- MBRange &skin_entities)
+ MBRange &skin_entities,
if (MBCN::Dimension(TYPE_FROM_HANDLE(*entities.begin())) !=
MBCN::Dimension(TYPE_FROM_HANDLE(*entities.rbegin())))
return MB_FAILURE;
MBRange tmp_skin_for, tmp_skin_rev;
- MBErrorCode result = find_skin(entities, tmp_skin_for, tmp_skin_rev);
+ MBErrorCode result = find_skin(entities, tmp_skin_for, tmp_skin_rev,
+ create_vert_elem_adjs);
if (MB_SUCCESS != result) return result;
tmp_skin_for.merge(tmp_skin_rev);
- result = thisMB->get_adjacencies(tmp_skin_for, dim, true, skin_entities);
+ if (MBCN::Dimension(TYPE_FROM_HANDLE(*tmp_skin_for.begin())) != dim ||
+ MBCN::Dimension(TYPE_FROM_HANDLE(*tmp_skin_for.rbegin())) != dim)
+ result = thisMB->get_adjacencies(tmp_skin_for, dim, true, skin_entities);
+ else
+ skin_entities.swap(tmp_skin_for);
return result;
Modified: MOAB/trunk/MBSkinner.hpp
--- MOAB/trunk/MBSkinner.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/MBSkinner.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -46,13 +46,15 @@
// will accept entities all of one dimension
// and return entities of n-1 dimension
MBErrorCode find_skin( const MBRange &entities,
- MBRange &forward_lower_entities,
- MBRange &reverse_lower_entities);
+ MBRange &forward_lower_entities,
+ MBRange &reverse_lower_entities,
+ bool create_vert_elem_adjs = false);
MBErrorCode find_skin(const MBRange &entities,
int dim,
- MBRange &skin_entities);
MBErrorCode classify_2d_boundary( const MBRange &boundary,
const MBRange &bar_elements,
@@ -74,7 +76,7 @@
protected:
- void initialize(const bool use_adjs = false);
+ void initialize();
void deinitialize();
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/ReadNCDF.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -981,28 +981,28 @@
ptr = new int [numberNodes_loading];
- temp_var = ncFile->get_var("node_num_map");
- if (NULL == temp_var || !temp_var->is_valid()) {
- readMeshIface->report_error("ReadNCDF:: Problem getting node number map variable.");
- delete [] ptr;
- return MB_FAILURE;
+ int varid = -1;
+ int cstatus = nc_inq_varid (ncFile->id(), "node_num_map", &varid);
+ if (cstatus == NC_NOERR && varid != -1) {
+ temp_var = ncFile->get_var("node_num_map");
+ status = temp_var->get(ptr, numberNodes_loading);
+ if (0 == status) {
+ readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
+ delete [] ptr;
+ return MB_FAILURE;
+ MBRange range(MB_START_ID+vertexOffset,
+ MB_START_ID+vertexOffset+numberNodes_loading-1);
+ MBErrorCode error = mdbImpl->tag_set_data(mGlobalIdTag,
+ range, &ptr[0]);
+ if (MB_SUCCESS != error)
+ readMeshIface->report_error("ReadNCDF:: Problem setting node global ids.");
- status = temp_var->get(ptr, numberNodes_loading);
- if (0 == status) {
- readMeshIface->report_error("ReadNCDF:: Problem getting node number map data.");
- delete [] ptr;
- MBRange range(1+vertexOffset, 1+vertexOffset+numberNodes_loading-1);
- MBErrorCode error = mdbImpl->tag_set_data(mGlobalIdTag,
- range, &ptr[0]);
- if (MB_SUCCESS != error)
- readMeshIface->report_error("ReadNCDF:: Problem setting node global ids.");
delete [] ptr;
- return error;
MBErrorCode ReadNCDF::read_nodesets()
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/mbparallelcomm_test.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -15,6 +15,7 @@
#include "EntitySequenceManager.hpp"
#include "mpi.h"
#include <iostream>
+#include <sstream>
#define REALTFI 1
@@ -32,7 +33,8 @@
MBErrorCode create_scd_mesh(MBInterface *mbImpl,
int IJK, int &nshared);
-MBErrorCode read_file(MBInterface *mbImpl, const char *filename);
+MBErrorCode read_file(MBInterface *mbImpl, const char *filename,
+ const char *tag_name, int tag_val);
int main(int argc, char **argv)
@@ -93,8 +95,11 @@
else if (2 == i && argc > 4) {
// read a file in parallel from the filename on the command line
- tmp_result = read_file(mbImpl, argv[4]);
+ const char *tag_name = NULL;
+ int tag_val = -1;
+ if (argc > 5) tag_name = argv[5];
+ if (argc > 6) tag_val = strtol(argv[6], NULL, 0);
+ tmp_result = read_file(mbImpl, argv[4], tag_name, tag_val);
if (MB_SUCCESS != tmp_result) {
result = tmp_result;
std::cerr << "Couldn't read mesh; error message:" << std::endl;
@@ -166,12 +171,19 @@
return (MB_SUCCESS == result ? 0 : 1);
- std::string options = "PARALLEL=BCAST_DELETE;PARTITION=MATERIAL_SET";
+ std::ostringstream options("PARALLEL=BCAST_DELETE;PARTITION=");
+ if (NULL == tag_name) options << "MATERIAL_SET";
+ else options << tag_name;
+ if (-1 != tag_val)
+ options << ";PARTITION_VAL=" << tag_val;
MBEntityHandle file_set;
MBErrorCode result = mbImpl->load_file(filename, file_set,
- options.c_str());
+ options.str().c_str());
return result;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -11,8 +11,12 @@
#include "MBCore.hpp"
#include "MBError.hpp"
+#include <iostream>
#define MAX_SHARING_PROCS 10
+const bool debug = true;
extern "C"
#include "gs.h"
@@ -82,16 +86,18 @@
//! assign a global id space, for largest-dimension or all entities (and
//! in either case for vertices too)
-MBErrorCode MBParallelComm::assign_global_ids(const int dimension,
+MBErrorCode MBParallelComm::assign_global_ids(MBEntityHandle this_set,
+ const int dimension,
const int start_id,
- const bool largest_dim_only)
+ const bool largest_dim_only,
+ const bool parallel)
MBRange entities[4];
int local_num_elements[4];
MBErrorCode result;
for (int dim = 0; dim <= dimension; dim++) {
if (dim == 0 || !largest_dim_only || dim == dimension) {
- result = mbImpl->get_entities_by_dimension(0, dim, entities[dim]);
+ result = mbImpl->get_entities_by_dimension(this_set, dim, entities[dim]);
RR("Failed to get vertices in assign_global_ids.");
@@ -109,7 +115,7 @@
// communicate numbers
std::vector<int> num_elements(procConfig.proc_size()*4);
#ifdef USE_MPI
- if (procConfig.proc_size() > 1) {
+ if (procConfig.proc_size() > 1 && parallel) {
int retval = MPI_Alltoall(local_num_elements, 4, MPI_INTEGER,
&num_elements[0], procConfig.proc_size()*4,
MPI_INTEGER, procConfig.proc_comm());
@@ -126,7 +132,7 @@
for (int dim = 0; dim < 4; dim++) total_elems[dim] += num_elements[4*proc + dim];
- //.assign global ids now
+ //assign global ids now
MBTag gid_tag;
int zero = 0;
result = mbImpl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int),
@@ -1062,6 +1068,8 @@
MBErrorCode MBParallelComm::resolve_shared_ents(MBRange &proc_ents,
int shared_dim)
+ if (debug) std::cerr << "Resolving shared entities." << std::endl;
MBRange::iterator rit;
MBSkinner skinner(mbImpl);
@@ -1076,8 +1084,9 @@
// start with skin entities
skin_dim = upper_dim-1;
result = skinner.find_skin(proc_ents, skin_ents[skin_dim],
- skin_ents[skin_dim]);
+ skin_ents[skin_dim], true);
RR("Failed to find skin.");
+ if (debug) std::cerr << "Found skin, now resolving." << std::endl;
else {
// otherwise start with original entities
@@ -1106,7 +1115,7 @@
else if (MB_ALREADY_ALLOCATED != result) {
// just created it, so we need global ids
- result = assign_global_ids(upper_dim);
+ result = assign_global_ids(0, upper_dim);
RR("Failed assigning global ids.");
@@ -1308,6 +1317,32 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::check_global_ids(MBEntityHandle this_set,
+ const int start_id,
+ // global id tag
+ MBTag gid_tag; int def_val = -1;
+ MBErrorCode result = mbImpl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int),
+ MB_TAG_DENSE, MB_TYPE_INTEGER, gid_tag,
+ &def_val, true);
+ if (MB_ALREADY_ALLOCATED != result &&
+ MB_SUCCESS != result) {
+ RR("Failed to create/get gid tag handle.");
+ else if (MB_ALREADY_ALLOCATED != result) {
+ // just created it, so we need global ids
+ result = assign_global_ids(this_set, dimension, start_id, largest_dim_only,
+ parallel);
+ RR("Failed assigning global ids.");
+ return result;
#ifdef TEST_PARALLELCOMM
#include <iostream>
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -47,10 +47,21 @@
- MBErrorCode assign_global_ids(const int dimension,
+ MBErrorCode assign_global_ids(MBEntityHandle this_set,
const int start_id = 1,
- const bool largest_dim_only = true);
+ const bool largest_dim_only = true,
+ const bool parallel = true);
+ //! check for global ids; based only on tag handle being there or not;
+ //! if it's not there, create them for the specified dimensions
+ MBErrorCode check_global_ids(MBEntityHandle this_set,
+ const int start_id = 1,
//! communicate entities from/to this range
MBErrorCode communicate_entities(const int from_proc, const int to_proc,
MBRange &entities,
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -9,6 +9,10 @@
#include "MBParallelConventions.h"
#include "MBCN.hpp"
#define RR(a) if (MB_SUCCESS != result) {\
dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(a);\
return result;}
@@ -47,6 +51,10 @@
if (MB_ENTITY_NOT_FOUND == result || partition_tag_name.empty())
partition_tag_name += "PARTITION";
+ // Get partition tag value(s), if any
+ std::vector<int> partition_tag_vals;
+ result = opts.get_ints_option("PARTITION_VAL", partition_tag_vals);
// get MPI IO processor rank
int reader_rank;
result = opts.get_int_option( "MPI_IO_RANK", reader_rank );
@@ -110,9 +118,16 @@
if (parallel_mode == POPT_BCAST ||
parallel_mode == POPT_BCAST_DELETE) {
MBRange entities;
+ MBParallelComm pcom( mbImpl);
// get which entities need to be broadcast, only if I'm the reader
if (reader_rank == (int)(mbImpl->proc_rank())) {
+ // if I'm root, check to make sure we have global ids (at least for
+ // vertices, anyway) & generate (in serial) if not
+ result = pcom.check_global_ids(file_set, 0, 1, true, false);
+ RR("Failed to generate/find global ids for parallel read.");
result = mbImpl->get_entities_by_handle( file_set, entities );
entities.clear();
@@ -137,8 +152,7 @@
// do the actual broadcast; if single-processor, ignore error
- MBParallelComm tool( mbImpl);
- result = tool.broadcast_entities( reader_rank, entities );
+ result = pcom.broadcast_entities( reader_rank, entities );
if (mbImpl->proc_size() == 1 && MB_SUCCESS != result)
result = MB_SUCCESS;
@@ -170,7 +184,9 @@
if (parallel_mode == POPT_BCAST_DELETE ||
parallel_mode == POPT_READ_DELETE) {
- result = delete_nonlocal_entities(partition_tag_name, file_set);
+ result = delete_nonlocal_entities(partition_tag_name,
+ partition_tag_vals,
+ file_set);
@@ -178,6 +194,7 @@
MBErrorCode ReadParallel::delete_nonlocal_entities(std::string &ptag_name,
+ std::vector<int> &ptag_vals,
MBEntityHandle file_set)
MBRange partition_sets, my_sets;
@@ -187,25 +204,16 @@
result = mbImpl->tag_get_handle(ptag_name.c_str(), ptag);
RR("Failed getting tag handle in delete_nonlocal_entities.");
- if (ptag_name == PARALLEL_PARTITION_TAG_NAME) {
- int my_rank = mbImpl->proc_rank(), *my_rank_ptr = &my_rank;
- result = mbImpl->get_entities_by_type_and_tag(file_set, MBENTITYSET,
- &ptag,
- (void* const*) &my_rank_ptr, 1,
- my_sets);
- RR("Couldn't get entities with partition tag.");
- else {
- // no explicit stategy to assign sets, so just balance # sets
- &ptag, NULL, 1,
- partition_sets);
- RR("Failed to get sets with partition-type tag.");
+ result = mbImpl->get_entities_by_type_and_tag(file_set, MBENTITYSET,
+ &ptag, NULL, 1,
+ partition_sets);
+ RR("Failed to get sets with partition-type tag.");
- int proc_sz = mbImpl->proc_size();
- int proc_rk = mbImpl->proc_rank();
+ int proc_sz = mbImpl->proc_size();
+ int proc_rk = mbImpl->proc_rank();
+ if (ptag_vals.empty()) {
+ // no values input, just distribute sets
int num_sets = partition_sets.size() / proc_sz, orig_numsets = num_sets;
if (partition_sets.size() % proc_sz != 0) {
num_sets++;
@@ -217,6 +225,19 @@
for (int i = 0; i < num_sets; i++)
my_sets.insert(partition_sets[istart+i]);
+ else {
+ // values input, get sets with those values
+ std::vector<int> tag_vals(partition_sets.size());
+ result = mbImpl->tag_get_data(ptag, partition_sets, &tag_vals[0]);
+ RR("Failed to get tag data for partition vals tag.");
+ for (std::vector<int>::iterator pit = ptag_vals.begin();
+ pit != ptag_vals.end(); pit++) {
+ std::vector<int>::iterator pit2 = std::find(tag_vals.begin(),
+ tag_vals.end(), *pit);
+ if (pit2 == tag_vals.end()) RR("Couldn't find partition tag value.");
+ my_sets.insert(partition_sets[pit2 - tag_vals.begin()]);
return delete_nonlocal_entities(my_sets, file_set);
@@ -224,6 +245,9 @@
MBErrorCode ReadParallel::delete_nonlocal_entities(MBRange &partition_sets,
+ if (debug) std::cerr << "Deleting non-local entities." << std::endl;
MBErrorCode result;
MBError *merror = ((MBCore*)mbImpl)->get_error_handler();
@@ -263,9 +287,10 @@
deletable_ents = deletable_ents.subtract(deletable_sets);
result = mbImpl->delete_entities(deletable_ents);
RR("Failure deleting entities in delete_nonlocal_entities.");
- result = ((MBCore*)mbImpl)->check_adjacencies();
+// if (debug)
+// result = ((MBCore*)mbImpl)->check_adjacencies();
return result;
Modified: MOAB/trunk/parallel/ReadParallel.hpp
--- MOAB/trunk/parallel/ReadParallel.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/parallel/ReadParallel.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -34,6 +34,7 @@
MBInterface *mbImpl;
MBErrorCode delete_nonlocal_entities(std::string &ptag_name,
MBEntityHandle file_set);
MBErrorCode delete_nonlocal_entities(MBRange &partition_sets,
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2007-10-11 19:30:24 UTC (rev 1310)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2007-10-12 19:02:11 UTC (rev 1311)
@@ -192,7 +192,7 @@
MBOrientedBoxTreeTool obbTree;
MBTag obbTag, geomTag, idTag, nameTag, senseTag;
- Option options[4];
+ Option options[5];
char specReflectName[NAME_TAG_SIZE];
char whiteReflectName[NAME_TAG_SIZE];
