[MOAB-dev] r1304 - MOAB/trunk/tools/dagmc
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Oct 10 09:34:46 CDT 2007
Author: tautges
Date: 2007-10-10 09:34:46 -0500 (Wed, 10 Oct 2007)
New Revision: 1304
Added:
   MOAB/trunk/tools/dagmc/pt_vol_test.cc
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/DagMC.hpp
   MOAB/trunk/tools/dagmc/Makefile.am
   MOAB/trunk/tools/dagmc/cgm2moab.cc
   MOAB/trunk/tools/dagmc/cgm2moab.hpp
   MOAB/trunk/tools/dagmc/test_geom.cc
Log:
1. Adding parsing of useCAD option
2. Adding a facet tolerance option, and passing that to function which
gets faceting from geometry
3. Adding simple test program for pt_in_volume from Paul.  To make,
either do a 'make check' in the root directory of MOAB, or in
tools/dagmc, do a 'make pt_vol_test'.  Run the code w/o arguments to
find usage.
4. Adding Brandon's implicit complement code.
This has not been tested in MCNPX, so that should be done quickly.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-10-10 14:34:46 UTC (rev 1304)
@@ -34,17 +34,21 @@
 DagMC::DagMC(MBInterface *mb_impl)
     : mbImpl(mb_impl), obbTree(mb_impl),
-      moabMCNPTolerance(1e-6), moabMCNPSourceCell(0), moabMCNPUseDistLimit(false)
+      distanceTolerance(1e-6), facetingTolerance(0.001),
+      moabMCNPSourceCell(0), moabMCNPUseDistLimit(false)
   options[0] = Option( "source_cell",        "source cell ID, or zero if unknown", "0" );
   options[1] = Option( "distance_tolerance", "positive real value", "0.001" );
   options[2] = Option( "use_distance_limit", "one to enable distance limit optimization, zero otherwise", "0" );
   options[3] = Option( "use_cad", "one to ray-trace to cad, zero for just facets", "0" );
+  options[4] = Option( "faceting_tolerance", "graphics faceting tolerance", "0.001" );
   memset( specReflectName, 0, NAME_TAG_SIZE );
   strcpy( specReflectName, "spec_reflect" );
   memset( whiteReflectName, 0, NAME_TAG_SIZE );
   strcpy( whiteReflectName, "white_reflect" );
+  memset( implComplName, 0, NAME_TAG_SIZE );
+  strcpy( implComplName , "impl_complement" );
   distanceLimit = std::numeric_limits<double>::max();
@@ -95,7 +99,7 @@
   rval = obbTree.ray_intersect_sets( distances,
                                      surfaces,
                                      root,
-                                     tolerance(),
+                                     distance_tolerance(),
                                      2,
                                      point, dir,
                                      &len);
@@ -104,7 +108,7 @@
 #ifdef CGM
   if (useCAD) {
 #ifdef CUBIT_CGM
-    std::cout << "USE_CAD = 1 not supported with this build of CGM/DagMC;"
+    std::cout << "use_cad = 1 not supported with this build of CGM/DagMC;"
               << std:: endl
               << "need an ACIS-based install of CGM." << std::endl;
     return MB_NOT_IMPLEMENTED;
@@ -128,7 +132,8 @@
   int smallest = std::min_element( distances.begin(), distances.end() ) - distances.begin();
     // If intersected previous surface near start of ray, reject it
-  if (surfaces[smallest] == last_surf_hit && distances[smallest] < tolerance()) {
+  if (surfaces[smallest] == last_surf_hit &&
+      distances[smallest] < distance_tolerance()) {
     distances.erase( distances.begin() + smallest );
     surfaces.erase( surfaces.begin() + smallest );
@@ -176,12 +181,23 @@
     std::cerr << "Invalid source_cell = " << moabMCNPSourceCell << std::endl;
     exit(2);
-  moabMCNPTolerance = strtod( options[1].value.c_str(), 0 );
-  if (moabMCNPTolerance <= 0 || moabMCNPTolerance > 1) {
-    std::cerr << "Invalid distance_tolerance = " << moabMCNPTolerance << std::endl;
+  distanceTolerance = strtod( options[1].value.c_str(), 0 );
+  if (distanceTolerance <= 0 || distanceTolerance > 1) {
+    std::cerr << "Invalid distance_tolerance = " << distanceTolerance << std::endl;
     exit(2);
   moabMCNPUseDistLimit = !!atoi( options[2].value.c_str() );
+  useCAD = !!atoi( options[3].value.c_str() );
+#ifdef CUBIT_CGM
+  if (useCAD) {
+    std::cout << "Warning: use_cad = 1 not supported with this build of "
+              << "CGM/DagMC;" << std:: endl
+              << "need an ACIS-based install of CGM." << std::endl;
+#endif
 void DagMC::read_settings( const char* filename )
@@ -376,7 +392,7 @@
                              int& result )
   MBErrorCode rval;
-  const double epsilon = moabMCNPTolerance;
+  const double epsilon = distanceTolerance;
     // Get OBB Tree for volume
   assert(volume - setOffset < rootSets.size());
@@ -534,6 +550,12 @@
   std::vector<MBEntityHandle> surfaces, surf_volumes;
   result = 0.0;
+   // don't try to calculate volume of implicit complement
+  if (volume == impl_compl_handle) {
+    result = 1.0;
+    return MB_SUCCESS;
     // get surfaces from volume
   rval = moab_instance()->get_child_meshsets( volume, surfaces );
   if (MB_SUCCESS != rval) return rval;
@@ -704,7 +726,7 @@
                 << std::endl;
       exit(2);
-    if (!cgm2moab(moab_instance())) {
+    if (!cgm2moab(moab_instance(), facetingTolerance)) {
       std::cerr << "Internal error copying geometry" << std::endl;
       exit(5);
@@ -751,6 +773,14 @@
     return rval;
+    // If it doesn't already exist, create implicit complement
+    // Create data structures for implicit complement
+  rval = get_impl_compl();
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Failed to find or create implicit complement handle." << std::endl;
+    return rval;
   // Build OBB trees for everything, but only if we only read geometry
   // Changed to build obb tree if tree does not already exist. -- JK
   if (!have_obb_tree()) {
@@ -901,14 +931,28 @@
       const char *cdensity = density_str.c_str();
       int matid = atoi(cmatid);
       double density = atof(cdensity);
-        // Get the volumes in the current group
-      MBRange grp_vols = grp_sets.intersect(vols_save);
-      for (MBRange::iterator rit = grp_vols.begin(); rit != grp_vols.end(); rit++) {
-        MBEntityHandle vol = *rit;
-        int cell_num = index_by_handle(vol);
-        mats[cell_num-1]=matid;
-        dens[cell_num-1]=density;
+        // check for material definition in complement
+      if (grp_names[0].find("comp",0) < 20) {
+        std::cout<<"write_log: complement material and density specified" << std::endl;
+        mats[ncells-1]=matid;
+        dens[ncells-1]=density;
+      else {
+          // Get the volumes in the current group
+        MBRange grp_vols = grp_sets.intersect(vols_save);
+        for (MBRange::iterator rit = grp_vols.begin();
+             rit != grp_vols.end(); rit++) {
+          MBEntityHandle vol = *rit;
+          int cell_num = index_by_handle(vol);
+          mats[cell_num-1]=matid;
+          dens[cell_num-1]=density;
     else if ((grp_names[0].find("spec_reflect",0)==0) ||
              (grp_names[0].find("white_reflect",0)==0)) {
@@ -1215,7 +1259,7 @@
   const double in_pt[] = { xxx, yyy, zzz };
   std::vector<MBEntityHandle> &facets = triList;
   facets.clear();
-  MBErrorCode rval = obbTree.closest_to_location( in_pt, root, tolerance(), facets );
+  MBErrorCode rval = obbTree.closest_to_location( in_pt, root, distance_tolerance(), facets );
   assert(MB_SUCCESS == rval);
   MBCartVect coords[3], normal(0.0);
@@ -1306,9 +1350,14 @@
     // surf/vol offsets are just first handles
   setOffset = (*surfs.begin() < *vols.begin() ? *surfs.begin() : *vols.begin());
-  unsigned int tmp_offset = (surfs.back() > vols.back() ? surfs.back() : vols.back())
-    - setOffset + 1;
-  rootSets.resize(tmp_offset);
+  setOffset = (impl_compl_handle < setOffset ? impl_compl_handle : setOffset);
+    // max
+  unsigned int tmp_offset = (surfs.back() > vols.back() ?
+                             surfs.back() : vols.back());
+  tmp_offset = (impl_compl_handle > tmp_offset ?
+                impl_compl_handle : tmp_offset);
+    // set size
+  rootSets.resize(tmp_offset - setOffset + 1);
   entIndices.resize(rootSets.size());
     // store surf/vol handles lists (surf/vol by index) and
@@ -1317,6 +1366,7 @@
   std::vector<MBEntityHandle>::iterator iter = entHandles[2].begin();
   *(iter++) = 0;
   std::copy( surfs.begin(), surfs.end(), iter );
+  entHandles[3].push_back(impl_compl_handle);
   int idx = 1;
   for (MBRange::iterator rit = surfs.begin(); rit != surfs.end(); rit++)
     entIndices[*rit-setOffset] = idx++;
@@ -1326,9 +1376,22 @@
   *(iter++) = 0;
   std::copy( vols.begin(), vols.end(), iter );
   idx = 1;
-  for (MBRange::iterator rit = vols.begin(); rit != vols.end(); rit++)
+  int max_id = -1;
+  for (MBRange::iterator rit = vols.begin(); rit != vols.end(); rit++)    {
+    int result=0;
+    moab_instance()->tag_get_data( idTag, &*rit, 1, &result );
+    max_id = (max_id > result ? max_id : result);
+    // add implicit complement to entity index
+  entIndices[impl_compl_handle-setOffset] = idx++ ;
+    // assign ID to implicit complement
+  max_id++;
+  moab_instance()->tag_set_data(idTag, &impl_compl_handle, 1, &max_id);
 #ifdef CGM
   if (is_geom) {
     geomEntities.resize(rootSets.size());
@@ -1391,6 +1454,13 @@
   for (i = 0, rit = vols.begin(); rit != vols.end(); rit++, i++)
     rootSets[*rit-setOffset] = rsets[i];
+  // add implicit complement root set
+  rsets.resize(1);
+  rval = moab_instance()->tag_get_data(obb_tag(), &impl_compl_handle, 1,
+                                       &rsets[0]);
+  if (MB_SUCCESS != rval) return MB_FAILURE;
+  rootSets[impl_compl_handle-setOffset] = rsets[0];
   return MB_SUCCESS;
@@ -1456,5 +1526,126 @@
+  rval = build_obb_impl_compl(surfs);
+    std::cerr << "Unable to build OBB tree for implicit complement." << std::endl;
+    return rval;
   return MB_SUCCESS;
+MBErrorCode DagMC::build_obb_impl_compl(MBRange &surfs)
+  MBEntityHandle comp_root, surf_obb_root;
+  MBRange comp_tree;
+  MBErrorCode rval;
+  std::vector<MBEntityHandle> parent_vols;
+    // search through all surfaces
+  for (MBRange::iterator surf_i = surfs.begin(); surf_i != surfs.end(); ++surf_i) {
+    parent_vols.clear();
+      // get parents of each surface
+    rval = moab_instance()->get_parent_meshsets( *surf_i, parent_vols );
+      return rval;
+      // if only one parent, get the OBB root for this surface
+    if (parent_vols.size() == 1 ) {
+      rval = moab_instance()->tag_get_data( obbTag, &*surf_i, 1, &surf_obb_root );
+        return rval;
+      if (!surf_obb_root)
+        return MB_FAILURE;
+        // add obb root to list of obb roots
+      comp_tree.insert( surf_obb_root );
+    // join surface trees to make OBB tree for implicit complement
+  rval = obbTree.join_trees( comp_tree, comp_root );
+    return rval;
+    // tag the implicit complement handle with the handle for its own OBB tree
+  rval = moab_instance()->tag_set_data( obbTag, &impl_compl_handle, 1, &comp_root );
+    return rval;
+MBErrorCode DagMC::getobb(MBEntityHandle volume, double minPt[3],
+                          double maxPt[3])
+  double center[3], axis1[3], axis2[3], axis3[3];
+    // get center point and vectors to OBB faces
+  MBErrorCode rval = getobb(volume, center, axis1, axis2, axis3);
+    return rval;
+    // compute min and max verticies
+  for (int i=0; i<3; i++)
+    minPt[i] = center[i] - (axis1[i] + axis2[i] + axis3[i]);
+    maxPt[i] = center[i] + (axis1[i] + axis2[i] + axis3[i]);
+MBErrorCode DagMC::getobb(MBEntityHandle volume, double center[3], double axis1[3],
+                          double axis2[3], double axis3[3])
+    //find MBEntityHandle node_set for use in box
+  MBEntityHandle root = rootSets[volume - setOffset];
+    // call box to get center and vectors to faces
+  return obbTree.box(root, center, axis1, axis2, axis3);
+MBErrorCode DagMC::get_impl_compl()
+  MBRange entities;
+  const void* const tagdata[] = {implComplName};
+  MBErrorCode rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET,
+                                                           &nameTag, tagdata, 1,
+                                                           entities );
+    std::cerr << "Unable to query for implicit complement." << std::endl;
+    return rval;
+  if (entities.size() > 1) {
+    std::cerr << "Too many implicit complement sets." << std::endl;
+    return MB_MULTIPLE_ENTITIES_FOUND;
+  if (entities.empty()) {
+    rval= moab_instance()->create_meshset(MESHSET_SET,impl_compl_handle);
+      std::cerr << "Failed to create mesh set for implicit complement." << std::endl;
+      return rval;
+      // tag this entity with name for implicit complement
+    rval = moab_instance()->tag_set_data(nameTag,&impl_compl_handle,1,&implComplName);
+      std::cerr << "Failed to tag new entity as implicit complement." << std::endl;
+    return rval;
+  } else {
+    impl_compl_handle = entities.front();
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp	2007-10-10 14:34:46 UTC (rev 1304)
@@ -120,13 +120,23 @@
   MBErrorCode get_angle(MBEntityHandle surf,
                         double xxx, double yyy, double zzz, double *ang);
+    // get the corners of the OBB for a given volume
+  MBErrorCode getobb(MBEntityHandle volume, double minPt[3], double maxPt[3]);
+    // get the center point and three vectors for the OBB of a given volume
+  MBErrorCode getobb(MBEntityHandle volume, double center[3],
+                     double axis1[3], double axis2[3], double axis3[3]);
   int get_entity_id(MBEntityHandle this_ent);
     // Get the instance of MOAB used by functions in this file.
   MBInterface* moab_instance() {return mbImpl;}
-  double tolerance() {return moabMCNPTolerance;}
+  double distance_tolerance() {return distanceTolerance;}
+  double faceting_tolerance() {return facetingTolerance;}
   int source_cell() {return moabMCNPSourceCell;}
   bool use_dist_limit() {return moabMCNPUseDistLimit;}
@@ -143,6 +153,8 @@
 private:
   bool have_obb_tree();
+  MBErrorCode get_impl_compl();
   MBTag get_tag( const char* name, int size, MBTagType store, MBDataType type,
                  bool create_if_missing = true);
@@ -156,6 +168,7 @@
     // build obb structure
   MBErrorCode build_obbs(MBRange &surfs, MBRange &vols);
+  MBErrorCode build_obb_impl_compl(MBRange &surfs);
   class Option {
   public:
@@ -176,10 +189,14 @@
   char specReflectName[NAME_TAG_SIZE];
   char whiteReflectName[NAME_TAG_SIZE];
+  char implComplName[NAME_TAG_SIZE];
   std::vector<MBEntityHandle> entHandles[5];
-  double moabMCNPTolerance;
+  MBEntityHandle impl_compl_handle;
+  double distanceTolerance;
+  double facetingTolerance;
   int moabMCNPSourceCell;
   bool moabMCNPUseDistLimit;
   bool useCAD;
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/Makefile.am	2007-10-10 14:34:46 UTC (rev 1304)
@@ -34,8 +34,10 @@
 cfg_DATA = dagmc.make
 TESTS = test_geom
-check_PROGRAMS = $(TESTS)
+check_PROGRAMS = $(TESTS) pt_vol_test
 test_geom_SOURCES = test_geom.cc
 test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LTFLAGS)  $(CGM_LIBS_LINK)
+pt_vol_test_SOURCES = pt_vol_test.cc
+pt_vol_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LTFLAGS)  $(CGM_LIBS_LINK)
Modified: MOAB/trunk/tools/dagmc/cgm2moab.cc
--- MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-10-10 14:34:46 UTC (rev 1304)
@@ -41,7 +41,7 @@
 // copy geometry into mesh database
 bool cgm2moab(MBInterface* iface,
-              double dist_tol,
+              double faceting_tol,
               int norm_tol,
               double len_tol,
               int actuate_attribs)
@@ -285,7 +285,7 @@
     GeometryQueryEngine* gqe = curve->get_geometry_query_engine();
     data.clean_out();
     int count;
-    CubitStatus s = gqe->get_graphics( curve, count, &data, dist_tol);
+    CubitStatus s = gqe->get_graphics( curve, count, &data, faceting_tol);
     if (CUBIT_SUCCESS != s)
       return false;
@@ -371,7 +371,7 @@
     data.clean_out();
     int nt, np, nf;
     CubitStatus s = gqe->get_graphics( surf, nt, np, nf, &data,
-                                       norm_tol, dist_tol, len_tol);
+                                       norm_tol, faceting_tol, len_tol);
       return false;
Modified: MOAB/trunk/tools/dagmc/cgm2moab.hpp
--- MOAB/trunk/tools/dagmc/cgm2moab.hpp	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/cgm2moab.hpp	2007-10-10 14:34:46 UTC (rev 1304)
@@ -14,7 +14,7 @@
 #define CGM2MOAB_HPP
-              double dist_tol = 0.001,
+              double faceting_tol = 0.001,
               int norm_tol = 5,
               double len_tol = 0.0,
               int actuate_attribs = true);
Added: MOAB/trunk/tools/dagmc/pt_vol_test.cc
--- MOAB/trunk/tools/dagmc/pt_vol_test.cc	                        (rev 0)
+++ MOAB/trunk/tools/dagmc/pt_vol_test.cc	2007-10-10 14:34:46 UTC (rev 1304)
@@ -0,0 +1,92 @@
+#include "MBInterface.hpp"
+#include "MBCore.hpp"
+#include "DagMC.hpp"
+#include "MBTagConventions.hpp"
+#include <vector>
+#include <iostream>
+#include <math.h>
+#include <limits>
+#define CHKERR if (MB_SUCCESS != rval) return rval
+MBErrorCode test_pt_volume(DagMC &dagmc, int volID, double xxx, double yyy, double zzz, int &inside)
+  MBErrorCode rval;
+  MBEntityHandle vol = dagmc.entity_by_id(3,volID);
+  rval = dagmc.point_in_volume( vol, xxx, yyy, zzz, inside);
+  CHKERR;
+MBErrorCode test_pt_volume_slow(DagMC &dagmc, int volID, double xxx, double yyy, double zzz, int &inside)
+  MBErrorCode rval;
+  rval = dagmc.point_in_volume_slow( vol, xxx, yyy, zzz, inside);
+  CHKERR;
+int main( int argc, char* argv[] )
+  MBErrorCode rval;
+  if (argc < 6) {
+    std::cerr << "Usage: " << argv[0] << " <mesh_filename> "
+              << " <vol_id> <xxx> <yyy> <zzz> " << std::endl;
+    return 1;
+  char* filename = argv[1];
+  int volID = atoi(argv[2]);
+  double xxx = atof(argv[3]);
+  double yyy = atof(argv[4]);
+  double zzz = atof(argv[5]);
+  int inside;
+  std::cout << "Checking pt_in_volume for:" << std::endl
+	    << "(x,y,z) = (" << xxx << "," << yyy << "," << zzz << ")"
+	    << std::endl << "in volume " << volID
+	    << " of geometry " << filename << std::endl;
+  DagMC& dagmc = *DagMC::instance();
+  rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0 );
+    std::cerr << "Failed to initialize DagMC." << std::endl;
+    return 2;
+  int errors = 0;
+  rval = test_pt_volume(dagmc,volID,xxx,yyy,zzz,inside);
+    std::cerr << "Failed to test point in volume [fast]." << std::endl;
+    return 3;
+  std::cout << "[fast] Point is " << (inside?"inside":"outside") << " volume "
+	    << volID << std::endl;
+  rval = test_pt_volume_slow(dagmc,volID,xxx,yyy,zzz,inside);
+    std::cerr << "Failed to test point in volume [slow]." << std::endl;
+    return 3;
+  std::cout << "[slow] Point is " << (inside?"inside":"outside") << " volume "
+  return errors;
Modified: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc	2007-10-10 14:30:46 UTC (rev 1303)
+++ MOAB/trunk/tools/dagmc/test_geom.cc	2007-10-10 14:34:46 UTC (rev 1304)
@@ -154,7 +154,6 @@
     std::cout << #A << "... " << std::endl; \
     if (MB_SUCCESS != A ( dagmc ) ) { \
       ++errors; \
-      std::cout << "<<FAILED>>" << std::endl; \
 } while(false)
@@ -180,7 +179,7 @@
   int errors = 0;
-  //RUN_TEST( test_ray_fire );
+  RUN_TEST( test_ray_fire );
   RUN_TEST( test_point_in_volume );
   RUN_TEST( test_measure_volume );
   RUN_TEST( test_measure_area );
