[MOAB-dev] r1302 - in MOAB/trunk: . parallel
    tautges at mcs.anl.gov
    Mon Oct  8 15:20:33 CDT 2007
Author: tautges
Date: 2007-10-08 15:20:33 -0500 (Mon, 08 Oct 2007)
New Revision: 1302
Modified:
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/mbparallelcomm_test.cpp
   MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Fixed a few errors when parallel loading .cub files.
mbparallelcomm_test.cpp: a few more diagnostics
Tqdcfr.cpp: adding global ids for nodes/elements from cubit ids
parallel/MBParallelComm.cpp: changing order of packing/unpacking set
parent/child handles to after all sets have been unpacked, so we're not
looking for sets that haven't yet been unpacked.  Also, adding
meaningful error messages to resolve_shared_entities.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2007-10-08 19:15:00 UTC (rev 1301)
+++ MOAB/trunk/Tqdcfr.cpp	2007-10-08 20:20:33 UTC (rev 1302)
@@ -128,7 +128,7 @@
 { return new Tqdcfr( iface ); }
 Tqdcfr::Tqdcfr(MBInterface *impl)
-    : cubFile(NULL), globalIdTag(0), cubIdTag(0), geomTag(0), uniqueIdTag(0),
+    : cubFile(NULL), globalIdTag(0), geomTag(0), uniqueIdTag(0),
       blockTag(0), nsTag(0), ssTag(0), attribVectorTag(0), entityNameTag(0),
       categoryTag(0)
@@ -146,14 +146,6 @@
   mdbImpl->tag_get_handle(DIRICHLET_SET_TAG_NAME, nsTag);
   mdbImpl->tag_get_handle(NEUMANN_SET_TAG_NAME, ssTag);
-  MBErrorCode result = mdbImpl->tag_get_handle("cubIdTag", cubIdTag);
-  if (MB_SUCCESS != result || MB_TAG_NOT_FOUND == result) {
-    int default_val = -1;
-    result = mdbImpl->tag_create("cubIdTag", sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER,
-                                 cubIdTag, &default_val);
-    assert (MB_SUCCESS == result);
   cubMOABVertexMap = NULL;
@@ -164,7 +156,6 @@
   if (NULL != cubMOABVertexMap) delete cubMOABVertexMap;
-  if (0 != cubIdTag) mdbImpl->tag_delete(cubIdTag);
@@ -901,7 +892,7 @@
     if (tmp_ents.empty() && 0 != id_buf_size) return MB_FAILURE;
     std::vector<int> cub_ids(id_buf_size);
-    result = mdbImpl->tag_get_data(cubIdTag, tmp_ents, &cub_ids[0]);
+    result = mdbImpl->tag_get_data(globalIdTag, tmp_ents, &cub_ids[0]);
     if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result) return result;
       // now go through id list, finding each entity by id
@@ -955,6 +946,10 @@
   result = mdbImpl->add_entities( mFileSet, dum_range );
   if (MB_SUCCESS != result) return result;
+    // set global ids on nodes
+  result = mdbImpl->tag_set_data(globalIdTag, dum_range, &int_buf[0]);
+  if (MB_SUCCESS != result) return result;
     // check for id contiguity
   long unsigned int node_offset = mdbImpl->id_from_handle( node_handle);
@@ -1125,8 +1120,8 @@
     result = mdbImpl->add_entities(mFileSet, dum_range);
-      // set cub ids
-    result = mdbImpl->tag_set_data(cubIdTag, dum_range, &int_buf[0]);
+      // set global ids
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp	2007-10-08 19:15:00 UTC (rev 1301)
+++ MOAB/trunk/mbparallelcomm_test.cpp	2007-10-08 20:20:33 UTC (rev 1302)
@@ -111,7 +111,8 @@
       MBParallelComm *pcomm = new MBParallelComm(mbImpl);
       tmp_result = pcomm->resolve_shared_ents();
       if (MB_SUCCESS != tmp_result) {
-        std::cerr << "Couldn't resolve shared entities." << std::endl;
+        std::cerr << "Couldn't resolve shared entities; error message:" << std::endl;
+        PRINT_LAST_ERROR
         result = tmp_result;
         continue;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2007-10-08 19:15:00 UTC (rev 1301)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2007-10-08 20:20:33 UTC (rev 1302)
@@ -721,7 +721,10 @@
         PACK_EH(buff_ptr, &members[0], *mem_it);
         mem_it++;
+    for (MBRange::const_iterator set_it = setRange.begin(); set_it != setRange.end();
+         set_it++, opt_it++) {
         // pack parents
       members.clear();
       result = mbImpl->get_parent_meshsets(*set_it, members);
@@ -762,7 +765,10 @@
   MBRange set_handles, new_sets;
   UNPACK_RANGE(buff_ptr, set_handles);
   std::vector<MBEntityHandle> members;
+  int num_ents;
+    // unpack set contents before parent/child relations, to make sure
+    // sets exist before being referenced
   for (MBRange::const_iterator rit = set_handles.begin();
        rit != set_handles.end(); rit++) {
@@ -776,7 +782,6 @@
     RR("Failed to create set in unpack.");
     new_sets.insert(set_handle);
-    int num_ents;
     if (opt & MESHSET_SET) {
         // unpack entities as a range
       MBRange set_range;
@@ -792,7 +797,11 @@
       result = mbImpl->add_entities(*rit, &members[0], num_ents);
       RR("Failed to add ents to ordered set in unpack.");
+    // now unpack parent/child links
+  for (MBRange::const_iterator rit = set_handles.begin();
+       rit != set_handles.end(); rit++) {
       // unpack parents/children
     UNPACK_INT(buff_ptr, num_ents);
     members.reserve(num_ents);
@@ -1068,7 +1077,7 @@
     skin_dim = upper_dim-1;
     result = skinner.find_skin(proc_ents, skin_ents[skin_dim],
                                skin_ents[skin_dim]);
-    if (MB_SUCCESS != result) return result;
+    RR("Failed to find skin.");
   else {
       // otherwise start with original entities
@@ -1085,7 +1094,7 @@
     result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
                                      false, skin_ents[this_dim],
                                      MBInterface::UNION);
+    RR("Failed getting skin adjacencies.");
     // global id tag
@@ -1098,7 +1107,7 @@
   else if (MB_ALREADY_ALLOCATED != result) {
       // just created it, so we need global ids
     result = assign_global_ids(upper_dim);
+    RR("Failed assigning global ids.");
     // store index in temp tag; reuse gid_data
@@ -1112,11 +1121,11 @@
                               MB_TYPE_INTEGER, idx_tag, &def_val, true);
   if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
   result = mbImpl->tag_set_data(idx_tag, skin_ents[0], &gid_data[0]);
+  RR("Couldn't assign index tag.");
     // get gids for skin verts in a vector, to pass to gs
   result = mbImpl->tag_get_data(gid_tag, skin_ents[0], &gid_data[0]);
+  RR("Couldn't get gid tag for skin vertices.");
     // get a crystal router
   crystal_data *cd = procConfig.crystal_router();
@@ -1128,11 +1137,17 @@
   int failure = MPI_Allreduce(&nverts_local, &nverts_total, 1,
                               MPI_INTEGER, MPI_SUM, procConfig.proc_comm());
-  if (failure) return MB_FAILURE;
+  if (failure) {
+    result = MB_FAILURE;
+    RR("Allreduce for total number of vertices failed.");
     // call gather-scatter to get shared ids & procs
   gs_data *gsd = gs_data_setup(skin_ents[0].size(), (const ulong_*)&gid_data[0], 1, cd);
-  if (NULL == gsd) return MB_FAILURE;
+  if (NULL == gsd) {
+    RR("Couldn't create gs data.");
     // get shared proc tags
   int def_vals[2] = {-10*procConfig.proc_size(), -10*procConfig.proc_size()};
@@ -1140,13 +1155,18 @@
   result = mbImpl->tag_create(PARALLEL_SHARED_PROC_TAG_NAME, 2*sizeof(int),
                               MB_TAG_DENSE,
                               MB_TYPE_INTEGER, sharedp_tag, &def_vals, true);
-  if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
+  if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
+    RR("Couldn't create shared_proc tag.");
   result = mbImpl->tag_create(PARALLEL_SHARED_PROCS_TAG_NAME,
                               MAX_SHARING_PROCS*sizeof(int),
                               MB_TAG_SPARSE,
                               MB_TYPE_INTEGER, sharedps_tag, NULL, true);
+    RR("Couldn't create shared_procs tag.");
     // load shared vertices into a tuple, then sort by index
   tuple_list shared_verts;
   tuple_list_init_max(&shared_verts, 0, 2, 0,
@@ -1178,7 +1198,7 @@
     else
       result = mbImpl->tag_set_data(sharedps_tag, &this_ent, 1,
                                     sharing_procs);
+    RR("Failed setting shared_procs tag on skin vertices.");
       // reset sharing proc(s) tags
     std::fill(sharing_procs, sharing_procs+nump, maxp);
@@ -1191,15 +1211,15 @@
          rit != skin_ents[d].end(); rit++) {
         // get connectivity
       result = mbImpl->get_connectivity(*rit, connect, num_connect);
+      RR("Failed to get connectivity on non-vertex skin entities.");
       MBRange sp_range, vp_range;
       for (int nc = 0; nc < num_connect; nc++) {
           // get sharing procs
         result = mbImpl->tag_get_data(sharedp_tag, &(*rit), 1, sharing_procs);
+        RR("Couldn't get sharedp_tag on skin vertices in entity.");
         if (sharing_procs[0] == maxp) {
           result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1, sharing_procs);
+          RR("Couldn't get sharedps_tag on skin vertices in entity.");
           // build range of sharing procs for this vertex
         unsigned int p = 0; vp_range.clear();
@@ -1225,7 +1245,7 @@
         result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1,
                                       sharing_procs);
+      RR("Failed to set sharedp(s)_tag on non-vertex skin entity.");
       std::fill(sharing_procs, sharing_procs+j, maxp);
