[MOAB-dev] r1428 - MOAB/trunk
tautges at mcs.anl.gov
Wed Nov 28 12:40:48 CST 2007
Author: tautges
Date: 2007-11-28 12:40:47 -0600 (Wed, 28 Nov 2007)
New Revision: 1428
Modified:
MOAB/trunk/DualTool.cpp
Log:
Make sure new entities in an foc go with the right side of the star (no longer always putting split entities on side 0).
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-11-28 14:45:44 UTC (rev 1427)
+++ MOAB/trunk/DualTool.cpp 2007-11-28 18:40:47 UTC (rev 1428)
@@ -1875,19 +1875,31 @@
std::vector<MBEntityHandle> star_dp1[2], star_dp2[2];
result = foc_get_stars(split_quads, split_edges, star_dp1, star_dp2); RR;
+ // get which star the split faces are in, and choose the other one
+ int new_side = -1;
+ if (std::find(star_dp1[0].begin(), star_dp1[0].end(), split_quads[0]) !=
+ star_dp1[0].end())
+ new_side = 1;
+ else if (std::find(star_dp1[1].begin(), star_dp1[1].end(), split_quads[0]) !=
+ star_dp1[1].end())
+ new_side = 0;
+ assert(-1 != new_side);
//=============== split faces
for (int i = 0; i < 2; i++) {
- // get a hex in star_dp2[0] that's adj to this split quad, to tell
- // mtu which one the orig should go with
+ // get a hex in star_dp2[new_side] that's adj to this split quad, to tell
+ // mtu which one the new quad should go with; there should be at least one,
+ // if we have any hexes connected to the split quad
MBEntityHandle gowith_hex = 0;
- for (std::vector<MBEntityHandle>::iterator vit = star_dp2[0].begin();
- vit != star_dp2[0].end(); vit++) {
+ for (std::vector<MBEntityHandle>::iterator vit = star_dp2[new_side].begin();
+ vit != star_dp2[new_side].end(); vit++) {
if (mtu.common_entity(*vit, split_quads[i], 2)) {
gowith_hex = *vit;
break;
+ assert(0 != gowith_hex);
// split manifold each of the split_quads, and put the results on the merge list
result = mtu.split_entities_manifold(split_quads+i, 1, new_quads+i, NULL,
@@ -1895,29 +1907,49 @@
// make ranges of faces which need to be explicitly adj to old, new
- // edge; faces come from stars and new_quads (which weren't in the stars)
+ // edge; faces come from stars and new_quads (which weren't in the stars);
+ // new_quads go with side j, which does not have split quads
MBRange tmp_addl_faces[2], addl_faces[2];
std::copy(star_dp1[i].begin(), star_dp1[i].end(),
mb_range_inserter(tmp_addl_faces[i]));
- tmp_addl_faces[0].insert(new_quads[i]);
+ tmp_addl_faces[new_side].insert(new_quads[i]);
+ bool cond1 = ("split_quads on 1, new_quads on 0" &&
+ tmp_addl_faces[0].find(split_quads[0]) == tmp_addl_faces[0].end() &&
+ tmp_addl_faces[0].find(split_quads[1]) == tmp_addl_faces[0].end() &&
+ tmp_addl_faces[1].find(split_quads[0]) != tmp_addl_faces[1].end() &&
+ tmp_addl_faces[1].find(split_quads[1]) != tmp_addl_faces[1].end() &&
+ tmp_addl_faces[0].find(new_quads[0]) != tmp_addl_faces[0].end() &&
+ tmp_addl_faces[0].find(new_quads[1]) != tmp_addl_faces[0].end() &&
+ tmp_addl_faces[1].find(new_quads[0]) == tmp_addl_faces[1].end() &&
+ tmp_addl_faces[1].find(new_quads[1]) == tmp_addl_faces[1].end()),
+ cond2 = ("split_quads on 0, new_quads on 1" &&
+ tmp_addl_faces[0].find(split_quads[0]) != tmp_addl_faces[0].end() &&
+ tmp_addl_faces[0].find(split_quads[1]) != tmp_addl_faces[0].end() &&
+ tmp_addl_faces[1].find(split_quads[0]) == tmp_addl_faces[1].end() &&
+ tmp_addl_faces[1].find(split_quads[1]) == tmp_addl_faces[1].end() &&
+ tmp_addl_faces[0].find(new_quads[0]) == tmp_addl_faces[0].end() &&
+ tmp_addl_faces[0].find(new_quads[1]) == tmp_addl_faces[0].end() &&
+ tmp_addl_faces[1].find(new_quads[0]) != tmp_addl_faces[1].end() &&
+ tmp_addl_faces[1].find(new_quads[1]) != tmp_addl_faces[1].end());
+ assert(cond1 || cond2);
//=============== split edge(s)
for (int j = 0; j < 3; j++) {
if (!split_edges[j]) break;
- // filter add'l faces to only those adj to split_edges[i]
+ // filter add'l faces to only those adj to split_edges[j]
addl_faces[0] = tmp_addl_faces[0]; addl_faces[1] = tmp_addl_faces[1];
result = mbImpl->get_adjacencies(&split_edges[j], 1, 2, false,
addl_faces[i]); RR;
- // split 2nd/3rd edge; again send old edge with addl_ents[1] to keep
- // on bdy
- result = mtu.split_entity_nonmanifold(split_edges[j], addl_faces[1],
- addl_faces[0], new_edges[j]); RR;
+ // split edge
+ result = mtu.split_entity_nonmanifold(split_edges[j], addl_faces[1-new_side],
+ addl_faces[new_side], new_edges[j]); RR;
//=============== split node(s)
@@ -1935,8 +1967,8 @@
// with the split/new node; new edges go with side 0, split with 1
for (int i = 0; i < 3; i++) {
if (!split_edges[i]) break;
- tmp_addl_edges[0].insert(new_edges[i]);
- tmp_addl_edges[1].insert(split_edges[i]);
+ tmp_addl_edges[new_side].insert(new_edges[i]);
+ tmp_addl_edges[1-new_side].insert(split_edges[i]);
// same for star faces and hexes
@@ -1946,7 +1978,7 @@
// finally, new quads
- for (int i = 0; i < 2; i++) tmp_addl_edges[0].insert(new_quads[i]);
+ for (int i = 0; i < 2; i++) tmp_addl_edges[new_side].insert(new_quads[i]);
// filter the entities, keeping only the ones adjacent to this node
MBRange addl_edges[2];
@@ -1958,8 +1990,8 @@
// now split the node too
- result = mtu.split_entity_nonmanifold(split_nodes[j], addl_edges[1],
- addl_edges[0], new_nodes[j]); RR;
+ result = mtu.split_entity_nonmanifold(split_nodes[j], addl_edges[1-new_side],
+ addl_edges[new_side], new_nodes[j]); RR;
return MB_SUCCESS;
