[MOAB-dev] r1417 - in MOAB/trunk: . tools/qvdual
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Nov 21 07:17:58 CST 2007
Author: tautges
Date: 2007-11-21 07:17:58 -0600 (Wed, 21 Nov 2007)
New Revision: 1417
Modified:
   MOAB/trunk/DualTool.cpp
   MOAB/trunk/DualTool.hpp
   MOAB/trunk/tools/qvdual/DrawDual.cpp
   MOAB/trunk/tools/qvdual/DrawDual.hpp
   MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
Log:
tools/qvdual/DrawDual: putting extra vertices at index 0 on the edge instead of 3, since there aren't any other vertices for edges; also fixed several compile warnings
vtkMOABUtils: a few more 64-bit related corrections.
DualTool:
- better organization of split_pair_nonmanifold
- simpler algorithm for foc_get_addl_ents; just gets all edges connected to half-star faces and split vertex; may not catch case where a face isn't in the half-star
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp	2007-11-20 22:15:01 UTC (rev 1416)
+++ MOAB/trunk/DualTool.cpp	2007-11-21 13:17:58 UTC (rev 1417)
@@ -1653,30 +1653,41 @@
   result = foc_delete_dual(split_quads, split_edges, hexes);
   if (MB_SUCCESS != result) return result;
-  std::vector<MBEntityHandle> merge_ents;
-  result = split_pair_nonmanifold(split_quads, split_edges, split_node, hexes,
-                                  other_edges, other_nodes, merge_ents);
+  MBEntityHandle new_quads[2], new_edges[2], new_node;
+  result = split_pair_nonmanifold(split_quads, split_edges, split_node,
+                                  other_edges, other_nodes,
+                                  new_quads, new_edges, new_node);
-    // put the other entities to be merged on the list
-  for (int i = 0; i < 4; i++) merge_ents.push_back(other_edges[i]);
-  if (!split_node)
-    for (int i = 4; i < 6; i++) merge_ents.push_back(other_edges[i]);
-  for (int i = 2; i < 4; i++) merge_ents.push_back(other_nodes[i]);
-  if (!split_node)
-    for (int i = 4; i < 6; i++) merge_ents.push_back(other_nodes[i]);
+    // now merge entities, the C of foc
+  MBEntityHandle keepit, deleteit;
+#define MIN(a,b) (a < b ? a : b)
+#define MAX(a,b) (a > b ? a : b)
+#define KEEP_DELETE(a,b,c,d) {c = MIN(a,b); d = MAX(a,b);}
+    // first the node(s)
+  KEEP_DELETE(other_nodes[2], other_nodes[3], keepit, deleteit);
+  result = mbImpl->merge_entities(keepit, deleteit, false, true); RR;
+  if (!split_edges[1]) {
+    KEEP_DELETE(other_nodes[4], other_nodes[5], keepit, deleteit);
-    // now merge them
-  for (std::vector<MBEntityHandle>::reverse_iterator vit = merge_ents.rbegin();
-       vit != merge_ents.rend(); vit+=2) {
-    if (*vit > *(vit+1))
-      result = mbImpl->merge_entities(*(vit+1), *vit, false, true);
-    else
-      result = mbImpl->merge_entities(*vit, *(vit+1), false, true);
-    if (MB_SUCCESS != result) return result;
+    // now the edges
+  int limit = (split_edges[1] ? 2 : 3);
+  for (int i = 0; i < limit; i++) {
+    KEEP_DELETE(other_edges[2*i], other_edges[2*i+1], keepit, deleteit);
+    // now the faces
+  KEEP_DELETE(split_quads[0], split_quads[1], keepit, deleteit);
+  result = mbImpl->merge_entities(new_quads[0], new_quads[1], false, true); RR;
   if (debug_ap) ((MBCore*)mbImpl)->check_adjacencies();
     // reconstruct dual
@@ -1749,7 +1760,7 @@
                                    split_edges[0], other_edges[2+i]); RR;
         // last other node is opposite split node on split quad
       result = mtu.opposite_entity(split_quads[i], split_node,
-                                   other_nodes[i]); RR;
+                                   other_nodes[2+i]); RR;
     other_edges[4] = other_edges[5] = 0;
@@ -1801,10 +1812,11 @@
 MBErrorCode DualTool::split_pair_nonmanifold(MBEntityHandle *split_quads,
                                              MBEntityHandle *split_edges,
                                              MBEntityHandle split_node,
-                                             MBRange &hexes,
                                              MBEntityHandle *other_edges,
                                              MBEntityHandle *other_nodes,
-                                             std::vector<MBEntityHandle> &merge_ents)
+                                             MBEntityHandle *new_quads,
+                                             MBEntityHandle *new_edges,
+                                             MBEntityHandle &new_node)
     // if there's a bdy in the star around the shared edge(s), get the quads on that
@@ -1815,106 +1827,101 @@
     // get star entities around edges, separated into halves
   std::vector<MBEntityHandle> star_dp1[2], star_dp2[2];
   result = foc_get_stars(split_quads, split_edges, star_dp1, star_dp2); RR;
+    //=============== split faces
     // split manifold each of the split_quads, and put the results on the merge list
-  MBEntityHandle new_quads[2];
   result = mtu.split_entities_manifold(split_quads, 2, new_quads, NULL); RR;
-  for (int i = 0; i < 2; i++) merge_ents.push_back(split_quads[i]);
-  for (int i = 0; i < 2; i++) merge_ents.push_back(new_quads[i]);
-    // if we're splitting 2 edges, there might be other edges that have the split
-    // node; also need to know which side they're on
-  MBRange addl_ents[2];
-  if (split_node) {
-    result = foc_get_addl_ents(star_dp1, star_dp2, split_node, addl_ents); RR;
+    // make ranges of faces which need to be explicitly adj to old, new
+    // edge; faces come from stars and new_quads (which weren't in the stars)
+  MBRange tmp_addl_faces[2];
+  for (int i = 0; i < 2; i++) {
+    std::copy(star_dp1[i].begin(), star_dp1[i].end(),
+            mb_range_inserter(tmp_addl_faces[i]));
+    tmp_addl_faces[0].insert(new_quads[i]);
-    // also need to put old/new quads on the addl_ents lists so they get adjs to
-    // split edges correctly
+    //=============== split 1st edge
+    // filter add'l faces to only those adj to split_edges[0]
+  MBRange addl_faces[2] = {tmp_addl_faces[0], tmp_addl_faces[1]};
-    addl_ents[0].insert(new_quads[i]);
-    addl_ents[1].insert(split_quads[i]);
+    result = mbImpl->get_adjacencies(&split_edges[0], 1, 2, false,
+                                     addl_faces[i]); RR;
-    // now split the edges; just add the star ents to addl_ents to pass into
-    // split_nonmanifold
-    std::copy(star_dp1[i].begin(), star_dp1[i].end(),
-              mb_range_inserter(addl_ents[i]));
+    // split the first edge
+  result = mtu.split_entity_nonmanifold(split_edges[0], addl_faces[1],
+                                        addl_faces[0], new_edges[0]); RR;
+  if (!split_edges[1]) return MB_SUCCESS;
+    //=============== split 2nd edge
+    // filter add'l faces to only those adj to split_edges[1]
+  addl_faces[0] = tmp_addl_faces[0]; addl_faces[1] = tmp_addl_faces[1];
+    result = mbImpl->get_adjacencies(&split_edges[1], 1, 2, false,
-  MBEntityHandle new_entity;
-    // pass addl_ents[1] in with split edge so that split edge remains
-    // on a bdy if it was before
-  result = mtu.split_entity_nonmanifold(split_edges[0], addl_ents[1],
-                                        addl_ents[0], new_entity); RR;
-  addl_ents[1].insert(split_edges[0]); addl_ents[0].insert(new_entity);
+    // split 2nd edge; again send old edge with addl_ents[1] to keep
+    // on bdy
+  result = mtu.split_entity_nonmanifold(split_edges[1], addl_faces[1],
+                                        addl_faces[0], new_edges[1]); RR;
+    //=============== split node
-  if (split_edges[1]) {
-      // split 2nd edge; again send old edge with addl_ents[1] to keep
-      // on bdy
-    result = mtu.split_entity_nonmanifold(split_edges[1], addl_ents[1],
-    addl_ents[1].insert(split_edges[1]); addl_ents[0].insert(new_entity);
+    //=============== prepare for splitting 2 edges/1 node part
-      // now split the node too
-    result = mtu.split_entity_nonmanifold(split_node, addl_ents[1],
+    // if we're splitting 2 edges, there might be other edges that have the split
+    // node; also need to know which side they're on
+  MBRange addl_edges[2];
+  result = foc_get_addl_ents(star_dp1, star_dp2, split_edges,
+                             split_node, addl_edges); RR;
+    // also, we need to know which of the split/new edges go
+    // with the split/new node; new edges go with side 0, split with 1
+    addl_edges[0].insert(new_edges[i]);
+    addl_edges[1].insert(split_edges[i]);
+    // now split the node too
+  result = mtu.split_entity_nonmanifold(split_node, addl_edges[1],
+                                        addl_edges[0], new_node); RR;
   return MB_SUCCESS;
 MBErrorCode DualTool::foc_get_addl_ents(std::vector<MBEntityHandle> *star_dp1,
                                         std::vector<MBEntityHandle> *star_dp2,
+                                        MBEntityHandle *split_edges,
                                         MBRange *addl_ents)
-    // algorithm:
-    // - start with star entities on search list
-    // - while (search list not empty):
-    // . take face off search list, put on result list
-    // . get all edge-adj faces also adj to split node
-    // . for each of these, if face is not on result list, put on search list
-    // - for each entity on result list:
-    // . get all entities also adj to split node & put on result list
+    // algorithm: for a given star_dp1 (faces) on a side:
+    // - get all edges adj to all faces -> R1
+    // - get all edges adj to split_node -> R2
+    // - R3 = R1 & R2 (edges connected to split_node & adj to a star face)
+    // - R3 -= split_edges (take split edges off addl_ents)
-  MBRange node_faces;
+  MBRange R2;
   MeshTopoUtil mtu(mbImpl);
-  MBErrorCode result = mbImpl->get_adjacencies(&split_node, 1, 2, false, node_faces); RR;
+  MBErrorCode result = mbImpl->get_adjacencies(&split_node, 1, 1, false, R2); RR;
   MBRange::iterator rit;
-    MBRange slist, rlist, tmp_list;
-    std::copy(star_dp1[i].begin(), star_dp1[i].end(), mb_range_inserter(slist));
-    while (!slist.empty()) {
-      MBEntityHandle this_ent = slist.pop_front();
-      rlist.insert(this_ent);
-      tmp_list.clear();
-      result = mtu.get_bridge_adjacencies(this_ent, 1, 2, tmp_list); RR;
-      tmp_list = tmp_list.intersect(node_faces);
-      for (rit = tmp_list.begin(); rit != tmp_list.end(); rit++)
-        if (rlist.find(*rit) == rlist.end()) slist.insert(*rit);
-    MBEntityHandle tmp_ents[2];
-    tmp_ents[0] = split_node;
-    MBRange rlist2;
-    for (rit = rlist.begin(); rit != rlist.end(); rit++) {
-      tmp_list.clear();
-      tmp_ents[1] = *rit;
-      result = mbImpl->get_adjacencies(tmp_ents, 2, 1, false, tmp_list); RR;
-      rlist2.merge(tmp_list);
-      tmp_list.clear();
-      result = mbImpl->get_adjacencies(tmp_ents, 2, 3, false, tmp_list); RR;
-      if (std::find(star_dp1[i].begin(), star_dp1[i].end(), *rit) ==
-          star_dp1[i].end()) addl_ents[i].insert(*rit);
-    addl_ents[i].merge(rlist2);
+    MBRange R1, R3;
+    result = mbImpl->get_adjacencies(&star_dp1[i][0], star_dp1[i].size(), 1, false,
+                                     R1, MBInterface::UNION); RR;
+    R3 = R1.intersect(R2);
+    R3.erase(split_edges[0]); R3.erase(split_edges[1]);
+    addl_ents[i].merge(R3);
   return MB_SUCCESS;
Modified: MOAB/trunk/DualTool.hpp
--- MOAB/trunk/DualTool.hpp	2007-11-20 22:15:01 UTC (rev 1416)
+++ MOAB/trunk/DualTool.hpp	2007-11-21 13:17:58 UTC (rev 1417)
@@ -334,15 +334,17 @@
   MBErrorCode split_pair_nonmanifold(MBEntityHandle *split_quads,
-                                     MBRange &hexes,
-                                     std::vector<MBEntityHandle> &merge_ents);
+                                     MBEntityHandle &new_node);
     //! for foc's splitting two shared edges, there might be additional entities
     //! connected to the split node that also have to be updated
   MBErrorCode foc_get_addl_ents(std::vector<MBEntityHandle> *star_dp1,
                                 MBRange *addl_ents);
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp	2007-11-20 22:15:01 UTC (rev 1416)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp	2007-11-21 13:17:58 UTC (rev 1417)
@@ -622,10 +622,10 @@
         // get the gv points for the four vertices
       void *next_points[2], *points[2];
-      get_graph_points(verts, 2, false, dual_surf, next_points);
+      get_graph_points(verts, 2, dual_surf, next_points);
       assert(next_points[0] != NULL && next_points[1] != NULL);
       result = MBI->get_connectivity(middle_edge, connect, num_connect); RR;
-      get_graph_points(connect, 2, false, dual_surf, points);
+      get_graph_points(connect, 2, dual_surf, points);
       assert(points[0] != NULL && points[1] != NULL);
         // now space points along the line segment joining the next_points
@@ -643,7 +643,7 @@
         // also fix the middle point on this edge
       points[0] = NULL;
-      get_graph_points(&middle_edge, 1, true, dual_surf, points);
+      get_graph_points(&middle_edge, 1, dual_surf, points);
       set_graphpoint_pos(points[0], avg_pos0);
         // now fix the other 2 dedges
@@ -658,7 +658,7 @@
         const MBEntityHandle *connect2;
         result = MBI->get_connectivity(*dum.begin(), connect2, num_connect); RR;
         std::vector<void*> tc_points(num_connect);
-        get_graph_points(connect2, num_connect, false, dual_surf, &tc_points[0]);
+        get_graph_points(connect2, num_connect, dual_surf, &tc_points[0]);
         avg_pos1[0] = avg_pos1[1] = avg_pos1[2] = 0.0;
         for (int i = 0; i < num_connect; i++) {
           if (connect2[i] != connect[0] && connect2[i] != connect[1]) {
@@ -669,7 +669,7 @@
         avg_pos1[0] = (.4*avg_pos1[0]/(num_connect-2) + .6*avg_pos0[0]);
         avg_pos1[1] = (.4*avg_pos1[1]/(num_connect-2) + .6*avg_pos0[1]);
-        get_graph_points(&(*rit), 1, true, dual_surf, &tc_points[0]);
+        get_graph_points(&(*rit), 1, dual_surf, &tc_points[0]);
         set_graphpoint_pos(tc_points[0], avg_pos1);
@@ -680,7 +680,7 @@
       const MBEntityHandle *connect;
       result = MBI->get_connectivity(*adj_2cells.begin(), connect, num_connect); RR;
-      get_graph_points(connect, num_connect, false, dual_surf, &tc_points[0]);
+      get_graph_points(connect, num_connect, dual_surf, &tc_points[0]);
       get_graphpoint_pos(tc_points[0], dum_pos0);
       get_graphpoint_pos(tc_points[1], dum_pos1);
@@ -699,7 +699,7 @@
         result = MBI->get_connectivity(*dum.begin(), connect, num_connect); RR;
           get_graphpoint_pos(tc_points[i], dum_pos0);
@@ -708,7 +708,7 @@
         avg_pos1[0] = (.2*avg_pos1[0]/num_connect + .8*avg_pos0[0]);
         avg_pos1[1] = (.2*avg_pos1[1]/num_connect + .8*avg_pos0[1]);
@@ -727,7 +727,7 @@
         int num_connect;
         result = MBI->get_connectivity(*adj_1cells.begin(), connect, num_connect); RR;
         void *vert_pts[2], *edge_pts[4];
-        get_graph_points(connect, 2, false, dual_surf, vert_pts);
+        get_graph_points(connect, 2, dual_surf, vert_pts);
         std::vector<MBEntityHandle> edges;
         std::copy(adj_1cells.begin(), adj_1cells.end(), std::back_inserter(edges));
@@ -742,7 +742,7 @@
           edges[2] = dum_h;
-        get_graph_points(&edges[0], 4, true, dual_surf, edge_pts);
+        get_graph_points(&edges[0], 4, dual_surf, edge_pts);
         dum_pos0[0] = CENT_X; dum_pos0[1] = CENT_Y+RAD_PTS;
         dum_pos1[0] = CENT_X; dum_pos1[1] = CENT_Y-RAD_PTS;
         set_graphpoint_pos(vert_pts[0], dum_pos0);
@@ -804,9 +804,9 @@
             // get the points for the two vertices and the 3 edges
             // non-middle chord; get the edges too
           void *vert_pts[2], *edge_pts[3];
-          get_graph_points(&chord_edges[i][0], 2, true, dual_surf, edge_pts);
-          get_graph_points(&(*middle_edges.begin()), 1, true, dual_surf, &edge_pts[2]);
+          get_graph_points(&chord_edges[i][0], 2, dual_surf, edge_pts);
+          get_graph_points(&(*middle_edges.begin()), 1, dual_surf, &edge_pts[2]);
           dum_pos0[0] = xpos; xpos += xdelta;
           dum_pos2[0] = (xpos < xcent ? xpos-xdelta/2 : xpos+xdelta/2);
@@ -876,7 +876,7 @@
   MBErrorCode result = dualTool->get_dual_entities(dual_surf, &dcells, &dedges,
                                                    &dverts, &dverts_loop, &dedges_loop);
     // get the GVEntity for each entity
   std::map<MBEntityHandle, GVEntity *> vert_gv_map;
@@ -905,7 +905,7 @@
   pd->GetCellData()->AddArray(color_ids);
   pd->GetCellData()->SetScalars(color_ids);
   pd->GetCellData()->SetActiveAttribute("ColorId", 0);
     // make the 1d cells chord by chord
   std::vector<MBEntityHandle> chords;
   result = MBI->get_child_meshsets(dual_surf, chords);
@@ -1006,7 +1006,7 @@
         this_gv = vert_gv_map[this_edge];
         assert(this_gv != NULL);
         index = this_gv->get_index(dual_surf);
-        assert(index >= 0 && this_gv->gvizPoints[index+2] != NULL);
+        assert(index >= 0 && this_gv->gvizPoints[index] != NULL);
         cell_points[num_pts++] = this_gv->vtkEntityIds[index+2];
@@ -1109,12 +1109,12 @@
     assert(NULL != gv_verts[i]);
     int index = gv_verts[i]->get_index(dual_surf);
     assert(index >= 0);
-    if (NULL != gv_verts[i]->gvizPoints[index+2] &&
+    if (NULL != gv_verts[i]->gvizPoints[index] &&
         gv_verts[i]->vtkEntityIds[index+2] == -1) {
-      get_graphpoint_pos(gv_verts[i]->gvizPoints[index+2], dum_pos);
+      get_graphpoint_pos(gv_verts[i]->gvizPoints[index], dum_pos);
       if (useGraphviz) {
         sprintf(dum_str, "%d,%d", (int)(dum_pos[0]*x_xform), (int)(dum_pos[1]*y_xform));
-        agxset(gv_verts[i]->gvizPoints[index+2], asym_pos->index, dum_str);
+        agxset(gv_verts[i]->gvizPoints[index], asym_pos->index, dum_str);
@@ -1310,7 +1310,7 @@
   GraphWindows &this_gw = surfDrawrings[dual_surf];
   if (useGraphviz && NULL == this_gw.gvizGraph) {
       // allocate a new graph and create a new window
-    sprintf(dum_str, "%d", MBI->id_from_handle(dual_surf));
+    sprintf(dum_str, "%d", (int)MBI->id_from_handle(dual_surf));
     this_gw.gvizGraph = agopen(dum_str, AGRAPH);
     if (this_gw.gvizGraph == NULL) return MB_FAILURE;
@@ -1373,7 +1373,7 @@
       int index0 = dvert_gv[0]->get_index(dual_surf);
       int index1 = dvert_gv[1]->get_index(dual_surf);
       assert(index0 >= 0 && index1 >= 0);
-      sprintf(dum_str, "%d", *rit);
+      sprintf(dum_str, "%d", (int)*rit);
         // first, check to see if it's degenerate; if so, add a mid-pt
       MBRange tmp_edges;
@@ -1382,8 +1382,8 @@
         if (useGraphviz) {
             // add a graphviz pt for the edge
           Agnode_t *mid_gvpt = agnode(this_gw.gvizGraph, dum_str);
-          sprintf(dum_str, "%up", MBI->id_from_handle(*rit));
-          this_gv->gvizPoints[dsindex+2] = mid_gvpt;
+          sprintf(dum_str, "%up", (int)MBI->id_from_handle(*rit));
+          this_gv->gvizPoints[dsindex] = mid_gvpt;
           Agedge_t *this_gved = agedge(this_gw.gvizGraph,
                                        (Agnode_t*)dvert_gv[0]->gvizPoints[index0],
@@ -1397,12 +1397,12 @@
         else {
             // add a vertex for the edge
+          sprintf(dum_str, "%up", (unsigned int) MBI->id_from_handle(*rit));
           MBEntityHandle mid_vert, edge1, edge2, edge_verts[2];
           double dum_pos[] = {CENT_X, CENT_Y, 0.0};
           result = MBI->create_vertex(dum_pos, mid_vert);
-          this_gv->gvizPoints[dsindex+2] = (void*)mid_vert;
+          this_gv->gvizPoints[dsindex] = (void*)mid_vert;
           edge_verts[0] = (MBEntityHandle) dvert_gv[0]->gvizPoints[index0];
           edge_verts[1] = (MBEntityHandle) mid_vert;
@@ -1490,7 +1490,7 @@
       dsindex = -dsindex - 1;
       if (useGraphviz) {
           // need to make a graphviz point
-        sprintf(dum_str, "%u", *rit);
+        sprintf(dum_str, "%u", (unsigned int)*rit);
         Agnode_t *this_gvpt = agnode(this_gw.gvizGraph, dum_str);
         if (NULL == this_gvpt) return MB_FAILURE;
         this_gv->gvizPoints[dsindex] = this_gvpt;
@@ -1654,11 +1654,11 @@
         MBErrorCode result = MBI->tag_get_data(gvEntityHandle, &(*rit), 1, &this_gv);
         if (MB_SUCCESS != result) continue;
         int index = this_gv->get_index(dual_surf);
         get_loop_vertex_pos(1+2*offset, loop_num, num_loops, .5*angle, xpos_pts, ypos_pts);
         if (useGraphviz) {
-          Agnode_t *this_gpt = (Agnode_t*)this_gv->gvizPoints[index+2];
+          Agnode_t *this_gpt = (Agnode_t*)this_gv->gvizPoints[index];
           sprintf(tmp_pos, "%d,%d!", xpos_pts, ypos_pts);
           agxset(this_gpt, asym_pos->index, tmp_pos);
           agxset(this_gpt, asym_pin->index, "true");
@@ -1669,7 +1669,7 @@
           ND_pinned(this_gpt) = true;
         else {
-          MBEntityHandle this_vert = (MBEntityHandle) this_gv->gvizPoints[index+2];
+          MBEntityHandle this_vert = (MBEntityHandle) this_gv->gvizPoints[index];
           double dum_pos[] = {xpos_pts, ypos_pts, 0.0};
           result = MBI->set_coords(&this_vert, 1, dum_pos);
@@ -1728,7 +1728,7 @@
   dum_pos[2] = dum_pos[5] = dum_pos[8] = 0.0;
   std::vector<MBEntityHandle> graph_points(face_verts.size());
-  get_graph_points(face_verts, false, dual_surf, (void**) &graph_points[0]);
+  get_graph_points(face_verts, dual_surf, (void**) &graph_points[0]);
   result = MBI->set_coords(&graph_points[0], face_verts.size(), dum_pos); RR;
   return result;
@@ -2135,6 +2135,7 @@
   else if (1 == dim) {
     vtkEntityIds[index+2] = -1;
+    vtkEntityIds[index+3] = -1;
     if (gvizEdges[index]) {
       if (useGraphviz)
         free(gvizEdges[index]);
@@ -2145,13 +2146,18 @@
       gvizEdges[index] = NULL;
     if (gvizEdges[index+2]) {
-      if (useGraphviz)
+      if (useGraphviz) {
         free(gvizEdges[index+2]);
+        if (gvizPoints[index]) free(gvizPoints[index]);
       else {
         assert(gvizEdges[index+2]);
         MBI->delete_entities((MBEntityHandle*)&gvizEdges[index+2], 1);
+          MBI->delete_entities((MBEntityHandle*)&gvizPoints[index], 1);
       gvizEdges[index+2] = NULL;
+      gvizPoints[index] = NULL;
@@ -2159,35 +2165,31 @@
 void DrawDual::get_graph_points(const MBEntityHandle *ents, const int num_ents,
-                                const bool extra,
                                 MBEntityHandle dual_surf, void **points)
   std::vector<GVEntity *> gvs(num_ents);
   MBErrorCode result = MBI->tag_get_data(gvEntityHandle, ents, num_ents, &gvs[0]);
   if (MB_SUCCESS != result) return;
-  int offset = (extra ? 2 : 0);
   for (int i = 0; i < num_ents; i++) {
     assert(NULL != gvs[i]);
     int index = gvs[i]->get_index(dual_surf);
     assert(index >= 0 && index < 3);
-    points[i] = gvs[i]->gvizPoints[index+offset];
+    points[i] = gvs[i]->gvizPoints[index];
 void DrawDual::get_graph_points(MBRange ents,
-                                const bool extra,
   std::vector<GVEntity *> gvs(ents.size());
   MBErrorCode result = MBI->tag_get_data(gvEntityHandle, ents, &gvs[0]);
   for (unsigned int i = 0; i < ents.size(); i++) {
@@ -2210,7 +2212,7 @@
   MeshTopoUtil mtu(vtkMOABUtils::mbImpl);
   std::vector<MBEntityHandle> graph_points(dverts.size());
-  get_graph_points(dverts, false, dual_surf, (void**) &graph_points[0]);
+  get_graph_points(dverts, dual_surf, (void**) &graph_points[0]);
   for (int i = 0; i < num_its; i++) {
       // get starting coords for all verts
@@ -2275,7 +2277,7 @@
     // get vertices on sheet drawing for that sheet, and their positions
   std::vector<MBEntityHandle> int_points(int_verts.size());
-  get_graph_points(int_verts, false, dual_surf, (void**) &int_points[0]);
+  get_graph_points(int_verts, dual_surf, (void**) &int_points[0]);
   std::vector<double> point_coords(3*int_verts.size());
   result = MBI->get_coords(&int_points[0], int_points.size(),
                            &point_coords[0]); RR;
Modified: MOAB/trunk/tools/qvdual/DrawDual.hpp
--- MOAB/trunk/tools/qvdual/DrawDual.hpp	2007-11-20 22:15:01 UTC (rev 1416)
+++ MOAB/trunk/tools/qvdual/DrawDual.hpp	2007-11-21 13:17:58 UTC (rev 1417)
@@ -245,11 +245,9 @@
   MBErrorCode get_graphpoint_pos(void *point, double *pos);
   void get_graph_points(const MBEntityHandle *ents, const int gnum_ents,
-                        const bool extra,
                         MBEntityHandle dual_surf, void **points);
   void get_graph_points(MBRange ents,
-                        const bool extra,
     //! given a renderer, return the sheet that this renderer renders
Modified: MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
--- MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx	2007-11-20 22:15:01 UTC (rev 1416)
+++ MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx	2007-11-21 13:17:58 UTC (rev 1417)
@@ -148,7 +148,7 @@
   MBErrorCode result = vtkMOABUtils::mbImpl->tag_get_handle(vtkCellTagName, vtkCellTag);
   if (MB_TAG_NOT_FOUND == result) {
-    int def_val = -1;
+    vtkIdType def_val = -1;
     result = vtkMOABUtils::mbImpl->tag_create(vtkCellTagName, sizeof(vtkIdType), MB_TAG_DENSE,
                                 vtkCellTag, &def_val);
@@ -156,14 +156,14 @@
   result = vtkMOABUtils::mbImpl->tag_get_handle(vtkTopContainsTagName, vtkTopContainsTag);
     unsigned char def_val = 0x0;
-    result = vtkMOABUtils::mbImpl->tag_create(vtkTopContainsTagName, 1, MB_TAG_BIT,
+    result = vtkMOABUtils::mbImpl->tag_create(vtkTopContainsTagName, sizeof(unsigned char), MB_TAG_BIT,
                                 vtkTopContainsTag, &def_val);
   result = vtkMOABUtils::mbImpl->tag_get_handle(vtkTopParentTagName, vtkTopParentTag);
-    result = vtkMOABUtils::mbImpl->tag_create(vtkTopParentTagName, 1, MB_TAG_BIT,
+    result = vtkMOABUtils::mbImpl->tag_create(vtkTopParentTagName, sizeof(unsigned char), MB_TAG_BIT,
                                 vtkTopParentTag, &def_val);
