[MOAB-dev] r1410 - in MOAB/trunk: . tools/qvdual
tautges at mcs.anl.gov
Mon Nov 19 11:49:21 CST 2007
Author: tautges
Date: 2007-11-19 11:49:21 -0600 (Mon, 19 Nov 2007)
New Revision: 1410
Modified:
MOAB/trunk/AEntityFactory.cpp
MOAB/trunk/DualTool.cpp
MOAB/trunk/MBCore.cpp
MOAB/trunk/tools/qvdual/CropTool.cpp
MOAB/trunk/tools/qvdual/DrawDual.cpp
MOAB/trunk/tools/qvdual/DrawDual.hpp
MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
MOAB/trunk/tools/qvdual/vtkMOABUtils.h
Log:
qvdual files: removed some unused var's to remove compile warnings;
also cleaned things up a bit for 64-bit operation
AEntityFactory.cpp: when removing an entity, check lower-dimensional
bounding entities for explicit adjacencies too, not just
higher-dimensional ones.
DualTool: more debugging on foc and ap, including better
implementation of split_pair_nonmanifold
MBCore.cpp: in range-based delete_entities, iterate over the range in
reverse, to avoid stale references to lower-dimensional entities.
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/AEntityFactory.cpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -467,7 +467,7 @@
if (adjvect[j] == base_entity)
remove_this = true;
- if (MBCN::Dimension(TYPE_FROM_HANDLE(adjvect[j])) > base_ent_dim
+ if (MBCN::Dimension(TYPE_FROM_HANDLE(adjvect[j])) != base_ent_dim
&& explicitly_adjacent( adjvect[j], base_entity ))
remove_adjacency( adjvect[j], base_entity );
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/DualTool.cpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -1417,21 +1417,24 @@
// perform an atomic pillow operation around dedge
- // 0. get star 2cells and 3cells around odedge (before odedge changes)
+ // grab the quad before deleting the odedge
+ quad1 = get_dual_entity(odedge);
+ assert(0 != quad1);
+ // 0. get star 2cells around odedge (before odedge changes) and 3cells around
+ // those 2cells (going to delete the 2cells, therefore need to delete the 3cells
+ // that depend on those too)
MeshTopoUtil mtu(mbImpl);
- MBRange star_2cells, star_3cells;
- MBErrorCode result = mbImpl->get_adjacencies(&odedge, 1, 2, false, star_2cells); RR;
- result = mbImpl->get_adjacencies(&odedge, 1, 3, false, star_3cells); RR;
+ MBRange star_cells, tmp_cells;
+ MBErrorCode result = mbImpl->get_adjacencies(&odedge, 1, 2, false, star_cells); RR;
+ result = mbImpl->get_adjacencies(star_cells, 3, false, tmp_cells,
+ MBInterface::UNION); RR;
+ star_cells.merge(tmp_cells);
+ star_cells.insert(odedge);
// tear down the dual entities which will be modified by the ap first
- result = delete_dual_entities(star_3cells);RR;
- result = delete_dual_entities(star_2cells);RR;
+ result = delete_dual_entities(star_cells); RR;
- // grab the quad before deleting the odedge
- quad1 = get_dual_entity(odedge);
- assert(0 != quad1);
- result = delete_dual_entities(&odedge, 1); RR;
// now change the quad to an ap
std::vector<MBEntityHandle> verts;
result = mbImpl->get_connectivity(&quad1, 1, verts); RR;
@@ -1579,61 +1582,55 @@
return MB_SUCCESS;
-MBErrorCode DualTool::delete_dual_entities(MBEntityHandle *entities,
- const int num_entities)
+MBErrorCode DualTool::delete_dual_entities(MBEntityHandle *entities,
+ int num_entities)
- if (NULL == entities || num_entities == 0) return delete_whole_dual();
+ MBRange tmp_ents;
+ std::copy(entities, entities+num_entities, mb_range_inserter(tmp_ents));
+ return delete_dual_entities(tmp_ents);
+MBErrorCode DualTool::delete_dual_entities(MBRange &entities)
+ if (entities.empty()) return delete_whole_dual();
MBEntityHandle null_entity = 0;
MBErrorCode result;
- std::vector<MBEntityHandle> ents_to_delete;
+ MBRange ents_to_delete;
- for (int i = 0; i < num_entities; i++) {
+ while (!entities.empty()) {
+ MBEntityHandle this_entity = entities.pop_back();
// reset the primal's dual entity
- MBEntityHandle primal = get_dual_entity(entities[i]);
- if (get_dual_entity(primal) == entities[i]) {
+ MBEntityHandle primal = get_dual_entity(this_entity);
+ if (get_dual_entity(primal) == this_entity) {
result = mbImpl->tag_set_data(dualEntity_tag(), &primal, 1, &null_entity); RR;
MBEntityHandle extra = get_extra_dual_entity(primal);
if (0 != extra) {
result = mbImpl->tag_set_data(extraDualEntity_tag(), &primal, 1, &null_entity); RR;
- ents_to_delete.push_back(entities[i]);
+ ents_to_delete.insert(this_entity);
// check for extra dual entities
- if (mbImpl->type_from_handle(entities[i]) == MBPOLYGON) {
+ if (mbImpl->type_from_handle(this_entity) == MBPOLYGON) {
// for 2cell, might be a loop edge
MBRange loop_edges;
- result = mbImpl->get_adjacencies(&entities[i], 1, 1, false, loop_edges);
- for (MBRange::iterator rit = loop_edges.begin(); rit != loop_edges.end(); rit++) {
- if (check_1d_loop_edge(*rit)) {
- MBEntityHandle this_ent = *rit;
- result = delete_dual_entities(&this_ent, 1); RR;
+ result = mbImpl->get_adjacencies(&this_entity, 1, 1, false, loop_edges);
+ for (MBRange::iterator rit = loop_edges.begin(); rit != loop_edges.end(); rit++)
+ if (check_1d_loop_edge(*rit)) entities.insert(*rit);
- else if (extra && extra != entities[i])
+ else if (extra && extra != this_entity)
// just put it on the list; primal for which we're extra has already been
// reset to not point to extra entity
- ents_to_delete.push_back(extra);
+ ents_to_delete.insert(extra);
// now delete the entities (sheets and chords will be updated automatically)
- return mbImpl->delete_entities(&ents_to_delete[0], ents_to_delete.size());
+ return mbImpl->delete_entities(ents_to_delete);
-MBErrorCode DualTool::delete_dual_entities(MBRange &entities)
- MBErrorCode result = MB_SUCCESS;
- for (MBRange::reverse_iterator rit = entities.rbegin(); rit != entities.rend(); rit++) {
- MBErrorCode tmp_result = delete_dual_entities(&this_ent, 1);
- if (MB_SUCCESS != tmp_result) result = tmp_result;
- return result;
MBErrorCode DualTool::face_open_collapse(MBEntityHandle ocl, MBEntityHandle ocr)
if (debug_ap) ((MBCore*)mbImpl)->check_adjacencies();
@@ -1821,7 +1818,6 @@
result = mtu.split_entities_manifold(split_quads, 2, new_quads, NULL); RR;
for (int i = 0; i < 2; i++) merge_ents.push_back(split_quads[i]);
for (int i = 0; i < 2; i++) merge_ents.push_back(new_quads[i]);
// if we're splitting 2 edges, there might be other edges that have the split
// node; also need to know which side they're on
@@ -1830,24 +1826,36 @@
result = foc_get_addl_ents(star_dp1, star_dp2, split_node, addl_ents); RR;
+ // also need to put old/new quads on the addl_ents lists so they get adjs to
+ // split edges correctly
+ for (int i = 0; i < 2; i++) {
+ addl_ents[0].insert(new_quads[i]);
+ addl_ents[1].insert(split_quads[i]);
// now split the edges; just add the star ents to addl_ents to pass into
// split_nonmanifold
- std::copy(star_dp1[i].begin(), star_dp1[i].end(), mb_range_inserter(addl_ents[i]));
+ std::copy(star_dp1[i].begin(), star_dp1[i].end(),
+ mb_range_inserter(addl_ents[i]));
MBEntityHandle new_entity;
- result = mtu.split_entity_nonmanifold(split_edges[0], addl_ents[0], addl_ents[1],
- new_entity); RR;
- addl_ents[0].insert(split_edges[0]); addl_ents[1].insert(new_entity);
+ // pass addl_ents[1] in with split edge so that split edge remains
+ // on a bdy if it was before
+ result = mtu.split_entity_nonmanifold(split_edges[0], addl_ents[1],
+ addl_ents[0], new_entity); RR;
+ addl_ents[1].insert(split_edges[0]); addl_ents[0].insert(new_entity);
if (split_edges[1]) {
- result = mtu.split_entity_nonmanifold(split_edges[1], addl_ents[0], addl_ents[1],
- new_entity); RR;
+ // split 2nd edge; again send old edge with addl_ents[1] to keep
+ // on bdy
+ result = mtu.split_entity_nonmanifold(split_edges[1], addl_ents[1],
+ addl_ents[1].insert(split_edges[1]); addl_ents[0].insert(new_entity);
// now split the node too
- result = mtu.split_entity_nonmanifold(split_node, addl_ents[0], addl_ents[1],
- new_entity); RR;
+ result = mtu.split_entity_nonmanifold(split_node, addl_ents[1],
return MB_SUCCESS;
@@ -1918,6 +1926,8 @@
bool on_bdy;
MBErrorCode result;
+ MBEntityHandle first_split_quad = 0;
// only do 2nd iteration if we have a 2nd edge
if (1 == i && !split_edges[1]) continue;
@@ -1927,31 +1937,36 @@
result = mtu.star_entities(split_edges[i], star_tmp[0], on_bdy, 0,
&star_tmp[1]); RR;
std::vector<MBEntityHandle>::iterator fit, hit;
- bool inside = false;
- // separate the star into halves; store faces in split_qstar[0],[1], and
- // the hexes in split_hstar[0],[1]
- for (fit = star_tmp[0].begin(), hit = star_tmp[1].begin(); fit != star_tmp[0].end();
- fit++, hit++) {
- // start of loop, see if we're going from outside to inside
- if (!inside && (*fit == split_quads[0] || *fit == split_quads[1]))
- inside = true;
- // put current face on right list
- if (inside) split_qstar[0].push_back(*fit);
- else split_qstar[1].push_back(*fit);
- // decide whether we're going outside after this face
- if (inside && *fit != *split_qstar[0].begin() &&
- (*fit == split_quads[0] || *fit == split_quads[1]))
- inside = false;
- // save hex based on inside/outside *after* outside test, so that hex
- // after outside face goes on outside list;
- // only save hex if we're not on the end with a bdy
- if (!on_bdy || fit != star_tmp[0].end()) {
- if (inside) split_hstar[0].push_back(*hit);
- else split_hstar[1].push_back(*hit);
+ // find 1st and 2nd split face around star
+ int first_ind = -1, second_ind = -1, j = 0;
+ for (fit = star_tmp[0].begin(); fit != star_tmp[0].end(); fit++, j++) {
+ if (*fit == split_quads[0] || *fit == split_quads[1]) {
+ if (first_ind == -1) first_ind = j;
+ else second_ind = j;
+ assert(-1 != first_ind && -1 != second_ind);
+ // now assemble the parts of the star
+ for (j = 0; j < (int) star_tmp[0].size(); j++) {
+ // split quads and ones before/after go on outside list
+ if (j <= first_ind || j >= second_ind)
+ split_qstar[1].push_back(star_tmp[0][j]);
+ else
+ split_qstar[0].push_back(star_tmp[0][j]);
+ // hexes before/after do too, but watch out for non-existent
+ // last one if we're on bdy
+ if (j >= first_ind && j < second_ind)
+ split_hstar[0].push_back(star_tmp[1][j]);
+ else if (!on_bdy || (on_bdy && j < (int) star_tmp[0].size()-1))
+ split_hstar[1].push_back(star_tmp[1][j]);
+ // save the 1st split quad on the 1st iteration, to align lists later
+ if (0 == first_split_quad)
+ first_split_quad = star_tmp[0][first_ind];
// if we're on edge 1, just put the halves into the result vectors
if (0 == i) {
star_dp1[0].swap(split_qstar[0]); star_dp1[1].swap(split_qstar[1]);
@@ -1964,10 +1979,12 @@
// the back depending whether that face is 1st or last on split_qstar[0]
MBEntityHandle hex1 = *star_dp2[0].begin();
MBEntityHandle hex2 = 0;
- if (*split_qstar[0].begin() == *star_dp1[0].begin())
+ if (star_tmp[0][first_ind] == first_split_quad)
hex2 = *split_hstar[0].begin();
- else if (*split_qstar[0].rbegin() == *star_dp1[0].begin())
+ else if (star_tmp[0][second_ind] == first_split_quad)
hex2 = *split_hstar[0].rbegin();
+ else assert(false);
if (hex1 == hex2) {
std::copy(split_qstar[i].begin(), split_qstar[i].end(),
@@ -2034,13 +2051,7 @@
for (MBRange::iterator rit = cells1or2.begin(); rit != cells1or2.end(); rit++)
dual_hps.insert(get_dual_hyperplane(*rit));
- std::vector<MBEntityHandle> dual_ents_vec;
- std::copy(dual_ents.rbegin(), dual_ents.rend(), std::back_inserter(dual_ents_vec));
-// for (MBRange::iterator rit = dual_ents.rbegin(); rit != dual_ents.rend(); rit++)
-// dual_ents_vec.push_back(*rit);
- result = delete_dual_entities(&dual_ents_vec[0], dual_ents_vec.size());
+ result = delete_dual_entities(dual_ents);
if (MB_SUCCESS != result) return result;
// now decide which sheet to delete (to be merged into the other)
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/MBCore.cpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -1794,7 +1794,7 @@
MBErrorCode MBCore::delete_entities(const MBRange &range)
MBErrorCode result = MB_SUCCESS, rval;
- for (MBRange::iterator i = range.begin(); i != range.end(); ++i)
+ for (MBRange::const_reverse_iterator i = range.rbegin(); i != range.rend(); ++i)
if (MB_SUCCESS != (rval = delete_entities( &*i, 1)))
result = rval;
return rval;
Modified: MOAB/trunk/tools/qvdual/CropTool.cpp
--- MOAB/trunk/tools/qvdual/CropTool.cpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/tools/qvdual/CropTool.cpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -46,7 +46,7 @@
void CropTool::type_activated(const int num, const int type_num)
- vtkImplicitFunction *the_func = NULL;
+ //vtkImplicitFunction *the_func = NULL;
vtkPlane *plane;
vtkCylinder *cyl;
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -246,11 +246,11 @@
// assembly
vtkActorCollection *actors = dualPicker->GetActors();
- vtkActor *picked_actor = NULL, *tmp_actor;
- MBEntityHandle picked_sheet = 0, picked_chord = 0;
+ vtkActor *tmp_actor;
+ //vtkActor *picked_actor = NULL;
+ //MBEntityHandle picked_sheet = 0, picked_chord = 0;
actors->InitTraversal();
- int i = 0;
while ((tmp_actor = actors->GetNextItem())) {
MBEntityHandle this_set = vtkMOABUtils::propSetMap[tmp_actor];
if (0 == this_set || -1 == dualPicker->GetCellId()) continue;
@@ -366,10 +366,9 @@
MBErrorCode result;
std::vector<MBEntityHandle> dual_sets;
std::vector<MBEntityHandle>::iterator vit;
- static std::vector<GVEntity*> gvents;
- gvents.reserve(pickRange.size());
+ GVEntity **gvents;
- result = MBI->tag_get_data(gvEntityHandle, pickRange, &gvents[0]);
+ result = MBI->tag_get_data(gvEntityHandle, pickRange, &gvents);
if (MB_SUCCESS != result) return;
unsigned int i, j;
MBRange::iterator rit;
@@ -957,13 +956,12 @@
vtkFloatArray *color_ids)
std::vector<MBEntityHandle> cell_verts;
- std::vector<GVEntity*> gv_cells;
+ std::vector<GVEntity *> gv_cells(cell_range.size());
int cell_num;
vtkIdType cell_points[20];
static int vtk_cell_type[] = {VTK_VERTEX, VTK_LINE, VTK_POLYGON};
- gv_cells.reserve(cell_range.size());
MBErrorCode result = MBI->tag_get_data(gvEntityHandle, cell_range, &gv_cells[0]);
@@ -1059,7 +1057,7 @@
pd->Allocate();
std::vector<GVEntity*> gv_verts;
- gv_verts.reserve(verts.size());
+ gv_verts.resize(verts.size());
// get the gventities
MBErrorCode result = MBI->tag_get_data(gvEntityHandle, verts, &gv_verts[0]);
@@ -1080,6 +1078,7 @@
result = get_xform(dual_surf, asym_pos, x_xform, y_xform);
for (rit = verts.begin(), i = 0; rit != verts.end(); rit++, i++) {
+ assert(NULL != gv_verts[i]);
int index = gv_verts[i]->get_index(dual_surf);
assert(index >= 0 && NULL != gv_verts[i]->gvizPoints[index]);
if (gv_verts[i]->vtkEntityIds[index] == -1) {
@@ -1098,7 +1097,7 @@
if (edges.empty()) return MB_SUCCESS;
// check for mid-edge points; reuse gv_verts
- gv_verts.reserve(edges.size());
+ gv_verts.resize(edges.size());
result = MBI->tag_get_data(gvEntityHandle, edges, &gv_verts[0]);
@@ -1107,6 +1106,7 @@
return result;
for (rit = edges.begin(), i = 0; rit != edges.end(); rit++, i++) {
assert(index >= 0);
if (NULL != gv_verts[i]->gvizPoints[index+2] &&
@@ -1146,6 +1146,7 @@
// find a vertex with non-zero x, y coordinates
for (std::vector<GVEntity*>::iterator vit = gv_verts.begin(); vit != gv_verts.end(); vit++) {
+ assert(NULL != *vit);
int index = (*vit)->get_index(dual_surf);
assert(index >= 0 && NULL != (*vit)->gvizPoints[index]);
// get new point position
@@ -1315,39 +1316,31 @@
// for each vertex, allocate a graphviz point if it doesn't already have one
- GVEntity **dvert_gv = new GVEntity*[dverts.size()];
- MBErrorCode result = MBI->tag_get_data(gvEntityHandle, dverts, dvert_gv); RR;
Agsym_t *asym_pos = (useGraphviz ? get_asym(dual_surf, 0, "pos") : NULL);
- result = construct_graphviz_points(dual_surf, dverts, asym_pos, dvert_gv); RR;
+ MBErrorCode result = construct_graphviz_points(dual_surf, dverts, asym_pos); RR;
// for each edge, allocate a graphviz edge if it doesn't already have one
- GVEntity **dedge_gv = new GVEntity*[dedges.size()];
- result = MBI->tag_get_data(gvEntityHandle, dedges, dedge_gv); RR;
- result = construct_graphviz_edges(dual_surf, dedges, face_verts, asym_pos,
- dvert_gv, dedge_gv); RR;
+ result = construct_graphviz_edges(dual_surf, dedges, face_verts, asym_pos); RR;
- delete [] dvert_gv;
- delete [] dedge_gv;
return result;
MBErrorCode DrawDual::construct_graphviz_edges(MBEntityHandle dual_surf,
MBRange &dedges,
MBRange &loop_verts,
- Agsym_t *asym_pos,
- GVEntity **dvert_gv,
- GVEntity **dedge_gv)
+ Agsym_t *asym_pos)
const MBEntityHandle *connect;
int num_connect;
char dum_str[80];
GraphWindows &this_gw = surfDrawrings[dual_surf];
- Agsym_t *asym_weight = (useGraphviz ? get_asym(dual_surf, 1, "weight") : NULL),
- *asym_len = (useGraphviz ? get_asym(dual_surf, 1, "len") : NULL);
+ //Agsym_t *asym_weight = (useGraphviz ? get_asym(dual_surf, 1, "weight") : NULL),
+ //*asym_len = (useGraphviz ? get_asym(dual_surf, 1, "len") : NULL);
+ std::vector<GVEntity*> dedge_gv(dedges.size());
+ result = MBI->tag_get_data(gvEntityHandle, dedges, &dedge_gv[0]); RR;
+ GVEntity *dvert_gv[2];
int i;
@@ -1468,14 +1461,15 @@
MBErrorCode DrawDual::construct_graphviz_points(MBEntityHandle dual_surf,
MBRange &dverts,
- GVEntity **dvert_gv)
int i;
char dum_str[80];
+ std::vector<GVEntity*> dvert_gv(dverts.size());
+ result = MBI->tag_get_data(gvEntityHandle, dverts, &dvert_gv[0]);
for (rit = dverts.begin(), i = 0; rit != dverts.end(); rit++, i++) {
@@ -1706,7 +1700,6 @@
// if more, get the first two vertices on the first chord, then a 3rd
// from another that's not in the 1st set
- MBEntityHandle dum_verts[3];
MBRange tmp_range;
result = MBI->get_entities_by_dimension(chords[0], 1, tmp_range); RR;
assert(3 < tmp_range.size());
@@ -2175,6 +2168,7 @@
int offset = (extra ? 2 : 0);
for (int i = 0; i < num_ents; i++) {
+ assert(NULL != gvs[i]);
int index = gvs[i]->get_index(dual_surf);
assert(index >= 0 && index < 3);
points[i] = gvs[i]->gvizPoints[index+offset];
Modified: MOAB/trunk/tools/qvdual/DrawDual.hpp
--- MOAB/trunk/tools/qvdual/DrawDual.hpp 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/tools/qvdual/DrawDual.hpp 2007-11-19 17:49:21 UTC (rev 1410)
@@ -217,15 +217,12 @@
MBErrorCode construct_graphviz_points(MBEntityHandle dual_surf,
MBRange &dverts,
- GVEntity **dvert_gv);
+ Agsym_t *asym_pos);
MBErrorCode construct_graphviz_edges(MBEntityHandle dual_surf,
MBRange &dedges,
- GVEntity **dege_gv);
Agsym_t *get_asym(MBEntityHandle dual_surf, const int dim,
const char *name, const char *def_val = NULL);
Modified: MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx
--- MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/tools/qvdual/vtkMOABUtils.cxx 2007-11-19 17:49:21 UTC (rev 1410)
@@ -84,37 +84,37 @@
MBTag vtkMOABUtils::vtkTopContainsTag = 0;
//! name for vtkTopContainsTag;
-char *vtkMOABUtils::vtkTopContainsTagName = "__vtkTopContainsTag";
+const char *vtkMOABUtils::vtkTopContainsTagName = "__vtkTopContainsTag";
//! tag indicating whether a given set is in top parent assy
MBTag vtkMOABUtils::vtkTopParentTag = 0;
//! name for vtkTopParentTag;
-char *vtkMOABUtils::vtkTopParentTagName = "__vtkTopParentTag";
+const char *vtkMOABUtils::vtkTopParentTagName = "__vtkTopParentTag";
//! tag for pointing to vtk cell representing an entity
MBTag vtkMOABUtils::vtkCellTag = 0;
//! name for vtkCellTag
-char *vtkMOABUtils::vtkCellTagName = "__vtkCellTag";
+const char *vtkMOABUtils::vtkCellTagName = "__vtkCellTag";
//! tag for pointing to vtk actor for a set
MBTag vtkMOABUtils::vtkSetActorTag = 0;
//! name for vtkSetActorTag
-char *vtkMOABUtils::vtkSetActorTagName = "__vtkSetActorTag";
+const char *vtkMOABUtils::vtkSetActorTagName = "__vtkSetActorTag";
//! tag for pointing to vtk prop assembly for a set
MBTag vtkMOABUtils::vtkSetPropAssemblyTag = 0;
//! name for vtkSetPropAssemblyTag
-char *vtkMOABUtils::vtkSetPropAssemblyTagName = "__vtkSetPropAssemblyTag";
+const char *vtkMOABUtils::vtkSetPropAssemblyTagName = "__vtkSetPropAssemblyTag";
//! tag for determining whether a point has been allocated for a vertex
MBTag vtkMOABUtils::vtkPointAllocatedTag = 0;
//! name for vtkPointAllocatedTag
-char *vtkMOABUtils::vtkPointAllocatedTagName = "__vtkPointAllocatedTag";
+const char *vtkMOABUtils::vtkPointAllocatedTagName = "__vtkPointAllocatedTag";
DrawDual *vtkMOABUtils::drawDual = NULL;
@@ -392,7 +392,7 @@
result = vtkMOABUtils::update_set_actors(sheet_sets, vtkMOABUtils::myUG, true, false, true);
- int table_size = ((int) chord_sets.size()+sheet_sets.size() > vtkMOABUtils::totalColors ?
+ int table_size = ((int) (chord_sets.size()+sheet_sets.size()) > vtkMOABUtils::totalColors ?
chord_sets.size()+sheet_sets.size() : vtkMOABUtils::totalColors);
vtkMOABUtils::construct_lookup_table(table_size);
Modified: MOAB/trunk/tools/qvdual/vtkMOABUtils.h
--- MOAB/trunk/tools/qvdual/vtkMOABUtils.h 2007-11-19 17:47:39 UTC (rev 1409)
+++ MOAB/trunk/tools/qvdual/vtkMOABUtils.h 2007-11-19 17:49:21 UTC (rev 1410)
@@ -65,38 +65,38 @@
static MBTag vtkTopContainsTag;
- static char *vtkTopContainsTagName;
+ static const char *vtkTopContainsTagName;
static MBTag vtkTopParentTag;
- static char *vtkTopParentTagName;
+ static const char *vtkTopParentTagName;
static MBTag vtkCellTag;
- static char *vtkCellTagName;
+ static const char *vtkCellTagName;
static MBTag vtkSetActorTag;
- static char *vtkSetActorTagName;
+ static const char *vtkSetActorTagName;
//! tag for pointing to vtk prop assembly for a set; a prop assembly
//! for a set is only created if the set contains sets
static MBTag vtkSetPropAssemblyTag;
- static char *vtkSetPropAssemblyTagName;
+ static const char *vtkSetPropAssemblyTagName;
static MBTag vtkPointAllocatedTag;
- static char *vtkPointAllocatedTagName;
+ static const char *vtkPointAllocatedTagName;
//! picked entities
static MBRange pickedEntities;
