[MOAB-dev] r1407 - MOAB/trunk
tautges at mcs.anl.gov
Fri Nov 16 14:25:35 CST 2007
Author: tautges
Date: 2007-11-16 14:25:34 -0600 (Fri, 16 Nov 2007)
New Revision: 1407
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/DualTool.hpp
MOAB/trunk/MBCN.cpp
MOAB/trunk/MBCore.cpp
Log:
MBCN: forgot OppositeSide functionality for edges, duh
MBCore: special handling for child entities of vertex type in
side_number function, since MBCN doesn't store that information for
vertices
DualTool: more fixes for FOC operation
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-11-16 19:41:24 UTC (rev 1406)
+++ MOAB/trunk/DualTool.cpp 2007-11-16 20:25:34 UTC (rev 1407)
@@ -1732,16 +1732,26 @@
MeshTopoUtil mtu(mbImpl);
if (common_edges.size() > 1) {
+ // split node is shared by split edges
split_node = mtu.common_entity(split_edges[0], split_edges[1], 0);
if (0 == split_node) return MB_FAILURE;
+ // first two other nodes are on split edges opposite split node
+ result = mtu.opposite_entity(split_edges[0], split_node,
+ other_nodes[0]); RR;
+ result = mtu.opposite_entity(split_edges[1], split_node,
+ other_nodes[1]); RR;
for (int i = 0; i < 2; i++) {
+ // 1st other edge is opposite second split edge on split quad
result = mtu.opposite_entity(split_quads[i],
split_edges[1-i], other_edges[i]); RR;
+ // 2nd other edge is opposite first split edge on split quad
split_edges[i], other_edges[2+i]); RR;
+ // last other node is opposite split node on split quad
result = mtu.opposite_entity(split_quads[i], split_node,
other_nodes[i]); RR;
+ other_edges[4] = other_edges[5] = 0;
else {
split_edges[1] = 0;
@@ -1750,26 +1760,40 @@
int num_connect;
result = mbImpl->get_connectivity(split_edges[0], connect, num_connect);
if (MB_SUCCESS != result) return result;
+ // other_nodes[0], [1] are on split edge
+ other_nodes[0] = connect[0];
+ other_nodes[1] = connect[1];
+ // for each of the split quads
+ // get the other edge on the split quad adj to node 0 on the split edge, by getting
+ // edges adj to split quad and node and removing split edge; that's other_edge[i]
MBRange tmp_range1, tmp_range2;
- tmp_range1.insert(connect[i]);
+ tmp_range1.insert(connect[0]);
tmp_range1.insert(split_quads[i]);
result = mbImpl->get_adjacencies(tmp_range1, 1, false, tmp_range2);
tmp_range2.erase(split_edges[0]);
assert(tmp_range2.size() == 1);
other_edges[i] = *tmp_range2.begin();
- result = mtu.opposite_entity(other_edges[i], connect[i],
- other_nodes[i]); RR;
+ // get edge connected to other node on split edge & split quad; that's
+ // opposite prev other_edges on the split quad; that's other_edges[2+i]
+ result = mtu.opposite_entity(split_quads[i], other_edges[i],
+ other_edges[2+i]); RR;
+ // get the edge on the split quad opposite the split edge; that's other_edges[4+i]
result = mtu.opposite_entity(split_quads[i], split_edges[0],
other_edges[4+i]); RR;
+ // get nodes on other side of split quad from split edge, by getting common
+ // node between top/bottom edge and opposite edge
+ other_nodes[2+i] = mtu.common_entity(other_edges[i], other_edges[4+i], 0);
+ other_nodes[4+i] = mtu.common_entity(other_edges[2+i], other_edges[4+i], 0);
+ if (0 == other_nodes[2+i] || 0 == other_nodes[4+i]) return MB_FAILURE;
- result = mbImpl->get_adjacencies(split_quads, 2, 3, false, hexes, MBInterface::UNION);
+ result = mbImpl->get_adjacencies(split_edges, (split_node ? 2 : 1), 3, false,
+ hexes, MBInterface::UNION);
- assert(4 >= hexes.size());
return MB_SUCCESS;
@@ -1777,7 +1801,7 @@
MBErrorCode DualTool::split_pair_nonmanifold(MBEntityHandle *split_quads,
MBEntityHandle *split_edges,
MBEntityHandle split_node,
- MBRange hexes,
+ MBRange &hexes,
MBEntityHandle *other_edges,
MBEntityHandle *other_nodes,
std::vector<MBEntityHandle> &merge_ents)
@@ -1802,7 +1826,9 @@
// if we're splitting 2 edges, there might be other edges that have the split
// node; also need to know which side they're on
MBRange addl_ents[2];
- result = foc_get_addl_ents(star_dp1, star_dp2, split_node, addl_ents); RR;
+ if (split_node) {
+ result = foc_get_addl_ents(star_dp1, star_dp2, split_node, addl_ents); RR;
// now split the edges; just add the star ents to addl_ents to pass into
// split_nonmanifold
@@ -1907,18 +1933,23 @@
// the hexes in split_hstar[0],[1]
for (fit = star_tmp[0].begin(), hit = star_tmp[1].begin(); fit != star_tmp[0].end();
fit++, hit++) {
+ // start of loop, see if we're going from outside to inside
if (!inside && (*fit == split_quads[0] || *fit == split_quads[1]))
inside = true;
+ // put current face on right list
if (inside) split_qstar[0].push_back(*fit);
else split_qstar[1].push_back(*fit);
+ // decide whether we're going outside after this face
+ if (inside && *fit != *split_qstar[0].begin() &&
+ (*fit == split_quads[0] || *fit == split_quads[1]))
+ inside = false;
+ // save hex based on inside/outside *after* outside test, so that hex
+ // after outside face goes on outside list;
// only save hex if we're not on the end with a bdy
if (!on_bdy || fit != star_tmp[0].end()) {
if (inside) split_hstar[0].push_back(*hit);
else split_hstar[1].push_back(*hit);
- if (inside && *fit != *split_qstar[0].begin() &&
- (*fit == split_quads[0] || *fit == split_quads[1]))
- inside = false;
// if we're on edge 1, just put the halves into the result vectors
Modified: MOAB/trunk/DualTool.hpp
--- MOAB/trunk/DualTool.hpp 2007-11-16 19:41:24 UTC (rev 1406)
+++ MOAB/trunk/DualTool.hpp 2007-11-16 20:25:34 UTC (rev 1407)
@@ -334,7 +334,7 @@
MBErrorCode split_pair_nonmanifold(MBEntityHandle *split_quads,
- MBRange hexes,
+ MBRange &hexes,
std::vector<MBEntityHandle> &merge_ents);
Modified: MOAB/trunk/MBCN.cpp
--- MOAB/trunk/MBCN.cpp 2007-11-16 19:41:24 UTC (rev 1406)
+++ MOAB/trunk/MBCN.cpp 2007-11-16 20:25:34 UTC (rev 1407)
@@ -306,6 +306,12 @@
int &opposite_dim)
switch (parent_type) {
+ case MBEDGE:
+ if (0 != child_dim) return -1;
+ else opposite_index = 1-child_index;
+ opposite_dim = 0;
+ break;
case MBTRI:
switch (child_dim) {
case 0:
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-11-16 19:41:24 UTC (rev 1406)
+++ MOAB/trunk/MBCore.cpp 2007-11-16 20:25:34 UTC (rev 1407)
@@ -1966,6 +1966,20 @@
int num_parent_vertices, num_child_vertices;
MBErrorCode result = get_connectivity(parent, parent_conn, num_parent_vertices, true);
+ if (TYPE_FROM_HANDLE(child) == MBVERTEX) {
+ int child_index = std::find(parent_conn, parent_conn+num_parent_vertices,
+ child) - parent_conn;
+ if (child_index == num_parent_vertices) {
+ side_number = -1;
+ return MB_SUCCESS;
+ else {
+ side_number = child_index;
result = get_connectivity(child, child_conn, num_child_vertices, true);
@@ -2127,8 +2141,9 @@
if (MB_SUCCESS != result && MB_MULTIPLE_ENTITIES_FOUND != result) return result;
if (!target_ents.empty() &&
- TYPE_FROM_HANDLE(*(target_ents.begin())) !=
- MBCN::mConnectivityMap[source_type][dim-1].target_type[side_number])
+ TYPE_FROM_HANDLE(*(target_ents.begin())) != MBVERTEX &&
+ MBCN::mConnectivityMap[source_type][dim-1].target_type[side_number])
return MB_ENTITY_NOT_FOUND;
if (!target_ents.empty()) target_entity = *(target_ents.begin());
