[MOAB-dev] r1378 - in MOAB/trunk: . parallel
kraftche at mcs.anl.gov
Mon Nov 12 08:30:53 CST 2007
Author: kraftche
Date: 2007-11-12 08:30:53 -0600 (Mon, 12 Nov 2007)
New Revision: 1378
Modified:
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/WriteHDF5.hpp
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
Log:
update parallel code for changes to poly(gon|hedron) representation
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2007-11-12 13:43:19 UTC (rev 1377)
+++ MOAB/trunk/WriteHDF5.cpp 2007-11-12 14:30:53 UTC (rev 1378)
@@ -401,14 +401,6 @@
for (ex_itor = exportList.begin(); ex_itor != exportList.end(); ++ex_itor)
if (MB_SUCCESS != write_elems( *ex_itor ))
goto write_fail;
-// if (ex_itor->type == MBPOLYGON || ex_itor->type == MBPOLYHEDRON)
-// result = write_poly( *ex_itor );
-// else
-// result = write_elems( *ex_itor );
-// if (MB_SUCCESS != result)
-// goto write_fail;
DEBUGOUT("Writing sets.\n");
@@ -1730,7 +1722,6 @@
writeUtil->assign_ids( ex_itor->range, idTag, (id_t)first_id );
ex_itor->first_id = (id_t)first_id;
ex_itor->offset = 0;
- ex_itor->poly_offset = 0;
// create node adjacency table
Modified: MOAB/trunk/WriteHDF5.hpp
--- MOAB/trunk/WriteHDF5.hpp 2007-11-12 13:43:19 UTC (rev 1377)
+++ MOAB/trunk/WriteHDF5.hpp 2007-11-12 14:30:53 UTC (rev 1378)
@@ -164,9 +164,6 @@
//! The offset at which to begin writting this processor's data.
//! Always zero except for parallel IO.
id_t offset;
- //! Offset for poly connectivity. Unused for non-poly elements.
- //! Always zero except for parallel IO.
- id_t poly_offset;
//! Offset for adjacency data. Always zero except for parallel IO
id_t adj_offset;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2007-11-12 13:43:19 UTC (rev 1377)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2007-11-12 14:30:53 UTC (rev 1378)
@@ -2,7 +2,7 @@
#include "MBParallelComm.hpp"
#include "MBWriteUtilIface.hpp"
#include "MBReadUtilIface.hpp"
-#include "EntitySequenceManager.hpp"
+#include "SequenceManager.hpp"
#include "EntitySequence.hpp"
#include "TagServer.hpp"
#include "MBTagConventions.hpp"
@@ -10,6 +10,8 @@
#include "MBParallelConventions.h"
#include "MBCore.hpp"
#include "MBError.hpp"
+#include "ElementSequence.hpp"
+#include "MBCN.hpp"
#include <iostream>
@@ -429,27 +431,28 @@
while (end_rit != entities.end() && TYPE_FROM_HANDLE(*start_rit) != MBENTITYSET) {
// get the sequence holding this entity
- MBEntitySequence *seq;
- ElementEntitySequence *eseq;
+ EntitySequence *seq;
+ ElementSequence *eseq;
result = sequenceManager->find(*start_rit, seq);
RR("Couldn't find entity sequence.");
if (NULL == seq) return MB_FAILURE;
- eseq = dynamic_cast<ElementEntitySequence*>(seq);
+ eseq = dynamic_cast<ElementSequence*>(seq);
// if type and nodes per element change, start a new range
- if (eseq->get_type() != *entTypes.rbegin() || (int) eseq->nodes_per_element() != *vertsPerEntity.rbegin()) {
- entTypes.push_back(eseq->get_type());
+ if (eseq->type() != *entTypes.rbegin() || (int) eseq->nodes_per_element() != *vertsPerEntity.rbegin()) {
+ entTypes.push_back(eseq->type());
vertsPerEntity.push_back(eseq->nodes_per_element());
allRanges.push_back(MBRange());
allr_it++;
// get position in entities list one past end of this sequence
- end_rit = entities.lower_bound(start_rit, entities.end(), eseq->get_end_handle()+1);
+ end_rit = entities.lower_bound(start_rit, entities.end(), eseq->end_handle()+1);
// put these entities in the last range
- eseq->get_entities(*allRanges.rbegin());
+ (*allRanges.rbegin()).insert( eseq->start_handle(), eseq->end_handle() );
+ //eseq->get_entities(*allRanges.rbegin());
whole_range.merge(*allRanges.rbegin());
// now start where we last left off
@@ -472,11 +475,12 @@
count += 2*sizeof(MBEntityHandle)*num_subranges(*vit);
// connectivity of subrange
if (iit != vertsPerEntity.begin()) {
- if (*eit != MBPOLYGON && *eit != MBPOLYHEDRON)
+ //if (*eit != MBPOLYGON && *eit != MBPOLYHEDRON)
// for non-poly's: #verts/ent * #ents * sizeof handle
- count += *iit * (*vit).size() * sizeof(MBEntityHandle);
+ // count += *iit * (*vit).size() * sizeof(MBEntityHandle);
// for poly's: length of conn list * handle size + #ents * int size (for offsets)
- else count += *iit * sizeof(MBEntityHandle) + (*vit).size() * sizeof(int);
+ //else
+ count += *iit * sizeof(MBEntityHandle) + (*vit).size() * sizeof(int);
// num_verts per subrange ent type in subrange
@@ -505,24 +509,24 @@
// pack the connectivity
const MBEntityHandle *connect;
int num_connect;
- if (*et_it == MBPOLYGON || *et_it == MBPOLYHEDRON) {
- std::vector<int> num_connects;
+ //if (*et_it == MBPOLYGON || *et_it == MBPOLYHEDRON) {
+ // std::vector<int> num_connects;
+ // for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
+ // result = mbImpl->get_connectivity(*rit, connect, num_connect);
+ // RR("Failed to get connectivity.");
+ // num_connects.push_back(num_connect);
+ // PACK_EH(buff_ptr, &connect[0], num_connect);
+ // PACK_INTS(buff_ptr, &num_connects[0], num_connects.size());
+ //else {
- num_connects.push_back(num_connect);
- PACK_EH(buff_ptr, &connect[0], num_connect);
- PACK_INTS(buff_ptr, &num_connects[0], num_connects.size());
- else {
- for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
- result = mbImpl->get_connectivity(*rit, connect, num_connect);
- RR("Failed to get connectivity.");
assert(num_connect == *nv_it);
whole_range.merge(*allr_it);
@@ -609,30 +613,30 @@
int num_elems = (*pit).second - (*pit).first + 1;
int *connect_offsets;
- if (this_type == MBPOLYGON || this_type == MBPOLYHEDRON) {
- result = ru->get_poly_element_array(num_elems, verts_per_entity, this_type,
- start_id, start_proc, actual_start,
- connect_offsets, connect);
- RR("Failed to allocate poly element arrays.");
+ //if (this_type == MBPOLYGON || this_type == MBPOLYHEDRON) {
+ // result = ru->get_poly_element_array(num_elems, verts_per_entity, this_type,
+ // start_id, start_proc, actual_start,
+ // connect_offsets, connect);
+ // RR("Failed to allocate poly element arrays.");
- else {
+ //else {
result = ru->get_element_array(num_elems, verts_per_entity, this_type,
connect);
RR("Failed to allocate element arrays.");
// copy connect arrays
- if (this_type != MBPOLYGON && this_type != MBPOLYHEDRON) {
- UNPACK_EH(buff_ptr, connect, num_elems * verts_per_entity);
- else {
+ //if (this_type != MBPOLYGON && this_type != MBPOLYHEDRON) {
+ // UNPACK_EH(buff_ptr, connect, num_elems * verts_per_entity);
+ //else {
UNPACK_EH(buff_ptr, connect, verts_per_entity);
assert(NULL != connect_offsets);
// and the offsets
UNPACK_INTS(buff_ptr, connect_offsets, num_elems);
entities.insert((*pit).first, (*pit).second);
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2007-11-12 13:43:19 UTC (rev 1377)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2007-11-12 14:30:53 UTC (rev 1378)
@@ -30,7 +30,7 @@
#include "MBProcConfig.hpp"
class TagServer;
-class EntitySequenceManager;
+class SequenceManager;
class MBParallelComm
@@ -192,7 +192,7 @@
TagServer *tagServer;
//! Sequence manager, to get more efficient access to entities
- EntitySequenceManager *sequenceManager;
+ SequenceManager *sequenceManager;
//! data buffer used to communicate
std::vector<unsigned char> myBuffer;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2007-11-12 13:43:19 UTC (rev 1377)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2007-11-12 14:30:53 UTC (rev 1378)
@@ -671,9 +671,7 @@
bool operator==( const elemtype& other ) const
return mbtype == other.mbtype &&
- (mbtype == MBPOLYGON ||
- mbtype == MBPOLYHEDRON ||
- mbtype == MBENTITYSET ||
+ (mbtype == MBENTITYSET ||
numnode == other.numnode);
bool operator<( const elemtype& other ) const
@@ -682,9 +680,7 @@
return false;
return mbtype < other.mbtype ||
- (mbtype != MBPOLYGON &&
- mbtype != MBPOLYHEDRON &&
- mbtype != MBENTITYSET &&
+ (mbtype != MBENTITYSET &&
numnode < other.numnode);
bool operator!=( const elemtype& other ) const
@@ -798,7 +794,7 @@
++ex_iter;
bool equal = ex_iter != exportList.end() && ex_iter->type == mbtype;
- if (equal && mbtype != MBPOLYGON && mbtype != MBPOLYHEDRON)
+ if (equal)
while (ex_iter != exportList.end() && ex_iter->num_nodes < numnode)
++ex_iter;
@@ -813,7 +809,6 @@
insert.num_nodes = numnode;
insert.first_id = 0;
insert.offset = 0;
- insert.poly_offset = 0;
insert.adj_offset = 0;
ex_iter = exportList.insert( ex_iter, insert );
@@ -864,51 +859,6 @@
for (ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter)
ex_iter->offset = (id_t)*(viter++);
- // If polygons or polyhedra, send calculate offsets for each
- std::vector<int> perproc(numProc+1);
- ExportSet *poly[] = {0,0};
- int polycount[2];
- for (ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter)
- if (ex_iter->type == MBPOLYGON)
- assert(!poly[0]);
- poly[0] = &*ex_iter;
- else if(ex_iter->type == MBPOLYHEDRON)
- assert(!poly[1]);
- poly[1] = &*ex_iter;
- for (int i = 0; i < 2; i++)
- ExportSet* ppoly = poly[i];
- if (!ppoly)
- continue;
- int count;
- rval = writeUtil->get_poly_array_size( ppoly->range.begin(),
- ppoly->range.end(),
- count );
- assert(MB_SUCCESS == rval);
- result = MPI_Gather( &count, 1, MPI_INT, &perproc[0], 1, MPI_INT, 0, MPI_COMM_WORLD );
- assert(MPI_SUCCESS == result);
- int prev = 0;
- for (int j = 1; j <= numProc; j++)
- int tmp = perproc[j];
- perproc[j] = prev;
- prev += tmp;
- polycount[i] = perproc[numProc];
- result = MPI_Scatter( &perproc[0], 1, MPI_INT, &count, 1, MPI_INT, 0, MPI_COMM_WORLD );
- ppoly->poly_offset = count;
// Create element tables
std::vector<long> start_ids(numtypes);
if (myRank == 0)
@@ -917,25 +867,10 @@
long* citer = &counts[numtypes * numProc];
- switch(ex_iter->type) {
- case MBPOLYGON:
- rval = create_poly_tables( MBPOLYGON,
- *citer,
- polycount[0],
- *viter );
- break;
- case MBPOLYHEDRON:
- rval = create_poly_tables( MBPOLYHEDRON,
- *citer,
- polycount[1],
- *viter );
- break;
- default:
- rval = create_elem_tables( ex_iter->type,
- ex_iter->num_nodes,
- *citer,
- *viter );
+ rval = create_elem_tables( ex_iter->type,
+ ex_iter->num_nodes,
+ *citer,
+ *viter );
++citer;
++viter;
