[MOAB-dev] r1374 - in MOAB/trunk: . test/perf tools/mbperf
kraftche at mcs.anl.gov
Fri Nov 9 16:28:33 CST 2007
Author: kraftche
Date: 2007-11-09 16:28:33 -0600 (Fri, 09 Nov 2007)
New Revision: 1374
Added:
MOAB/trunk/ElementSequence.hpp
MOAB/trunk/ScdElementData.cpp
MOAB/trunk/ScdElementData.hpp
MOAB/trunk/ScdVertexData.cpp
MOAB/trunk/ScdVertexData.hpp
MOAB/trunk/SequenceData.cpp
MOAB/trunk/SequenceData.hpp
MOAB/trunk/SequenceManager.cpp
MOAB/trunk/SequenceManager.hpp
MOAB/trunk/StructuredElementSeq.cpp
MOAB/trunk/StructuredElementSeq.hpp
MOAB/trunk/TestTypeSequenceManager.cpp
MOAB/trunk/TestUtil.hpp
MOAB/trunk/TypeSequenceManager.cpp
MOAB/trunk/TypeSequenceManager.hpp
MOAB/trunk/UnstructuredElemSeq.cpp
MOAB/trunk/UnstructuredElemSeq.hpp
MOAB/trunk/VertexSequence.cpp
MOAB/trunk/VertexSequence.hpp
Removed:
MOAB/trunk/EntitySequenceManager.cpp
MOAB/trunk/EntitySequenceManager.hpp
MOAB/trunk/PolyEntitySequence.cpp
MOAB/trunk/PolyEntitySequence.hpp
MOAB/trunk/ScdElementSeq.cpp
MOAB/trunk/ScdElementSeq.hpp
MOAB/trunk/ScdVertexSeq.cpp
MOAB/trunk/ScdVertexSeq.hpp
Modified:
MOAB/trunk/EntitySequence.cpp
MOAB/trunk/EntitySequence.hpp
MOAB/trunk/HigherOrderFactory.cpp
MOAB/trunk/HigherOrderFactory.hpp
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBRangeSeqIntersectIter.cpp
MOAB/trunk/MBRangeSeqIntersectIter.hpp
MOAB/trunk/MBReadUtil.cpp
MOAB/trunk/MBReadUtil.hpp
MOAB/trunk/MBReadUtilIface.hpp
MOAB/trunk/MBTest.cpp
MOAB/trunk/MBWriteUtil.cpp
MOAB/trunk/Makefile.am
MOAB/trunk/MeshSetSequence.cpp
MOAB/trunk/MeshSetSequence.hpp
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadVtk.cpp
MOAB/trunk/ReadVtk.hpp
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/WriteHDF5.hpp
MOAB/trunk/scdseq_test.cpp
MOAB/trunk/test/perf/perf.cpp
MOAB/trunk/tools/mbperf/mbperf.cpp
Log:
Rewrite EntitySequence data structure and logic:
o Represent holes in blocks of data by separating the EntitySequence
instance from the SequenceData instance.
o Separate entity-type specific logic and type-independent logic.
The latter is implemented in TypeSequenceManager. The SequenceManager
class implements the former and gains the latter through the
contained array of TypeSequenceManager instances (one for each
MBEntityType).
o Represent MBPOLYGON and MBPOLYHEDRON elements using the same fixed-
length connectivity data structure that is used for other unstructred
mesh elements. Create multiple sequences and group into sequences
by connectivity length.
o Update file readers and writers for change to poly element
representation. .H5M file format modified to use similar data
organization in the file format. Support for reading older-format
poly data is retained.
Added: MOAB/trunk/ElementSequence.hpp
--- MOAB/trunk/ElementSequence.hpp (rev 0)
+++ MOAB/trunk/ElementSequence.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,75 @@
+#ifndef ELEMENT_SEQUENCE_HPP
+#define ELEMENT_SEQUENCE_HPP
+#include "EntitySequence.hpp"
+#include "SequenceData.hpp"
+#include "MBCN.hpp"
+class ElementSequence : public EntitySequence
+public:
+ ElementSequence( MBEntityHandle start,
+ MBEntityID count,
+ unsigned int nodes_per_element,
+ SequenceData* data )
+ : EntitySequence( start, count, data ),
+ nodesPerElement(nodes_per_element)
+ virtual ~ElementSequence() {}
+ inline unsigned int nodes_per_element() const { return nodesPerElement; }
+ virtual MBErrorCode get_connectivity( MBEntityHandle handle,
+ std::vector<MBEntityHandle>& connect,
+ bool topological = false ) const = 0;
+ MBEntityHandle const*& connect,
+ int &connect_length,
+ bool topological = false,
+ std::vector<MBEntityHandle>* storage = 0
+ ) const = 0;
+ virtual MBErrorCode set_connectivity( MBEntityHandle handle,
+ MBEntityHandle const* connect,
+ int connect_length ) = 0;
+ inline MBEntityHandle const* get_connectivity_array() const;
+ virtual MBEntityHandle* get_connectivity_array() = 0;
+ inline bool has_mid_edge_nodes() const;
+ inline bool has_mid_face_nodes() const;
+ inline bool has_mid_volume_nodes() const;
+protected:
+ ElementSequence( ElementSequence& split_from, MBEntityHandle here )
+ : EntitySequence( split_from, here ),
+ nodesPerElement( split_from.nodesPerElement )
+private:
+ unsigned nodesPerElement;
+inline MBEntityHandle const*
+ElementSequence::get_connectivity_array() const
+ { return const_cast<ElementSequence*>(this)->get_connectivity_array(); }
+inline bool
+ElementSequence::has_mid_edge_nodes() const
+ { return MBCN::HasMidEdgeNodes( type(), nodes_per_element() ); }
+inline bool
+ElementSequence::has_mid_face_nodes() const
+ { return MBCN::HasMidFaceNodes( type(), nodes_per_element() ); }
+inline bool
+ElementSequence::has_mid_volume_nodes() const
+ { return MBCN::HasMidRegionNodes( type(), nodes_per_element() ); }
+#endif
Modified: MOAB/trunk/EntitySequence.cpp
--- MOAB/trunk/EntitySequence.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/EntitySequence.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,816 +1,73 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation. Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-#ifdef WIN32
-#ifdef _DEBUG
-// turn off warnings that say they debugging identifier has been truncated
-// this warning comes up when using some STL containers
-#pragma warning(disable : 4786)
-#endif
-#endif
-#include "EntitySequenceManager.hpp"
-#include "MBCN.hpp"
-#include <assert.h>
-#include "AEntityFactory.hpp"
-#include "MBCore.hpp"
-#include <set>
-using namespace std;
-//Constructor
-MBEntitySequence::MBEntitySequence(EntitySequenceManager* seq_manager,
- MBEntityHandle start_handle, MBEntityID num_entities )
- : mSequenceManager(seq_manager)
+bool EntitySequence::using_entire_data() const
- assert(MB_START_ID <= ID_FROM_HANDLE(start_handle));
- assert(TYPE_FROM_HANDLE(start_handle) < MBMAXTYPE);
- // set first entity handle in sequence
- mStartEntityHandle = start_handle;
- // set number of entity handles in sequence
- mNumAllocated = num_entities;
- // no entities created yet
- mNumEntities = 0;
- mLastDeletedIndex = -1;
+ return start_handle() == data()->start_handle()
+ && end_handle() == data()-> end_handle();
-MBEntitySequence::~MBEntitySequence()
+int EntitySequence::values_per_entity() const
+ { return 0; }
-VertexEntitySequence::VertexEntitySequence(EntitySequenceManager* seq_manager,
- MBEntityID num_entities,
- bool all_handles_used)
-: MBEntitySequence(seq_manager, start_handle, num_entities)
+MBErrorCode EntitySequence::pop_back( MBEntityID count )
- // we are assuming this through most of this class, so make
- // sure it's true. - j.k. 2007-03-09
- assert(sizeof(MBEntityID) <= sizeof(double));
- seq_manager->entity_sequence_created(this);
- // allocate the arrays
- mCoords = new double* [3];
- mCoords[0] = new double[num_entities];
- mCoords[1] = new double[num_entities];
- mCoords[2] = new double[num_entities];
+ MBEntityHandle new_end = endHandle - count;
+ if (new_end < startHandle)
+ return MB_FAILURE;
- mFreeEntities.clear();
- if(all_handles_used)
- mNumEntities = num_entities;
- mFirstFreeIndex = -1;
- else
- seq_manager->notify_not_full(this);
- mFreeEntities.resize(mNumAllocated, true);
- mNumEntities = 0;
- mFirstFreeIndex = 0;
- for(MBEntityID i=0; i<num_entities; i++)
- reinterpret_cast<MBEntityID&>(mCoords[0][i]) = i+1;
- reinterpret_cast<MBEntityID&>(mCoords[0][num_entities-1]) = -1;
+ endHandle = new_end;
+ return MB_SUCCESS;
-VertexEntitySequence::~VertexEntitySequence()
+MBErrorCode EntitySequence::pop_front( MBEntityID count )
- mSequenceManager->entity_sequence_deleted(this);
- delete [] mCoords[0];
- delete [] mCoords[1];
- delete [] mCoords[2];
- delete [] mCoords;
-MBEntityHandle VertexEntitySequence::get_unused_handle()
- if(mFirstFreeIndex == -1)
- return 0;
- MBEntityHandle new_handle = mStartEntityHandle + mFirstFreeIndex;
- mFreeEntities[mFirstFreeIndex] = false;
- mFirstFreeIndex = reinterpret_cast<MBEntityID&>(mCoords[0][mFirstFreeIndex]);
- mNumEntities++;
- if(mNumEntities == mNumAllocated) {
- mSequenceManager->notify_full(this);
- std::vector<bool> empty;
- mFreeEntities.swap(empty);
- if( mLastDeletedIndex == (MBEntityID)( new_handle - mStartEntityHandle ))
- return new_handle;
-MBErrorCode VertexEntitySequence::allocate_handle(MBEntityHandle handle)
- return MB_FAILURE;
-void VertexEntitySequence::free_handle(MBEntityHandle handle)
- if(!is_valid_entity(handle))
- return;
- mSequenceManager->notify_not_full(this);
- mFreeEntities.resize( mNumAllocated, false );
- mFreeEntities[handle - mStartEntityHandle] = true;
- MBEntityID prev_free_handle = -1;
- const MBEntityID handle_index = handle - mStartEntityHandle;
+ MBEntityHandle new_start = startHandle + count;
+ if (new_start > endHandle)
- MBEntityID index = mFirstFreeIndex;
- if( mLastDeletedIndex != -1 && handle_index > mLastDeletedIndex)
- index = mLastDeletedIndex;
- mLastDeletedIndex = handle_index;
- for(;
- (index != -1) && (index < handle_index);
- index = reinterpret_cast<MBEntityID&>(mCoords[0][index]) )
- prev_free_handle = index;
- // was full and now has one free handle
- if(prev_free_handle == -1 && mFirstFreeIndex == -1)
- mFirstFreeIndex = handle_index;
- reinterpret_cast<MBEntityID&>(mCoords[0][handle_index]) = -1;
- // insert before all free handles
- else if(prev_free_handle == -1)
- reinterpret_cast<MBEntityID&>(mCoords[0][handle_index]) = mFirstFreeIndex;
- // insert in middle or end
- else
- reinterpret_cast<MBEntityID&>(mCoords[0][prev_free_handle]);
- reinterpret_cast<MBEntityID&>(mCoords[0][prev_free_handle]) = handle_index;
- mNumEntities--;
+ startHandle = new_start;
-void VertexEntitySequence::get_entities(MBRange& entities) const
- MBRange::iterator iter = entities.insert(mStartEntityHandle, mStartEntityHandle+mNumAllocated-1);
- for(MBEntityID index = mFirstFreeIndex; (index != -1);
- index = reinterpret_cast<MBEntityID&>(mCoords[0][index]))
- for(; *iter != (mStartEntityHandle+index); ++iter);
- entities.erase(iter);
-MBEntityID VertexEntitySequence::get_next_free_index( MBEntityID prev_free_index ) const
+MBErrorCode EntitySequence::prepend_entities( MBEntityID count )
- if (prev_free_index < 0)
- return mFirstFreeIndex;
- return reinterpret_cast<MBEntityID&>(mCoords[0][prev_free_index]);
-void VertexEntitySequence::get_memory_use( unsigned long& used,
- unsigned long& allocated) const
- unsigned long per_ent = get_memory_use((MBEntityHandle)0);
- allocated = sizeof(*this) + mFreeEntities.capacity()/8 + per_ent*number_allocated();
- used = per_ent * number_entities();
-unsigned long VertexEntitySequence::get_memory_use( MBEntityHandle ) const
- return 3 * sizeof(double);
-MBEntityID ElementEntitySequence::get_next_free_index( MBEntityID prev_free_index ) const
- return reinterpret_cast<MBEntityID&>(mElements[prev_free_index*mNodesPerElement]);
-ElementEntitySequence::ElementEntitySequence(EntitySequenceManager* seq_manager,
- MBEntityHandle start_handle, MBEntityID num_entities,
- int nodes_per_element, bool all_handles_used,
- bool allocate_connect)
- // this should never fail unless something when seriously wrong
- // during the configure phase, but make sure anyway because we're
- // doing reintepret_casts
- assert(sizeof(MBEntityHandle)>=sizeof(MBEntityID));
- assert(nodes_per_element < 28);
- if (allocate_connect) {
- mElements = new MBEntityHandle[num_entities*nodes_per_element];
- memset(mElements, 0, sizeof(MBEntityHandle)*num_entities*nodes_per_element);
- else {
- mElements = NULL;
+ MBEntityHandle new_start = startHandle - count;
+ if (new_start < data()->start_handle())
- mNodesPerElement = nodes_per_element;
- else
- mFreeEntities.resize( mNumAllocated, true );
- mNumEntities = 0;
- if (nodes_per_element)
- MBEntityID max = (num_entities-1)*nodes_per_element;
- for(MBEntityID i=0; i<max ; i+=nodes_per_element)
- mElements[i] = (i/nodes_per_element)+1;
- reinterpret_cast<MBEntityID&>(mElements[max]) = -1;
-ElementEntitySequence::~ElementEntitySequence()
+MBErrorCode EntitySequence::append_entities( MBEntityID count )
- if (NULL != mElements)
- delete [] mElements;
-MBEntityHandle ElementEntitySequence::get_unused_handle()
- return 0;
- mFirstFreeIndex = reinterpret_cast<MBEntityID&>(mElements[mFirstFreeIndex*mNodesPerElement]);
- mNumEntities++;
+ MBEntityHandle new_end = endHandle + count;
+ if (new_end > data()->end_handle())
-MBErrorCode ElementEntitySequence::allocate_handle(MBEntityHandle handle)
+MBErrorCode EntitySequence::merge( EntitySequence& other )
-void ElementEntitySequence::free_handle(MBEntityHandle handle)
- return;
+ if (sequenceData != other.sequenceData)
+ if (end_handle() + 1 == other.start_handle()) {
+ endHandle = other.end_handle();
+ other.startHandle = other.end_handle()+1;
- mFreeEntities[handle-mStartEntityHandle] = true;
- MBEntityID prev_free_index = -1;
- for(;
- index = reinterpret_cast<MBEntityID&>(mElements[index*mNodesPerElement]) )
- prev_free_index = index;
+ else if (start_handle() == other.end_handle() + 1) {
+ startHandle = other.start_handle();
+ other.endHandle = other.start_handle()-1;
- memset(&mElements[handle_index*mNodesPerElement], 0, sizeof(MBEntityHandle)*mNodesPerElement);
- if(prev_free_index == -1 && mFirstFreeIndex == -1)
- reinterpret_cast<MBEntityID&>(mElements[handle_index*mNodesPerElement]) = -1;
- else if(prev_free_index == -1)
- reinterpret_cast<MBEntityID&>(mElements[handle_index*mNodesPerElement]) = mFirstFreeIndex;
else
- mElements[handle_index*mNodesPerElement] = mElements[prev_free_index*mNodesPerElement];
- reinterpret_cast<MBEntityID&>(mElements[prev_free_index*mNodesPerElement]) = handle_index;
- mNumEntities--;
-void ElementEntitySequence::get_entities(MBRange& entities) const
- for(MBEntityID index = mFirstFreeIndex; index != -1;
-MBErrorCode ElementEntitySequence::split(MBEntityHandle split_location,
- MBEntitySequence*& new_sequence)
- // only split (begin, end)
- assert(mStartEntityHandle < split_location);
- assert(get_end_handle() >= split_location);
- // make a new sequence
- const bool all_used = mFreeEntities.empty();
- ElementEntitySequence* seq = new ElementEntitySequence( mSequenceManager, split_location,
- get_end_handle() - split_location + 1 , mNodesPerElement, all_used);
- new_sequence = seq;
- // copy data into new sequence
- memcpy(seq->mElements, &mElements[mNodesPerElement*(split_location - mStartEntityHandle)],
- seq->mNumAllocated*mNodesPerElement*sizeof(MBEntityHandle));
- // make a new shorter array for this sequence and copy data over
- mNumAllocated = split_location - mStartEntityHandle;
- MBEntityHandle* tmp = new MBEntityHandle[mNumAllocated*mNodesPerElement];
- memcpy(tmp, mElements, mNumAllocated*mNodesPerElement*sizeof(MBEntityHandle));
- mElements = tmp;
- if (all_used) {
- mNumEntities = split_location - get_start_handle();
- assert( mFirstFreeIndex == -1 );
- assert( mLastDeletedIndex == -1 );
- assert( seq->mFirstFreeIndex == -1 );
- assert( seq->mLastDeletedIndex == -1 );
- assert( mNumEntities == mNumAllocated );
- assert( seq->mNumEntities == seq->mNumAllocated );
- return MB_SUCCESS;
- //copy free handles over too
- std::copy(mFreeEntities.begin()+(split_location-mStartEntityHandle),
- mFreeEntities.end(), seq->mFreeEntities.begin());
- // shrink capacity to what we need
- mFreeEntities.resize(mNumAllocated);
- std::vector<bool>(mFreeEntities).swap(mFreeEntities);
- // need to recompute : mNumEntities, mFirstFreeIndex for both sequences
- mNumEntities = 0;
- std::vector<bool>::reverse_iterator iter = mFreeEntities.rbegin();
- std::vector<bool>::reverse_iterator end_iter = mFreeEntities.rend();
- MBEntityID index = mFreeEntities.size() - 1;
- MBEntityID last_index = -1;
- for(; iter != end_iter; )
- if(*iter == true)
- reinterpret_cast<MBEntityID&>(mElements[index*mNodesPerElement]) = last_index;
- last_index = index;
- else
- ++mNumEntities;
- ++iter;
- --index;
- mFirstFreeIndex = last_index;
- mFreeEntities.swap( empty );
- else
- seq->mNumEntities = 0;
- seq->mFirstFreeIndex = -1;
- iter = seq->mFreeEntities.rbegin();
- end_iter = seq->mFreeEntities.rend();
- index = seq->mFreeEntities.size() - 1;
- last_index = -1;
- if(*iter == true)
- reinterpret_cast<MBEntityID&>(seq->mElements[index*mNodesPerElement]) = last_index;
- else
- ++seq->mNumEntities;
- ++iter;
- --index;
- seq->mFirstFreeIndex = last_index;
- if(seq->mNumEntities == seq->mNumAllocated) {
- mSequenceManager->notify_full(seq);
- seq->mFreeEntities.swap( empty );
- else
- mSequenceManager->notify_not_full(seq);
return MB_SUCCESS;
-MBErrorCode ElementEntitySequence::convert_realloc(bool& mid_edge_nodes,
- bool& mid_face_nodes, bool& mid_volume_nodes, MBCore* MB,
- MBTag delete_mark_bit )
- MBEntityType this_type = get_type();
- // figure out how many nodes per element we'll end up with
- int num_corner_nodes = MBCN::VerticesPerEntity(this_type);
- int new_nodes_per_element = num_corner_nodes;
- if(mid_edge_nodes)
- new_nodes_per_element += MBCN::mConnectivityMap[this_type][0].num_sub_elements;
- if(mid_face_nodes)
- new_nodes_per_element += MBCN::mConnectivityMap[this_type][1].num_sub_elements;
- if(mid_volume_nodes)
- new_nodes_per_element++;
- if(new_nodes_per_element == mNodesPerElement)
- // make the new array
- MBEntityHandle* new_array = new MBEntityHandle[mNumAllocated*new_nodes_per_element];
- memset(new_array, 0, sizeof(MBEntityHandle)*mNumAllocated*new_nodes_per_element);
- // copy the corner nodes
- MBEntityHandle* old_end_handle = mElements + mNodesPerElement*mNumAllocated;
- MBEntityHandle* old_iter = mElements;
- MBEntityHandle* new_iter = new_array;
- int amount_to_copy = num_corner_nodes*sizeof(MBEntityHandle);
- for(; old_iter < old_end_handle; )
- memcpy(new_iter, old_iter, amount_to_copy);
- old_iter += mNodesPerElement;
- new_iter += new_nodes_per_element;
- // copy mid edge nodes if they existed and we want to keep them
- if(mid_edge_nodes && has_mid_edge_nodes())
- amount_to_copy = MBCN::mConnectivityMap[this_type][0].num_sub_elements * sizeof(MBEntityHandle);
- old_end_handle = mElements + mNodesPerElement*mNumAllocated;
- old_iter = mElements + MBCN::VerticesPerEntity(this_type);
- new_iter = new_array + MBCN::VerticesPerEntity(this_type);
- // need to delete them
- else if(has_mid_edge_nodes())
- int number_to_delete = MBCN::mConnectivityMap[this_type][0].num_sub_elements;
- std::set<MBEntityHandle> nodes_processed;
- //tag each node-to-delete with parent element entity handle and number
- //of elements it is found on
- for(int i=0; i<number_to_delete; i++)
- //see if node has been processed yet
- if( old_iter[i] && nodes_processed.insert(old_iter[i]).second )
- //determines if node should be deleted or not
- //(makes sure it's not on other entities besides those in this sequence)
- if( tag_for_deletion( old_iter - mElements, MB ) )
- //tag node as deletable
- unsigned char bit = 0x1;
- MB->tag_set_data(delete_mark_bit, &(old_iter[i]), 1, &bit);
- // copy mid face nodes if they existed and we want to keep them
- if(mid_face_nodes && has_mid_face_nodes())
- amount_to_copy = MBCN::mConnectivityMap[this_type][1].num_sub_elements * sizeof(MBEntityHandle);
- if(has_mid_edge_nodes())
- old_iter += MBCN::mConnectivityMap[this_type][0].num_sub_elements;
- new_iter += MBCN::mConnectivityMap[this_type][0].num_sub_elements;
- else if(has_mid_face_nodes())
- int number_to_delete = MBCN::mConnectivityMap[this_type][1].num_sub_elements;
- old_iter+=MBCN::mConnectivityMap[this_type][0].num_sub_elements;
- // copy mid volume nodes if they existed and we want to keep them
- if(mid_volume_nodes && has_mid_volume_nodes())
- if(has_mid_face_nodes())
- old_iter += MBCN::mConnectivityMap[this_type][1].num_sub_elements;
- new_iter = new_array + (new_nodes_per_element - 1);
- *new_iter = *old_iter;
- else if(has_mid_volume_nodes())
- if( *old_iter != 0 && tag_for_deletion( old_iter - mElements, MB ) )
- MB->tag_set_data(delete_mark_bit, &(*old_iter), 1, &bit);
- // did we actually allocate new space for these?
- mid_edge_nodes = !has_mid_edge_nodes();
- mid_face_nodes = !has_mid_face_nodes();
- mid_volume_nodes = !has_mid_volume_nodes();
- // swap arrays
- mElements = new_array;
- mNodesPerElement = new_nodes_per_element;
-bool ElementEntitySequence::has_mid_edge_nodes() const
- return MBCN::HasMidEdgeNodes(get_type(), mNodesPerElement);
-bool ElementEntitySequence::has_mid_face_nodes() const
- return MBCN::HasMidFaceNodes(get_type(), mNodesPerElement);
-bool ElementEntitySequence::has_mid_volume_nodes() const
- return MBCN::HasMidRegionNodes(get_type(), mNodesPerElement);
-bool ElementEntitySequence::tag_for_deletion( MBEntityID node_index,
- MBCore *MB )
- //get type of this sequence
- //find 'parent' element (in this sequence)
- const MBEntityHandle elem_index = node_index / mNodesPerElement;
- const int conn_index = node_index % mNodesPerElement;
- const MBEntityHandle parent_handle = elem_index + mStartEntityHandle;
- //get dimension of 'parent' element
- int this_dimension = MB->dimension_from_handle( parent_handle );
- //tells us if higher order node is on
- int dimension, side_number;
- MBCN::HONodeParent( this_type, mNodesPerElement,
- conn_index, dimension, side_number );
- //it MUST be a higher-order node
- bool delete_node = false;
- assert( dimension != -1 );
- assert( side_number != -1 );
- //could be a mid-volume/face/edge node on a hex/face/edge respectively
- //if so...delete it bc/ no one else owns it too
- std::vector<MBEntityHandle> connectivity;
- if( dimension == this_dimension && side_number == 0 )
- delete_node = true;
- else //the node could also be on a lower order entity of 'tmp_entity'
- //get 'side' of 'parent_handle' that node is on
- MBEntityHandle target_entity = 0;
- MB->side_element( parent_handle, dimension, side_number, target_entity );
- if( target_entity )
- AEntityFactory *a_fact = MB->a_entity_factory();
- MBEntityHandle low_meshset;
- int dum;
- low_meshset = CREATE_HANDLE(MBENTITYSET, 0, dum);
- //just get corner nodes of target_entity
- connectivity.clear();
- MB->get_connectivity(&( target_entity), 1, connectivity, true );
- //for each node, get all common adjacencies of nodes in 'parent_handle'
- std::vector<MBEntityHandle> adj_list_1, adj_list_2, adj_entities;
- a_fact->get_adjacencies(connectivity[0], adj_list_1);
- // remove meshsets
- adj_list_1.erase(std::remove_if(adj_list_1.begin(), adj_list_1.end(),
- std::bind2nd(std::greater<MBEntityHandle>(),low_meshset)), adj_list_1.end());
- size_t i;
- for( i=1; i<connectivity.size(); i++)
- adj_list_2.clear();
- a_fact->get_adjacencies(connectivity[i], adj_list_2);
- adj_list_2.erase(std::remove_if(adj_list_2.begin(), adj_list_2.end(),
- std::bind2nd(std::greater<MBEntityHandle>(),low_meshset)), adj_list_2.end());
- //intersect the 2 lists
- adj_entities.clear();
- std::set_intersection(adj_list_1.begin(), adj_list_1.end(),
- adj_list_2.begin(), adj_list_2.end(),
- std::back_inserter< std::vector<MBEntityHandle> >(adj_entities));
- adj_list_1.clear();
- adj_list_1 = adj_entities;
- assert( adj_entities.size() ); //has to have at least one adjacency
- //see if node is in other elements, not in this sequence...if so, delete it
- for( i=0; i<adj_entities.size(); i++)
- if( adj_entities[i] >= get_start_handle() &&
- adj_entities[i] <= get_end_handle() )
- delete_node = false;
- break;
- else
- else //there is no lower order entity that also contains node
- return delete_node;
-void ElementEntitySequence::get_memory_use( unsigned long& used,
-unsigned long ElementEntitySequence::get_memory_use( MBEntityHandle ) const
- return sizeof(MBEntityHandle) * nodes_per_element();
+unsigned long EntitySequence::get_per_entity_memory_use( MBEntityHandle,
+ MBEntityHandle ) const
+ { return 0; }
Modified: MOAB/trunk/EntitySequence.hpp
--- MOAB/trunk/EntitySequence.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/EntitySequence.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,352 +1,126 @@
+#ifndef ENTITY_SEQUENCE_HPP
+#define ENTITY_SEQUENCE_HPP
- * \class MBEntitySequence
- * \authors Karl Merkley & Corey Ernst
- * \date 3/27/02
- * \brief The MBEntitySequence represents a contiguous range of
- * mesh entities of a single type. MBEntitySequence manages
- * the internal ids of those entities using a starting id and
- * the number of entities in the range. All MBEntitySequences
- * for a given MBEntity type are stored in an stl Map. When a
- * MBHandle references an entity in mdb, mdb finds the Entity-
- * Sequence associated with the MBHandle from the stl Map.
-#ifndef MB_ENTITY_SEQUENCE_HPP
-#define MB_ENTITY_SEQUENCE_HPP
-#ifndef IS_BUILDING_MB
-#error "EntitySequence.hpp isn't supposed to be included into an application"
-#endif
-#include "MBForward.hpp"
+#include "MBTypes.h"
#include "MBInternals.hpp"
-#include <set>
-class EntitySequenceManager;
-class MBCore;
+class SequenceData;
-class MBEntitySequence
-public:
+class EntitySequence {
+private:
+ MBEntityHandle startHandle, endHandle;
+ SequenceData* sequenceData;
- //! Constructor-- takes a start handle, and number of entities
- //! if all_handles_used is true, then there is no room to create
- //! new entities
- MBEntitySequence( EntitySequenceManager* manager,
- MBEntityID num_entities);
+protected:
- //! Destructor
- virtual ~MBEntitySequence();
+ EntitySequence( MBEntityHandle h )
+ : startHandle(h), endHandle(h) {}
- //! gets starting MBEntityHandle (mStartEntityHandle)
- //! note: this doesn't account for unused entity handles
- MBEntityHandle get_start_handle() const { return mStartEntityHandle; }
- //! gets the end of allocated entities, does not account for holes
- MBEntityHandle get_end_handle() const { return mStartEntityHandle + mNumAllocated - 1; }
- //! get type of elements in EntitySequence
- MBEntityType get_type() const { return TYPE_FROM_HANDLE(mStartEntityHandle); }
- //! returns number of MBEntityHandles in MBEntitySequence
- MBEntityID number_entities() const {return mNumEntities;}
- //! returns the number of entities space was allocated for
- MBEntityID number_allocated() const { return mNumAllocated; }
- inline bool is_valid_entity(MBEntityHandle entity) const;
- //! get an unused handle
- virtual MBEntityHandle get_unused_handle() = 0;
- //! free an entity handle
- virtual void free_handle(MBEntityHandle handle) = 0;
- //! get entities in this range, will not add unused entities
- virtual void get_entities(MBRange& entities) const = 0;
- //! split this sequence range [begin, end] into
- //! [begin, split_location-1] and [split_location, end]
- //! returns the new_entitiy sequence which holds [split_location, end]
- //! returns success
- virtual MBErrorCode split(MBEntityHandle split_location, MBEntitySequence*& new_sequence)
+ EntitySequence( EntitySequence& split_from, MBEntityHandle here )
+ : startHandle( here ),
+ endHandle( split_from.endHandle ),
+ sequenceData( split_from.sequenceData )
- split_location = split_location;
- new_sequence = NULL;
+ split_from.endHandle = here - 1;
- virtual MBEntityID get_next_free_index( MBEntityID prev_free_index ) const = 0;
- virtual void get_memory_use( unsigned long& used,
- unsigned long& allocated ) const = 0;
- virtual unsigned long get_memory_use( MBEntityHandle handle ) const = 0;
+ SequenceData* create_data_subset( MBEntityHandle start_handle,
+ MBEntityHandle end_handle,
+ int num_sequence_arrays,
+ unsigned const* bytes_per_element ) const;
-protected:
+ MBErrorCode prepend_entities( MBEntityID count );
+ MBErrorCode append_entities( MBEntityID count );
- //! allocate the handle passed in, effectively creating the entity
- virtual MBErrorCode allocate_handle(MBEntityHandle handle) = 0;
- EntitySequenceManager* mSequenceManager;
- //!id to 1st element in EntitySequence
- MBEntityHandle mStartEntityHandle;
- //!number of Entities in EntitySequence
- MBEntityID mNumEntities;
- //!the number of entities that space has been allocated for
- MBEntityID mNumAllocated;
- //! the head to the list of unused handles, -1 is no free handles
- MBEntityID mFirstFreeIndex;
- //! the last entity deleted, for speed when deleting entities sequentially
- //! -1 is means no last index
- MBEntityID mLastDeletedIndex;
- //! a list of whether entities are free or not
- std::vector<bool> mFreeEntities;
-//! entity sequence for vertex type entities
-class VertexEntitySequence : public MBEntitySequence
public:
- //! constructor
- VertexEntitySequence(EntitySequenceManager* seq_manager,
- MBEntityHandle start_handle, MBEntityID num_entities, bool all_handles_used);
- //! destructor
- virtual ~VertexEntitySequence();
- MBEntityHandle get_unused_handle();
- virtual void free_handle(MBEntityHandle handle);
+ EntitySequence( MBEntityHandle start, MBEntityID count, SequenceData* data )
+ : startHandle(start), endHandle( start + count - 1 ), sequenceData( data )
- MBErrorCode get_coordinates(MBEntityHandle entity,
- double& x, double& y, double& z) const;
- double* xyz) const;
- MBErrorCode get_coordinates_ref(MBEntityHandle entity,
- const double*& x, const double*& y, const double*& z) const;
- MBErrorCode set_coordinates(MBEntityHandle entity,
- const double& x,
- const double& y,
- const double& z);
- MBErrorCode get_coordinate_arrays(double*& x, double*& y, double*& z);
+ virtual ~EntitySequence() {}
- virtual void get_entities(MBRange& entities) const;
- virtual MBEntityID get_next_free_index( MBEntityID prev_free_index ) const;
+ MBEntityType type() const
+ { return TYPE_FROM_HANDLE(start_handle()); }
- virtual void get_memory_use( unsigned long& used, unsigned long& allocated ) const;
- virtual unsigned long get_memory_use( MBEntityHandle handle ) const;
-protected:
- virtual MBErrorCode allocate_handle(MBEntityHandle handle);
+ MBEntityHandle start_handle() const
+ { return startHandle; }
-private:
- // coordinate arrays x,y,z
- double** mCoords;
+ MBEntityHandle end_handle() const
+ { return endHandle; }
-class ElementEntitySequence: public MBEntitySequence
-public:
- ElementEntitySequence(EntitySequenceManager* seq_manager,
- bool allocate_connect = true);
- virtual ~ElementEntitySequence();
- virtual MBEntityHandle get_unused_handle();
- virtual unsigned int nodes_per_element() const { return mNodesPerElement; }
- virtual MBErrorCode get_connectivity(MBEntityHandle entity,
- std::vector<MBEntityHandle>& connectivity,
- const bool topological_connectivity = false) const;
- const MBEntityHandle*& connectivity,
- int &num_vertices,
- const bool topological_connectivity = false,
- std::vector<MBEntityHandle>* storage = 0) const;
- virtual MBErrorCode set_connectivity(MBEntityHandle entity, const MBEntityHandle *conn,
- const int num_vertices);
- virtual MBErrorCode get_connectivity_array(MBEntityHandle*& conn_array);
+ SequenceData* data() const
+ { return sequenceData; }
+ void data( SequenceData* ptr )
+ { sequenceData = ptr; }
+ MBEntityID size() const
+ { return endHandle - startHandle + 1; }
+ /**\brief True if SequenceData has no holes and is used only
+ * by this EntitySequence */
+ bool using_entire_data() const;
+ /**\brief Integer value used in finding appropriate SequenceData
+ * This value is matched to input values by TypeSequenceManager to
+ * determine if an available, unused portino of a SequenceData can
+ * be used for a specific entity allocation. For example, it is
+ * used to find a SequenceData with the appropriate number of vertices
+ * per element when allocating elements. The default value is zero.
+ virtual int values_per_entity() const;
- virtual MBErrorCode split(MBEntityHandle split_location, MBEntitySequence*& new_sequence);
+ /**\brief Split this sequence into two consecutive sequences
+ * Split this sequence into two sequences.
+ *\param here New sequences should be [start_handle(),here) & [here,end_handle()]
+ *\return New sequence containing [here,end_handle()]
+ virtual EntitySequence* split( MBEntityHandle here ) = 0;
- // reallocated the sequence to hold extra/less nodes, pass in what you want, and will return whether it needed
- // reallocate space for those nodes
- virtual MBErrorCode convert_realloc(bool& mid_edge_nodes, bool& mid_face_nodes, bool& mid_volume_nodes,
- MBCore* MB, MBTag bit_delete_mark );
+ /**\brief Merge this sequence with another
+ * Combine two adjacent sequences. Sequence handle blocks must be
+ * consective and sequences must share a common SequenceData.
+ virtual MBErrorCode merge( EntitySequence& other );
- virtual bool has_mid_edge_nodes() const;
- virtual bool has_mid_face_nodes() const;
- virtual bool has_mid_volume_nodes() const;
-protected:
+ /**\brief Erase entities in range: (end_handle()-count, end_handle()] */
+ virtual MBErrorCode pop_back( MBEntityID count );
+ /**\brief Erase entities in range: [start_handle(), start_handle()+count) */
+ virtual MBErrorCode pop_front( MBEntityID count );
- unsigned short mNodesPerElement;
+ /**\brief Create a new SequenceData that is a copy of a subset of
+ * the one referenced by this sequence.
+ * Create a new SequenceData that is a copy of a subset of the
+ * SequenceData referenced by this EntitySequence. Do not make any
+ * changes to this EntitySequence or the current SequenceData.
+ virtual SequenceData* create_data_subset( MBEntityHandle start_handle,
+ MBEntityHandle end_handle ) const = 0;
- MBEntityHandle* mElements;
- /** Check if HO node should be deleted when removed from element.
- *\param node_index Location of node in connectivity array of this sequence
+ /**\brief Get memory characteristcs that are the same for all entities
+ * Get charactersitic constant memory use for all entities in sequence.
+ *\param bytes_per_entity The total bytes consumed for each entity in
+ * the underlying SequenceData. It is assumed
+ * that the same amount of memory is consumed
+ * for unused portions of the SequenceData.
+ *\param size_of_sequence The size of the leaf subclass of this class
- bool tag_for_deletion( MBEntityID node_index, MBCore *MB );
+ virtual void get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& size_of_sequence ) const = 0;
+ /**\brief Get portion of memory use that varies per entity
+ *\return Any per-entity memory use not accounted for in the results
+ * of get_const_memory_use.
+ virtual unsigned long get_per_entity_memory_use( MBEntityHandle first,
+ MBEntityHandle last ) const;
-inline bool MBEntitySequence::is_valid_entity(MBEntityHandle entity) const
- return mFreeEntities.empty() || !mFreeEntities[entity-mStartEntityHandle];
-inline MBErrorCode VertexEntitySequence::get_coordinates(MBEntityHandle handle,
- unsigned int index = handle - mStartEntityHandle;
- x = mCoords[0][index];
- y = mCoords[1][index];
- z = mCoords[2][index];
- xyz[0] = mCoords[0][index];
- xyz[1] = mCoords[1][index];
- xyz[2] = mCoords[2][index];
-inline MBErrorCode VertexEntitySequence::get_coordinates_ref(MBEntityHandle handle,
- x = &mCoords[0][index];
- y = &mCoords[1][index];
- z = &mCoords[2][index];
-inline MBErrorCode VertexEntitySequence::set_coordinates(MBEntityHandle handle,
- const double& x, const double& y, const double& z)
- mCoords[0][index] = x;
- mCoords[1][index] = y;
- mCoords[2][index] = z;
-inline MBErrorCode VertexEntitySequence::get_coordinate_arrays(double*& x, double*& y, double*& z)
- x = mCoords[0];
- y = mCoords[1];
- z = mCoords[2];
-inline MBErrorCode ElementEntitySequence::get_connectivity(MBEntityHandle entity,
- const MBEntityHandle*& conn,
- const bool topological_connectivity,
- std::vector<MBEntityHandle>* ) const
- num_vertices = mNodesPerElement;
- int index = entity - mStartEntityHandle;
- conn = mElements+index*mNodesPerElement;
- num_vertices = (topological_connectivity ? MBCN::VerticesPerEntity(TYPE_FROM_HANDLE(entity))
- : mNodesPerElement);
- std::vector<MBEntityHandle> &conn,
- const bool topological_connectivity) const
- int numv = (topological_connectivity ? MBCN::VerticesPerEntity(TYPE_FROM_HANDLE(entity))
- conn.reserve(numv);
- MBErrorCode result = MB_SUCCESS;
- if (!is_valid_entity(entity)) result = MB_FAILURE;
- else
- conn.insert(conn.end(), mElements+index*mNodesPerElement,
- mElements+index*mNodesPerElement+numv);
- return result;
-inline MBErrorCode ElementEntitySequence::set_connectivity(MBEntityHandle entity,
- const MBEntityHandle *conn,
- if(num_vertices != mNodesPerElement)
- MBEntityHandle* iter = &mElements[(entity - mStartEntityHandle) * mNodesPerElement];
- std::copy(conn, (conn+num_vertices), iter);
-inline MBErrorCode ElementEntitySequence::get_connectivity_array(MBEntityHandle*& conn_array)
- conn_array = mElements;
#endif
Deleted: MOAB/trunk/EntitySequenceManager.cpp
--- MOAB/trunk/EntitySequenceManager.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/EntitySequenceManager.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,787 +0,0 @@
-#ifdef WIN32
-#ifdef _DEBUG
-#endif
-#endif
-#include "PolyEntitySequence.hpp"
-#include "EntitySequence.hpp"
-#include "MBRange.hpp"
-#include "ScdElementSeq.hpp"
-#include "ScdVertexSeq.hpp"
-#include "MeshSetSequence.hpp"
-#include "MBHandleUtils.hpp"
-#include <algorithm>
-EntitySequenceManager::EntitySequenceManager( const MBHandleUtils &handle_utils)
- : handleUtils(handle_utils)
- memset(mLastAccessed, 0, MBMAXTYPE*sizeof(void*));
-EntitySequenceManager::~EntitySequenceManager()
- // delete the entity sequences
- delete_all();
-void EntitySequenceManager::entity_sequence_created(MBEntitySequence* seq)
- mSequenceMap[seq->get_type()].insert(
- std::pair<MBEntityHandle, MBEntitySequence*> (seq->get_start_handle(), seq));
-void EntitySequenceManager::entity_sequence_deleted(MBEntitySequence* seq)
- mSequenceMap[seq->get_type()].erase(seq->get_start_handle());
- mPartlyFullSequenceMap[seq->get_type()].erase(seq->get_start_handle());
-void EntitySequenceManager::notify_full(MBEntitySequence* seq)
-void EntitySequenceManager::notify_not_full(MBEntitySequence* seq)
- mPartlyFullSequenceMap[seq->get_type()].insert(
- std::pair<MBEntityHandle, MBEntitySequence*>(seq->get_start_handle(), seq));
- //! create a structured sequence of vertices or elements
-MBErrorCode EntitySequenceManager::create_scd_sequence(const int imin, const int jmin, const int kmin,
- const int imax, const int jmax, const int kmax,
- const MBEntityType type,
- const MBEntityID hint_start_id,
- MBEntityHandle &start_handle,
- MBEntitySequence *&seq)
- int this_dim = MBCN::Dimension(type);
- // use > instead of != in the following assert to also catch cases where imin > imax, etc.
- assert((this_dim < 3 || kmax > kmin) &&
- (this_dim < 2 || jmax > jmin) &&
- (this_dim < 1 || imax > imin));
- // compute # entities; not as easy as it would appear...
- MBEntityID num_ent;
- if (MBVERTEX == type)
- num_ent = (MBEntityID)(imax-imin+1)*(MBEntityID)(jmax-jmin+1)*(MBEntityID)(kmax-kmin+1);
- else {
- num_ent = (imax-imin) *
- (this_dim >= 2 ? (jmax-jmin) : 1) *
- (this_dim >= 3 ? (kmax-kmin) : 1);
- // get a start handle
- MBErrorCode rval = get_start_handle(hint_start_id, handleUtils.proc_rank(), type, num_ent, start_handle);
- if (MB_SUCCESS != rval) return rval;
- // create a new structured vertex sequence
- seq = new ScdVertexSeq(this, start_handle,
- imin, jmin, kmin, imax, jmax, kmax);
- else
- seq = new ScdElementSeq(this, start_handle,
- if (NULL == seq) return MB_FAILURE;
- else return MB_SUCCESS;
-MBErrorCode EntitySequenceManager::create_scd_sequence(const HomCoord &coord_min,
- const HomCoord &coord_max,
- return create_scd_sequence(coord_min.i(), coord_min.j(), coord_min.k(),
- coord_max.i(), coord_max.j(), coord_max.k(),
- type, hint_start_id,
- start_handle, seq);
-MBErrorCode EntitySequenceManager::create_meshset_sequence( MBEntityID num_ent,
- MBEntityID hint_start_id,
- int hint_start_proc,
- const unsigned* flags,
- MBEntitySequence *&seq )
- MBEntityHandle start_handle;
- MBErrorCode rval = get_start_handle(hint_start_id, hint_start_proc, MBENTITYSET, num_ent, start_handle);
- return rval;
- seq = new MeshSetSequence( this, start_handle, num_ent, flags );
- creates an entity sequence based on number of entities and type.
- uses the hint_start as the start id for the entity handles if possible
- returns the actual start handle and the entity sequence pointer
-MBErrorCode EntitySequenceManager::create_entity_sequence( MBEntityType type, MBEntityID num_ent, int num_nodes,
- MBEntityID hint_start, int hint_start_proc,
- MBEntityHandle& start_handle,
- MBEntitySequence*& seq)
- MBErrorCode rval = get_start_handle(hint_start, hint_start_proc, type, num_ent, start_handle);
- return rval;
- // actually create the sequence
- return private_create_entity_sequence( start_handle, num_ent, num_nodes, true, seq);
-MBErrorCode EntitySequenceManager::get_start_handle( MBEntityID hint_start,
- int proc,
- MBEntityType type,
- MBEntityID num_ent,
- MBEntityHandle& start_hint_handle)
- if (hint_start < MB_START_ID)
- return find_free_handles( proc, type, num_ent, start_hint_handle );
- // Create handles from input parameters
- int dum = 0;
- start_hint_handle = CREATE_HANDLE(type, handleUtils.create_id(hint_start, proc), dum);
- MBEntityHandle end_hint_handle = start_hint_handle + num_ent - 1;
- MBEntityHandle last_handle = CREATE_HANDLE( type, handleUtils.last_id(proc), dum );
- // Check if the handle type can accomodate the requested number of handles
- if (end_hint_handle > last_handle)
- // Find the first entity sequence with a handle greater than requested handle.
- SeqMap::iterator iter = mSequenceMap[type].upper_bound(start_hint_handle);
- // Check that the requested handle range is before the beginning
- // of the next sequence.
- if (iter != mSequenceMap[type].end() && iter->first <= end_hint_handle)
- // If there is no previous sequence, then done.
- if (iter == mSequenceMap[type].begin())
- // Otherwise make sure the start of the requested range is
- // after the previous sequence.
- --iter;
- if (iter->second->get_end_handle() < start_hint_handle)
- else
-MBErrorCode EntitySequenceManager::find_free_handles( int proc,
- MBEntityHandle& handle_out )
- int dum = 0;
- // get first and largest possible handle for specified proc and type
- handle_out = CREATE_HANDLE( type, handleUtils.first_id(proc), dum );
- // check that handle space is large enough to accomodate requested
- // number of entities
- if (last_handle - handle_out + 1 < (MBEntityHandle)num_ent)
- return MB_MEMORY_ALLOCATION_FAILED;
- // get the first entity sequence for the NEXT rank (processor id)
- SeqMap::iterator iter = mSequenceMap[type].upper_bound( last_handle );
- // If map is empty or all sequences have larger processor ID
- // decrement to get first sequence with same (or smaller)
- // rank (processor ID)
- --iter;
- // If previous sequence is for previous processor, then there
- // are currently no handles allocated for this type and proc.
- // Return the first handle.
- if (handleUtils.rank_from_handle(iter->second->get_end_handle()) < (unsigned)proc)
- // Otherwise try the handle after those currently allocated
- // for this type and processor.
- handle_out = iter->second->get_end_handle() + 1;
- // Check if enough IDs at end of range
- if (last_handle - handle_out + 1 >= (MBEntityHandle)num_ent)
- // Not enough available handles at the end of the range of handles
- // for the specified entity type and processor. Scan the entire
- // range of handles looking for a large enough hole before we give
- // up entirely.
- for (;;) {
- MBEntityHandle last_start = iter->second->get_start_handle();
- // If this is the first sequence for this processor
- if (iter == mSequenceMap[type].begin() ||
- handleUtils.rank_from_handle((--iter)->second->get_end_handle()) < (unsigned)proc) {
- MBEntityHandle first_handle = CREATE_HANDLE( type, handleUtils.first_id(proc), dum );
- if (first_handle - last_start > (MBEntityHandle)num_ent) {
- handle_out = last_start - num_ent;
- break;
- // check if we fit in the current range
- if (last_start - iter->second->get_end_handle() - 1 > (MBEntityHandle)num_ent) {
-MBErrorCode EntitySequenceManager::private_create_entity_sequence(MBEntityHandle start,
- MBEntityID num_ent, int num_nodes,
- bool full,
- MBEntitySequence *& seq)
- MBEntityType type = TYPE_FROM_HANDLE(start);
- if(type == MBVERTEX)
- seq = new VertexEntitySequence(this, start, num_ent, full);
- else if(type == MBPOLYGON || type == MBPOLYHEDRON)
- seq = new PolyEntitySequence(this, start, num_ent, num_nodes, full);
- else
- seq = new ElementEntitySequence(this, start, num_ent, num_nodes, full);
-MBErrorCode EntitySequenceManager::create_vertex( const unsigned processor_id,
- const double coords[3],
- MBEntityHandle& handle )
- VertexEntitySequence* seq = 0;
- // see if there is an existing sequence that can take this new vertex
- SeqMap& seq_map = mPartlyFullSequenceMap[MBVERTEX];
- for (SeqMap::iterator i = seq_map.begin(); i != seq_map.end(); ++i) {
- if (handleUtils.rank_from_handle(i->second->get_start_handle()) == processor_id) {
- seq = static_cast<VertexEntitySequence*>(i->second);
- break;
- if (!seq) {
- MBErrorCode rval = get_start_handle( MB_START_ID, processor_id, MBVERTEX, 4096, handle );
- return rval;
- seq = new VertexEntitySequence( this, handle, 4096, false );
- handle = seq->get_unused_handle();
- seq->set_coordinates(handle, coords[0], coords[1], coords[2]);
-MBErrorCode EntitySequenceManager::create_element( MBEntityType type,
- const unsigned processor_id,
- const unsigned num_vertices,
- MBErrorCode rval;
- const bool poly = (MBPOLYGON == type || MBPOLYHEDRON == type);
- const unsigned connlen = poly ? 0 : num_vertices;
- ElementEntitySequence* seq = 0;
- SeqMap& seq_map = mPartlyFullSequenceMap[type];
- ElementEntitySequence* tseq = reinterpret_cast<ElementEntitySequence*>(i->second);
- if (tseq->nodes_per_element() == connlen &&
- handleUtils.rank_from_handle( tseq->get_start_handle() ) == processor_id) {
- seq = tseq;
- break;
- if (poly) {
- PolyEntitySequence* pseq = reinterpret_cast<PolyEntitySequence*>(seq);
- if (!pseq) {
- rval = get_start_handle( MB_START_ID, processor_id, type, 4096, handle );
- return rval;
- pseq = new PolyEntitySequence(this, handle, 4096, 0, false);
- handle = pseq->get_unused_handle();
- return pseq->add_entity(conn, num_vertices, handle);
- if (!seq) {
- return rval;
- seq = new ElementEntitySequence(this, handle, 4096, num_vertices, false);
- return seq->set_connectivity(handle, conn, num_vertices);
-MBErrorCode EntitySequenceManager::create_mesh_set( unsigned proc_id,
- unsigned flags,
- MBEntityHandle& h )
- MeshSetSequence* seq = 0;
- SeqMap& seq_map = mPartlyFullSequenceMap[MBENTITYSET];
- if (handleUtils.rank_from_handle(i->second->get_start_handle()) == proc_id) {
- seq = static_cast<MeshSetSequence*>(i->second);
- break;
- if (!seq) {
- MBErrorCode rval = get_start_handle( MB_START_ID, proc_id, MBENTITYSET, 4096, h );
- return rval;
- seq = new MeshSetSequence( this, h, 4096, (const unsigned*)0 );
- h = seq->add_meshset( flags );
-//MBErrorCode EntitySequenceManager::allocate_handle( MBEntityHandle handle, unsigned flags )
-// return MB_FAILURE;
-MBErrorCode EntitySequenceManager::allocate_mesh_set( MBEntityHandle handle, unsigned flags )
- std::map<MBEntityHandle, MBEntitySequence*>::iterator seq_itr;
- seq_itr = mSequenceMap[MBENTITYSET].lower_bound( handle );
- if (seq_itr != mSequenceMap[MBENTITYSET].begin())
- --seq_itr;
- for (; seq_itr != mSequenceMap[MBENTITYSET].end() &&
- seq_itr->second->get_end_handle() < handle;
- ++seq_itr );
- MeshSetSequence* seq;
- if (seq_itr != mSequenceMap[MBENTITYSET].end() &&
- seq_itr->second->get_start_handle() <= handle)
- seq = reinterpret_cast<MeshSetSequence*>(seq_itr->second);
- else {
- MBEntityID new_seq_size = 4096;
- if (seq_itr != mSequenceMap[MBENTITYSET].end()) {
- MBEntityID diff = seq_itr->second->get_start_handle() - handle;
- if (diff < new_seq_size)
- new_seq_size = diff;
- seq = new MeshSetSequence( this, handle, new_seq_size, (const unsigned*)0 );
- return seq->add_meshset( handle, flags );
-MBErrorCode EntitySequenceManager::get_entities(MBEntityType type, MBRange &entities) const
- //index into the static sequence map to get the sequences according to type only
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator beg_seq, end_seq;
- beg_seq = mSequenceMap[type].begin();
- end_seq = mSequenceMap[type].end();
- //for each sequence, get all the entity handles it contains
- for (; beg_seq != end_seq; ++beg_seq)
- const MBEntitySequence* tmp_seq = beg_seq->second;
- tmp_seq->get_entities(entities);
-MBErrorCode EntitySequenceManager::get_number_entities(MBEntityType type, MBEntityID& num_entities) const
- num_entities = 0;
- num_entities += beg_seq->second->number_entities();
-void EntitySequenceManager::delete_all()
- for(MBEntityType i = MBVERTEX; i<MBMAXTYPE; i++)
- while(!mSequenceMap[i].empty())
- delete mSequenceMap[i].begin()->second;
- mSequenceMap[i].clear();
-MBErrorCode EntitySequenceManager::find( MBEntityHandle entity_handle,
- MBEntitySequence*& sequence ) const
- MBEntityType ent_type = TYPE_FROM_HANDLE(entity_handle);
- // check to see if the sequence is cached
- sequence = mLastAccessed[ent_type];
- if (sequence && sequence->get_start_handle() <= entity_handle &&
- sequence->get_end_handle() >= entity_handle)
- sequence = 0;
- if ( !mSequenceMap[ent_type].empty() )
- if (ID_FROM_HANDLE(entity_handle) < MB_START_ID)
- return MB_INDEX_OUT_OF_RANGE;
- // create an iterator to look for which sequence entity handle will be found in
- // using lower bounds function of map
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator iter =
- mSequenceMap[ent_type].upper_bound(entity_handle);
- if (iter == mSequenceMap[ent_type].begin())
- return MB_ENTITY_NOT_FOUND;
- --iter;
- // ensure that the entity is bounded by this sequence.
- // upper_bound will indicate that this sequence can hold this entity
- // but doesn't guarantee that it does!
- MBEntitySequence* seq = iter->second;
- if ( (entity_handle >= seq->get_start_handle()) &&
- (entity_handle <= seq->get_end_handle()))
- sequence = seq;
- mLastAccessed[ent_type] = seq;
- else
-MBErrorCode EntitySequenceManager::delete_entity( MBEntityHandle entity )
- MBEntitySequence* seq;
- find(entity, seq);
- if(seq != NULL)
- seq->free_handle(entity);
- // leave the sequences around for a while if it is empty
-void EntitySequenceManager::get_memory_use( unsigned long& entity,
- unsigned long& total) const
- total = entity = 0;
- unsigned long used, allocated;
- for (MBEntityType type = MBVERTEX; type < MBMAXTYPE; ++type) {
- get_memory_use( type, used, allocated );
- total += allocated;
- entity += used;
-void EntitySequenceManager::get_memory_use( MBEntityType type,
- unsigned long& entity,
- unsigned long& total ) const
- entity = total = 0;
- for (SeqMap::const_iterator i = mSequenceMap[type].begin(); i != mSequenceMap[type].end(); ++i) {
- i->second->get_memory_use( used, allocated );
- entity += used;
-MBErrorCode EntitySequenceManager::get_memory_use(
- const MBRange& entities,
- unsigned long& min_per_entity,
- unsigned long& amortized ) const
- min_per_entity = 0;
- amortized =0;
- if (entities.empty())
- MBRange::iterator e, i = entities.begin();
- for (unsigned type = TYPE_FROM_HANDLE( *i ); type < MBMAXTYPE; ++type) {
- if (i == entities.end())
- break;
- const SeqMap& map = mSequenceMap[type];
- if (map.empty())
- continue;
- for (SeqMap::const_iterator j = map.begin(); j != map.end(); ++j)
- MBEntitySequence* seq = j->second;
- if (seq->get_end_handle() < *i)
- continue;
- if (*i < seq->get_start_handle())
- e = entities.upper_bound( i, entities.end(), seq->get_end_handle() );
- MBEntityID count = 0;
- for (; i != e; ++i) {
- min_per_entity += seq->get_memory_use( *i );
- ++count;
- seq->get_memory_use( used, allocated );
- amortized += (unsigned long)( (double)count * allocated / seq->number_entities() );
-#ifdef TEST
-#include <iostream>
-#define check( A ) \
- do { \
- if ((A) == MB_SUCCESS) break; \
- std::cerr << "Error at " << __FILE__ << ":" << __LINE__ << std::endl; \
- return 1; \
- } while(false)
-#define ensure( A ) \
- do { \
- if ((A)) break; \
- std::cerr << "Failed test at " << __FILE__ << ":" << __LINE__ << std::endl; \
- std::cerr << " " #A << std::endl; \
- return 1; \
- } while(false)
-int main()
- EntitySequenceManager manager( MBHandleUtils(0,1) );
- // create some sequences
- const unsigned NV[] = { 100, 5, 1000 };
- MBEntityHandle vh[3];
- MBEntitySequence* vs[3];
- MBEntityHandle th;
- MBEntitySequence *ts;
- const MBEntityID TRI_START_ID = 3;
- const unsigned NT = 640;
- check(manager.create_entity_sequence( MBVERTEX, NV[0], 0, 35, 0, vh[0], vs[0] ));
- check(manager.create_entity_sequence( MBVERTEX, NV[1], 0, 8, 0, vh[1], vs[1] ));
- check(manager.create_entity_sequence( MBVERTEX, NV[2], 0, 1, 0, vh[2], vs[2] ));
- check(manager.create_entity_sequence( MBTRI, NT, 3, TRI_START_ID, 0, th, ts ));
- // check that returned entity sequences are valid
- ensure( ID_FROM_HANDLE(vh[0]) > 0 && TYPE_FROM_HANDLE(vh[0]) == MBVERTEX );
- ensure( ID_FROM_HANDLE(vh[0]) > 0 && TYPE_FROM_HANDLE(vh[1]) == MBVERTEX );
- ensure( ID_FROM_HANDLE(vh[0]) > 0 && TYPE_FROM_HANDLE(vh[2]) == MBVERTEX );
- ensure( ID_FROM_HANDLE( th ) > 0 && TYPE_FROM_HANDLE( th ) == MBTRI );
- ensure( ID_FROM_HANDLE(th) == TRI_START_ID );
- ensure( vs[0] );
- ensure( vs[1] );
- ensure( vs[2] );
- ensure( ts );
- ensure( vs[0]->get_type() == MBVERTEX );
- ensure( vs[1]->get_type() == MBVERTEX );
- ensure( vs[2]->get_type() == MBVERTEX );
- ensure( ts ->get_type() == MBTRI );
- ensure( vs[0]->get_start_handle() == vh[0] );
- ensure( vs[1]->get_start_handle() == vh[1] );
- ensure( vs[2]->get_start_handle() == vh[2] );
- ensure( ts ->get_start_handle() == th );
- ensure( vs[0]->get_end_handle() - vs[0]->get_start_handle() == NV[0] - 1 );
- ensure( vs[1]->get_end_handle() - vs[1]->get_start_handle() == NV[1] - 1 );
- ensure( vs[2]->get_end_handle() - vs[2]->get_start_handle() == NV[2] - 1 );
- ensure( ts ->get_end_handle() - ts ->get_start_handle() == NT - 1 );
- // construct ranges
- MBRange vertices;
- vertices.insert( vs[0]->get_start_handle(), vs[0]->get_end_handle() );
- vertices.insert( vs[1]->get_start_handle(), vs[1]->get_end_handle() );
- vertices.insert( vs[2]->get_start_handle(), vs[2]->get_end_handle() );
- MBRange tris( ts->get_start_handle(), ts->get_end_handle() );
- // check find sequence given first
- check( manager.find( vs[0]->get_start_handle(), seq ) );
- ensure( seq == vs[0] );
- check( manager.find( vs[1]->get_start_handle(), seq ) );
- ensure( seq == vs[1] );
- check( manager.find( vs[2]->get_start_handle(), seq ) );
- ensure( seq == vs[2] );
- check( manager.find( ts ->get_start_handle(), seq ) );
- ensure( seq == ts );
- // check find sequence given last
- check( manager.find( vs[0]->get_end_handle(), seq ) );
- check( manager.find( vs[1]->get_end_handle(), seq ) );
- check( manager.find( vs[2]->get_end_handle(), seq ) );
- check( manager.find( ts ->get_end_handle(), seq ) );
- // check find of invalid handle
- MBEntityHandle badhandle = (MBEntityHandle)(ts->get_end_handle() + 1);
- ensure( manager.find( badhandle, seq ) == MB_ENTITY_NOT_FOUND );
- // check find of invalid type
- int junk;
- badhandle = CREATE_HANDLE( MBTET, 1, junk );
- // check get_entities
- MBRange chkverts, chktris, chkhexes;
- check( manager.get_entities( MBVERTEX, chkverts ) );
- check( manager.get_entities( MBTRI , chktris ) );
- check( manager.get_entities( MBHEX , chkhexes ) );
- ensure( chkverts.size() == vertices.size() &&
- std::equal(chkverts.begin(), chkverts.end(), vertices.begin() ) );
- ensure( chktris.size() == tris.size() &&
- std::equal(chktris.begin(), chktris.end(), tris.begin() ) );
- ensure( chkhexes.empty() );
- // check get_number_entities
- MBEntityID num_vtx, num_tri, num_hex;
- check( manager.get_number_entities( MBVERTEX, num_vtx ) );
- check( manager.get_number_entities( MBTRI, num_tri ) );
- check( manager.get_number_entities( MBHEX, num_hex ) );
- ensure( num_vtx >= 0 && (unsigned)num_vtx == chkverts.size() );
- ensure( num_tri >= 0 && (unsigned)num_tri == chktris .size() );
- ensure( num_hex == 0 );
- // check allocation of meshsets with caller-specified handles
- EntitySequenceManager setman( MBHandleUtils(0,1) );
- MBEntityHandle start_handle = CREATE_HANDLE( MBENTITYSET, 1, junk );
- // ID space: {}
- check( setman.allocate_mesh_set( start_handle + 2, 0 ) );
- // get current sequence
- MBEntitySequence* b_seq_ptr;
- check( setman.find( start_handle + 2, b_seq_ptr ) );
- MeshSetSequence* seq_ptr = dynamic_cast<MeshSetSequence*>(b_seq_ptr);
- check( seq_ptr->is_valid() );
- ensure( seq_ptr->number_entities() == 1 );
- // ID space: {3}
- check( setman.allocate_mesh_set( start_handle + 4, 0 ) );
- ensure( seq_ptr->number_entities() == 2 );
- // ID space: {3,5}
- check( setman.allocate_mesh_set( start_handle + 5, 0 ) );
- ensure( seq_ptr->number_entities() == 3 );
- // ID space: {3,5,6}
- check( setman.allocate_mesh_set( start_handle + 3, 0 ) );
- ensure( seq_ptr->number_entities() == 4 );
- // ID space: {3-6}
- // create new sequence after current one, with a single ID whole between them
- MBEntityHandle offset_handle = seq_ptr->get_end_handle();
- check( setman.allocate_mesh_set( offset_handle + 2, 0 ) );
- // now fill in that whole (with a 1-entity sequence?)
- check( setman.allocate_mesh_set( offset_handle + 1, 0 ) );
- // make sure all sequences are valid
- MBEntityHandle prev_handle = 0;
- const std::map<MBEntityHandle, MBEntitySequence*>& map = *setman.entity_map( MBENTITYSET );
- for (std::map<MBEntityHandle, MBEntitySequence*>::const_iterator mi = map.begin();
- mi != map.end(); ++mi) {
- seq_ptr = dynamic_cast<MeshSetSequence*>(mi->second);
- check( seq_ptr->is_valid());
- ensure( seq_ptr->get_start_handle() == mi->first );
- ensure( seq_ptr->get_start_handle() > prev_handle );
- ensure( seq_ptr->number_entities() <= seq_ptr->number_allocated() );
- ensure( seq_ptr->number_entities() > 0 );
- prev_handle = mi->second->get_end_handle();
- // make sure attempt to re-allocate existing set fails
- ensure( MB_ALREADY_ALLOCATED == setman.allocate_mesh_set( start_handle + 2, 0 ) );
- ensure( MB_ALREADY_ALLOCATED == setman.allocate_mesh_set( start_handle + 3, 0 ) );
- ensure( MB_ALREADY_ALLOCATED == setman.allocate_mesh_set( start_handle + 4, 0 ) );
- ensure( MB_ALREADY_ALLOCATED == setman.allocate_mesh_set( start_handle + 5, 0 ) );
- // some consistency checks
- MBEntityID count;
- check( setman.get_number_entities( MBENTITYSET, count ) );
- ensure( 6 == count );
- MBRange setlist;
- check( setman.get_entities( MBENTITYSET, setlist ) );
- MBRange setlist2;
- setlist2.insert( start_handle + 2, start_handle + 5 );
- setlist2.insert( offset_handle + 1, offset_handle + 2 );
- if (setlist != setlist2) {
- std::cout << "Expected:\n";
- setlist2.print( std::cout );
- std::cout << "Actual:\n";
- setlist.print( std::cout );
- ensure( setlist2 == setlist );
- return 0;
-#endif
Deleted: MOAB/trunk/EntitySequenceManager.hpp
--- MOAB/trunk/EntitySequenceManager.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/EntitySequenceManager.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,195 +0,0 @@
- * \class MBEntitySequenceManager
- * \date 3/27/02
- * All enquires for any data associated with the MBEntity are
- * directed through the MBEntitySequence object to which the
- * MBEntity's MBHandle refers. A MBEntitySequence knows
- * about all DenseTags defined for that MBEntitySequence, and
- * contains one TagRange for each of these DenseTags. The
- * MBEntitySequence can query for and return any of the DenseTag
- * data from the TagRanges it manages.
-#ifndef ENTITY_SEQUENCE_MANAGER_HPP
-#define ENTITY_SEQUENCE_MANAGER_HPP
-#error "EntitySequenceManager.hpp isn't supposed to be included into an application"
-#endif
-#include <map>
-class MBEntitySequence;
-class HomCoord;
-//! class for managing entity sequences
-public:
- //! constructor
- EntitySequenceManager( const MBHandleUtils &handle_utils);
- //! destructor
- ~EntitySequenceManager();
- MBErrorCode create_scd_sequence(const int imin, const int jmin, const int kmin,
- MBEntityHandle &start,
- MBEntitySequence *&seq);
- MBErrorCode create_scd_sequence(const HomCoord &coord_min,
- //! creates an entity sequence that will fit number of entities. uses hint_start
- //! for the start handle if possible
- //! returns the start handle and a pointer to the entity sequence.
- MBErrorCode create_entity_sequence(MBEntityType type, MBEntityID num_ent, int num_nodes_per,
- MBEntityID hint_start_id, int hint_start_proc,
- MBEntityHandle& start, MBEntitySequence *&);
- //! Create entity sequence for mesh sets. If flags is NULL,
- //! sequence will be created with all handles unused. If
- //! flags is not NULL, it should be an array of num_ent values.
- MBErrorCode create_meshset_sequence( MBEntityID num_ent,
- MBEntitySequence *&seq );
- //! finds the specific MBEntitySequence in which MBEntityHandle resides
- MBErrorCode find( MBEntityHandle entity_handle,
- MBEntitySequence*& sequence ) const;
- //! get entities from the entity sequences according to type
- MBErrorCode get_entities(MBEntityType,
- MBRange &entities) const;
- MBErrorCode get_number_entities(MBEntityType, MBEntityID& entities) const;
- //! deletes an entity from the database
- MBErrorCode delete_entity( MBEntityHandle entity );
- //! creates a vertex in the database
- MBErrorCode create_vertex( const unsigned processor_id,
- MBEntityHandle& vertex );
- //! creates a vertex in the database with specified id
- const unsigned entity_id,
- MBEntityHandle& vertex ) {return MB_FAILURE;}
- //! creates an element in the database
- MBErrorCode create_element( MBEntityType type,
- const MBEntityHandle *conn_array,
- MBEntityHandle& element);
- //! creates an element in the database with specified id
- MBEntityHandle& element) {return MB_FAILURE;}
- MBErrorCode create_mesh_set( unsigned proc_id,
- unsigned flags,
- MBEntityHandle& h );
- MBErrorCode allocate_mesh_set( MBEntityHandle handle, unsigned flags );
- //! return a const reference to the map of sequences
- const std::map<MBEntityHandle, MBEntitySequence*>*
- entity_map( MBEntityType type ) const { return &(mSequenceMap[type]); }
- void entity_sequence_created(MBEntitySequence* seq);
- void entity_sequence_deleted(MBEntitySequence* seq);
- void notify_full(MBEntitySequence* seq);
- void notify_not_full(MBEntitySequence* seq);
- void get_memory_use( unsigned long& total_entity_storage,
- unsigned long& total_storage ) const;
- void get_memory_use( MBEntityType type,
- unsigned long& total_entity_storage,
- MBErrorCode get_memory_use( const MBRange& entities,
- unsigned long& total_amortized_storage ) const;
-private:
- //! creates an entity sequence with a start handle and number of entities
- MBErrorCode private_create_entity_sequence(MBEntityHandle start,
- bool full, MBEntitySequence *&);
- void delete_all();
- //! last instance of entity sequence that was accessed
- //! each entity type keeps its own cache
- mutable MBEntitySequence* mLastAccessed[MBMAXTYPE];
- //! map of all the EntitySequences that are created
- //! each entity type has its own map, and each processor
- //! ID has it's own map.
- typedef std::map< MBEntityHandle, MBEntitySequence* > SeqMap;
- SeqMap mSequenceMap[MBMAXTYPE];
- SeqMap mPartlyFullSequenceMap[MBMAXTYPE];
- //! get a valid start handle for this type and a hinted-at start id
- MBErrorCode get_start_handle( MBEntityID hint_start,
- int hint_proc,
- MBEntityHandle& start_handle );
- //! helper function for get_start_handle, if the requested entity ID
- //! is not available, find any available range of handles
- MBErrorCode find_free_handles( int proc,
- const MBHandleUtils handleUtils;
-#endif
Modified: MOAB/trunk/HigherOrderFactory.cpp
--- MOAB/trunk/HigherOrderFactory.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/HigherOrderFactory.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -23,8 +23,9 @@
#endif
#include "HigherOrderFactory.hpp"
+#include "SequenceManager.hpp"
+#include "UnstructuredElemSeq.hpp"
+#include "VertexSequence.hpp"
#include "MBCN.hpp"
@@ -65,8 +66,10 @@
//mMapInitialized = true;
-MBErrorCode HigherOrderFactory::convert(const MBEntityHandle meshset, const bool mid_edge_nodes,
- const bool mid_face_nodes, const bool mid_volume_nodes)
+MBErrorCode HigherOrderFactory::convert( const MBEntityHandle meshset,
+ const bool mid_edge_nodes,
+ const bool mid_face_nodes,
+ const bool mid_volume_nodes )
// TODO -- add some more code to prevent from splitting of entity sequences when we don't need to.
@@ -79,167 +82,116 @@
// find out what entity sequences we need to convert
// and where, if necessary, to split them
- EntitySequenceManager* seq_manager = mMB->sequence_manager();
- std::vector< std::pair<ElementEntitySequence*,MBRange> > sequence_range_pairs;
- // get all the sequences that have these entities
- // could speed this up a bit by using a MBRange::pair_iterator
- for(MBRange::iterator p_iter = entities.begin(); p_iter != entities.end(); ++p_iter)
- if(TYPE_FROM_HANDLE(*p_iter) == MBVERTEX || TYPE_FROM_HANDLE(*p_iter) >= MBENTITYSET)
- continue;
- MBEntitySequence* seq = NULL;
- MBErrorCode rval = seq_manager->find(*p_iter, seq);
- if(MB_SUCCESS == rval)
- if(sequence_range_pairs.empty() || seq != sequence_range_pairs.rbegin()->first)
- sequence_range_pairs.push_back(
- std::pair<ElementEntitySequence*,MBRange>( static_cast<ElementEntitySequence*>(seq), MBRange() )
- sequence_range_pairs.rbegin()->second.insert(*p_iter);
+ SequenceManager* seq_manager = mMB->sequence_manager();
+ MBRange::const_pair_iterator p_iter;
+ for (p_iter = entities.const_pair_begin(); p_iter != entities.const_pair_end(); ++p_iter) {
+ MBEntityHandle h = p_iter->first;
+ while (h <= p_iter->second) {
+ EntitySequence* seq;
+ MBErrorCode rval = seq_manager->find( h, seq );
+ if (MB_SUCCESS != rval)
+ return rval;
+ if (seq->type() == MBVERTEX || seq->type() >= MBENTITYSET)
+ return MB_TYPE_OUT_OF_RANGE;
+ // make sequence is not structured mesh
+ ElementSequence* elemseq = static_cast<ElementSequence*>(seq);
+ if (NULL == elemseq->get_connectivity_array())
+ return MB_NOT_IMPLEMENTED;
+ MBEntityHandle last = p_iter->second;
+ if (last > seq->end_handle())
+ last = seq->end_handle();
+ rval = convert_sequence( elemseq, h, last,
+ mid_edge_nodes,
+ mid_face_nodes,
+ mid_volume_nodes );
+ return rval;
+ h = last + 1;
- std::vector<ElementEntitySequence*> sequences_to_process;
- // iterate through each entity sequence and split up entity sequences where we need to
- // put results into sequences list to process
- std::vector< std::pair<ElementEntitySequence*, MBRange> >::iterator s_iter;
- for(s_iter = sequence_range_pairs.begin(); s_iter != sequence_range_pairs.end(); ++s_iter)
- // find all the entities we weren't told to convert
- MBRange holes;
- // we have a hole at the beginning of the sequence
- if(*(s_iter->second.begin()) != s_iter->first->get_start_handle())
- holes.insert(s_iter->first->get_start_handle(), *(s_iter->second.begin())-1);
- //we have a hole at the end of the sequence
- if(*(s_iter->second.rbegin()) != s_iter->first->get_end_handle())
- holes.insert(*(s_iter->second.rbegin())+1, s_iter->first->get_end_handle());
- // any holes in the middle
- MBRange::pair_iterator r_iter = s_iter->second.begin();
- MBRange::pair_iterator prev_r_iter = r_iter;
- r_iter++;
- for(; r_iter != s_iter->second.end(); )
- holes.insert(prev_r_iter->second+1, r_iter->first-1);
- ++r_iter;
- ++prev_r_iter;
- // remove entities from the holes list that are unallocated entities
- for(MBRange::iterator rm_iter = holes.begin(); rm_iter != holes.end(); )
- if(!s_iter->first->is_valid_entity(*rm_iter))
- rm_iter = holes.erase(rm_iter);
- else
- ++rm_iter;
- // no holes, convert the whole sequence
- if(holes.empty())
- sequences_to_process.push_back(s_iter->first);
- else
- MBEntitySequence* new_seq=NULL;
- // now we know where we need to split
- r_iter = holes.begin();
- //split at beginning
- if(r_iter->first == s_iter->first->get_start_handle())
- s_iter->first->split(r_iter->second+1, new_seq);
- s_iter->first = static_cast<ElementEntitySequence*>(new_seq);
- sequences_to_process.push_back(static_cast<ElementEntitySequence*>(new_seq));
- else
- s_iter->first->split(r_iter->first, new_seq);
- if(r_iter->second != new_seq->get_end_handle())
- // split in middle
- ++r_iter;
- MBRange::pair_iterator next_r_iter = r_iter;
- ++next_r_iter;
- for( ; r_iter != holes.end(); )
- if( (next_r_iter != holes.end()) || (next_r_iter == holes.end() && r_iter->second != new_seq->get_end_handle()) )
- ++r_iter;
- ++next_r_iter;
- // now convert the entity sequences
- for(std::vector<ElementEntitySequence*>::iterator ziter = sequences_to_process.begin();
- ziter != sequences_to_process.end(); ++ziter)
- convert_sequence(*ziter, mid_edge_nodes, mid_face_nodes, mid_volume_nodes);
return MB_SUCCESS;
-MBErrorCode HigherOrderFactory::convert_sequence(ElementEntitySequence* seq, const bool mid_edge_nodes,
+MBErrorCode HigherOrderFactory::convert_sequence( ElementSequence* seq,
+ MBEntityHandle start,
+ MBEntityHandle end,
+ bool mid_edge_nodes,
+ bool mid_face_nodes,
+ bool mid_volume_nodes)
MBErrorCode status = MB_SUCCESS;
- bool temp_mid_edge = mid_edge_nodes;
- bool temp_mid_face = mid_face_nodes;
- bool temp_mid_volume = mid_volume_nodes;
// lets make sure parameters are ok before we continue
- MBEntityType this_type = seq->get_type();
- if(this_type == MBEDGE)
- temp_mid_face = temp_mid_volume = false;
- if(this_type == MBTRI || this_type == MBQUAD)
- temp_mid_volume = false;
+ switch (seq->type()) {
+ default: return MB_TYPE_OUT_OF_RANGE;
+ case MBEDGE:
+ mid_face_nodes = false;
+ case MBTRI:
+ case MBQUAD:
+ mid_volume_nodes = false;
+ case MBTET:
+ case MBHEX:
+ case MBPRISM:
+ case MBPYRAMID:
+ case MBKNIFE:
+ break;
+ // calculate number of nodes in target configuration
+ unsigned nodes_per_elem = MBCN::VerticesPerEntity( seq->type() );
+ if (mid_edge_nodes)
+ nodes_per_elem += (seq->type() == MBEDGE) ? 1 : MBCN::NumSubEntities( seq->type(), 1 );
+ if (mid_face_nodes)
+ nodes_per_elem += (MBCN::Dimension(seq->type()) == 2) ? 1 : MBCN::NumSubEntities( seq->type(), 2 );
+ if (mid_volume_nodes)
+ nodes_per_elem += 1;
+ if (nodes_per_elem == seq->nodes_per_element())
+ return MB_SUCCESS;
MBTag deletable_nodes;
- mMB->tag_create("", 1, MB_TAG_BIT, deletable_nodes, NULL);
+ status = mMB->tag_create("", 1, MB_TAG_BIT, deletable_nodes, NULL);
+ if (MB_SUCCESS != status)
+ return status;
+ UnstructuredElemSeq* new_seq = new UnstructuredElemSeq( start,
+ end - start + 1,
+ nodes_per_elem,
+ end - start + 1 );
+ copy_corner_nodes( seq, new_seq );
- // will return if we need to create them
- seq->convert_realloc(temp_mid_edge, temp_mid_face, temp_mid_volume, mMB, deletable_nodes);
+ if (seq->has_mid_edge_nodes() && mid_edge_nodes)
+ status = copy_mid_edge_nodes( seq, new_seq );
+ else if (seq->has_mid_edge_nodes() && !mid_edge_nodes)
+ status = remove_mid_edge_nodes( seq, start, end, deletable_nodes );
+ return status;
+ if (seq->has_mid_face_nodes() && mid_face_nodes)
+ status = copy_mid_face_nodes( seq, new_seq );
+ else if (seq->has_mid_face_nodes() && !mid_face_nodes)
+ status = remove_mid_face_nodes( seq, start, end, deletable_nodes );
+ return status;
+ if (seq->has_mid_volume_nodes() && mid_volume_nodes)
+ status = copy_mid_volume_nodes( seq, new_seq );
+ else if (seq->has_mid_volume_nodes() && !mid_volume_nodes)
+ status = remove_mid_volume_nodes( seq, start, end, deletable_nodes );
+ return status;
// gather nodes that were marked
MBRange nodes;
mMB->get_entities_by_type_and_tag(0, MBVERTEX, &deletable_nodes, NULL, 1, nodes);
@@ -261,27 +213,45 @@
+ const bool create_midedge = !seq->has_mid_edge_nodes() && mid_edge_nodes;
+ const bool create_midface = !seq->has_mid_face_nodes() && mid_face_nodes;
+ const bool create_midvolm = !seq->has_mid_volume_nodes() && mid_volume_nodes;
mMB->tag_delete(deletable_nodes);
- // create mid edge nodes if necessary
- if(temp_mid_edge)
- status = add_mid_edge_nodes(seq);
- // create mid face nodes if necessary
- if(temp_mid_face)
- status = add_mid_face_nodes(seq);
- // create mid volume nodes if necessary
- if(temp_mid_volume)
- status = add_mid_volume_nodes(seq);
+ status = mMB->sequence_manager()->replace_subsequence( new_seq, mMB->tag_server() );
+ if (MB_SUCCESS != status) {
+ SequenceData* data = new_seq->data();
+ delete new_seq;
+ delete data;
+ return status;
+ if (create_midedge) {
+ status = add_mid_edge_nodes( new_seq );
+ return status;
+ if (create_midface) {
+ status = add_mid_face_nodes( new_seq );
+ return status;
+ if (create_midvolm) {
+ status = add_mid_volume_nodes( new_seq );
+ return status;
return status;
-MBErrorCode HigherOrderFactory::add_mid_volume_nodes(ElementEntitySequence* seq)
+MBErrorCode HigherOrderFactory::add_mid_volume_nodes(ElementSequence* seq)
+ MBEntityType this_type = seq->type();
// find out where in the connectivity list to add these new mid volume nodes
int edge_factor = seq->has_mid_edge_nodes() ? 1 : 0;
@@ -292,29 +262,21 @@
new_node_index += edge_factor * MBCN::mConnectivityMap[this_type][0].num_sub_elements;
new_node_index += face_factor * MBCN::mConnectivityMap[this_type][1].num_sub_elements;
- MBEntityHandle* element = NULL;
- seq->get_connectivity_array(element);
- MBEntityHandle curr_handle = seq->get_start_handle();
+ MBEntityHandle* element = seq->get_connectivity_array();
+ MBEntityHandle curr_handle = seq->start_handle();
int nodes_per_element = seq->nodes_per_element();
- MBEntityHandle* end_element = element + nodes_per_element * (seq->number_allocated());
+ MBEntityHandle* end_element = element + nodes_per_element * (seq->size());
// iterate over the elements
for(; element < end_element; element+=nodes_per_element)
- // this element isn't being used, skip it
- if(!seq->is_valid_entity(curr_handle))
- curr_handle++;
- continue;
// find the centroid of this element
double tmp_coords[3], sum_coords[3] = {0,0,0};
- MBEntitySequence* seq=NULL;
+ EntitySequence* seq=NULL;
for(int i=0; i<num_corner_nodes; i++)
seq_manager->find(element[i], seq);
- static_cast<VertexEntitySequence*>(seq)->get_coordinates(
+ static_cast<VertexSequence*>(seq)->get_coordinates(
element[i], tmp_coords[0], tmp_coords[1], tmp_coords[2]
sum_coords[0] += tmp_coords[0];
@@ -338,10 +300,10 @@
-MBErrorCode HigherOrderFactory::add_mid_face_nodes(ElementEntitySequence* seq)
+MBErrorCode HigherOrderFactory::add_mid_face_nodes(ElementSequence* seq)
int num_vertices = MBCN::VerticesPerEntity(this_type);
int num_edges = MBCN::mConnectivityMap[this_type][0].num_sub_elements;
num_edges = seq->has_mid_edge_nodes() ? num_edges : 0;
@@ -349,11 +311,10 @@
const MBCN::ConnMap& entity_faces = MBCN::mConnectivityMap[this_type][1];
MBEntityHandle tmp_face_conn[4]; // max face nodes = 4
std::vector<MBEntityHandle> adjacent_entities(4);
@@ -363,13 +324,6 @@
- curr_handle++;
- continue;
// for each edge in this entity
for(int i=0; i<num_faces; i++)
@@ -394,13 +348,13 @@
// create a node
else
- MBEntitySequence* tmp_sequence = NULL;
+ EntitySequence* tmp_sequence = NULL;
double sum_coords[3] = {0,0,0};
int max_nodes = entity_faces.num_nodes_per_sub_element[i];
for(int k=0; k<max_nodes; k++)
seq_manager->find(tmp_face_conn[k], tmp_sequence);
- static_cast<VertexEntitySequence*>(tmp_sequence)->get_coordinates(
+ static_cast<VertexSequence*>(tmp_sequence)->get_coordinates(
tmp_face_conn[k], tmp_coords[0], tmp_coords[1], tmp_coords[2]);
sum_coords[1] += tmp_coords[1];
@@ -427,11 +381,11 @@
-MBErrorCode HigherOrderFactory::add_mid_edge_nodes(ElementEntitySequence* seq)
+MBErrorCode HigherOrderFactory::add_mid_edge_nodes(ElementSequence* seq)
// for each node, need to see if it was already created.
// offset by number of corner nodes
@@ -439,12 +393,10 @@
const MBCN::ConnMap& entity_edges = MBCN::mConnectivityMap[this_type][0];
MBEntityHandle tmp_edge_conn[2];
std::vector<MBEntityHandle> adjacent_entities(32);
@@ -454,13 +406,6 @@
- curr_handle++;
- continue;
for(int i=0; i<num_edges; i++)
@@ -481,16 +426,16 @@
// create a node
else
seq_manager->find(tmp_edge_conn[0], tmp_sequence);
tmp_edge_conn[0], tmp_coords[0], tmp_coords[1], tmp_coords[2]);
sum_coords[2] += tmp_coords[2];
seq_manager->find(tmp_edge_conn[1], tmp_sequence);
tmp_edge_conn[1], tmp_coords[0], tmp_coords[1], tmp_coords[2]);
sum_coords[0] = (sum_coords[0] + tmp_coords[0]) /2;
sum_coords[1] = (sum_coords[1] + tmp_coords[1]) /2;
@@ -540,6 +485,10 @@
iter != adj_entities.end(); )
MBEntityType this_type = TYPE_FROM_HANDLE(*iter);
+ if (this_type == MBENTITYSET) {
+ ++iter;
+ continue;
mMB->get_connectivity(*iter, conn, conn_size);
// if this entity has mid edge nodes
if(MBCN::HasMidEdgeNodes(this_type, conn_size))
@@ -598,6 +547,10 @@
+ ++iter;
+ continue;
int offset = MBCN::VerticesPerEntity(this_type);
@@ -669,3 +622,286 @@
return true;
+MBErrorCode
+HigherOrderFactory::copy_corner_nodes( ElementSequence* src, ElementSequence* dst )
+ unsigned num_corners = MBCN::VerticesPerEntity( src->type() );
+ return copy_nodes( src, dst, num_corners, 0, 0 );
+MBErrorCode
+HigherOrderFactory::copy_mid_edge_nodes( ElementSequence* src, ElementSequence* dst )
+ if (!src->has_mid_edge_nodes() || !dst->has_mid_edge_nodes())
+ return MB_FAILURE;
+ unsigned num_edges = (src->type() == MBEDGE) ? 1 : MBCN::NumSubEntities( src->type(), 1 );
+ return copy_nodes( src, dst, num_edges, num_corners, num_corners );
+MBErrorCode
+HigherOrderFactory::copy_mid_face_nodes( ElementSequence* src, ElementSequence* dst )
+ if (!src->has_mid_face_nodes() || !dst->has_mid_face_nodes())
+ unsigned src_offset = MBCN::VerticesPerEntity( src->type() );
+ unsigned dst_offset = src_offset;
+ if (src->has_mid_edge_nodes())
+ src_offset += MBCN::NumSubEntities( src->type(), 1 );
+ if (dst->has_mid_edge_nodes())
+ dst_offset += MBCN::NumSubEntities( dst->type(), 1 );
+ unsigned num_faces = (MBCN::Dimension(src->type()) == 2) ? 1 : MBCN::NumSubEntities( src->type(), 2 );
+ return copy_nodes( src, dst, num_faces, src_offset, dst_offset );
+MBErrorCode
+HigherOrderFactory::copy_mid_volume_nodes( ElementSequence* src, ElementSequence* dst )
+ if (!src->has_mid_volume_nodes() || !dst->has_mid_volume_nodes())
+ if (src->has_mid_face_nodes())
+ src_offset += MBCN::NumSubEntities( src->type(), 2 );
+ if (dst->has_mid_face_nodes())
+ dst_offset += MBCN::NumSubEntities( dst->type(), 2 );
+ return copy_nodes( src, dst, 1, src_offset, dst_offset );
+MBErrorCode
+HigherOrderFactory::copy_nodes( ElementSequence* src,
+ ElementSequence* dst,
+ unsigned nodes_per_elem,
+ unsigned src_offset,
+ unsigned dst_offset )
+ if (src->type() != dst->type())
+ unsigned src_stride = src->nodes_per_element();
+ unsigned dst_stride = dst->nodes_per_element();
+ MBEntityHandle* src_conn = src->get_connectivity_array();
+ MBEntityHandle* dst_conn = dst->get_connectivity_array();
+ if (!src_conn || !dst_conn)
+ if (dst->start_handle() < src->start_handle() ||
+ dst->end_handle() > src->end_handle())
+ src_conn += (dst->start_handle() - src->start_handle()) * src_stride;
+ MBEntityID count = dst->size();
+ for (MBEntityID i = 0; i < count; ++i) {
+ for (unsigned j = 0; j < nodes_per_elem; ++j)
+ dst_conn[j+dst_offset] = src_conn[j+src_offset];
+ src_conn += src_stride;
+ dst_conn += dst_stride;
+MBErrorCode
+HigherOrderFactory::remove_mid_edge_nodes( ElementSequence* seq,
+ MBTag deletable_nodes )
+ int count;
+ int offset;
+ if (seq->type() == MBEDGE) {
+ count = 1;
+ offset = 2;
+ else {
+ count = MBCN::NumSubEntities( seq->type(), 1 );
+ offset = MBCN::VerticesPerEntity( seq->type() );
+ return remove_ho_nodes( seq, start, end, count, offset, deletable_nodes );
+MBErrorCode
+HigherOrderFactory::remove_mid_face_nodes( ElementSequence* seq,
+ int count;
+ if (MBCN::Dimension(seq->type()) == 2)
+ count = 1;
+ else
+ count = MBCN::NumSubEntities( seq->type(), 2 );
+ int offset = MBCN::VerticesPerEntity( seq->type() );
+ if (seq->has_mid_edge_nodes())
+ offset += MBCN::NumSubEntities( seq->type(), 1 );
+MBErrorCode
+HigherOrderFactory::remove_mid_volume_nodes( ElementSequence* seq,
+ if (seq->has_mid_face_nodes())
+ offset += MBCN::NumSubEntities( seq->type(), 2 );
+ return remove_ho_nodes( seq, start, end, 1, offset, deletable_nodes );
+// Code mostly copied from old EntitySequence.cpp
+// (ElementEntitySequence::convert_realloc &
+// ElementEntitySequence::tag_for_deletion).
+// Copyright from old EntitySequence.cpp:
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+MBErrorCode
+HigherOrderFactory::remove_ho_nodes( ElementSequence* seq,
+ int nodes_per_elem,
+ int elem_conn_offset,
+ if (start < seq->start_handle() || end > seq->end_handle())
+ return MB_ENTITY_NOT_FOUND;
+ MBEntityHandle* array = seq->get_connectivity_array();
+ if (!array)
+ std::set<MBEntityHandle> nodes_processed;
+ for (MBEntityHandle i = start; i <= end; ++i) { // for each element
+ for (int j = 0; j < nodes_per_elem; ++j) { // for each HO node to remove
+ const MBEntityID elem = (i - seq->start_handle()); // element index
+ const int conn_idx = j + elem_conn_offset;
+ const MBEntityID index = elem * seq->nodes_per_element() + conn_idx;
+ if (array[index] && nodes_processed.insert( array[index] ).second) {
+ if (tag_for_deletion( i, conn_idx, seq )) {
+ unsigned char bit = 0x1;
+ mMB->tag_set_data( deletable_nodes, &(array[index]), 1, &bit );
+bool
+HigherOrderFactory::tag_for_deletion( MBEntityHandle parent_handle,
+ int conn_index,
+ ElementSequence* seq )
+ //get type of this sequence
+ //get dimension of 'parent' element
+ int this_dimension = mMB->dimension_from_handle( parent_handle );
+ //tells us if higher order node is on
+ int dimension, side_number;
+ MBCN::HONodeParent( this_type, seq->nodes_per_element(),
+ conn_index, dimension, side_number );
+ //it MUST be a higher-order node
+ bool delete_node = false;
+ assert( dimension != -1 );
+ assert( side_number != -1 );
+ //could be a mid-volume/face/edge node on a hex/face/edge respectively
+ //if so...delete it bc/ no one else owns it too
+ std::vector<MBEntityHandle> connectivity;
+ if( dimension == this_dimension && side_number == 0 )
+ delete_node = true;
+ else //the node could also be on a lower order entity of 'tmp_entity'
+ //get 'side' of 'parent_handle' that node is on
+ MBEntityHandle target_entity = 0;
+ mMB->side_element( parent_handle, dimension, side_number, target_entity );
+ if( target_entity )
+ AEntityFactory *a_fact = mMB->a_entity_factory();
+ MBEntityHandle low_meshset;
+ int dum;
+ low_meshset = CREATE_HANDLE(MBENTITYSET, 0, dum);
+ //just get corner nodes of target_entity
+ connectivity.clear();
+ mMB->get_connectivity(&( target_entity), 1, connectivity, true );
+ //for each node, get all common adjacencies of nodes in 'parent_handle'
+ std::vector<MBEntityHandle> adj_list_1, adj_list_2, adj_entities;
+ a_fact->get_adjacencies(connectivity[0], adj_list_1);
+ // remove meshsets
+ adj_list_1.erase(std::remove_if(adj_list_1.begin(), adj_list_1.end(),
+ std::bind2nd(std::greater<MBEntityHandle>(),low_meshset)), adj_list_1.end());
+ size_t i;
+ for( i=1; i<connectivity.size(); i++)
+ adj_list_2.clear();
+ a_fact->get_adjacencies(connectivity[i], adj_list_2);
+ adj_list_2.erase(std::remove_if(adj_list_2.begin(), adj_list_2.end(),
+ std::bind2nd(std::greater<MBEntityHandle>(),low_meshset)), adj_list_2.end());
+ //intersect the 2 lists
+ adj_entities.clear();
+ std::set_intersection(adj_list_1.begin(), adj_list_1.end(),
+ adj_list_2.begin(), adj_list_2.end(),
+ std::back_inserter< std::vector<MBEntityHandle> >(adj_entities));
+ adj_list_1.clear();
+ adj_list_1 = adj_entities;
+ assert( adj_entities.size() ); //has to have at least one adjacency
+ //see if node is in other elements, not in this sequence...if so, delete it
+ for( i=0; i<adj_entities.size(); i++)
+ if( adj_entities[i] >= seq->start_handle() &&
+ adj_entities[i] <= seq->end_handle() )
+ delete_node = false;
+ break;
+ else
+ else //there is no lower order entity that also contains node
+ return delete_node;
Modified: MOAB/trunk/HigherOrderFactory.hpp
--- MOAB/trunk/HigherOrderFactory.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/HigherOrderFactory.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -29,7 +29,7 @@
#endif
#include "MBInterface.hpp"
-class ElementEntitySequence;
+class ElementSequence;
class MBCore;
class HigherOrderFactory
@@ -52,11 +52,15 @@
MBCore* mMB;
MBInterface::HONodeAddedRemoved* mHONodeAddedRemoved;
- MBErrorCode convert_sequence(ElementEntitySequence*, const bool mid_edge_nodes,
- const bool mid_face_nodes, const bool mid_volume_nodes);
- MBErrorCode add_mid_edge_nodes(ElementEntitySequence*);
- MBErrorCode add_mid_face_nodes(ElementEntitySequence*);
- MBErrorCode add_mid_volume_nodes(ElementEntitySequence*);
+ MBErrorCode convert_sequence(ElementSequence* sequence,
+ MBEntityHandle sequence_subset_start,
+ MBEntityHandle sequence_subset_end,
+ bool mid_volume_nodes);
+ MBErrorCode add_mid_edge_nodes(ElementSequence*);
+ MBErrorCode add_mid_face_nodes(ElementSequence*);
+ MBErrorCode add_mid_volume_nodes(ElementSequence*);
//! returns the handle of the first center node found between the two corner nodes.
//! returns zero if none found
@@ -74,6 +78,38 @@
bool add_center_node(MBEntityType type, MBEntityHandle* element_conn, int conn_size,
MBEntityHandle corner_node1, MBEntityHandle corner_node2, MBEntityHandle center_node);
+ MBErrorCode copy_corner_nodes( ElementSequence* src, ElementSequence* dst );
+ MBErrorCode copy_mid_edge_nodes( ElementSequence* src, ElementSequence* dst );
+ MBErrorCode copy_mid_face_nodes( ElementSequence* src, ElementSequence* dst );
+ MBErrorCode copy_mid_volume_nodes( ElementSequence* src, ElementSequence* dst );
+ MBErrorCode copy_nodes( ElementSequence* src,
+ unsigned nodes_per_elem_to_copy,
+ unsigned src_conn_offset,
+ unsigned dst_conn_offset );
+ MBErrorCode remove_mid_edge_nodes( ElementSequence* seq,
+ MBEntityHandle stop,
+ MBTag deletable_ndoes );
+ MBErrorCode remove_mid_face_nodes( ElementSequence* seq,
+ MBErrorCode remove_mid_volume_nodes( ElementSequence* seq,
+ MBErrorCode remove_ho_nodes( ElementSequence* sequence,
+ MBEntityHandle subset_start_handle,
+ MBEntityHandle subset_end_handle,
+ int nodes_per_elem_to_remove,
+ int elem_conn_offset_to_remove,
+ MBTag deletable_nodes );
+ bool tag_for_deletion( MBEntityHandle element_with_node,
+ int node_index_in_elem_connectivity,
+ ElementSequence* sequence );
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBCore.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -28,13 +28,15 @@
#include "MBCore.hpp"
#include "TagServer.hpp"
+#include "ElementSequence.hpp"
#include "assert.h"
#include "AEntityFactory.hpp"
#include "MBReadUtil.hpp"
#include "MBWriteUtil.hpp"
#include "MBCN.hpp"
-#include "EntitySequenceManager.hpp"
#include "MBError.hpp"
#include "MBReaderWriterSet.hpp"
#include "MBReaderIface.hpp"
@@ -88,13 +90,11 @@
"MB_FAILURE",
-static inline MBMeshSet* get_mesh_set( const EntitySequenceManager* sm,
+static inline MBMeshSet* get_mesh_set( const SequenceManager* sm,
MBEntityHandle h )
- if (MBENTITYSET != TYPE_FROM_HANDLE(h) ||
- MB_SUCCESS != sm->find( h, seq ) ||
- !seq->is_valid_entity(h))
+ if (MBENTITYSET != TYPE_FROM_HANDLE(h) || MB_SUCCESS != sm->find( h, seq ))
return 0;
return reinterpret_cast<MeshSetSequence*>(seq)->get_set(h);
@@ -142,7 +142,7 @@
if (!tagServer)
- sequenceManager = new EntitySequenceManager( handleUtils );
+ sequenceManager = new SequenceManager( handleUtils );
if (!sequenceManager)
@@ -308,11 +308,8 @@
handle = CREATE_HANDLE(type, id, err);
//check to see if handle exists
- MBEntitySequence *dummy_seq = 0;
+ EntitySequence *dummy_seq = 0;
MBErrorCode error_code = sequence_manager()->find(handle, dummy_seq);
- if(error_code == MB_SUCCESS && type != MBVERTEX)
- error_code = dummy_seq->is_valid_entity(handle) ? MB_SUCCESS : MB_ENTITY_NOT_FOUND;
return error_code;
@@ -490,7 +487,7 @@
if (sequenceManager)
delete sequenceManager;
return result;
@@ -560,67 +557,45 @@
MBErrorCode MBCore::get_coords(const MBRange& entities, double *coords) const
- int node_index = 0;
- // lets get ready to iterate the entity sequences and copy data
- // we'll iterate the map in the sequence manager and
- // the entities range at the same time
- MBRange::const_iterator range_iter = entities.begin();
- MBRange::const_iterator range_iter_end = entities.end();
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_iter
- = sequence_manager()->entity_map(MBVERTEX)->begin();
+ const TypeSequenceManager& vert_data = sequence_manager()->entity_map( MBVERTEX );
+ TypeSequenceManager::const_iterator seq_iter;
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_iter_end
- = sequence_manager()->entity_map(MBVERTEX)->end();
+ MBRange::const_pair_iterator i = entities.const_pair_begin();
+ MBEntityHandle first = i->first;
+ while (i != entities.const_pair_end()) {
+ seq_iter = vert_data.lower_bound( first );
+ if (seq_iter == vert_data.end() || first < (*seq_iter)->start_handle())
+ const VertexSequence* vseq = reinterpret_cast<const VertexSequence*>(*seq_iter);
- // lets find the entity sequence which holds the first entity
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_iter_lookahead = seq_iter;
- seq_iter_lookahead++;
- for( ; seq_iter_lookahead != seq_iter_end &&
- seq_iter_lookahead->second->get_start_handle() < *range_iter; )
- ++seq_iter;
- ++seq_iter_lookahead;
- // a look ahead iterator
- MBRange::const_iterator range_iter_lookahead = range_iter;
- // our main loop
- for(; range_iter != range_iter_end && seq_iter != seq_iter_end; /* ++ is handled in loop*/ )
- // find a range that fits in the current entity sequence
- for(; range_iter_lookahead != range_iter_end &&
- *range_iter_lookahead <= seq_iter->second->get_end_handle();
- ++range_iter_lookahead)
- double* coord_array[3];
- static_cast<VertexEntitySequence*>(seq_iter->second)->get_coordinate_arrays(
- coord_array[0], coord_array[1], coord_array[2]);
- MBEntityHandle start_ent = seq_iter->second->get_start_handle();
- // for each of the entities in this entity sequence, copy data
- for(MBRange::const_iterator tmp_iter = range_iter;
- tmp_iter != range_iter_lookahead;
- ++tmp_iter)
- coords[node_index] = coord_array[0][*tmp_iter - start_ent];
- node_index++;
- coords[node_index] = coord_array[1][*tmp_iter - start_ent];
- node_index++;
- coords[node_index] = coord_array[2][*tmp_iter - start_ent];
- node_index++;
+ MBEntityID offset = first - vseq->start_handle();
+ MBEntityID count;
+ if (i->second <= vseq->end_handle()) {
+ count = i->second - first + 1;
+ ++i;
+ if (i != entities.const_pair_end())
+ first = i->first;
- // go to the next entity sequence
- ++seq_iter;
- // start with the next entities
- range_iter = range_iter_lookahead;
+ else {
+ count = vseq->end_handle() - first + 1;
+ first = vseq->end_handle()+1;
+ double const *x, *y, *z;
+ MBErrorCode rval = vseq->get_coordinate_arrays( x, y, z );
+ return rval;
+ x += offset;
+ y += offset;
+ z += offset;
+ for (MBEntityID j = 0; j < count; ++j) {
+ *coords = *x; ++coords; ++x;
+ *coords = *y; ++coords; ++y;
+ *coords = *z; ++coords; ++z;
return MB_SUCCESS;
@@ -630,63 +605,43 @@
double *y_coords,
double *z_coords ) const
- // declare some iterators
- MBRange::const_iterator iter = entities.begin();
- const MBRange::const_iterator end = entities.end();
- const std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_end
- // if no vertices in database, give up now
- if (seq_iter == seq_end)
- // loop over all entities in range
- while(iter != end) {
- // find sequence for vertex at *iter
- while (seq_iter->second->get_end_handle() < *iter)
- if (++seq_iter == seq_end)
- if (*iter < seq_iter->second->get_start_handle())
- // get data for sequence
- VertexEntitySequence* seq = static_cast<VertexEntitySequence*>(seq_iter->second);
- const MBEntityHandle start_ent = seq->get_start_handle();
- const MBEntityHandle end_ent = seq->get_end_handle();
- double *seq_x, *seq_y, *seq_z;
- seq->get_coordinate_arrays( seq_x, seq_y, seq_z );
- // for each entity in range and sequence
- while (iter != end && *iter <= end_ent) {
+ MBEntityID count;
+ ++i;
+ first = i->first;
+ else {
- // get block of consecutive handles
- const MBEntityHandle range_start = *iter;
- iter = iter.end_of_block();
- if (*iter > end_ent) // trim block to those in the sequence
- iter -= *iter - end_ent;
- const MBEntityID offset = range_start - start_ent;
- const MBEntityID count = *iter - range_start + 1;
- ++iter; // done with iter for this iteration, advance to next handle
- // copy coordinate data
- if (x_coords) {
- memcpy( x_coords, seq_x + offset, sizeof(double)*count );
- x_coords += count;
- if (y_coords) {
- memcpy( y_coords, seq_y + offset, sizeof(double)*count );
- y_coords += count;
- if (z_coords) {
- memcpy( z_coords, seq_z + offset, sizeof(double)*count );
- z_coords += count;
+ return rval;
+ memcpy( x_coords, x + offset, count * sizeof(double ) );
+ memcpy( y_coords, y + offset, count * sizeof(double ) );
+ memcpy( z_coords, z + offset, count * sizeof(double ) );
+ x_coords += count;
+ y_coords += count;
+ z_coords += count;
return MB_SUCCESS;
@@ -695,7 +650,7 @@
MBErrorCode status;
const MBEntityHandle* const end = entities + num_entities;
for(const MBEntityHandle* iter = entities; iter != end; ++iter)
@@ -704,10 +659,10 @@
status = sequence_manager()->find(*iter, seq);
- if(status != MB_SUCCESS || !seq->is_valid_entity(*iter) )
+ if(status != MB_SUCCESS )
- static_cast<VertexEntitySequence*>(seq)->get_coordinates(*iter, coords);
+ static_cast<VertexSequence*>(seq)->get_coordinates(*iter, coords);
coords += 3;
@@ -723,13 +678,13 @@
if ( TYPE_FROM_HANDLE(entity_handle) == MBVERTEX )
- MBEntitySequence* seq = 0;
+ EntitySequence* seq = 0;
status = sequence_manager()->find(entity_handle, seq);
- if (seq == 0 || status != MB_SUCCESS || !seq->is_valid_entity(entity_handle) )
+ if (seq == 0 || status != MB_SUCCESS)
- status = static_cast<VertexEntitySequence*>(seq)->get_coordinates_ref(entity_handle,
+ status = static_cast<VertexSequence*>(seq)->get_coordinates_ref(entity_handle,
x, y, z);
@@ -751,11 +706,11 @@
for (i = 0; i < num_entities; i++) {
if ( TYPE_FROM_HANDLE(entity_handles[i]) == MBVERTEX )
status = sequence_manager()->find(entity_handles[i], seq);
if (seq != 0 && status == MB_SUCCESS) {
- status = static_cast<VertexEntitySequence*>(seq)->set_coordinates(entity_handles[i], coords[j], coords[j+1], coords[j+2]);
+ status = static_cast<VertexSequence*>(seq)->set_coordinates(entity_handles[i], coords[j], coords[j+1], coords[j+2]);
j += 3;
@@ -779,11 +734,11 @@
for (MBRange::iterator rit = entity_handles.begin(); rit != entity_handles.end(); rit++) {
if ( TYPE_FROM_HANDLE(*rit) == MBVERTEX )
status = sequence_manager()->find(*rit, seq);
- status = static_cast<VertexEntitySequence*>(seq)->set_coordinates(*rit, coords[j], coords[j+1], coords[j+2]);
+ status = static_cast<VertexSequence*>(seq)->set_coordinates(*rit, coords[j], coords[j+1], coords[j+2]);
j += 3;
@@ -871,12 +826,12 @@
MBErrorCode result = MB_SUCCESS, temp_result;
for (i = 0; i < num_handles; i++) {
// We know that connectivity is stored in an EntitySequence so jump straight
// to the entity sequence
temp_result = sequence_manager()->find(entity_handles[i], seq);
- if (seq == NULL || !seq->is_valid_entity(entity_handles[i])) {
+ if (seq == NULL) {
result = MB_ENTITY_NOT_FOUND;
continue;
@@ -885,7 +840,7 @@
continue;
- ElementEntitySequence *elem_seq = static_cast<ElementEntitySequence*>(seq);
+ ElementSequence *elem_seq = static_cast<ElementSequence*>(seq);
// let's be smart about this...
temp_result = elem_seq->get_connectivity(entity_handles[i], connectivity,
topological_connectivity);
@@ -905,7 +860,6 @@
bool topological_connectivity,
std::vector<MBEntityHandle>* storage) const
MBErrorCode status;
// Make sure the entity should have a connectivity.
@@ -919,18 +873,19 @@
return MB_FAILURE;
- if (seq == 0 || status != MB_SUCCESS || !seq->is_valid_entity(entity_handle))
- return static_cast<ElementEntitySequence*>(seq)->get_connectivity(entity_handle, connectivity,
- number_nodes,
- topological_connectivity,
- storage);
+ return static_cast<ElementSequence*>(seq)->get_connectivity(entity_handle,
+ connectivity,
+ number_nodes,
+ topological_connectivity,
+ storage);
//! set the connectivity for element handles. For non-element handles, return an error
@@ -944,25 +899,25 @@
// WARNING: This is very dependent on the ordering of the MBEntityType enum
MBEntityType type = TYPE_FROM_HANDLE(entity_handle);
if (type < MBVERTEX || type > MBENTITYSET)
return (status != MB_SUCCESS ? status : MB_ENTITY_NOT_FOUND);
const MBEntityHandle* old_conn;
int len;
- status = static_cast<ElementEntitySequence*>(seq)->get_connectivity(entity_handle, old_conn, len);
+ status = static_cast<ElementSequence*>(seq)->get_connectivity(entity_handle, old_conn, len);
if (status != MB_SUCCESS) return status;
aEntityFactory->notify_change_connectivity(
entity_handle, old_conn, connect, num_connect);
- status = static_cast<ElementEntitySequence*>(seq)->set_connectivity(entity_handle,
- connect, num_connect);
+ status = static_cast<ElementSequence*>(seq)->set_connectivity(entity_handle,
+ connect, num_connect);
entity_handle, connect, old_conn, num_connect);
@@ -1133,23 +1088,22 @@
MBErrorCode result = MB_SUCCESS;
if (meshset) {
result = sequence_manager()->find( meshset, seq );
if (MB_SUCCESS != result)
return result;
MeshSetSequence* mseq = reinterpret_cast<MeshSetSequence*>(seq);
- result = mseq->get_dimension( meshset, dimension, entities, recursive );
+ result = mseq->get_dimension( sequence_manager(), meshset, dimension, entities, recursive );
else if (dimension > 3) {
- result = sequence_manager()->get_entities( MBENTITYSET, entities );
+ sequence_manager()->get_entities( MBENTITYSET, entities );
+ result = MB_SUCCESS;
else {
for (MBEntityType this_type = MBCN::TypeDimensionMap[dimension].first;
this_type <= MBCN::TypeDimensionMap[dimension].second;
this_type++) {
- result = sequence_manager()->get_entities( this_type, entities );
- if (MB_SUCCESS != result)
- break;
+ sequence_manager()->get_entities( this_type, entities );
@@ -1166,15 +1120,17 @@
if (meshset) {
return result;
- result = mseq->get_type( meshset, type, entities, recursive );
+ result = mseq->get_type( sequence_manager(), meshset, type, entities, recursive );
- else
- result = sequence_manager()->get_entities( type, entities );
+ else {
+ sequence_manager()->get_entities( type, entities );
return result;
@@ -1223,20 +1179,17 @@
if (meshset) {
return result;
- result = mseq->get_entities( meshset, entities, recursive );
+ result = mseq->get_entities( sequence_manager(), meshset, entities, recursive );
else {
// iterate backards so range insertion is quicker
- for (MBEntityType type = MBENTITYSET; type >= MBVERTEX; --type) {
- break;
+ for (MBEntityType type = MBENTITYSET; type >= MBVERTEX; --type)
return result;
@@ -1256,7 +1209,7 @@
std::copy( tmp_range.begin(), tmp_range.end(), entities.begin() + offset );
else {
return result;
@@ -1279,20 +1232,16 @@
for (MBEntityType this_type = MBCN::TypeDimensionMap[dim].first;
this_type <= MBCN::TypeDimensionMap[dim].second;
this_type++) {
- MBEntityID dummy = 0;
- result = sequence_manager()->get_number_entities( this_type, dummy );
- if (result != MB_SUCCESS)
- break;
- number += dummy;
+ number += sequence_manager()->get_number_entities( this_type );
else {
return result;
- result = mseq->num_dimension( meshset, dim, number, recursive );
+ result = mseq->num_dimension( sequence_manager(), meshset, dim, number, recursive );
return result;
@@ -1310,17 +1259,15 @@
if (meshset) {
return result;
- result = mseq->num_type( meshset, type, num_ent, recursive );
+ result = mseq->num_type( sequence_manager(), meshset, type, num_ent, recursive );
else {
- MBEntityID tmp;
- result = sequence_manager()->get_number_entities( type, tmp );
- num_ent = tmp;
+ num_ent = sequence_manager()->get_number_entities( type );
return result;
@@ -1347,12 +1294,12 @@
MBErrorCode result;
if (meshset) {
return result;
- return mseq->num_entities( meshset, num_ent, recursive );
+ return mseq->num_entities( sequence_manager(), meshset, num_ent, recursive );
num_ent = 0;
@@ -1401,7 +1348,7 @@
return tagServer->set_mesh_data(tag_handle, tag_data);
//verify handles
const MBEntityHandle* iter;
const MBEntityHandle* end = entity_handles + num_entities;
for(iter = entity_handles; iter != end; ++iter)
@@ -1421,18 +1368,9 @@
const void *tag_data)
//verify handles
- MBRange::const_iterator iter;
- MBErrorCode result;
- for(iter = entity_handles.begin();
- iter != entity_handles.end() && TYPE_FROM_HANDLE(*iter) != MBENTITYSET;
- ++iter)
- result = sequenceManager->find(*iter, seq);
- if(result != MB_SUCCESS)
- return result;
+ MBErrorCode result = sequence_manager()->check_valid_entities( entity_handles );
+ if (MB_SUCCESS != result)
+ return result;
return tagServer->set_data(tag_handle, entity_handles, tag_data);
@@ -1757,15 +1695,13 @@
// Make sure both entities exist before trying to merge.
MBErrorCode result, status;
status = sequence_manager()->find(entity_to_keep, seq);
- if(seq == 0 || status != MB_SUCCESS ||
- !seq->is_valid_entity(entity_to_keep))
+ if(seq == 0 || status != MB_SUCCESS)
status = sequence_manager()->find(entity_to_remove, seq);
- !seq->is_valid_entity(entity_to_remove))
// If auto_merge is not set, all sub-entities should
@@ -2373,13 +2309,13 @@
if (0 == meshset) return MB_SUCCESS;
- MBEntitySequence *seq;
+ EntitySequence *seq;
MBErrorCode rval = sequence_manager()->find( meshset, seq );
- if (MB_SUCCESS != rval || !seq->is_valid_entity(meshset))
- return mseq->get_parents( meshset, parents, num_hops );
+ return mseq->get_parents( sequence_manager(), meshset, parents, num_hops );
MBErrorCode MBCore::get_parent_meshsets(const MBEntityHandle meshset,
@@ -2402,13 +2338,13 @@
- return mseq->get_children( meshset, children, num_hops );
+ return mseq->get_children( sequence_manager(), meshset, children, num_hops );
MBErrorCode MBCore::get_child_meshsets(const MBEntityHandle meshset,
@@ -2433,13 +2369,13 @@
return MB_SUCCESS;
- return mseq->num_parents( meshset, *number, num_hops );
+ return mseq->num_parents( sequence_manager(), meshset, *number, num_hops );
MBErrorCode MBCore::num_child_meshsets(const MBEntityHandle meshset, int* number,
@@ -2450,13 +2386,13 @@
return MB_SUCCESS;
- return mseq->num_children( meshset, *number, num_hops );
+ return mseq->num_children( sequence_manager(), meshset, *number, num_hops );
@@ -2728,9 +2664,9 @@
// now check and reverse-evaluate them
for (MBRange::iterator rit = adjs.begin(); rit != adjs.end(); rit++) {
tmp_result = sequence_manager()->find(*rit, seq);
- if(seq == 0 || tmp_result != MB_SUCCESS || !seq->is_valid_entity(*rit)) {
+ if(seq == 0 || tmp_result != MB_SUCCESS) {
oss << ent_str.str() <<
"Adjacent entity " << MBCN::EntityTypeName(TYPE_FROM_HANDLE(*rit)) << " "
<< ID_FROM_HANDLE(*rit) << " is invalid." << std::endl;
@@ -2770,11 +2706,9 @@
bool MBCore::is_valid(const MBEntityHandle this_ent) const
MBErrorCode result = sequence_manager()->find(this_ent, seq);
- if(seq == 0 || result != MB_SUCCESS || !seq->is_valid_entity(this_ent))
- return false;
- else return true;
+ return seq != 0 && result == MB_SUCCESS;
static unsigned long get_num_entities_with_tag( TagServer* ts,
@@ -3013,4 +2947,106 @@
return handleUtils;
+void MBCore::print_database() const
+ MBErrorCode rval;
+ TypeSequenceManager::iterator i;
+ const TypeSequenceManager& verts = sequence_manager()->entity_map(MBVERTEX);
+ if (!verts.empty())
+ printf(" Vertex ID X Y Z Adjacencies \n"
+ " ---------- -------- -------- -------- -----------...\n");
+ const MBEntityHandle* adj;
+ int nadj;
+ for (i = verts.begin(); i != verts.end(); ++i) {
+ const VertexSequence* seq = static_cast<const VertexSequence* >(*i);
+ printf("(Sequence [%d,%d] in SequenceData [%d,%d])\n",
+ (int)ID_FROM_HANDLE(seq->start_handle()),
+ (int)ID_FROM_HANDLE(seq->end_handle()),
+ (int)ID_FROM_HANDLE(seq->data()->start_handle()),
+ (int)ID_FROM_HANDLE(seq->data()->end_handle()));
+ double c[3];
+ for (MBEntityHandle h = seq->start_handle(); h <= seq->end_handle(); ++h) {
+ rval = seq->get_coordinates( h, c );
+ if (MB_SUCCESS == rval)
+ printf(" %10d %8g %8g %8g", (int)ID_FROM_HANDLE(h), c[0], c[1], c[2] );
+ else
+ printf(" %10d < ERROR %4d >", (int)ID_FROM_HANDLE(h), (int)rval );
+ rval = a_entity_factory()->get_adjacencies( h, adj, nadj );
+ if (MB_SUCCESS != rval) {
+ printf(" <ERROR %d>\n", (int)rval );
+ continue;
+ MBEntityType pt = MBMAXTYPE;
+ for (int j = 0; j < nadj; ++j) {
+ if (TYPE_FROM_HANDLE(adj[j]) != pt) {
+ pt = TYPE_FROM_HANDLE(adj[j]);
+ printf(" %s", pt >= MBMAXTYPE ? "INVALID TYPE" : MBCN::EntityTypeName(pt) );
+ printf(" %d", (int)ID_FROM_HANDLE(adj[j]));
+ printf("\n");
+ for (MBEntityType t = MBEDGE; t < MBENTITYSET; ++t) {
+ const TypeSequenceManager& elems = sequence_manager()->entity_map(t);
+ if (elems.empty())
+ continue;
+ int clen = 0;
+ for (i = elems.begin(); i != elems.end(); ++i) {
+ int n = static_cast<const ElementSequence*>(*i)->nodes_per_element();
+ if (n > clen)
+ clen = n;
+ clen *= 5;
+ if (clen < (int)strlen("Connectivity"))
+ clen = strlen("Connectivity");
+ std::vector<char> dashes( clen, '-' );
+ dashes.push_back( '\0' );
+ printf( " %7s ID %-*s Adjacencies\n", MBCN::EntityTypeName(t), clen, "Connectivity" );
+ printf( " ---------- %s -----------...\n", &dashes[0] );
+ std::vector<MBEntityHandle> storage;
+ const MBEntityHandle* conn;
+ int nconn;
+ const ElementSequence* seq = static_cast<const ElementSequence*>(*i);
+ printf( " %10d", (int)ID_FROM_HANDLE(h) );
+ rval = get_connectivity( h, conn, nconn, false, &storage );
+ printf( " <ERROR %2d>%*s", (int)rval, clen-10, "" );
+ else {
+ for (int j = 0; j < nconn; ++j)
+ printf(" %4d", (int)ID_FROM_HANDLE(conn[j]));
+ printf("%*s", clen - 5*nconn, "" );
+ continue;
+ printf("\n");
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBCore.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -23,7 +23,7 @@
class MBWriteUtil;
class MBReadUtil;
class AEntityFactory;
-class EntitySequenceManager;
+class SequenceManager;
class TagServer;
class MBError;
class MBReaderWriterSet;
@@ -877,11 +877,12 @@
TagServer* tag_server() {return tagServer;}
//! return a reference to the sequence manager
- EntitySequenceManager* sequence_manager() { return sequenceManager; }
- const EntitySequenceManager* sequence_manager() const { return sequenceManager; }
+ SequenceManager* sequence_manager() { return sequenceManager; }
+ const SequenceManager* sequence_manager() const { return sequenceManager; }
//! return the a_entity_factory pointer
AEntityFactory *a_entity_factory() { return aEntityFactory; }
+ const AEntityFactory *a_entity_factory() const { return aEntityFactory; }
//! return set of registered IO tools
MBReaderWriterSet* reader_writer_set() { return readerWriterSet; }
@@ -1002,6 +1003,8 @@
//! Return the utility for dealing with entity handles
virtual const MBHandleUtils &handle_utils() const;
+ void print_database() const;
private:
void estimated_memory_use_internal( const MBRange* ents,
@@ -1048,7 +1051,7 @@
//! tag server for this interface
TagServer* tagServer;
- EntitySequenceManager *sequenceManager;
+ SequenceManager *sequenceManager;
AEntityFactory *aEntityFactory;
Modified: MOAB/trunk/MBRangeSeqIntersectIter.cpp
--- MOAB/trunk/MBRangeSeqIntersectIter.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBRangeSeqIntersectIter.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -19,8 +19,9 @@
#include "MBRangeSeqIntersectIter.hpp"
#include "EntitySequence.hpp"
+#include <assert.h>
MBErrorCode MBRangeSeqIntersectIter::init( MBRange::const_iterator start,
MBRange::const_iterator end )
@@ -91,44 +92,24 @@
// (reduce mEndHandle) for the current EntitySequence.
// Need to update the sequence pointer?
- if (!mSequence || mStartHandle > mSequence->get_end_handle()) {
+ if (!mSequence || mStartHandle > mSequence->end_handle()) {
- // Check that the mStartHandle is not a mesh set.
- // We don't care if mEndHandle is (yet) because the end
- // will be trimmed to the end of the EntitySequence
- // containing mStartHandle.
- if (TYPE_FROM_HANDLE(mStartHandle) >= MBENTITYSET)
+ // Check that the mStartHandle is valid
+ if (TYPE_FROM_HANDLE(mStartHandle) >= MBMAXTYPE)
if (MB_SUCCESS != mSequenceManager->find( mStartHandle, mSequence ))
return find_invalid_range();
- freeIndex = mSequence->get_next_free_index( -1 );
- if (freeIndex < 0)
- freeIndex = mSequence->number_allocated();
- // Find first hole in sequence after mStartHandle
- MBEntityID start_index = mStartHandle - mSequence->get_start_handle();
- while (start_index > freeIndex) {
- freeIndex = mSequence->get_next_free_index( freeIndex );
- if (freeIndex == -1)
- if (start_index == freeIndex)
- return find_deleted_range();
// if mEndHandle is past end of sequence or block of used
// handles within sequence, shorten it.
- MBEntityID end_index = mEndHandle - mSequence->get_start_handle();
- if(end_index >= freeIndex)
- mEndHandle = mSequence->get_start_handle() + (freeIndex-1);
+ if(mEndHandle > mSequence->end_handle())
+ mEndHandle = mSequence->end_handle();
return MB_SUCCESS;
-typedef std::map<MBEntityHandle,MBEntitySequence*> SeqMap;
MBErrorCode MBRangeSeqIntersectIter::find_invalid_range()
assert(!mSequence);
@@ -139,10 +120,10 @@
// Find the next MBEntitySequence
MBEntityType type = TYPE_FROM_HANDLE(mStartHandle);
- const SeqMap* map = mSequenceManager->entity_map( type );
- SeqMap::const_iterator iter = map->upper_bound( mStartHandle );
+ const TypeSequenceManager& map = mSequenceManager->entity_map( type );
+ TypeSequenceManager::const_iterator iter = map.upper_bound( mStartHandle );
// If no next sequence of the same type
- if (iter == map->end()) {
+ if (iter == map.end()) {
// If end type not the same as start type, split on type
if (type != TYPE_FROM_HANDLE( mEndHandle )) {
int junk;
@@ -150,37 +131,12 @@
// otherwise invalid range ends at min(mEndHandle, sequence start handle - 1)
- else if (iter->second->get_start_handle() <= mEndHandle) {
- mEndHandle = iter->second->get_start_handle()-1;
+ else if ((*iter)->start_handle() <= mEndHandle) {
+ mEndHandle = (*iter)->start_handle()-1;
-MBErrorCode MBRangeSeqIntersectIter::find_deleted_range()
- // If we're here, then its because freeIndex == start_index
- assert (mSequence);
- assert (mSequence->get_start_handle() + freeIndex >= mStartHandle);
- // Find the last deleted entity before mEndHandle
- while (freeIndex < end_index) {
- MBEntityID index = mSequence->get_next_free_index( freeIndex );
- // If there was a break in the span of deleted entities before
- // mEndHandle, then set mEndHandle to the end of the span of
- // deleted entities and stop. In the case where we've reached
- // the end of the list (index < 0) then freeIndex will be the
- // last index in the sequence.
- if (index < 0 || index - freeIndex > 1) {
- mEndHandle = mSequence->get_start_handle() + freeIndex;
- break;
- freeIndex = index;
- return MB_ENTITY_NOT_FOUND;
#if MB_RANGE_SEQ_INTERSECT_ITER_STATS
double MBRangeSeqIntersectIter::doubleNumCalls = 0;
Modified: MOAB/trunk/MBRangeSeqIntersectIter.hpp
--- MOAB/trunk/MBRangeSeqIntersectIter.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBRangeSeqIntersectIter.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -16,6 +16,7 @@
/**\file MBRangeSeqIntersectIter.hpp
*\author Jason Kraftcheck (kraftche at cae.wisc.edu)
*\date 2006-08-11
+ *\date 2007-11-06
#ifndef MB_RANGE_SEQ_INTERSECT_ITER_HPP
@@ -24,48 +25,44 @@
#include "MBTypes.h"
#include "MBRange.hpp"
+class EntitySequence;
#define MB_RANGE_SEQ_INTERSECT_ITER_STATS 0
/** \brief Iterate over the blocks of MBEntityHandles in an MBRange that
- * are in the same MBEntitySequence.
+ * are in the same EntitySequence.
* Iterate over an MBRange, returning blocks of entities that are the
* largest ranges of contiguous handles that meet one of the following
* conditions:
- * - All are valid handles belonging to the same MBEntitySequence
- * - All are invalid handles that are holes in the same MBEntitySequence
- * - All are invalid handles of the same MBEntityType and aren't holes
- * in any MBEntitySequence.
+ * - All are valid handles belonging to the same EntitySequence
+ * - All are invalid handles of the same MBEntityType
* The return type from init() or step() indicates whether or not the
* current range contains valid entities. If the handles are either
- * all valid or all holes in an MBEntitySequence, that sequence can
+ * all valid or all holes in an EntitySequence, that sequence can
* be obtained with get_sequence(). get_sequence() will return NULL if
- * there is no corresponding MBEntitySequence for the block of handles.
+ * there is no corresponding EntitySequence for the block of handles.
- * This class keeps a data related to the 'current' MBEntitySequence and
+ * This class keeps a data related to the 'current' EntitySequence and
* references to the MBRange pasesd to init(). Changing either of these
* while an instance of this class is in use would be bad.
class MBRangeSeqIntersectIter {
public:
- MBRangeSeqIntersectIter( EntitySequenceManager* sequences )
+ MBRangeSeqIntersectIter( SequenceManager* sequences )
: mSequenceManager( sequences ),
mSequence( 0 ),
mStartHandle( 0 ),
mEndHandle( 0 ),
- mLastHandle( 0 ),
- freeIndex( 0 )
+ mLastHandle( 0 )
/** Initialize iterator to first valid subset
*\return - MB_SUCCESS : initial position of iterator is valid
* - MB_ENITITY_NOT_FOUND : range contains invalid handle -- can step past by calling again
- * - MB_TYPE_OUT_OF_RANGE : range contains mesh sets -- cannot step past as sets are at end of range
* - MB_FAILURE : No entities (start == end)
MBErrorCode init( MBRange::const_iterator start, MBRange::const_iterator end );
@@ -73,7 +70,6 @@
/** Step iterator to next range.
*\return - MB_SUCCESS : there is another range, and iter has been changed to it
* - MB_FAILURE : at end.
MBErrorCode step();
@@ -90,7 +86,7 @@
/** Get the MBEntitySequence for the current block.
* May be NULL for invaild handles.
- MBEntitySequence* get_sequence() const
+ EntitySequence* get_sequence() const
{ return mSequence; }
/** Get first handle in block */
@@ -122,20 +118,12 @@
*\return Always returns MB_ENTITY_NOT_FOUND
MBErrorCode find_invalid_range();
- /** Handle error case where mStartHandle corresponds to a hole in an
- * entity sequence. Find the end of the block of invalid entities
- * in the sequence.
- *\return Always returns MB_ENTITY_NOT_FOUND
- MBErrorCode find_deleted_range();
- EntitySequenceManager* mSequenceManager; //!< THE EntitySequenceManager
- MBEntitySequence* mSequence; //!< MBEntitySequence corresponding to current location
+ SequenceManager* mSequenceManager; //!< THE EntitySequenceManager
+ EntitySequence* mSequence; //!< EntitySequence corresponding to current location
MBRange::const_pair_iterator rangeIter; //!< Current position in MBRange.
MBEntityHandle mStartHandle, mEndHandle; //!< Subset of current MBEntitySequence
MBEntityHandle mLastHandle; //!< The last of the list of all handles in the MBRange
- MBEntityID freeIndex; //!< Current position in free list of mSequence
static double doubleNumCalls, doubleEntCount;
Modified: MOAB/trunk/MBReadUtil.cpp
--- MOAB/trunk/MBReadUtil.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBReadUtil.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -25,8 +25,9 @@
-#include "PolyEntitySequence.hpp"
#define RR if (MB_SUCCESS != result) return result
@@ -48,17 +49,11 @@
MBErrorCode error;
- MBEntityHandle preferred_start_handle;
- preferred_start_handle =
- mMB->handle_utils().create_handle(MBVERTEX,
- preferred_start_id,
- preferred_start_proc);
// create an entity sequence for these nodes
error = mMB->sequence_manager()->create_entity_sequence(
- MBVERTEX, num_nodes, 0, preferred_start_handle,
+ MBVERTEX, num_nodes, 0, preferred_start_id,
preferred_start_proc, actual_start_handle,
seq);
@@ -67,7 +62,10 @@
arrays.resize(3);
- error = static_cast<VertexEntitySequence*>(seq)->get_coordinate_arrays(arrays[0], arrays[1], arrays[2]);
+ error = static_cast<VertexSequence*>(seq)->get_coordinate_arrays(arrays[0], arrays[1], arrays[2]);
+ for (unsigned i = 0; i< arrays.size(); ++i)
+ if (arrays[i])
+ arrays[i] += (actual_start_handle - seq->start_handle());
return error;
@@ -83,10 +81,10 @@
MBErrorCode error;
- MBEntitySequence* seq;
- if (mdb_type <= MBVERTEX || mdb_type >= MBPOLYHEDRON || mdb_type == MBPOLYGON)
- return MB_TYPE_OUT_OF_RANGE;
+// if (mdb_type <= MBVERTEX || mdb_type >= MBPOLYHEDRON || mdb_type == MBPOLYGON)
+// return MB_TYPE_OUT_OF_RANGE;
// make an entity sequence to hold these elements
unsigned proc_id = proc < 0 ? parallel_rank() : proc;
@@ -97,43 +95,16 @@
return error;
// get an array for the connectivity
- error = static_cast<ElementEntitySequence*>(seq)->get_connectivity_array(array);
+ array = static_cast<ElementSequence*>(seq)->get_connectivity_array();
+ if (!array)
+ array += (actual_start_handle - seq->start_handle())
+ * static_cast<ElementSequence*>(seq)->nodes_per_element();
return error;
-MBErrorCode MBReadUtil::get_poly_element_array(
- const int num_poly,
- const int conn_list_length,
- const MBEntityType mdb_type,
- const int preferred_start_id,
- const int preferred_start_proc,
- MBEntityHandle& actual_start_handle,
- int*& last_index_array,
- MBEntityHandle*& connectivity_array )
- MBErrorCode error;
- if (mdb_type != MBPOLYGON && mdb_type != MBPOLYHEDRON)
- error = mMB->sequence_manager()->create_entity_sequence(
- mdb_type, num_poly, conn_list_length, preferred_start_id,
- preferred_start_proc, actual_start_handle, seq);
- if (MB_SUCCESS != error || NULL == seq)
- return error;
- PolyEntitySequence *pseq = dynamic_cast<PolyEntitySequence*>(seq);
- assert(NULL != pseq);
- pseq->get_connectivity_array( connectivity_array );
- pseq->get_index_array( last_index_array );
- return MB_SUCCESS;
MBErrorCode MBReadUtil::create_entity_sets( MBEntityID num_sets,
const unsigned* flags ,
MBEntityID start_id,
@@ -141,14 +112,13 @@
MBErrorCode error;
error = mMB->sequence_manager()->create_meshset_sequence( num_sets,
start_id,
proc,
flags,
+ start_handle,
seq );
- if (seq)
- start_handle = seq->get_start_handle();
return error;
Modified: MOAB/trunk/MBReadUtil.hpp
--- MOAB/trunk/MBReadUtil.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBReadUtil.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -77,31 +77,6 @@
MBRange &related_ents,
MBRange *all_sets);
- /** Allocate storage for poly (polygon or polyhedron elements)
- * Allocate storage for poly (polygon or polyhedron elements) and
- * return connectivity arrays for direct read into memory.
- *\param num_poly The number of polygons to allocate handles for.
- *\param conn_list_length The total length of the connectivity list.
- *\param mdb_type <code>MBPOLYGON</code> or <code>MBPOLYHEDRON</code>
- *\param preferred_start_id Preferred integer id for first element
- *\param actual_start_handle Actual integer id for first element (returned)
- *\param last_index_array Array of indices into <code>connectivity_array</code<
- *\param connectivity_array The connectivity array
- *\author Jason Kraftcheck
- MBErrorCode get_poly_element_array(
MBErrorCode create_entity_sets(
const unsigned* set_flags,
Modified: MOAB/trunk/MBReadUtilIface.hpp
--- MOAB/trunk/MBReadUtilIface.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBReadUtilIface.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -90,40 +90,6 @@
MBRange *all_sets) = 0;
- * The format of the poly data in memory is two lists. The array of
- * entity handles contains a concatenation of the connectivity lists
- * of all the polys in the sequence, in order. The second list contains
- * indices into the connectivity list where each index is the index of
- * the <em>last</em> handle for the corresponding poly.
- * For polygons, the connectivity list contains vertex handles. For
- * polyhedra, it contains face (element of dimension 2) handles.
- virtual MBErrorCode get_poly_element_array(
- ) = 0;
virtual MBErrorCode create_entity_sets(
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBTest.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -47,7 +47,7 @@
#endif
#include "MBInternals.hpp"
@@ -2254,12 +2254,13 @@
result = MB->get_connectivity(&entity_vec[0], entity_vec.size(), nodes);
if(result != MB_SUCCESS )
return result;
+ assert( nodes.size() == 4 * temp_range.size() );
temp_vec.clear();
std::vector<double> coords(3*nodes.size());
result = MB->get_coords(&nodes[0], nodes.size(), &coords[0]);
return result;
unsigned int k = 0;
for(MBRange::iterator it = temp_range.begin(); it != temp_range.end(); it++) {
if( coords[12*k] == 2.5 && coords[12*k+3] == 2.5 &&
@@ -3998,6 +3999,11 @@
for (this_type = MBEDGE; this_type != MBKNIFE; this_type++) {
+ // skip remainder of the loop for POLYGONS and POLYHEDRA, which don't follow
+ // the standard canonical ordering
+ if (this_type == MBPOLYGON || this_type == MBPOLYHEDRON)
+ continue;
// make an entity of this type
result = MB->create_element(this_type, vertex_handles,
MBCN::VerticesPerEntity(this_type),
@@ -4007,11 +4013,6 @@
<< MBCN::EntityTypeName(this_type) << endl;
return MB_FAILURE;
- // skip remainder of the loop for POLYGONS and POLYHEDRA, which don't follow
- // the standard canonical ordering
- if (this_type == MBPOLYGON || this_type == MBPOLYHEDRON)
- continue;
// now get the connectivity vector *
const MBEntityHandle *entity_vertices;
@@ -4667,12 +4668,12 @@
MBErrorCode mb_range_seq_intersect_test( MBInterface*)
MBErrorCode rval;
- EntitySequenceManager sequences(MBHandleUtils( 0, 1 ));
+ SequenceManager sequences(MBHandleUtils( 0, 1 ));
MBRangeSeqIntersectIter iter( &sequences );
MBRange range;
// create some entity sequences
- MBEntitySequence *ts1, *ts2, *ts3, *qs1;
+ EntitySequence *ts1, *ts2, *ts3, *qs1;
MBEntityHandle th1, th2, th3, qh1;
const int nt1 = 100, nt2 = 10, nt3 = 1, nq1 = 20;
rval = sequences.create_entity_sequence( MBTRI, nt1, 3, 5, 0, th1, ts1 );
@@ -4690,10 +4691,10 @@
// construct an MBRange containing all valid handles;
range.clear();
- ts1->get_entities( range );
- ts2->get_entities( range );
- ts3->get_entities( range );
- qs1->get_entities( range );
+ range.insert( ts1->start_handle(), ts1->end_handle() );
+ range.insert( ts2->start_handle(), ts2->end_handle() );
+ range.insert( ts3->start_handle(), ts3->end_handle() );
+ range.insert( qs1->start_handle(), qs1->end_handle() );
// iterate over all and check results
@@ -4702,9 +4703,9 @@
return rval;
if (ts1 != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != ts1->get_start_handle())
+ if (iter.get_start_handle() != ts1->start_handle())
return MB_FAILURE;
- if (iter.get_end_handle() != ts1->get_end_handle())
+ if (iter.get_end_handle() != ts1->end_handle())
return MB_FAILURE;
rval = iter.step();
@@ -4712,9 +4713,9 @@
return rval;
if (ts2 != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != ts2->get_start_handle())
+ if (iter.get_start_handle() != ts2->start_handle())
return MB_FAILURE;
- if (iter.get_end_handle() != ts2->get_end_handle())
+ if (iter.get_end_handle() != ts2->end_handle())
return MB_FAILURE;
rval = iter.step();
@@ -4722,9 +4723,9 @@
return rval;
if (ts3 != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != ts3->get_start_handle())
+ if (iter.get_start_handle() != ts3->start_handle())
return MB_FAILURE;
- if (iter.get_end_handle() != ts3->get_end_handle())
+ if (iter.get_end_handle() != ts3->end_handle())
return MB_FAILURE;
rval = iter.step();
@@ -4732,9 +4733,9 @@
return rval;
if (qs1 != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != qs1->get_start_handle())
+ if (iter.get_start_handle() != qs1->start_handle())
return MB_FAILURE;
- if (iter.get_end_handle() != qs1->get_end_handle())
+ if (iter.get_end_handle() != qs1->end_handle())
return MB_FAILURE;
if (!iter.is_at_end())
@@ -4750,9 +4751,9 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
@@ -4771,9 +4772,9 @@
return rval;
return MB_FAILURE;
- if (iter.get_start_handle() != ts1->get_start_handle() + 1)
+ if (iter.get_start_handle() != ts1->start_handle() + 1)
return MB_FAILURE;
return MB_FAILURE;
rval = iter.step();
@@ -4781,9 +4782,9 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
@@ -4800,9 +4801,9 @@
return rval;
return MB_FAILURE;
- if (iter.get_start_handle() != qs1->get_start_handle() + 1)
+ if (iter.get_start_handle() != qs1->start_handle() + 1)
return MB_FAILURE;
- if (iter.get_end_handle() != qs1->get_end_handle() - 1)
+ if (iter.get_end_handle() != qs1->end_handle() - 1)
return MB_FAILURE;
@@ -4814,7 +4815,7 @@
// Iterate over two subsets of the quad sequence
MBRange quads = range.subset_by_type( MBQUAD );
- MBEntityHandle removed = qs1->get_start_handle() + nq1/2;
+ MBEntityHandle removed = qs1->start_handle() + nq1/2;
if (quads.erase( removed ) == quads.end())
return MB_FAILURE;
@@ -4823,7 +4824,7 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
if (iter.get_end_handle() != removed - 1)
return MB_FAILURE;
@@ -4835,7 +4836,7 @@
return MB_FAILURE;
if (iter.get_start_handle() != removed + 1)
return MB_FAILURE;
return MB_FAILURE;
@@ -4850,7 +4851,7 @@
MBRange big;
int junk;
MBEntityHandle last = CREATE_HANDLE(MBQUAD+1, 0, junk);
- big.insert( ts1->get_start_handle() - 1, last );
+ big.insert( ts1->start_handle() - 1, last );
// first some invalid handles in the beginning of the range
rval = iter.init( big.begin(), big.end() );
@@ -4860,7 +4861,7 @@
return MB_FAILURE;
if (iter.get_start_handle() != *big.begin())
return MB_FAILURE;
- if (iter.get_end_handle() != ts1->get_start_handle() - 1)
+ if (iter.get_end_handle() != ts1->start_handle() - 1)
return MB_FAILURE;
// next the first triangle sequence
@@ -4869,21 +4870,21 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next the the invalid handles between the first two tri sequences
- if (ts1->get_end_handle() + 1 != ts2->get_start_handle()) {
+ if (ts1->end_handle() + 1 != ts2->start_handle()) {
rval = iter.step();
if (MB_ENTITY_NOT_FOUND != rval)
return MB_FAILURE;
if (NULL != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != ts1->get_end_handle()+1)
+ if (iter.get_start_handle() != ts1->end_handle()+1)
return MB_FAILURE;
- if (iter.get_end_handle() != ts2->get_start_handle()-1)
+ if (iter.get_end_handle() != ts2->start_handle()-1)
return MB_FAILURE;
@@ -4893,21 +4894,21 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next the the invalid handles between the 2nd and 3rd tri sequences
- if (ts2->get_end_handle() + 1 != ts3->get_start_handle()) {
+ if (ts2->end_handle() + 1 != ts3->start_handle()) {
rval = iter.step();
return MB_FAILURE;
return MB_FAILURE;
- if (iter.get_start_handle() != ts2->get_end_handle()+1)
+ if (iter.get_start_handle() != ts2->end_handle()+1)
return MB_FAILURE;
- if (iter.get_end_handle() != ts3->get_start_handle()-1)
+ if (iter.get_end_handle() != ts3->start_handle()-1)
return MB_FAILURE;
@@ -4917,23 +4918,23 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// third tri sequence contains the MAX tri handle, so no more
// invalid triangles.
// next 1 invalid quad at the before MB_START_ID
- if (ts3->get_end_handle() + 1 != qs1->get_start_handle()) {
+ if (ts3->end_handle() + 1 != qs1->start_handle()) {
rval = iter.step();
return MB_FAILURE;
return MB_FAILURE;
- if (iter.get_start_handle() != ts3->get_end_handle()+1)
+ if (iter.get_start_handle() != ts3->end_handle()+1)
return MB_FAILURE;
- if (iter.get_end_handle() != qs1->get_start_handle()-1)
+ if (iter.get_end_handle() != qs1->start_handle()-1)
return MB_FAILURE;
@@ -4943,9 +4944,9 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next remaining invalid quad handles in the range
@@ -4954,7 +4955,7 @@
return MB_FAILURE;
if (0 != iter.get_sequence())
return MB_FAILURE;
- if (iter.get_start_handle() != qs1->get_end_handle() + 1)
+ if (iter.get_start_handle() != qs1->end_handle() + 1)
return MB_FAILURE;
if (iter.get_end_handle() != last - 1)
return MB_FAILURE;
@@ -4980,12 +4981,15 @@
// Create some holes
- MBEntityHandle dead1 = ts1->get_start_handle() + 1;
- MBEntityHandle dead2 = ts1->get_start_handle() + 2;
- MBEntityHandle dead3 = ts2->get_start_handle();
- MBEntityHandle dead4 = ts2->get_end_handle();
- MBEntityHandle dead5 = qs1->get_start_handle() + nq1/2;
+ MBEntityHandle ts1s = ts1->start_handle();
+ MBEntityHandle dead1 = ts1->start_handle() + 1;
+ MBEntityHandle dead2 = ts1->start_handle() + 2;
+ MBEntityHandle ts1e = ts1->end_handle();
+ MBEntityHandle dead3 = ts2->start_handle();
+ MBEntityHandle dead4 = ts2->end_handle();
+ MBEntityHandle qs1s = qs1->start_handle();
+ MBEntityHandle qs1e = qs1->end_handle();
+ MBEntityHandle dead5 = qs1->start_handle() + nq1/2;
MBEntityHandle dead6 = dead5+1;
rval = sequences.delete_entity( dead1 );
if (MB_SUCCESS != rval) return rval;
@@ -5007,9 +5011,11 @@
rval = iter.init( range.begin(), range.end() );
return rval;
- if (ts1 != iter.get_sequence())
+ if (0 == iter.get_sequence() ||
+ ts1s != iter.get_sequence()->start_handle() ||
+ dead1-1 != iter.get_sequence()->end_handle())
return MB_FAILURE;
return MB_FAILURE;
if (iter.get_end_handle() != dead1 - 1)
return MB_FAILURE;
@@ -5018,7 +5024,7 @@
rval = iter.step( );
return MB_FAILURE;
+ if (0 != iter.get_sequence())
return MB_FAILURE;
if (iter.get_start_handle() != dead1)
return MB_FAILURE;
@@ -5029,18 +5035,20 @@
rval = iter.step();
return rval;
+ dead2+1 != iter.get_sequence()->start_handle() ||
+ ts1e != iter.get_sequence()->end_handle())
return MB_FAILURE;
if (iter.get_start_handle() != dead2+1)
return MB_FAILURE;
+ if (iter.get_end_handle() != ts1e)
return MB_FAILURE;
// next an invalid handle at the start of the second sequence
rval = iter.step();
return MB_FAILURE;
- if (ts2 != iter.get_sequence())
return MB_FAILURE;
if (iter.get_start_handle() != dead3)
return MB_FAILURE;
@@ -5051,6 +5059,10 @@
rval = iter.step();
return rval;
+ dead3+1 != iter.get_sequence()->start_handle() ||
+ dead4-1 != iter.get_sequence()->end_handle())
return MB_FAILURE;
if (iter.get_start_handle() != dead3+1)
@@ -5062,7 +5074,7 @@
rval = iter.step();
return MB_FAILURE;
return MB_FAILURE;
if (iter.get_start_handle() != dead4)
return MB_FAILURE;
@@ -5075,18 +5087,22 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next the quad sequence up to the invalid handle in the middle
rval = iter.step();
return rval;
+ qs1s != iter.get_sequence()->start_handle() ||
+ dead5-1 != iter.get_sequence()->end_handle())
return MB_FAILURE;
+ if (iter.get_start_handle() != qs1s)
return MB_FAILURE;
if (iter.get_end_handle() != dead5-1)
return MB_FAILURE;
@@ -5095,7 +5111,7 @@
rval = iter.step();
return MB_FAILURE;
- if (qs1 != iter.get_sequence())
return MB_FAILURE;
if (iter.get_start_handle() != dead5)
return MB_FAILURE;
@@ -5106,11 +5122,13 @@
rval = iter.step();
return rval;
+ dead6+1 != iter.get_sequence()->start_handle() ||
+ qs1e != iter.get_sequence()->end_handle())
return MB_FAILURE;
if (iter.get_start_handle() != dead6+1)
return MB_FAILURE;
+ if (iter.get_end_handle() != qs1e)
return MB_FAILURE;
// now at the end
@@ -5141,9 +5159,11 @@
return rval;
return MB_FAILURE;
+ if (iter.get_start_handle() != ts1s)
return MB_FAILURE;
return MB_FAILURE;
@@ -5152,18 +5172,22 @@
rval = iter.step();
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next the second sequence between deleted start and end handles
rval = iter.step();
return rval;
return MB_FAILURE;
return MB_FAILURE;
@@ -5176,18 +5200,20 @@
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// next the quad sequence up to the hole in the middle
rval = iter.step();
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
@@ -5196,11 +5222,13 @@
rval = iter.step();
return rval;
return MB_FAILURE;
return MB_FAILURE;
return MB_FAILURE;
// now at the end
Modified: MOAB/trunk/MBWriteUtil.cpp
--- MOAB/trunk/MBWriteUtil.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MBWriteUtil.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -20,10 +20,11 @@
+#include "SequenceManager.hpp"
+#include "VertexSequence.hpp"
#include "MBTagConventions.hpp"
#include <sys/types.h>
@@ -128,9 +129,9 @@
return MB_FAILURE;
// Sequence iterators
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_iter, seq_end;
- seq_iter = mMB->sequence_manager()->entity_map(MBVERTEX)->begin();
- seq_end = mMB->sequence_manager()->entity_map(MBVERTEX)->end();
+ TypeSequenceManager::iterator seq_iter, seq_end;
+ seq_iter = mMB->sequence_manager()->entity_map(MBVERTEX).begin();
+ seq_end = mMB->sequence_manager()->entity_map(MBVERTEX).end();
// loop over range, getting coordinate value
double* output_iter = output_array;
@@ -138,9 +139,9 @@
while (iter != end)
// Find the sqeuence containing the current handle
- while (seq_iter != seq_end && seq_iter->second->get_end_handle() < *iter)
+ while (seq_iter != seq_end && (*seq_iter)->end_handle() < *iter)
++seq_iter;
- if (seq_iter == seq_end || *iter < seq_iter->second->get_start_handle())
+ if (seq_iter == seq_end || *iter < (*seq_iter)->start_handle())
return MB_FAILURE;
// Determine how much of the sequence we want.
@@ -148,19 +149,19 @@
MBRange::const_iterator prev(end);
--prev;
MBEntityHandle range_end = pair->second;
- MBEntityHandle sequence_end = seq_iter->second->get_end_handle();
+ MBEntityHandle sequence_end = (*seq_iter)->end_handle();
MBEntityHandle end_handle = range_end > sequence_end ? sequence_end : range_end;
if (end_handle > *prev)
end_handle = *prev;
MBEntityHandle count = end_handle - *iter + 1;
// Get offset in sequence to start at
- assert( *iter >= seq_iter->second->get_start_handle() );
- MBEntityHandle offset = *iter - seq_iter->second->get_start_handle();
+ assert( *iter >= (*seq_iter)->start_handle() );
+ MBEntityHandle offset = *iter - (*seq_iter)->start_handle();
// Get coordinate arrays from sequence
+ static_cast<VertexSequence*>(*seq_iter)
->get_coordinate_arrays( coord_array[0], coord_array[1], coord_array[2]);
// Copy data to ouput buffer
@@ -201,17 +202,17 @@
MBRange::const_iterator range_iter = elements.begin();
MBRange::const_iterator range_iter_end = elements.end();
- std::map<MBEntityHandle, MBEntitySequence*>::const_iterator seq_iter, seq_iter_end;
+ TypeSequenceManager::iterator seq_iter, seq_iter_end;
MBEntityType current_type = TYPE_FROM_HANDLE(*range_iter);
- seq_iter = mMB->sequence_manager()->entity_map(current_type)->begin();
- seq_iter_end = mMB->sequence_manager()->entity_map(current_type)->end();
+ seq_iter = mMB->sequence_manager()->entity_map(current_type).begin();
+ seq_iter_end = mMB->sequence_manager()->entity_map(current_type).end();
+ TypeSequenceManager::iterator seq_iter_lookahead = seq_iter;
+ (*seq_iter_lookahead)->start_handle() < *range_iter; )
++seq_iter;
@@ -225,34 +226,34 @@
+ *range_iter_lookahead <= (*seq_iter)->end_handle();
if(current_type != TYPE_FROM_HANDLE(*range_iter))
// lets find the entity sequence which holds the first entity of this type
+ TypeSequenceManager::const_iterator seq_iter_lookahead = seq_iter;
++seq_iter;
- int i = static_cast<ElementEntitySequence*>(seq_iter->second)->nodes_per_element();
+ int i = static_cast<ElementSequence*>(*seq_iter)->nodes_per_element();
// get the connectivity array
- MBEntityHandle* conn_array = NULL;
- static_cast<ElementEntitySequence*>(seq_iter->second)->get_connectivity_array(conn_array);
+ MBEntityHandle* conn_array =
+ static_cast<ElementSequence*>(*seq_iter)->get_connectivity_array();
- MBEntityHandle start_handle = seq_iter->second->get_start_handle();
+ MBEntityHandle start_handle = (*seq_iter)->start_handle();
@@ -301,7 +302,7 @@
+ TypeSequenceManager::const_iterator seq_iter, seq_end;
MBEntityType current_type = MBMAXTYPE;
@@ -316,36 +317,36 @@
if (type >= MBENTITYSET || type < MBEDGE)
return MB_FAILURE;
- seq_iter = mMB->sequence_manager()->entity_map(type)->begin();
- seq_end = mMB->sequence_manager()->entity_map(type)->end();
+ seq_iter = mMB->sequence_manager()->entity_map(type).begin();
+ seq_end = mMB->sequence_manager()->entity_map(type).end();
current_type = type;
++seq_iter;
return MB_FAILURE;
- int conn_size = static_cast<ElementEntitySequence*>(seq_iter->second)->nodes_per_element();
+ int conn_size = static_cast<ElementSequence*>(*seq_iter)->nodes_per_element();
+ conn_array = static_cast<ElementSequence*>(*seq_iter)->get_connectivity_array();
MBRange::pair_iterator pair(iter);
--prev;
end_handle = *prev;
// Make sure sufficient space in output array
if (output_iter + (count * conn_size) > output_end)
@@ -395,208 +396,24 @@
MBErrorCode MBWriteUtil::get_poly_array_size(
- MBRange::const_iterator iter,
- const MBRange::const_iterator end,
- int& connectivity_size )
+ MBRange::const_iterator ,
+ const MBRange::const_iterator ,
+ int& )
- connectivity_size = 0;
- // check the data we got
- if(iter == end)
- return MB_FAILURE;
- // Sequence iterators
- // loop over range, getting coordinate value
- MBEntityType current_type = MBMAXTYPE;
- while (iter != end)
- // Make sure we have the right sequence list (and get the sequence
- // list for the first iteration.)
- MBEntityType type = TYPE_FROM_HANDLE(*iter);
- if (type != current_type)
- if (type != MBPOLYGON && type != MBPOLYHEDRON)
- current_type = type;
- // Find the sqeuence containing the current handle
- ++seq_iter;
- // get the index array
- int* last_index_array;
- PolyEntitySequence* poly_seq = dynamic_cast<PolyEntitySequence*>(seq_iter->second);
- if (NULL == poly_seq) { assert(0); return MB_FAILURE; }
- poly_seq->get_index_array( last_index_array );
- // Determine how much of the sequence we want.
- MBRange::pair_iterator pair(iter);
- MBRange::const_iterator prev(end);
- --prev;
- MBEntityHandle range_end = pair->second;
- MBEntityHandle sequence_end = poly_seq->get_end_handle();
- MBEntityHandle end_handle = range_end > sequence_end ? sequence_end : range_end;
- if (end_handle > *prev)
- end_handle = *prev;
- MBEntityHandle count = end_handle - *iter + 1;
- // Get offset in sequence to start at
- assert( *iter >= poly_seq->get_start_handle() );
- MBEntityHandle offset = *iter - poly_seq->get_start_handle();
- // Calculate the connectivity length for the subset of the current sequence
- int prev_index = (offset == 0) ? -1 : last_index_array[offset-1];
- int last_index = last_index_array[offset + count - 1];
- connectivity_size += last_index - prev_index;
- iter += count;
+ return MB_NOT_IMPLEMENTED;
MBErrorCode MBWriteUtil::get_poly_arrays(
- MBRange::const_iterator& iter,
- const MBTag node_id_tag,
- size_t& element_array_len,
- int *const element_array,
- size_t& index_array_len,
- int*const index_array,
- int& index_offset )
+ MBRange::const_iterator& ,
+ const MBTag ,
+ size_t& ,
+ int *const ,
+ size_t& ,
+ int*const ,
+ int& )
- if (iter == end)
- if (index_array_len < 1 || element_array_len < 1)
- if (!element_array || !index_array)
- TagServer* tag_server = mMB->tag_server();
- // Iterators into output arrays
- int* elem_out_iter = element_array;
- int*const elem_out_end = element_array + element_array_len;
- int* idx_out_iter = index_array;
- int* idx_out_end = index_array + index_array_len;
- while (iter != end && idx_out_iter != idx_out_end)
- ++seq_iter;
- // get the arrays
- MBEntityHandle* conn_array;
- poly_seq->get_connectivity_array( conn_array );
- --prev;
- // Check if sufficient space in index array
- if (idx_out_iter + count > idx_out_end)
- count = idx_out_end - idx_out_iter;
- int conn_size = last_index - prev_index;
- // Check for sufficient space in id array
- int space = elem_out_end - elem_out_iter;
- if (conn_size > space)
- // back up until the data fits.
- int* back_iter = last_index_array + offset + count - 1;
- int* back_end = last_index_array + offset;
- while (back_iter != back_end && (*back_iter - prev_index) > space)
- --back_iter;
- // not even the first poly fits?
- if (back_iter == back_end)
- break;
- // update how many polys we're writing
- count = back_iter - back_end + 1;
- last_index = *back_iter;
- conn_size = *back_iter - prev_index;
- // Convert element handles to global IDs and write IDs into output array
- MBErrorCode rval = tag_server->get_data( node_id_tag,
- conn_array + prev_index + 1,
- conn_size,
- elem_out_iter );
- elem_out_iter += conn_size;
- if (MB_SUCCESS != rval)
- return rval;
- // Copy indices into output array, offsetting as necessary
- // offsetting must account for a) initial input offset from user,
- // b) the offset since the last sequence and c) the offset from
- // the start of the current sequence.
- int curr_offset = index_offset - (prev_index + 1);
- int *const index_end = idx_out_iter + count;
- last_index_array += offset;
- while (idx_out_iter != index_end)
- *idx_out_iter = *last_index_array + curr_offset;
- ++idx_out_iter;
- ++last_index_array;
- index_offset += conn_size;
- iter += count;
- element_array_len = elem_out_iter - element_array;
- index_array_len = idx_out_iter - index_array;
@@ -627,17 +444,17 @@
+ TypeSequenceManager::const_iterator seq_iter, seq_iter_end;
++seq_iter;
@@ -654,34 +471,34 @@
++seq_iter;
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/Makefile.am 2007-11-09 22:28:33 UTC (rev 1374)
@@ -94,10 +94,9 @@
DenseTagCollections.cpp \
DenseTagCollections.hpp \
DualTool.cpp \
+ ElementSequence.hpp \
EntitySequence.cpp \
EntitySequence.hpp \
- EntitySequenceManager.cpp \
- EntitySequenceManager.hpp \
ExoIIUtil.cpp \
ExoIIUtil.hpp \
FileOptions.cpp \
@@ -144,24 +143,34 @@
MeshSetSequence.cpp \
MeshSetSequence.hpp \
MeshTopoUtil.cpp \
- PolyEntitySequence.cpp \
- PolyEntitySequence.hpp \
ReadGmsh.cpp \
ReadGmsh.hpp \
ReadSTL.cpp \
ReadSTL.hpp \
ReadVtk.cpp \
ReadVtk.hpp \
- ScdElementSeq.cpp \
- ScdElementSeq.hpp \
- ScdVertexSeq.cpp \
- ScdVertexSeq.hpp \
+ ScdElementData.cpp \
+ ScdElementData.hpp \
+ ScdVertexData.cpp \
+ ScdVertexData.hpp \
+ SequenceData.hpp \
+ SequenceData.cpp \
+ SequenceManager.cpp \
+ SequenceManager.hpp \
SparseTagCollections.cpp \
SparseTagCollections.hpp \
+ StructuredElementSeq.cpp \
+ StructuredElementSeq.hpp \
TagServer.cpp \
TagServer.hpp \
Tqdcfr.cpp \
Tqdcfr.hpp \
+ TypeSequenceManager.cpp \
+ TypeSequenceManager.hpp \
+ UnstructuredElemSeq.cpp \
+ UnstructuredElemSeq.hpp \
+ VertexSequence.hpp \
+ VertexSequence.cpp \
VtkUtil.cpp \
VtkUtil.hpp \
WriteAns.cpp \
@@ -265,7 +274,7 @@
test_adj_LDADD = $(top_builddir)/libMOAB.la
test_adj_DEPENDENCIES = $(top_builddir)/libMOAB.la
-seq_man_test_SOURCES = EntitySequenceManager.cpp
+seq_man_test_SOURCES = TestTypeSequenceManager.cpp
seq_man_test_LDADD = $(top_builddir)/libMOAB.la
seq_man_test_CXXFLAGS = -DTEST $(CXXFLAGS)
Modified: MOAB/trunk/MeshSetSequence.cpp
--- MOAB/trunk/MeshSetSequence.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MeshSetSequence.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -19,299 +19,143 @@
#include "MeshSetSequence.hpp"
-MeshSetSequence::MeshSetSequence( EntitySequenceManager* man,
- MBEntityHandle start_handle,
- MBEntityID num_entities,
- unsigned flags )
- : MBEntitySequence( man, start_handle, num_entities )
+MeshSetSequence::MeshSetSequence( MBEntityHandle start,
+ MBEntityID count,
+ const unsigned* flags,
+ SequenceData* data )
+ : EntitySequence( start, count, data )
- std::vector<unsigned> flag_vect(num_entities, flags);
- initialize( man, start_handle, num_entities, &flag_vect[0] );
+ initialize( flags );
- const unsigned* flags )
+ MBEntityID count,
+ unsigned flags,
- initialize( man, start_handle, num_entities, flags );
+ std::vector<unsigned> vect( count, flags );
+ initialize( &vect[0] );
-void MeshSetSequence::initialize( EntitySequenceManager* man,
+ MBEntityID count,
+ MBEntityID data_size )
+ : EntitySequence( start, count, new SequenceData( 1, start, start+data_size-1) )
- man->entity_sequence_created( this );
- // allocate storage
- mSets = new unsigned char[SET_SIZE * num_entities];
- mFreeEntities.clear();
- if (flags) {
- mNumEntities = num_entities;
- mFirstFreeIndex = -1;
- for (MBEntityID i = 0; i < num_entities; ++i)
- allocate_set( flags[i], i );
- else {
- man->notify_not_full( this );
- mNumEntities = 0;
- mFirstFreeIndex = 0;
- mFreeEntities.resize( mNumAllocated, true );
- next_free(i) = i + 1;
- next_free(num_entities-1) = -1;
-MeshSetSequence::~MeshSetSequence()
+ MBEntityID count,
+ unsigned flags,
- mSequenceManager->entity_sequence_deleted( this );
- if (mSets) {
- for (MBEntityID i = 0; i < mNumAllocated; ++i)
- if (is_valid_entity(get_start_handle()+i))
- deallocate_set( i );
- delete [] mSets;
-MBEntityHandle MeshSetSequence::get_unused_handle()
+void MeshSetSequence::initialize( const unsigned* flags )
- return 0;
+ if (!data()->get_sequence_data(0))
+ data()->create_sequence_data( 0, SET_SIZE );
+ MBEntityID offset = start_handle() - data()->start_handle();
+ for (MBEntityID i = 0; i < size(); ++i)
+ allocate_set( flags[i], i+offset );
-MBErrorCode MeshSetSequence::add_meshset(MBEntityHandle handle, unsigned flags)
+MeshSetSequence::~MeshSetSequence()
- if (handle < get_start_handle() || handle > get_end_handle())
- return MB_INDEX_OUT_OF_RANGE;
- // check and update allocated flag
- const MBEntityID index = handle - get_start_handle();
- if (mFreeEntities.empty() || !mFreeEntities[index])
- return MB_ALREADY_ALLOCATED;
- mFreeEntities[index] = false;
- // remove from linked list of free entities
- if (mFirstFreeIndex == index)
- mFirstFreeIndex = next_free(index);
- else {
-#ifndef NDEBUG
- int counter = 0;
-#endif
- MBEntityID i = mFirstFreeIndex;
- while (next_free(i) != index) {
- assert( ++counter <= (number_allocated() - number_entities()) );
- i = next_free(i);
- next_free(i) = next_free(index);
- // update last-deleted index
- if (mLastDeletedIndex == index)
- mLastDeletedIndex = -1;
- // initialze entity set
- allocate_set( flags, index );
- mNumEntities++;
- if (mNumEntities == mNumAllocated) {
- mSequenceManager->notify_full(this);
- std::vector<bool> empty;
- mFreeEntities.swap( empty);
+ MBEntityID count = size();
+ for (MBEntityID i = 0; i < count; ++i)
+ deallocate_set( i + offset );
-MBErrorCode MeshSetSequence::allocate_handle(MBEntityHandle handle)
+EntitySequence* MeshSetSequence::split( MBEntityHandle here )
+ return new MeshSetSequence( *this, here );
-MBEntityHandle MeshSetSequence::add_meshset( unsigned flags )
+MBErrorCode MeshSetSequence::pop_back( MBEntityID count )
- if (mFirstFreeIndex == -1)
- return 0;
- const MBEntityID index = mFirstFreeIndex;
- mNumEntities++;
- return get_start_handle() + index;
+ MBEntityID offset = end_handle() + 1 - count - data()->start_handle();
+ MBErrorCode rval = EntitySequence::pop_back(count);
+ return rval;
-MBErrorCode MeshSetSequence::is_valid() const
+MBErrorCode MeshSetSequence::pop_front( MBEntityID count )
- if (mFirstFreeIndex >= number_allocated())
+ MBErrorCode rval = EntitySequence::pop_front(count);
+ return rval;
- // if entity sequence is full by any indicator, ensure
- // all indicators are consistant
- if (number_entities() == number_allocated() || mFreeEntities.empty() || mFirstFreeIndex < 0) {
- if (number_entities() != number_allocated())
- if (!mFreeEntities.empty())
- if (mFirstFreeIndex >= 0)
- // make sure mFreeEntities is correctly allocated
- if (mFreeEntities.size() != (size_t)number_allocated())
- // count number of unallocated entities
- size_t count = 0;
- for (size_t i = 0; i < mFreeEntities.size(); ++i)
- if (mFreeEntities[i])
- ++count;
- // check number of free entities
- if (count != (size_t)(number_allocated() - number_entities()))
- // check linked list of free entities
- for (MBEntityID i = mFirstFreeIndex; i != -1; i = next_free(i)) {
- --count;
- if (i < 0)
- if (i >= number_allocated())
- if (!mFreeEntities[i])
- // check length of linked list
- if (count != 0)
- // check last deleted
- if (mLastDeletedIndex != -1) {
- if (mLastDeletedIndex < 0)
- if (mLastDeletedIndex >= number_allocated())
- if (!mFreeEntities[mLastDeletedIndex])
-void MeshSetSequence::free_handle( MBEntityHandle handle )
+MBErrorCode MeshSetSequence::push_back( MBEntityID count, const unsigned* flags )
- if (!is_valid_entity(handle))
- return;
- // free any memory allocated by the MBMeshSet
- deallocate_set( index );
- // decerement count of valid entities
- if(mNumEntities == mNumAllocated) {
- mSequenceManager->notify_not_full(this);
- mFreeEntities.resize( mNumAllocated, false );
- --mNumEntities;
- // mark this entity as invalid
- mFreeEntities[index] = true;
- // Add this entity to the free list.
- // Free list is maintained in sorted order.
- // insert at beginning?
- if (mFirstFreeIndex == -1 || mFirstFreeIndex > index) {
- next_free(index) = mFirstFreeIndex;
- mFirstFreeIndex = mLastDeletedIndex = index;
- return;
- // Find entry to insert after.
- MBEntityID prev_index = mFirstFreeIndex;
- // mLastDeletedIndex is a cache of the last deleted
- // entity. Used to speed up sequential deletion.
- if (mLastDeletedIndex != -1 && mLastDeletedIndex < index)
- prev_index = mLastDeletedIndex;
- // Search list for location to insert at
- MBEntityID next = next_free(prev_index);
- while (next != -1 && next < index) {
- prev_index = next;
- next = next_free(next);
- // insert in free list
- mLastDeletedIndex = index;
- next_free(index) = next_free(prev_index);
- next_free(prev_index) = index;
-void MeshSetSequence::get_entities( MBRange& entities ) const
- MBRange::iterator iter = entities.insert(get_start_handle(), get_end_handle());
- for(MBEntityID index = mFirstFreeIndex; index != -1; index = next_free(index))
- iter += get_start_handle() + index - *iter;
- iter = entities.erase(iter);
+ MBEntityID offset = end_handle() + 1 - data()->start_handle();
+ MBErrorCode rval = EntitySequence::append_entities( count );
+ allocate_set( flags[i], i + offset );
+ return rval;
-MBEntityID MeshSetSequence::get_next_free_index( MBEntityID prev_free_index ) const
+MBErrorCode MeshSetSequence::push_front( MBEntityID count, const unsigned* flags )
- return prev_free_index < 0 ? mFirstFreeIndex : next_free(prev_free_index);
+ MBEntityID offset = start_handle() - data()->start_handle() - count;
+ MBErrorCode rval = EntitySequence::prepend_entities( count );
+ return rval;
-void MeshSetSequence::get_memory_use( unsigned long& used,
- unsigned long& allocated ) const
+void MeshSetSequence::get_const_memory_use( unsigned long& per_ent,
+ unsigned long& seq_size ) const
- used = 0;
- allocated = sizeof(*this) + mFreeEntities.capacity()/8;
- allocated += mNumAllocated * SET_SIZE;
- for (MBEntityHandle h = get_start_handle(); h <= get_end_handle(); ++h) {
- if (is_valid_entity(h)) {
- unsigned long m = get_set(h)->get_memory_use();
- used += m;
- allocated += m;
- else {
- allocated += SET_SIZE;
+ per_ent = SET_SIZE;
+ seq_size = sizeof(*this);
-unsigned long MeshSetSequence::get_memory_use( MBEntityHandle h ) const
+unsigned long MeshSetSequence::get_per_entity_memory_use( MBEntityHandle first,
+ MBEntityHandle last
+ ) const
- return SET_SIZE + get_set(h)->get_memory_use();
+ if (first < start_handle())
+ first = start_handle();
+ if (last > end_handle())
+ last = end_handle();
+ unsigned long sum = 0;
+ for (MBEntityHandle h = first; h <= last; ++h)
+ sum += get_set(h)->get_memory_use();
+ return sum;
-MBErrorCode MeshSetSequence::get_entities( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::get_entities( const SequenceManager* seqman,
+ MBEntityHandle handle,
MBRange& entities,
bool recursive ) const
if (!recursive) {
get_set(handle)->get_entities( entities );
return MB_SUCCESS;
else {
std::vector<MBMeshSet*> list;
- MBErrorCode rval = recursive_get_sets( handle, list );
+ MBErrorCode rval = recursive_get_sets( handle, seqman, list );
for (std::vector<MBMeshSet*>::iterator i = list.begin(); i != list.end(); ++i)
(*i)->get_non_set_entities( entities );
return rval;
@@ -321,115 +165,103 @@
std::vector<MBEntityHandle>& entities ) const
return MB_SUCCESS;
-MBErrorCode MeshSetSequence::get_dimension( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::get_dimension( const SequenceManager* seqman,
int dimension,
MBRange& entities,
if (!recursive) {
get_set(handle)->get_entities_by_dimension( dimension, entities );
return MB_SUCCESS;
else {
(*i)->get_entities_by_dimension( dimension, entities );
return rval;
-MBErrorCode MeshSetSequence::get_type( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::get_type( const SequenceManager* seqman,
MBEntityType type,
MBRange& entities,
if (!recursive) {
get_set(handle)->get_entities_by_type( type, entities );
return MB_SUCCESS;
else {
(*i)->get_entities_by_type( type, entities );
return rval;
-MBErrorCode MeshSetSequence::num_entities( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::num_entities( const SequenceManager* seqman,
int& number,
if (!recursive) {
number = get_set(handle)->num_entities();
return MB_SUCCESS;
else {
MBRange range;
- MBErrorCode result = get_entities( handle, range, true );
+ MBErrorCode result = get_entities( seqman, handle, range, true );
number = range.size();
return result;
-MBErrorCode MeshSetSequence::num_dimension( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::num_dimension( const SequenceManager* seqman,
int dimension,
int& number,
if (!recursive) {
number = get_set(handle)->num_entities_by_dimension(dimension);
return MB_SUCCESS;
else {
MBRange range;
- MBErrorCode result = get_dimension( handle, dimension, range, true );
+ MBErrorCode result = get_dimension( seqman, handle, dimension, range, true );
return result;
-MBErrorCode MeshSetSequence::num_type( MBEntityHandle handle,
+MBErrorCode MeshSetSequence::num_type( const SequenceManager* seqman,
MBEntityType type,
int& number,
if (!recursive) {
number = get_set(handle)->num_entities_by_type(type);
return MB_SUCCESS;
else {
MBRange range;
- MBErrorCode result = get_type( handle, type, range, true );
+ MBErrorCode result = get_type( seqman, handle, type, range, true );
return result;
MBErrorCode MeshSetSequence::recursive_get_sets( MBEntityHandle start_set,
+ const SequenceManager* seq_sets,
std::vector<MBMeshSet*>& sets ) const
std::set<MBEntityHandle> visited;
@@ -442,16 +274,12 @@
if (!visited.insert(handle).second)
continue;
- MBErrorCode rval = mSequenceManager->find( handle, seq );
+ EntitySequence* seq;
+ MBErrorCode rval = seq_sets->find( handle, seq );
return rval;
- if (!mseq->is_valid_entity(handle))
MBMeshSet *ms_ptr = mseq->get_set( handle );
sets.push_back( ms_ptr );
@@ -464,6 +292,7 @@
MBErrorCode MeshSetSequence::get_parent_child_meshsets( MBEntityHandle meshset,
std::vector<MBEntityHandle>& results,
int num_hops, bool parents ) const
@@ -490,12 +319,10 @@
// for each set at the current num_hops
for (i = lists[index].begin(); i != lists[index].end(); ++i) {
// get meshset from handle
- MBErrorCode rval = mSequenceManager->find( *i, seq );
+ MBErrorCode rval = seq_sets->find( *i, seq );
return rval;
- if (!seq->is_valid_entity(*i))
MBMeshSet *ms_ptr = reinterpret_cast<MeshSetSequence*>(seq)->get_set( *i );
// querying for parents or children?
@@ -520,14 +347,12 @@
return result;
-MBErrorCode MeshSetSequence::get_parents( MBEntityHandle handle,
- std::vector<MBEntityHandle>& parents,
- int num_hops ) const
+MBErrorCode MeshSetSequence::get_parents( const SequenceManager* seqman,
+ std::vector<MBEntityHandle>& parents,
+ int num_hops ) const
if (num_hops == 1) {
int count;
const MBEntityHandle* array = get_set( handle )->get_parents(count);
if (parents.empty()) {
@@ -541,19 +366,17 @@
if (num_hops > 0)
- return get_parent_child_meshsets( handle, parents, num_hops, true );
+ return get_parent_child_meshsets( handle, seqman, parents, num_hops, true );
else
- return get_parent_child_meshsets( handle, parents, -1, true );
+ return get_parent_child_meshsets( handle, seqman, parents, -1, true );
-MBErrorCode MeshSetSequence::get_children( MBEntityHandle handle,
- std::vector<MBEntityHandle>& children,
+MBErrorCode MeshSetSequence::get_children( const SequenceManager* seqman,
+ std::vector<MBEntityHandle>& children,
int count;
const MBEntityHandle* array = get_set( handle )->get_children(count);
if (children.empty()) {
@@ -567,44 +390,40 @@
if (num_hops > 0)
- return get_parent_child_meshsets( handle, children, num_hops, false );
+ return get_parent_child_meshsets( handle, seqman, children, num_hops, false );
else
- return get_parent_child_meshsets( handle, children, -1, false );
+ return get_parent_child_meshsets( handle, seqman, children, -1, false );
-MBErrorCode MeshSetSequence::num_parents( MBEntityHandle handle,
- int& number,
+MBErrorCode MeshSetSequence::num_parents( const SequenceManager* seqman,
+ int& number,
number = get_set( handle )->num_parents();
return MB_SUCCESS;
std::vector<MBEntityHandle> parents;
- MBErrorCode result = get_parents( handle, parents, num_hops );
+ MBErrorCode result = get_parents( seqman, handle, parents, num_hops );
number = parents.size();
return result;
-MBErrorCode MeshSetSequence::num_children( MBEntityHandle handle,
- int& number,
+MBErrorCode MeshSetSequence::num_children( const SequenceManager* seqman,
+ int& number,
number = get_set( handle )->num_children();
return MB_SUCCESS;
std::vector<MBEntityHandle> children;
- MBErrorCode result = get_children( handle, children, num_hops );
+ MBErrorCode result = get_children( seqman, handle, children, num_hops );
number = children.size();
return result;
Modified: MOAB/trunk/MeshSetSequence.hpp
--- MOAB/trunk/MeshSetSequence.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/MeshSetSequence.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -23,84 +23,101 @@
#include "MBMeshSet.hpp"
+#include "SequenceData.hpp"
-class MeshSetSequence : public MBEntitySequence
+class MeshSetSequence : public EntitySequence
public:
- MeshSetSequence( EntitySequenceManager* seq_man,
- unsigned set_flags );
+ MeshSetSequence( MBEntityHandle start,
+ MBEntityID count,
+ SequenceData* data );
+ MBEntityID count,
+ unsigned flags,
- const unsigned* set_flags = 0 );
+ MBEntityID count,
+ MBEntityID sequence_size );
+ MBEntityID count,
+ unsigned flags,
virtual ~MeshSetSequence();
- virtual MBEntityHandle get_unused_handle();
- MBEntityHandle add_meshset( unsigned flags );
- MBErrorCode add_meshset( MBEntityHandle handle, unsigned flags );
- virtual void free_handle( MBEntityHandle handle );
- virtual void get_entities( MBRange& entities ) const;
- virtual MBEntityID get_next_free_index( MBEntityID prev_free_index ) const;
- virtual void get_memory_use( unsigned long& ,unsigned long& ) const;
- virtual unsigned long get_memory_use( MBEntityHandle ) const;
+ EntitySequence* split( MBEntityHandle here );
- MBMeshSet* get_set( MBEntityHandle h );
- const MBMeshSet* get_set( MBEntityHandle h ) const;
+ SequenceData* create_data_subset( MBEntityHandle, MBEntityHandle ) const
+ { return 0; }
- MBErrorCode get_entities( MBEntityHandle set, MBRange& entities, bool recursive ) const;
- MBErrorCode get_entities( MBEntityHandle set, std::vector<MBEntityHandle>& entities ) const;
- MBErrorCode get_dimension( MBEntityHandle set, int dim, MBRange& entities, bool recursive ) const;
- MBErrorCode get_type( MBEntityHandle set, MBEntityType type, MBRange& entities, bool recursive ) const;
+ MBErrorCode pop_back( MBEntityID count );
+ MBErrorCode pop_front( MBEntityID count );
+ MBErrorCode push_back( MBEntityID count, const unsigned* flags );
+ MBErrorCode push_front( MBEntityID count, const unsigned* flags );
- MBErrorCode num_entities( MBEntityHandle set, int& count, bool recursive ) const;
- MBErrorCode num_dimension( MBEntityHandle set, int dim, int& count, bool recursive ) const;
- MBErrorCode num_type( MBEntityHandle set, MBEntityType type, int& count, bool recursive ) const;
+ void get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& size_of_sequence ) const;
+ unsigned long get_per_entity_memory_use( MBEntityHandle first,
+ MBEntityHandle last ) const;
- MBErrorCode get_parents ( MBEntityHandle of, std::vector<MBEntityHandle>& parents, int num_hops ) const;
- MBErrorCode get_children( MBEntityHandle of, std::vector<MBEntityHandle>& children, int num_hops ) const;
- MBErrorCode num_parents ( MBEntityHandle of, int& number, int num_hops ) const;
- MBErrorCode num_children( MBEntityHandle of, int& number, int num_hops ) const;
+ inline MBMeshSet* get_set( MBEntityHandle h );
+ inline const MBMeshSet* get_set( MBEntityHandle h ) const;
- MBErrorCode is_valid() const;
+ MBErrorCode get_entities( MBEntityHandle set, std::vector<MBEntityHandle>& entities ) const;
+ MBErrorCode get_entities( SequenceManager const* seqman, MBEntityHandle set, MBRange& entities, bool recursive ) const;
+ MBErrorCode get_dimension( SequenceManager const* seqman, MBEntityHandle set, int dim, MBRange& entities, bool recursive ) const;
+ MBErrorCode get_type( SequenceManager const* seqman, MBEntityHandle set, MBEntityType type, MBRange& entities, bool recursive ) const;
-protected:
- //! allocate the handle passed in, effectively creating the entity
- virtual MBErrorCode allocate_handle(MBEntityHandle handle);
+ MBErrorCode num_entities( SequenceManager const* seqman, MBEntityHandle set, int& count, bool recursive ) const;
+ MBErrorCode num_dimension( SequenceManager const* seqman, MBEntityHandle set, int dim, int& count, bool recursive ) const;
+ MBErrorCode num_type( SequenceManager const* seqman, MBEntityHandle set, MBEntityType type, int& count, bool recursive ) const;
+ MBErrorCode get_parents ( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& parents, int num_hops ) const;
+ MBErrorCode get_children( SequenceManager const* seqman, MBEntityHandle of, std::vector<MBEntityHandle>& children, int num_hops ) const;
+ MBErrorCode num_parents ( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
+ MBErrorCode num_children( SequenceManager const* seqman, MBEntityHandle of, int& number, int num_hops ) const;
private:
- void initialize( EntitySequenceManager* seq_man,
- const unsigned* set_flags );
+ MeshSetSequence( MeshSetSequence& split_from, MBEntityHandle split_at )
+ : EntitySequence( split_from, split_at )
+ void initialize( const unsigned* set_flags );
MBErrorCode get_parent_child_meshsets( MBEntityHandle meshset,
+ SequenceManager const* set_sequences,
int num_hops, bool parents ) const;
MBErrorCode recursive_get_sets( MBEntityHandle start_set,
std::vector<MBMeshSet*>& sets_out ) const ;
enum {
SET_SIZE = (sizeof(MBMeshSet_MBRange) > sizeof(MBMeshSet_Vector)) ?
sizeof(MBMeshSet_MBRange) : sizeof(MBMeshSet_Vector)
- unsigned char* mSets;
- inline MBEntityID& next_free( MBEntityID index )
- { return *reinterpret_cast<MBEntityID*>(mSets + SET_SIZE * index ); }
- inline MBEntityID next_free( MBEntityID index ) const
+ inline const unsigned char* array() const
+ { return reinterpret_cast<const unsigned char*>(data()->get_sequence_data(0)); }
+ inline unsigned char* array()
+ { return reinterpret_cast<unsigned char*>(data()->get_sequence_data(0)); }
inline void allocate_set( unsigned flags, MBEntityID index )
const bool tracking = (0 != (flags&MESHSET_TRACK_OWNER));
- unsigned char* const ptr = mSets + index * SET_SIZE;
+ unsigned char* const ptr = array() + index * SET_SIZE;
if (flags & MESHSET_ORDERED)
new (ptr) MBMeshSet_Vector(tracking);
else
@@ -109,7 +126,7 @@
inline void deallocate_set( MBEntityID index )
- MBMeshSet* set = reinterpret_cast<MBMeshSet*>(mSets + SET_SIZE * index );
+ MBMeshSet* set = reinterpret_cast<MBMeshSet*>(array() + SET_SIZE * index );
if (set->vector_based())
reinterpret_cast<MBMeshSet_Vector*>(set)->~MBMeshSet_Vector();
else
@@ -119,13 +136,11 @@
inline MBMeshSet* MeshSetSequence::get_set( MBEntityHandle h )
- assert(is_valid_entity(h));
- return reinterpret_cast<MBMeshSet*>(mSets + SET_SIZE*(h - get_start_handle()));
+ return reinterpret_cast<MBMeshSet*>(array() + SET_SIZE*(h - data()->start_handle()));
inline const MBMeshSet* MeshSetSequence::get_set( MBEntityHandle h ) const
+ return reinterpret_cast<const MBMeshSet*>(array() + SET_SIZE*(h - data()->start_handle()));
#endif
Deleted: MOAB/trunk/PolyEntitySequence.cpp
--- MOAB/trunk/PolyEntitySequence.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/PolyEntitySequence.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,233 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation. Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-#ifdef WIN32
-#pragma warning(disable:4786)
-#endif
-#include "EntitySequenceManager.hpp"
-#include "MBRange.hpp"
-#define CHUNK_SIZE 4096
-PolyEntitySequence::PolyEntitySequence(EntitySequenceManager* seq_manager,
- int nodes_per_element, bool all_handles_used,
- bool allocate_connect)
-: ElementEntitySequence(seq_manager, start_handle, num_entities, 0, all_handles_used, false)
- if (allocate_connect) {
- // for a poly sequence, the nodes_per_element is really the total # vertices/faces
- polyConn.reserve(nodes_per_element);
- mElements = &polyConn[0];
- mLastIndex.reserve(num_entities);
- mNodesPerElement = nodes_per_element;
-PolyEntitySequence::~PolyEntitySequence()
- // set the mElement pointer to NULL to avoid deleting in ~ElementEntitySequence
- mElements = NULL;
-MBErrorCode PolyEntitySequence::get_connectivity(MBEntityHandle entity,
- const MBEntityHandle*& conn,
- int &num_vertices,
- const bool /*topological_connectivity*/,
- std::vector<MBEntityHandle>* ) const
- MBEntityID index = entity - mStartEntityHandle;
- if (!is_valid_entity(entity))
- if (0 == index) {
- conn = &polyConn[0];
- num_vertices = mLastIndex[0]+1;
- else {
- conn = &polyConn[mLastIndex[index-1]+1];
- num_vertices = mLastIndex[index] - mLastIndex[index-1];
- std::vector<MBEntityHandle> &conn,
- const bool) const
- if (!is_valid_entity(entity)) return MB_ENTITY_NOT_FOUND;
- const MBEntityHandle *this_conn;
- int numv;
- MBErrorCode result = get_connectivity(entity, this_conn, numv);
- if (MB_SUCCESS != result) return result;
- conn.reserve(numv);
- conn.insert(conn.end(), this_conn, this_conn+numv);
-MBErrorCode PolyEntitySequence::get_connectivity_array(MBEntityHandle*& conn_array)
- conn_array = mElements;
-MBErrorCode PolyEntitySequence::get_index_array(int*& index_array)
- index_array = &mLastIndex[0];
-MBErrorCode PolyEntitySequence::add_entity(const MBEntityHandle *conn,
- const int num_conn, MBEntityHandle &handle)
- // make sure input connectivity is the right type
-#ifndef NDEBUG
- const int conn_dim = get_type() == MBPOLYGON ? 0 : 2;
- for (const MBEntityHandle *it = conn; it < conn+num_conn; it++) {
- if (MBCN::Dimension(TYPE_FROM_HANDLE(*it)) != conn_dim)
-#endif
- if (mNumEntities+mDeadEntities.size() == 0 ||
- mLastIndex[mNumEntities+mDeadEntities.size()-1]+num_conn+1 > mNumAllocated) {
- // reserve more space
- if (mNumEntities+mDeadEntities.size() == 0) {
- polyConn.reserve(CHUNK_SIZE);
- mNumAllocated = CHUNK_SIZE;
- else {
- mNumAllocated *= 2;
- polyConn.reserve(mNumAllocated);
- // need to re-assign mElements
- // check a few things: num entities agrees with index array size...
- assert(mNumEntities+mDeadEntities.size() == mLastIndex.size());
- // ... last index agrees with connectivity array size...
- assert(0 == mNumEntities+mDeadEntities.size() ||
- mLastIndex[mNumEntities+mDeadEntities.size()-1] == (int) polyConn.size()-1);
- handle = mStartEntityHandle + mNumEntities + mDeadEntities.size();
- // add the last index to the index array
- if (0 == mNumEntities+mDeadEntities.size())
- mLastIndex.push_back(num_conn-1);
- else
- mLastIndex.push_back(mLastIndex[mNumEntities+mDeadEntities.size()-1]+num_conn);
- mNumEntities++;
- mFreeEntities.swap( empty );
- mFreeEntities[handle - get_start_handle()] = false;
- // put the connectivity on the end of that array
- polyConn.insert(polyConn.end(), conn, conn+num_conn);
-MBErrorCode PolyEntitySequence::set_connectivity(MBEntityHandle entity,
- const MBEntityHandle *conn,
- const int num_vertices)
- // only works if entity is next handle to be allocated
- if (entity != mStartEntityHandle+mNumEntities+mDeadEntities.size())
- return MB_NOT_IMPLEMENTED;
- assert(TYPE_FROM_HANDLE(entity) == TYPE_FROM_HANDLE(mStartEntityHandle));
- // ok, it's the right one; just add an entity
- MBEntityHandle dum_handle;
- MBErrorCode result = add_entity(conn, num_vertices, dum_handle);
- assert(entity == dum_handle);
- return result;
-void PolyEntitySequence::get_entities(MBRange& entities) const
- entities.insert(mStartEntityHandle, mStartEntityHandle+mNumEntities+mDeadEntities.size()-1);
- for (std::vector<MBEntityHandle>::const_iterator vit = mDeadEntities.begin();
- vit != mDeadEntities.end(); vit++)
- entities.erase(*vit);
-void PolyEntitySequence::free_handle(MBEntityHandle entity)
- // add this handle to the dead list, and zero out its connectivity
- if (!is_valid_entity(entity)) return;
- int start_index;
- if (0 == index) start_index = 0;
- else start_index = mLastIndex[index-1]+1;
- for (int i = start_index; i <= mLastIndex[index]; i++)
- mElements[i] = 0;
- // now add it to the dead list
- mDeadEntities.push_back(entity);
- if (mFreeEntities.empty())
- // decrement number of entities
- mNumEntities--;
-MBEntityHandle PolyEntitySequence::get_unused_handle()
- return mNumEntities + mDeadEntities.size() + mStartEntityHandle;
-void PolyEntitySequence::get_memory_use( unsigned long& used,
- unsigned long& allocated) const
- + mFreeEntities.capacity() / 8
- + polyConn.capacity() * sizeof(MBEntityHandle)
- + mLastIndex.capacity() * sizeof(int)
- + mDeadEntities.capacity() * sizeof(MBEntityHandle)
- used = 0;
- used += get_memory_use( h );
-unsigned long PolyEntitySequence::get_memory_use( MBEntityHandle h ) const
- //MBEntityID id = h - get_start_handle();
- unsigned long result = 0;
- if (!h)
- result = mLastIndex[h];
- else if (h < mLastIndex.size())
- result = mLastIndex[h] - mLastIndex[h-1];
- return result * sizeof(MBEntityHandle) + sizeof(int);
Deleted: MOAB/trunk/PolyEntitySequence.hpp
--- MOAB/trunk/PolyEntitySequence.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/PolyEntitySequence.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,99 +0,0 @@
- * \class PolyEntitySequence
- * \authors Tim Tautges
- * \date 2/04
- * \brief PolyEntitySequence is a sequence of polygons or polyhedra
- * These entities represent connectivity as a list of
- * handles, which represent vertices for polygons, or faces for polyhedra. The
- * sequence stores the number of vertices for each entity by storing the ending
- * index for its connectivity array.
-#ifndef POLY_ENTITY_SEQUENCE_HPP
-#define POLY_ENTITY_SEQUENCE_HPP
-#ifndef IS_BUILDING_MB
-#error "PolyEntitySequence.hpp isn't supposed to be included into an application"
-#endif
-#include "EntitySequence.hpp"
-class PolyEntitySequence : public ElementEntitySequence
-public:
- PolyEntitySequence(EntitySequenceManager* seq_manager,
- bool allocate_connect = true);
- virtual ~PolyEntitySequence();
- MBEntityHandle get_unused_handle();
- virtual MBErrorCode get_connectivity(MBEntityHandle entity,
- std::vector<MBEntityHandle>& connectivity,
- const bool topological_connectivity = false) const;
- const MBEntityHandle*& connectivity,
- const bool topological_connectivity = false,
- std::vector<MBEntityHandle>* storage = 0) const;
- MBErrorCode set_connectivity(MBEntityHandle entity, const MBEntityHandle *conn,
- const int num_vertices);
- virtual MBErrorCode get_connectivity_array(MBEntityHandle*& conn_array);
- MBErrorCode get_index_array(int*& index_array);
- virtual MBErrorCode split(MBEntityHandle , MBEntitySequence*& )
- {return MB_FAILURE;}
- // reallocated the sequence to hold extra/less nodes, pass in what you want, and will return whether it needed
- // reallocate space for those nodes
- MBErrorCode convert_realloc(bool&, bool&, bool&,
- MBCore* , MBTag ) {return MB_FAILURE;}
- bool has_mid_edge_nodes() const {return false;}
- bool has_mid_face_nodes() const {return false;}
- bool has_mid_volume_nodes() const {return false;}
- MBErrorCode add_entity(const MBEntityHandle *conn,
- const int num_conn, MBEntityHandle &handle);
- //! get entities in this range, will not add unused entities
- virtual void get_entities(MBRange& entities) const;
- virtual void free_handle(MBEntityHandle entity);
- virtual void get_memory_use( unsigned long& used, unsigned long& allocated ) const;
- virtual unsigned long get_memory_use( MBEntityHandle handle ) const;
-private:
- std::vector<MBEntityHandle> polyConn;
- std::vector<int> mLastIndex;
- std::vector<MBEntityHandle> mDeadEntities;
-#endif
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ReadHDF5.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -429,7 +429,11 @@
return MB_FAILURE;
- rval = convert_id_to_handle( nodeSet, array, (size_t)(nodes_per_elem*count) );
+ if (elems.type == MBPOLYHEDRON)
+ rval = convert_id_to_handle( array, (size_t)(nodes_per_elem*count) );
+ else
+ rval = convert_id_to_handle( nodeSet, array, (size_t)(nodes_per_elem*count) );
return rval;
@@ -438,30 +442,15 @@
MBErrorCode rval;
mhdf_Status status;
char name[64];
- // Put elem set in list early so clean up code can
- // get rid of them if we fail.
- ElemSet empty_set;
- empty_set.type2 = elem_group;
- elemList.push_back( empty_set );
- std::list<ElemSet>::iterator it = elemList.end();
- --it;
- ElemSet& elems = *it;
mhdf_getElemTypeName( filePtr, elem_group, name, sizeof(name), &status );
if (mhdf_isError( &status ))
readUtil->report_error( mhdf_message( &status ) );
return MB_FAILURE;
+ MBEntityType type = MBCN::EntityTypeFromName( name );
- elems.type = MBCN::EntityTypeFromName( name );
- if (elems.type == MBMAXTYPE)
- readUtil->report_error( "Unknown element type: \"%s\".\n", name );
long count, first_id, data_len;
hid_t handles[2];
mhdf_openPolyConnectivity( filePtr, elem_group, &count, &data_len,
@@ -471,57 +460,61 @@
return MB_FAILURE;
- elems.first_id = first_id;
+ ElemSet empty_set;
+ empty_set.type = MBCN::EntityTypeFromName( name );
+ empty_set.type2 = elem_group;
- MBEntityHandle handle;
- int* index_array;
- rval = readUtil->get_poly_element_array( count, data_len, elems.type,
- first_id, readUtil->parallel_rank(),
- handle, index_array, conn_array );
- mhdf_closeData( filePtr, handles[0], &status );
- mhdf_closeData( filePtr, handles[1], &status );
- return rval;
+ MBEntityHandle h;
+ bool first = true;
+ long connend = -1;
+ std::vector<MBEntityHandle> connectivity;
+ for (long i = 0; i < count; ++i) {
+ long prevend = connend;
+ mhdf_readPolyConnIndices( handles[0], i, 1, H5T_NATIVE_LONG, &connend, &status );
+ if (mhdf_isError( &status ))
+ readUtil->report_error( mhdf_message( &status ) );
+ mhdf_closeData( filePtr, handles[0], &status );
+ mhdf_closeData( filePtr, handles[1], &status );
+ return MB_FAILURE;
+ connectivity.resize( connend - prevend );
+ mhdf_readPolyConnIDs( handles[1], prevend+1, connectivity.size(), handleType,
+ &connectivity[0], &status );
+ rval = iFace->create_element( type, &connectivity[0], connectivity.size(), h );
+ if (MB_SUCCESS != rval)
+ return rval;
+ rval= convert_id_to_handle( &connectivity[0], connectivity.size() );
+ return rval;
+ if (first || elemList.back().range.back() + 1 >= h) {
+ elemList.push_back( empty_set );
+ elemList.back().first_id = first_id + i;
+ first = false;
+ elemList.back().range.insert( h );
- elems.range.insert( handle, handle + count - 1 );
- mhdf_readPolyConnIndices( handles[0], 0, count, H5T_NATIVE_INT,
- index_array, &status );
- if (mhdf_isError( &status ))
- readUtil->report_error( mhdf_message( &status ) );
- mhdf_readPolyConnIDs( handles[1], 0, data_len, handleType,
- conn_array, &status );
- return convert_id_to_handle( conn_array, (size_t)data_len );
+ return MB_SUCCESS;
template <typename T>
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ReadVtk.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -261,32 +261,6 @@
return mdbImpl->add_entities(mCurrentMeshHandle, range);
-MBErrorCode ReadVtk::allocate_poly_elems( long num_elements,
- int connectivity_length,
- MBEntityType type,
- MBEntityHandle& start_handle_out,
- MBEntityHandle*& conn_array_out,
- int*& index_array_out,
- std::vector<MBRange>& append_to_this )
- MBErrorCode result;
- start_handle_out = 0;
- result = readMeshIface->get_poly_element_array( num_elements,
- connectivity_length,
- type,
- 0, 0,
- start_handle_out,
- index_array_out,
- conn_array_out );
- return result;
- MBRange range(start_handle_out, start_handle_out+num_elements-1);
- append_to_this.push_back( range );
- return mdbImpl->add_entities(mCurrentMeshHandle, range);
MBErrorCode ReadVtk::vtk_read_dataset( FileTokenizer& tokens,
MBRange& vertex_list,
std::vector<MBRange>& element_list )
@@ -513,23 +487,28 @@
case 0:
result = MB_FAILURE;
+ break;
case 1:
readMeshIface->report_error(
"Vertex element type at line %d",
tokens.line_number() );
+ break;
case 2:
"Unsupported type: polylines at line %d",
+ break;
case 3:
result = vtk_read_polygons( tokens, start_handle, elem_list );
+ break;
case 4:
"Unsupported type: triangle strips at line %d",
+ break;
return result;
@@ -546,32 +525,41 @@
!tokens.get_newline( ))
return MB_FAILURE;
- // Create polygons
- MBEntityHandle first_poly = 0;
- MBEntityHandle* conn_array = 0;
- int* index_array = 0;
- result = allocate_poly_elems( size[0], size[1] - size[0], MBPOLYGON,
- first_poly, conn_array, index_array,
- elem_list );
- return result;
- // Read connectivity
- int prev_index = -1;
- for (int i = 0; i < size[0]; ++i)
+ const MBRange empty;
+ std::vector<MBEntityHandle> conn_hdl;
+ std::vector<long> conn_idx;
+ MBEntityHandle first = 0, prev = 0, handle;
+ for (int i = 0; i < size[0]; ++i) {
long count;
- if (!tokens.get_long_ints( 1, &count ) ||
- !tokens.get_long_ints( count, (long*)conn_array ))
+ if (!tokens.get_long_ints( 1, &count ))
return MB_FAILURE;
+ conn_idx.resize(count);
+ conn_hdl.resize(count);
+ if (!tokens.get_long_ints( count, &conn_idx[0]))
- *index_array = ( prev_index += count );
for (long j = 0; j < count; ++j)
- *conn_array += first_vtx;
- ++conn_array;
+ conn_hdl[j] = first_vtx + conn_idx[j];
+ result = mdbImpl->create_element( MBPOLYGON, &conn_hdl[0], count, handle );
+ if (MB_SUCCESS != result)
+ return result;
+ if (prev +1 != handle) {
+ if (first) { // true except for first iteration (first == 0)
+ if (first < elem_list.back().front()) // only need new range if order would get mixed up
+ elem_list.push_back( empty );
+ elem_list.back().insert( first, prev );
+ first = handle;
+ prev = handle;
+ if (first) { // true unless no elements (size[0] == 0)
return MB_SUCCESS;
@@ -638,51 +626,41 @@
return MB_FAILURE;
MBEntityType type = VtkUtil::vtkElemTypes[vtk_type].mb_type;
- int num_vtx = VtkUtil::vtkElemTypes[vtk_type].num_nodes;
if (type == MBMAXTYPE) {
readMeshIface->report_error( "Unsupported VTK element type: %s (%d)\n",
VtkUtil::vtkElemTypes[vtk_type].name, vtk_type );
return MB_FAILURE;
+ int num_vtx = *conn_iter;
+ if (type != MBPOLYGON && num_vtx != (int)VtkUtil::vtkElemTypes[vtk_type].num_nodes) {
+ readMeshIface->report_error(
+ "Cell %ld is of type '%s' but has %u vertices.\n",
+ id, VtkUtil::vtkElemTypes[vtk_type].name, num_vtx );
// Find any subsequent elements of the same type
- long end_id = id + 1;
- while ( end_id < num_elems[0] && (unsigned)types[end_id] == vtk_type)
+ std::vector<long>::iterator conn_iter2 = conn_iter + num_vtx + 1;
+ long end_id = id + 1;
+ while ( end_id < num_elems[0] &&
+ (unsigned)types[end_id] == vtk_type &&
+ *conn_iter2 == num_vtx) {
++end_id;
+ conn_iter2 += num_vtx + 1;
// Allocate element block
long num_elem = end_id - id;
MBEntityHandle start_handle = 0;
- if (type == MBPOLYGON)
- // Calculate total length of connectivity list
- std::vector<long>::iterator conn_iter2 = conn_iter;
- long conn_len = 0;
- for (i = 0; i < num_elem; ++i)
- conn_len += *conn_iter2;
- conn_iter2 += *conn_iter2 + 1;
- // Allocate elements
- result = allocate_poly_elems( num_elem, conn_len, type, start_handle,
- conn_array, index_array, elem_list );
- else
- result = allocate_elements( num_elem, num_vtx, type, start_handle,
- conn_array, elem_list );
+ result = allocate_elements( num_elem, num_vtx, type, start_handle,
+ conn_array, elem_list );
return result;
// Store element connectivity
- int index_array_prev = -1;
for ( ; id < end_id; ++id)
if (conn_iter == connectivity.end())
@@ -692,16 +670,9 @@
return MB_FAILURE;
- // For poly elements, store end index
- if (index_array)
+ // make sure connectivity length is correct.
+ if (*conn_iter != num_vtx)
- index_array_prev += num_vtx = *conn_iter;
- *index_array = index_array_prev;
- ++index_array;
- // For non-poly elements, make sure connectivity length is correct.
- else if (*conn_iter != num_vtx)
Modified: MOAB/trunk/ReadVtk.hpp
--- MOAB/trunk/ReadVtk.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ReadVtk.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -61,14 +61,6 @@
std::vector<MBRange>& append_to_this );
- MBErrorCode allocate_poly_elems( long num_elements,
- std::vector<MBRange>& append_to_this );
MBErrorCode vtk_read_dataset( FileTokenizer& tokens,
std::vector<MBRange>& element_list );
Copied: MOAB/trunk/ScdElementData.cpp (from rev 1308, MOAB/trunk/ScdElementSeq.cpp)
--- MOAB/trunk/ScdElementData.cpp (rev 0)
+++ MOAB/trunk/ScdElementData.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,149 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#include "ScdElementData.hpp"
+#include "ScdVertexData.hpp"
+#include "MBInterface.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBCN.hpp"
+#include "MBInternals.hpp"
+#include <assert.h>
+MBEntityID ScdElementData::calc_num_entities(MBEntityHandle start_handle,
+ int irange, int jrange, int krange)
+ size_t result = 1;
+ switch (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle))) {
+ default: result = 0; assert( false );
+ case 3: result *= krange;
+ case 2: result *= jrange;
+ case 1: result *= irange;
+ return result;
+ScdElementData::ScdElementData(
+ MBEntityHandle start_handle,
+ const int imin, const int jmin, const int kmin,
+ const int imax, const int jmax, const int kmax)
+ : SequenceData(0, start_handle,
+ start_handle +
+ calc_num_entities( start_handle, imax-imin, jmax-jmin, kmax-kmin )
+ - 1)
+ // need to have meaningful parameters
+ assert(imax >= imin && jmax >= jmin && kmax >= kmin);
+ elementParams[0] = HomCoord(imin, jmin, kmin);
+ elementParams[1] = HomCoord(imax, jmax, kmax);
+ elementParams[2] = HomCoord(1, 1, 1);
+ // assign and compute parameter stuff
+ dIJK[0] = elementParams[1][0] - elementParams[0][0] + 1;
+ dIJK[1] = elementParams[1][1] - elementParams[0][1] + 1;
+ dIJK[2] = elementParams[1][2] - elementParams[0][2] + 1;
+ dIJKm1[0] = dIJK[0] - 1;
+ dIJKm1[1] = dIJK[1] - 1;
+ dIJKm1[2] = dIJK[2] - 1;
+ScdElementData::~ScdElementData()
+bool ScdElementData::boundary_complete() const
+ // test the bounding vertex sequences to see if they fully define the
+ // vertex parameter space for this rectangular block of elements
+ int p;
+ std::vector<VertexDataRef> minlist, maxlist;
+ // pseudo code:
+ // for each vertex sequence v:
+ for (std::vector<VertexDataRef>::const_iterator vseq = vertexSeqRefs.begin();
+ vseq != vertexSeqRefs.end(); vseq++)
+ // test min corner mincorner:
+ bool mincorner = true;
+ // for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1):
+ for (p = 0; p < 3; p++) {
+ // for each vsequence v' != v:
+ for (std::vector<VertexDataRef>::const_iterator othervseq = vertexSeqRefs.begin();
+ othervseq != vertexSeqRefs.end(); othervseq++)
+ if (othervseq == vseq) continue;
+ // if v.min-p contained in v'
+ if ((*othervseq).contains((*vseq).minmax[0]-HomCoord::unitv[p])) {
+ // mincorner = false
+ mincorner = false;
+ break;
+ if (!mincorner) break;
+ bool maxcorner = true;
+ // if v.max+p contained in v'
+ if ((*othervseq).contains((*vseq).minmax[1]+HomCoord::unitv[p])) {
+ // maxcorner = false
+ maxcorner = false;
+ break;
+ if (!maxcorner) break;
+ // if mincorner add to min corner list minlist
+ if (mincorner) minlist.push_back(*vseq);
+ // if maxcorner add to max corner list maxlist
+ if (maxcorner) maxlist.push_back(*vseq);
+ // if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min &
+ // maxlist[0] = esequence.max+(1,1,1)
+ if (minlist.size() == 1 && maxlist.size() == 1 &&
+ minlist[0].minmax[0] == elementParams[0] &&
+ maxlist[0].minmax[1] == elementParams[1])
+ // complete
+ return true;
+ // else
+ return false;
+SequenceData* ScdElementData::subset( MBEntityHandle /*start*/,
+ MBEntityHandle /*end*/,
+ const int* /*sequence_data_sizes*/,
+ const int* /*tag_data_sizes*/ ) const
+ return 0;
+unsigned long ScdElementData::get_memory_use() const
+ return sizeof(*this) + vertexSeqRefs.capacity() * sizeof(VertexDataRef);
Copied: MOAB/trunk/ScdElementData.hpp (from rev 1308, MOAB/trunk/ScdElementSeq.hpp)
--- MOAB/trunk/ScdElementData.hpp (rev 0)
+++ MOAB/trunk/ScdElementData.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,305 @@
+#ifndef SCD_ELEMENT_DATA_HPP
+#define SCD_ELEMENT_DATA_HPP
+// Class: ScdElementSeq
+// Purpose: represent a rectangular element of mesh
+// A ScdElement represents a rectangular element of mesh, including both vertices and
+// elements, and the parametric space used to address that element. Vertex data,
+// i.e. coordinates, may not be stored directly in the element, but the element returns
+// information about the vertex handles of vertices in the element. Vertex and element
+// handles associated with the element are each contiguous.
+#include "HomXform.hpp"
+#include "MBRange.hpp"
+#include <vector>
+#include <algorithm>
+ //! structure to hold references to bounding vertex blocks
+class VertexDataRef
+private:
+ HomCoord minmax[2];
+ HomXform xform, invXform;
+ ScdVertexData *srcSeq;
+public:
+ friend class ScdElementData;
+ VertexDataRef(const HomCoord &min, const HomCoord &max,
+ const HomXform &tmp_xform, ScdVertexData *this_seq);
+ bool contains(const HomCoord &coords) const;
+class ScdElementData : public SequenceData
+private:
+ //! parameter min/max/stride, in homogeneous coords ijkh
+ HomCoord elementParams[3];
+ //! difference between max and min params plus one (i.e. # VERTICES in
+ //! each parametric direction)
+ int dIJK[3];
+ //! difference between max and min params (i.e. # ELEMENTS in
+ int dIJKm1[3];
+ //! bare constructor, so compiler doesn't create one for me
+ ScdElementData();
+ //! list of bounding vertex blocks
+ std::vector<VertexDataRef> vertexSeqRefs;
+public:
+ //! constructor
+ ScdElementData( MBEntityHandle start_handle,
+ const int imax, const int jmax, const int kmax);
+ virtual ~ScdElementData();
+ //! get handle of vertex at homogeneous coords
+ inline MBEntityHandle get_vertex(const HomCoord &coords) const;
+ inline MBEntityHandle get_vertex(int i, int j, int k) const
+ { return get_vertex(HomCoord(i,j,k)); }
+ //! get handle of element at i, j, k
+ MBEntityHandle get_element(const int i, const int j, const int k) const;
+ //! get min params for this element
+ const HomCoord &min_params() const;
+ //! get max params for this element
+ const HomCoord &max_params() const;
+ //! get the number of vertices in each direction, inclusive
+ void param_extents(int &di, int &dj, int &dk) const;
+ //! given a handle, get the corresponding parameters
+ MBErrorCode get_params(const MBEntityHandle ehandle,
+ int &i, int &j, int &k) const;
+ //! convenience functions for parameter extents
+ int i_min() const {return (elementParams[0].hom_coord())[0];}
+ int j_min() const {return (elementParams[0].hom_coord())[1];}
+ int k_min() const {return (elementParams[0].hom_coord())[2];}
+ int i_max() const {return (elementParams[1].hom_coord())[0];}
+ int j_max() const {return (elementParams[1].hom_coord())[1];}
+ int k_max() const {return (elementParams[1].hom_coord())[2];}
+ //! test the bounding vertex sequences and determine whether they fully
+ //! define the vertices covering this element block's parameter space
+ bool boundary_complete() const;
+ //! test whether this sequence contains these parameters
+ inline bool contains(const HomCoord &coords) const;
+ //! get connectivity of an entity given entity's parameters
+ inline MBErrorCode get_params_connectivity(const int i, const int j, const int k,
+ std::vector<MBEntityHandle>& connectivity) const;
+ //! add a vertex seq ref to this element sequence;
+ //! if bb_input is true, bounding box (in eseq-local coords) of vseq being added
+ //! is input in bb_min and bb_max (allows partial sharing of vseq rather than the whole
+ //! vseq); if it's false, the whole vseq is referenced and the eseq-local coordinates
+ //! is computed from the transformed bounding box of the vseq
+ MBErrorCode add_vsequence(ScdVertexData *vseq,
+ const HomCoord &p1, const HomCoord &q1,
+ const HomCoord &p2, const HomCoord &q2,
+ const HomCoord &p3, const HomCoord &q3,
+ bool bb_input = false,
+ const HomCoord &bb_min = HomCoord::unitv[0],
+ const HomCoord &bb_max = HomCoord::unitv[0]);
+ SequenceData* subset( MBEntityHandle start,
+ MBEntityHandle end,
+ const int* sequence_data_sizes,
+ const int* tag_data_sizes ) const;
+ static MBEntityID calc_num_entities( MBEntityHandle start_handle,
+ int irange,
+ int jrange,
+ int krange );
+ unsigned long get_memory_use() const;
+inline MBEntityHandle ScdElementData::get_element(const int i, const int j, const int k) const
+ return start_handle() + (i-i_min()) + (j-j_min())*dIJKm1[0] + (k-k_min())*dIJKm1[0]*dIJKm1[1];
+inline const HomCoord &ScdElementData::min_params() const
+ return elementParams[0];
+inline const HomCoord &ScdElementData::max_params() const
+ return elementParams[1];
+inline void ScdElementData::param_extents(int &di, int &dj, int &dk) const
+ di = dIJK[0];
+ dj = dIJK[1];
+ dk = dIJK[2];
+inline MBErrorCode ScdElementData::get_params(const MBEntityHandle ehandle,
+ if (TYPE_FROM_HANDLE(ehandle) != TYPE_FROM_HANDLE(start_handle())) return MB_FAILURE;
+ int hdiff = ehandle - start_handle();
+ // use double ?: test below because on some platforms, both sides of the : are
+ // evaluated, and if dIJKm1[1] is zero, that'll generate a divide-by-zero
+ k = (dIJKm1[1] > 0 ? hdiff / (dIJKm1[1] > 0 ? dIJKm1[0]*dIJKm1[1] : 1) : 0);
+ j = (hdiff - (k*dIJKm1[0]*dIJKm1[1])) / dIJKm1[0];
+ i = hdiff % dIJKm1[0];
+ k += elementParams[0].k();
+ j += elementParams[0].j();
+ i += elementParams[0].i();
+ return (ehandle >= start_handle() &&
+ ehandle < start_handle()+size() &&
+ i >= i_min() && i <= i_max() &&
+ j >= j_min() && j <= j_max() &&
+ k >= k_min() && k <= k_max()) ? MB_SUCCESS : MB_FAILURE;
+inline bool ScdElementData::contains(const HomCoord &temp) const
+ // upper bound is < instead of <= because element params max is one less
+ // than vertex params max
+ return (temp >= elementParams[0] && temp < elementParams[1]);
+inline bool VertexDataRef::contains(const HomCoord &coords) const
+ return (minmax[0] <= coords && minmax[1] >= coords);
+inline VertexDataRef::VertexDataRef(const HomCoord &this_min, const HomCoord &this_max,
+ : xform(tmp_xform), invXform(tmp_xform.inverse()), srcSeq(this_seq)
+ minmax[0] = HomCoord(this_min);
+ minmax[1] = HomCoord(this_max);
+inline MBEntityHandle ScdElementData::get_vertex(const HomCoord &coords) const
+ for (std::vector<VertexDataRef>::const_iterator it = vertexSeqRefs.begin();
+ it != vertexSeqRefs.end(); it++) {
+ if ((*it).minmax[0] <= coords && (*it).minmax[1] >= coords) {
+ // first get the vertex block-local parameters
+ HomCoord local_coords = coords / (*it).xform;
+ // now get the vertex handle for those coords
+ return (*it).srcSeq->get_vertex(local_coords);
+ // got here, it's an error
+ return 0;
+inline MBErrorCode ScdElementData::add_vsequence(ScdVertexData *vseq,
+ bool bb_input,
+ const HomCoord &bb_min,
+ const HomCoord &bb_max)
+ // compute the transform given the vseq-local parameters and the mapping to
+ // this element sequence's parameters passed in minmax
+ HomXform M;
+ M.three_pt_xform(p1, q1, p2, q2, p3, q3);
+ // min and max in element seq's parameter system may not be same as those in
+ // vseq's system, so need to take min/max
+ if (bb_input) {
+ minmax[0] = bb_min;
+ minmax[1] = bb_max;
+ else {
+ minmax[0] = vseq->min_params() * M;
+ minmax[1] = vseq->max_params() * M;
+ // check against other vseq's to make sure they don't overlap
+ for (std::vector<VertexDataRef>::const_iterator vsit = vertexSeqRefs.begin();
+ vsit != vertexSeqRefs.end(); vsit++)
+ if ((*vsit).contains(minmax[0]) || (*vsit).contains(minmax[1]))
+ HomCoord tmp_min(std::min(minmax[0].i(), minmax[1].i()),
+ std::min(minmax[0].j(), minmax[1].j()),
+ std::min(minmax[0].k(), minmax[1].k()));
+ HomCoord tmp_max(std::max(minmax[0].i(), minmax[1].i()),
+ std::max(minmax[0].j(), minmax[1].j()),
+ std::max(minmax[0].k(), minmax[1].k()));
+ // set up a new vertex sequence reference
+ VertexDataRef tmp_seq_ref(tmp_min, tmp_max, M, vseq);
+ // add to the list
+ vertexSeqRefs.push_back(tmp_seq_ref);
+inline MBErrorCode ScdElementData::get_params_connectivity(const int i, const int j, const int k,
+ if (contains(HomCoord(i, j, k)) == false) return MB_FAILURE;
+ connectivity.push_back(get_vertex(i, j, k));
+ connectivity.push_back(get_vertex(i+1, j, k));
+ if (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle())) < 2) return MB_SUCCESS;
+ connectivity.push_back(get_vertex(i+1, j+1, k));
+ connectivity.push_back(get_vertex(i, j+1, k));
+ if (MBCN::Dimension(TYPE_FROM_HANDLE(start_handle())) < 3) return MB_SUCCESS;
+ connectivity.push_back(get_vertex(i, j, k+1));
+ connectivity.push_back(get_vertex(i+1, j, k+1));
+ connectivity.push_back(get_vertex(i+1, j+1, k+1));
+ connectivity.push_back(get_vertex(i, j+1, k+1));
+#endif
Deleted: MOAB/trunk/ScdElementSeq.cpp
--- MOAB/trunk/ScdElementSeq.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ScdElementSeq.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,146 +0,0 @@
-#include "ScdElementSeq.hpp"
-#include "ScdVertexSeq.hpp"
-#include "MBInterface.hpp"
-#include "MBReadUtilIface.hpp"
-#include "MBCN.hpp"
-#include "MBInternals.hpp"
-ScdElementSeq::ScdElementSeq(EntitySequenceManager *seq_mgr,
- const int imin, const int jmin, const int kmin,
- const int imax, const int jmax, const int kmax)
- : ElementEntitySequence(seq_mgr, start_handle,
- (imax-imin)*(jmax-jmin)*(kmax-kmin),
- MBCN::VerticesPerEntity(TYPE_FROM_HANDLE(start_handle)),
- true, false)
- // need to have meaningful parameters
- assert(imax >= imin && jmax >= jmin && kmax >= kmin);
- // correct num entities if necessary
- if (mNumEntities == 0) {
- int this_dim = MBCN::Dimension(TYPE_FROM_HANDLE(start_handle));
- if (this_dim == 1) mNumEntities = imax - imin;
- else if (this_dim == 2) mNumEntities = (imax - imin)*(jmax - jmin);
- // if neither of the previous two tests passed, it's an error
- else assert(false);
- assert(mNumEntities > 0);
- elementParams[0] = HomCoord(imin, jmin, kmin);
- elementParams[1] = HomCoord(imax, jmax, kmax);
- elementParams[2] = HomCoord(1, 1, 1);
- // assign and compute parameter stuff
- dIJK[0] = elementParams[1][0] - elementParams[0][0] + 1;
- dIJK[1] = elementParams[1][1] - elementParams[0][1] + 1;
- dIJK[2] = elementParams[1][2] - elementParams[0][2] + 1;
- dIJKm1[0] = dIJK[0] - 1;
- dIJKm1[1] = dIJK[1] - 1;
- dIJKm1[2] = dIJK[2] - 1;
-ScdElementSeq::~ScdElementSeq()
-bool ScdElementSeq::boundary_complete() const
- // test the bounding vertex sequences to see if they fully define the
- // vertex parameter space for this rectangular block of elements
- int p;
- std::vector<VertexSeqRef> minlist, maxlist;
- // pseudo code:
- // for each vertex sequence v:
- for (std::vector<VertexSeqRef>::const_iterator vseq = vertexSeqRefs.begin();
- vseq != vertexSeqRefs.end(); vseq++)
- // test min corner mincorner:
- bool mincorner = true;
- // for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1):
- for (p = 0; p < 3; p++) {
- // for each vsequence v' != v:
- for (std::vector<VertexSeqRef>::const_iterator othervseq = vertexSeqRefs.begin();
- othervseq != vertexSeqRefs.end(); othervseq++)
- if (othervseq == vseq) continue;
- // if v.min-p contained in v'
- if ((*othervseq).contains((*vseq).minmax[0]-HomCoord::unitv[p])) {
- // mincorner = false
- mincorner = false;
- break;
- if (!mincorner) break;
- bool maxcorner = true;
- // if v.max+p contained in v'
- if ((*othervseq).contains((*vseq).minmax[1]+HomCoord::unitv[p])) {
- // maxcorner = false
- maxcorner = false;
- break;
- if (!maxcorner) break;
- // if mincorner add to min corner list minlist
- if (mincorner) minlist.push_back(*vseq);
- // if maxcorner add to max corner list maxlist
- if (maxcorner) maxlist.push_back(*vseq);
- // if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min &
- // maxlist[0] = esequence.max+(1,1,1)
- if (minlist.size() == 1 && maxlist.size() == 1 &&
- minlist[0].minmax[0] == elementParams[0] &&
- maxlist[0].minmax[1] == elementParams[1])
- // complete
- return true;
- // else
- return false;
-void ScdElementSeq::get_memory_use( unsigned long& used,
- allocated = used = sizeof(*this) + sizeof(VertexSeqRef) * vertexSeqRefs.capacity();
-unsigned long ScdElementSeq::get_memory_use( MBEntityHandle ) const
- return 0;
Deleted: MOAB/trunk/ScdElementSeq.hpp
--- MOAB/trunk/ScdElementSeq.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ScdElementSeq.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,431 +0,0 @@
-#ifndef SCDELEMENTSEQ
-#define SCDELEMENTSEQ
-// Class: ScdElementSeq
-// Purpose: represent a rectangular element of mesh
-// A ScdElement represents a rectangular element of mesh, including both vertices and
-// elements, and the parametric space used to address that element. Vertex data,
-// i.e. coordinates, may not be stored directly in the element, but the element returns
-// information about the vertex handles of vertices in the element. Vertex and element
-// handles associated with the element are each contiguous.
-#include "HomXform.hpp"
-#include <vector>
- //! structure to hold references to bounding vertex blocks
-class VertexSeqRef
-private:
- HomCoord minmax[2];
- HomXform xform, invXform;
- ScdVertexSeq *srcSeq;
-public:
- friend class ScdElementSeq;
- VertexSeqRef(const HomCoord &min, const HomCoord &max,
- const HomXform &tmp_xform, ScdVertexSeq *this_seq);
- bool contains(const HomCoord &coords) const;
-class ScdElementSeq : public ElementEntitySequence
-private:
- //! parameter min/max/stride, in homogeneous coords ijkh
- HomCoord elementParams[3];
- //! difference between max and min params plus one (i.e. # VERTICES in
- //! each parametric direction)
- int dIJK[3];
- //! difference between max and min params (i.e. # ELEMENTS in
- int dIJKm1[3];
- //! bare constructor, so compiler doesn't create one for me
- ScdElementSeq();
- //! list of bounding vertex blocks
- std::vector<VertexSeqRef> vertexSeqRefs;
-public:
- //! constructor
- ScdElementSeq(EntitySequenceManager *seq_mgr,
- const int imax, const int jmax, const int kmax);
- virtual ~ScdElementSeq();
- //! get handle of vertex at i, j, k
- MBEntityHandle get_vertex(const int i, const int j, const int k) const;
- //! get handle of vertex at homogeneous coords
- inline MBEntityHandle get_vertex(const HomCoord &coords) const;
- //! get handle of element at i, j, k
- MBEntityHandle get_element(const int i, const int j, const int k) const;
- //! get handle of element at homogeneous coords
- MBEntityHandle get_element(const HomCoord &coords) const;
- //! get min params for this element
- void min_params(HomCoord &coords) const;
- void min_params(int &i, int &j, int &k) const;
- const HomCoord &min_params() const;
- //! get max params for this element
- void max_params(HomCoord &coords) const;
- void max_params(int &i, int &j, int &k) const;
- const HomCoord &max_params() const;
- //! get the number of vertices in each direction, inclusive
- void param_extents(int &di, int &dj, int &dk) const;
- //! given a handle, get the corresponding parameters
- MBErrorCode get_params(const MBEntityHandle ehandle,
- int &i, int &j, int &k) const;
- //! convenience functions for parameter extents
- int i_min() const {return (elementParams[0].hom_coord())[0];}
- int j_min() const {return (elementParams[0].hom_coord())[1];}
- int k_min() const {return (elementParams[0].hom_coord())[2];}
- int i_max() const {return (elementParams[1].hom_coord())[0];}
- int j_max() const {return (elementParams[1].hom_coord())[1];}
- int k_max() const {return (elementParams[1].hom_coord())[2];}
- //! test the bounding vertex sequences and determine whether they fully
- //! define the vertices covering this element block's parameter space
- bool boundary_complete() const;
- //! test whether this sequence contains these parameters
- bool contains(const int i, const int j, const int k) const;
- inline bool contains(const HomCoord &coords) const;
- // from parent class
- std::vector<MBEntityHandle>* stroage = 0) const;
- //! get connectivity of an entity given entity's parameters
- inline MBErrorCode get_params_connectivity(const int i, const int j, const int k,
- std::vector<MBEntityHandle>& connectivity) const;
- //! add a vertex seq ref to this element sequence;
- //! if bb_input is true, bounding box (in eseq-local coords) of vseq being added
- //! is input in bb_min and bb_max (allows partial sharing of vseq rather than the whole
- //! vseq); if it's false, the whole vseq is referenced and the eseq-local coordinates
- //! is computed from the transformed bounding box of the vseq
- MBErrorCode add_vsequence(ScdVertexSeq *vseq,
- const HomCoord &p1, const HomCoord &q1,
- const HomCoord &p2, const HomCoord &q2,
- const HomCoord &p3, const HomCoord &q3,
- bool bb_input = false,
- const HomCoord &bb_min = HomCoord::unitv[0],
- const HomCoord &bb_max = HomCoord::unitv[0]);
- virtual MBErrorCode set_connectivity(MBEntityHandle entity, const MBEntityHandle *conn,
- virtual void get_entities(MBRange& ) const;
- MBEntitySequence*& );
- virtual MBErrorCode convert_realloc(bool& , bool& , bool& ,
- MBCore*, MBTag );
- virtual unsigned long get_memory_use( MBEntityHandle h ) const;
-inline MBEntityHandle ScdElementSeq::get_element(const int i, const int j, const int k) const
- return mStartEntityHandle + (i-i_min()) + (j-j_min())*dIJKm1[0] + (k-k_min())*dIJKm1[0]*dIJKm1[1];
-inline MBEntityHandle ScdElementSeq::get_element(const HomCoord &coord) const
- return get_element(coord.i(), coord.j(), coord.k());
-inline void ScdElementSeq::min_params(HomCoord &coords) const
- coords = elementParams[0];
-inline void ScdElementSeq::min_params(int &i, int &j, int &k) const
- i = elementParams[0].i();
- j = elementParams[0].j();
- k = elementParams[0].k();
-inline const HomCoord &ScdElementSeq::min_params() const
- return elementParams[0];
-//! get max params for this element
-inline void ScdElementSeq::max_params(HomCoord &coords) const
- coords = elementParams[1];
-inline void ScdElementSeq::max_params(int &i, int &j, int &k) const
- i = elementParams[1].i();
- j = elementParams[1].j();
- k = elementParams[1].k();
-inline const HomCoord &ScdElementSeq::max_params() const
- return elementParams[1];
-inline void ScdElementSeq::param_extents(int &di, int &dj, int &dk) const
- di = dIJK[0];
- dj = dIJK[1];
- dk = dIJK[2];
-inline MBErrorCode ScdElementSeq::get_params(const MBEntityHandle ehandle,
- if (TYPE_FROM_HANDLE(ehandle) != TYPE_FROM_HANDLE(mStartEntityHandle)) return MB_FAILURE;
- int hdiff = ehandle - mStartEntityHandle;
- // use double ?: test below because on some platforms, both sides of the : are
- // evaluated, and if dIJKm1[1] is zero, that'll generate a divide-by-zero
- k = (dIJKm1[1] > 0 ? hdiff / (dIJKm1[1] > 0 ? dIJKm1[0]*dIJKm1[1] : 1) : 0);
- j = (hdiff - (k*dIJKm1[0]*dIJKm1[1])) / dIJKm1[0];
- i = hdiff % dIJKm1[0];
- k += elementParams[0].k();
- j += elementParams[0].j();
- i += elementParams[0].i();
- return (ehandle >= mStartEntityHandle &&
- ehandle < mStartEntityHandle+number_entities() &&
- i >= i_min() && i <= i_max() &&
- j >= j_min() && j <= j_max() &&
- k >= k_min() && k <= k_max()) ? MB_SUCCESS : MB_FAILURE;
-inline bool ScdElementSeq::contains(const int i, const int j, const int k) const
- return contains(HomCoord(i, j, k));
-inline bool ScdElementSeq::contains(const HomCoord &temp) const
- // upper bound is < instead of <= because element params max is one less
- // than vertex params max
- return (temp >= elementParams[0] && temp < elementParams[1]);
-inline MBEntityHandle ScdElementSeq::get_vertex(const int i, const int j, const int k) const
- return get_vertex(HomCoord(i,j,k));
-inline MBEntityHandle ScdElementSeq::get_unused_handle()
- return MB_FAILURE;
-inline MBErrorCode ScdElementSeq::set_connectivity(MBEntityHandle ,
- const MBEntityHandle *,
- const int )
-inline void ScdElementSeq::get_entities(MBRange& range) const
- range.insert(mStartEntityHandle, mStartEntityHandle+mNumEntities-1);
-inline MBErrorCode ScdElementSeq::split(MBEntityHandle ,
- // and will return whether it needed
-inline MBErrorCode ScdElementSeq::convert_realloc(bool& , bool& , bool& ,
- MBCore*, MBTag )
-inline bool VertexSeqRef::contains(const HomCoord &coords) const
- return (minmax[0] <= coords && minmax[1] >= coords);
-inline VertexSeqRef::VertexSeqRef(const HomCoord &this_min, const HomCoord &this_max,
- : xform(tmp_xform), invXform(tmp_xform.inverse()), srcSeq(this_seq)
- minmax[0] = HomCoord(this_min);
- minmax[1] = HomCoord(this_max);
-inline MBErrorCode ScdElementSeq::get_connectivity(MBEntityHandle entity,
- const bool) const
- // get parameter values
- int i, j, k;
- MBErrorCode result = get_params(entity, i, j, k);
- return get_params_connectivity(i, j, k, connectivity);
-inline MBErrorCode ScdElementSeq::get_connectivity(MBEntityHandle handle,
- int &len,
- const bool topo,
- std::vector<MBEntityHandle>* storage) const
- if (!storage)
- MBErrorCode result = get_connectivity( handle, *storage, topo );
- conn = &(*storage)[0];
- len = storage->size();
- return result;
-inline MBEntityHandle ScdElementSeq::get_vertex(const HomCoord &coords) const
- for (std::vector<VertexSeqRef>::const_iterator it = vertexSeqRefs.begin();
- it != vertexSeqRefs.end(); it++) {
- if ((*it).minmax[0] <= coords && (*it).minmax[1] >= coords) {
- // first get the vertex block-local parameters
- HomCoord local_coords = coords / (*it).xform;
- // now get the vertex handle for those coords
- return (*it).srcSeq->get_vertex(local_coords);
- // got here, it's an error
- return 0;
-inline MBErrorCode ScdElementSeq::add_vsequence(ScdVertexSeq *vseq,
- bool bb_input,
- const HomCoord &bb_min,
- const HomCoord &bb_max)
- // compute the transform given the vseq-local parameters and the mapping to
- // this element sequence's parameters passed in minmax
- HomXform M;
- M.three_pt_xform(p1, q1, p2, q2, p3, q3);
- // min and max in element seq's parameter system may not be same as those in
- // vseq's system, so need to take min/max
- if (bb_input) {
- minmax[0] = bb_min;
- minmax[1] = bb_max;
- else {
- minmax[0] = vseq->min_params() * M;
- minmax[1] = vseq->max_params() * M;
- // check against other vseq's to make sure they don't overlap
- for (std::vector<VertexSeqRef>::const_iterator vsit = vertexSeqRefs.begin();
- vsit != vertexSeqRefs.end(); vsit++)
- if ((*vsit).contains(minmax[0]) || (*vsit).contains(minmax[1]))
-#define MIN(a,b) ((a <= b) ? a : b)
-#define MAX(a,b) ((a >= b) ? a : b)
- HomCoord tmp_min(MIN(minmax[0].i(), minmax[1].i()),
- MIN(minmax[0].j(), minmax[1].j()),
- MIN(minmax[0].k(), minmax[1].k()));
- HomCoord tmp_max(MAX(minmax[0].i(), minmax[1].i()),
- MAX(minmax[0].j(), minmax[1].j()),
- MAX(minmax[0].k(), minmax[1].k()));
- // set up a new vertex sequence reference
- VertexSeqRef tmp_seq_ref(tmp_min, tmp_max, M, vseq);
- // add to the list
- vertexSeqRefs.push_back(tmp_seq_ref);
- return MB_SUCCESS;
-inline MBErrorCode ScdElementSeq::get_params_connectivity(const int i, const int j, const int k,
- if (contains(i, j, k) == false) return MB_FAILURE;
- connectivity.push_back(get_vertex(i, j, k));
- connectivity.push_back(get_vertex(i+1, j, k));
- if (MBCN::Dimension(get_type()) < 2) return MB_SUCCESS;
- connectivity.push_back(get_vertex(i+1, j+1, k));
- connectivity.push_back(get_vertex(i, j+1, k));
- if (MBCN::Dimension(get_type()) < 3) return MB_SUCCESS;
- connectivity.push_back(get_vertex(i, j, k+1));
- connectivity.push_back(get_vertex(i+1, j, k+1));
- connectivity.push_back(get_vertex(i+1, j+1, k+1));
- connectivity.push_back(get_vertex(i, j+1, k+1));
-#endif
Copied: MOAB/trunk/ScdVertexData.cpp (from rev 1308, MOAB/trunk/ScdVertexSeq.cpp)
--- MOAB/trunk/ScdVertexData.cpp (rev 0)
+++ MOAB/trunk/ScdVertexData.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,49 @@
+ //! constructor
+ScdVertexData::ScdVertexData(const MBEntityHandle start_vertex,
+ : SequenceData( 3, start_vertex,
+ start_vertex + (imax-imin+1)*(jmax-jmin+1)*(kmax-kmin+1) - 1 )
+ vertexParams[0] = HomCoord(imin, jmin, kmin);
+ vertexParams[1] = HomCoord(imax, jmax, kmax);
+ vertexParams[2] = HomCoord(1,1,1);
+ dIJK[0] = imax-imin+1; dIJK[1] = jmax-jmin+1; dIJK[2] = kmax-kmin+1;
+ dIJKm1[0] = dIJK[0]-1;
+ dIJKm1[1] = dIJK[1]-1;
+ dIJKm1[2] = dIJK[2]-1;
+ create_sequence_data( 0, sizeof(double) );
+ create_sequence_data( 1, sizeof(double) );
+ create_sequence_data( 2, sizeof(double) );
+SequenceData* ScdVertexData::subset( MBEntityHandle /*start*/,
+ return 0;
Copied: MOAB/trunk/ScdVertexData.hpp (from rev 1308, MOAB/trunk/ScdVertexSeq.hpp)
--- MOAB/trunk/ScdVertexData.hpp (rev 0)
+++ MOAB/trunk/ScdVertexData.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,176 @@
+#ifndef SCD_VERTEX_DATA_HPP
+#define SCD_VERTEX_DATA_HPP
+// Class: ScdVertexData
+// Purpose: represent a rectangular vertex block of mesh
+// A ScdVertex represents a rectangular vertex block of mesh, including both vertices and
+// the parametric space used to address those vertices.
+class ScdVertexData : public SequenceData
+private:
+ //! parameter min/max, in homogeneous coords ijkh (extra row for stride eventually)
+ HomCoord vertexParams[3];
+ int dIJK[3];
+ //! difference between max and min params (i.e. # VERTEXS in
+ int dIJKm1[3];
+public:
+ //! constructor
+ ScdVertexData(const MBEntityHandle start_vertex,
+ const int imax, const int jmax, const int kmax) ;
+ virtual ~ScdVertexData() {};
+ //! get handle of vertex at i, j, k
+ MBEntityHandle get_vertex(const int i, const int j, const int k) const;
+ //! get handle of vertex at homogeneous coordinates
+ MBEntityHandle get_vertex(const HomCoord &coords) const;
+ //! get the parameters of a given handle; return MB_FAILURE if vhandle not in this
+ //! sequence
+ MBErrorCode get_params(const MBEntityHandle vhandle,
+ //! get min params for this vertex
+ void min_params(int &i, int &j, int &k) const;
+ //! get max params for this vertex
+ void max_params(int &i, int &j, int &k) const;
+ //! get the min params
+ //! get the max params
+ int i_min() const {return vertexParams[0].hom_coord()[0];}
+ int j_min() const {return vertexParams[0].hom_coord()[1];}
+ int k_min() const {return vertexParams[0].hom_coord()[2];}
+ int i_max() const {return vertexParams[1].hom_coord()[0];}
+ int j_max() const {return vertexParams[1].hom_coord()[1];}
+ int k_max() const {return vertexParams[1].hom_coord()[2];}
+ //! return whether this vseq's parameter space contains these parameters
+ bool contains(const int i, const int j, const int k) const;
+inline MBEntityHandle ScdVertexData::get_vertex(const int i, const int j,
+ const int k) const
+ return start_handle() + (i-i_min()) + (j-j_min())*dIJK[0] +
+ (k-k_min())*dIJK[0]*dIJK[1];
+inline MBEntityHandle ScdVertexData::get_vertex(const HomCoord &coords) const
+ return get_vertex(coords.hom_coord()[0], coords.hom_coord()[1], coords.hom_coord()[2]);
+inline MBErrorCode ScdVertexData::get_params(const MBEntityHandle vhandle,
+ if (TYPE_FROM_HANDLE(vhandle) != MBVERTEX) return MB_FAILURE;
+ int hdiff = vhandle - start_handle();
+ k = hdiff / (dIJK[0]*dIJK[1]);
+ j = (hdiff - (k*dIJK[0]*dIJK[1])) / dIJK[0];
+ i = hdiff % dIJK[0];
+ k += vertexParams[0].k();
+ j += vertexParams[0].j();
+ i += vertexParams[0].i();
+ return (vhandle >= start_handle() &&
+inline void ScdVertexData::min_params(int &i, int &j, int &k) const
+ i = i_min();
+ j = j_min();
+ k = k_min();
+//! get max params for this vertex
+inline void ScdVertexData::max_params(int &i, int &j, int &k) const
+ i = i_max();
+ j = j_max();
+ k = k_max();
+inline const HomCoord &ScdVertexData::min_params() const
+ return vertexParams[0];
+inline const HomCoord &ScdVertexData::max_params() const
+ return vertexParams[1];
+inline void ScdVertexData::param_extents(int &di, int &dj, int &dk) const
+ di = dIJK[0];
+ dj = dIJK[1];
+ dk = dIJK[2];
+inline bool ScdVertexData::contains(const HomCoord &coords) const
+ return (coords >= vertexParams[0] && coords <= vertexParams[1]) ? true : false;
+inline bool ScdVertexData::contains(const int i, const int j, const int k) const
+ return contains(HomCoord(i, j, k));
+#endif
Deleted: MOAB/trunk/ScdVertexSeq.cpp
--- MOAB/trunk/ScdVertexSeq.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ScdVertexSeq.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,52 +0,0 @@
- //! constructor
-ScdVertexSeq::ScdVertexSeq(EntitySequenceManager* seq_mgr,
- const MBEntityHandle start_vertex,
- : VertexEntitySequence(seq_mgr, start_vertex,
- (imax-imin+1)*(jmax-jmin+1)*(kmax-kmin+1),
- true)
- vertexParams[0] = HomCoord(imin, jmin, kmin);
- vertexParams[1] = HomCoord(imax, jmax, kmax);
- vertexParams[2] = HomCoord(1,1,1);
- dIJK[0] = imax-imin+1; dIJK[1] = jmax-jmin+1; dIJK[2] = kmax-kmin+1;
- dIJKm1[0] = dIJK[0]-1;
- dIJKm1[1] = dIJK[1]-1;
- dIJKm1[2] = dIJK[2]-1;
-MBEntityHandle ScdVertexSeq::get_unused_handle()
- assert(false);
- return 0;
-void ScdVertexSeq::get_memory_use( unsigned long& used,
- VertexEntitySequence::get_memory_use( used, allocated );
- allocated += sizeof(*this) - sizeof(VertexEntitySequence);
Deleted: MOAB/trunk/ScdVertexSeq.hpp
--- MOAB/trunk/ScdVertexSeq.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/ScdVertexSeq.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -1,176 +0,0 @@
-#ifndef SCDVERTEXSEQ
-#define SCDVERTEXSEQ
-// Class: ScdVertexSeq
-// Purpose: represent a rectangular vertex block of mesh
-// A ScdVertex represents a rectangular vertex block of mesh, including both vertices and
-// the parametric space used to address those vertices.
-class ScdVertexSeq : public VertexEntitySequence
-private:
- //! parameter min/max, in homogeneous coords ijkh (extra row for stride eventually)
- HomCoord vertexParams[3];
- int dIJK[3];
- //! difference between max and min params (i.e. # VERTEXS in
- int dIJKm1[3];
-public:
- //! constructor
- ScdVertexSeq(EntitySequenceManager* seq_mgr,
- const int imax, const int jmax, const int kmax) ;
- virtual ~ScdVertexSeq() {};
- //! get handle of vertex at homogeneous coordinates
- MBEntityHandle get_vertex(const HomCoord &coords) const;
- //! get the parameters of a given handle; return MB_FAILURE if vhandle not in this
- //! sequence
- MBErrorCode get_params(const MBEntityHandle vhandle,
- //! get min params for this vertex
- //! get max params for this vertex
- //! get the min params
- //! get the max params
- int i_min() const {return vertexParams[0].hom_coord()[0];}
- int j_min() const {return vertexParams[0].hom_coord()[1];}
- int k_min() const {return vertexParams[0].hom_coord()[2];}
- int i_max() const {return vertexParams[1].hom_coord()[0];}
- int j_max() const {return vertexParams[1].hom_coord()[1];}
- int k_max() const {return vertexParams[1].hom_coord()[2];}
- //! return whether this vseq's parameter space contains these parameters
-inline MBEntityHandle ScdVertexSeq::get_vertex(const int i, const int j,
- const int k) const
- return mStartEntityHandle + (i-i_min()) + (j-j_min())*dIJK[0] +
- (k-k_min())*dIJK[0]*dIJK[1];
-inline MBEntityHandle ScdVertexSeq::get_vertex(const HomCoord &coords) const
- return get_vertex(coords.hom_coord()[0], coords.hom_coord()[1], coords.hom_coord()[2]);
-inline MBErrorCode ScdVertexSeq::get_params(const MBEntityHandle vhandle,
- if (TYPE_FROM_HANDLE(vhandle) != MBVERTEX) return MB_FAILURE;
- int hdiff = vhandle - mStartEntityHandle;
- k = hdiff / (dIJK[0]*dIJK[1]);
- j = (hdiff - (k*dIJK[0]*dIJK[1])) / dIJK[0];
- i = hdiff % dIJK[0];
- k += vertexParams[0].k();
- j += vertexParams[0].j();
- i += vertexParams[0].i();
- return (vhandle >= mStartEntityHandle &&
-inline void ScdVertexSeq::min_params(int &i, int &j, int &k) const
- i = i_min();
- j = j_min();
- k = k_min();
-//! get max params for this vertex
-inline void ScdVertexSeq::max_params(int &i, int &j, int &k) const
- i = i_max();
- j = j_max();
- k = k_max();
-inline const HomCoord &ScdVertexSeq::min_params() const
- return vertexParams[0];
-inline const HomCoord &ScdVertexSeq::max_params() const
- return vertexParams[1];
-inline void ScdVertexSeq::param_extents(int &di, int &dj, int &dk) const
- di = dIJK[0];
- dj = dIJK[1];
- dk = dIJK[2];
-inline bool ScdVertexSeq::contains(const HomCoord &coords) const
- return (coords >= vertexParams[0] && coords <= vertexParams[1]) ? true : false;
-inline bool ScdVertexSeq::contains(const int i, const int j, const int k) const
-#endif
Added: MOAB/trunk/SequenceData.cpp
--- MOAB/trunk/SequenceData.cpp (rev 0)
+++ MOAB/trunk/SequenceData.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,129 @@
+#include "SequenceData.hpp"
+SequenceData::~SequenceData()
+ for (int i = -numSequenceData; i <= numTagData; ++i)
+ free( arraySet[i] );
+ free( arraySet - numSequenceData );
+void* SequenceData::create_data( int index, int bytes_per_ent, void* initial_value )
+ char* array = (char*)malloc( bytes_per_ent * size() );
+ if (initial_value) {
+ memcpy( array, initial_value, bytes_per_ent );
+ const size_t last = size() / 2;
+ size_t count;
+ for (count = 1; count < last; count *= 2)
+ memcpy( array + count * bytes_per_ent, array, count * bytes_per_ent );
+ memcpy( array + count * bytes_per_ent, array, (size() - count) * bytes_per_ent );
+ else {
+ memset( array, 0, bytes_per_ent * size() );
+ arraySet[index] = array;
+ return array;
+void* SequenceData::create_sequence_data( int array_num,
+ int bytes_per_ent,
+ void* initial_value )
+ const int index = -1 - array_num;
+ assert( array_num < numSequenceData );
+ assert( !arraySet[index] );
+ return create_data( index, bytes_per_ent, initial_value );
+void* SequenceData::create_custom_data( int array_num, size_t total_bytes )
+ void* array = malloc( total_bytes );
+ memset( array, 0, total_bytes );
+ return array;
+SequenceData::AdjacencyDataType* SequenceData::allocate_adjacency_data()
+ assert( !arraySet[0] );
+ const size_t s = sizeof(AdjacencyDataType*) * size();
+ arraySet[0] = malloc( s );
+ memset( arraySet[0], 0, s );
+ return reinterpret_cast<AdjacencyDataType*>(arraySet[0]);
+void* SequenceData::create_tag_data( int tag_num,
+ void* initial_val )
+ const int index = tag_num + 1;
+ if (tag_num >= numTagData) {
+ void** list = arraySet - numSequenceData;
+ const size_t size = sizeof(void*) * (numSequenceData + tag_num + 1);
+ list = (void**)realloc( list, size );
+ arraySet = list + numSequenceData;
+ memset( arraySet + numTagData, 0, sizeof(void*) * (tag_num + 1 - numTagData) );
+ return create_data( index, bytes_per_ent, initial_val );
+SequenceData* SequenceData::subset( MBEntityHandle start,
+ return new SequenceData( this, start, end, sequence_data_sizes, tag_data_sizes );
+SequenceData::SequenceData( const SequenceData* from,
+ MBEntityHandle start,
+ : numSequenceData( from->numSequenceData ),
+ numTagData( from->numTagData ),
+ startHandle( start ),
+ endHandle( end )
+ assert( start <= end );
+ assert( from != 0 );
+ assert( from->start_handle() <= start );
+ assert( from->end_handle() >= end );
+ void** array = (void**)malloc( sizeof(void*) * (numSequenceData + numTagData + 1) );
+ arraySet = array + numSequenceData;
+ const size_t offset = start - from->start_handle();
+ const size_t count = end - start + 1;
+ for (int i = 0; i < numSequenceData; ++i)
+ copy_data_subset( -1 - i, sequence_data_sizes[i], from->get_sequence_data(i), offset, count );
+ copy_data_subset( 0, sizeof(AdjacencyDataType*), from->get_adjacency_data(), offset, count );
+ for (int i = 0; i< numTagData; ++i)
+ copy_data_subset( 1 + i, tag_data_sizes[i], from->get_tag_data(i), offset, count );
+void SequenceData::copy_data_subset( int index,
+ int size_per_ent,
+ const void* source,
+ size_t offset,
+ size_t count )
+ if (!source)
+ arraySet[index] = 0;
+ else {
+ arraySet[index] = malloc( count * size_per_ent );
+ memcpy( arraySet[index],
+ (const char*)source + offset * size_per_ent,
+ count * size_per_ent );
Added: MOAB/trunk/SequenceData.hpp
--- MOAB/trunk/SequenceData.hpp (rev 0)
+++ MOAB/trunk/SequenceData.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,104 @@
+#ifndef SEQUENCE_DATA_HPP
+#define SEQUENCE_DATA_HPP
+#include "TypeSequenceManager.hpp"
+#include <vector>
+class TagServer;
+class SequenceData
+public:
+ typedef std::vector<MBEntityHandle> AdjacencyDataType;
+ inline SequenceData( int num_sequence_arrays,
+ MBEntityHandle end );
+ virtual ~SequenceData();
+ MBEntityHandle start_handle() const
+ { return startHandle; }
+ MBEntityHandle end_handle() const
+ { return endHandle; }
+ MBEntityID size() const
+ { return endHandle + 1 - startHandle; }
+ void* get_sequence_data( int array_num )
+ { return arraySet[-1-array_num]; }
+ void const* get_sequence_data( int array_num ) const
+ AdjacencyDataType* get_adjacency_data( )
+ { return reinterpret_cast<AdjacencyDataType*>(arraySet[0]); }
+ AdjacencyDataType const* get_adjacency_data( ) const
+ { return reinterpret_cast<AdjacencyDataType const*>(arraySet[0]); }
+ void* get_tag_data( int tag_num )
+ { return tag_num < numTagData ? arraySet[tag_num+1] : 0; }
+ void const* get_tag_data( int tag_num ) const
+ void* create_sequence_data( int array_num,
+ void* initial_val = 0 );
+ void* create_custom_data( int array_num, size_t total_bytes );
+ AdjacencyDataType* allocate_adjacency_data();
+ void* create_tag_data( int tag_num, int bytes_per_ent, void* initial_val = 0 );
+ TypeSequenceManager::SequenceDataPtr seqManData;
+ void move_tag_data( SequenceData* destination, TagServer* tag_server ) {}
+protected:
+ SequenceData( const SequenceData* subset_from,
+ const int* tag_data_sizes );
+private:
+ void* create_data( int index, int bytes_per_ent, void* initial_val = 0 );
+ void copy_data_subset( int index,
+ int size_per_ent,
+ size_t offset,
+ size_t count );
+ const int numSequenceData;
+ int numTagData;
+ void** arraySet;
+ MBEntityHandle startHandle, endHandle;
+inline SequenceData::SequenceData( int num_sequence_arrays,
+ : numSequenceData(num_sequence_arrays),
+ numTagData(0),
+ startHandle(start),
+ endHandle(end)
+ const size_t size = sizeof(void*) * (num_sequence_arrays + 1);
+ void** data = (void**)malloc( size );
+ memset( data, 0, size );
+ arraySet = data + num_sequence_arrays;
+#endif
Added: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp (rev 0)
+++ MOAB/trunk/SequenceManager.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,661 @@
+#include "SequenceManager.hpp"
+#include "VertexSequence.hpp"
+#include "UnstructuredElemSeq.hpp"
+#include "MeshSetSequence.hpp"
+#include "StructuredElementSeq.hpp"
+const int DEFAULT_VERTEX_SEQUENCE_SIZE = 4096;
+const int DEFAULT_ELEMENT_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
+const int DEFAULT_POLY_SEQUENCE_SIZE = 4 * DEFAULT_ELEMENT_SEQUENCE_SIZE;
+const int DEFAULT_MESHSET_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
+MBErrorCode SequenceManager::check_valid_entities( const MBRange& entities ) const
+ MBErrorCode rval;
+ MBRange::const_pair_iterator i;
+ for (i = entities.const_pair_begin(); i != entities.const_pair_end(); ++i) {
+ const MBEntityType type1 = TYPE_FROM_HANDLE(i->first);
+ const MBEntityType type2 = TYPE_FROM_HANDLE(i->second);
+ if (type1 == type2) {
+ rval = typeData[type1].check_valid_handles( i->first, i->second );
+ return rval;
+ else {
+ int junk;
+ MBEntityHandle split = CREATE_HANDLE( type2, 0, junk );
+ rval = typeData[type1].check_valid_handles( i->first, split-1 );
+ return rval;
+ rval = typeData[type2].check_valid_handles( split, i->second );
+ return rval;
+MBErrorCode SequenceManager::delete_entity( MBEntityHandle entity )
+ return typeData[TYPE_FROM_HANDLE(entity)].erase( entity );
+MBErrorCode SequenceManager::delete_entities( const MBRange& entities )
+ MBErrorCode rval = check_valid_entities( entities );
+ return rval;
+ MBErrorCode result = MB_SUCCESS;
+ rval = typeData[type1].erase( i->first, i->second );
+ return result = rval;
+ else {
+ int junk;
+ rval = typeData[type1].erase( i->first, split-1 );
+ rval = typeData[type2].erase( split, i->second );
+ return result;
+MBErrorCode SequenceManager::create_vertex( unsigned proc_id,
+ const double coords[3],
+ MBEntityHandle& handle )
+ if (proc_id == (unsigned)-1)
+ proc_id = handleUtils.proc_rank();
+ const MBEntityHandle start = handleUtils.create_handle( MBVERTEX, handleUtils.first_id(proc_id), proc_id );
+ const MBEntityHandle end = handleUtils.create_handle( MBVERTEX, handleUtils. last_id(proc_id), proc_id );
+ bool append;
+ TypeSequenceManager::iterator seq = typeData[MBVERTEX].find_free_handle( start, end, append );
+ VertexSequence* vseq;
+ if (seq == typeData[MBVERTEX].end()) {
+ SequenceData* seq_data = 0;
+ handle = typeData[MBVERTEX].find_free_sequence( DEFAULT_VERTEX_SEQUENCE_SIZE, start, end, seq_data );
+ if (!handle)
+ if (seq_data)
+ vseq = new VertexSequence( handle, 1, seq_data );
+ else
+ vseq = new VertexSequence( handle, 1, DEFAULT_VERTEX_SEQUENCE_SIZE );
+ MBErrorCode rval = typeData[MBVERTEX].insert_sequence( vseq );
+ if (MB_SUCCESS != rval) {
+ SequenceData* vdata = vseq->data();
+ delete vseq;
+ if (!seq_data)
+ delete vdata;
+ return rval;
+ else {
+ vseq = reinterpret_cast<VertexSequence*>(*seq);
+ if (append) {
+ vseq->push_back( 1 );
+ handle = vseq->end_handle();
+ typeData[MBVERTEX].notify_appended( seq );
+ else {
+ vseq->push_front( 1 );
+ handle = vseq->start_handle();
+ typeData[MBVERTEX].notify_prepended( seq );
+ return vseq->set_coordinates( handle, coords );
+MBErrorCode SequenceManager::create_element( MBEntityType type,
+ unsigned proc_id,
+ const MBEntityHandle* conn,
+ unsigned conn_len,
+ if (type <= MBVERTEX || type >= MBENTITYSET)
+ return MB_TYPE_OUT_OF_RANGE;
+ const MBEntityHandle start = handleUtils.create_handle( type, handleUtils.first_id(proc_id), proc_id );
+ const MBEntityHandle end = handleUtils.create_handle( type, handleUtils. last_id(proc_id), proc_id );
+ bool append;
+ TypeSequenceManager::iterator seq = typeData[type].find_free_handle( start, end, append, conn_len );
+ UnstructuredElemSeq* eseq;
+ if (seq == typeData[type].end()) {
+ unsigned size = DEFAULT_ELEMENT_SEQUENCE_SIZE;
+ if (type == MBPOLYGON || type == MBPOLYHEDRON) {
+ size = DEFAULT_POLY_SEQUENCE_SIZE / conn_len;
+ if (!size)
+ size = 1;
+ handle = typeData[type].find_free_sequence( size, start, end, seq_data, conn_len );
+ if (!handle)
+ if (seq_data)
+ eseq = new UnstructuredElemSeq( handle, 1, conn_len, seq_data );
+ else
+ eseq = new UnstructuredElemSeq( handle, 1, conn_len, size );
+ MBErrorCode rval = typeData[type].insert_sequence( eseq );
+ SequenceData* vdata = eseq->data();
+ delete eseq;
+ if (!seq_data)
+ delete vdata;
+ return rval;
+ else {
+ eseq = reinterpret_cast<UnstructuredElemSeq*>(*seq);
+ if (append) {
+ eseq->push_back( 1 );
+ handle = eseq->end_handle();
+ typeData[type].notify_appended( seq );
+ else {
+ eseq->push_front( 1 );
+ handle = eseq->start_handle();
+ typeData[type].notify_prepended( seq );
+ return eseq->set_connectivity( handle, conn, conn_len );
+MBErrorCode SequenceManager::create_mesh_set( unsigned proc_id,
+ unsigned flags,
+ const MBEntityHandle start = handleUtils.create_handle( MBENTITYSET, handleUtils.first_id(proc_id), proc_id );
+ const MBEntityHandle end = handleUtils.create_handle( MBENTITYSET, handleUtils. last_id(proc_id), proc_id );
+ bool append;
+ TypeSequenceManager::iterator seq = typeData[MBENTITYSET].find_free_handle( start, end, append );
+ MeshSetSequence* msseq;
+ if (seq == typeData[MBENTITYSET].end()) {
+ handle = typeData[MBENTITYSET].find_free_sequence( DEFAULT_MESHSET_SEQUENCE_SIZE, start, end, seq_data );
+ if (!handle)
+ if (seq_data)
+ msseq = new MeshSetSequence( handle, 1, flags, seq_data );
+ else
+ msseq = new MeshSetSequence( handle, 1, flags, DEFAULT_MESHSET_SEQUENCE_SIZE );
+ MBErrorCode rval = typeData[MBENTITYSET].insert_sequence( msseq );
+ SequenceData* vdata = msseq->data();
+ delete msseq;
+ if (!seq_data)
+ delete vdata;
+ return rval;
+ else {
+ msseq = reinterpret_cast<MeshSetSequence*>(*seq);
+ if (append) {
+ msseq->push_back( 1, &flags );
+ handle = msseq->end_handle();
+ typeData[MBENTITYSET].notify_appended( seq );
+ else {
+ msseq->push_front( 1, &flags );
+ handle = msseq->start_handle();
+ typeData[MBENTITYSET].notify_prepended( seq );
+MBErrorCode SequenceManager::allocate_mesh_set( MBEntityHandle handle,
+ unsigned flags )
+ SequenceData* data = 0;
+ TypeSequenceManager::iterator seqptr;
+ MBEntityHandle block_start = 1, block_end = 0;
+ MBErrorCode rval = typeData[MBENTITYSET].is_free_handle( handle, seqptr, data, block_start, block_end );
+ return rval;
+ MeshSetSequence* seq;
+ if (seqptr != typeData[MBENTITYSET].end()) {
+ seq = static_cast<MeshSetSequence*>(*seqptr);
+ if (seq->start_handle() + 1 == handle) {
+ rval = seq->push_front( 1, &flags );
+ if (MB_SUCCESS == rval) {
+ rval = typeData[MBENTITYSET].notify_prepended( seqptr );
+ seq->pop_front( 1 );
+ return rval;
+ else if (seq->end_handle() == handle + 1) {
+ rval = seq->push_back( 1, &flags );
+ rval = typeData[MBENTITYSET].notify_appended( seqptr );
+ seq->pop_back( 1 );
+ return rval;
+ else
+ return MB_FAILURE; // should be unreachable
+ else {
+ if (data) {
+ seq = new MeshSetSequence( handle, 1, flags, data );
+ else {
+ assert( handle >= block_start && handle <= block_end );
+ trim_sequence_block( handle, block_end, DEFAULT_MESHSET_SEQUENCE_SIZE );
+ seq = new MeshSetSequence( handle, 1, flags, block_end - handle + 1 );
+ MBErrorCode rval = typeData[MBENTITYSET].insert_sequence( seq );
+ SequenceData* vdata = seq->data();
+ delete seq;
+ if (!data)
+ delete vdata;
+ return rval;
+void
+SequenceManager::trim_sequence_block( MBEntityHandle start_handle,
+ MBEntityHandle& end_handle,
+ unsigned max_size )
+ assert( end_handle >= start_handle );
+ assert( (int)max_size > 0 ); // cast to int also prohibits some rediculously large values
+ // if input range is larger than preferred size, trim it
+ if (end_handle - start_handle >= max_size)
+ end_handle = start_handle + max_size - 1;
+ // if range spans more than one proc, trim it to one
+ const unsigned rank = handleUtils.rank_from_handle( start_handle );
+ if (handleUtils.rank_from_handle(end_handle) != rank)
+ end_handle = handleUtils.create_handle( TYPE_FROM_HANDLE(start_handle),
+ handleUtils.max_id(),
+ rank );
+MBEntityHandle
+SequenceManager::sequence_start_handle( MBEntityType type,
+ MBEntityID count,
+ int size,
+ MBEntityID start,
+ int proc,
+ SequenceData*& data )
+ TypeSequenceManager &tsm = typeData[type];
+ data = 0;
+ MBEntityHandle handle = handleUtils.create_handle( type, start, proc );
+ if (start < MB_START_ID ||
+ !tsm.is_free_sequence( handle, count, data, size )) {
+ MBEntityHandle pstart = handleUtils.create_handle( type, MB_START_ID, proc );
+ MBEntityHandle pend = handleUtils.create_handle( type, MB_END_ID, proc );
+ handle = tsm.find_free_sequence( count, pstart, pend, data, size );
+ return handle;
+MBErrorCode
+SequenceManager::create_entity_sequence( MBEntityType type,
+ MBEntityID count,
+ int size,
+ MBEntityID start,
+ int proc,
+ MBEntityHandle& handle,
+ EntitySequence*& sequence )
+ if (proc == -1)
+ proc = handleUtils.proc_rank();
+ handle = sequence_start_handle( type, count, size, start, proc, data );
+ if (!handle)
+ return MB_MEMORY_ALLOCATION_FAILED;
+ switch (type) {
+ case MBENTITYSET:
+ case MBMAXTYPE:
+ case MBVERTEX:
+ if (size != 0)
+ return MB_INDEX_OUT_OF_RANGE;
+ if (data)
+ sequence = new VertexSequence( handle, count, data );
+ else
+ sequence = new VertexSequence( handle, count, count );
+ break;
+ default:
+ if (size == 0)
+ if (data)
+ sequence = new UnstructuredElemSeq( handle, count, size, data );
+ else
+ sequence = new UnstructuredElemSeq( handle, count, size, count );
+ break;
+ MBErrorCode result = typeData[type].insert_sequence( sequence );
+ if (MB_SUCCESS != result) {
+ // change to NULL if had an existing data or if no existing data,
+ // change to the new data created
+ data = data ? 0 : sequence->data();
+ delete sequence;
+ delete data;
+ return result;
+MBErrorCode
+SequenceManager::create_meshset_sequence( MBEntityID count,
+ MBEntityID start,
+ int proc,
+ const unsigned* flags,
+ if (proc == -1)
+ handle = sequence_start_handle( MBENTITYSET, count, 0, start, proc, data );
+ if (!handle)
+ if (data)
+ sequence = new MeshSetSequence( handle, count, flags, data );
+ else
+ sequence = new MeshSetSequence( handle, count, flags, count );
+ MBErrorCode result = typeData[MBENTITYSET].insert_sequence( sequence );
+ delete sequence;
+ delete data;
+ return result;
+MBErrorCode
+ MBEntityID start,
+ int proc,
+ unsigned flags,
+ if (proc == -1)
+ if (!handle)
+ if (data)
+ else
+ delete sequence;
+ delete data;
+ return result;
+MBErrorCode
+SequenceManager::create_scd_sequence( int imin, int jmin, int kmin,
+ int imax, int jmax, int kmax,
+ MBEntityType type,
+ MBEntityID start_id_hint,
+ int processor_id,
+ if (processor_id == -1)
+ processor_id = handleUtils.proc_rank();
+ int this_dim = MBCN::Dimension(type);
+ // use > instead of != in the following assert to also catch cases where imin > imax, etc.
+ assert((this_dim < 3 || kmax > kmin) &&
+ (this_dim < 2 || jmax > jmin) &&
+ (this_dim < 1 || imax > imin));
+ // compute # entities; not as easy as it would appear...
+ MBEntityID num_ent;
+ if (MBVERTEX == type)
+ num_ent = (MBEntityID)(imax-imin+1)*(MBEntityID)(jmax-jmin+1)*(MBEntityID)(kmax-kmin+1);
+ else {
+ num_ent = (imax-imin) *
+ (this_dim >= 2 ? (jmax-jmin) : 1) *
+ (this_dim >= 3 ? (kmax-kmin) : 1);
+ // get a start handle
+ handle = sequence_start_handle( type, num_ent, -1, start_id_hint, processor_id, data );
+ if (!handle)
+ assert(!data);
+ switch (type) {
+ case MBVERTEX:
+ data = new ScdVertexData( handle, imin, jmin, kmin, imax, jmax, kmax );
+ sequence = new VertexSequence( handle, data->size(), data );
+ break;
+ case MBEDGE:
+ case MBQUAD:
+ case MBHEX:
+ sequence = new StructuredElementSeq( handle, imin, jmin, kmin, imax, jmax, kmax );
+ break;
+ default:
+ data = sequence->data();
+ delete sequence;
+ delete data;
+ return result;
+MBErrorCode
+SequenceManager::create_scd_sequence( const HomCoord& coord_min,
+ const HomCoord& coord_max,
+ int processor_id,
+ MBEntityHandle& first_handle_out,
+ EntitySequence*& sequence_out )
+ return create_scd_sequence( coord_min.i(), coord_min.j(), coord_min.k(),
+ coord_max.i(), coord_max.j(), coord_max.k(),
+ type, start_id_hint, processor_id,
+ first_handle_out, sequence_out );
+MBErrorCode
+SequenceManager::replace_subsequence( EntitySequence* new_seq, TagServer* ts )
+ const MBEntityType type = TYPE_FROM_HANDLE(new_seq->start_handle());
+ return typeData[type].replace_subsequence( new_seq, ts );
+void SequenceManager::get_memory_use( unsigned long& total_entity_storage,
+ unsigned long& total_storage ) const
+ total_entity_storage = 0;
+ total_storage = 0;
+ unsigned long temp_entity, temp_total;
+ for (MBEntityType i = MBVERTEX; i < MBMAXTYPE; ++i) {
+ temp_entity = temp_total = 0;
+ get_memory_use( i, temp_entity, temp_total );
+ total_entity_storage += temp_entity;
+ total_storage += temp_total;
+void SequenceManager::get_memory_use( MBEntityType type,
+ unsigned long& total_entity_storage,
+ typeData[type].get_memory_use( total_entity_storage, total_storage );
+void SequenceManager::get_memory_use( const MBRange& entities,
+ unsigned long& total_amortized_storage ) const
+ total_amortized_storage = 0;
+ const MBEntityType t1 = TYPE_FROM_HANDLE(i->first);
+ const MBEntityType t2 = TYPE_FROM_HANDLE(i->second);
+ if (t1 == t2) {
+ typeData[t1].get_memory_use( i->first, i->second, temp_entity, temp_total );
+ total_amortized_storage += temp_total;
+ else {
+ int junk;
+ typeData[t1].get_memory_use( i->first, CREATE_HANDLE(t1,MB_END_ID,junk), temp_entity, temp_total );
+ typeData[t2].get_memory_use( CREATE_HANDLE(t2,MB_START_ID,junk), i->second, temp_entity, temp_total );
+// These are meant to be called from the debugger (not declared in any header)
+// so leave them out of release builds (-DNDEBUG).
+#ifndef NDEBUG
+#include <iostream>
+std::ostream& operator<<( std::ostream& s, const TypeSequenceManager& seq_man )
+ const SequenceData* prev_data = 0;
+ for (TypeSequenceManager::const_iterator i = seq_man.begin(); i != seq_man.end(); ++i) {
+ const EntitySequence* seq = *i;
+ if (seq->data() != prev_data) {
+ prev_data = seq->data();
+ s << "SequenceData ["
+ << ID_FROM_HANDLE(seq->data()->start_handle())
+ << ID_FROM_HANDLE(seq->data()->end_handle())
+ << std::endl;
+ s << " Sequence ["
+ << ID_FROM_HANDLE(seq->start_handle())
+ << ID_FROM_HANDLE(seq->end_handle())
+ << std::endl;
+ return s;
+std::ostream& operator<<( std::ostream& s, const SequenceManager& seq_man )
+ for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++t)
+ if (!seq_man.entity_map(t).empty())
+ s << std::endl
+ << "****************** " << MBCN::EntityTypeName( t ) << " ******************"
+ << std::endl << seq_man.entity_map(t) << std::endl;
+ return s;
+void print_sequences( const SequenceManager& seqman )
+ std::cout << seqman << std::endl;
+void print_sequences( const TypeSequenceManager& seqman )
+#endif
Added: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp (rev 0)
+++ MOAB/trunk/SequenceManager.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,146 @@
+#ifndef SEQUENCE_MANAGER_HPP
+#define SEQUENCE_MANAGER_HPP
+#include "MBHandleUtils.hpp"
+class HomCoord;
+class TagServer;
+class SequenceManager
+ public:
+ SequenceManager( const MBHandleUtils& handle_utils )
+ : handleUtils(handle_utils)
+ MBErrorCode find( MBEntityHandle handle, EntitySequence*& sequence_out ) const
+ return typeData[TYPE_FROM_HANDLE(handle)].find( handle, sequence_out );
+ void get_entities( MBEntityType type, MBRange& entities_out ) const
+ { typeData[type].get_entities( entities_out ); }
+ MBEntityID get_number_entities( MBEntityType type ) const
+ { return typeData[type].get_number_entities(); }
+ MBErrorCode replace_subsequence( EntitySequence* new_seq, TagServer* ts );
+ MBErrorCode check_valid_entities( const MBRange& entities ) const;
+ MBErrorCode delete_entity( MBEntityHandle entity );
+ MBErrorCode delete_entities( const MBRange& entities );
+ MBErrorCode create_vertex( unsigned processor_id,
+ MBEntityHandle& handle_out );
+ MBErrorCode create_element( MBEntityType type,
+ unsigned processor_id,
+ const MBEntityHandle* conn_array,
+ unsigned num_vertices,
+ MBErrorCode create_mesh_set( unsigned processor_id,
+ unsigned flags,
+ MBErrorCode allocate_mesh_set( MBEntityHandle at_this_handle,
+ unsigned flags );
+ MBErrorCode create_entity_sequence( MBEntityType type,
+ MBEntityID num_entities,
+ int nodes_per_entity,
+ int processor_id,
+ EntitySequence*& sequence_out );
+ MBErrorCode create_meshset_sequence( MBEntityID num_sets,
+ int processor_id,
+ int processor_id,
+ unsigned flags,
+ MBErrorCode create_scd_sequence( int imin, int jmin, int kmin,
+ int processor_id,
+ MBErrorCode create_scd_sequence( const HomCoord& coord_min,
+ int processor_id,
+ const TypeSequenceManager& entity_map( MBEntityType type ) const
+ { return typeData[type]; }
+ void get_memory_use( unsigned long& total_entity_storage,
+ unsigned long& total_storage ) const;
+ void get_memory_use( MBEntityType type,
+ void get_memory_use( const MBRange& entities,
+ unsigned long& total_amortized_storage ) const;
+ private:
+ /**\brief Utility function for allocate_mesh_set (and similar)
+ * Given a block of available handles, determine the non-strict
+ * subset at which to create a new EntitySequence.
+ void trim_sequence_block( MBEntityHandle start_handle,
+ MBEntityHandle& end_handle_in_out,
+ unsigned maximum_sequence_size );
+ /**\brief Get range of handles in which to create an entity sequence
+ * Get range of handles in whcih to place a new entity sequence.
+ *\param type The MBEntityType for the contents of the sequence
+ *\param entity_count The number of entities in the range
+ *\param values_per_entity Vertices per element, zero for other types
+ *\param start_id_hint Preferred id of first handle
+ *\param processor_rank MPI processor ID
+ *\param data_out Output: Either NULL or an existing SequenceData
+ * with a sufficiently large block to accomodate
+ * the handle range.
+ *\return zero if no available handle range, start handle otherwise.
+ MBEntityHandle sequence_start_handle( MBEntityType type,
+ MBEntityID entity_count,
+ int values_per_entity,
+ int processor_rank,
+ SequenceData*& data_out );
+ const MBHandleUtils handleUtils;
+ TypeSequenceManager typeData[MBMAXTYPE];
+#endif
Copied: MOAB/trunk/StructuredElementSeq.cpp (from rev 1308, MOAB/trunk/ScdElementSeq.cpp)
--- MOAB/trunk/StructuredElementSeq.cpp (rev 0)
+++ MOAB/trunk/StructuredElementSeq.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,100 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#include "ScdVertexData.hpp"
+#include "ScdElementData.hpp"
+#include "MBInterface.hpp"
+#include "MBReadUtilIface.hpp"
+#include "MBCN.hpp"
+#include "MBInternals.hpp"
+StructuredElementSeq::StructuredElementSeq(MBEntityHandle start_handle,
+ const int imin, const int jmin, const int kmin,
+ : ElementSequence( start_handle,
+ ScdElementData::calc_num_entities( start_handle,
+ imax-imin,
+ jmax-jmin,
+ kmax-kmin ),
+ MBCN::VerticesPerEntity(TYPE_FROM_HANDLE(start_handle)),
+ new ScdElementData( start_handle,
+ imin, jmin, kmin,
+ imax, jmax, kmax ) )
+StructuredElementSeq::~StructuredElementSeq()
+MBErrorCode StructuredElementSeq::get_connectivity(
+ MBEntityHandle handle,
+ std::vector<MBEntityHandle>& connect,
+ bool /*topological*/ ) const
+ int i, j, k;
+ MBErrorCode rval = get_params( handle, i, j, k );
+ rval = get_params_connectivity( i, j, k, connect );
+ return rval;
+ MBEntityHandle const*& connect,
+ int &connect_length,
+ bool topo,
+ std::vector<MBEntityHandle>* storage
+ ) const
+ if (!storage) {
+ connect = 0;
+ connect_length = 0;
+ return MB_NOT_IMPLEMENTED;
+ MBErrorCode rval = get_connectivity( handle, *storage, topo );
+ connect = &(*storage)[0];
+ connect_length = storage->size();
+ return rval;
+MBErrorCode StructuredElementSeq::set_connectivity(
+ MBEntityHandle,
+ MBEntityHandle const*,
+ int )
+MBEntityHandle* StructuredElementSeq::get_connectivity_array()
+ { return 0; }
+int StructuredElementSeq::values_per_entity() const
+ { return -1; } // never reuse freed handles for structured elements
+EntitySequence* StructuredElementSeq::split( MBEntityHandle here )
+ { return new StructuredElementSeq( *this, here ); }
+SequenceData* StructuredElementSeq::create_data_subset( MBEntityHandle, MBEntityHandle ) const
+ { return 0; }
+void StructuredElementSeq::get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& sequence_size ) const
+ sequence_size = sizeof(*this);
+ bytes_per_entity = sdata()->get_memory_use() / sdata()->size();
Copied: MOAB/trunk/StructuredElementSeq.hpp (from rev 1308, MOAB/trunk/ScdElementSeq.hpp)
--- MOAB/trunk/StructuredElementSeq.hpp (rev 0)
+++ MOAB/trunk/StructuredElementSeq.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,158 @@
+#ifndef STRUCTURED_ELEMENT_SEQUENCE
+#define STRUCTURED_ELEMENT_SEQUENCE
+// Class: StructuredElementSeq
+#include "ElementSequence.hpp"
+class StructuredElementSeq : public ElementSequence
+public:
+ //! constructor
+ StructuredElementSeq(
+ MBEntityHandle start_handle,
+ virtual ~StructuredElementSeq();
+ ScdElementData* sdata()
+ { return reinterpret_cast<ScdElementData*>(data()); }
+ ScdElementData const* sdata() const
+ { return reinterpret_cast<const ScdElementData*>(data()); }
+ { return get_vertex( HomCoord(i,j,k) ); }
+ { return sdata()->get_vertex(coords); }
+ { return sdata()->get_element( i, j, k ); }
+ //! get handle of element at homogeneous coords
+ MBEntityHandle get_element(const HomCoord &coords) const
+ { return sdata()->get_element( coords.i(), coords.j(), coords.k() ); }
+ { return sdata()->min_params(); }
+ void min_params(HomCoord &coords) const
+ { coords = min_params(); }
+ { i = min_params().i(); j = min_params().j(); k = min_params().k(); }
+ { return sdata()->max_params(); }
+ void max_params(HomCoord &coords) const
+ { coords = max_params(); }
+ { i = max_params().i(); j = max_params().j(); k = max_params().k(); }
+ { sdata()->param_extents( di, dj, dk ); }
+ { return sdata()->get_params( ehandle, i, j, k ); }
+ int i_min() const {return min_params().i();}
+ int j_min() const {return min_params().j();}
+ int k_min() const {return min_params().k();}
+ int i_max() const {return max_params().i();}
+ int j_max() const {return max_params().j();}
+ int k_max() const {return max_params().k();}
+ inline bool boundary_complete() const
+ { return sdata()->boundary_complete(); }
+ { return sdata()->contains(HomCoord(i,j,k)); }
+ { return sdata()->contains(coords); }
+ MBErrorCode get_params_connectivity(const int i, const int j, const int k,
+ { return sdata()->get_params_connectivity( i, j, k, connectivity ); }
+ /***************** Methods from ElementSequence *****************/
+ virtual MBErrorCode get_connectivity( MBEntityHandle handle,
+ bool topological = false ) const;
+ bool topological = false,
+ std::vector<MBEntityHandle>* storage = 0
+ ) const;
+ virtual MBErrorCode set_connectivity( MBEntityHandle handle,
+ MBEntityHandle const* connect,
+ int connect_length );
+ virtual MBEntityHandle* get_connectivity_array();
+ /***************** Methods from EntitySequence *****************/
+ /* Replace the ElementSequence implementation of this method with
+ * one that always returns zero, because we cannot re-use handles
+ * that are within a ScdElementData
+ virtual int values_per_entity() const;
+ virtual EntitySequence* split( MBEntityHandle here );
+ virtual SequenceData* create_data_subset( MBEntityHandle start_handle,
+ MBEntityHandle end_handle ) const;
+ virtual void get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& size_of_sequence ) const;
+protected:
+ StructuredElementSeq( StructuredElementSeq& split_from, MBEntityHandle here )
+ : ElementSequence( split_from, here )
+#endif
Added: MOAB/trunk/TestTypeSequenceManager.cpp
--- MOAB/trunk/TestTypeSequenceManager.cpp (rev 0)
+++ MOAB/trunk/TestTypeSequenceManager.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,972 @@
+#include "EntitySequence.hpp"
+#include "TestUtil.hpp"
+void test_basic();
+void test_lower_bound();
+void test_upper_bound();
+void test_find();
+void test_get_entities();
+void test_insert_sequence_merge();
+void test_insert_sequence_nomerge();
+void test_remove_sequence();
+void test_replace_subsequence();
+void test_erase();
+void test_find_free_handle();
+void test_find_free_sequence();
+void test_is_free_sequence();
+void test_is_free_handle();
+/* Construct sequence of vertex handles containing
+ the ID ranges: { [3,7], [100,111], [1001] }
+ referencing a SequnceData with the range [1,22000]
+void make_basic_sequence( TypeSequenceManager& seq );
+void make_basic_sequence( TypeSequenceManager& seq,
+ EntitySequence*& seq3to7,
+ EntitySequence*& seq100to111,
+ EntitySequence*& seq1001 );
+/* Compare expected sequence contents to actual contents.
+ * Also does some consistency checks.
+bool seqman_equal( const MBEntityHandle pair_array[][2],
+ unsigned num_pairs,
+ const TypeSequenceManager& seqman );
+ * Insert a sequence into a sequence manager. Delete passed
+ * sequence (and optionally SequenceData) if insertion fails.
+MBErrorCode insert_seq( TypeSequenceManager& seqman,
+ MBEntityID count,
+ SequenceData* data,
+ bool del_data = false );
+int main( )
+ if (RUN_TEST( test_basic )) {
+ printf( "BASIC USE TEST FAILED\nCANNOT TEST FURTHER\n" );
+ return 1;
+ int error_count = 0;
+ error_count += RUN_TEST( test_lower_bound );
+ error_count += RUN_TEST( test_upper_bound );
+ error_count += RUN_TEST( test_find );
+ error_count += RUN_TEST( test_get_entities );
+ error_count += RUN_TEST( test_insert_sequence_merge );
+ error_count += RUN_TEST( test_insert_sequence_nomerge );
+ error_count += RUN_TEST( test_remove_sequence );
+ error_count += RUN_TEST( test_replace_subsequence );
+ error_count += RUN_TEST( test_erase );
+ error_count += RUN_TEST( test_find_free_handle );
+ error_count += RUN_TEST( test_find_free_sequence );
+ error_count += RUN_TEST( test_is_free_sequence );
+ if (!error_count)
+ printf( "ALL TESTS PASSED\n");
+ else
+ printf( "%d TESTS FAILED\n", error_count );
+ return error_count;
+class DumSeq : public EntitySequence {
+ private:
+ int valsPerEnt;
+ public:
+ DumSeq( MBEntityHandle start, MBEntityID count, SequenceData* data, int vals_per_ent = 0 )
+ : EntitySequence( start, count, data), valsPerEnt(vals_per_ent) {}
+ DumSeq( SequenceData* data, int vals_per_ent = 0 )
+ : EntitySequence( data->start_handle(), data->size(), data), valsPerEnt(vals_per_ent) {}
+ DumSeq( DumSeq& split_from, MBEntityHandle here )
+ : EntitySequence( split_from, here ), valsPerEnt(split_from.valsPerEnt) {}
+ virtual ~DumSeq() {}
+ EntitySequence* split( MBEntityHandle here )
+ { return new DumSeq(*this, here); }
+ SequenceData* create_data_subset( MBEntityHandle a, MBEntityHandle b ) const
+ { return data()->subset( a, b, 0, 0 ); }
+ void get_const_memory_use( unsigned long& a, unsigned long& b) const
+ { a = b = 0; }
+ unsigned long get_per_entity_memory_use( MBEntityHandle, MBEntityHandle) const
+ { return 0; }
+ int values_per_entity() const
+ { return valsPerEnt; }
+void make_basic_sequence( TypeSequenceManager& seqman )
+ EntitySequence *s, *t, *u;
+ make_basic_sequence( seqman, s, t, u );
+ MBEntityID count,
+ bool del_data )
+ EntitySequence* seq = new DumSeq( start_handle, count, data );
+ MBErrorCode rval = seqman.insert_sequence( seq );
+ delete seq;
+ if (del_data)
+ delete data;
+ else {
+ CHECK( start_handle >= seq->start_handle() );
+ CHECK( start_handle+count-1 <= seq-> end_handle() );
+ return rval;
+void make_basic_sequence( TypeSequenceManager& seqman,
+ EntitySequence*& seq1,
+ EntitySequence*& seq2,
+ EntitySequence*& seq3 )
+ CHECK( seqman.empty() );
+ CHECK_EQUAL( (MBEntityID)0, seqman.get_number_entities() );
+ SequenceData* data = new SequenceData( 0, 1, 22000 );
+ CHECK_ERR( insert_seq( seqman, 3, 5, data ) );
+ CHECK_ERR( insert_seq( seqman, 100, 12, data ) );
+ CHECK_ERR( insert_seq( seqman, 1001, 1, data ) );
+ CHECK( !seqman.empty() );
+ CHECK_EQUAL( (MBEntityID)18, seqman.get_number_entities() );
+ TypeSequenceManager::iterator iter = seqman.begin();
+ CHECK( iter != seqman.end() );
+ seq1 = *iter;
+ CHECK_EQUAL( (MBEntityHandle)3, seq1->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)7, seq1->end_handle() );
+ CHECK_EQUAL( data, seq1->data() );
+ CHECK_EQUAL( (MBEntityID)5, seq1->size() );
+ ++iter;
+ seq2 = *iter;
+ CHECK_EQUAL( (MBEntityHandle)100, seq2->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)111, seq2->end_handle() );
+ CHECK_EQUAL( data, seq2->data() );
+ CHECK_EQUAL( (MBEntityID)12, seq2->size() );
+ ++iter;
+ seq3 = *iter;
+ CHECK_EQUAL( (MBEntityHandle)1001, seq3->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)1001, seq3->end_handle() );
+ CHECK_EQUAL( data, seq3->data() );
+ CHECK_EQUAL( (MBEntityID)1, seq3->size() );
+ ++iter;
+ CHECK( iter == seqman.end() );
+void test_basic( )
+ TypeSequenceManager seqman;
+ make_basic_sequence( seqman );
+ TypeSequenceManager::const_iterator i;
+ EntitySequence *seq1, // 3 to 7
+ *seq2, // 100 to 111
+ *seq3; // 1001
+ make_basic_sequence( seqman, seq1, seq2, seq3 );
+ i = seqman.lower_bound( 2 );
+ CHECK_EQUAL( seq1, *i );
+ i = seqman.lower_bound( 3 );
+ i = seqman.lower_bound( 4 );
+ i = seqman.lower_bound( 7 );
+ i = seqman.lower_bound( 8 );
+ CHECK_EQUAL( seq2, *i );
+ i = seqman.lower_bound( 99 );
+ i = seqman.lower_bound( 100 );
+ i = seqman.lower_bound( 110 );
+ i = seqman.lower_bound( 111 );
+ i = seqman.lower_bound( 112 );
+ CHECK_EQUAL( seq3, *i );
+ i = seqman.lower_bound( 1000 );
+ i = seqman.lower_bound( 1001 );
+ i = seqman.lower_bound( 1002 );
+ CHECK( i == seqman.end() );
+ *seq3; // 1001
+ i = seqman.upper_bound( 2 );
+ i = seqman.upper_bound( 3 );
+ i = seqman.upper_bound( 4 );
+ i = seqman.upper_bound( 7 );
+ i = seqman.upper_bound( 8 );
+ i = seqman.upper_bound( 99 );
+ i = seqman.upper_bound( 100 );
+ i = seqman.upper_bound( 110 );
+ i = seqman.upper_bound( 111 );
+ i = seqman.upper_bound( 112 );
+ i = seqman.upper_bound( 1000 );
+ i = seqman.upper_bound( 1001 );
+void test_find()
+ *seq3, // 1001
+ *seq;
+ seq = seqman.find( 2 );
+ CHECK_EQUAL( NULL, seq );
+ seq = seqman.find( 3 );
+ CHECK_EQUAL( seq1, seq );
+ seq = seqman.find( 4 );
+ seq = seqman.find( 7 );
+ seq = seqman.find( 8 );
+ seq = seqman.find( 99 );
+ seq = seqman.find( 100 );
+ CHECK_EQUAL( seq2, seq );
+ seq = seqman.find( 110 );
+ seq = seqman.find( 111 );
+ seq = seqman.find( 112 );
+ seq = seqman.find( 1000 );
+ seq = seqman.find( 1001 );
+ CHECK_EQUAL( seq3, seq );
+ seq = seqman.find( 1002 );
+ unsigned i;
+ TypeSequenceManager::const_iterator j = seqman.begin();
+ EntitySequence* seq = 0;
+ for (i = 0; i < num_pairs; ++i, ++j) {
+ if (j == seqman.end())
+ break;
+ if (seq && seq->end_handle() >= (*j)->start_handle()) {
+ printf( "Sequence [%lu,%lu] overlaps sequence [%lu,%lu]\n",
+ (unsigned long)ID_FROM_HANDLE( seq->start_handle()),
+ (unsigned long)ID_FROM_HANDLE( seq-> end_handle()),
+ (unsigned long)ID_FROM_HANDLE((*j)->start_handle()),
+ (unsigned long)ID_FROM_HANDLE((*j)-> end_handle()));
+ return false;
+ if (seq && seq->data() != (*j)->data() &&
+ seq->data()->end_handle() >= (*j)->data()->start_handle()) {
+ printf( "SequenceData [%lu,%lu] overlaps SequenceData [%lu,%lu]\n",
+ (unsigned long)ID_FROM_HANDLE( seq->data()->start_handle()),
+ (unsigned long)ID_FROM_HANDLE( seq->data()-> end_handle()),
+ (unsigned long)ID_FROM_HANDLE((*j)->data()->start_handle()),
+ (unsigned long)ID_FROM_HANDLE((*j)->data()-> end_handle()));
+ return false;
+ seq = *j;
+ if (seq->start_handle() > seq->end_handle()) {
+ printf( "Inverted sequence [%lu,%lu]\n",
+ (unsigned long)ID_FROM_HANDLE( seq-> end_handle()));
+ return false;
+ if (pair_array[i][0] != seq->start_handle() ||
+ pair_array[i][1] != seq->end_handle())
+ break;
+ if (seq->data()->start_handle() > seq->start_handle() ||
+ seq->data()-> end_handle() < seq-> end_handle()) {
+ printf( "Sequence [%lu,%lu] has data [%lu,%lu]\n",
+ (unsigned long)ID_FROM_HANDLE(seq->start_handle()),
+ (unsigned long)ID_FROM_HANDLE(seq-> end_handle()),
+ (unsigned long)ID_FROM_HANDLE(seq->data()->start_handle()),
+ (unsigned long)ID_FROM_HANDLE(seq->data()-> end_handle()));
+ return false;
+ if (i == num_pairs && j == seqman.end())
+ return true;
+ if (i < num_pairs)
+ printf("Sequence Mismatch: Expected: [%lu,%lu], got ",
+ (unsigned long)ID_FROM_HANDLE(pair_array[i][0]),
+ (unsigned long)ID_FROM_HANDLE(pair_array[i][1]) );
+ else
+ printf("Sequence Mismatch: Expected END, got " );
+ printf( "END.\n" );
+ else
+ printf("[%lu,%lu]\n",
+ (unsigned long)ID_FROM_HANDLE((*j)->end_handle()) );
+ return false;
+ MBRange entities;
+ seqman.get_entities( entities );
+ CHECK_EQUAL( (MBEntityHandle)18, entities.size() );
+ MBEntityHandle pairs[][2] = { {3, 7}, {100, 111}, {1001, 1001} };
+ CHECK( seqman_equal( pairs, 3, seqman ) );
+ SequenceData* data = (*seqman.begin())->data();
+ // append a sequence
+ CHECK_ERR( insert_seq( seqman, 1003, 1, data ) );
+ MBEntityHandle exp1[][2] = { { 3, 7}, {100, 111}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp1, 4, seqman ) );
+ // prepend a sequence
+ CHECK_ERR( insert_seq( seqman, 1, 1, data ) );
+ MBEntityHandle exp2[][2] = { {1, 1}, { 3, 7}, {100, 111}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp2, 5, seqman ) );
+ // insert sequence in middle
+ CHECK_ERR( insert_seq( seqman, 150, 11, data ) );
+ MBEntityHandle exp3[][2] = { {1, 1}, { 3, 7}, {100, 111}, {150,160}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp3, 6, seqman ) );
+ // merge sequence with predecessor
+ CHECK_ERR( insert_seq( seqman, 8, 13, data ) );
+ MBEntityHandle exp4[][2] = { {1, 1}, { 3, 20}, {100, 111}, {150,160}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp4, 6, seqman ) );
+ // merge sequence with following one
+ CHECK_ERR( insert_seq( seqman, 87, 13, data ) );
+ MBEntityHandle exp5[][2] = { {1, 1}, { 3, 20}, {87, 111}, {150,160}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp5, 6, seqman ) );
+ // merge sequence with two adjacent ones
+ CHECK_ERR( insert_seq( seqman, 2, 1, data ) );
+ MBEntityHandle exp6[][2] = { {1, 20}, {87, 111}, {150,160}, {1001, 1001}, {1003, 1003} };
+ CHECK( seqman_equal( exp6, 5, seqman ) );
+ // try to insert a sequence that overlaps on the end
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 900, 1001, data ) );
+ // try to insert a sequence that overlaps at the start
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 111, 140, data ) );
+ // make sure inserting a sequence w/out a SequenceData fails
+ CHECK_EQUAL( MB_FAILURE, insert_seq( seqman, 1, 5, NULL ) );
+ // Now set up a TypeSequenceManager for testing
+ // Insert an EntitySequence for which the corresponding SequenceData
+ // is exactly the same size.
+ SequenceData *data1 = new SequenceData( 0, 3, 7 );
+ DumSeq* seq = new DumSeq( data1 );
+ delete seq;
+ delete data1;
+ CHECK_ERR( rval );
+ // Insert an EntitySequence with additional room on both ends of
+ // the SequenceData
+ SequenceData *data2 = new SequenceData( 0, 100, 999 );
+ seq = new DumSeq( 200, 100, data2 );
+ rval = seqman.insert_sequence( seq );
+ delete seq;
+ delete data2;
+ // Insert another EntitySequence sharing the previous SequenceData
+ seq = new DumSeq( 400, 100, data2 );
+ delete seq;
+ // Setup complete, begin tests
+ // Test inserting sequence that appends an existing sequence
+ // but overlaps underling SequenceData boundary
+ SequenceData* data = new SequenceData( 0, 999, 1000 );
+ seq = new DumSeq( data );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval );
+ delete seq;
+ delete data;
+ // Test inserting sequence that prepends an existing sequence
+ data = new SequenceData( 0, 50, 199 );
+ delete seq;
+ delete data;
+ // Test fits within existing, but has different SequenceData
+ data = new SequenceData( 0, 500, 599 );
+ delete seq;
+ delete data;
+ // Make sure we're starting out with what we exoect
+ MBEntityHandle exp1[][2] = { { 3, 7}, {200, 299}, {400, 499} };
+ CHECK( seqman_equal( exp1, 3, seqman ) );
+ // Test fits within existing, and has same data
+ CHECK_ERR( insert_seq( seqman, 600, 100, data2 ) );
+ MBEntityHandle exp2[][2] = { { 3, 7}, {200, 299}, {400, 499}, {600, 699} };
+ CHECK( seqman_equal( exp2, 4, seqman ) );
+ // Test is entirely outside existing data
+ CHECK_ERR( insert_seq( seqman, 2000, 2, new SequenceData( 0, 2000, 2001 ), true ) );
+ MBEntityHandle exp3[][2] = { { 3, 7}, {200, 299}, {400, 499}, {600, 699}, {2000, 2001} };
+ CHECK( seqman_equal( exp3, 5, seqman ) );
+ // Test abutts end of exising data
+ CHECK_ERR( insert_seq( seqman, 1000, 6, new SequenceData( 0, 1000, 1005 ), true ) );
+ MBEntityHandle exp4[][2] = { { 3, 7}, {200, 299}, {400, 499}, {600, 699}, {1000,1005}, {2000, 2001} };
+ // Test abutts beginning of exising data
+ CHECK_ERR( insert_seq( seqman, 50, 50, new SequenceData( 0, 50, 99 ), true ) );
+ MBEntityHandle exp5[][2] = { { 3, 7}, {50, 99}, {200, 299}, {400, 499}, {600, 699}, {1000,1005}, {2000, 2001} };
+ CHECK( seqman_equal( exp5, 7, seqman ) );
+ *seq3; // 1001
+ // test removing something that hasn't been inserted
+ bool last;
+ DumSeq junk( 3, 5, NULL );
+ CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.remove_sequence( &junk, last ) );
+ MBEntityHandle exp1[][2] = { { 3, 7}, {100, 111}, {1001, 1001} };
+ // remove the middle sequence
+ CHECK_ERR( seqman.remove_sequence( seq2, last ) );
+ CHECK( !last );
+ delete seq2;
+ // remove the first sequence
+ CHECK_ERR( seqman.remove_sequence( seq1, last ) );
+ CHECK( !last );
+ delete seq1;
+ // remove the last sequence
+ CHECK_ERR( seqman.remove_sequence( seq3, last ) );
+ CHECK( last );
+ SequenceData* data = seq3->data();
+ delete seq3;
+ delete data;
+ MBErrorCode rval;
+ // create an intial set
+ SequenceData* data1 = new SequenceData( 0, 51, 950 );
+ CHECK_ERR( insert_seq( seqman, 101, 100, data1, true ) );
+ CHECK_ERR( insert_seq( seqman, 301, 300, data1 ) );
+ CHECK_ERR( insert_seq( seqman, 701, 100, data1 ) );
+ // try a sequence that is outside all existing data
+ SequenceData* data = new SequenceData( 0, 10, 20 );
+ DumSeq* seq = new DumSeq( data );
+ rval = seqman.replace_subsequence( seq, 0 );
+ CHECK_EQUAL( MB_FAILURE, rval );
+ delete seq;
+ delete data;
+ // try a sequence that overlaps the start of the data
+ data = new SequenceData( 0, 40, 60 );
+ delete seq;
+ delete data;
+ // try a sequence that is within the data but not within any sequence
+ data = new SequenceData( 0, 60, 70 );
+ delete seq;
+ delete data;
+ // try a sequence that overlaps an existing sequence
+ data = new SequenceData( 0, 60, 101 );
+ delete seq;
+ delete data;
+ // try a sequence that should work, but with a SequenceData that
+ // overlaps an existing sequence
+ data = new SequenceData( 0, 150, 200 );
+ seq = new DumSeq( 190, 200, data );
+ delete seq;
+ delete data;
+ // check that we're starting with what we expect
+ MBEntityHandle exp1[][2] = { {101, 200}, {301, 600}, {701, 800} };
+ // split at start of sequence
+ data = new SequenceData( 0, 101, 105 );
+ delete seq;
+ delete data;
+ MBEntityHandle exp2[][2] = { {101, 105}, {106, 200}, {301, 600}, {701, 800} };
+ // split at end of sequence
+ data = new SequenceData( 0, 750, 800 );
+ delete seq;
+ delete data;
+ MBEntityHandle exp3[][2] = { {101, 105}, {106, 200}, {301, 600}, {701, 749}, {750,800} };
+ // split at middle of sequence
+ data = new SequenceData( 0, 400, 499 );
+ delete seq;
+ delete data;
+ MBEntityHandle exp4[][2] = { {101, 105}, {106, 200}, {301, 399}, {400,499}, {500,600}, {701, 749}, {750,800} };
+ CHECK( seqman_equal( exp4, 7, seqman ) );
+void test_erase()
+ // verify initial state
+ MBEntityHandle exp1[][2] = { {3, 7}, {100, 111}, {1001, 1001} };
+ // try erasing invalid handles at start of existing sequence
+ CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( 1000, 1001 ) );
+ // try erasing invalid entities at end of existing sequence
+ CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( 3, 8 ) );
+ // erase from front of sequence
+ CHECK_ERR( seqman.erase( 3, 6 ) );
+ MBEntityHandle exp2[][2] = { {7, 7}, {100, 111}, {1001, 1001} };
+ CHECK( seqman_equal( exp2, 3, seqman ) );
+ // erase from end of sequence
+ CHECK_ERR( seqman.erase( 110, 111 ) );
+ MBEntityHandle exp3[][2] = { {7, 7}, {100, 109}, {1001, 1001} };
+ CHECK( seqman_equal( exp3, 3, seqman ) );
+ // erase from middle of sequence
+ CHECK_ERR( seqman.erase( 105, 107 ) );
+ MBEntityHandle exp4[][2] = { {7, 7}, {100, 104}, {108,109}, {1001, 1001} };
+ CHECK( seqman_equal( exp4, 4, seqman ) );
+ // erase sequence
+ CHECK_ERR( seqman.erase( 7, 7 ) );
+ MBEntityHandle exp5[][2] = { {100, 104}, {108,109}, {1001, 1001} };
+ CHECK( seqman_equal( exp5, 3, seqman ) );
+ // erase sequence
+ CHECK_ERR( seqman.erase( 108, 109 ) );
+ MBEntityHandle exp6[][2] = { {100, 104}, {1001, 1001} };
+ CHECK( seqman_equal( exp6, 2, seqman ) );
+ // erase sequence
+ CHECK_ERR( seqman.erase( 100, 104 ) );
+ MBEntityHandle exp7[][2] = { {1001, 1001} };
+ CHECK( seqman_equal( exp7, 1, seqman ) );
+ // erase sequence
+ CHECK_ERR( seqman.erase( 1001, 1001 ) );
+ bool append;
+ TypeSequenceManager::iterator seq;
+ make_basic_sequence( seqman ); // { [3,7], [100,111], [1001] }
+ seq = seqman.find_free_handle( 0, MB_END_ID, append );
+ CHECK( seq != seqman.end() );
+ // expect the first available handle (2).
+ CHECK_EQUAL( (MBEntityHandle)3, (*seq)->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)7, (*seq)-> end_handle() );
+ CHECK( !append );
+ // Expect end() if no adjacent sequence
+ seq = seqman.find_free_handle( 9, 98, append );
+ CHECK( seq == seqman.end() );
+ // Try a limited handle range
+ seq = seqman.find_free_handle( 8, 99, append );
+ // expect the first available handle (8).
+ CHECK( append );
+ // Try an unambigious case (above tests have multiple
+ // possible answers, were we assume the first available
+ // handle).
+ seq = seqman.find_free_handle( 8, 98, append );
+ CHECK( append );
+ // handle).
+ seq = seqman.find_free_handle( 9, 99, append );
+ CHECK_EQUAL( (MBEntityHandle)100, (*seq)->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)111, (*seq)-> end_handle() );
+ CHECK( !append );
+ // Try a case where the expected result handle
+ // is in the middle of the input range.
+ seq = seqman.find_free_handle( 900, 1100, append );
+ CHECK_EQUAL( (MBEntityHandle)1001, (*seq)->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)1001, (*seq)-> end_handle() );
+ // Expect first available handle
+ CHECK( !append );
+ MBEntityHandle start;
+ SequenceData* expdata = (*seqman.begin())->data();
+ start = seqman.find_free_sequence( 2, 1, 3, data );
+ CHECK_EQUAL( expdata, data );
+ CHECK_EQUAL( (MBEntityHandle)1, start );
+ start = seqman.find_free_sequence( 3, 1, 7, data );
+ CHECK_EQUAL( (MBEntityHandle)0, start );
+ CHECK_EQUAL( NULL, data );
+ start = seqman.find_free_sequence( 30, 1, 120, data );
+ CHECK( start == 8 || start == 70 );
+ start = seqman.find_free_sequence( 10, 92, 999, data );
+ CHECK_EQUAL( (MBEntityHandle)112, start );
+ start = seqman.find_free_sequence( 100, 1, 600, data );
+ start = seqman.find_free_sequence( 1000, 1, MB_END_ID, data );
+ CHECK_EQUAL( (MBEntityHandle)1002, start );
+ start = seqman.find_free_sequence( 980, 1, 1800, data );
+ CHECK( !seqman.is_free_sequence( 1, 3, data ) );
+ CHECK( seqman.is_free_sequence( 1, 2, data ) );
+ CHECK( !seqman.is_free_sequence( 7, 93, data ) );
+ CHECK( !seqman.is_free_sequence( 8, 93, data ) );
+ CHECK( seqman.is_free_sequence( 8, 92, data ) );
+ CHECK( !seqman.is_free_sequence( 111, 890, data ) );
+ CHECK( !seqman.is_free_sequence( 112, 890, data ) );
+ CHECK( seqman.is_free_sequence( 112, 879, data ) );
+ CHECK( seqman.is_free_sequence( 1002, 1, data ) );
+ CHECK( seqman.is_free_sequence( 2000, 20000, data ) );
+ // Construct a TypeSequenceManager with the following data:
+ // EntitySequence: |[1,500]| |[601,1000]| |[2500,2599]| |[2800,2999]|
+ // SequenceData: | [1,1000] | | [2001,3000] |
+ SequenceData* data1 = new SequenceData(0, 1,1000);
+ SequenceData* data2 = new SequenceData(0,2001,3000);
+ CHECK( insert_seq( seqman, 1, 500, data1, true ) );
+ CHECK( insert_seq( seqman, 601, 400, data1, false ) );
+ CHECK( insert_seq( seqman, 2500, 100, data2, true ) );
+ CHECK( insert_seq( seqman, 2800, 200, data2, false ) );
+ // Begin tests
+ SequenceData* data;
+ MBEntityHandle first, last;
+ // Test handle in use
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 1, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 300, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 500, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 601, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle(2500, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle(2599, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle(2800, seq, data, first, last ) );
+ CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle(2999, seq, data, first, last ) );
+ // Test prepend to sequence
+ seq = seqman.end(); data = 0; first = last = 0;
+ CHECK( seqman.is_free_handle( 600, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)601, (*seq)->start_handle() );
+ CHECK_EQUAL( data1, data );
+ CHECK_EQUAL( (MBEntityHandle)600, first );
+ CHECK_EQUAL( (MBEntityHandle)600, last );
+ CHECK( seqman.is_free_handle( 2499, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)2500, (*seq)->start_handle() );
+ CHECK_EQUAL( data2, data );
+ CHECK_EQUAL( (MBEntityHandle)2499, first );
+ CHECK_EQUAL( (MBEntityHandle)2499, last );
+ CHECK( seqman.is_free_handle( 2799, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)2800, (*seq)->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)2799, first );
+ CHECK_EQUAL( (MBEntityHandle)2799, last );
+ // Test append to sequence
+ CHECK( seqman.is_free_handle( 501, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)1, (*seq)->start_handle() );
+ CHECK_EQUAL( (MBEntityHandle)501, first );
+ CHECK_EQUAL( (MBEntityHandle)501, last );
+ CHECK( seqman.is_free_handle( 2600, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)2600, first );
+ CHECK_EQUAL( (MBEntityHandle)2600, last );
+ CHECK( seqman.is_free_handle( 3000, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)3000, first );
+ CHECK_EQUAL( (MBEntityHandle)3000, last );
+ // Test new sequence in existing SequenceData
+ CHECK( seqman.is_free_handle( 502, seq, data, first, last ) );
+ CHECK( seqman.end() == seq );
+ CHECK( seqman.is_free_handle( 599, seq, data, first, last ) );
+ CHECK( seqman.is_free_handle( 2001, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)2001, first );
+ CHECK( seqman.is_free_handle( 2498, seq, data, first, last ) );
+ // Test new SequenceData
+ CHECK( seqman.is_free_handle( 1001, seq, data, first, last ) );
+ CHECK_EQUAL( (SequenceData*)0, data );
+ CHECK_EQUAL( (MBEntityHandle)1001, first );
+ CHECK_EQUAL( (MBEntityHandle)2000, last );
+ CHECK( seqman.is_free_handle( 1500, seq, data, first, last ) );
+ CHECK( seqman.is_free_handle( 2000, seq, data, first, last ) );
+ CHECK( seqman.is_free_handle( 3001, seq, data, first, last ) );
+ CHECK_EQUAL( (MBEntityHandle)3001, first );
+ CHECK_EQUAL( (MBEntityHandle)MB_END_ID, last );
+ CHECK( seqman.is_free_handle( 10000, seq, data, first, last ) );
Added: MOAB/trunk/TestUtil.hpp
--- MOAB/trunk/TestUtil.hpp (rev 0)
+++ MOAB/trunk/TestUtil.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,225 @@
+#ifndef TEST_UTIL_HPP
+#define TEST_UTIL_HPP
+#define NOFORK
+#include <math.h>
+/** Check that A is MB_SUCCESS */
+#define CHECK_ERR( A ) check_equal( MB_SUCCESS, (A), "MB_SUCCESS", #A, __LINE__, __FILE__ )
+/** Ensure that A is true */
+#define CHECK( A ) check_true( (A), #A, __LINE__, __FILE__ )
+/** Check that two values are equal */
+#define CHECK_EQUAL( EXP, ACT ) check_equal( (EXP), (ACT), #EXP, #ACT, __LINE__, __FILE__ )
+/** Check that two real (float or double) values are equal within EPS */
+#define CHECK_REAL_EQUAL( EXP, ACT, EPS ) check_equal( (EXP), (ACT), (EPS), #EXP, #ACT, __LINE__, __FILE__ )
+/** Run a test
+ * Argument should be a function with the signature: void func(void)
+#define RUN_TEST( FUNC ) run_test( &FUNC, #FUNC )
+#include <stdio.h>
+#include <stdlib.h>
+#if defined(_MSC_VER) || defined(NOFORK)
+ struct ErrorExcept{};
+# define FLAG_ERROR throw ErrorExcept()
+#else
+# include <sys/types.h>
+# include <sys/wait.h>
+# include <unistd.h>
+# include <errno.h>
+# define FLAG_ERROR exit(1)
+#endif
+/* Make sure IS_BUILDING_MB is defined so we can include MBInternals.hpp */
+#include "MBTypes.h"
+#ifndef IS_BUILDING_MB
+# define IS_BUILDING_MB
+# include "MBInternals.hpp"
+# undef IS_BUILDING_MB
+#else
+#endif
+typedef void (*test_func)(void);
+int run_test( test_func test, const char* func_name )
+ printf("Running %s ...\n", func_name );
+ /* On Windows, run all tests in same process.
+ Flag errors by throwing an exception.
+ try {
+ (*test)();
+ return 0;
+ catch (ErrorExcept) {
+ printf( " %s: FAILED\n", func_name );
+ return 1;
+ catch (...) {
+ printf( " %s: UNCAUGHT EXCEPTION\n", func_name );
+ return 1;
+#else
+ /* For non-Windows OSs, fork() and run test in child process. */
+ pid_t pid = fork();
+ int status;
+ /* Fork failed? */
+ if (pid == -1) {
+ perror( "fork()" );
+ abort(); /* abort all tests (can't fork child processes) */
+ /* If child process*/
+ if (pid == 0) {
+ (*test)(); /* call test function */
+ exit(0); /* if function returned, then it succeeded */
+ /* If here, then parent process */
+ /* Wait until child process exists */
+ waitpid( pid, &status, 0 );
+ /* Check child exit status */
+ if (WIFSIGNALED(status)) {
+ if (WTERMSIG(status))
+ printf(" %s: TERMINATED (signal %d)\n", func_name, (int)WTERMSIG(status) );
+ if (WCOREDUMP(status))
+ printf(" %s: CORE DUMP\n", func_name);
+ return 1;
+ else if(WEXITSTATUS(status)) {
+ return 1;
+ else {
+ return 0;
+#endif
+#define EQUAL_TEST_IMPL( TEST, TYPE ) if( !(TEST) ) { \
+ printf( "Equality Test Failed: %s == %s\n", sA, sB ); \
+ printf( " at line %d of '%s'\n", line, file ); \
+ printf( " Expected value: %" #TYPE "\n", A ); \
+ printf( " Actual value: %" #TYPE "\n", B ); \
+ printf( "\n" ); \
+ FLAG_ERROR; \
+void check_equal( int A, int B, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( A == B, d ) }
+void check_equal( unsigned A, unsigned B, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( A == B, u ) }
+void check_equal( long A, long B, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( A == B, ld ) }
+void check_equal( unsigned long A, unsigned long B, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( A == B, lu ) }
+void check_equal( void* A, void* B, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( A == B, p ) }
+void check_equal( float A, float B, float eps, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( fabsf(A - B) <= eps, f ) }
+void check_equal( double A, double B, float eps, const char* sA, const char* sB, int line, const char* file )
+ { EQUAL_TEST_IMPL( fabs(A - B) <= eps, f ) }
+const char* mb_error_str( MBErrorCode err )
+ switch (err) {
+ case MB_SUCCESS : return "Success";
+ case MB_INDEX_OUT_OF_RANGE : return "Index Out of Range";
+ case MB_TYPE_OUT_OF_RANGE : return "Type Out of Range";
+ case MB_MEMORY_ALLOCATION_FAILED: return "Memory Alloc. Failed";
+ case MB_ENTITY_NOT_FOUND : return "Entity Not Found";
+ case MB_MULTIPLE_ENTITIES_FOUND : return "Multiple Entities Found";
+ case MB_TAG_NOT_FOUND : return "Tag Not Found";
+ case MB_FILE_DOES_NOT_EXIST : return "File Not Found";
+ case MB_FILE_WRITE_ERROR : return "File Write Error";
+ case MB_NOT_IMPLEMENTED : return "Not Implemented";
+ case MB_ALREADY_ALLOCATED : return "Already Allocated";
+ case MB_FAILURE : return "Failure";
+ default : return "(unknown)";
+void check_equal( MBErrorCode A, MBErrorCode B, const char* sA, const char* sB, int line, const char* file )
+ if (A == B)
+ return;
+ printf( "MBErrorCode Test Failed: %s == %s\n", sA, sB );
+ printf( " Expected value: %s (%d)\n", mb_error_str(A), (int)A );
+ printf( " Actual value: %s (%d)\n", mb_error_str(B), (int)B );
+ printf( "\n" );
+ FLAG_ERROR;
+const char* mb_type_str( MBEntityType type )
+ switch(type) {
+ case MBVERTEX : return "Vertex";
+ case MBEDGE : return "Edge";
+ case MBTRI : return "Triangle";
+ case MBQUAD : return "Quadrilateral";
+ case MBPOLYGON : return "Polygon";
+ case MBTET : return "Tetrahedron";
+ case MBPYRAMID : return "Pyramid";
+ case MBPRISM : return "Prism (wedge)";
+ case MBKNIFE : return "Knife";
+ case MBHEX : return "Hexahedron";
+ case MBPOLYHEDRON: return "Polyhedron";
+ case MBENTITYSET : return "Entity (Mesh) Set";
+ case MBMAXTYPE : return "(max type)";
+const char* mb_type_str( MBEntityHandle a )
+ { return mb_type_str( TYPE_FROM_HANDLE(a) ); }
+void check_equal( MBEntityHandle A, MBEntityHandle B, const char* sA, const char* sB, int line, const char* file )
+ if (A == B)
+ return;
+ printf( "Entity handles not equal: %s == %s\n", sA, sB );
+ if (A)
+ printf( " Expected value: %lx (%s %ld)\n", (unsigned long)A, mb_type_str( A ), (long)ID_FROM_HANDLE(A) );
+ else
+ printf( " Expected value: 0\n" );
+ if (B)
+ printf( " Actual value: %lx (%s %ld)\n", (unsigned long)B, mb_type_str( B ), (long)ID_FROM_HANDLE(B) );
+ else
+ printf( " Actual value: 0\n" );
+ printf( "\n" );
+ FLAG_ERROR;
+void check_true( bool cond, const char* str, int line, const char* file )
+ if( !cond ) {
+ printf( "Test Failed: %s\n", str );
+ printf( "\n" );
+ FLAG_ERROR;
+#endif
Added: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp (rev 0)
+++ MOAB/trunk/TypeSequenceManager.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,887 @@
+#include "SequenceData.hpp"
+#include <assert.h>
+TypeSequenceManager::~TypeSequenceManager()
+ // We assume that for there to be multiple squences referenceing
+ // the same SequenceData, there must be some portion of the
+ // SequenceData that is unused. Otherwise the sequences should
+ // have been merged. Given that assumption, it is the case that
+ // either a) a SequenceData is in availableList or b) the
+ // SequenceData is referenced by exactly one sequence.
+ // Delete every entity sequence
+ for (iterator i = begin(); i != end(); ++i) {
+ EntitySequence* seq = *i;
+ // check for case b) above
+ if (seq->using_entire_data()) {
+ // delete sequence before data, because sequence
+ // has a pointer to data and may try to dereference
+ // that pointer during its destruction.
+ SequenceData* data = seq->data();
+ delete seq;
+ delete data;
+ else {
+ delete seq;
+ sequenceSet.clear();
+ // case a) above
+ for (data_iterator i = availableList.begin(); i != availableList.end(); ++i)
+ delete *i;
+ availableList.clear();
+MBErrorCode TypeSequenceManager::merge_internal( iterator i, iterator j )
+ EntitySequence* dead = *j;
+ sequenceSet.erase( j );
+ MBErrorCode rval = (*i)->merge( *dead );
+ sequenceSet.insert( dead );
+ return rval;
+ if (lastReferenced == dead)
+ lastReferenced = *i;
+ delete dead;
+ // If merging results in no unused portions of the SequenceData,
+ // remove it from the available list.
+ if ((*i)->using_entire_data())
+ availableList.erase( (*i)->data() );
+ return MB_SUCCESS;
+MBErrorCode TypeSequenceManager::check_merge_next( iterator i )
+ iterator j = i; ++j;
+ if (j == end() || (*j)->data() != (*i)->data() ||
+ (*j)->start_handle() > (*i)->end_handle() + 1)
+ assert( (*i)->end_handle() + 1 == (*j)->start_handle() );
+ return merge_internal( i, j );
+MBErrorCode TypeSequenceManager::check_merge_prev( iterator i )
+ if (i == begin())
+ iterator j = i; --j;
+ if ((*j)->data() != (*i)->data() ||
+ (*j)->end_handle() + 1 < (*i)->start_handle())
+ assert( (*j)->end_handle() + 1 == (*i)->start_handle() );
+MBErrorCode TypeSequenceManager::insert_sequence( EntitySequence* seq_ptr )
+ if (!seq_ptr->data())
+ iterator i = lower_bound( seq_ptr->start_handle() );
+ if (i != end()) {
+ if ((*i)->start_handle() <= seq_ptr->end_handle())
+ return MB_ALREADY_ALLOCATED;
+ if (seq_ptr->data() != (*i)->data() &&
+ (*i)->data()->start_handle() <= seq_ptr->data()->end_handle())
+ if (i != begin()) {
+ if (seq_ptr->data() != (*j)->data() &&
+ (*j)->data()->end_handle() >= seq_ptr->data()->start_handle())
+ i = sequenceSet.insert( i, seq_ptr );
+ // merge with previous sequence ?
+ if (seq_ptr->start_handle() > seq_ptr->data()->start_handle() && i != begin()) {
+ if (MB_SUCCESS != check_merge_prev( i )) {
+ sequenceSet.erase( i );
+ // merge with next sequence ?
+ if ((*i)->end_handle() < (*i)->data()->end_handle()) {
+ if (MB_SUCCESS != check_merge_next( i )) {
+ // We merged adjacent sequences sharing a SequenceData, so
+ // we can safely assume that unless this EntitySequence is
+ // using the entire SequenceData, there are unused portions.
+ if (!seq_ptr->using_entire_data())
+ availableList.insert( seq_ptr->data() );
+ // lastReferenced is only allowed to be NULL if there are
+ // no sequences (avoids unnecessary if's in fast path).
+ if (!lastReferenced)
+ lastReferenced = seq_ptr;
+ // Each SequenceData has a pointer to the first EntitySequence
+ // referencing it. Update that pointer if the new sequence is
+ // the first one.
+ if ((*i)->start_handle() == (*i)->data()->start_handle() ||
+ lower_bound( (*i)->data()->start_handle() ) == i)
+ (*i)->data()->seqManData.firstSequence = i;
+ assert( check_valid_data( seq_ptr ) );
+MBErrorCode TypeSequenceManager::replace_subsequence( EntitySequence* seq_ptr,
+ TagServer* tag_server )
+ // find the sequence of interest
+ if (i == end() || (*i)->data() == seq_ptr->data())
+ if (seq_ptr->start_handle() < (*i)->start_handle() ||
+ seq_ptr->end_handle() > (*i)->end_handle())
+ (*i)->data()->move_tag_data( seq_ptr->data(), tag_server );
+ // Get the range of sequences that point to the shared
+ // SequenceData instance. Untimately, should have the
+ // following iterators:
+ // p : first sequence sharing SequenceData
+ // j : last sequence before where seq_ptr will be (or i if no prev seq)
+ // i : first sequence after where seq_ptr will be (or j if no next seq)
+ // n : the last sequence sharing the SequenceData
+ iterator j = i, n = i;
+ iterator p = (*i)->data()->seqManData.firstSequence;
+ for (++n; n != end() && (*n)->data() == (*i)->data(); ++n);
+ --n;
+ // quick case -- replacing entire, single sequence
+ if (n == p &&
+ (*i)->start_handle() == seq_ptr->start_handle() &&
+ (*i)->end_handle() == seq_ptr->end_handle())
+ // delete old sequence and data (sequence first in case
+ // it needs to reference data during destruction)
+ if (!seq->using_entire_data())
+ availableList.erase( data );
+ delete seq;
+ delete data;
+ // update structures for tracking sequences
+ iterator d = i++;
+ sequenceSet.erase( d );
+ // make sure lastReferenced isn't stale
+ if (lastReferenced == seq)
+ // each SequenceData has pointer to the first EntitySequence referencing it
+ seq_ptr->data()->seqManData.firstSequence = i;
+ // remove entities in new sequence from current sequence list
+ if ((*i)->start_handle() == seq_ptr->start_handle()) {
+ if (j != p)
+ --j;
+ (*i)->pop_front( seq_ptr->end_handle() - seq_ptr->start_handle() + 1 );
+ else if ((*i)->end_handle() == seq_ptr->end_handle()) {
+ (*i)->pop_back( seq_ptr->end_handle() - seq_ptr->start_handle() + 1 );
+ if (i != n)
+ ++i;
+ else {
+ i = split_sequence( i, seq_ptr->start_handle() );
+ if (n == j)
+ n = i;
+ // split underlying sequence data
+ SequenceData* dead_data = (*i)->data();
+ availableList.erase( dead_data );
+ if (p != i) {
+ SequenceData* new_data = (*p)->create_data_subset( (*p)->start_handle(), (*j)->end_handle() );
+ new_data->seqManData.firstSequence = p;
+ iterator s = j;
+ for (++s; p != s; ++p)
+ (*p)->data( new_data );
+ dead_data->move_tag_data( new_data, tag_server );
+ if (j != n) {
+ SequenceData* new_data = (*n)->create_data_subset( (*i)->start_handle(), (*n)->end_handle() );
+ new_data->seqManData.firstSequence = i;
+ for (++n; i != n; ++i)
+ (*i)->data( new_data );
+ delete dead_data;
+ // put new sequence in lists
+ return insert_sequence( seq_ptr );
+TypeSequenceManager::iterator TypeSequenceManager::erase( iterator i )
+ iterator j;
+ // check if we need to delete the referenced SequenceData also
+ bool delete_data;
+ if (seq->using_entire_data()) // only sequence
+ delete_data = true;
+ else if (data->seqManData.firstSequence != i) {// earlier sequence?
+ delete_data = false;
+ availableList.insert( data );
+ else { // later sequence ?
+ j = i; ++j;
+ delete_data = (j == end() || (*j)->data() != data);
+ if (delete_data)
+ else {
+ data->seqManData.firstSequence = j;
+ // remove sequence, updating i to be next sequence
+ j = i++;
+ // Make sure lastReferenced isn't stale. It can only be NULL if
+ // no sequences.
+ lastReferenced = sequenceSet.empty() ? 0 : *sequenceSet.begin();
+ // Always delete sequence before the SequenceData it references.
+ assert( 0 == find(seq->start_handle()) );
+ delete seq;
+ if (delete_data)
+ delete data;
+ else {
+ assert( check_valid_data( *data->seqManData.firstSequence ) );
+ assert( lastReferenced != seq );
+ return i;
+MBErrorCode TypeSequenceManager::remove_sequence( const EntitySequence* seq_ptr,
+ bool& unreferenced_data )
+ // remove sequence from set
+ if (i == end() || *i != seq_ptr)
+ return MB_ENTITY_NOT_FOUND;
+ // check if this is the only sequence referencing its data
+ if (seq_ptr->using_entire_data())
+ unreferenced_data = true;
+ else {
+ i = lower_bound( seq_ptr->data()->start_handle() );
+ unreferenced_data = i == end() || (*i)->data() != seq_ptr->data();
+ if (unreferenced_data)
+ availableList.erase( seq_ptr->data() );
+ else
+ seq_ptr->data()->seqManData.firstSequence = i; // might be 'i' already
+ if (lastReferenced == seq_ptr)
+TypeSequenceManager::find_free_handle( MBEntityHandle min_start_handle,
+ MBEntityHandle max_end_handle,
+ bool& append_out,
+ int values_per_ent )
+ for (data_iterator i = availableList.begin(); i != availableList.end(); ++i) {
+ if ((*(*i)->seqManData.firstSequence)->values_per_entity() != values_per_ent)
+ continue;
+ if ((*i)->start_handle() > max_end_handle || (*i)->end_handle() < min_start_handle)
+ continue;
+ for (iterator j = (*i)->seqManData.firstSequence;
+ j != end() && (*j)->start_handle() <= (max_end_handle + 1) && (*j)->data() == *i;
+ ++j) {
+ if ((*j)->end_handle() + 1 < min_start_handle)
+ continue;
+ if ((*j)->start_handle() > (*i)->start_handle() &&
+ (*j)->start_handle() > min_start_handle) {
+ append_out = false;
+ return j;
+ if ((*j)->end_handle() < (*i)->end_handle() &&
+ (*j)->end_handle() < max_end_handle) {
+ append_out = true;
+ return j;
+ return end();
+bool TypeSequenceManager::is_free_sequence( MBEntityHandle start,
+ SequenceData*& data_out,
+ data_out = 0;
+ if (empty())
+ return true;
+ const_iterator i = lower_bound( start );
+ if (i == end()) {
+ --i; // safe because already tested empty()
+ // if we don't overlap the last data object...
+ if ((*i)->data()->end_handle() < start)
+ return true;
+ data_out = (*i)->data();
+ if ((*i)->values_per_entity() != values_per_ent)
+ return false;
+ // if we overlap a data object, we must be entirely inside of it
+ return start + num_entities - 1 <= (*i)->data()->end_handle();
+ // check if we fit in the block of free handles
+ if (start + num_entities > (*i)->start_handle()) // start + num + 1 >= i->start
+ return false;
+ // check if we overlap the data for the next sequence
+ if (start + num_entities > (*i)->data()->start_handle()) {
+ return false;
+ // if overlap, must be entirely contained
+ return start >= data_out->start_handle();
+ // check if we overlap the data for the previous sequence
+ --i;
+ if ((*i)->data()->end_handle() >= start) {
+ return false;
+ // unused handle block that overlaps no SequenceData
+ return true;
+MBEntityHandle TypeSequenceManager::find_free_block( MBEntityID num_entities,
+ MBEntityHandle min_start_handle,
+ MBEntityHandle max_end_handle )
+ const_iterator i = lower_bound( min_start_handle );
+ if (i == end())
+ return min_start_handle;
+ if ((*i)->start_handle() < min_start_handle + num_entities)
+ MBEntityHandle prev_end = (*i)->end_handle(); ++i;
+ for (; i != end(); prev_end = (*i)->end_handle(), ++i) {
+ MBEntityID len = (*i)->start_handle() - prev_end - 1;
+ if (len >= num_entities)
+ break;
+ if (prev_end + num_entities > max_end_handle)
+ return 0;
+ else
+ return prev_end + 1;
+struct range_data {
+ MBEntityID num_entities;
+ MBEntityHandle min_start_handle, max_end_handle;
+static bool check_range( const range_data& d,
+ bool prefer_end,
+ MBEntityHandle& result )
+ MBEntityHandle first = std::max( d.min_start_handle, d.first );
+ MBEntityHandle last = std::min( d.max_end_handle, d.last );
+ if (last < first + d.num_entities - 1) {
+ result = 0;
+ return false;
+ result = prefer_end ? last + 1 - d.num_entities : first;
+ return true;
+MBEntityHandle TypeSequenceManager::find_free_sequence( MBEntityID num_entities,
+ int num_verts )
+ if (max_end_handle < min_start_handle + num_entities - 1)
+ return 0;
+ MBEntityHandle result;
+ iterator p, i = lower_bound( min_start_handle );
+ range_data d = { num_entities, min_start_handle, max_end_handle, 0, 0 };
+ if (i == end()) {
+ data_out = 0;
+ else if (i == begin()) {
+ if ((*i)->values_per_entity() == num_verts) {
+ d.first = (*i)->data()->start_handle();
+ d.last = (*i)->start_handle() - 1;
+ if (check_range( d, true, result )) {
+ return result;
+ d.first = min_start_handle;
+ d.last = (*i)->data()->start_handle() - 1;
+ if (check_range( d, true, result)) {
+ data_out = 0;
+ return result;
+ p = i++;
+ else {
+ p = i;
+ --p;
+ for (; i != end() && (*i)->start_handle() < max_end_handle; p = i++) {
+ if ((*p)->data() == (*i)->data()) {
+ if ((*p)->values_per_entity() == num_verts) {
+ d.first = (*p)->end_handle() + 1;
+ if (check_range( d, false, result )) {
+ data_out = (*p)->data();
+ return result;
+ else {
+ d.last = (*p)->data()->end_handle();
+ return result;
+ return result;
+ d.first = (*p)->data()->end_handle() + 1;
+ data_out = 0;
+ return result;
+ return result;
+ d.last = max_end_handle;
+ data_out = 0;
+ return result;
+ data_out = 0;
+ return 0;
+MBErrorCode TypeSequenceManager::check_valid_handles( MBEntityHandle first,
+ MBEntityHandle last ) const
+ iterator i = lower_bound( first );
+ if (i == end() || (*i)->start_handle() > first)
+ while ((*i)->end_handle() < last) {
+ ++i;
+ if (i == end() || prev_end + 1 != (*i)->start_handle())
+MBErrorCode TypeSequenceManager::erase( MBEntityHandle h )
+ EntitySequence* seq = find(h);
+ if (!seq)
+ if (seq->start_handle() == h) {
+ if (seq->end_handle() != h)
+ return seq->pop_front(1);
+ bool delete_data;
+ MBErrorCode rval = remove_sequence( seq, delete_data );
+ if (MB_SUCCESS != rval)
+ return rval;
+ delete seq;
+ if (delete_data)
+ delete data;
+ else if (seq->end_handle() == h)
+ return seq->pop_back(1);
+ else {
+ iterator i = lower_bound( h );
+ i = split_sequence( i, h );
+ seq = *i;
+ assert(seq->start_handle() == h);
+MBErrorCode TypeSequenceManager::erase( MBEntityHandle first, MBEntityHandle last )
+ // first check that all entities in range are valid
+ MBErrorCode rval = check_valid_handles( first, last );
+ return rval;
+ // now remove entities
+ // get first sequence intersecting range
+ if (i == end()) // shouuldn't be possible given check_valid_handles call above.
+ // if range is entirely in interior of sequence, need to split sequence.
+ if ((*i)->start_handle() < first && (*i)->end_handle() > last) {
+ availableList.insert( (*i)->data() );
+ i = split_sequence( i, first );
+ (*i)->pop_front( last - first + 1 );
+ assert( check_valid_data( *i ) );
+ // if range doesn't entirely contain first sequence, remove some
+ // handles from the end of the sequence and advance to the next
+ // sequence.
+ if ((*i)->start_handle() < first) {
+ (*i)->pop_back((*i)->end_handle() - first + 1);
+ ++i;
+ // destroy all sequences contained entirely within the range
+ while (i != end() && (*i)->end_handle() <= last)
+ i = erase(i);
+ // if necesessary, remove entities from the beginning of the
+ // last sequence.
+ if (i != end() && (*i)->start_handle() <= last) {
+ (*i)->pop_front( last - (*i)->start_handle() + 1 );
+TypeSequenceManager::split_sequence( iterator i, MBEntityHandle h )
+ EntitySequence* seq = (*i)->split( h );
+ if (!seq)
+ return end();
+ i = sequenceSet.insert( i, seq );
+ return i;
+MBErrorCode
+TypeSequenceManager::is_free_handle( MBEntityHandle handle,
+ iterator& seq_iter_out,
+ SequenceData*& data_ptr_out,
+ MBEntityHandle& block_start,
+ MBEntityHandle& block_end,
+ int junk;
+ block_start = CREATE_HANDLE( TYPE_FROM_HANDLE(handle), MB_START_ID, junk );
+ block_end = CREATE_HANDLE( TYPE_FROM_HANDLE(handle), MB_END_ID, junk );
+ iterator i = lower_bound( handle );
+ if (i != end()) {
+ block_end = (*i)->start_handle() - 1;
+ // if sequence contains handle, then already allocated
+ if ((*i)->start_handle() <= handle)
+ // handle is not within an existing sequence, but is
+ // within an existing SequenceData...
+ if ((*i)->data()->start_handle() <= handle) {
+ // if values_per_entity don't match, can't put new entity
+ // in existing SequenceData
+ data_ptr_out = (*i)->data();
+ if (block_end == handle) {
+ // prepend to existing sequence
+ seq_iter_out = i;
+ block_start = handle;
+ else {
+ // add new sequence to existing SequenceData
+ seq_iter_out = end();
+ if (i == begin() || (*--i)->data() != data_ptr_out)
+ block_start = data_ptr_out->start_handle();
+ else
+ block_start = (*i)->end_handle() + 1;
+ --i;
+ // handle is within previous sequence data...
+ if ((*i)->data()->end_handle() >= handle) {
+ if (block_start == handle) {
+ // append to existing sequence
+ seq_iter_out = i;
+ block_end = handle;
+ else {
+ if (++i == end() || (*i)->data() != data_ptr_out)
+ block_end = data_ptr_out->end_handle();
+ else
+ data_ptr_out = 0;
+MBErrorCode TypeSequenceManager::notify_appended( iterator seq )
+ MBErrorCode rval = check_merge_next( seq );
+ if ((*seq)->using_entire_data())
+ availableList.erase( (*seq)->data() );
+ return rval;
+MBErrorCode TypeSequenceManager::notify_prepended( iterator seq )
+ MBErrorCode rval = check_merge_prev( seq );
+ return rval;
+void TypeSequenceManager::get_memory_use( unsigned long& entity_storage,
+ entity_storage = total_storage = 0;
+ if (empty())
+ return;
+ MBEntityType mytype = TYPE_FROM_HANDLE(lastReferenced->start_handle());
+ int junk;
+ get_memory_use( CREATE_HANDLE( mytype, MB_START_ID, junk ),
+ CREATE_HANDLE( mytype, MB_END_ID, junk ),
+ entity_storage,
+ total_storage );
+void TypeSequenceManager::append_memory_use( MBEntityHandle first,
+ MBEntityHandle last,
+ const SequenceData* data,
+ unsigned long& entity_storage,
+ const unsigned long allocated_count = data->size();
+ unsigned long bytes_per_ent, seq_size;
+ const_iterator i = data->seqManData.firstSequence;
+ (*i)->get_const_memory_use( bytes_per_ent, seq_size );
+ unsigned long other_ent_mem = 0;
+ unsigned long occupied_count = 0, entity_count = 0, sequence_count = 0;
+ for (; i != end() && (*i)->data() == data; ++i) {
+ occupied_count += (*i)->size();
+ ++sequence_count;
+ MBEntityHandle start = std::max( first, (*i)->start_handle() );
+ MBEntityHandle stop = std::min( last, (*i)->end_handle() );
+ if (stop < start)
+ continue;
+ entity_count += stop - start + 1;
+ other_ent_mem += (*i)->get_per_entity_memory_use( start, stop );
+ unsigned long sum = sequence_count * seq_size +
+ allocated_count * bytes_per_ent;
+ // watch for overflow
+ if (std::numeric_limits<unsigned long>::max() / entity_count <= sum) {
+ total_storage += sum * (entity_count / occupied_count) + other_ent_mem;
+ entity_storage += sum * (entity_count / allocated_count) + other_ent_mem;
+ else {
+ total_storage += sum * entity_count / occupied_count + other_ent_mem;
+ entity_storage += sum * entity_count / allocated_count + other_ent_mem;
+void TypeSequenceManager::get_memory_use( MBEntityHandle first,
+ while (first <= last) {
+ const_iterator i = lower_bound(first);
+ if (i == end())
+ return;
+ SequenceData* data = (*i)->data();
+ if (first < data->end_handle()) {
+ append_memory_use( first, last, data, entity_storage, total_storage );
+ first = data->end_handle() + 1;
+#ifndef NDEBUG
+bool TypeSequenceManager::check_valid_data( const EntitySequence* seq ) const
+ // caller passed a sequence that should be contained, so cannot be empty
+ if (empty())
+ return false;
+ // make sure lastReferenced points to something
+ return false;
+ const EntitySequence* seq2 = find( lastReferenced->start_handle() );
+ if (seq2 != lastReferenced)
+ return false;
+ // make sure passed sequence is in list
+ seq2 = find( seq->start_handle() );
+ if (seq2 != seq)
+ return false;
+ // check all sequences referencing the same SequenceData
+ const SequenceData* data = seq->data();
+ const_iterator i = lower_bound( data->start_handle() );
+ if (i != data->seqManData.firstSequence)
+ return false;
+ const_iterator j = i;
+ --j;
+ if ((*j)->end_handle() >= data->start_handle())
+ return false;
+ if ((*j)->data()->end_handle() >= data->start_handle())
+ return false;
+ for (;;) {
+ seq2 = *i;
+ ++i;
+ if (i == end())
+ return true;
+ if ((*i)->data() != data)
+ break;
+ if (seq2->end_handle() >= (*i)->start_handle())
+ return false;
+ if ((*i)->start_handle() <= data->end_handle())
+ return false;
+ if ((*i)->data()->start_handle() <= data->end_handle())
+ return false;
+ return true;
+#endif
Added: MOAB/trunk/TypeSequenceManager.hpp
--- MOAB/trunk/TypeSequenceManager.hpp (rev 0)
+++ MOAB/trunk/TypeSequenceManager.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,374 @@
+#ifndef TYPE_SEQUENCE_MANAGER_HPP
+#define TYPE_SEQUENCE_MANAGER_HPP
+#include "MBRange.hpp"
+#include <set>
+class TagServer;
+/**\brief Maintain data structures organizing EntitySequence instances
+ * EntitySequenceManager is a composition of instances of TypeSequenceManager,
+ * one instance for each MBEntityType. The TypeSequenceManager provides
+ * organization, owership, and querying of EntitySequences for a specific
+ * MBEntityType.
+class TypeSequenceManager
+public:
+ /**\brief Comparision function used in std::set
+ * Define less-than comparison for EntitySequence pointers as a comparison
+ * of the entity handles in the pointed-to EntitySequences.
+ class SequenceCompare {
+ public: bool operator()( const EntitySequence* a, const EntitySequence* b ) const
+ { return a->end_handle() < b->start_handle(); }
+ /**\brief Dummy EntitySequence for use in querying set container */
+ class DummySequence : public EntitySequence {
+ public:
+ DummySequence( MBEntityHandle start )
+ : EntitySequence( start ) {}
+ EntitySequence* split( MBEntityHandle )
+ { return 0; }
+ SequenceData* create_data_subset( MBEntityHandle, MBEntityHandle ) const
+ { return 0; }
+ { a = b = 0; }
+ { return 0; }
+ /**\brief Type of container for organizing EntitySequence instances */
+ typedef std::set<EntitySequence*,SequenceCompare> set_type;
+ /**\brief Iterator for set_type */
+ typedef set_type::iterator iterator;
+ typedef set_type::const_iterator const_iterator;
+ /**\brief Type of container for organizing SequenceData instaces */
+ typedef std::set<SequenceData*> data_set_type;
+ /**\brief iterator type for data_set_type */
+ typedef data_set_type::iterator data_iterator;
+ struct SequenceDataPtr {
+ private:
+ friend class TypeSequenceManager;
+ TypeSequenceManager::iterator firstSequence;
+private:
+ mutable EntitySequence* lastReferenced;//!< Last accessed EntitySequence - Null only if no sequences
+ set_type sequenceSet; //!< Set of all managed EntitySequence instances
+ data_set_type availableList; //!< SequenceData containing unused entries
+ iterator erase( iterator i ); //!< Remove a sequence
+ iterator split_sequence( iterator i, MBEntityHandle h ); //!< split a sequence
+ void append_memory_use( MBEntityHandle first,
+ // check if sequence at passed iterator should be merged with
+ // the subsequent sequence, and if so merge them retaining i.
+ MBErrorCode check_merge_next( iterator i );
+ // the previous sequence, and if so merge them retaining i.
+ MBErrorCode check_merge_prev( iterator i );
+ // common code for check_merge_next and check_merge_prev
+ MBErrorCode merge_internal( iterator keep, iterator dead );
+#ifndef NDEBUG
+ bool check_valid_data( const EntitySequence* seq ) const;
+#endif
+public:
+ /**\brief Add an entity sequence
+ * Take ownership of passed EntitySequence, and update relevant
+ * data structures. Sequence may not overlap with any existing
+ * sequence.
+ * NOTE: Sequence may be merged with other, existing sequences.
+ * This function will always ensure that the passed
+ * EntitySequence* is the remaining one, but the passed
+ * sequence may have modified start and end handles.
+ MBErrorCode insert_sequence( EntitySequence* seq_ptr );
+ /**\brief Remove an entity sequence.
+ * Give up ownership of specified EntitySequence, and remove it
+ * from all internal data structures. Passes back bool flag to
+ * notify caller that ownership of the correspoding SequenceData
+ * is also relinquished because the specified EntitySequence is
+ * the last one referencing it.
+ MBErrorCode remove_sequence( const EntitySequence* seq_ptr,
+ bool& is_last_user_of_sequence_data );
+ /**\brief Replace sequence or subset of sequence
+ * Replace one sequence or a subset of one sequence with
+ * another sequence. With fail if a) the existing
+ * sequence is not a subset of an existing sequence or
+ * b) existing sequence shares a SequenceData with the
+ * passed sequence.
+ * This method is provided for use when changing the
+ * number of nodes in elements.
+ MBErrorCode replace_subsequence( EntitySequence* seq_ptr, TagServer* ts );
+ TypeSequenceManager() : lastReferenced(0) {}
+ ~TypeSequenceManager();
+ /**\brief Start of EntitySequence set */
+ const_iterator begin() const { return sequenceSet.begin(); }
+ /**\brief End of EntitySequence set */
+ const_iterator end() const { return sequenceSet.end(); }
+ /**\brief Return EntitySequence for specified handle.
+ * Return EntitySequence for specified handle, or if
+ * no such sequence, the next one. Returns end() if
+ * all sequences have ranges less than specified handle.
+ const_iterator lower_bound( MBEntityHandle h ) const
+ DummySequence f(h);
+ return sequenceSet.lower_bound( &f );
+ /**\brief Return EntitySequence after specified handle.
+ * Return EntitySequence with smallest start handle
+ * that is greater than input handle. Returns end() if
+ * all sequences have start handles less than specified
+ * handle.
+ const_iterator upper_bound( MBEntityHandle h ) const
+ return sequenceSet.upper_bound( &f );
+ /**\brief Get EntitySequence for handle.
+ *\return EntitySequence for handle, or NULL if no such sequence.
+ inline EntitySequence* find( MBEntityHandle h ) const;
+ inline MBErrorCode find( MBEntityHandle h, EntitySequence*& ) const;
+ /**\brief Get handles for all entities in all sequences. */
+ inline void get_entities( MBRange& entities_out ) const;
+ /**\brief Get number of entities represented by all sequences. */
+ inline MBEntityID get_number_entities() const;
+ MBErrorCode check_valid_handles( MBEntityHandle first, MBEntityHandle last ) const;
+ /**\brief Remove entities
+ * Update EntitySequence data as necessary to "delete" the
+ * specified entities (e.g. split sequences, delete sequences,
+ * free SequenceData instances, etc.)
+ MBErrorCode erase( MBEntityHandle first, MBEntityHandle last );
+ MBErrorCode erase( MBEntityHandle entity );
+ /**\brief Test if this instance contains no sequences */
+ bool empty() const
+ { return 0 == lastReferenced; }
+ /**\brief Allocate a handle in an existing entity sequence
+ * Find an existing entity sequence to which a new handle can
+ * be prepended or appended. The 'append_out' flag indicates
+ * to the caller that the new handle should be appended to the
+ * returned sequence if true, and prepended if false.
+ * If no appropriate EntitySequence is available, NULL will
+ * be returned. The caller will typically then want to use
+ * find_free_sequence() to find appropriate values for the
+ * creation of a new EntitySequence.
+ iterator find_free_handle( MBEntityHandle min_start_handle,
+ bool& append_out,
+ int values_per_ent = 0 );
+ /**\brief Find block of free handles
+ * Find block of free handles, such that block does not
+ * overlap any existing EntitySequence.
+ *\return First handle of block, or zero if no block found.
+ MBEntityHandle find_free_block( MBEntityID num_entities,
+ MBEntityHandle max_end_handle );
+ * Find block of free handles, such that block a) does not
+ * overlap any existing EntitySequence and b) is either
+ * entirely within one existing SequenceData or does not
+ * overlap any SequenceData.
+ *\param num_entities Size of handle block.
+ *\param min_start_handle Block may not contain any handle less than this.
+ *\param max_end_handle Block may not contain any handle greater than this.
+ *\param sequence_data_out If block is within an unused portion of an
+ * existing SequenceData, a pointer to that
+ * SequenceData. NULL otherwise.
+ *\return values_per_ent Matched against EntitySequence::values_per_entity.
+ * An existing SequenceData will not be returned if
+ * the existing EntitySequences using have a different
+ * value than the passed one.
+ MBEntityHandle find_free_sequence( MBEntityID num_entities,
+ SequenceData*& sequence_data_out,
+ /**\brief Check if block of handles is free.
+ * Check if block of handles is free and can be allocated
+ * as a single EntitySequence. If the block of handles
+ * is contained within an unused portion of a SequenceData,
+ * the SequenceData is returned.
+ bool is_free_sequence( MBEntityHandle start_handle,
+ MBEntityID num_entities,
+ /**\brief Check if specific handle is free for allocation
+ * Check if a specific handle is not currently allocated
+ * and can be allocated with the passed value of values_per_ent.
+ * For example, the handle may not be allocated, but it may
+ * fall within an existing SequenceData. In that case, it
+ * must be possible to store the speciified values_per_ent
+ * in the existing SequenceData.
+ * There are four possible return 'states' from this function:
+ * - handle is not available or cannot be allocated with specified
+ * values_per_ent. Returned error code is MB_ALREADY_ALLOCATED.
+ * - handle can be appended or prepended to an existing sequence.
+ * seq_ptr_out is set to the sequence the handle should be added to.
+ * - handle cannot be appended to an existing sequence but falls
+ * within an existing SequenceData. The caller is expected
+ * to create a new sequence referencing that SequenceData. seq_ptr_out
+ * is NULL and data_ptr_out is set to existing SequenceData.
+ * - handle does not correspond to any existing sequence or data.
+ * The caller is expected to create a new sequence and SequenceData.
+ * Both seq_ptr_out and data_ptr_out are set to NULL.
+ * block_start and block_end are set to start and end handles of the
+ * largest sequence that can be allocated and contain the input handle.
+ *\param handle The handle the caller wishes to allocate as a new entity
+ *\param seq_ptr_out Output: pointer to sequence to append or prepend to
+ * to allocate handle. end() if no such sequence.
+ *\param data_ptr_out Output: Pointer to existing SequenceData containing input
+ * handle, or NULL if no such SequenceData.
+ *\param block_start Output: Smallest possible start handle for new sequence.
+ *\param block_end Output: Largest possible end handle for new sequence.
+ MBErrorCode is_free_handle( MBEntityHandle handle,
+ iterator& seq_ptr_out,
+ /**\brief Notify that sequence was prepended to
+ * Notify of sequence modifications so we can check if
+ * sequence needs to be merged.
+ MBErrorCode notify_prepended( iterator seq );
+ /**\brief Notify that sequence was appended to
+ MBErrorCode notify_appended( iterator seq );
+ void get_memory_use( unsigned long& total_entity_storage,
+ unsigned long& total_storage ) const;
+ void get_memory_use( MBEntityHandle start, MBEntityHandle end,
+ unsigned long& total_entity_storage,
+ unsigned long& total_amortized_storage ) const;
+ unsigned long get_sequence_count() const
+ { return sequenceSet.size(); }
+inline EntitySequence* TypeSequenceManager::find( MBEntityHandle h ) const
+ if (!lastReferenced) // only null if empty
+ return 0;
+ else if (h >= lastReferenced->start_handle() && h <= lastReferenced->end_handle())
+ return lastReferenced;
+ else {
+ DummySequence seq(h);
+ iterator i = sequenceSet.find( &seq );
+ return i == end() ? 0 : (lastReferenced = *i);
+inline MBErrorCode TypeSequenceManager::find( MBEntityHandle h, EntitySequence*& seq ) const
+ if (!lastReferenced) { // only null if empty
+ seq = 0;
+ else if (h >= lastReferenced->start_handle() && h <= lastReferenced->end_handle()) {
+ seq = lastReferenced;
+ else {
+ DummySequence ds(h);
+ iterator i = sequenceSet.lower_bound( &ds );
+ if (i == end() || (*i)->start_handle() > h ) {
+ seq = 0;
+ else {
+ seq = lastReferenced = *i;
+inline void TypeSequenceManager::get_entities( MBRange& entities_out ) const
+ MBRange::iterator in = entities_out.begin();
+ for (const_iterator i = begin(); i != end(); ++i)
+ in = entities_out.insert( in, (*i)->start_handle(), (*i)->end_handle() );
+inline MBEntityID TypeSequenceManager::get_number_entities() const
+ MBEntityID count = 0;
+ count += (*i)->size();
+ return count;
+#endif
Added: MOAB/trunk/UnstructuredElemSeq.cpp
--- MOAB/trunk/UnstructuredElemSeq.cpp (rev 0)
+++ MOAB/trunk/UnstructuredElemSeq.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,105 @@
+#include "UnstructuredElemSeq.hpp"
+#include "MBCN.hpp"
+UnstructuredElemSeq::UnstructuredElemSeq( MBEntityHandle start_handle,
+ MBEntityID entity_count,
+ unsigned nodes_per_entity,
+ SequenceData* data )
+ : ElementSequence( start_handle, entity_count, nodes_per_entity, data )
+ MBEntityID data_size )
+ new SequenceData( 1, start_handle, start_handle + data_size - 1))
+ data()->create_sequence_data( 0, nodes_per_entity * sizeof(MBEntityHandle) );
+UnstructuredElemSeq::~UnstructuredElemSeq()
+int UnstructuredElemSeq::values_per_entity() const
+ { return nodes_per_element(); }
+EntitySequence*
+UnstructuredElemSeq::split( MBEntityHandle here )
+ if (here <= start_handle() || here > end_handle())
+ return 0;
+ return new UnstructuredElemSeq( *this, here );
+SequenceData*
+UnstructuredElemSeq::create_data_subset( MBEntityHandle start, MBEntityHandle end ) const
+ int esize = nodes_per_element() * sizeof(MBEntityHandle);
+ return data()->subset(start, end, &esize, 0 );
+void
+UnstructuredElemSeq::get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& size_of_sequence ) const
+ bytes_per_entity = nodes_per_element() * sizeof(MBEntityHandle);
+ size_of_sequence = sizeof(this);
+MBErrorCode
+UnstructuredElemSeq::get_connectivity( MBEntityHandle handle,
+ std::vector<MBEntityHandle>& connect,
+ bool topological ) const
+ MBEntityHandle const* conn = get_array() + nodes_per_element() * (handle - start_handle());
+ int len = topological ? MBCN::VerticesPerEntity(type()) : nodes_per_element();
+ connect.reserve( connect.size() + len );
+ std::copy( conn, conn+len, std::back_inserter( connect ) );
+MBErrorCode
+ MBEntityHandle const*& conn_ptr,
+ int& len,
+ bool topological,
+ std::vector<MBEntityHandle>* ) const
+ conn_ptr = get_array() + nodes_per_element() * (handle - start_handle());
+ len = topological ? MBCN::VerticesPerEntity(type()) : nodes_per_element();
+MBErrorCode
+UnstructuredElemSeq::set_connectivity( MBEntityHandle handle,
+ MBEntityHandle const* connect,
+ int connect_length )
+ if ((unsigned)connect_length != nodes_per_element())
+ return MB_INDEX_OUT_OF_RANGE;
+ MBEntityHandle* conn_ptr = get_array() + nodes_per_element() * (handle - start_handle());
+ std::copy( connect, connect+connect_length, conn_ptr );
+MBEntityHandle* UnstructuredElemSeq::get_connectivity_array()
+ { return get_array(); }
+MBErrorCode UnstructuredElemSeq::push_back( MBEntityID count )
+ { return EntitySequence::append_entities(count); }
+MBErrorCode UnstructuredElemSeq::push_front( MBEntityID count )
+ { return EntitySequence::prepend_entities(count); }
Added: MOAB/trunk/UnstructuredElemSeq.hpp
--- MOAB/trunk/UnstructuredElemSeq.hpp (rev 0)
+++ MOAB/trunk/UnstructuredElemSeq.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,74 @@
+#ifndef UNSTRUCTURED_ELEM_SEQ_HPP
+#define UNSTRUCTURED_ELEM_SEQ_HPP
+#include "ElementSequence.hpp"
+class UnstructuredElemSeq : public ElementSequence
+public:
+ UnstructuredElemSeq( MBEntityHandle start_handle,
+ SequenceData* data );
+ MBEntityID sequence_data_size);
+ ~UnstructuredElemSeq();
+ int values_per_entity() const;
+ EntitySequence* split( MBEntityHandle here );
+ SequenceData* create_data_subset( MBEntityHandle start, MBEntityHandle end ) const;
+ MBErrorCode get_connectivity( MBEntityHandle handle,
+ bool topological = false ) const;
+ MBEntityHandle const*& connect,
+ int &connect_length,
+ bool topological = false,
+ std::vector<MBEntityHandle>* storage = 0
+ ) const;
+ MBErrorCode set_connectivity( MBEntityHandle handle,
+ int connect_length );
+ MBEntityHandle* get_connectivity_array();
+ MBErrorCode push_front( MBEntityID count );
+ MBErrorCode push_back ( MBEntityID count );
+ void get_const_memory_use( unsigned long& bytes_per_entity,
+ unsigned long& size_of_sequence ) const;
+protected:
+ inline MBEntityHandle const* get_array() const
+ return reinterpret_cast<MBEntityHandle const*>(data()->get_sequence_data(0))
+ + nodes_per_element() * (start_handle() - data()->start_handle());
+ inline MBEntityHandle* get_array()
+ return reinterpret_cast<MBEntityHandle*>(data()->get_sequence_data(0))
+ UnstructuredElemSeq( UnstructuredElemSeq& split_from, MBEntityHandle here )
+ : ElementSequence( split_from, here )
+#endif
Added: MOAB/trunk/VertexSequence.cpp
--- MOAB/trunk/VertexSequence.cpp (rev 0)
+++ MOAB/trunk/VertexSequence.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,25 @@
+#include "VertexSequence.hpp"
+VertexSequence::~VertexSequence() {}
+EntitySequence* VertexSequence::split( MBEntityHandle here )
+ { return new VertexSequence( *this, here ); }
+SequenceData* VertexSequence::create_data_subset( MBEntityHandle start,
+ MBEntityHandle end ) const
+ const int sizes[] = { sizeof(double), sizeof(double), sizeof(double) };
+ return data()->subset(start, end, sizes, 0 );
+MBErrorCode VertexSequence::push_back( MBEntityID count )
+MBErrorCode VertexSequence::push_front( MBEntityID count )
+void VertexSequence::get_const_memory_use( unsigned long& per_ent, unsigned long& seq ) const
+ per_ent = 3 * sizeof(double);
+ seq = sizeof(*this);
Added: MOAB/trunk/VertexSequence.hpp
--- MOAB/trunk/VertexSequence.hpp (rev 0)
+++ MOAB/trunk/VertexSequence.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -0,0 +1,171 @@
+#ifndef VERTEX_SEQUENCE_HPP
+#define VERTEX_SEQUENCE_HPP
+#include "EntitySequence.hpp"
+class VertexSequence : public EntitySequence
+public:
+ VertexSequence( MBEntityHandle start,
+ MBEntityID count,
+ : EntitySequence( start, count, data )
+ MBEntityID count,
+ : EntitySequence( start, count, new SequenceData( 3, start, start+data_size-1 ) )
+ data()->create_sequence_data( X, sizeof(double) );
+ data()->create_sequence_data( Y, sizeof(double) );
+ data()->create_sequence_data( Z, sizeof(double) );
+ virtual ~VertexSequence();
+ inline MBErrorCode get_coordinates( MBEntityHandle handle,
+ double& x,
+ double& y,
+ double& z ) const;
+ double coords[3] ) const;
+ inline MBErrorCode get_coordinates_ref( MBEntityHandle handle,
+ const double*& x,
+ const double*& y,
+ const double*& z ) const;
+ inline MBErrorCode set_coordinates( MBEntityHandle entity,
+ double x,
+ double y,
+ double z );
+ const double xyz[3] );
+ inline MBErrorCode get_coordinate_arrays( double*& x,
+ double*& y,
+ double*& z );
+ inline MBErrorCode get_coordinate_arrays( const double*& x,
+ const double*& y,
+ MBErrorCode push_back( MBEntityID count );
+private:
+ enum Coord{ X = 0, Y = 1, Z = 2 };
+ inline double* array( Coord coord )
+ return reinterpret_cast<double*>(data()->get_sequence_data( coord ));
+ inline const double* array( Coord coord ) const
+ return reinterpret_cast<const double*>(data()->get_sequence_data( coord ));
+ inline double* x_array() { return array(X); }
+ inline double* y_array() { return array(Y); }
+ inline double* z_array() { return array(Z); }
+ inline const double* x_array() const { return array(X); }
+ inline const double* y_array() const { return array(Y); }
+ inline const double* z_array() const { return array(Z); }
+ VertexSequence( VertexSequence& split_from, MBEntityHandle here )
+ : EntitySequence( split_from, here )
+MBErrorCode VertexSequence::get_coordinates( MBEntityHandle handle,
+ double& x,
+ double& y,
+ double& z ) const
+ MBEntityID offset = handle - data()->start_handle();
+ x = x_array()[offset];
+ y = y_array()[offset];
+ z = z_array()[offset];
+ coords[X] = x_array()[offset];
+ coords[Y] = y_array()[offset];
+ coords[Z] = z_array()[offset];
+MBErrorCode VertexSequence::get_coordinates_ref( MBEntityHandle handle,
+ const double*& x,
+ const double*& y,
+ x = x_array()+offset;
+ y = y_array()+offset;
+ z = z_array()+offset;
+MBErrorCode VertexSequence::set_coordinates( MBEntityHandle entity,
+ double x,
+ double y,
+ double z )
+ MBEntityID offset = entity - data()->start_handle();
+ x_array()[offset] = x;
+ y_array()[offset] = y;
+ z_array()[offset] = z;
+ const double* xyz )
+ x_array()[offset] = xyz[0];
+ y_array()[offset] = xyz[1];
+ z_array()[offset] = xyz[2];
+MBErrorCode VertexSequence::get_coordinate_arrays( double*& x,
+ double*& y,
+ double*& z )
+ MBEntityID offset = start_handle() - data()->start_handle();
+MBErrorCode VertexSequence::get_coordinate_arrays( const double*& x,
+ const double*& y,
+ return get_coordinates_ref( start_handle(), x, y, z );
+#endif
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/WriteHDF5.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -217,9 +217,6 @@
return mhdf_node_type_handle();
case MBENTITYSET:
return mhdf_set_type_handle();
- case MBPOLYGON:
- case MBPOLYHEDRON:
- return MBCN::EntityTypeName( type );
default:
sprintf( buffer, "%s%d", MBCN::EntityTypeName( type ), num_nodes );
return buffer;
@@ -402,14 +399,16 @@
// Write element connectivity
for (ex_itor = exportList.begin(); ex_itor != exportList.end(); ++ex_itor)
- if (ex_itor->type == MBPOLYGON || ex_itor->type == MBPOLYHEDRON)
- result = write_poly( *ex_itor );
- else
- result = write_elems( *ex_itor );
- if (MB_SUCCESS != result)
+ if (MB_SUCCESS != write_elems( *ex_itor ))
goto write_fail;
+// if (ex_itor->type == MBPOLYGON || ex_itor->type == MBPOLYHEDRON)
+// result = write_poly( *ex_itor );
+// else
+// result = write_elems( *ex_itor );
+// if (MB_SUCCESS != result)
+// goto write_fail;
DEBUGOUT("Writing sets.\n");
@@ -485,86 +484,73 @@
return MB_SUCCESS;
- // For a given element type, get all higher-order configurations
- // (and the linear element type) has a list of node counts in
- // each.
-MBErrorCode WriteHDF5::midnode_combinations( MBEntityType type,
- std::vector<int>& combinations )
+MBErrorCode WriteHDF5::initialize_mesh( const MBRange ranges[5] )
- combinations.clear();
+ MBErrorCode rval;
+ if (!ranges[0].all_of_type(MBVERTEX))
+ return MB_FAILURE;
+ nodeSet.range = ranges[0];
+ nodeSet.type = MBVERTEX;
+ nodeSet.num_nodes = 1;
+ if (!ranges[4].all_of_type(MBENTITYSET))
+ setSet.range = ranges[4];
+ setSet.type = MBENTITYSET;
+ setSet.num_nodes = 0;
- int dimension = MBCN::Dimension( type );
- int num_faces = 0;
- int num_edges = 0;
- switch (dimension)
+ exportList.clear();
+ std::vector<MBRange> bins(1024); // sort entities by connectivity length
+ // resize is expensive due to MBRange copy, so start big
+ for (MBEntityType type = MBEDGE; type < MBENTITYSET; ++type)
- case 3:
- num_faces = MBCN::NumSubEntities( type, 2 );
- num_edges = MBCN::NumSubEntities( type, 1 );
- combinations.push_back(num_faces + num_edges + 1);
- combinations.push_back(num_faces + num_edges);
- combinations.push_back(num_faces + 1);
- combinations.push_back(num_faces);
- case 2:
- combinations.push_back(num_edges + 1);
- combinations.push_back(num_edges);
- case 1:
- combinations.push_back(1);
- combinations.push_back(0);
- break;
- default:
- assert(0);
- return MB_FAILURE;
+ ExportSet set;
+ const int dim = MBCN::Dimension(type);
- return MB_SUCCESS;
+ // Group entities by connectivity length
+ bins.clear();
+ std::pair<MBRange::const_iterator,MBRange::const_iterator> p = ranges[dim].equal_range(type);
+ MBRange::const_iterator i = p.first;
+ while (i != p.second) {
+ MBRange::const_iterator first = i;
+ MBEntityHandle const* conn;
+ int len, firstlen;
+ rval = iFace->get_connectivity( *i, conn, firstlen );
+ return rval;
+ for (++i; i != p.second; ++i) {
+ rval = iFace->get_connectivity( *i, conn, len );
+ return rval;
+ if (len != firstlen)
+ break;
+ if (firstlen >= (int)bins.size())
+ bins.resize(firstlen+1);
+ bins[firstlen].merge( first, i );
- // Get the subset of the passed range that matches both the passed
- // element type and the number of nodes in the element (the
- // subtype, e.g. HEX20 vs. HEX8).
-MBErrorCode WriteHDF5::subrange_by_type_and_conn( const MBRange& input,
- MBEntityType type,
- int nodecount,
- MBRange& output )
- MBRange::const_iterator itor;
- const MBEntityHandle* junk;
- MBErrorCode rval;
- int num_nodes;
- output.clear();
- for (itor = input.begin(); itor != input.end(); ++itor)
- // The connectivity pointer (junk) is passed back.
- rval = iFace->get_connectivity( *itor, junk, num_nodes, false );
- CHK_MB_ERR_0(rval);
- if (num_nodes == nodecount &&
- iFace->type_from_handle(*itor) == type)
- output.insert( *itor );
+ // Create ExportSet for each group
+ for (std::vector<MBRange>::iterator j = bins.begin(); j != bins.end(); ++j) {
+ if (j->empty())
+ continue;
+ set.range.clear();
+ set.type = type;
+ set.num_nodes = j - bins.begin();
+ exportList.push_back( set );
+ exportList.back().range.swap( *j );
- // Get the subset of a range containing a given element type.
-MBErrorCode WriteHDF5::subrange_by_type( const MBRange& input,
- MBRange& output )
- int err;
- MBEntityHandle first, last;
- first = CREATE_HANDLE( type, 0, err ); assert(!err);
- last = CREATE_HANDLE( type+1, 0, err ); assert(!err);
- MBRange::const_iterator start, end;
- start = input.lower_bound( input.begin(), input.end(), first );
- end = input.lower_bound( start, input.end(), last );
- output.clear();
- output.merge( start, end );
// Gather the mesh to be written from a list of owning meshsets.
MBErrorCode WriteHDF5::gather_mesh_info(
@@ -572,13 +558,9 @@
MBErrorCode rval;
- nodeSet.range.clear();
- setSet.range.clear();
- exportList.clear();
int dim;
- MBRange range;
- MBRange ranges[4];
+ MBRange range; // temporary storage
+ MBRange ranges[5]; // lists of entities to export, grouped by dimension
// Gather list of all related sets
std::vector<MBEntityHandle> stack(export_sets);
@@ -587,14 +569,14 @@
while( !stack.empty() )
MBEntityHandle meshset = stack.back(); stack.pop_back();
- setSet.range.insert( meshset );
+ ranges[4].insert( meshset );
// Get contained sets
range.clear();
rval = iFace->get_entities_by_type( meshset, MBENTITYSET, range );
CHK_MB_ERR_0(rval);
for (MBRange::iterator ritor = range.begin(); ritor != range.end(); ++ritor)
- if (setSet.range.find( *ritor ) == setSet.range.end())
+ if (ranges[4].find( *ritor ) == ranges[4].end())
stack.push_back( *ritor );
// Get child sets
@@ -603,14 +585,14 @@
CHK_MB_ERR_0(rval);
for (std::vector<MBEntityHandle>::iterator vitor = set_children.begin();
vitor != set_children.end(); ++vitor )
- if (setSet.range.find( *vitor ) == setSet.range.end())
+ if (ranges[4].find( *vitor ) == ranges[4].end())
stack.push_back( *vitor );
// Gather list of all mesh entities from list of sets,
// grouped by dimension.
- for (MBRange::iterator setitor = setSet.range.begin();
- setitor != setSet.range.end(); ++setitor)
+ for (MBRange::iterator setitor = ranges[4].begin();
+ setitor != ranges[4].end(); ++setitor)
for (dim = 0; dim < 4; ++dim)
@@ -639,126 +621,36 @@
ranges[0].merge( range );
- // Split lists by element type and number of nodes
- nodeSet.range = ranges[0];
- nodeSet.type = MBVERTEX;
- nodeSet.num_nodes = 1;
- setSet.type = MBENTITYSET;
- setSet.num_nodes = 0;
- std::vector<int> node_counts;
- for (MBEntityType type = MBEDGE; type < MBENTITYSET; ++type)
- ExportSet set;
- dim = MBCN::Dimension(type);
- if (ranges[dim].empty())
- continue;
- if (type == MBPOLYGON || type == MBPOLYHEDRON)
- rval = subrange_by_type( ranges[dim], type, set.range );
- if (!set.range.empty())
- set.type = type;
- set.num_nodes = 0;
- exportList.push_back( set );
- else
- node_counts.clear();
- rval = midnode_combinations( type, node_counts );
- const int num_corners = MBCN::VerticesPerEntity( type );
- for (std::vector<int>::iterator itor = node_counts.begin();
- itor != node_counts.end(); ++itor)
- set.range.clear();
- int num_nodes = *itor + num_corners;
- rval = subrange_by_type_and_conn( ranges[dim], type, num_nodes, set.range );
- set.type = type;
- set.num_nodes = num_nodes;
+ return initialize_mesh( ranges );
// Gather all the mesh and related information to be written.
MBErrorCode WriteHDF5::gather_all_mesh( )
MBErrorCode rval;
- // Get all nodes
- rval = iFace->get_entities_by_type( 0, MBVERTEX, nodeSet.range );
- // Get all sets
- rval = iFace->get_entities_by_type( 0, MBENTITYSET, setSet.range );
- // Get all elements, grouped by type and number of higher-order nodes
- ExportSet set;
- MBRange range;
- rval = iFace->get_entities_by_type( 0, type, range );
- if (range.empty())
- continue;
- set.range = range;
- set.type = type;
- continue;
- rval = subrange_by_type_and_conn( range, type, num_nodes, set.range );
- set.type = type;
+ rval = iFace->get_entities_by_type( 0, MBVERTEX, ranges[0] );
+ return rval;
+ rval = iFace->get_entities_by_dimension( 0, 1, ranges[1] );
+ return rval;
+ rval = iFace->get_entities_by_dimension( 0, 2, ranges[2] );
+ return rval;
+ rval = iFace->get_entities_by_dimension( 0, 3, ranges[3] );
+ return rval;
+ rval = iFace->get_entities_by_type( 0, MBENTITYSET, ranges[4] );
+ return rval;
MBErrorCode WriteHDF5::write_nodes( )
@@ -865,70 +757,6 @@
return MB_SUCCESS;
-MBErrorCode WriteHDF5::write_poly( ExportSet& elems )
- mhdf_Status status;
- MBErrorCode rval;
- long first_id, table_size, poly_count;
- assert( elems.type == MBPOLYGON || elems.type == MBPOLYHEDRON );
- const MBRange::const_iterator end = elems.range.end();
- MBRange::const_iterator iter;
- // Create the tables in the file and assign IDs to polys
- hid_t handles[2];
- mhdf_openPolyConnectivity( filePtr,
- MBCN::EntityTypeName(elems.type),
- &poly_count,
- &table_size,
- &first_id,
- handles,
- &status );
- CHK_MHDF_ERR_0(status);
- assert (first_id <= elems.first_id);
- assert ((unsigned long)poly_count >= elems.offset + elems.range.size());
- // Split the data buffer into two chunks, one for the indices
- // and one for the IDs. Assume average of 4 IDs per poly.
- size_t chunk_size = bufferSize / (5*sizeof(id_t));
- id_t* idx_buffer = (id_t*)dataBuffer;
- id_t* conn_buffer = idx_buffer + chunk_size;
- long offset[2] = {0,0};
- id_t index_offset = 0;
- iter = elems.range.begin();
- while (iter != end)
- size_t num_idx = chunk_size;
- size_t num_conn = 4*chunk_size;
- rval = writeUtil->get_poly_arrays( iter, end, idTag,
- num_conn, conn_buffer,
- num_idx, idx_buffer,
- index_offset );
- CHK_MB_ERR_2(rval, handles, status);
- mhdf_writePolyConnIndices( handles[0], offset[0], num_idx, id_type, idx_buffer, &status );
- CHK_MHDF_ERR_2(status, handles);
- offset[0] += num_idx;
- mhdf_writePolyConnIDs( handles[1], offset[1], num_conn, id_type, conn_buffer, &status );
- offset[1] += num_conn;
- mhdf_closeData( filePtr, handles[0], &status );
- CHK_MHDF_ERR_1(status, handles[1]);
- mhdf_closeData( filePtr, handles[1], &status );
MBErrorCode WriteHDF5::get_set_info( MBEntityHandle set,
long& num_entities,
long& num_children,
@@ -1893,26 +1721,10 @@
// Create element tables
- int mb_count;
- rval = writeUtil->get_poly_array_size( ex_itor->range.begin(),
- ex_itor->range.end(),
- mb_count );
- rval = create_poly_tables( ex_itor->type,
- ex_itor->range.size(),
- mb_count,
- first_id );
- else
- rval = create_elem_tables( ex_itor->type,
- ex_itor->num_nodes,
- first_id );
+ rval = create_elem_tables( ex_itor->type,
+ ex_itor->num_nodes,
+ ex_itor->range.size(),
+ first_id );
CHK_MB_ERR_0(rval);
writeUtil->assign_ids( ex_itor->range, idTag, (id_t)first_id );
@@ -2051,34 +1863,6 @@
-MBErrorCode WriteHDF5::create_poly_tables( MBEntityType mb_type,
- id_t num_poly,
- id_t connectivity_size,
- long& first_id_out )
- char name[64];
- hid_t handles[2];
- strcpy( name, MBCN::EntityTypeName(mb_type) );
- mhdf_addElement( filePtr, name, mb_type, &status );
- mhdf_createPolyConnectivity( filePtr,
- name,
- num_poly,
- connectivity_size,
- &first_id_out,
- handles,
- &status );
MBErrorCode WriteHDF5::count_set_size( const MBRange& sets,
MBRange& compressed_sets,
long& contents_length_out,
Modified: MOAB/trunk/WriteHDF5.hpp
--- MOAB/trunk/WriteHDF5.hpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/WriteHDF5.hpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -114,16 +114,6 @@
int nodes_per_element,
id_t number_elements,
long& first_id_out );
- /** Helper function for create-file
- * Create zero-ed tables where poly connectivity and
- * adjacency data will be stored.
- MBErrorCode create_poly_tables( MBEntityType mb_type,
- id_t number_elements,
- id_t connectivity_length,
- long& first_id_out );
@@ -256,35 +246,6 @@
//! Zero the ID tag on all entities in the mesh.
MBErrorCode clear_all_id_tags();
- /** Get the subset of an entity range that is a specified element type
- * \param input_range The range to subset
- * \param type The base element type
- * \param number_nodes The number of nodes per element
- * \param output_range The result subset of the input range.
- MBErrorCode subrange_by_type_and_conn( const MBRange& input_range,
- int number_nodes,
- MBRange& output_range );
- /** Get the subrange of a given range containing the specified elem type
- * \param type The element type
- * \param output_range The subset of input_range of type <code>type</code>
- MBErrorCode subrange_by_type( const MBRange& input_range,
- /** Get higher-order types
- * For each higher-order type of the element, append the number of
- * of nodes beyond those of the base/simplest type that that higher-
- * order type has. Also appends zero to the list for the base type.
- MBErrorCode midnode_combinations( MBEntityType type,
- std::vector<int>& combinations );
//! Get information about a meshset
MBErrorCode get_set_info( MBEntityHandle set,
@@ -337,6 +298,9 @@
//! Same as gather_mesh_info, except for entire mesh
MBErrorCode gather_all_mesh( );
+ //! Initialize internal data structures from gathered mesh
+ MBErrorCode initialize_mesh( const MBRange entities_by_dim[5] );
/** Write out the nodes.
@@ -353,16 +317,6 @@
MBErrorCode write_elems( ExportSet& elemset );
- /** Write out poly(hedr/g)on connectivity
- * Write connectivity for passed set of poly
- * Note: Assigns element IDs.
- * Note: Must do write of lower-dimension entities first so
- * IDs get assigned to them.
- MBErrorCode write_poly( ExportSet& elemset );
/** Write out meshsets
* Write passed set of meshsets, including parent/child relations.
Modified: MOAB/trunk/scdseq_test.cpp
--- MOAB/trunk/scdseq_test.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/scdseq_test.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -17,27 +17,29 @@
// test the structured sequence stuff
-#include "ScdVertexSeq.hpp"
-#include "ScdElementSeq.hpp"
-#include "EntitySequenceManager.hpp"
-#include "EntitySequence.hpp"
+#include "ScdVertexData.hpp"
+#include "ScdElementData.hpp"
+#include "SequenceManager.hpp"
+#include "StructuredElementSeq.hpp"
#include "MBCore.hpp"
#include <iostream>
int test_vertex_seq(MBCore *gMB);
-MBErrorCode check_vertex_sequence(const ScdVertexSeq *this_seq,
+MBErrorCode check_vertex_sequence(const ScdVertexData *this_seq,
const int imin, const int jmin, const int kmin,
const int imax, const int jmax, const int kmax,
const MBEntityHandle this_start);
-MBErrorCode evaluate_vertex_sequence(ScdVertexSeq *this_seq);
+MBErrorCode evaluate_vertex_sequence(ScdVertexData *this_seq);
int test_element_seq(MBCore *gMB);
-MBErrorCode check_element_sequence(const ScdElementSeq *this_seq,
+MBErrorCode check_element_sequence(const StructuredElementSeq *this_seq,
const HomCoord &min_params,
const HomCoord &max_params,
-MBErrorCode evaluate_element_sequence(ScdElementSeq *this_seq);
+MBErrorCode evaluate_element_sequence(StructuredElementSeq *this_seq);
int eseq_test1a(MBCore *gMB, HomCoord tmp_min, HomCoord tmp_max);
int eseq_test1b(MBCore *gMB, HomCoord tmp_min, HomCoord tmp_max);
int eseq_test1c(MBCore *gMB, HomCoord tmp_min, HomCoord tmp_max);
@@ -48,25 +50,25 @@
int create_1d_3_sequences(MBCore *gMB,
HomCoord tmp_min, HomCoord tmp_max,
- ScdVertexSeq **vseq, MBEntityHandle *vstart,
- ScdElementSeq **eseq, MBEntityHandle *estart);
+ ScdVertexData **vseq, MBEntityHandle *vstart,
+ StructuredElementSeq **eseq, MBEntityHandle *estart);
int create_2d_3_sequences(MBCore *gMB,
int create_2dtri_3_sequences(MBCore *gMB,
const int int1, const int int2, const int int3,
int create_3dtri_3_sequences(MBCore *gMB,
const int int1, const int int2, const int int3, const int int4,
// first comes general-capability code used by various tests; main and test functions
// come after these, starting with main
@@ -94,7 +96,7 @@
result = MB_FAILURE;
- if (this_start != this_seq->get_start_handle()) {
+ if (this_start != this_seq->start_handle()) {
std::cout << "Start handle for sequence wrong." << std::endl;
@@ -102,7 +104,7 @@
return result;
@@ -130,7 +132,7 @@
@@ -143,7 +145,7 @@
return result;
MBErrorCode result = MB_SUCCESS;
@@ -153,7 +155,7 @@
this_seq->max_params(imax, jmax, kmax);
// then the start vertex
- MBEntityHandle start_handle = this_seq->get_start_handle();
+ MBEntityHandle start_handle = this_seq->start_handle();
// now evaluate all the vertices in forward and reverse
MBEntityHandle tmp_handle, tmp_handle2;
@@ -200,7 +202,7 @@
return result;
@@ -282,18 +284,18 @@
// get the seq manager from gMB
- EntitySequenceManager *seq_mgr = gMB->sequence_manager();
+ SequenceManager *seq_mgr = gMB->sequence_manager();
int errors = 0;
MBEntityHandle oned_start, twod_start, threed_start;
- MBEntitySequence *dum_seq = NULL;
- ScdVertexSeq *oned_seq = NULL, *twod_seq = NULL, *threed_seq = NULL;
+ EntitySequence *dum_seq = NULL;
+ ScdVertexData *oned_seq = NULL, *twod_seq = NULL, *threed_seq = NULL;
// make a 1d sequence
MBErrorCode result = seq_mgr->create_scd_sequence(-10, 0, 0, 10, 0, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
oned_start, dum_seq);
- if (NULL != dum_seq) oned_seq = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) oned_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || oned_start == 0 || dum_seq == NULL ||
oned_seq == NULL) {
std::cout << "Problems creating a 1d sequence." << std::endl;
@@ -318,9 +320,9 @@
// make a 2d sequence
dum_seq = NULL;
result = seq_mgr->create_scd_sequence(-10, -10, 0, 10, 10, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
twod_start, dum_seq);
- if (NULL != dum_seq) twod_seq = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) twod_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || twod_start == 0 || dum_seq == NULL ||
twod_seq == NULL) {
std::cout << "Problems creating a 2d sequence." << std::endl;
@@ -345,9 +347,9 @@
// make a 3d sequence
dum_seq = NULL;
result = seq_mgr->create_scd_sequence(-10, -10, -10, 10, 10, 10,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
threed_start, dum_seq);
- if (NULL != dum_seq) threed_seq = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) threed_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || threed_start == 0 || dum_seq == NULL ||
threed_seq == NULL) {
std::cout << "Problems creating a 3d sequence." << std::endl;
@@ -404,28 +406,29 @@
tmp_min[1] = tmp_min[2] = tmp_max[1] = tmp_max[2] = 0;
MBEntityHandle oned_start;
- MBEntitySequence *dum_seq;
- ScdVertexSeq *oned_seq = NULL;
+ EntitySequence *dum_seq;
+ ScdVertexData *oned_seq = NULL;
MBErrorCode result = seq_mgr->create_scd_sequence(tmp_min, tmp_max,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
assert (MB_FAILURE != result && oned_start != 0 && dum_seq != NULL && oned_seq != NULL);
// now create the element sequence
MBEntityHandle eseq_start;
- ScdElementSeq *eseq = NULL;
+ StructuredElementSeq *eseq = NULL;
- MBEDGE, 1,
+ MBEDGE, 1, 0,
eseq_start, dum_seq);
- if (NULL != dum_seq) eseq = dynamic_cast<ScdElementSeq*>(dum_seq);
+ if (NULL != dum_seq) eseq = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && eseq_start != 0 && dum_seq != NULL && eseq != NULL);
// add vertex seq to element seq
- result = eseq->add_vsequence(oned_seq,
+ result = dynamic_cast<ScdElementData*>(eseq->data())
+ ->add_vsequence(oned_seq,
tmp_min, tmp_min,
tmp_max, tmp_max,
tmp_min, tmp_min);
@@ -460,30 +463,31 @@
tmp_min[2] = tmp_max[2] = 0;
MBEntityHandle twod_start;
- ScdVertexSeq *twod_seq = NULL;
+ ScdVertexData *twod_seq = NULL;
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
assert (MB_FAILURE != result && twod_start != 0 && dum_seq != NULL && twod_seq != NULL);
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// add vertex seq to element seq; first need to construct proper 3pt input (p1 is tmp_min)
HomCoord p2(tmp_max.i(), tmp_min.j(), tmp_min.k());
HomCoord p3(tmp_min.i(), tmp_max.j(), tmp_min.k());
- result = eseq->add_vsequence(twod_seq,
+ ->add_vsequence(twod_seq,
tmp_min, tmp_min,
p2, p2, p3, p3);
if (MB_SUCCESS != result) {
@@ -514,31 +518,31 @@
int errors = 0;
MBEntityHandle threed_start;
- ScdVertexSeq *threed_seq = NULL;
+ ScdVertexData *threed_seq = NULL;
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
assert (MB_FAILURE != result && threed_start != 0 && dum_seq != NULL && threed_seq != NULL);
- MBHEX, 1,
+ MBHEX, 1, 0,
- result = eseq->add_vsequence(threed_seq,
- tmp_min, tmp_min, p2, p2, p3, p3);
+ ->add_vsequence(threed_seq, tmp_min, tmp_min, p2, p2, p3, p3);
std::cout << "Couldn't add vsequence to 3d single-block element sequence." << std::endl;
errors++;
@@ -565,8 +569,8 @@
// TEST 2a: 1d composite block, 0d difference between owning/sharing blocks
// create vertex seq
- ScdVertexSeq *vseq[3];
- ScdElementSeq *eseq[3];
+ ScdVertexData *vseq[3];
+ StructuredElementSeq *eseq[3];
MBEntityHandle vstart[3], estart[3];
int errors = create_1d_3_sequences(gMB, tmp_min, tmp_max,
@@ -607,8 +611,8 @@
// TEST 2b: 2d composite block, 0d difference between owning/sharing blocks
int errors = create_2d_3_sequences(gMB, vseq, vstart, eseq, estart);
@@ -650,8 +654,8 @@
// TEST 2c: 2d composite block, 0d difference between owning/sharing blocks,
// tri-valent shared vertex between the three blocks
// interval settings: only 3 of them
@@ -685,8 +689,8 @@
// TEST 2d: 3d composite block, 0d difference between owning/sharing blocks,
// tri-valent shared edge between the three blocks
@@ -717,8 +721,8 @@
int errors = 0;
@@ -733,32 +737,32 @@
HomCoord vseq2_minmax[2] = {HomCoord(tmp_min), HomCoord(tmp_max[0]-5*idiff, tmp_max[1], tmp_max[2])};
// create three vertex sequences
vseq[0] = vseq[1] = vseq[2] = NULL;
// first vertex sequence
MBErrorCode result = seq_mgr->create_scd_sequence(vseq0_minmax[0], vseq0_minmax[1],
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
vstart[0], dum_seq);
- if (NULL != dum_seq) vseq[0] = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) vseq[0] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[0] != 0 && dum_seq != NULL && vseq[0] != NULL);
// second vertex sequence
result = seq_mgr->create_scd_sequence(vseq1_minmax[0], vseq1_minmax[1],
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
vstart[1], dum_seq);
- if (NULL != dum_seq) vseq[1] = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) vseq[1] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[1] != 0 && dum_seq != NULL && vseq[1] != NULL);
// third vertex sequence
result = seq_mgr->create_scd_sequence(vseq2_minmax[0], vseq2_minmax[1],
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
vstart[2], dum_seq);
- if (NULL != dum_seq) vseq[2] = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ if (NULL != dum_seq) vseq[2] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[2] != 0 && dum_seq != NULL && vseq[2] != NULL);
// now create the three element sequences
@@ -766,13 +770,13 @@
// create the first element sequence
- MBEDGE, 1,
+ MBEDGE, 1, 0,
estart[0], dum_seq);
- if (NULL != dum_seq) eseq[0] = dynamic_cast<ScdElementSeq*>(dum_seq);
+ if (NULL != dum_seq) eseq[0] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[0] != 0 && dum_seq != NULL && eseq[0] != NULL);
// add first vertex seq to first element seq, forward orientation, unity transform
- result = eseq[0]->add_vsequence(vseq[0],
+ result = eseq[0]->sdata()->add_vsequence(vseq[0],
vseq0_minmax[0], vseq0_minmax[0],
vseq0_minmax[1], vseq0_minmax[1],
vseq0_minmax[0], vseq0_minmax[0]);
@@ -786,14 +790,14 @@
// end of the previous eseq
result = seq_mgr->create_scd_sequence(HomCoord(vseq0_minmax[1].i(), 0, 0),
HomCoord(1+vseq0_minmax[1].i()+vseq1_minmax[1].i()-vseq1_minmax[0].i(), 0, 0),
- MBEDGE, 1,
+ MBEDGE, 1, 0,
estart[1], dum_seq);
- if (NULL != dum_seq) eseq[1] = dynamic_cast<ScdElementSeq*>(dum_seq);
+ if (NULL != dum_seq) eseq[1] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[1] != 0 && dum_seq != NULL && eseq[1] != NULL);
// add shared vertex from first vseq to this eseq; parameter space should be the same since
// we're adding to that parameter space
- result = eseq[1]->add_vsequence(vseq[0],
+ result = eseq[1]->sdata()->add_vsequence(vseq[0],
@@ -807,7 +811,7 @@
// add second vseq to this eseq, but reversed; parameter space should be such that the
// last vertex in the second vseq occurs first, and so on
- result = eseq[1]->add_vsequence(vseq[1],
+ result = eseq[1]->sdata()->add_vsequence(vseq[1],
vseq1_minmax[1], eseq[1]->min_params()+HomCoord::unitv[0],
vseq1_minmax[0], eseq[1]->max_params(),
vseq1_minmax[1], eseq[1]->min_params()+HomCoord::unitv[0]);
@@ -821,14 +825,14 @@
result = seq_mgr->create_scd_sequence(eseq[1]->max_params(),
HomCoord(eseq[1]->max_params().i()+1+vseq2_minmax[1].i()-vseq2_minmax[0].i(),0,0),
- MBEDGE, 1,
+ MBEDGE, 1, 0,
estart[2], dum_seq);
- if (NULL != dum_seq) eseq[2] = dynamic_cast<ScdElementSeq*>(dum_seq);
+ if (NULL != dum_seq) eseq[2] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[2] != 0 && dum_seq != NULL && eseq[2] != NULL);
// add shared vertex from second vseq to this eseq; parameter space mapping such that we get
// first vertex only of that vseq
- result = eseq[2]->add_vsequence(vseq[1],
+ result = eseq[2]->sdata()->add_vsequence(vseq[1],
vseq0_minmax[0], eseq[2]->min_params(),
vseq0_minmax[0]+HomCoord::unitv[0], eseq[2]->min_params()-HomCoord::unitv[0],
@@ -841,7 +845,7 @@
// add third vseq to this eseq, forward orientation
- result = eseq[2]->add_vsequence(vseq[2],
+ result = eseq[2]->sdata()->add_vsequence(vseq[2],
vseq2_minmax[0], eseq[2]->min_params()+HomCoord::unitv[0],
vseq2_minmax[1], eseq[2]->max_params(),
vseq1_minmax[0], eseq[2]->min_params()+HomCoord::unitv[0]);
@@ -854,8 +858,8 @@
// create 3 rectangular esequences attached end to end and back (periodic); vsequences are
// assorted orientations, esequences have globally-consistent (periodic in i) parameter space
@@ -867,31 +871,31 @@
HomCoord vseq2_minmax[2] = {HomCoord(0,0,0), HomCoord(8,5,0)};
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
@@ -899,13 +903,13 @@
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// p1: imin,jmin
// p2: imax,jmin
@@ -925,14 +929,14 @@
result = seq_mgr->create_scd_sequence(HomCoord(eseq[0]->max_params().i(), eseq[0]->min_params().j(), 0),
HomCoord(vseq0_minmax[1].i()+1+vseq1_minmax[1].i()-vseq1_minmax[0].i(),
eseq[0]->max_params().j(), 0),
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// add shared side from first vseq to this eseq; parameter space should be the same since
@@ -946,7 +950,7 @@
// add second vseq to this eseq, with different orientation but all of it (no bb input)
// p1: one right of top left
vseq1_minmax[0],
HomCoord(eseq[1]->min_params().i()+1, eseq[1]->max_params().j(), 0),
@@ -968,14 +972,14 @@
// add one extra for each of left and right sides
HomCoord(eseq[1]->max_params().i()+1+vseq2_minmax[1].i()-vseq2_minmax[0].i()+1,
eseq[1]->max_params().j(),0),
- MBEDGE, 1,
+ MBEDGE, 1, 0,
// add shared side from second vseq to this eseq; parameter space mapping such that we get
// a side only of that vseq
// p1: bottom left
vseq1_minmax[1], eseq[2]->min_params(),
// p2: one right from p1
@@ -995,7 +999,7 @@
// add shared side from first vseq to this eseq; parameter space mapping such that we get
- result = eseq[2]->add_vsequence(vseq[0],
+ result = eseq[2]->sdata()->add_vsequence(vseq[0],
// p1: bottom right
vseq1_minmax[0], HomCoord(eseq[2]->max_params().i(), eseq[2]->min_params().j(),0),
@@ -1015,7 +1019,7 @@
// p1: top right and left one
vseq2_minmax[0], eseq[2]->max_params()-HomCoord::unitv[0],
// p2: one left of p1
@@ -1033,8 +1037,8 @@
// create 3 rectangular esequences arranged such that the all share a common (tri-valent) corner;
// orient each region such that its origin is at the tri-valent corner and the k direction is
@@ -1053,31 +1057,31 @@
HomCoord vseq2_minmax[2] = {HomCoord(0,0,0), HomCoord(int2-1,int3-1,0)};
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
@@ -1094,13 +1098,13 @@
result = seq_mgr->create_scd_sequence(eseq0_minmax[0], eseq0_minmax[1],
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// only need to add one vseq to this, unity transform
// trick: if I know it's going to be unity, just input
// 3 sets of equivalent points
@@ -1114,13 +1118,13 @@
// create the second element sequence
result = seq_mgr->create_scd_sequence(eseq1_minmax[0], eseq1_minmax[1],
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// add shared side from first vseq to this eseq, with bb to get just the line
// p1: origin in both systems
vseq0_minmax[0], eseq0_minmax[0],
// p2: one unit along the shared line (i in one, j in other)
@@ -1137,7 +1141,7 @@
// p1: origin/i+1 (vseq/eseq)
vseq1_minmax[0], eseq1_minmax[0]+HomCoord::unitv[0],
// p2: j+1 from p1
@@ -1153,13 +1157,13 @@
// create the third element sequence
result = seq_mgr->create_scd_sequence(eseq2_minmax[0], eseq2_minmax[1],
- MBQUAD, 1,
+ MBQUAD, 1, 0,
// p1: origin/j+1 (vseq/eseq)
vseq1_minmax[0], eseq[2]->min_params()+HomCoord::unitv[1],
// p2: i+1/j+2 (vseq/eseq)
@@ -1177,7 +1181,7 @@
// p1: origin/origin
vseq1_minmax[0], eseq2_minmax[0],
// p2: j+1/i+1
@@ -1195,7 +1199,7 @@
// p1: origin/i+1,j+1
vseq2_minmax[0], eseq[2]->min_params()+HomCoord::unitv[0]+HomCoord::unitv[1],
// p2: i+1 from p1
@@ -1212,8 +1216,8 @@
// create 3 brick esequences arranged such that the all share a common (tri-valent) edge;
// orient each region similarly to the 2dtri_3_esequences test problem, swept into 3d in the
@@ -1233,31 +1237,31 @@
HomCoord vseq2_minmax[2] = {HomCoord(0,0,0), HomCoord(int2-1,int3-1,int4)};
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
- MBVERTEX, 1,
+ MBVERTEX, 1, 0,
@@ -1274,13 +1278,13 @@
- MBHEX, 1,
+ MBHEX, 1, 0,
@@ -1294,13 +1298,13 @@
- MBHEX, 1,
+ MBHEX, 1, 0,
// add shared side from first vseq to this eseq, with bb to get just the face
@@ -1318,7 +1322,7 @@
// p2: j+1 from p1
@@ -1334,13 +1338,13 @@
- MBHEX, 1,
+ MBHEX, 1, 0,
@@ -1359,7 +1363,7 @@
// p2: j+1/i+1
@@ -1378,7 +1382,7 @@
// p2: i+1 from p1
Modified: MOAB/trunk/test/perf/perf.cpp
--- MOAB/trunk/test/perf/perf.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/test/perf/perf.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -27,15 +27,18 @@
#endif
#endif
+#define IS_BUILDING_MB
#include <stdlib.h>
#include <stdio.h>
+#include <assert.h>
#include <iostream>
#include "MBReadUtilIface.hpp"
#include "HomXform.hpp"
double LENGTH = 1.0;
@@ -394,27 +397,27 @@
print_time(false, ttime0, utime, stime);
// make a 3d block of vertices
- ScdVertexSeq *vseq = NULL;
- EntitySequenceManager *seq_mgr = dynamic_cast<MBCore*>(gMB)->sequence_manager();
+ ScdVertexData *vseq = NULL;
+ SequenceManager *seq_mgr = dynamic_cast<MBCore*>(gMB)->sequence_manager();
HomCoord vseq_minmax[2] = {HomCoord(0,0,0),
HomCoord(nelem, nelem, nelem)};
MBEntityHandle vstart, estart;
MBErrorCode result = seq_mgr->create_scd_sequence(vseq_minmax[0], vseq_minmax[1],
- MBVERTEX, 1, vstart, dum_seq);
- if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexSeq*>(dum_seq);
+ MBVERTEX, 1, -1, vstart, dum_seq);
+ if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart != 0 && dum_seq != NULL && vseq != NULL);
// now the element sequence
- MBHEX, 1, estart, dum_seq);
+ MBHEX, 1, -1, estart, dum_seq);
assert (MB_FAILURE != result && estart != 0 && dum_seq != NULL && eseq != NULL);
// trick: if I know it's going to be unity, just input 3 sets of equivalent points
- result = eseq->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
+ result = eseq->sdata()->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
vseq_minmax[0], vseq_minmax[0], vseq_minmax[0]);
assert(MB_SUCCESS == result);
@@ -465,7 +468,7 @@
// create a sequence to hold the node coordinates
// get the current number of entities and start at the next slot
std::vector<double*> coord_arrays;
- MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, vstart, coord_arrays);
+ MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, -1, vstart, coord_arrays);
assert(MB_SUCCESS == result && 1 == vstart &&
coord_arrays[0] && coord_arrays[1] && coord_arrays[2]);
// memcpy the coordinate data into place
@@ -474,7 +477,7 @@
memcpy(coord_arrays[2], &coords[2*num_verts], sizeof(double)*num_verts);
MBEntityHandle *conn = 0;
- result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, estart, conn);
+ result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, -1, estart, conn);
memcpy(conn, connect, num_elems*8*sizeof(MBEntityHandle));
result = readMeshIface->update_adjacencies(estart, num_elems, 8, conn);
Modified: MOAB/trunk/tools/mbperf/mbperf.cpp
--- MOAB/trunk/tools/mbperf/mbperf.cpp 2007-11-09 22:17:23 UTC (rev 1373)
+++ MOAB/trunk/tools/mbperf/mbperf.cpp 2007-11-09 22:28:33 UTC (rev 1374)
@@ -35,12 +35,14 @@
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
@@ -450,27 +452,28 @@
<< std::endl;
+ MBVERTEX, 1, 0, vstart, dum_seq);
+ MBHEX, 1, 0, estart, dum_seq);
+ ->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
