[MOAB-dev] r1368 - MOAB/trunk/test/perf
kraftche at mcs.anl.gov
Thu Nov 8 16:17:12 CST 2007
Author: kraftche
Date: 2007-11-08 16:17:12 -0600 (Thu, 08 Nov 2007)
New Revision: 1368
Modified:
MOAB/trunk/test/perf/seqperf.cpp
Log:
Previous code divided all vertices into blocks of 100 and deleted
the later X entities from each group, where X is the % of entities
to delete. It did a similar operation for elements, without any
regard for whether or not the vertices referenced by a particular
element were deleted. This was a fairly simple integer-based
percentage calculation.
The test mesh is a NxNxN structured hex grid. New code deletes
whole sheets of vertices from the max(x) side of the cube. This
allows easy calculation of the corresponding elements to delete
such that all elements referencing deleted vertices are also
deleted. It also results in rapidly splitting into many sequences
(as desired) because vertices are stored in X-major order.
Original query code iterated over all handles (even handles
for deleted entities.) This was because the cost of calculating
which elements and which element vertices were deleted was too
high, biasing the results. Utilize new deletion scheme to
quickly skip deleted entities, querying only valid handles.
Also, remove all computations and such from query timing code.
Just due the query, and now assert on success of the query.
Modified: MOAB/trunk/test/perf/seqperf.cpp
--- MOAB/trunk/test/perf/seqperf.cpp 2007-11-08 18:34:04 UTC (rev 1367)
+++ MOAB/trunk/test/perf/seqperf.cpp 2007-11-08 22:17:12 UTC (rev 1368)
@@ -18,7 +18,7 @@
#endif
// constants
-const bool dump_mesh = false; //!< write mesh to vtk file
+const bool dump_mesh = true; //!< write mesh to vtk file
const int default_intervals = 25; //!< defaul interval count for cubic structured hex mesh
const int default_query_count = 100; //!< number of times to do each query set
const int default_order[] = {0, 1, 2};
@@ -35,7 +35,6 @@
MBInterface& mb = moab; //!< moab instance
MBEntityHandle vertStart, elemStart; //!< first handle
MBReadUtilIface *readTool = 0;
-double centroid[3];
long* queryVertPermutation = 0; //!< pupulated by init(): "random" order for vertices
long* queryElemPermutation = 0; //!< pupulated by init(): "random" order for elements
@@ -78,17 +77,17 @@
void create_elements_single( ); //!< create elements one at a time
void create_elements_block( ); //!< create elements in block using MBReadUtilIface
-void forward_order_query_vertices(); //!< calculate mean of all vertex coordinates
-void reverse_order_query_vertices(); //!< calculate mean of all vertex coordinates
-void random_order_query_vertices(); //!< calculate mean of all vertex coordinates
+void forward_order_query_vertices(int percent); //!< calculate mean of all vertex coordinates
+void reverse_order_query_vertices(int percent); //!< calculate mean of all vertex coordinates
+void random_order_query_vertices(int percent); //!< calculate mean of all vertex coordinates
-void forward_order_query_elements(); //!< check all element connectivity for valid vertex handles
-void reverse_order_query_elements(); //!< check all element connectivity for valid vertex handles
-void random_order_query_elements(); //!< check all element connectivity for valid vertex handles
+void forward_order_query_elements(int percent); //!< check all element connectivity for valid vertex handles
+void reverse_order_query_elements(int percent); //!< check all element connectivity for valid vertex handles
+void random_order_query_elements(int percent); //!< check all element connectivity for valid vertex handles
-void forward_order_query_element_verts(); //!< calculate centroid
-void reverse_order_query_element_verts(); //!< calculate centroid
-void random_order_query_element_verts(); //!< calculate centroid
+void forward_order_query_element_verts(int percent); //!< calculate centroid
+void reverse_order_query_element_verts(int percent); //!< calculate centroid
+void random_order_query_element_verts(int percent); //!< calculate centroid
void forward_order_delete_vertices( int percent ); //!< delete x% of vertices
void reverse_order_delete_vertices( int percent ); //!< delete x% of vertices
@@ -110,15 +109,15 @@
typedef void (*naf_t)();
typedef void (*iaf_t)(int);
-naf_t query_verts[3] = { &forward_order_query_vertices,
+iaf_t query_verts[3] = { &forward_order_query_vertices,
&reverse_order_query_vertices,
& random_order_query_vertices };
-naf_t query_elems[3] = { &forward_order_query_elements,
+iaf_t query_elems[3] = { &forward_order_query_elements,
&reverse_order_query_elements,
& random_order_query_elements };
-naf_t query_elem_verts[3] = { &forward_order_query_element_verts,
+iaf_t query_elem_verts[3] = { &forward_order_query_element_verts,
&reverse_order_query_element_verts,
& random_order_query_element_verts };
@@ -178,12 +177,12 @@
//! run function query_repeat times, printing time spent
-void TIME_QRY( const char* str, void (*func)() )
+void TIME_QRY( const char* str, void (*func)(int percent), int percent )
std::cout << str << "... " << std::flush;
clock_t t = clock();
for (int i = 0; i < queryCount; ++i)
- (*func)();
+ (*func)(percent);
std::cout << ts(clock() - t) << std::endl;
@@ -224,8 +223,8 @@
std::cout << order_strs[order] <<
" order with deletion of " << percent << "% of vertices and elements" << std::endl;
- TIME_DEL( " Deleting vertices", delete_verts[order], percent );
TIME_DEL( " Deleting elements", delete_elems[order], percent );
+ TIME_DEL( " Deleting vertices", delete_verts[order], percent );
int num_vert = 0;
int num_elem = 0;
@@ -237,9 +236,9 @@
<< get_number_sequences(MBHEX) << " element sequences." << std::endl;
#endif
- TIME_QRY( " Quering vertex coordinates", query_verts[order] );
- TIME_QRY( " Quering element connectivity", query_elems[order] );
- TIME_QRY( " Quering element coordinates", query_elem_verts[order] );
+ TIME_QRY( " Quering vertex coordinates", query_verts[order], percent );
+ TIME_QRY( " Quering element connectivity", query_elems[order], percent );
+ TIME_QRY( " Quering element coordinates", query_elem_verts[order], percent );
TIME_DEL( " Re-creating vertices", create_missing_vertices, percent );
TIME_DEL( " Re-creating elements", create_missing_elements, percent );
@@ -377,6 +376,46 @@
+inline void vertex_coords( long vert_index, double& x, double& y, double& z )
+ const long vs = numSideInt + 1;
+ x = vert_index % vs;
+ y = (vert_index / vs) % vs;
+ z = (vert_index / vs / vs);
+inline long vert_index( long x, long y, long z )
+ return x + vs * (y + vs * z);
+inline void element_conn( long elem_index, MBEntityHandle conn[8] )
+ const long x = elem_index % numSideInt;
+ const long y = (elem_index / numSideInt) % numSideInt;
+ const long z = (elem_index / numSideInt / numSideInt);
+ conn[0] = vertStart + vert_index(x ,y ,z );
+ conn[1] = vertStart + vert_index(x+1,y ,z );
+ conn[2] = vertStart + vert_index(x+1,y+1,z );
+ conn[3] = vertStart + vert_index(x ,y+1,z );
+ conn[4] = vertStart + vert_index(x ,y ,z+1);
+ conn[5] = vertStart + vert_index(x+1,y ,z+1);
+ conn[6] = vertStart + vert_index(x+1,y+1,z+1);
+ conn[7] = vertStart + vert_index(x ,y+1,z+1);
+inline bool deleted_vert( long index, int percent )
+ return index%(numSideInt+1) >= (numSideInt+1)*(100-percent) / 100;
+inline bool deleted_elem( long index, int percent )
+ return index % numSideInt + 1 >= (numSideInt+1)*(100-percent) / 100;
void create_vertices_single( )
double coords[3];
@@ -432,104 +471,115 @@
element_conn( i, conn + 8*i );
- double coords[3], sum[3] = {0,0,0};
- const MBEntityHandle last = vertStart + numVert;
- for (MBEntityHandle h = vertStart; h < last; ++h) {
- mb.get_coords( &h, 1, coords );
- sum[0] += coords[0];
- sum[1] += coords[1];
- sum[2] += coords[2];
+ MBErrorCode r;
+ double coords[3];
+ long x, y, z;
+ const long vert_per_edge = numSideInt + 1;
+ const long deleted_x = (numSideInt+1)*(100-percent) / 100;
+ MBEntityHandle h = vertStart;
+ for (z = 0; z < vert_per_edge; ++z) {
+ for (y = 0; y < vert_per_edge; ++y) {
+ for (x = 0; x < deleted_x; ++x, ++h) {
+ r = mb.get_coords( &h, 1, coords );
+ assert(MB_SUCCESS == r);
+ h += (vert_per_edge - deleted_x);
- centroid[0] = sum[0] / numVert;
- centroid[1] = sum[1] / numVert;
- centroid[2] = sum[2] / numVert;
- for (MBEntityHandle h = last-1; h >= vertStart; --h) {
+ MBErrorCode r;
+ double coords[3];
+ long x, y, z;
+ MBEntityHandle h = vertStart + numVert - 1;;
+ for (z = vert_per_edge-1; z >= 0; --z) {
+ for (y = vert_per_edge-1; y >= 0; --y) {
+ h -= (vert_per_edge - deleted_x);
+ for (x = deleted_x-1; x >= 0; --x, --h) {
+ MBErrorCode r;
MBEntityHandle h;
+ double coords[3];
for (long i = 0; i < numVert; ++i) {
- h = vertStart + queryVertPermutation[i];
+ if (!deleted_vert(queryVertPermutation[i],percent)) {
+ h = vertStart + queryVertPermutation[i];
+ MBErrorCode r;
const MBEntityHandle* conn;
int len;
- const MBEntityHandle lastVert = vertStart + numVert - 1;
- const MBEntityHandle last = elemStart + numElem;
- for (MBEntityHandle h = elemStart; h < last; ++h) {
- if (MB_SUCCESS == mb.get_connectivity( h, conn, len )) {
- assert( 8 == len );
- for (int j = 0; j < 8; ++j)
- if (conn[j] < vertStart || conn[j] > lastVert)
- std::cerr << "Invalid vertex handle: " << conn[j] << std::endl;
+ long x, y, z;
+ const long elem_per_edge = numSideInt;
+ const long deleted_x = (numSideInt+1)*(100-percent) / 100 - 1;
+ MBEntityHandle h = elemStart;
+ for (z = 0; z < elem_per_edge; ++z) {
+ for (y = 0; y < elem_per_edge; ++y) {
+ r = mb.get_connectivity( h, conn, len );
+ assert(conn && 8 == len);
+ h += (elem_per_edge - deleted_x);
+ MBErrorCode r;
int len;
- for (MBEntityHandle h = last-1; h >= elemStart; --h) {
+ long x, y, z;
+ MBEntityHandle h = elemStart + numElem - 1;;
+ for (z = elem_per_edge-1; z >= 0; --z) {
+ for (y = elem_per_edge-1; y >= 0; --y) {
+ h -= (elem_per_edge - deleted_x);
+ MBErrorCode r;
int len;
for (long i = 0; i < numElem; ++i) {
- MBEntityHandle h = elemStart + queryElemPermutation[i];
+ if (!deleted_elem( queryElemPermutation[i], percent )) {
+ r = mb.get_connectivity( elemStart + queryElemPermutation[i], conn, len );
static double hex_centroid( double coords[24], double cent[3] )
double a[3], b[3], c[3], vol;
@@ -548,83 +598,71 @@
vol = c[0]*(a[1]*b[2] - a[2]*b[1]) + c[1]*(a[2]*b[0] - a[0]*b[2]) + c[2]*(a[0]*b[1] - a[1]*b[0]);
return (1./64.) * vol;
+ MBErrorCode r;
int len;
+ long x, y, z;
double coords[24];
- double cent[3], vol, sum_vol = 0.0;
- centroid[0] = centroid[1] = centroid[2] = 0.0;
- if (MB_SUCCESS == mb.get_coords( conn, len, coords )) {
- vol = hex_centroid( coords, cent );
- centroid[0] += cent[0] * vol;
- centroid[1] += cent[1] * vol;
- centroid[2] += cent[2] * vol;
- sum_vol += vol;
+ r = mb.get_coords( conn, len, coords );
+ assert(MB_SUCCESS == r );
- centroid[0] /= sum_vol;
- centroid[1] /= sum_vol;
- centroid[2] /= sum_vol;
+ MBErrorCode r;
int len;
+ long x, y, z;
double coords[24];
- sum_vol += vol;
+ MBErrorCode r;
int len;
double coords[24];
- sum_vol += vol;
@@ -690,46 +728,6 @@
-inline void vertex_coords( long vert_index, double& x, double& y, double& z )
- const long vs = numSideInt + 1;
- x = vert_index % vs;
- y = (vert_index / vs) % vs;
- z = (vert_index / vs / vs);
-inline long vert_index( long x, long y, long z )
- return x + vs * (y + vs * z);
-inline void element_conn( long elem_index, MBEntityHandle conn[8] )
- const long x = elem_index % numSideInt;
- const long y = (elem_index / numSideInt) % numSideInt;
- const long z = (elem_index / numSideInt / numSideInt);
- conn[0] = vertStart + vert_index(x ,y ,z );
- conn[1] = vertStart + vert_index(x+1,y ,z );
- conn[2] = vertStart + vert_index(x+1,y+1,z );
- conn[3] = vertStart + vert_index(x ,y+1,z );
- conn[4] = vertStart + vert_index(x ,y ,z+1);
- conn[5] = vertStart + vert_index(x+1,y ,z+1);
- conn[6] = vertStart + vert_index(x+1,y+1,z+1);
- conn[7] = vertStart + vert_index(x ,y+1,z+1);
-inline bool deleted_vert( long index, int percent )
- return index % 100 >= (100-percent);
-inline bool deleted_elem( long index, int percent )
inline void delete_vert( long index, int percent )
if (deleted_vert(index, percent)) {
