[MOAB-dev] r1360 - MOAB/trunk/test/perf
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Wed Nov 7 16:00:54 CST 2007
Author: kraftche
Date: 2007-11-07 16:00:54 -0600 (Wed, 07 Nov 2007)
New Revision: 1360
Added:
   MOAB/trunk/test/perf/Makefile.am
   MOAB/trunk/test/perf/seqperf.cpp
Modified:
   MOAB/trunk/test/perf/perf.cpp
Log:
performance testing
Added: MOAB/trunk/test/perf/Makefile.am
--- MOAB/trunk/test/perf/Makefile.am	                        (rev 0)
+++ MOAB/trunk/test/perf/Makefile.am	2007-11-07 22:00:54 UTC (rev 1360)
@@ -0,0 +1,17 @@
+DEFS = $(DEFINES)
+INCLUDES += -I$(top_srcdir) \
+            -I$(top_srcdir)/mhdf/include \
+            -I$(top_builddir) \
+            -I$(top_srcdir)/tools/iMesh \
+            -I$(top_builddir)/tools/iMesh
+LDADD = $(top_builddir)/libMOAB.la
+check_PROGRAMS = perf seqperf #cubit_perf tstt_perf tstt_perf_binding
+perf_SOURCES = perf.cpp
+seqperf_SOURCES = seqperf.cpp
+#cubit_perf_SOURCES = cubit_perf.cpp
+#tstt_perf_SOURCES = tstt_perf.cpp
+#tstt_perf_binding_SOURCES = tstt_perf_binding.cpp
Modified: MOAB/trunk/test/perf/perf.cpp
--- MOAB/trunk/test/perf/perf.cpp	2007-11-07 20:36:28 UTC (rev 1359)
+++ MOAB/trunk/test/perf/perf.cpp	2007-11-07 22:00:54 UTC (rev 1360)
@@ -27,15 +27,18 @@
 #endif
 #endif
+#define IS_BUILDING_MB
 #include <stdlib.h>
 #include <stdio.h>
+#include <assert.h>
 #include <iostream>
 #include "MBCore.hpp"
 #include "MBReadUtilIface.hpp"
-#include "ScdVertexSeq.hpp"
-#include "ScdElementSeq.hpp"
+#include "VertexSequence.hpp"
+#include "StructuredElementSeq.hpp"
 #include "EntitySequence.hpp"
-#include "EntitySequenceManager.hpp"
+#include "SequenceManager.hpp"
 #include "HomXform.hpp"
 double LENGTH = 1.0;
@@ -394,27 +397,27 @@
   print_time(false, ttime0, utime, stime);
     // make a 3d block of vertices
-  MBEntitySequence *dum_seq = NULL;
-  ScdVertexSeq *vseq = NULL;
-  ScdElementSeq *eseq = NULL;
-  EntitySequenceManager *seq_mgr = dynamic_cast<MBCore*>(gMB)->sequence_manager();
+  EntitySequence *dum_seq = NULL;
+  ScdVertexData *vseq = NULL;
+  StructuredElementSeq *eseq = NULL;
+  SequenceManager *seq_mgr = dynamic_cast<MBCore*>(gMB)->sequence_manager();
   HomCoord vseq_minmax[2] = {HomCoord(0,0,0),
                              HomCoord(nelem, nelem, nelem)};
   MBEntityHandle vstart, estart;
   MBErrorCode result = seq_mgr->create_scd_sequence(vseq_minmax[0], vseq_minmax[1],
-                                                    MBVERTEX, 1, vstart, dum_seq);
-  if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexSeq*>(dum_seq);
+                                                    MBVERTEX, 1, -1, vstart, dum_seq);
+  if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexData*>(dum_seq->data());
   assert (MB_FAILURE != result && vstart != 0 && dum_seq != NULL && vseq != NULL);
     // now the element sequence
-                                        MBHEX, 1, estart, dum_seq);
-  if (NULL != dum_seq) eseq = dynamic_cast<ScdElementSeq*>(dum_seq);
+                                        MBHEX, 1, -1, estart, dum_seq);
+  if (NULL != dum_seq) eseq = dynamic_cast<StructuredElementSeq*>(dum_seq);
   assert (MB_FAILURE != result && estart != 0 && dum_seq != NULL && eseq != NULL);
     // only need to add one vseq to this, unity transform
     // trick: if I know it's going to be unity, just input 3 sets of equivalent points
-  result = eseq->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
+  result = eseq->sdata()->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
                                vseq_minmax[0], vseq_minmax[0], vseq_minmax[0]);
   assert(MB_SUCCESS == result);
@@ -465,7 +468,7 @@
   // create a sequence to hold the node coordinates
   // get the current number of entities and start at the next slot
   std::vector<double*> coord_arrays;
-  MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, vstart, coord_arrays);
+  MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, -1, vstart, coord_arrays);
   assert(MB_SUCCESS == result && 1 == vstart &&
          coord_arrays[0] && coord_arrays[1] && coord_arrays[2]);
     // memcpy the coordinate data into place
@@ -474,7 +477,7 @@
   memcpy(coord_arrays[2], &coords[2*num_verts], sizeof(double)*num_verts);
   MBEntityHandle *conn = 0;
-  result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, estart, conn);
+  result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, -1, estart, conn);
   memcpy(conn, connect, num_elems*8*sizeof(MBEntityHandle));
   result = readMeshIface->update_adjacencies(estart, num_elems, 8, conn);
Added: MOAB/trunk/test/perf/seqperf.cpp
--- MOAB/trunk/test/perf/seqperf.cpp	                        (rev 0)
+++ MOAB/trunk/test/perf/seqperf.cpp	2007-11-07 22:00:54 UTC (rev 1360)
@@ -0,0 +1,727 @@
+#include <time.h>
+#include <iostream>
+#include <sstream>
+#include "MBCore.hpp"
+#include "MBReadUtilIface.hpp"
+  // constants
+const bool dump_mesh = false;        //!< write mesh to vtk file
+const int default_intervals = 25;    //!< defaul interval count for cubic structured hex mesh
+const int default_query_count = 100; //!< number of times to do each query set
+const int default_order[] = {0, 1, 2};
+const int default_create[] = {0,1};
+const int default_delete[] = {0,10,20,30,40,50,60,70,80,90};
+  // input parameters
+long numSideInt, numVert, numElem;   //!< total counts;
+int queryCount;                      //!< number of times to do each query set
+  // misc globals
+MBCore moab;                         //!< moab instance
+MBInterface& mb = moab;              //!< moab instance
+MBEntityHandle vertStart, elemStart; //!< first handle
+MBReadUtilIface *readTool = 0;
+double centroid[3];
+long* queryVertPermutation = 0;      //!< pupulated by init(): "random" order for vertices
+long* queryElemPermutation = 0;      //!< pupulated by init(): "random" order for elements
+//! Generate random permutation of values in [0,count-1]
+long* permutation( long count )
+  srand( count );
+  long* array = new long[count];
+  for (long i = 0; i < count; ++i)
+    array[i] = i;
+  for (long i = 0; i < count; ++i) {
+    long r = rand();
+    if (count > RAND_MAX) {
+      r += RAND_MAX * rand();
+      if (count > ((long)RAND_MAX*RAND_MAX))
+        r += RAND_MAX*RAND_MAX*rand();
+    std::swap( array[i], array[r%count] );
+  return array;
+//! Initialize global variables
+void init()
+  void* ptr;
+  MBErrorCode rval = mb.query_interface( "MBReadUtilIface", &ptr );
+  readTool = static_cast<MBReadUtilIface*>(ptr);
+  assert( !rval && readTool );
+  queryVertPermutation = permutation( numVert );
+  queryElemPermutation = permutation( numElem );
+void create_vertices_single( ); //!< create vertices one at a time
+void create_vertices_block( );  //!< create vertices in block using MBReadUtilIface
+void create_elements_single( ); //!< create elements one at a time
+void create_elements_block( );  //!< create elements in block using MBReadUtilIface
+void forward_order_query_vertices(); //!< calculate mean of all vertex coordinates
+void reverse_order_query_vertices(); //!< calculate mean of all vertex coordinates
+void  random_order_query_vertices(); //!< calculate mean of all vertex coordinates
+void forward_order_query_elements(); //!< check all element connectivity for valid vertex handles
+void reverse_order_query_elements(); //!< check all element connectivity for valid vertex handles
+void  random_order_query_elements();  //!< check all element connectivity for valid vertex handles
+void forward_order_query_element_verts(); //!< calculate centroid
+void reverse_order_query_element_verts(); //!< calculate centroid
+void  random_order_query_element_verts(); //!< calculate centroid
+void forward_order_delete_vertices( int percent ); //!< delete x% of vertices
+void reverse_order_delete_vertices( int percent ); //!< delete x% of vertices
+void  random_order_delete_vertices( int percent ); //!< delete x% of vertices
+void forward_order_delete_elements( int percent ); //!< delete x% of elements
+void reverse_order_delete_elements( int percent ); //!< delete x% of elements
+void  random_order_delete_elements( int percent ); //!< delete x% of elements
+void create_missing_vertices( int percent ); //!< re-create deleted vertices
+void create_missing_elements( int percent ); //!< re-create deleted elements
+/* Build arrays of function pointers, indexed by the order the entities are traversed in */
+typedef void (*naf_t)();
+typedef void (*iaf_t)(int);
+naf_t query_verts[3] = { &forward_order_query_vertices,
+                         &reverse_order_query_vertices,
+                         & random_order_query_vertices };
+naf_t query_elems[3] = { &forward_order_query_elements,
+                         &reverse_order_query_elements,
+                         & random_order_query_elements };
+naf_t query_elem_verts[3] = { &forward_order_query_element_verts,
+                              &reverse_order_query_element_verts,
+                              & random_order_query_element_verts };
+iaf_t delete_verts[3] = { &forward_order_delete_vertices,
+                          &reverse_order_delete_vertices,
+                          & random_order_delete_vertices };
+iaf_t delete_elems[3] = { &forward_order_delete_elements,
+                          &reverse_order_delete_elements,
+                          & random_order_delete_elements };
+const char* order_strs[] = { "Forward", "Reverse", "Random" };
+//! Coordinates for ith vertex in structured hex mesh
+inline void vertex_coords( long vert_index, double& x, double& y, double& z );
+//! Connectivity for ith hex in structured hex mesh
+inline void element_conn( long elem_index, MBEntityHandle conn[8] );
+//! True if passed index is one of the x% to be deleted
+inline bool deleted_vert( long index, int percent );
+inline bool deleted_elem( long index, int percent );
+//! if (deleted_vert(index,percent)) delete vertex
+inline void delete_vert( long index, int percent );
+//! if (deleted_elem(index,percent)) delete element
+inline void delete_elem( long index, int percent );
+//! print usage and exit
+void usage() {
+  std::cerr << "Usage: seqperf [-i <intervals>] [-o <order>] [-d <percent>] [-b|-s] [-q <count>]" << std::endl;
+  std::cerr << " -i specify size of cubic structured hex mesh in intervals.  Default: " << default_intervals << std::endl;
+  std::cerr << " -o one of \"forward\", \"reverse\", or \"random\".  May be specified multiple times.  Default is all." << std::endl;
+  std::cerr << " -d percent of entities to delete.  May be specified multiple times.  Default is {0,10,20,...,90}." << std::endl;
+  std::cerr << " -b block creation of mesh" << std::endl;
+  std::cerr << " -s single entity mesh creation" << std::endl;
+  std::cerr << " -q number of times to repeat queries.  Default: " << default_query_count << std::endl;
+  exit(1);
+//! convert CPU time to string
+std::string ts( clock_t t )
+  std::ostringstream s;
+  s << ((double)t)/CLOCKS_PER_SEC << 's';
+  return s.str();
+//! run function, printing time spent
+void TIME( const char* str, void (*func)() )
+  std::cout << str << "... " << std::flush;
+  clock_t t = clock();
+  (*func)();
+  std::cout << ts(clock() - t) << std::endl;
+//! run function query_repeat times, printing time spent
+void TIME_QRY( const char* str, void (*func)() )
+  for (int i = 0; i < queryCount; ++i)
+    (*func)();
+//! run function with integer argument, printing time spent
+void TIME_DEL( const char* str, void (*func)(int), int percent )
+  (*func)(percent);
+//! call MB::delete_mesh().  function so can be passed to TIME
+void delete_mesh()
+  mb.delete_mesh();
+//! Run a single combination of test parameters
+void do_test( int create_mode, //!< 0 == single, 1 == block
+              int order,       //!< 0 == forward, 1 == reverse, 2 == random
+              int percent )    //!< percent of entities to delete
+  if (create_mode) {
+    std::cout << "Block Entity Creation (all entities in single block of memory)" << std::endl;
+    TIME ( "  Creating initial vertices", create_vertices_block );
+    TIME ( "  Creating initial elements", create_elements_block );
+    if (dump_mesh && !percent && mb.write_file( "seqperf.vtk" ) == MB_SUCCESS)
+      std::cout << "Wrote mesh to file: seqperf.vtk" << std::endl;
+  else {
+    std::cout << "Single Entity Creation (entities grouped in memory blocks of constant size)" << std::endl;
+    TIME ( "  Creating initial vertices", create_vertices_single );
+    TIME ( "  Creating initial elements", create_elements_single );
+  std::cout << order_strs[order] <<
+    " order with deletion of " << percent << "% of vertices and elements" << std::endl;
+  TIME_DEL( "  Deleting vertices", delete_verts[order], percent );
+  TIME_DEL( "  Deleting elements", delete_elems[order], percent );
+  int num_vert = 0;
+  int num_elem = 0;
+  mb.get_number_entities_by_type( 0, MBVERTEX, num_vert );
+  mb.get_number_entities_by_type( 0, MBHEX,    num_elem );
+  std::cout << "  " << num_vert << " vertices and " << num_elem << " elements remaining" << std::endl;
+  TIME_QRY( "  Quering vertex coordinates", query_verts[order] );
+  TIME_QRY( "  Quering element connectivity", query_elems[order] );
+  TIME_QRY( "  Quering element coordinates", query_elem_verts[order] );
+  TIME_DEL( "  Re-creating vertices", create_missing_vertices, percent );
+  TIME_DEL( "  Re-creating elements", create_missing_elements, percent );
+  TIME( "  Clearing mesh instance", delete_mesh );
+  std::cout << "Total time for test: " << ts(clock()-t) << std::endl << std::endl;
+void parse_order( const char* str, std::vector<int>& list )
+  if (str[0] == 'f') {
+    if (strncmp( str, "forward", strlen(str) ))
+      usage();
+    list.push_back( 0 );
+  else if (str[0] != 'r')
+    usage();
+  else if (str[1] == 'e') {
+    if (strncmp( str, "reverse", strlen(str) ))
+      usage();
+  else {
+    if (strncmp( str, "random", strlen(str) ))
+      usage();
+void parse_percent( const char* str, std::vector<int>& list )
+  char* endptr;
+  long p = strtol( str, &endptr, 0 );
+  if (!endptr || *endptr || p < 0 || p > 100)
+    usage();
+  list.push_back((int)p);
+int parse_positive_int( const char* str )
+  char* endptr;
+  if (!endptr || *endptr || p < 1)
+    usage();
+  int result = p;
+  if (p != (long)result) // overflow
+    usage();
+  return result;
+void check_default( std::vector<int>& list, const int* array, size_t array_len )
+  if (list.empty())
+    std::copy( array, array+array_len, std::back_inserter(list) );
+#define ARRSIZE(A) (sizeof(A)/sizeof(A[0]))
+int main( int argc, char* argv[] )
+    // Parse arguments
+  std::vector<int> createList, orderList, deleteList;
+  numSideInt = default_intervals;
+  queryCount = default_query_count;
+  for (int i = 1; i < argc; ++i) {
+      // check that arg is a '-' followed by a single character
+    if (argv[i][0] != '-' || argv[i][1] == '\0' || argv[i][2] != '\0')
+      usage();
+    const char flag = argv[i][1];
+    switch (flag) {
+      case 'b': createList.push_back( 1 ); break;
+      case 's': createList.push_back( 0 ); break;
+      default:
+        if (++i == argc)
+          usage();
+        switch (flag) {
+          case 'i':
+            numSideInt = parse_positive_int( argv[i] );
+            break;
+          case 'o':
+            parse_order( argv[i], orderList );
+            break;
+          case 'p':
+            parse_percent( argv[i], deleteList );
+            break;
+          case 'q':
+            queryCount = parse_positive_int( argv[i] );
+            break;
+          default:
+            usage();
+  check_default( createList, default_create, ARRSIZE(default_create) );
+  check_default( orderList, default_order, ARRSIZE(default_create) );
+  check_default( deleteList, default_delete, ARRSIZE(default_create) );
+    // Do some initialization.
+  int numSideVert = numSideInt + 1;
+  numVert = numSideVert * numSideVert * numSideVert;
+  numElem = numSideInt * numSideInt * numSideInt;
+  if (numVert / numSideVert / numSideVert != numSideVert) // overflow
+    usage();
+  init();
+    // Echo input args
+  std::cout << numSideInt << "x" << numSideInt << "x" << numSideInt << " hex grid: "
+            << numElem << " elements and " << numVert << " vertices" << std::endl;
+    // Run tests
+  std::vector<int>::const_iterator i,j,k;
+  for (std::vector<int>::iterator i = createList.begin(); i != createList.end(); ++i) {
+    for (std::vector<int>::iterator j = deleteList.begin(); j != deleteList.end(); ++j) {
+      for (std::vector<int>::iterator k = orderList.begin(); k != orderList.end(); ++k) {
+        do_test( *i, *k, *j );
+    // Clean up
+  std::cout << "TOTAL: " << ts(clock() - t) << std::endl << std::endl;
+  delete [] queryVertPermutation;
+  delete [] queryElemPermutation;
+  return 0;
+  double coords[3];
+  vertex_coords( 0, coords[0], coords[1], coords[2] );
+  MBErrorCode rval = mb.create_vertex( coords, vertStart );
+  assert(!rval);
+  MBEntityHandle h;
+  for (long i = 1; i < numVert; ++i) {
+    vertex_coords( i, coords[0], coords[1], coords[2] );
+    rval = mb.create_vertex( coords, h );
+    assert(!rval);
+    assert(h - vertStart == (MBEntityHandle)i);
+  std::vector<double*> arrays;
+  MBErrorCode rval = readTool->get_node_arrays( 3, numVert, 0, -1, vertStart, arrays );
+  assert(!rval && arrays.size() == 3);
+  double *x = arrays[0], *y = arrays[1], *z = arrays[2];
+  assert( x && y && z );
+  for (long i = 0; i < numVert; ++i)
+    vertex_coords( i, *x++, *y++, *z++ );
+  MBEntityHandle conn[8];
+  element_conn( 0, conn );
+  MBErrorCode rval = mb.create_element( MBHEX, conn, 8, elemStart );
+  assert(!rval);
+  MBEntityHandle h;
+  for (long i = 1; i < numElem; ++i) {
+    element_conn( i, conn );
+    rval = mb.create_element( MBHEX, conn, 8, h );
+    assert(!rval);
+    assert(h - elemStart == (MBEntityHandle)i);
+  MBEntityHandle* conn = 0;
+  MBErrorCode rval = readTool->get_element_array( numElem, 8, MBHEX, 0, -1, elemStart, conn );
+  assert(!rval && conn);
+  for (long i = 0; i < numElem; ++i)
+    element_conn( i, conn + 8*i );
+  double coords[3], sum[3] = {0,0,0};
+  const MBEntityHandle last = vertStart + numVert;
+  for (MBEntityHandle h = vertStart; h < last; ++h) {
+    mb.get_coords( &h, 1, coords );
+    sum[0] += coords[0];
+    sum[1] += coords[1];
+    sum[2] += coords[2];
+  centroid[0] = sum[0] / numVert;
+  centroid[1] = sum[1] / numVert;
+  centroid[2] = sum[2] / numVert;
+  for (MBEntityHandle h = last-1; h >= vertStart; --h) {
+  MBEntityHandle h;
+  for (long i = 0; i < numVert; ++i) {
+    h = vertStart + queryVertPermutation[i];
+  const MBEntityHandle* conn;
+  int len;
+  const MBEntityHandle lastVert = vertStart + numVert - 1;
+  const MBEntityHandle last = elemStart + numElem;
+  for (MBEntityHandle h = elemStart; h < last; ++h) {
+    if (MB_SUCCESS == mb.get_connectivity( h, conn, len )) {
+      assert( 8 == len );
+      for (int j = 0; j < 8; ++j)
+        if (conn[j] < vertStart || conn[j] > lastVert)
+          std::cerr << "Invalid vertex handle: " << conn[j] << std::endl;
+  int len;
+  for (MBEntityHandle h = last-1; h >= elemStart; --h) {
+  int len;
+  for (long i = 0; i < numElem; ++i) {
+    MBEntityHandle h = elemStart + queryElemPermutation[i];
+static double hex_centroid( double coords[24], double cent[3] )
+  double a[3], b[3], c[3], vol;
+  cent[0] += 0.125*(coords[0] + coords[3] + coords[6] + coords[ 9] + coords[12] + coords[15] + coords[18] + coords[21]);
+  cent[1] += 0.125*(coords[1] + coords[4] + coords[7] + coords[10] + coords[13] + coords[16] + coords[19] + coords[22]);
+  cent[2] += 0.125*(coords[2] + coords[5] + coords[8] + coords[11] + coords[14] + coords[17] + coords[20] + coords[23]);
+  a[0] = coords[0] + coords[3] + coords[15] + coords[12] - coords[ 9] - coords[6] - coords[18] - coords[21];
+  a[1] = coords[1] + coords[4] + coords[16] + coords[13] - coords[10] - coords[7] - coords[19] - coords[22];
+  a[2] = coords[2] + coords[5] + coords[17] + coords[14] - coords[11] - coords[8] - coords[20] - coords[23];
+  b[0] = coords[0] + coords[ 9] + coords[21] + coords[12] - coords[3] - coords[6] - coords[18] - coords[15];
+  b[1] = coords[1] + coords[10] + coords[22] + coords[13] - coords[4] - coords[7] - coords[19] - coords[16];
+  b[2] = coords[2] + coords[11] + coords[23] + coords[14] - coords[5] - coords[8] - coords[20] - coords[17];
+  c[0] = coords[0] + coords[3] + coords[6] + coords[ 9] - coords[12] - coords[15] - coords[18] - coords[21];
+  c[1] = coords[1] + coords[4] + coords[7] + coords[10] - coords[13] - coords[16] - coords[19] - coords[22];
+  c[2] = coords[2] + coords[5] + coords[8] + coords[11] - coords[14] - coords[17] - coords[20] - coords[23];
+  vol = c[0]*(a[1]*b[2] - a[2]*b[1]) + c[1]*(a[2]*b[0] - a[0]*b[2]) + c[2]*(a[0]*b[1] - a[1]*b[0]);
+  return (1./64.) * vol;
+  int len;
+  double coords[24];
+  double cent[3], vol, sum_vol = 0.0;
+  centroid[0] = centroid[1] = centroid[2] = 0.0;
+      if (MB_SUCCESS == mb.get_coords( conn, len, coords )) {
+        vol = hex_centroid( coords, cent );
+        centroid[0] += cent[0] * vol;
+        centroid[1] += cent[1] * vol;
+        centroid[2] += cent[2] * vol;
+        sum_vol += vol;
+  centroid[0] /= sum_vol;
+  centroid[1] /= sum_vol;
+  centroid[2] /= sum_vol;
+  int len;
+        sum_vol += vol;
+  int len;
+        sum_vol += vol;
+    delete_vert( i, percent );
+  for (long i = numVert-1; i >= 0; --i)
+    delete_vert( queryVertPermutation[i], percent );
+    delete_elem( i, percent );
+  for (long i = numElem-1; i >= 0; --i)
+    delete_elem( queryElemPermutation[i], percent );
+  MBEntityHandle h;
+  MBErrorCode rval;
+  double coords[3];
+    if (deleted_vert( i, percent )) {
+      assert(!rval);
+  MBEntityHandle h;
+  MBErrorCode rval;
+    if (deleted_elem( i, percent )) {
+      assert(!rval);
+  const long vs = numSideInt + 1;
+  x = vert_index % vs;
+  y = (vert_index / vs) % vs;
+  z = (vert_index / vs / vs);
+inline long vert_index( long x, long y, long z )
+  return x + vs * (y + vs * z);
+  const long x = elem_index % numSideInt;
+  const long y = (elem_index / numSideInt) % numSideInt;
+  const long z = (elem_index / numSideInt / numSideInt);
+  conn[0] = vertStart + vert_index(x  ,y  ,z  );
+  conn[1] = vertStart + vert_index(x+1,y  ,z  );
+  conn[2] = vertStart + vert_index(x+1,y+1,z  );
+  conn[3] = vertStart + vert_index(x  ,y+1,z  );
+  conn[4] = vertStart + vert_index(x  ,y  ,z+1);
+  conn[5] = vertStart + vert_index(x+1,y  ,z+1);
+  conn[6] = vertStart + vert_index(x+1,y+1,z+1);
+  conn[7] = vertStart + vert_index(x  ,y+1,z+1);
+  return index % 100 >= (100-percent);
+  if (deleted_vert(index, percent)) {
+    MBEntityHandle h = index + vertStart;
+    MBErrorCode rval = mb.delete_entities( &h, 1 );
+    assert(!rval);
+  if (deleted_elem(index, percent)) {
+    MBEntityHandle h = index + elemStart;
+    assert(!rval);
