[MOAB-dev] r1355 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Nov 5 12:55:19 CST 2007
Author: kraftche
Date: 2007-11-05 12:55:19 -0600 (Mon, 05 Nov 2007)
New Revision: 1355
Modified:
   MOAB/trunk/AEntityFactory.cpp
   MOAB/trunk/AEntityFactory.hpp
   MOAB/trunk/DenseTagCollections.cpp
   MOAB/trunk/DenseTagCollections.hpp
Log:
Make functions 'const' where appropriate
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2007-11-05 16:33:12 UTC (rev 1354)
+++ MOAB/trunk/AEntityFactory.cpp	2007-11-05 18:55:19 UTC (rev 1355)
@@ -575,7 +575,7 @@
 MBErrorCode AEntityFactory::get_adjacencies(MBEntityHandle entity,
                                             const MBEntityHandle *&adjacent_entities,
-                                            int &num_entities)
+                                            int &num_entities) const
   MBAdjacencyVector *adj_vec = NULL;
   MBErrorCode result = mDensePageGroup.get_data(entity, &adj_vec);
@@ -591,7 +591,7 @@
-                                            std::vector<MBEntityHandle>& adjacent_entities)
+                                            std::vector<MBEntityHandle>& adjacent_entities) const
Modified: MOAB/trunk/AEntityFactory.hpp
--- MOAB/trunk/AEntityFactory.hpp	2007-11-05 16:33:12 UTC (rev 1354)
+++ MOAB/trunk/AEntityFactory.hpp	2007-11-05 18:55:19 UTC (rev 1355)
@@ -97,11 +97,11 @@
     //! return const array * for adjacencies
   MBErrorCode get_adjacencies(MBEntityHandle entity,
-                               int &num_entities);
+                               int &num_entities) const;
   //! returns the entities in sorted order
-                               std::vector<MBEntityHandle>& adjacent_entities);
+                               std::vector<MBEntityHandle>& adjacent_entities) const;
   //! creates vertex to element adjacency information
Modified: MOAB/trunk/DenseTagCollections.cpp
--- MOAB/trunk/DenseTagCollections.cpp	2007-11-05 16:33:12 UTC (rev 1354)
+++ MOAB/trunk/DenseTagCollections.cpp	2007-11-05 18:55:19 UTC (rev 1355)
@@ -195,15 +195,15 @@
 MBErrorCode DensePageGroup::get_entities_with_tag_value(const MBEntityType type,
                                                         const void* value,
-                                                        MBRange &entities)
+                                                        MBRange &entities) const
     // for now, return if default value is requested
   if (mDefaultValue && !memcmp(value,mDefaultValue,mBytesPerFlag))
     return MB_FAILURE;
     // iterate over dense pages
-  std::vector<DensePage>::iterator page_it;
-  const std::vector<DensePage>::iterator end = mDensePages[type].end();
+  std::vector<DensePage>::const_iterator page_it;
+  const std::vector<DensePage>::const_iterator end = mDensePages[type].end();
   int dum =0;
   MBEntityHandle handle = CREATE_HANDLE(type, 0, dum);
   MBRange::iterator insert_iter = entities.begin();
@@ -224,7 +224,7 @@
 MBErrorCode DensePageGroup::get_memory_use( unsigned long& total,
-                                            unsigned long& per_entity )
+                                            unsigned long& per_entity ) const
   per_entity = tag_size();
Modified: MOAB/trunk/DenseTagCollections.hpp
--- MOAB/trunk/DenseTagCollections.hpp	2007-11-05 16:33:12 UTC (rev 1354)
+++ MOAB/trunk/DenseTagCollections.hpp	2007-11-05 18:55:19 UTC (rev 1355)
@@ -62,7 +62,7 @@
   //! get the bytes from a page
   MBErrorCode get_bytes(int offset, int num_bytes_per_flag,
-      void* data);
+      void* data) const;
   //! set the bytes in a page
   MBErrorCode set_bytes(int offset, int num_bytes_per_flag,
@@ -76,7 +76,7 @@
   bool has_data() const { return mByteArray != 0; }
     //! do a memcmp on one of the values in this page
-  bool memcmp(int offset, int num_bytes_per_flag, const void *data);
+  bool memcmp(int offset, int num_bytes_per_flag, const void *data) const;
   //!std::auto_ptr-style behavior
   DensePage( const DensePage& other )
@@ -102,7 +102,7 @@
     takes how many bytes to get
     return data
-inline MBErrorCode DensePage::get_bytes(int offset, int num_bytes_per_flag, void* data)
+inline MBErrorCode DensePage::get_bytes(int offset, int num_bytes_per_flag, void* data) const
   // if no memory has been allocated, get the default value
   if(!mByteArray)
@@ -117,7 +117,7 @@
-inline bool DensePage::memcmp(int offset, int num_bytes_per_flag, const void *data)
+inline bool DensePage::memcmp(int offset, int num_bytes_per_flag, const void *data) const
   assert(mByteArray);
@@ -199,7 +199,7 @@
   ~DensePageGroup() { free(mDefaultValue); }
   //! get data from byte pages
-  MBErrorCode get_data(MBEntityHandle handle, void* data);
+  MBErrorCode get_data(MBEntityHandle handle, void* data) const;
   //! set data in byte pages
   MBErrorCode set_data(MBEntityHandle handle, const void* data);
@@ -208,17 +208,17 @@
   MBErrorCode remove_data(MBEntityHandle handle);
   //! get number of entities of type
-  MBErrorCode get_number_entities(MBEntityType type, int& num_entities);
+  MBErrorCode get_number_entities(MBEntityType type, int& num_entities) const;
   //! get the entities
-  MBErrorCode get_entities(MBEntityType type, MBRange& entities);
+  MBErrorCode get_entities(MBEntityType type, MBRange& entities) const;
-  MBErrorCode get_entities(MBRange& entities);
+  MBErrorCode get_entities(MBRange& entities) const;
   //! get the entities with a value
   MBErrorCode get_entities_with_tag_value(const MBEntityType type, const void* value,
-                                          MBRange &entities);
+                                          MBRange &entities) const;
     //! return true if this page group contains this entity, false otherwise
   bool contains(const MBEntityHandle entity) const;
@@ -229,7 +229,7 @@
   const void* get_default_value() const { return mDefaultValue; }
   MBErrorCode get_memory_use( unsigned long& total,
-                              unsigned long& per_entity );
+                              unsigned long& per_entity ) const;
 private:
@@ -257,7 +257,7 @@
     takes entity handle
     return the data
-inline MBErrorCode DensePageGroup::get_data(MBEntityHandle handle, void* data)
+inline MBErrorCode DensePageGroup::get_data(MBEntityHandle handle, void* data) const
   // strip off the entity type
   const MBEntityType type = TYPE_FROM_HANDLE( handle );
@@ -266,7 +266,7 @@
   const MBEntityID which_page = entity_id / DensePage::mPageSize;
   const unsigned int offset = entity_id % DensePage::mPageSize;
-  std::vector<DensePage>::iterator page = mDensePages[type].begin() + which_page;
+  std::vector<DensePage>::const_iterator page = mDensePages[type].begin() + which_page;
   if (page >= mDensePages[type].end())
     return MB_TAG_NOT_FOUND;
@@ -333,10 +333,10 @@
-inline MBErrorCode DensePageGroup::get_entities(MBEntityType type, MBRange& entities)
+inline MBErrorCode DensePageGroup::get_entities(MBEntityType type, MBRange& entities) const
-  std::vector<DensePage>::iterator iter;
+  std::vector<DensePage>::const_iterator iter;
   int dum =0;
   MBEntityID first_time = MB_START_ID; // Don't want zero-ID handle at start of range.
@@ -351,12 +351,12 @@
-inline MBErrorCode DensePageGroup::get_entities(MBRange& entities)
+inline MBErrorCode DensePageGroup::get_entities(MBRange& entities) const
   int dum =0;
   for (MBEntityType type = MBENTITYSET; type >= MBVERTEX; type--) {
     MBRange::iterator insert_pos = entities.begin();
@@ -372,11 +372,11 @@
-inline MBErrorCode DensePageGroup::get_number_entities(MBEntityType type, int& entities)
+inline MBErrorCode DensePageGroup::get_number_entities(MBEntityType type, int& entities) const
   entities = 0;
   for(iter = mDensePages[type].begin(); iter != end; ++iter) {
     if(iter->has_data())
