[MOAB-dev] r1177 - in MOAB/trunk: . test
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jun 28 22:52:11 CDT 2007
Author: tautges
Date: 2007-06-28 22:52:10 -0500 (Thu, 28 Jun 2007)
New Revision: 1177
Added:
   MOAB/trunk/test/brick_cubit10.1.cub
   MOAB/trunk/test/brick_cubit10.2.cub
   MOAB/trunk/test/brick_cubit10.cub
Removed:
   MOAB/trunk/test/block.cub
Modified:
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/Tqdcfr.hpp
Log:
Removing test/block.cub, and replacing with versioned cub files.  The
original block.cub was from cubit v10.1b, and didn't read in right,
while .cub files from 10.0, 10.1, and 10.2 did read in right.
Fixed an annoying compile warning initializing non-const strings.
All the make check tests pass now.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2007-06-29 03:03:36 UTC (rev 1176)
+++ MOAB/trunk/Tqdcfr.cpp	2007-06-29 03:52:10 UTC (rev 1177)
@@ -70,8 +70,8 @@
   8, 8, 9, 20, 27, 12, // hexes (incl. hexshell at end)
   0};
-char *Tqdcfr::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET";
-char *Tqdcfr::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET";
+std::string Tqdcfr::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET";
+std::string Tqdcfr::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET";
 #define RR if (MB_SUCCESS != result) return result
@@ -313,7 +313,7 @@
     // set, we don't need to convert
   int nodeset_offset, sideset_offset;
   MBTag tmp_tag;
-  MBErrorCode result = mdbImpl->tag_get_handle(BLOCK_NODESET_OFFSET_TAG_NAME,
+  MBErrorCode result = mdbImpl->tag_get_handle(BLOCK_NODESET_OFFSET_TAG_NAME.c_str(),
                                                tmp_tag);
   if (MB_SUCCESS != result) nodeset_offset = 0;
   else {
@@ -321,7 +321,7 @@
     if (MB_SUCCESS != result) return result;
-  result = mdbImpl->tag_get_handle(BLOCK_SIDESET_OFFSET_TAG_NAME,
+  result = mdbImpl->tag_get_handle(BLOCK_SIDESET_OFFSET_TAG_NAME.c_str(),
                                    tmp_tag);
   if (MB_SUCCESS != result) sideset_offset = 0;
   else {
@@ -2388,7 +2388,7 @@
     // Check command line arg
-  const char* file = TEST_DIR "/block.cub";
+  const char* file = TEST_DIR "/brick_cubit10.2.cub";
   if (argc < 2)
     std::cout << "Usage: tqdcfr <cub_file_name>" << std::endl;
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp	2007-06-29 03:03:36 UTC (rev 1176)
+++ MOAB/trunk/Tqdcfr.hpp	2007-06-29 03:52:10 UTC (rev 1177)
@@ -316,8 +316,8 @@
   Tqdcfr(MBInterface *impl);
-  static char *BLOCK_NODESET_OFFSET_TAG_NAME;
-  static char *BLOCK_SIDESET_OFFSET_TAG_NAME;
+  static std::string BLOCK_NODESET_OFFSET_TAG_NAME;
+  static std::string BLOCK_SIDESET_OFFSET_TAG_NAME;
 private:
Deleted: MOAB/trunk/test/block.cub
--- MOAB/trunk/test/block.cub	2007-06-29 03:03:36 UTC (rev 1176)
+++ MOAB/trunk/test/block.cub	2007-06-29 03:52:10 UTC (rev 1177)
@@ -1,369 +0,0 @@
-CUBE              UÇ        4 !:               ”   ô‹                                     ˆŒ ¬                                                ô‹    X    ‹ ¬‹ ¸‹         Ä‹    ¸  Ћ    è  Ü‹    H  è‹        ¨                  >aC       Ä                  „íre       à                  Æ/YA       ü                  -ŠÃ                         §‰ëF       4                  Åh3       P                  ƒ°}       l                  `	àl    	   ˆ
-   „     „   ÑŠ@
-        „   ,n t    	   ˆ
-   „	     „   ŽÈÏ
-        „   „e!4    	   ˆ
-   „     „   ‡›Ï
-        „       	   ˆ
-        „   „Æ«9    	   ˆ
-   „     „   Ö1Y,
-        „   ÚeN    	   ˆ
-   „     „   ýz
-        „   _L¸I    Q   ˆ    d      X  nôÕf    Q   ¼0    ˜9     X  ¾1ß    Q   ðI    ÌR     X  \á^7    Q   $c     l     X  ¸Y    Q   X|    4…     X  Ñ׊}    Q   Œ•    hž     X  wy#B    Ù  À®  è  |þ     ¬Œ  É	       '      (‹        ÿÿÿÿ                       4‹        ÿÿÿÿ             @‹        ÿÿÿÿ             L‹        ÿÿÿÿ             X‹        ÿÿÿÿ             p‹        ÿÿÿÿ             ˆ‹        ÿÿÿÿ                @      À      @         @      @      @         À      @      @         À      À      @z         @      @      À{         @      À      À…         À      À      À         À      @      À
-            @      @      @      @      @      @      @      @      @      À      À       À      ð¿              ð?       @      @      @      @      @      @      @      @      @      @      @      @
-                                 @      @       @      ð?              ð¿       À      À      À      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @
-                                    À      À      À      À      À      À      À      À      À      @      @       @      ð?              ð¿       À      À      À      @      @      @      @      @      @      @      @      @
-        !   "   #   $   %   &   '   (         À      À       À      ð¿              ð?       @      @      @      À      À      À      À      À      À      À      À      À      @      @      @      @      @      @      @      @      @
-   (   '   &   %   $   #   "   !          (      '   (   &   '   %   &   $   %   #   $   "   #   !   "       !          |   }   ~      €      ‚   ƒ   „         @      @      @      @      @      @      @      @      @      @      @       @      ð?              ð¿       À      À      À      À      À      À      À      À      À      À      À      À
-   æ   å   ä   ã   â   á   à   ß   Þ   Ý   „   {   ƒ   „   ‚   ƒ      ‚   €         €   ~      }   ~   |   }   z   |   †   ‡   ˆ   ‰   Š   ‹   Œ      Ž         @      @       @      ð?              ð¿       À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À
-   ð   ï   î   í   ì   ë   ê   é   è   ç   Ž   …      Ž   Œ      ‹   Œ   Š   ‹   ‰   Š   ˆ   ‰   ‡   ˆ   †   ‡   {   †      ‘   ’   “   ”   •   –   —   ˜         À      À      À      À      À      À      À      À      À      À      À       À      ð¿              ð?       @      @      @      À      À      À      À      À      À      À      À      À
-   ú   ù   ø   ÷   ö   õ   ô   ó   ò   ñ   ˜      —   ˜   –   —   •   –   ”   •   “   ”   ’   “   ‘   ’      ‘   …      ™   š   ›   œ      ž   Ÿ       ¡         À      À       À      ð¿              ð?       @      @      @      @      @      @      @      @      @      @      @      @      À      À      À      À      À      À      À      À      À
-              ÿ   þ   ý   ü   û   ¡   z       ¡   Ÿ       ž   Ÿ      ž   œ      ›   œ   š   ›   ™   š      ™   ó   ô   õ   ö   ÷   ø   ù   ú   û         À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      @      @       @      ð?              ð¿       À      À      À
-   Â  Á  À  ¿  ¾  ½  ¼  »  º  ¹  û   …   ú   û   ù   ú   ø   ù   ÷   ø   ö   ÷   õ   ö   ô   õ   ó   ô      ó   ü   ý   þ   ÿ                    @      @      @      @      @      @      @      @      @      À      À      À      À      À      À      À      À      À      @      @       @      ð?              ð¿       À      À      À
-   Ì  Ë  Ê  É  È  Ç  Æ  Å  Ä  Ã    {                    ÿ      þ   ÿ   ý   þ   ü   ý      ü   V  W  X  Y  Z  [  \  ]  ^        À      À      À      À      À      À      À      À      À      @      @      @      @      @      @      @      @      @      @      @       @      ð?              ð¿       À      À      À
-   Š  ‰  ˆ  ‡  †  …  „  ƒ  ‚    ^     ]  ^  \  ]  [  \  Z  [  Y  Z  X  Y  W  X  V  W     V  °  ±  ²  ³  ´  µ  ¶  ·  ¸        @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @       @      ð?              ð¿       À      À      À
-   H  G  F  E  D  C  B  A  @  ?  ¸  z   ·  ¸  ¶  ·  µ  ¶  ´  µ  ³  ´  ²  ³  ±  ²  °  ±     °  )   *   +   ,   -   .   /   0   1   2   3   4   5   6   7   8   9   :   ;   <   =   >   ?   @   A   B   C   D   E   F   G   H   I   J   K   L   M   N   O   P   Q   R   S   T   U   V   W   X   Y   Z   [   \   ]   ^   _   `   a   b   c   d   e   f   g   h   i   j   k   l   m   n   o   p   q   r   s   t   u   v   w   x   y         @     @þÿÿÿÿÿÿ?     ð?      ”<     ð¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÀüÿÿÿÿÿÀ     @      @ýÿÿÿÿÿÿ?      ð?      ¤<ÿÿÿÿÿÿï¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @       @      ð?      ¤¼      ð¿ÿÿÿÿÿÿÿ¿     ÀÿÿÿÿÿÿÀ      @      @       @      ð?      <     ð¿þÿÿÿÿÿÿ¿     À     À      @      @       @      ð?              ð¿       À      À      À     @     @ÿÿÿÿÿÿÿ?      ð?      ¼     ð¿      ÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ     @ÿÿÿÿÿÿ@       @ýÿÿÿÿÿï?       ¼þÿÿÿÿÿï¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?       <     ð¿      À     À      Àÿÿÿÿÿÿ@ÿÿÿÿÿÿ@       @     ð?      <     ð¿þÿÿÿÿÿÿ¿üÿÿÿÿÿÀ      À      À      À      À      À      À     À      À      ÀÿÿÿÿÿÿÀ     À     ÀÿÿÿÿÿÿÀ      À      À     À      À     ÀÿÿÿÿÿÿÀþÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À       Àþÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À     ð¿     ð¿     ð¿     ð¿      ð¿     ð¿      ð¿     ð¿     ð¿      ”¼      ¤¼      ¤<      ¼              <       <       ¼      ¼     ð?      ð?     ð?     ð?      ð?ÿÿÿÿÿÿï?     ð?     ð?      ð?       @ýÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @      @þÿÿÿÿÿÿ?       @      @ýÿÿÿÿÿ@     @þÿÿÿÿÿ@þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿ@üÿÿÿÿÿ@þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      d   d   c   b   a   `   _   ^   ]   \   [   Z   Y   X   W   V   U   T   S   R   Q   P   O   N   M   L   K   J   I   H   G   F   E   D   C   B   A   @   ?   >   =   <   ;   :   9   8   7   6   5   4   3   2   1   0   /   .   -   ,   +   *   )   (   '   &   %   $   #   "   !
-   	                           y            p   y         g   p         ^   g         U   ^         L   U         C   L         :   C         1   :             1         x         y   o   x   y   p   f   o   p   g   ]   f   g   ^   T   ]   ^   U   K   T   U   L   B   K   L   C   9   B   C   :   0   9   :   1   !   0   1       w         x   n   w   x   o   e   n   o   f   \   e   f   ]   S   \   ]   T   J   S   T   K   A   J   K   B   8   A   B   9   /   8   9   0   "   /   0   !   v         w   m   v   w   n   d   m   n   e   [   d   e   \   R   [   \   S   I   R   S   J   @   I   J   A   7   @   A   8   .   7   8   /   #   .   /   "   u         v   l   u   v   m   c   l   m   d   Z   c   d   [   Q   Z   [   R   H   Q   R   I   ?   H   I   @   6   ?   @   7   -   6   7   .   $   -   .   #   t         u   k   t   u   l   b   k   l   c   Y   b   c   Z   P   Y   Z   Q   G   P   Q   H   >   G   H   ?   5   >   ?   6   ,   5   6   -   %   ,   -   $   s         t   j   s   t   k   a   j   k   b   X   a   b   Y   O   X   Y   P   F   O   P   G   =   F   G   >   4   =   >   5   +   4   5   ,   &   +   ,   %   r         s   i   r   s   j   `   i   j   a   W   `   a   X   N   W   X   O   E   N   O   F   <   E   F   =   3   <   =   4   *   3   4   +   '   *   +   &   q
-      r   h   q   r   i   _   h   i   `   V   _   `   W   M   V   W   N   D   M   N   E   ;   D   E   <   2   ;   <   3   )   2   3   *   (   )   *   '
-   q
-      q   h
-   h   _      	   _   V         V   M         M   D         D   ;         ;   2         2   )         )   (         ´   Ü   Û   Ú   Ù   Ø   ×   Ö   Õ   Ô   Ó   Ò   Ñ   Ð   Ï   Î   Í   Ì   Ë   Ê   É   È   Ç   Æ   Å   Ä   à      Á   À   ¿   ¾   ½   ¼   »   º   ¹   ¸   ·   ¶   µ   ´   ³   ²   ±   °   ¯   ®   ­   ¬   «   ª   ©   ¨   §   ¦   ¥   ¤   £   ¢   ¡       Ÿ   ž      œ   ›   š   ™   ˜   —   –   •   ”   “   ’   ‘         Ž      Œ   ‹   Š   ‰   ˆ   ‡   †   …   „   ƒ   ‚      €      ~   }   |   {   z   y   x   w   v   u   t   s   r   q   p   o   n   m   l   k   j   i   h   g   f   e   d   c   b   a   `   _   ^   ]   \   [   Z   Y   X   W   V   U   T   S   R   Q   P   O   N   M   L   K   J   I   H   G   F   E   D   C   B   A   @   ?   >   =   <   ;   :   9   8   7   6   5   4   3   2   1   0   /   .   -   ,   +   *   )   y      p      g      ^      U      L      C      :      1         y   y   p   x   y   p   g   o   p   g   ^   f   g   ^   U   ]   ^   U   L   T   U   L   C   K   L   C   :   B   C   :   1   9   :   1       0   1      x   x   o   w   x   o   f   n   o   f   ]   e   f   ]   T   \   ]   T   K   S   T   K   B   J   K   B   9   A   B   9   0   8   9   0   !   /   0      w   w   n   v   w   n   e   m   n   e   \   d   e   \   S   [   \   S   J   R   S   J   A   I   J   A   8   @   A   8   /   7   8   /   "   .   /      v   v   m   u   v   m   d   l   m   d   [   c   d   [   R   Z   [   R   I   Q   R   I   @   H   I   @   7   ?   @   7   .   6   7   .   #   -   .      u   u   l   t   u   l   c   k   l   c   Z   b   c   Z   Q   Y   Z   Q   H   P   Q   H   ?   G   H   ?   6   >   ?   6   -   5   6   -   $   ,   -      t   t   k   s   t   k   b   j   k   b   Y   a   b   Y   P   X   Y   P   G   O   P   G   >   F   G   >   5   =   >   5   ,   4   5   ,   %   +   ,      s   s   j   r   s   j   a   i   j   a   X   `   a   X   O   W   X   O   F   N   O   F   =   E   F   =   4   <   =   4   +   3   4   +   &   *   +      r   r   i   q   r   i   `   h   i   `   W   _   `   W   N   V   W   N   E   M   N   E   <   D   E   <   3   ;   <   3   *   2   3   *   '   )   *
-   q   q   h      q   h   _
-   h   _   V   	   _   V   M      V   M   D      M   D   ;      D   ;   2      ;   2   )      2   )   (      )   ¢   £   ¤   ¥   ¦   §   ¨   ©   ª   «   ¬   ­   ®   ¯   °   ±   ²   ³   ´   µ   ¶   ·   ¸   ¹   º   »   ¼   ½   ¾   ¿   À   Á      à   Ä   Å   Æ   Ç   È   É   Ê   Ë   Ì   Í   Î   Ï   Ð   Ñ   Ò   Ó   Ô   Õ   Ö   ×   Ø   Ù   Ú   Û   Ü   Ý   Þ   ß   à   á   â   ã   ä   å   æ   ç   è   é   ê   ë   ì   í   î   ï   ð   ñ   ò         @     @þÿÿÿÿÿÿ?     ð?      ”<     ð¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÀüÿÿÿÿÿÀ     @      @ýÿÿÿÿÿÿ?      ð?      ¤<ÿÿÿÿÿÿï¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @       @      ð?      ¤¼      ð¿ÿÿÿÿÿÿÿ¿     ÀÿÿÿÿÿÿÀ      @      @       @      ð?      <     ð¿þÿÿÿÿÿÿ¿     À     À      @      @       @      ð?              ð¿       À      À      À     @     @ÿÿÿÿÿÿÿ?      ð?      ¼     ð¿      ÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ     @ÿÿÿÿÿÿ@       @ýÿÿÿÿÿï?       ¼þÿÿÿÿÿï¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?       <     ð¿      À     À      Àÿÿÿÿÿÿ@ÿÿÿÿÿÿ@       @     ð?      <     ð¿þÿÿÿÿÿÿ¿üÿÿÿÿÿÀ      À      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@      @      @     @      @     @ÿÿÿÿÿÿ@þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @     ð?     ð?     ð?     ð?      ð?     ð?      ð?     ð?     ð?      ”<      ¤<      ¤¼      <              ¼       ¼       <      <     ð¿      ð¿     ð¿     ð¿      ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿      ð¿       Àýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À      Àþÿÿÿÿÿÿ¿       À      ÀýÿÿÿÿÿÀ     ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀüÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀ      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      d   È   Ç   Æ   Å   Ä   à      Á   À   ¿   ¾   ½   ¼   »   º   ¹   ¸   ·   ¶   µ   ´   ³   ²   ±   °   ¯   ®   ­   ¬   «   ª   ©   ¨   §   ¦   ¥   ¤   £   ¢   ¡       Ÿ   ž      œ   ›   š   ™   ˜   —   –   •   ”   “   ’   ‘         Ž      Œ   ‹   Š   ‰   ˆ   ‡   †   …   „   ƒ   ‚      €      ~   }   |   {   z   y   x   w   v   u   t   s   r   q   p   o   n   m   l   k   j   i   h   g   f   e   ò   Ž   …      é   ò      ‘   à   é   ‘   ’   ×   à   ’   “   Î   ×   “   ”   Å   Î   ”   •   ¼   Å   •   –   ³   ¼   –   —   ª   ³   —   ˜   ™   ª   ˜      ñ      Ž   ò   è   ñ   ò   é   ß   è   é   à   Ö   ß   à   ×   Í   Ö   ×   Î   Ä   Í   Î   Å   »   Ä   Å   ¼   ²   »   ¼   ³   ©   ²   ³   ª   š   ©   ª   ™   ð   Œ      ñ   ç   ð   ñ   è   Þ   ç   è   ß   Õ   Þ   ß   Ö   Ì   Õ   Ö   Í   à   Ì   Í   Ä   º   à   Ä   »   ±   º   »   ²   ¨   ±   ²   ©   ›   ¨   ©   š   ï   ‹   Œ   ð   æ   ï   ð   ç   Ý   æ   ç   Þ   Ô   Ý   Þ   Õ   Ë   Ô   Õ   Ì      Ë   Ì   à   ¹      à   º   °   ¹   º   ±   §   °   ±   ¨   œ   §   ¨   ›   î   Š   ‹   ï   å   î   ï   æ   Ü   å   æ   Ý   Ó   Ü   Ý   Ô   Ê   Ó   Ô   Ë   Á   Ê   Ë      ¸   Á      ¹   ¯   ¸   ¹   °   ¦   ¯   °   §      ¦   §   œ   í   ‰   Š   î   ä   í   î   å   Û   ä   å   Ü   Ò   Û   Ü   Ó   É   Ò   Ó   Ê   À   É   Ê   Á   ·   À   Á   ¸   ®   ·   ¸   ¯   ¥   ®   ¯   ¦   ž   ¥   ¦      ì   ˆ   ‰   í   ã   ì   í   ä   Ú   ã   ä   Û   Ñ   Ú   Û   Ò   È   Ñ   Ò   É   ¿   È   É   À   ¶   ¿   À   ·   ­   ¶   ·   ®   ¤   ­   ®   ¥   Ÿ   ¤   ¥   ž   ë   ‡   ˆ   ì   â   ë   ì   ã   Ù   â   ã   Ú   Ð   Ù   Ú   Ñ   Ç   Ð   Ñ   È   ¾   Ç   È   ¿   µ   ¾   ¿   ¶   ¬   µ   ¶   ­   £   ¬   ­   ¤       £   ¤   Ÿ   ê   †   ‡   ë   á   ê   ë   â   Ø   á   â   Ù   Ï   Ø   Ù   Ð   Æ   Ï   Ð   Ç   ½   Æ   Ç   ¾   ´   ½   ¾   µ   «   ´   µ   ¬   ¢   «   ¬   £   ¡   ¢   £       „   {   †   ê   ƒ   „   ê   á   ‚   ƒ   á   Ø      ‚   Ø   Ï   €      Ï   Æ      €   Æ   ½   ~      ½   ´   }   ~   ´   «   |   }   «   ¢   z   |   ¢   ¡         ´   ¸  ·  ¶  µ  ´  ³  ²  ±  °  ¯  ®  ­  ¬  «  ª  ©  ¨  §  ¦  ¥  ¤  £  ¢  ¡     Ÿ  ž    œ  ›  š  ™  ˜  —  –  •  ”  “  ’  ‘      Ž    Œ  ‹  Š  ‰  ˆ  ‡  †  …  „  ƒ  ‚    €    ~  }  |  {  z  y  x  w  v  u  t  s  r  q  p  o  n  m  l  k  j  i  h  g  f  e  d  c  b  a  `  _  ^  ]  \  [  Z  Y  X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  H  G  F  E  D  C  B  A  @  ?  >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ,  +  *  )  (  '  &  %  $  #  "  !
-  	          ò      é   ‘   à   ’   ×   “   Î   ”   Å   •   ¼   –   ³   —   ª   ˜   Ž   ò   ò   é   ñ   ò   é   à   è   é   à   ×   ß   à   ×   Î   Ö   ×   Î   Å   Í   Î   Å   ¼   Ä   Å   ¼   ³   »   ¼   ³   ª   ²   ³   ª   ™   ©   ª      ñ   ñ   è   ð   ñ   è   ß   ç   è   ß   Ö   Þ   ß   Ö   Í   Õ   Ö   Í   Ä   Ì   Í   Ä   »   à   Ä   »   ²   º   »   ²   ©   ±   ²   ©   š   ¨   ©   Œ   ð   ð   ç   ï   ð   ç   Þ   æ   ç   Þ   Õ   Ý   Þ   Õ   Ì   Ô   Õ   Ì   à   Ë   Ì   à   º      à   º   ±   ¹   º   ±   ¨   °   ±   ¨   ›   §   ¨   ‹   ï   ï   æ   î   ï   æ   Ý   å   æ   Ý   Ô   Ü   Ý   Ô   Ë   Ó   Ô   Ë      Ê   Ë      ¹   Á      ¹   °   ¸   ¹   °   §   ¯   °   §   œ   ¦   §   Š   î   î   å   í   î   å   Ü   ä   å   Ü   Ó   Û   Ü   Ó   Ê   Ò   Ó   Ê   Á   É   Ê   Á   ¸   À   Á   ¸   ¯   ·   ¸   ¯   ¦   ®   ¯   ¦      ¥   ¦   ‰   í   í   ä   ì   í   ä   Û   ã   ä   Û   Ò   Ú   Û   Ò   É   Ñ   Ò   É   À   È   É   À   ·   ¿   À   ·   ®   ¶   ·   ®   ¥   ­   ®   ¥   ž   ¤   ¥   ˆ   ì   ì   ã   ë   ì   ã   Ú   â   ã   Ú   Ñ   Ù   Ú   Ñ   È   Ð   Ñ   È   ¿   Ç   È   ¿   ¶   ¾   ¿   ¶   ­   µ   ¶   ­   ¤   ¬   ­   ¤   Ÿ   £   ¤   ‡   ë   ë   â   ê   ë   â   Ù   á   â   Ù   Ð   Ø   Ù   Ð   Ç   Ï   Ð   Ç   ¾   Æ   Ç   ¾   µ   ½   ¾   µ   ¬   ´   µ   ¬   £   «   ¬   £       ¢   £   †   ê   ê   á   „   ê   á   Ø   ƒ   á   Ø   Ï   ‚   Ø   Ï   Æ      Ï   Æ   ½   €   Æ   ½   ´      ½   ´   «   ~   ´   «   ¢   }   «   ¢   ¡   |   ¢
-                                         !  "  #  $  %  &  '  (  )  *  +  ,  -  .  /  0  1  2  3  4  5  6  7  8  9  :  ;  <  =  >  ?  @  A  B  C  D  E  F  G  H  I  J  K  L  M  N  O  P  Q  R  S  T  U        À     Àþÿÿÿÿÿÿ¿     ð¿      ”¼     ð?ÿÿÿÿÿÿÿ?þÿÿÿÿÿ@üÿÿÿÿÿ@     À      Àýÿÿÿÿÿÿ¿      ð¿      ¤¼ÿÿÿÿÿÿï?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÀ      À       À      ð¿      ¤<      ð?ÿÿÿÿÿÿÿ?     @ÿÿÿÿÿÿ@      À      À       À      ð¿      ¼     ð?þÿÿÿÿÿÿ?     @     @      À      À       À      ð¿              ð?       @      @      @     À     Àÿÿÿÿÿÿÿ¿      ð¿      <     ð?      @ÿÿÿÿÿÿ@þÿÿÿÿÿ@     ÀÿÿÿÿÿÿÀ       Àýÿÿÿÿÿï¿       <þÿÿÿÿÿï?þÿÿÿÿÿÿ?      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿÀ     Àÿÿÿÿÿÿÿ¿     ð¿       ¼     ð?      @     @      @ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ       À     ð¿      ¼     ð?þÿÿÿÿÿÿ?üÿÿÿÿÿ@      @      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@      @      @     @      @     @ÿÿÿÿÿÿ@þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @     ð?     ð?     ð?     ð?      ð?     ð?      ð?     ð?     ð?      ”<      ¤<      ¤¼      <              ¼       ¼       <      <     ð¿      ð¿     ð¿     ð¿      ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿      ð¿       Àýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À      Àþÿÿÿÿÿÿ¿       À      ÀýÿÿÿÿÿÀ     ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀüÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀ      À      À      d   ,  +  *  )  (  '  &  %  $  #  "  !
-  	                     ÿ   þ   ý   ü   û   ú   ù   ø   ÷   ö   õ   ô   ó   ò   ñ   ð   ï   î   í   ì   ë   ê   é   è   ç   æ   å   ä   ã   â   á   à   ß   Þ   Ý   Ü   Û   Ú   Ù   Ø   ×   Ö   Õ   Ô   Ó   Ò   Ñ   Ð   Ï   Î   Í   Ì   Ë   Ê   É   U  †   {     L  U      C  L      :  C      1  :       (  1     ÿ     (  ÿ   þ       þ   ý
-    ý   ü   (
-  ü      T  ‡   †   U  K  T  U  L  B  K  L  C  9  B  C  :  0  9  :  1  '  0  1  (    '  (            
-  (   S  ˆ   ‡   T  J  S  T  K  A  J  K  B  8  A  B  9  /  8  9  0  &  /  0  '    &  '                    &       '   R  ‰   ˆ   S  I  R  S  J  @  I  J  A  7  @  A  8  .  7  8  /  %  .  /  &    %  &
-    &   Q  Š   ‰   R  H  Q  R  I  ?  H  I  @  6  ?  @  7  -  6  7  .  $  -  .  %    $  %
-  %   P  ‹   Š   Q  G  P  Q  H  >  G  H  ?  5  >  ?  6  ,  5  6  -  #  ,  -  $    #  $                  	  #     	  $   O  Œ   ‹   P  F  O  P  G  =  F  G  >  4  =  >  5  +  4  5  ,  "  +  ,  #    "  #                    "       #   N     Œ   O  E  N  O  F  <  E  F  =  3  <  =  4  *  3  4  +  !  *  +  "    !  "                    !       "   M  Ž      N  D  M  N  E  ;  D  E  <  2  ;  <  3  )  2  3  *     )  *  !       !                            !   û   …   Ž   M  ú   û   M  D  ù   ú   D  ;  ø   ù   ;  2  ÷   ø   2  )  ö   ÷   )     õ   ö        ô   õ       ó   ô          ó               ´   €    ~  }  |  {  z  y  x  w  v  u  t  s  r  q  p  o  n  m  l  k  j  i  h  g  f  e  d  c  b  a  `  _  ^  ]  \  [  Z  Y  X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  H  G  F  E  D  C  B  A  @  ?  >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ,  +  *  )  (  '  &  %  $  #  "  !
-  	                     ÿ  þ  ý  ü  û  ú  ù  ø  ÷  ö  õ  ô  ó  ò  ñ  ð  ï  î  í  ì  ë  ê  é  è  ç  æ  å  ä  ã  â  á  à  ß  Þ  Ý  Ü  Û  Ú  Ù  Ø  ×  Ö  Õ  Ô  Ó  Ò  Ñ  Ð  Ï  Î  Í  U    L    C    :    1     (  ÿ     þ     ý
-  ü   †   U  U  L  T  U  L  C  K  L  C  :  B  C  :  1  9  :  1  (  0  1  (    '  (
-  ‡   T  T  K  S  T  K  B  J  K  B  9  A  B  9  0  8  9  0  '  /  0  '    &  '                    '       ˆ   S  S  J  R  S  J  A  I  J  A  8  @  A  8  /  7  8  /  &  .  /  &    %  &                    &
-    ‰   R  R  I  Q  R  I  @  H  I  @  7  ?  @  7  .  6  7  .  %  -  .  %    $  %
-  Š   Q  Q  H  P  Q  H  ?  G  H  ?  6  >  ?  6  -  5  6  -  $  ,  -  $    #  $            	      	  $     	  ‹   P  P  G  O  P  G  >  F  G  >  5  =  >  5  ,  4  5  ,  #  +  ,  #    "  #                    #       Œ   O  O  F  N  O  F  =  E  F  =  4  <  =  4  +  3  4  +  "  *  +  "    !  "                    "          N  N  E  M  N  E  <  D  E  <  3  ;  <  3  *  2  3  *  !  )  *  !       !                    !       Ž   M  M  D  û   M  D  ;  ú   D  ;  2  ù   ;  2  )  ø   2  )     ÷   )       ö          õ         ô           ó     _  `  a  b  c  d  e  f  g  h  i  j  k  l  m  n  o  p  q  r  s  t  u  v  w  x  y  z  {  |  }  ~    €    ‚  ƒ  „  …  †  ‡  ˆ  ‰  Š  ‹  Œ    Ž      ‘  ’  “  ”  •  –  —  ˜  ™  š  ›  œ    ž  Ÿ     ¡  ¢  £  ¤  ¥  ¦  §  ¨  ©  ª  «  ¬  ­  ®  ¯        À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      @     @þÿÿÿÿÿÿ?     ð?      ”<     ð¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÀüÿÿÿÿÿÀ     @      @ýÿÿÿÿÿÿ?      ð?      ¤<ÿÿÿÿÿÿï¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @       @      ð?      ¤¼      ð¿ÿÿÿÿÿÿÿ¿     ÀÿÿÿÿÿÿÀ      @      @       @      ð?      <     ð¿þÿÿÿÿÿÿ¿     À     À      @      @       @      ð?              ð¿       À      À      À     @     @ÿÿÿÿÿÿÿ?      ð?      ¼     ð¿      ÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ     @ÿÿÿÿÿÿ@       @ýÿÿÿÿÿï?       ¼þÿÿÿÿÿï¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?       <     ð¿      À     À      Àÿÿÿÿÿÿ@ÿÿÿÿÿÿ@       @     ð?      <     ð¿þÿÿÿÿÿÿ¿üÿÿÿÿÿÀ      À      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@      @      @     @      @     @ÿÿÿÿÿÿ@þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @     ð?     ð?     ð?     ð?      ð?     ð?      ð?     ð?     ð?      ”<      ¤<      ¤¼      <              ¼       ¼       <      <     ð¿      ð¿     ð¿     ð¿      ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿      ð¿       Àýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À      Àþÿÿÿÿÿÿ¿       À      ÀýÿÿÿÿÿÀ     ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀüÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀ      À      À      d       Ž    Œ  ‹  Š  ‰  ˆ  ‡  †  …  „  ƒ  ‚    €    ~  }  |  {  z  y  x  w  v  u  t  s  r  q  p  o  n  m  l  k  j  i  h  g  f  e  d  c  b  a  `  _  ^  ]  \  [  Z  Y  X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  H  G  F  E  D  C  B  A  @  ?  >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ¯     …   û   ¦  ¯  û   ú     ¦  ú   ù   ”    ù   ø   ‹  ”  ø   ÷   ‚  ‹  ÷   ö   y  ‚  ö   õ   p  y  õ   ô   g  p  ô   ó      g  ó      ®  ‘      ¯  ¥  ®  ¯  ¦  œ  ¥  ¦    “  œ    ”  Š  “  ”  ‹    Š  ‹  ‚  x    ‚  y  o  x  y  p  f  o  p  g     f  g     ­  ’   ‘   ®  ¤  ­  ®  ¥  ›  ¤  ¥  œ  ’  ›  œ  “  ‰  ’  “  Š  €  ‰  Š    w  €    x  n  w  x  o  e  n  o  f     e  f     ¬  “   ’   ­  £  ¬  ­  ¤  š  £  ¤  ›  ‘  š  ›  ’  ˆ  ‘  ’  ‰    ˆ  ‰  €  v    €  w  m  v  w  n  d  m  n  e     d  e     «  ”   “   ¬  ¢  «  ¬  £  ™  ¢  £  š    ™  š  ‘  ‡    ‘  ˆ  ~  ‡  ˆ    u  ~    v  l  u  v  m  c  l  m  d     c  d     ª  •   ”   «  ¡  ª  «  ¢  ˜  ¡  ¢  ™    ˜  ™    †      ‡  }  †  ‡  ~  t  }  ~  u  k  t  u  l  b  k  l  c     b  c     ©  –   •   ª     ©  ª  ¡  —     ¡  ˜  Ž  —  ˜    …  Ž    †  |  …  †  }  s  |  }  t  j  s  t  k  a  j  k  b     a  b     ¨  —   –   ©  Ÿ  ¨  ©     –  Ÿ     —    –  —  Ž  „    Ž  …  {  „  …  |  r  {  |  s  i  r  s  j  `  i  j  a     `  a     §  ˜   —   ¨  ž  §  ¨  Ÿ  •  ž  Ÿ  –  Œ  •  –    ƒ  Œ    „  z  ƒ  „  {  q  z  {  r  h  q  r  i  _  h  i  `     _  `     ^     ˜   §  ]  ^  §  ž  \  ]  ž  •  [  \  •  Œ  Z  [  Œ  ƒ  Y  Z  ƒ  z  X  Y  z  q  W  X  q  h  V  W  h  _     V  _           ´   >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ,  +  *  )  (  '  &  %  $  #  "  !
-  	                     ÿ  þ  ý  ü  û  ú  ù  ø  ÷  ö  õ  ô  ó  ò  ñ  ð  ï  î  í  ì  ë  ê  é  è  ç  æ  å  ä  ã  â  á  à  ß  Þ  Ý  Ü  Û  Ú  Ù  Ø  ×  Ö  Õ  Ô  Ó  Ò  Ñ  Ð  Ï  Î  Í  Ì  Ë  Ê  É  È  Ç  Æ  Å  Ä  à    Á  À  ¿  ¾  ½  ¼  »  º  ¹  ¸  ·  ¶  µ  ´  ³  ²  ±  °  ¯  ®  ­  ¬  «  ª  ©  ¨  §  ¦  ¥  ¤  £  ¢  ¡     Ÿ  ž    œ  ›  š  ™  ˜  —  –  •  ”  “  ’  ‘      Ž    Œ  ‹  ¯  û   ¦  ú     ù   ”  ø   ‹  ÷   ‚  ö   y  õ   p  ô   g  ó      ¯  ¯  ¦  ®  ¯  ¦    ¥  ¦    ”  œ    ”  ‹  “  ”  ‹  ‚  Š  ‹  ‚  y    ‚  y  p  x  y  p  g  o  p  g     f  g  ‘   ®  ®  ¥  ­  ®  ¥  œ  ¤  ¥  œ  “  ›  œ  “  Š  ’  “  Š    ‰  Š    x  €    x  o  w  x  o  f  n  o  f     e  f  ’   ­  ­  ¤  ¬  ­  ¤  ›  £  ¤  ›  ’  š  ›  ’  ‰  ‘  ’  ‰  €  ˆ  ‰  €  w    €  w  n  v  w  n  e  m  n  e     d  e  “   ¬  ¬  £  «  ¬  £  š  ¢  £  š  ‘  ™  š  ‘  ˆ    ‘  ˆ    ‡  ˆ    v  ~    v  m  u  v  m  d  l  m  d     c  d  ”   «  «  ¢  ª  «  ¢  ™  ¡  ¢  ™    ˜  ™    ‡      ‡  ~  †  ‡  ~  u  }  ~  u  l  t  u  l  c  k  l  c     b  c  •   ª  ª  ¡  ©  ª  ¡  ˜     ¡  ˜    —  ˜    †  Ž    †  }  …  †  }  t  |  }  t  k  s  t  k  b  j  k  b     a  b  –   ©  ©     ¨  ©     —  Ÿ     —  Ž  –  —  Ž  …    Ž  …  |  „  …  |  s  {  |  s  j  r  s  j  a  i  j  a     `  a  —   ¨  ¨  Ÿ  §  ¨  Ÿ  –  ž  Ÿ  –    •  –    „  Œ    „  {  ƒ  „  {  r  z  {  r  i  q  r  i  `  h  i  `     _  `  ˜   §  §  ž  ^  §  ž  •  ]  ž  •  Œ  \  •  Œ  ƒ  [  Œ  ƒ  z  Z  ƒ  z  q  Y  z  q  h  X  q  h  _  W  h  _     V  _  ¹  º  »  ¼  ½  ¾  ¿  À  Á    à  Ä  Å  Æ  Ç  È  É  Ê  Ë  Ì  Í  Î  Ï  Ð  Ñ  Ò  Ó  Ô  Õ  Ö  ×  Ø  Ù  Ú  Û  Ü  Ý  Þ  ß  à  á  â  ã  ä  å  æ  ç  è  é  ê  ë  ì  í  î  ï  ð  ñ  ò  ó  ô  õ  ö  ÷  ø  ù  ú  û  ü  ý  þ  ÿ                     	        @     @þÿÿÿÿÿÿ?     ð?      ”<     ð¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÀüÿÿÿÿÿÀ     @      @ýÿÿÿÿÿÿ?      ð?      ¤<ÿÿÿÿÿÿï¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @       @      ð?      ¤¼      ð¿ÿÿÿÿÿÿÿ¿     ÀÿÿÿÿÿÿÀ      @      @       @      ð?      <     ð¿þÿÿÿÿÿÿ¿     À     À      @      @       @      ð?              ð¿       À      À      À     @     @ÿÿÿÿÿÿÿ?      ð?      ¼     ð¿      ÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ     @ÿÿÿÿÿÿ@       @ýÿÿÿÿÿï?       ¼þÿÿÿÿÿï¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?       <     ð¿      À     À      Àÿÿÿÿÿÿ@ÿÿÿÿÿÿ@       @     ð?      <     ð¿þÿÿÿÿÿÿ¿üÿÿÿÿÿÀ      À      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@      @      @     @      @     @ÿÿÿÿÿÿ@þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @     ð?     ð?     ð?     ð?      ð?     ð?      ð?     ð?     ð?      ”<      ¤<      ¤¼      <              ¼       ¼       <      <     ð¿      ð¿     ð¿     ð¿      ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿      ð¿       Àýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À      Àþÿÿÿÿÿÿ¿       À      ÀýÿÿÿÿÿÀ     ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀüÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀ      À      À      d   ô  ó  ò  ñ  ð  ï  î  í  ì  ë  ê  é  è  ç  æ  å  ä  ã  â  á  à  ß  Þ  Ý  Ü  Û  Ú  Ù  Ø  ×  Ö  Õ  Ô  Ó  Ò  Ñ  Ð  Ï  Î  Í  Ì  Ë  Ê  É  È  Ç  Æ  Å  Ä  à    Á  À  ¿  ¾  ½  ¼  »  º  ¹  ¸  ·  ¶  µ  ´  ³  ²  ±  °  ¯  ®  ­  ¬  «  ª  ©  ¨  §  ¦  ¥  ¤  £  ¢  ¡     Ÿ  ž    œ  ›  š  ™  ˜  —  –  •  ”  “  ’  ‘  	  ™      ^     	  ^  ]  ÷     ]  \  î  ÷  \  [  å  î  [  Z  Ü  å  Z  Y  Ó  Ü  Y  X  Ê  Ó  X  W  Á  Ê  W  V     Á  V       š   ™   	  ÿ    	     ö  ÿ     ÷  í  ö  ÷  î  ä  í  î  å  Û  ä  å  Ü  Ò  Û  Ü  Ó  É  Ò  Ó  Ê  À  É  Ê  Á     À  Á       ›   š     þ      ÿ  õ  þ  ÿ  ö  ì  õ  ö  í  ã  ì  í  ä  Ú  ã  ä  Û  Ñ  Ú  Û  Ò  È  Ñ  Ò  É  ¿  È  É  À     ¿  À       œ   ›     ý      þ  ô  ý  þ  õ  ë  ô  õ  ì  â  ë  ì  ã  Ù  â  ã  Ú  Ð  Ù  Ú  Ñ  Ç  Ð  Ñ  È  ¾  Ç  È  ¿     ¾  ¿          œ     ü      ý  ó  ü  ý  ô  ê  ó  ô  ë  á  ê  ë  â  Ø  á  â  Ù  Ï  Ø  Ù  Ð  Æ  Ï  Ð  Ç  ½  Æ  Ç  ¾     ½  ¾       ž        û      ü  ò  û  ü  ó  é  ò  ó  ê  à  é  ê  á  ×  à  á  Ø  Î  ×  Ø  Ï  Å  Î  Ï  Æ  ¼  Å  Æ  ½     ¼  ½       Ÿ   ž     ú      û  ñ  ú  û  ò  è  ñ  ò  é  ß  è  é  à  Ö  ß  à  ×  Í  Ö  ×  Î  Ä  Í  Î  Å  »  Ä  Å  ¼     »  ¼           Ÿ     ù      ú  ð  ù  ú  ñ  ç  ð  ñ  è  Þ  ç  è  ß  Õ  Þ  ß  Ö  Ì  Õ  Ö  Í  à  Ì  Í  Ä  º  à  Ä  »     º  »       ¡         ø      ù  ï  ø  ù  ð  æ  ï  ð  ç  Ý  æ  ç  Þ  Ô  Ý  Þ  Õ  Ë  Ô  Õ  Ì    Ë  Ì  à  ¹    à  º
-   ¹  º     ¸  z   ¡     ·  ¸    ø  ¶  ·  ø  ï  µ  ¶  ï  æ  ´  µ  æ  Ý  ³  ´  Ý  Ô  ²  ³  Ô  Ë  ±  ²  Ë  Â  °  ±  Â  ¹     °  ¹
-         ´   ü  û  ú  ù  ø  ÷  ö  õ  ô  ó  ò  ñ  ð  ï  î  í  ì  ë  ê  é  è  ç  æ  å  ä  ã  â  á  à  ß  Þ  Ý  Ü  Û  Ú  Ù  Ø  ×  Ö  Õ  Ô  Ó  Ò  Ñ  Ð  Ï  Î  Í  Ì  Ë  Ê  É  È  Ç  Æ  Å  Ä  à    Á  À  ¿  ¾  ½  ¼  »  º  ¹  ¸  ·  ¶  µ  ´  ³  ²  ±  °  ¯  ®  ­  ¬  «  ª  ©  ¨  §  ¦  ¥  ¤  £  ¢  ¡     Ÿ  ž    œ  ›  š  ™  ˜  —  –  •  ”  “  ’  ‘      Ž    Œ  ‹  Š  ‰  ˆ  ‡  †  …  „  ƒ  ‚    €    ~  }  |  {  z  y  x  w  v  u  t  s  r  q  p  o  n  m  l  k  j  i  h  g  f  e  d  c  b  a  `  _  ^  ]  \  [  Z  Y  X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  	  ^     ]  ÷  \  î  [  å  Z  Ü  Y  Ó  X  Ê  W  Á  V  ™   	  	       	     ÷  ÿ     ÷  î  ö  ÷  î  å  í  î  å  Ü  ä  å  Ü  Ó  Û  Ü  Ó  Ê  Ò  Ó  Ê  Á  É  Ê  Á     À  Á  š       ÿ      ÿ  ö  þ  ÿ  ö  í  õ  ö  í  ä  ì  í  ä  Û  ã  ä  Û  Ò  Ú  Û  Ò  É  Ñ  Ò  É  À  È  É  À     ¿  À  ›       þ      þ  õ  ý  þ  õ  ì  ô  õ  ì  ã  ë  ì  ã  Ú  â  ã  Ú  Ñ  Ù  Ú  Ñ  È  Ð  Ñ  È  ¿  Ç  È  ¿     ¾  ¿  œ       ý      ý  ô  ü  ý  ô  ë  ó  ô  ë  â  ê  ë  â  Ù  á  â  Ù  Ð  Ø  Ù  Ð  Ç  Ï  Ð  Ç  ¾  Æ  Ç  ¾     ½  ¾         ü      ü  ó  û  ü  ó  ê  ò  ó  ê  á  é  ê  á  Ø  à  á  Ø  Ï  ×  Ø  Ï  Æ  Î  Ï  Æ  ½  Å  Æ  ½     ¼  ½  ž       û      û  ò  ú  û  ò  é  ñ  ò  é  à  è  é  à  ×  ß  à  ×  Î  Ö  ×  Î  Å  Í  Î  Å  ¼  Ä  Å  ¼     »  ¼  Ÿ       ú      ú  ñ  ù  ú  ñ  è  ð  ñ  è  ß  ç  è  ß  Ö  Þ  ß  Ö  Í  Õ  Ö  Í  Ä  Ì  Í  Ä  »  à  Ä  »     º  »          ù      ù  ð  ø  ù  ð  ç  ï  ð  ç  Þ  æ  ç  Þ  Õ  Ý  Þ  Õ  Ì  Ô  Õ  Ì  à  Ë  Ì  à  º    à  º     ¹  º  ¡       ø  ¸    ø  ï  ·  ø  ï  æ  ¶  ï  æ  Ý  µ  æ  Ý  Ô  ´  Ý  Ô  Ë  ³  Ô  Ë    ²  Ë    ¹  ±    ¹
-   °  ¹
-                                         !  "  #  $  %  &  '  (  )  *  +  ,  -  .  /  0  1  2  3  4  5  6  7  8  9  :  ;  <  =  >  ?  @  A  B  C  D  E  F  G  H  I  J  K  L  M  N  O  P  Q  R  S  T  U  V  W  X  Y  Z        @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      @      À     Àþÿÿÿÿÿÿ¿     ð¿      ”¼     ð?ÿÿÿÿÿÿÿ?þÿÿÿÿÿ@üÿÿÿÿÿ@     À      Àýÿÿÿÿÿÿ¿      ð¿      ¤¼ÿÿÿÿÿÿï?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÀ      À       À      ð¿      ¤<      ð?ÿÿÿÿÿÿÿ?     @ÿÿÿÿÿÿ@      À      À       À      ð¿      ¼     ð?þÿÿÿÿÿÿ?     @     @      À      À       À      ð¿              ð?       @      @      @     À     Àÿÿÿÿÿÿÿ¿      ð¿      <     ð?      @ÿÿÿÿÿÿ@þÿÿÿÿÿ@     ÀÿÿÿÿÿÿÀ       Àýÿÿÿÿÿï¿       <þÿÿÿÿÿï?þÿÿÿÿÿÿ?      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿÀ     Àÿÿÿÿÿÿÿ¿     ð¿       ¼     ð?      @     @      @ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ       À     ð¿      ¼     ð?þÿÿÿÿÿÿ?üÿÿÿÿÿ@      @      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@      @      @     @      @     @ÿÿÿÿÿÿ@þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @     ð?     ð?     ð?     ð?      ð?     ð?      ð?     ð?     ð?      ”<      ¤<      ¤¼      <              ¼       ¼       <      <     ð¿      ð¿     ð¿     ð¿      ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿      ð¿       Àýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À      Àþÿÿÿÿÿÿ¿       À      ÀýÿÿÿÿÿÀ     ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀüÿÿÿÿÿÀþÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀ      À      À      d   X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  H  G  F  E  D  C  B  A  @  ?  >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ,  +  *  )  (  '  &  %  $  #  "  !
-  	                     ÿ  þ  ý  ü  û  ú  ù  ø  ÷  ö  õ  Z  |   z   ¸  Q  Z  ¸  ·  H  Q  ·  ¶  ?  H  ¶  µ  6  ?  µ  ´  -  6  ´  ³  $  -  ³  ²    $  ²  ±      ±  °       °     Y  }   |   Z  P  Y  Z  Q  G  P  Q  H  >  G  H  ?  5  >  ?  6  ,  5  6  -  #  ,  -  $    #  $
-          X  ~   }   Y  O  X  Y  P  F  O  P  G  =  F  G  >  4  =  >  5  +  4  5  ,  "  +  ,  #    "  #
-   W     ~   X  N  W  X  O  E  N  O  F  <  E  F  =  3  <  =  4  *  3  4  +  !  *  +  "    !  "                   	   V  €      W  M  V  W  N  D  M  N  E  ;  D  E  <  2  ;  <  3  )  2  3  *     )  *  !       !                      U     €   V  L  U  V  M  C  L  M  D  :  C  D  ;  1  :  ;  2  (  1  2  )    (  )
-       T  ‚      U  K  T  U  L  B  K  L  C  9  B  C  :  0  9  :  1  '  0  1  (    '  (            
-     S  ƒ   ‚   T  J  S  T  K  A  J  K  B  8  A  B  9  /  8  9  0  &  /  0  '    &  '                              R  „   ƒ   S  I  R  S  J  @  I  J  A  7  @  A  8  .  7  8  /  %  .  /  &    %  &
-         {   „   R      R  I      I  @      @  7       7  .  ÿ      .  %  þ   ÿ   %    ý   þ       ü   ý
-     ü
-           ´   °  ¯  ®  ­  ¬  «  ª  ©  ¨  §  ¦  ¥  ¤  £  ¢  ¡     Ÿ  ž    œ  ›  š  ™  ˜  —  –  •  ”  “  ’  ‘      Ž    Œ  ‹  Š  ‰  ˆ  ‡  †  …  „  ƒ  ‚    €    ~  }  |  {  z  y  x  w  v  u  t  s  r  q  p  o  n  m  l  k  j  i  h  g  f  e  d  c  b  a  `  _  ^  ]  \  [  Z  Y  X  W  V  U  T  S  R  Q  P  O  N  M  L  K  J  I  H  G  F  E  D  C  B  A  @  ?  >  =  <  ;  :  9  8  7  6  5  4  3  2  1  0  /  .  -  ,  +  *  )  (  '  &  %  $  #  "  !
-  	                     ÿ  þ  ý  Z  ¸  Q  ·  H  ¶  ?  µ  6  ´  -  ³  $  ²    ±    °  |   Z  Z  Q  Y  Z  Q  H  P  Q  H  ?  G  H  ?  6  >  ?  6  -  5  6  -  $  ,  -  $    #  $                   }   Y  Y  P  X  Y  P  G  O  P  G  >  F  G  >  5  =  >  5  ,  4  5  ,  #  +  ,  #    "  #
-       ~   X  X  O  W  X  O  F  N  O  F  =  E  F  =  4  <  =  4  +  3  4  +  "  *  +  "    !  "            	          W  W  N  V  W  N  E  M  N  E  <  D  E  <  3  ;  <  3  *  2  3  *  !  )  *  !       !                   €   V  V  M  U  V  M  D  L  M  D  ;  C  D  ;  2  :  ;  2  )  1  2  )     (  )
-       U  U  L  T  U  L  C  K  L  C  :  B  C  :  1  9  :  1  (  0  1  (    '  (
-  ‚   T  T  K  S  T  K  B  J  K  B  9  A  B  9  0  8  9  0  '  /  0  '    &  '                           ƒ   S  S  J  R  S  J  A  I  J  A  8  @  A  8  /  7  8  /  &  .  /  &    %  &
-    „   R  R  I    R  I  @    I  @  7    @  7  .    7  .  %     .  %    ÿ   %      þ
-  ý
-     ü
-  [  \  ]  ^  _  `  a  b  c  d  e  f  g  h  i  j  k  l  m  n  o  p  q  r  s  t  u  v  w  x  y  z  {  |  }  ~    €    ‚  ƒ  „  …  †  ‡  ˆ  ‰  Š  ‹  Œ    Ž      ‘  ’  “  ”  •  –  —  ˜  ™  š  ›  œ    ž  Ÿ     ¡  ¢  £  ¤  ¥  ¦  §  ¨  ©  ª  «  ¬  ­  ®  ¯  °  ±  ²  ³  ´  µ  ¶  ·  ¸  ¹  º  »  ¼  ½  ¾  ¿  À  Á    à  Ä  Å  Æ  Ç  È  É  Ê  Ë  Ì  Í  Î  Ï  Ð  Ñ  Ò  Ó  Ô  Õ  Ö  ×  Ø  Ù  Ú  Û  Ü  Ý  Þ  ß  à  á  â  ã  ä  å  æ  ç  è  é  ê  ë  ì  í  î  ï  ð  ñ  ò  ó  ô  õ  ö  ÷  ø  ù  ú  û  ü  ý  þ  ÿ
-                                         !  "  #  $  %  &  '  (  )  *  +  ,  -  .  /  0  1  2  3  4  5  6  7  8  9  :  ;  <  =  >  ?  @  A  B  C  D  E  F  G  H  I  J  K  L  M  N  O  P  Q  R  S  T  U  V  W  X  Y  Z  [  \  ]  ^  _  `  a  b  c  d  e  f  g  h  i  j  k  l  m  n  o  p  q  r  s  t  u  v  w  x  y  z  {  |  }  ~    €    ‚  ƒ  „  …  †  ‡  ˆ  ‰  Š  ‹  Œ    Ž      ‘  ’  “  ”  •  –  —  ˜  ™  š  ›  œ    ž  Ÿ     ¡  ¢  £  ¤  ¥  ¦  §  ¨  ©  ª  «  ¬  ­  ®  ¯  °  ±  ²  ³  ´  µ  ¶  ·  ¸  ¹  º  »  ¼  ½  ¾  ¿  À  Á    à  Ä  Å  Æ  Ç  È  É  Ê  Ë  Ì  Í  Î  Ï  Ð  Ñ  Ò  Ó  Ô  Õ  Ö  ×  Ø  Ù  Ú  Û  Ü  Ý  Þ  ß  à  á  â  ã  ä  å  æ  ç  è  é  ê  ë  ì  í  î  ï  ð  ñ  ò  ó  ô  õ  ö  ÷  ø  ù  ú  û  ü  ý  þ  ÿ
-                                         !  "  #  $  %  &  '  (  )  *  +  ,  -  .  /  0  1  2  3        À      ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      À      À      À      À      À      À     À      À      À      À     À      À      À      À      À      À      À      À      À      À      À      ÀþÿÿÿÿÿÀ      À     À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      ÀþÿÿÿÿÿÀ      ÀþÿÿÿÿÿÀ      À      ÀþÿÿÿÿÿÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      À      À      À      À      À      À      ÀþÿÿÿÿÿÀ      ÀþÿÿÿÿÿÀ      À     À      À      À      À     À      À     À      À     À      À     À     À      À     À      À      À      À     À      À      À     À      À     À      À      ÀþÿÿÿÿÿÀ      À      À     À     À      À      À      À     À      À      À      À      À      À      À     À      À     À      À      À      À     À     À      À     À     À     À      À      À      À     À     À      À      À      À      ÀþÿÿÿÿÿÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      À      ÀþÿÿÿÿÿÀ      À      À      ÀþÿÿÿÿÿÀþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       À       À       À       À       À      À      À      Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿      Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       À       À       À       À       À       Àþÿÿÿÿÿÿ¿      À       À       À      Àþÿÿÿÿÿÿ¿       À       À      À      Àÿÿÿÿÿÿÿ¿      À      À      Àÿÿÿÿÿÿÿ¿      Àÿÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àþÿÿÿÿÿÿ¿      À      À      À       À       À      À       À       Àþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       À      Àþÿÿÿÿÿÿ¿      Àþÿÿÿÿÿÿ¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿     ð¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿üÿÿÿÿÿï¿      ð¿      ð¿     ð¿      ð¿      ð¿     ð¿     ð¿     ð¿      ð¿     ð¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿     ð¿      ð¿      ð¿     ð¿      ð¿     ð¿      ð¿     ð¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿      ð¿     ð¿      ð¿      ð¿     ð¿      ð¿      ð¿      ð¿      ð¿      ð¿     ð¿      ð¿      ð¿     ð¿      ð¿     ð¿      ð¿     ð¿     ð¿     €a¼     @c¼     €Y¼     €f¼      `¼      S¼      `¼      `¼      `¼      q¼     @s¼     €i¼     `v¼      p¼     @c¼      p¼      p¼      p¼     @k<     €f<     К¼     €Y<      p<     ˜™¼      p<      p<      p<      ¼     0ƒ¼      y¼     `†¼      €¼     @s¼      €¼      €¼      €¼      P¼      `¼      `<      p¼              p<                             @{<     `v<     Є<     €i<      €<      ‰<      €<      €<      €<     €V¼     €f¼     €f<     `v¼             `v<                             €Y¼     €i¼     €i<      y¼              y<                              ]¼     Àl¼     Àl<     À|¼             À|<                             ð?     ð?     ð?     ð?     ð?     ð?      ð?     ð?     ð?     ð?      ð?      ð?     ð?      ð?     ð?      ð?     ð?     ð?     ð?þÿÿÿÿÿï?      ð?     ð?þÿÿÿÿÿï?      ð?þÿÿÿÿÿï?      ð?     ð?      ð?þÿÿÿÿÿï?      ð?      ð?ÿÿÿÿÿÿï?     ð?þÿÿÿÿÿï?ÿÿÿÿÿÿï?ÿÿÿÿÿÿï?     ð?      ð?      ð?     ð?      ð?     ð?þÿÿÿÿÿï?     ð?     ð?     ð?      ð?      ð?      ð?      ð?     ð?ÿÿÿÿÿÿï?      ð?      ð?      ð?þÿÿÿÿÿï?þÿÿÿÿÿï?      ð?þÿÿÿÿÿï?      ð?þÿÿÿÿÿï?      ð?      ð?     ð?     ð?      ð?     ð?      ð?      ð?þÿÿÿÿÿï?      ð?     ð?     ð?     ð?     ð?      ð?      ð?     ð?      ð?     ð?     ð?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @       @þÿÿÿÿÿÿ?      @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?      @þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @       @þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?       @       @       @       @þÿÿÿÿÿÿ?       @       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @       @       @       @þÿÿÿÿÿÿ?       @       @       @þÿÿÿÿÿÿ?       @       @       @       @       @       @       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?       @      @      @     @     @      @      @      @     @ýÿÿÿÿÿ@ÿÿÿÿÿÿ@     @     @     @      @      @     @     @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @     @      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@þÿÿÿÿÿ@ÿÿÿÿÿÿ@      @     @     @      @     @      @     @ÿÿÿÿÿÿ@      @      @     @     @      @      @      @     @ÿÿÿÿÿÿ@     @     @     @     @      @     @      @     @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @      @      @ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @      @     @      @      @     @      @     @ÿÿÿÿÿÿ@      @      @      @      @      @     @      @     @      @þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @      @     @      @     @      @ÿÿÿÿÿÿ@      @      @      @þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @      @      @      @      @      @      @      @ÿÿÿÿÿÿ@      @      @      @      @      @     @      @      @ÿÿÿÿÿÿ@      @      @      @      @      @      @      @     @      @      @      @      @      @      @      @      @     @      @      @      @      @      @      @ÿÿÿÿÿÿ@      @     @ÿÿÿÿÿÿ@      @      @     @     @      @      @      @     @ÿÿÿÿÿÿ@      @      @      @      @ÿÿÿÿÿÿ@      @þÿÿÿÿÿÀ      À      À     À      À      À      À      À      ÀýÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀýÿÿÿÿÿÀÿÿÿÿÿÿÀýÿÿÿÿÿÀ       Àÿÿÿÿÿÿÿ¿       À       À       À      À       À      À      À     ð¿      ð¿      ð¿     ð¿      ð¿     ð¿      ð¿     ð¿     ð¿¡™™™™™9¼ÌÌÌÌÌÌ|<ffffff޼˜™™™™™i¼        ˜™™™™™i<433333ƒ¼š™™™™™‘<š™™™™™‰<     ð?      ð?      ð?      ð?      ð?      ð?      ð?     ð?     ð?       @       @       @       @       @       @       @       @       @þÿÿÿÿÿ@þÿÿÿÿÿ@üÿÿÿÿÿ@þÿÿÿÿÿ@þÿÿÿÿÿ@     @þÿÿÿÿÿ@      @þÿÿÿÿÿ@þÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@      @      @     @      @      @ÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ     ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À      À      À      À     À      À     ÀþÿÿÿÿÿÀÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿      Àÿÿÿÿÿÿÿ¿      Àÿÿÿÿÿÿÿ¿     ð¿     ð¿     ð¿     ð¿      ð¿     ð¿     ð¿     ð¿     𿚙™™™™¼™™™™™Y¼ÌÌÌÌÌÌŒ¼˜™™™™™y¼        ˜™™™™™y<ž™™™™™i¼433333“<š™™™™™‘<     ð?     ð?     ð?     ð?      ð?     ð?     ð?     ð?     ð?       @þÿÿÿÿÿÿ?       @       @       @       @       @       @       @      @      @      @      @      @      @      @     @      @ÿÿÿÿÿÿ@     @ÿÿÿÿÿÿ@þÿÿÿÿÿ@ÿÿÿÿÿÿ@     @     @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@ÿÿÿÿÿÿÀ     ÀÿÿÿÿÿÿÀ     À     À      À      À     À     À      À      À      À      À      À      À      À      ÀþÿÿÿÿÿÀþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿       À       Àÿÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿     ð¿      ð¿      ð¿     ð¿     ð¿     ð¿ÿÿÿÿÿÿï¿     ð¿     𿚙™™™™<433333‹<433333c<ž™™™™™Y¼        ž™™™™™Y<˜™™™™™‰¼ž™™™™™i¼433333ƒ¼     ð?     ð?     ð?     ð?     ð?     ð?ÿÿÿÿÿÿï?     ð?     ð?       @þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?ýÿÿÿÿÿÿ?þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @ýÿÿÿÿÿÿ?ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@     @     @      @ÿÿÿÿÿÿ@      @     @ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@     @      @      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@þÿÿÿÿÿÀ     À      À      À      ÀÿÿÿÿÿÿÀ      À      À      À      À      À     À     À      À      À      À      ÀþÿÿÿÿÿÀ       Àþÿÿÿÿÿÿ¿       Àþÿÿÿÿÿÿ¿       À      Àþÿÿÿÿÿÿ¿       Àþÿÿÿÿÿÿ¿     ð¿      ð¿      ð¿     ð¿      ð¿      ð¿þÿÿÿÿÿï¿     ð¿     𿚙™™™™y<433333s<™™™™™™i<433333s¼        433333s<˜™™™™™y¼ ™™™™™Y¼433333s¼     ð?þÿÿÿÿÿï?      ð?     ð?      ð?     ð?ÿÿÿÿÿÿï?     ð?     ð?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?      @       @ÿÿÿÿÿÿÿ?       @ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿ@      @      @      @ÿÿÿÿÿÿ@      @      @     @      @      @      @      @      @      @      @      @      @     @      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      À      ÀÿÿÿÿÿÿÀ       Àÿÿÿÿÿÿÿ¿       À       À       À       À       À       À       À     ð¿þÿÿÿÿÿï¿      ð¿     ð¿      ð¿      ð¿þÿÿÿÿÿï¿      ð¿      ð¿      `¼      p¼      p<      €¼              €<                             ð?      ð?      ð?     ð?      ð?     ð?þÿÿÿÿÿï?     ð?     ð?       @ÿÿÿÿÿÿÿ?       @þÿÿÿÿÿÿ?       @      @       @       @þÿÿÿÿÿÿ?ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@     @     @      @ÿÿÿÿÿÿ@      @     @þÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @      @      @      @      @      @      @      À      ÀÿÿÿÿÿÿÀ      À      À      À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À     À      ÀÿÿÿÿÿÿÀþÿÿÿÿÿÀÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       À       À       À       À       À      À       À     ð¿      ð¿      ð¿     ð¿      ð¿     ð¿ÿÿÿÿÿÿï¿     ð¿     ð¿ÍÌÌÌÌÌ„¼š™™™™™‰¼433333s<ffffff†¼        ffffff†<˜™™™™™y< ™™™™™Y<533333s<     ð?      ð?      ð?     ð?      ð?     ð?ÿÿÿÿÿÿï?     ð?     ð?       @þÿÿÿÿÿÿ?       @ýÿÿÿÿÿÿ?       @      @       @      @þÿÿÿÿÿÿ?þÿÿÿÿÿ@þÿÿÿÿÿ@      @      @      @ÿÿÿÿÿÿ@      @      @þÿÿÿÿÿ@þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      ÀÿÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      À     ÀÿÿÿÿÿÿÀ      ÀþÿÿÿÿÿÀþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿     ð¿      ð¿      ð¿     ð¿      ð¿      ð¿þÿÿÿÿÿï¿     ð¿     ð¿      „<      09      ”<ÌÌÌÌÌÌ|¼        ÌÌÌÌÌÌ|<˜™™™™™Y¼ffffff’¼333333“¼     ð?ÿÿÿÿÿÿï?      ð?     ð?      ð?     ð?ÿÿÿÿÿÿï?     ð?     ð?       @       @       @ÿÿÿÿÿÿÿ?       @ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?      @ÿÿÿÿÿÿÿ?þÿÿÿÿÿ@þÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@      @      @þÿÿÿÿÿ@þÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@ÿÿÿÿÿÿÀ     ÀÿÿÿÿÿÿÀ      À      À      À      À      À      À     À     À     À     À      À     À      À     ÀÿÿÿÿÿÿÀþÿÿÿÿÿÿ¿þÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿       Àÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ¿ýÿÿÿÿÿÿ¿     ð¿      ð¿     ð¿     ð¿     ð¿      ð¿þÿÿÿÿÿï¿     ð¿     ð¿      ˜¼      œ¼      €<ÍÌÌÌÌ̐¼        ÍÌÌÌÌ̐<š™™™™™‘<433333c<gfffff†<     ð?ÿÿÿÿÿÿï?      ð?     ð?     ð?     ð?ÿÿÿÿÿÿï?     ð?     ð?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?þÿÿÿÿÿÿ?ýÿÿÿÿÿÿ?þÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?      @ýÿÿÿÿÿÿ?ÿÿÿÿÿÿ@     @     @     @     @     @      @     @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @ÿÿÿÿÿÿ@     @      @      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      À     ÀþÿÿÿÿÿÀ      À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ      À      À      À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      ÀþÿÿÿÿÿÀÿÿÿÿÿÿÀþÿÿÿÿÿÀ       Àýÿÿÿÿÿÿ¿       À       À       À      À       À       À       À     ð¿     ð¿     ð¿     ð¿     ð¿     ð¿      ð¿     ð¿     ð¿      ’¼      š¼      <ffffff¼        ffffff<ÍÌÌÌÌ̐<333333{¼œ™™™™™Y<     ð?      ð?      ð?     ð?     ð?     ð?     ð?     ð?     ð?      @ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?ÿÿÿÿÿÿÿ?       @       @ÿÿÿÿÿÿÿ?      @ÿÿÿÿÿÿÿ?ýÿÿÿÿÿ@ÿÿÿÿÿÿ@      @      @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@      @     @ÿÿÿÿÿÿ@ÿÿÿÿÿÿ@þÿÿÿÿÿ@þÿÿÿÿÿ@     @      @      @      @      @      @      @     @þÿÿÿÿÿÿ?     ð?gfffff€<      ð¿       ÀüÿÿÿÿÿÀ      À      @     @þÿÿÿÿÿÿ?     ð?gfffff<     ð¿       ÀþÿÿÿÿÿÀÿÿÿÿÿÿÀ      @      @þÿÿÿÿÿÿ?      ð?gfffff¼     ð¿ÿÿÿÿÿÿÿ¿ýÿÿÿÿÿÀ      À     @     @       @     ð?š™™™™™y¼      ð¿       ÀþÿÿÿÿÿÀ      À      @ÿÿÿÿÿÿ@       @      ð?              ð¿       ÀüÿÿÿÿÿÀ      À      @      @       @     ð?š™™™™™y<     ð¿       ÀüÿÿÿÿÿÀ      À      @ÿÿÿÿÿÿ@       @     ð?š™™™™™“¼     ð¿       ÀüÿÿÿÿÿÀ      À      @     @       @     ð?š™™™™™“<      ð¿       ÀþÿÿÿÿÿÀ      À      @     @       @     ð?š™™™™™ƒ<     ð¿       ÀüÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ€<      ð¿       ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌ̐<     ð¿       À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ýÿÿÿÿÿÿ?      ð?ÍÌÌÌÌ̐¼     ð¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀ     @     @ÿÿÿÿÿÿÿ?     ð?433333s¼      ð¿       À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÿ?      ð?              ð¿       À      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?433333s<     ð¿       ÀþÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÿ?     ð?333333“¼     ð¿þÿÿÿÿÿÿ¿þÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?333333“<      ð¿þÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?333333ƒ<     ð¿       ÀþÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @       @     ð?333333<     ð¿       ÀüÿÿÿÿÿÀ      À      @      @       @     ð?333333‘<     ð¿ýÿÿÿÿÿÿ¿      À      À     @      @ÿÿÿÿÿÿÿ?     ð?333333‘¼     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ     @      @ÿÿÿÿÿÿÿ?     ð?™™™™™™i¼      ð¿       ÀÿÿÿÿÿÿÀ      À     @      @       @     ð?             ð¿þÿÿÿÿÿÿ¿      À      À     @      @       @     ð?™™™™™™i<     ð¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ     @      @       @     ð?ÍÌÌÌÌÌ’¼     ð¿ýÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀ     @      @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ’<     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      À     @      @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ‚<     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @     @       @     ð?š™™™™™<     ð¿      ÀþÿÿÿÿÿÀ      À      @     @       @      ð?š™™™™™‘<      ð¿ÿÿÿÿÿÿÿ¿      À      À      @      @       @     ð?š™™™™™‘¼     ð¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀþÿÿÿÿÿÀ      @      @þÿÿÿÿÿÿ?     ð?˜™™™™™Y¼     ð¿      ÀÿÿÿÿÿÿÀ      À      @      @       @      ð?              ð¿       ÀÿÿÿÿÿÿÀ      À     @     @       @     ð?˜™™™™™Y<      ð¿      ÀÿÿÿÿÿÿÀ      À     @     @       @      ð?ffffff’¼     ð¿      ÀÿÿÿÿÿÿÀ      À     @     @þÿÿÿÿÿÿ?     ð?ffffff’<     ð¿       ÀÿÿÿÿÿÿÀ      À     @     @üÿÿÿÿÿÿ?     ð?ffffff‚<ÿÿÿÿÿÿï¿      ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      @      @       @     ð?      ‚<      ð¿       ÀýÿÿÿÿÿÀ      À      @     @       @      ð?      ’<      ð¿       À     À      À      @      @       @     ð?      ’¼     ð¿ÿÿÿÿÿÿÿ¿      À      À      @      @       @      ð?              ð¿       ÀÿÿÿÿÿÿÀ      À      @      @       @      ð?              ð¿       À      À      À      @      @       @      ð?              ð¿      ÀÿÿÿÿÿÿÀ      À      @      @       @      ð?      ’¼      ð¿þÿÿÿÿÿÿ¿      À      À      @      @       @     ð?      ’<     ð¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      À      @      @       @     ð?      ‚<      ð¿      ÀþÿÿÿÿÿÀ      À     @     @ýÿÿÿÿÿÿ?     ð?ffffff‚<ÿÿÿÿÿÿï¿       ÀýÿÿÿÿÿÀÿÿÿÿÿÿÀ     @     @ýÿÿÿÿÿÿ?     ð?ffffff’<     ð¿       À      À      À      @      @þÿÿÿÿÿÿ?     ð?ffffff’¼ÿÿÿÿÿÿï¿       ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @     @       @      ð?˜™™™™™Y<      ð¿       ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @      @       @      ð?              ð¿       À      À      À      @      @ÿÿÿÿÿÿÿ?      ð?˜™™™™™Y¼      ð¿      ÀþÿÿÿÿÿÀ      À      @      @ÿÿÿÿÿÿÿ?      ð?š™™™™™‘¼      ð¿       ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @      @       @     ð?š™™™™™‘<     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @       @     ð?š™™™™™<      ð¿      ÀýÿÿÿÿÿÀ      Àÿÿÿÿÿÿ@      @þÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ‚<      ð¿       ÀýÿÿÿÿÿÀþÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ’<      ð¿ÿÿÿÿÿÿÿ¿      ÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ýÿÿÿÿÿÿ?      ð?ÍÌÌÌÌÌ’¼     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @      @ÿÿÿÿÿÿÿ?     ð?˜™™™™™i<      ð¿       ÀÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÿ?      ð?              ð¿       À      ÀÿÿÿÿÿÿÀ      @     @þÿÿÿÿÿÿ?     ð?˜™™™™™i¼     ð¿       ÀþÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÿ?     ð?333333‘¼     ð¿ýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @ÿÿÿÿÿÿÿ?     ð?333333‘<      ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@      @ÿÿÿÿÿÿÿ?     ð?333333<     ð¿       ÀýÿÿÿÿÿÀÿÿÿÿÿÿÀÿÿÿÿÿÿ@     @       @     ð?333333ƒ<     ð¿       ÀþÿÿÿÿÿÀ      À      @     @       @     ð?333333“<     ð¿ÿÿÿÿÿÿÿ¿      À      À      @     @ÿÿÿÿÿÿÿ?     ð?333333“¼     ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @     @ÿÿÿÿÿÿÿ?     ð?433333s<      ð¿       ÀþÿÿÿÿÿÀ      À      @     @       @     ð?             ð¿þÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀ      À     @     @       @     ð?433333s¼     ð¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @     @       @     ð?ÍÌÌÌÌ̐¼     ð¿ýÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @     @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌ̐<     ð¿þÿÿÿÿÿÿ¿      À      À      @      @ÿÿÿÿÿÿÿ?     ð?ÍÌÌÌÌÌ€<     ð¿ÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÀÿÿÿÿÿÿÀ      @      @       @     ð?š™™™™™ƒ<     ð¿      ÀüÿÿÿÿÿÀ      À      @     @       @     ð?š™™™™™“<      ð¿       ÀþÿÿÿÿÿÀ      À      @      @       @     ð?š™™™™™“¼     ð¿ÿÿÿÿÿÿÿ¿ýÿÿÿÿÿÀ      À      @      @       @     ð?š™™™™™y<     ð¿       ÀýÿÿÿÿÿÀ      À      @      @       @      ð?              ð¿       ÀýÿÿÿÿÿÀ      À     @      @       @     ð?š™™™™™y¼      ð¿       ÀýÿÿÿÿÿÀ      À      @      @       @      ð?ffffff¼     ð¿ÿÿÿÿÿÿÿ¿þÿÿÿÿÿÀ      À      @     @þÿÿÿÿÿÿ?     ð?ffffff<     ð¿       ÀþÿÿÿÿÿÀþÿÿÿÿÿÀ      @      @þÿÿÿÿÿÿ?     ð?ffffff€<      ð¿       ÀýÿÿÿÿÿÀþÿÿÿÿÿÀ      è
-                                         !  "  #  $  %  &  '  (  )  *  +  ,  -  .  /  0  1  2  3  4  5  6  7  8  9  :  ;  <  =  >  ?  @  A  B  C  D  E  F  G  H  I  J  K  L  M  N  O  P  Q  R  S  T  U  V  W  X  Y  Z  [  \  ]  ^  _  `  a  b  c  d  e  f  g  h  i  j  k  l  m  n  o  p  q  r  s  t  u  v  w  x  y  z  {  |  }  ~    €    ‚  ƒ  „  …  †  ‡  ˆ  ‰  Š  ‹  Œ    Ž      ‘  ’  “  ”  •  –  —  ˜  ™  š  ›  œ    ž  Ÿ     ¡  ¢  £  ¤  ¥  ¦  §  ¨  ©  ª  «  ¬  ­  ®  ¯  °  ±  ²  ³  ´  µ  ¶  ·  ¸  ¹  º  »  ¼  ½  ¾  ¿  À  Á    à  Ä  Å  Æ  Ç  È  É  Ê  Ë  Ì  Í  Î  Ï  Ð  Ñ  Ò  Ó  Ô  Õ  Ö  ×  Ø  Ù  Ú  Û  Ü  Ý  Þ  ß  à  á  â  ã  ä  å  æ  ç  è     ó   g           [  1   ó   ô   p  g      \  [  ô   õ   y  p      ]  \  õ   ö   ‚  y       ^  ]  ö   ÷   ‹  ‚     )  _  ^  ÷   ø   ”  ‹  )  2  `  _  ø   ù     ”  2  ;  a  `  ù   ú   ¦    ;  D  b  a  ú   û   ¯  ¦  D  M  c  b  û   …      ¯  M  Ž   ò   c     g  f     1   [  d  :   g  p  o  f  [  \  e  d  p  y  x  o  \  ]  f  e  y  ‚    x  ]  ^  g  f  ‚  ‹  Š    ^  _  h  g  ‹  ”  “  Š  _  `  i  h  ”    œ  “  `  a  j  i    ¦  ¥  œ  a  b  k  j  ¦  ¯  ®  ¥  b  c  l  k  ¯     ‘   ®  c  ò   é   l     f  e     :   d  m  C   f  o  n  e  d  e  n  m  o  x  w  n  e  f  o  n  x    €  w  f  g  p  o    Š  ‰  €  g  h  q  p  Š  “  ’  ‰  h  i  r  q  “  œ  ›  ’  i  j  s  r  œ  ¥  ¤  ›  j  k  t  s  ¥  ®  ­  ¤  k  l  u  t  ®  ‘   ’   ­  l  é   à   u     e  d     C   m  v  L   e  n  m  d  m  n  w  v  n  w  v  m  n  o  x  w  w  €    v  o  p  y  x  €  ‰  ˆ    p  q  z  y  ‰  ’  ‘  ˆ  q  r  {  z  ’  ›  š  ‘  r  s  |  {  ›  ¤  £  š  s  t  }  |  ¤  ­  ¬  £  t  u  ~  }  ­  ’   “   ¬  u  à   ×   ~     d  c     L   v    U   d  m  l  c  v  w  €    m  v  u  l  w  x    €  v    ~  u  x  y  ‚      ˆ  ‡  ~  y  z  ƒ  ‚  ˆ  ‘    ‡  z  {  „  ƒ  ‘  š  ™    {  |  …  „  š  £  ¢  ™  |  }  †  …  £  ¬  «  ¢  }  ~  ‡  †  ¬  “   ”   «  ~  ×   Î   ‡     c  b     U     ˆ  ^   c  l  k  b    €  ‰  ˆ  l  u  t  k  €    Š  ‰  u  ~  }  t    ‚  ‹  Š  ~  ‡  †  }  ‚  ƒ  Œ  ‹  ‡      †  ƒ  „    Œ    ™  ˜    „  …  Ž    ™  ¢  ¡  ˜  …  †    Ž  ¢  «  ª  ¡  †  ‡      «  ”   •   ª  ‡  Î   Å        b  a     ^   ˆ  ‘  g   b  k  j  a  ˆ  ‰  ’  ‘  k  t  s  j  ‰  Š  “  ’  t  }  |  s  Š  ‹  ”  “  }  †  …  |  ‹  Œ  •  ”  †    Ž  …  Œ    –  •    ˜  —  Ž    Ž  —  –  ˜  ¡     —  Ž    ˜  —  ¡  ª  ©         ™  ˜  ª  •   –   ©    Å   ¼   ™     a  `     g   ‘  š  p   a  j  i  `  ‘  ’  ›  š  j  s  r  i  ’  “  œ  ›  s  |  {  r  “  ”    œ  |  …  „  {  ”  •  ž    …  Ž    „  •  –  Ÿ  ž  Ž  —  –    –  —     Ÿ  —     Ÿ  –  —  ˜  ¡        ©  ¨  Ÿ  ˜  ™  ¢  ¡  ©  –   —   ¨  ™  ¼   ³   ¢     `  _     p   š  £  y   `  i  h  _  š  ›  ¤  £  i  r  q  h  ›  œ  ¥  ¤  r  {  z  q  œ    ¦  ¥  {  „  ƒ  z    ž  §  ¦  „    Œ  ƒ  ž  Ÿ  ¨  §    –  •  Œ  Ÿ     ©  ¨  –  Ÿ  ž  •     ¡  ª  ©  Ÿ  ¨  §  ž  ¡  ¢  «  ª  ¨  —   ˜   §  ¢  ³   ª   «     _  V     y   £  Á     _  h  W  V  £  ¤  Ê  Á  h  q  X  W  ¤  ¥  Ó  Ê  q  z  Y  X  ¥  ¦  Ü  Ó  z  ƒ  Z  Y  ¦  §  å  Ü  ƒ  Œ  [  Z  §  ¨  î  å  Œ  •  \  [  ¨  ©  ÷  î  •  ž  ]  \  ©  ª     ÷  ž  §  ^  ]  ª  «  	     §  ˜      ^  «  ª   ™   	        [  1   !     ¬  0       \  [      ­  ¬      ]  \      ®  ­       ^  ]    !  ¯  ®     )  _  ^  !  *  °  ¯  )  2  `  _  *  3  ±  °  2  ;  a  `  3  <  ²  ±  ;  D  b  a  <  E  ³  ²  D  M  c  b  E  N  ´  ³  M  Ž   ò   c  N     ñ   ´  1   [  d  :   0   ¬  µ  9   [  \  e  d  ¬  ­  ¶  µ  \  ]  f  e  ­  ®  ·  ¶  ]  ^  g  f  ®  ¯  ¸  ·  ^  _  h  g  ¯  °  ¹  ¸  _  `  i  h  °  ±  º  ¹  `  a  j  i  ±  ²  »  º  a  b  k  j  ²  ³  ¼  »  b  c  l  k  ³  ´  ½  ¼  c  ò   é   l  ´  ñ   è   ½  :   d  m  C   9   µ  ¾  B   d  e  n  m  µ  ¶  ¿  ¾  e  f  o  n  ¶  ·  À  ¿  f  g  p  o  ·  ¸  Á  À  g  h  q  p  ¸  ¹    Á  h  i  r  q  ¹  º  à    i  j  s  r  º  »  Ä  à  j  k  t  s  »  ¼  Å  Ä  k  l  u  t  ¼  ½  Æ  Å  l  é   à   u  ½  è   ß   Æ  C   m  v  L   B   ¾  Ç  K   m  n  w  v  ¾  ¿  È  Ç  n  o  x  w  ¿  À  É  È  o  p  y  x  À  Á  Ê  É  p  q  z  y  Á    Ë  Ê  q  r  {  z    à  Ì  Ë  r  s  |  {  à  Ä  Í  Ì  s  t  }  |  Ä  Å  Î  Í  t  u  ~  }  Å  Æ  Ï  Î  u  à   ×   ~  Æ  ß   Ö   Ï  L   v    U   K   Ç  Ð  T   v  w  €    Ç  È  Ñ  Ð  w  x    €  È  É  Ò  Ñ  x  y  ‚    É  Ê  Ó  Ò  y  z  ƒ  ‚  Ê  Ë  Ô  Ó  z  {  „  ƒ  Ë  Ì  Õ  Ô  {  |  …  „  Ì  Í  Ö  Õ  |  }  †  …  Í  Î  ×  Ö  }  ~  ‡  †  Î  Ï  Ø  ×  ~  ×   Î   ‡  Ï  Ö   Í   Ø  U     ˆ  ^   T   Ð  Ù  ]     €  ‰  ˆ  Ð  Ñ  Ú  Ù  €    Š  ‰  Ñ  Ò  Û  Ú    ‚  ‹  Š  Ò  Ó  Ü  Û  ‚  ƒ  Œ  ‹  Ó  Ô  Ý  Ü  ƒ  „    Œ  Ô  Õ  Þ  Ý  „  …  Ž    Õ  Ö  ß  Þ  …  †    Ž  Ö  ×  à  ß  †  ‡      ×  Ø  á  à  ‡  Î   Å     Ø  Í   Ä   á  ^   ˆ  ‘  g   ]   Ù  â  f   ˆ  ‰  ’  ‘  Ù  Ú  ã  â  ‰  Š  “  ’  Ú  Û  ä  ã  Š  ‹  ”  “  Û  Ü  å  ä  ‹  Œ  •  ”  Ü  Ý  æ  å  Œ    –  •  Ý  Þ  ç  æ    Ž  —  –  Þ  ß  è  ç  Ž    ˜  —  ß  à  é  è      ™  ˜  à  á  ê  é    Å   ¼   ™  á  Ä   »   ê  g   ‘  š  p   f   â  ë  o   ‘  ’  ›  š  â  ã  ì  ë  ’  “  œ  ›  ã  ä  í  ì  “  ”    œ  ä  å  î  í  ”  •  ž    å  æ  ï  î  •  –  Ÿ  ž  æ  ç  ð  ï  –  —     Ÿ  ç  è  ñ  ð  —  ˜  ¡     è  é  ò  ñ  ˜  ™  ¢  ¡  é  ê  ó  ò  ™  ¼   ³   ¢  ê  »   ²   ó  p   š  £  y   o   ë  ô  x   š  ›  ¤  £  ë  ì  õ  ô  ›  œ  ¥  ¤  ì  í  ö  õ  œ    ¦  ¥  í  î  ÷  ö    ž  §  ¦  î  ï  ø  ÷  ž  Ÿ  ¨  §  ï  ð  ù  ø  Ÿ     ©  ¨  ð  ñ  ú  ù     ¡  ª  ©  ñ  ò  û  ú  ¡  ¢  «  ª  ò  ó  ü  û  ¢  ³   ª   «  ó  ²   ©   ü  y   £  Á     x   ô  À     £  ¤  Ê  Á  ô  õ  É  À  ¤  ¥  Ó  Ê  õ  ö  Ò  É  ¥  ¦  Ü  Ó  ö  ÷  Û  Ò  ¦  §  å  Ü  ÷  ø  ä  Û  §  ¨  î  å  ø  ù  í  ä  ¨  ©  ÷  î  ù  ú  ö  í  ©  ª     ÷  ú  û  ÿ  ö  ª  «  	     û  ü    ÿ  «  ª   ™   	  ü  ©   š     !     ¬  0   "     ý  /       ­  ¬      þ  ý      ®  ­      ÿ  þ    !  ¯  ®    "     ÿ  !  *  °  ¯  "  +       *  3  ±  °  +  4      3  <  ²  ±  4  =      <  E  ³  ²  =  F      E  N  ´  ³  F  O      N     ñ   ´  O  Œ   ð     0   ¬  µ  9   /   ý    8   ¬  ­  ¶  µ  ý  þ      ­  ®  ·  ¶  þ  ÿ      ®  ¯  ¸  ·  ÿ     	    ¯  °  ¹  ¸
-  	  °  ±  º  ¹
-  ±  ²  »  º          ²  ³  ¼  »
-    ³  ´  ½  ¼
-  ´  ñ   è   ½    ð   ç     9   µ  ¾  B   8       A   µ  ¶  ¿  ¾          ¶  ·  À  ¿          ·  ¸  Á  À    	      ¸  ¹  Â  Á
-      ¹  º  Ã  Â
-        º  »  Ä  Ã          »  ¼  Å  Ä  
-      ¼  ½  Æ  Å
-        ½  è   ß   Æ    ç   Þ     B   ¾  Ç  K   A       J   ¾  ¿  È  Ç          ¿  À  É  È          À  Á  Ê  É          Á    Ë  Ê            à  Ì  Ë          à  Ä  Í  Ì          Ä  Å  Î  Í          Å  Æ  Ï  Î           Æ  ß   Ö   Ï    Þ   Õ      K   Ç  Ð  T   J     !  S   Ç  È  Ñ  Ð      "  !  È  É  Ò  Ñ      #  "  É  Ê  Ó  Ò      $  #  Ê  Ë  Ô  Ó      %  $  Ë  Ì  Õ  Ô      &  %  Ì  Í  Ö  Õ      '  &  Í  Î  ×  Ö      (  '  Î  Ï  Ø  ×       )  (  Ï  Ö   Í   Ø     Õ   Ì   )  T   Ð  Ù  ]   S   !  *  \   Ð  Ñ  Ú  Ù  !  "  +  *  Ñ  Ò  Û  Ú  "  #  ,  +  Ò  Ó  Ü  Û  #  $  -  ,  Ó  Ô  Ý  Ü  $  %  .  -  Ô  Õ  Þ  Ý  %  &  /  .  Õ  Ö  ß  Þ  &  '  0  /  Ö  ×  à  ß  '  (  1  0  ×  Ø  á  à  (  )  2  1  Ø  Í   Ä   á  )  Ì   à   2  ]   Ù  â  f   \   *  3  e   Ù  Ú  ã  â  *  +  4  3  Ú  Û  ä  ã  +  ,  5  4  Û  Ü  å  ä  ,  -  6  5  Ü  Ý  æ  å  -  .  7  6  Ý  Þ  ç  æ  .  /  8  7  Þ  ß  è  ç  /  0  9  8  ß  à  é  è  0  1  :  9  à  á  ê  é  1  2  ;  :  á  Ä   »   ê  2  à   º   ;  f   â  ë  o   e   3  <  n   â  ã  ì  ë  3  4  =  <  ã  ä  í  ì  4  5  >  =  ä  å  î  í  5  6  ?  >  å  æ  ï  î  6  7  @  ?  æ  ç  ð  ï  7  8  A  @  ç  è  ñ  ð  8  9  B  A  è  é  ò  ñ  9  :  C  B  é  ê  ó  ò  :  ;  D  C  ê  »   ²   ó  ;  º   ±   D  o   ë  ô  x   n   <  E  w   ë  ì  õ  ô  <  =  F  E  ì  í  ö  õ  =  >  G  F  í  î  ÷  ö  >  ?  H  G  î  ï  ø  ÷  ?  @  I  H  ï  ð  ù  ø  @  A  J  I  ð  ñ  ú  ù  A  B  K  J  ñ  ò  û  ú  B  C  L  K  ò  ó  ü  û  C  D  M  L  ó  ²   ©   ü  D  ±   ¨   M  x   ô  À     w   E  ¿     ô  õ  É  À  E  F  È  ¿  õ  ö  Ò  É  F  G  Ñ  È  ö  ÷  Û  Ò  G  H  Ú  Ñ  ÷  ø  ä  Û  H  I  ã  Ú  ø  ù  í  ä  I  J  ì  ã  ù  ú  ö  í  J  K  õ  ì  ú  û  ÿ  ö  K  L  þ  õ  û  ü    ÿ  L  M    þ  ü  ©   š     M  ¨   ›     "     ý  /   #     N  .       þ  ý      O  N      ÿ  þ      P  O    "     ÿ    #  Q  P  "  +       #  ,  R  Q  +  4      ,  5  S  R  4  =      5  >  T  S  =  F      >  G  U  T  F  O      G  P  V  U  O  Œ   ð     P  ‹   ï   V  /   ý    8   .   N  W  7   ý  þ      N  O  X  W  þ  ÿ      O  P  Y  X  ÿ     	    P  Q  Z  Y
-  	  Q  R  [  Z
-  R  S  \  [          S  T  ]  \
-    T  U  ^  ]
-  U  V  _  ^    ð   ç     V  ï   æ   _  8       A   7   W  `  @           W  X  a  `          X  Y  b  a    	      Y  Z  c  b
-      Z  [  d  c
-        [  \  e  d          \  ]  f  e  
-      ]  ^  g  f
-        ^  _  h  g    ç   Þ     _  æ   Ý   h  A       J   @   `  i  I           `  a  j  i          a  b  k  j          b  c  l  k          c  d  m  l          d  e  n  m          e  f  o  n          f  g  p  o           g  h  q  p    Þ   Õ      h  Ý   Ô   q  J     !  S   I   i  r  R       "  !  i  j  s  r      #  "  j  k  t  s      $  #  k  l  u  t      %  $  l  m  v  u      &  %  m  n  w  v      '  &  n  o  x  w      (  '  o  p  y  x       )  (  p  q  z  y     Õ   Ì   )  q  Ô   Ë   z  S   !  *  \   R   r  {  [   !  "  +  *  r  s  |  {  "  #  ,  +  s  t  }  |  #  $  -  ,  t  u  ~  }  $  %  .  -  u  v    ~  %  &  /  .  v  w  €    &  '  0  /  w  x    €  '  (  1  0  x  y  ‚    (  )  2  1  y  z  ƒ  ‚  )  Ì   à   2  z  Ë      ƒ  \   *  3  e   [   {  „  d   *  +  4  3  {  |  …  „  +  ,  5  4  |  }  †  …  ,  -  6  5  }  ~  ‡  †  -  .  7  6  ~    ˆ  ‡  .  /  8  7    €  ‰  ˆ  /  0  9  8  €    Š  ‰  0  1  :  9    ‚  ‹  Š  1  2  ;  :  ‚  ƒ  Œ  ‹  2  à   º   ;  ƒ     ¹   Œ  e   3  <  n   d   „    m   3  4  =  <  „  …  Ž    4  5  >  =  …  †    Ž  5  6  ?  >  †  ‡      6  7  @  ?  ‡  ˆ  ‘    7  8  A  @  ˆ  ‰  ’  ‘  8  9  B  A  ‰  Š  “  ’  9  :  C  B  Š  ‹  ”  “  :  ;  D  C  ‹  Œ  •  ”  ;  º   ±   D  Œ  ¹   °   •  n   <  E  w   m     –  v   <  =  F  E    Ž  —  –  =  >  G  F  Ž    ˜  —  >  ?  H  G      ™  ˜  ?  @  I  H    ‘  š  ™  @  A  J  I  ‘  ’  ›  š  A  B  K  J  ’  “  œ  ›  B  C  L  K  “  ”    œ  C  D  M  L  ”  •  ž    D  ±   ¨   M  •  °   §   ž  w   E  ¿     v   –  ¾     E  F  È  ¿  –  —  Ç  ¾  F  G  Ñ  È  —  ˜  Ð  Ç  G  H  Ú  Ñ  ˜  ™  Ù  Ð  H  I  ã  Ú  ™  š  â  Ù  I  J  ì  ã  š  ›  ë  â  J  K  õ  ì  ›  œ  ô  ë  K  L  þ  õ  œ    ý  ô  L  M    þ    ž    ý  M  ¨   ›     ž  §   œ     #     N  .   $   	  Ÿ  -       O  N  	       Ÿ      P  O      ¡       #  Q  P    $  ¢  ¡  #  ,  R  Q  $  -  £  ¢  ,  5  S  R  -  6  ¤  £  5  >  T  S  6  ?  ¥  ¤  >  G  U  T  ?  H  ¦  ¥  G  P  V  U  H  Q  §  ¦  P  ‹   ï   V  Q  Š   î   §  .   N  W  7   -   Ÿ  ¨  6   N  O  X  W  Ÿ     ©  ¨  O  P  Y  X     ¡  ª  ©  P  Q  Z  Y  ¡  ¢  «  ª  Q  R  [  Z  ¢  £  ¬  «  R  S  \  [  £  ¤  ­  ¬  S  T  ]  \  ¤  ¥  ®  ­  T  U  ^  ]  ¥  ¦  ¯  ®  U  V  _  ^  ¦  §  °  ¯  V  ï   æ   _  §  î   å   °  7   W  `  @   6   ¨  ±  ?   W  X  a  `  ¨  ©  ²  ±  X  Y  b  a  ©  ª  ³  ²  Y  Z  c  b  ª  «  ´  ³  Z  [  d  c  «  ¬  µ  ´  [  \  e  d  ¬  ­  ¶  µ  \  ]  f  e  ­  ®  ·  ¶  ]  ^  g  f  ®  ¯  ¸  ·  ^  _  h  g  ¯  °  ¹  ¸  _  æ   Ý   h  °  å   Ü   ¹  @   `  i  I   ?   ±  º  H   `  a  j  i  ±  ²  »  º  a  b  k  j  ²  ³  ¼  »  b  c  l  k  ³  ´  ½  ¼  c  d  m  l  ´  µ  ¾  ½  d  e  n  m  µ  ¶  ¿  ¾  e  f  o  n  ¶  ·  À  ¿  f  g  p  o  ·  ¸  Á  À  g  h  q  p  ¸  ¹    Á  h  Ý   Ô   q  ¹  Ü   Ó     I   i  r  R   H   º  à  Q   i  j  s  r  º  »  Ä  à  j  k  t  s  »  ¼  Å  Ä  k  l  u  t  ¼  ½  Æ  Å  l  m  v  u  ½  ¾  Ç  Æ  m  n  w  v  ¾  ¿  È  Ç  n  o  x  w  ¿  À  É  È  o  p  y  x  À  Á  Ê  É  p  q  z  y  Á    Ë  Ê  q  Ô   Ë   z    Ó   Ê   Ë  R   r  {  [   Q   à  Ì  Z   r  s  |  {  à  Ä  Í  Ì  s  t  }  |  Ä  Å  Î  Í  t  u  ~  }  Å  Æ  Ï  Î  u  v    ~  Æ  Ç  Ð  Ï  v  w  €    Ç  È  Ñ  Ð  w  x    €  È  É  Ò  Ñ  x  y  ‚    É  Ê  Ó  Ò  y  z  ƒ  ‚  Ê  Ë  Ô  Ó  z  Ë      ƒ  Ë  Ê   Á   Ô  [   {  „  d   Z   Ì  Õ  c   {  |  …  „  Ì  Í  Ö  Õ  |  }  †  …  Í  Î  ×  Ö  }  ~  ‡  †  Î  Ï  Ø  ×  ~    ˆ  ‡  Ï  Ð  Ù  Ø    €  ‰  ˆ  Ð  Ñ  Ú  Ù  €    Š  ‰  Ñ  Ò  Û  Ú    ‚  ‹  Š  Ò  Ó  Ü  Û  ‚  ƒ  Œ  ‹  Ó  Ô  Ý  Ü  ƒ     ¹   Œ  Ô  Á   ¸   Ý  d   „    m   c   Õ  Þ  l   „  …  Ž    Õ  Ö  ß  Þ  …  †    Ž  Ö  ×  à  ß  †  ‡      ×  Ø  á  à  ‡  ˆ  ‘    Ø  Ù  â  á  ˆ  ‰  ’  ‘  Ù  Ú  ã  â  ‰  Š  “  ’  Ú  Û  ä  ã  Š  ‹  ”  “  Û  Ü  å  ä  ‹  Œ  •  ”  Ü  Ý  æ  å  Œ  ¹   °   •  Ý  ¸   ¯   æ  m     –  v   l   Þ  ç  u     Ž  —  –  Þ  ß  è  ç  Ž    ˜  —  ß  à  é  è      ™  ˜  à  á  ê  é    ‘  š  ™  á  â  ë  ê  ‘  ’  ›  š  â  ã  ì  ë  ’  “  œ  ›  ã  ä  í  ì  “  ”    œ  ä  å  î  í  ”  •  ž    å  æ  ï  î  •  °   §   ž  æ  ¯   ¦   ï  v   –  ¾     u   ç  ½     –  —  Ç  ¾  ç  è  Æ  ½  —  ˜  Ð  Ç  è  é  Ï  Æ  ˜  ™  Ù  Ð  é  ê  Ø  Ï  ™  š  â  Ù  ê  ë  á  Ø  š  ›  ë  â  ë  ì  ê  á  ›  œ  ô  ë  ì  í  ó  ê  œ    ý  ô  í  î  ü  ó    ž    ý  î  ï    ü  ž  §   œ     ï  ¦        $   	  Ÿ  -   %
-  ð  ,   	       Ÿ
-    ñ  ð      ¡         ò  ñ    $  ¢  ¡    %  ó  ò  $  -  £  ¢  %  .  ô  ó  -  6  ¤  £  .  7  õ  ô  6  ?  ¥  ¤  7  @  ö  õ  ?  H  ¦  ¥  @  I  ÷  ö  H  Q  §  ¦  I  R  ø  ÷  Q  Š   î   §  R  ‰   í   ø  -   Ÿ  ¨  6   ,   ð  ù  5   Ÿ     ©  ¨  ð  ñ  ú  ù     ¡  ª  ©  ñ  ò  û  ú  ¡  ¢  «  ª  ò  ó  ü  û  ¢  £  ¬  «  ó  ô  ý  ü  £  ¤  ­  ¬  ô  õ  þ  ý  ¤  ¥  ®  ­  õ  ö  ÿ  þ  ¥  ¦  ¯  ®  ö  ÷     ÿ  ¦  §  °  ¯  ÷  ø       §  î   å   °  ø  í   ä     6   ¨  ±  ?   5   ù    >   ¨  ©  ²  ±  ù  ú      ©  ª  ³  ²  ú  û      ª  «  ´  ³  û  ü      «  ¬  µ  ´  ü  ý      ¬  ­  ¶  µ  ý  þ      ­  ®  ·  ¶  þ  ÿ      ®  ¯  ¸  ·  ÿ     	    ¯  °  ¹  ¸
-  	  °  å   Ü   ¹    ä   Û
-  ?   ±  º  H   >       G   ±  ²  »  º          ²  ³  ¼  »
-    ³  ´  ½  ¼
-  ´  µ  ¾  ½          µ  ¶  ¿  ¾          ¶  ·  À  ¿          ·  ¸  Á  À    	      ¸  ¹  Â  Á
-      ¹  Ü   Ó   Â
-  Û   Ò     H   º  Ã  Q   G       P   º  »  Ä  Ã          »  ¼  Å  Ä  
-      ¼  ½  Æ  Å
-        ½  ¾  Ç  Æ          ¾  ¿  È  Ç          ¿  À  É  È          À  Á  Ê  É          Á    Ë  Ê            Ó   Ê   Ë    Ò   É     Q   à  Ì  Z   P       Y   à  Ä  Í  Ì          Ä  Å  Î  Í          Å  Æ  Ï  Î           Æ  Ç  Ð  Ï      !     Ç  È  Ñ  Ð      "  !  È  É  Ò  Ñ      #  "  É  Ê  Ó  Ò      $  #  Ê  Ë  Ô  Ó      %  $  Ë  Ê   Á   Ô    É   À   %  Z   Ì  Õ  c   Y     &  b   Ì  Í  Ö  Õ      '  &  Í  Î  ×  Ö      (  '  Î  Ï  Ø  ×       )  (  Ï  Ð  Ù  Ø     !  *  )  Ð  Ñ  Ú  Ù  !  "  +  *  Ñ  Ò  Û  Ú  "  #  ,  +  Ò  Ó  Ü  Û  #  $  -  ,  Ó  Ô  Ý  Ü  $  %  .  -  Ô  Á   ¸   Ý  %  À   ·   .  c   Õ  Þ  l   b   &  /  k   Õ  Ö  ß  Þ  &  '  0  /  Ö  ×  à  ß  '  (  1  0  ×  Ø  á  à  (  )  2  1  Ø  Ù  â  á  )  *  3  2  Ù  Ú  ã  â  *  +  4  3  Ú  Û  ä  ã  +  ,  5  4  Û  Ü  å  ä  ,  -  6  5  Ü  Ý  æ  å  -  .  7  6  Ý  ¸   ¯   æ  .  ·   ®   7  l   Þ  ç  u   k   /  8  t   Þ  ß  è  ç  /  0  9  8  ß  à  é  è  0  1  :  9  à  á  ê  é  1  2  ;  :  á  â  ë  ê  2  3  <  ;  â  ã  ì  ë  3  4  =  <  ã  ä  í  ì  4  5  >  =  ä  å  î  í  5  6  ?  >  å  æ  ï  î  6  7  @  ?  æ  ¯   ¦   ï  7  ®   ¥   @  u   ç  ½     t   8  ¼     ç  è  Æ  ½  8  9  Å  ¼  è  é  Ï  Æ  9  :  Î  Å  é  ê  Ø  Ï  :  ;  ×  Î  ê  ë  á  Ø  ;  <  à  ×  ë  ì  ê  á  <  =  é  à  ì  í  ó  ê  =  >  ò  é  í  î  ü  ó  >  ?  û  ò  î  ï    ü  ?  @    û  ï  ¦        @  ¥   ž     %
-  ð  ,   &     A  +
-    ñ  ð      B  A      ò  ñ      C  B    %  ó  ò    &  D  C  %  .  ô  ó  &  /  E  D  .  7  õ  ô  /  8  F  E  7  @  ö  õ  8  A  G  F  @  I  ÷  ö  A  J  H  G  I  R  ø  ÷  J  S  I  H  R  ‰   í   ø  S  ˆ   ì   I  ,   ð  ù  5   +   A  J  4   ð  ñ  ú  ù  A  B  K  J  ñ  ò  û  ú  B  C  L  K  ò  ó  ü  û  C  D  M  L  ó  ô  ý  ü  D  E  N  M  ô  õ  þ  ý  E  F  O  N  õ  ö  ÿ  þ  F  G  P  O  ö  ÷     ÿ  G  H  Q  P  ÷  ø       H  I  R  Q  ø  í   ä     I  ì   ã   R  5   ù    >   4   J  S  =   ù  ú      J  K  T  S  ú  û      K  L  U  T  û  ü      L  M  V  U  ü  ý      M  N  W  V  ý  þ      N  O  X  W  þ  ÿ      O  P  Y  X  ÿ     	    P  Q  Z  Y
-  	  Q  R  [  Z    ä   Û
-  R  ã   Ú   [  >       G   =   S  \  F           S  T  ]  \
-    T  U  ^  ]
-  U  V  _  ^          V  W  `  _          W  X  a  `          X  Y  b  a    	      Y  Z  c  b
-      Z  [  d  c
-  Û   Ò     [  Ú   Ñ   d  G       P   F   \  e  O           \  ]  f  e  
-      ]  ^  g  f
-        ^  _  h  g          _  `  i  h          `  a  j  i          a  b  k  j          b  c  l  k          c  d  m  l    Ò   É     d  Ñ   È   m  P       Y   O   e  n  X           e  f  o  n          f  g  p  o           g  h  q  p      !     h  i  r  q      "  !  i  j  s  r      #  "  j  k  t  s      $  #  k  l  u  t      %  $  l  m  v  u    É   À   %  m  È   ¿   v  Y     &  b   X   n  w  a       '  &  n  o  x  w      (  '  o  p  y  x       )  (  p  q  z  y     !  *  )  q  r  {  z  !  "  +  *  r  s  |  {  "  #  ,  +  s  t  }  |  #  $  -  ,  t  u  ~  }  $  %  .  -  u  v    ~  %  À   ·   .  v  ¿   ¶     b   &  /  k   a   w  €  j   &  '  0  /  w  x    €  '  (  1  0  x  y  ‚    (  )  2  1  y  z  ƒ  ‚  )  *  3  2  z  {  „  ƒ  *  +  4  3  {  |  …  „  +  ,  5  4  |  }  †  …  ,  -  6  5  }  ~  ‡  †  -  .  7  6  ~    ˆ  ‡  .  ·   ®   7    ¶   ­   ˆ  k   /  8  t   j   €  ‰  s   /  0  9  8  €    Š  ‰  0  1  :  9    ‚  ‹  Š  1  2  ;  :  ‚  ƒ  Œ  ‹  2  3  <  ;  ƒ  „    Œ  3  4  =  <  „  …  Ž    4  5  >  =  …  †    Ž  5  6  ?  >  †  ‡      6  7  @  ?  ‡  ˆ  ‘    7  ®   ¥   @  ˆ  ­   ¤   ‘  t   8  ¼     s   ‰  »     8  9  Å  ¼  ‰  Š  Ä  »  9  :  Î  Å  Š  ‹  Í  Ä  :  ;  ×  Î  ‹  Œ  Ö  Í  ;  <  à  ×  Œ    ß  Ö  <  =  é  à    Ž  è  ß  =  >  ò  é  Ž    ñ  è  >  ?  û  ò      ú  ñ  ?  @    û    ‘    ú  @  ¥   ž     ‘  ¤   Ÿ     &     A  +   '     ’  *       B  A      “  ’      C  B      ”  “    &  D  C    '  •  ”  &  /  E  D  '  0  –  •  /  8  F  E  0  9  —  –  8  A  G  F  9  B  ˜  —  A  J  H  G  B  K  ™  ˜  J  S  I  H  K  T  š  ™  S  ˆ   ì   I  T  ‡   ë   š  +   A  J  4   *   ’  ›  3   A  B  K  J  ’  “  œ  ›  B  C  L  K  “  ”    œ  C  D  M  L  ”  •  ž    D  E  N  M  •  –  Ÿ  ž  E  F  O  N  –  —     Ÿ  F  G  P  O  —  ˜  ¡     G  H  Q  P  ˜  ™  ¢  ¡  H  I  R  Q  ™  š  £  ¢  I  ì   ã   R  š  ë   â   £  4   J  S  =   3   ›  ¤  <   J  K  T  S  ›  œ  ¥  ¤  K  L  U  T  œ    ¦  ¥  L  M  V  U    ž  §  ¦  M  N  W  V  ž  Ÿ  ¨  §  N  O  X  W  Ÿ     ©  ¨  O  P  Y  X     ¡  ª  ©  P  Q  Z  Y  ¡  ¢  «  ª  Q  R  [  Z  ¢  £  ¬  «  R  ã   Ú   [  £  â   Ù   ¬  =   S  \  F   <   ¤  ­  E   S  T  ]  \  ¤  ¥  ®  ­  T  U  ^  ]  ¥  ¦  ¯  ®  U  V  _  ^  ¦  §  °  ¯  V  W  `  _  §  ¨  ±  °  W  X  a  `  ¨  ©  ²  ±  X  Y  b  a  ©  ª  ³  ²  Y  Z  c  b  ª  «  ´  ³  Z  [  d  c  «  ¬  µ  ´  [  Ú   Ñ   d  ¬  Ù   Ð   µ  F   \  e  O   E   ­  ¶  N   \  ]  f  e  ­  ®  ·  ¶  ]  ^  g  f  ®  ¯  ¸  ·  ^  _  h  g  ¯  °  ¹  ¸  _  `  i  h  °  ±  º  ¹  `  a  j  i  ±  ²  »  º  a  b  k  j  ²  ³  ¼  »  b  c  l  k  ³  ´  ½  ¼  c  d  m  l  ´  µ  ¾  ½  d  Ñ   È   m  µ  Ð   Ç   ¾  O   e  n  X   N   ¶  ¿  W   e  f  o  n  ¶  ·  À  ¿  f  g  p  o  ·  ¸  Á  À  g  h  q  p  ¸  ¹    Á  h  i  r  q  ¹  º  à    i  j  s  r  º  »  Ä  à  j  k  t  s  »  ¼  Å  Ä  k  l  u  t  ¼  ½  Æ  Å  l  m  v  u  ½  ¾  Ç  Æ  m  È   ¿   v  ¾  Ç   ¾   Ç  X   n  w  a   W   ¿  È  `   n  o  x  w  ¿  À  É  È  o  p  y  x  À  Á  Ê  É  p  q  z  y  Á    Ë  Ê  q  r  {  z    à  Ì  Ë  r  s  |  {  à  Ä  Í  Ì  s  t  }  |  Ä  Å  Î  Í  t  u  ~  }  Å  Æ  Ï  Î  u  v    ~  Æ  Ç  Ð  Ï  v  ¿   ¶     Ç  ¾   µ   Ð  a   w  €  j   `   È  Ñ  i   w  x    €  È  É  Ò  Ñ  x  y  ‚    É  Ê  Ó  Ò  y  z  ƒ  ‚  Ê  Ë  Ô  Ó  z  {  „  ƒ  Ë  Ì  Õ  Ô  {  |  …  „  Ì  Í  Ö  Õ  |  }  †  …  Í  Î  ×  Ö  }  ~  ‡  †  Î  Ï  Ø  ×  ~    ˆ  ‡  Ï  Ð  Ù  Ø    ¶   ­   ˆ  Ð  µ   ¬   Ù  j   €  ‰  s   i   Ñ  Ú  r   €    Š  ‰  Ñ  Ò  Û  Ú    ‚  ‹  Š  Ò  Ó  Ü  Û  ‚  ƒ  Œ  ‹  Ó  Ô  Ý  Ü  ƒ  „    Œ  Ô  Õ  Þ  Ý  „  …  Ž    Õ  Ö  ß  Þ  …  †    Ž  Ö  ×  à  ß  †  ‡      ×  Ø  á  à  ‡  ˆ  ‘    Ø  Ù  â  á  ˆ  ­   ¤   ‘  Ù  ¬   £   â  s   ‰  »     r   Ú  º     ‰  Š  Ä  »  Ú  Û  à  º  Š  ‹  Í  Ä  Û  Ü  Ì  à  ‹  Œ  Ö  Í  Ü  Ý  Õ  Ì  Œ    ß  Ö  Ý  Þ  Þ  Õ    Ž  è  ß  Þ  ß  ç  Þ  Ž    ñ  è  ß  à  ð  ç      ú  ñ  à  á  ù  ð    ‘    ú  á  â    ù  ‘  ¤   Ÿ     â  £         '     ’  *   (
-  ã  )       “  ’
-    ä  ã      ”  “      å  ä    '  •  ”    (  æ  å  '  0  –  •  (  1  ç  æ  0  9  —  –  1  :  è  ç  9  B  ˜  —  :  C  é  è  B  K  ™  ˜  C  L  ê  é  K  T  š  ™  L  U  ë  ê  T  ‡   ë   š  U  †   ê   ë  *   ’  ›  3   )   ã  ì  2   ’  “  œ  ›  ã  ä  í  ì  “  ”    œ  ä  å  î  í  ”  •  ž    å  æ  ï  î  •  –  Ÿ  ž  æ  ç  ð  ï  –  —     Ÿ  ç  è  ñ  ð  —  ˜  ¡     è  é  ò  ñ  ˜  ™  ¢  ¡  é  ê  ó  ò  ™  š  £  ¢  ê  ë  ô  ó  š  ë   â   £  ë  ê   á   ô  3   ›  ¤  <   2   ì  õ  ;   ›  œ  ¥  ¤  ì  í  ö  õ  œ    ¦  ¥  í  î  ÷  ö    ž  §  ¦  î  ï  ø  ÷  ž  Ÿ  ¨  §  ï  ð  ù  ø  Ÿ     ©  ¨  ð  ñ  ú  ù     ¡  ª  ©  ñ  ò  û  ú  ¡  ¢  «  ª  ò  ó  ü  û  ¢  £  ¬  «  ó  ô  ý  ü  £  â   Ù   ¬  ô  á   Ø   ý  <   ¤  ­  E   ;   õ  þ  D   ¤  ¥  ®  ­  õ  ö  ÿ  þ  ¥  ¦  ¯  ®  ö  ÷     ÿ  ¦  §  °  ¯  ÷  ø       §  ¨  ±  °  ø  ù      ¨  ©  ²  ±  ù  ú      ©  ª  ³  ²  ú  û      ª  «  ´  ³  û  ü      «  ¬  µ  ´  ü  ý      ¬  Ù   Ð   µ  ý  Ø   Ï     E   ­  ¶  N   D   þ    M   ­  ®  ·  ¶  þ  ÿ      ®  ¯  ¸  ·  ÿ     	    ¯  °  ¹  ¸
-  	  °  ±  º  ¹
-  ±  ²  »  º          ²  ³  ¼  »
-    ³  ´  ½  ¼
-  ´  µ  ¾  ½          µ  Ð   Ç   ¾    Ï   Æ     N   ¶  ¿  W   M       V   ¶  ·  À  ¿          ·  ¸  Á  À    	      ¸  ¹  Â  Á
-      ¹  º  Ã  Â
-        º  »  Ä  Ã          »  ¼  Å  Ä  
-      ¼  ½  Æ  Å
-        ½  ¾  Ç  Æ          ¾  Ç   ¾   Ç    Æ   ½     W   ¿  È  `   V       _   ¿  À  É  È          À  Á  Ê  É          Á  Â  Ë  Ê          Â  Ã  Ì  Ë          Ã  Ä  Í  Ì          Ä  Å  Î  Í          Å  Æ  Ï  Î           Æ  Ç  Ð  Ï      !     Ç  ¾   µ   Ð    ½   ´   !  `   È  Ñ  i   _     "  h   È  É  Ò  Ñ      #  "  É  Ê  Ó  Ò      $  #  Ê  Ë  Ô  Ó      %  $  Ë  Ì  Õ  Ô      &  %  Ì  Í  Ö  Õ      '  &  Í  Î  ×  Ö      (  '  Î  Ï  Ø  ×       )  (  Ï  Ð  Ù  Ø     !  *  )  Ð  µ   ¬   Ù  !  ´   «   *  i   Ñ  Ú  r   h   "  +  q   Ñ  Ò  Û  Ú  "  #  ,  +  Ò  Ó  Ü  Û  #  $  -  ,  Ó  Ô  Ý  Ü  $  %  .  -  Ô  Õ  Þ  Ý  %  &  /  .  Õ  Ö  ß  Þ  &  '  0  /  Ö  ×  à  ß  '  (  1  0  ×  Ø  á  à  (  )  2  1  Ø  Ù  â  á  )  *  3  2  Ù  ¬   £   â  *  «   ¢   3  r   Ú  º     q   +  ¹
-   Ú  Û  Ã  º  +  ,  Â  ¹  Û  Ü  Ì  Ã  ,  -  Ë  Â  Ü  Ý  Õ  Ì  -  .  Ô  Ë  Ý  Þ  Þ  Õ  .  /  Ý  Ô  Þ  ß  ç  Þ  /  0  æ  Ý  ß  à  ð  ç  0  1  ï  æ  à  á  ù  ð  1  2  ø  ï  á  â    ù  2  3    ø  â  £         3  ¢   ¡     (
-  ã  )      ü
-    ä  ã  ü   ý
-      å  ä  ý   þ         (  æ  å  þ   ÿ   %    (  1  ç  æ  ÿ      .  %  1  :  è  ç       7  .  :  C  é  è      @  7  C  L  ê  é      I  @  L  U  ë  ê      R  I  U  †   ê   ë    {   „   R  )   ã  ì  2
-       ã  ä  í  ì
-        ä  å  î  í          å  æ  ï  î    %  &    æ  ç  ð  ï  %  .  /  &  ç  è  ñ  ð  .  7  8  /  è  é  ò  ñ  7  @  A  8  é  ê  ó  ò  @  I  J  A  ê  ë  ô  ó  I  R  S  J  ë  ê   á   ô  R  „   ƒ   S  2   ì  õ  ;             ì  í  ö  õ          í  î  ÷  ö          î  ï  ø  ÷    &  '    ï  ð  ù  ø  &  /  0  '  ð  ñ  ú  ù  /  8  9  0  ñ  ò  û  ú  8  A  B  9  ò  ó  ü  û  A  J  K  B  ó  ô  ý  ü  J  S  T  K  ô  á   Ø   ý  S  ƒ   ‚   T  ;   õ  þ  D      
-     õ  ö  ÿ  þ  
-  ö  ÷     ÿ          ÷  ø         '  (    ø  ù      '  0  1  (  ù  ú      0  9  :  1  ú  û      9  B  C  :  û  ü      B  K  L  C  ü  ý      K  T  U  L  ý  Ø   Ï     T  ‚      U  D   þ    M
-       þ  ÿ
-        ÿ
-  (  1  2  )          1  :  ;  2
-    :  C  D  ;
-  C  L  M  D          L  U  V  M    Ï   Æ     U     €   V  M       V                               	           !
-        )  2  3  *          2  ;  <  3  
-      ;  D  E  <
-        D  M  N  E          M  V  W  N    Æ   ½     V  €      W  V       _          	                             !  "            !  *  +  "          *  3  4  +          3  <  =  4          <  E  F  =           E  N  O  F      !     N  W  X  O    ½   ´   !  W     ~   X  _     "  h
-       #  "              $  #    "  #        %  $  "  +  ,  #      &  %  +  4  5  ,      '  &  4  =  >  5      (  '  =  F  G  >       )  (  F  O  P  G     !  *  )  O  X  Y  P  !  ´   «   *  X  ~   }   Y  h   "  +  q
-          "  #  ,  +          #  $  -  ,    #  $    $  %  .  -  #  ,  -  $  %  &  /  .  ,  5  6  -  &  '  0  /  5  >  ?  6  '  (  1  0  >  G  H  ?  (  )  2  1  G  P  Q  H  )  *  3  2  P  Y  Z  Q  *  «   ¢   3  Y  }   |   Z  q   +  ¹
-        °     +  ,  Â  ¹      ±  °  ,  -  Ë  Â    $  ²  ±  -  .  Ô  Ë  $  -  ³  ²  .  /  Ý  Ô  -  6  ´  ³  /  0  æ  Ý  6  ?  µ  ´  0  1  ï  æ  ?  H  ¶  µ  1  2  ø  ï  H  Q  ·  ¶  2  3    ø  Q  Z  ¸  ·  3  ¢   ¡     Z  |   z   ¸        ¬           X   d   p           |           ˆ           ”        1400 0 1 16
-11 Cubit 10.1b 17 ACIS 14.0.5 Linux 24 Wed Nov  2 17:46:21 2005
-1 9.9999999999999995e-07 1e-10
-body $1 -1 -1 $-1 $2 $-1 $-1 T -5 -5 -5 5 5 5 #
-simple-snl-attrib $-1 -1 $-1 $-1 $0 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
-lump $3 -1 -1 $-1 $-1 $4 $0 T -5 -5 -5 5 5 5 #
-simple-snl-attrib $-1 -1 $5 $-1 $2 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
-shell $-1 -1 -1 $-1 $-1 $-1 $6 $-1 $2 T -5 -5 -5 5 5 5 #
-simple-snl-attrib $-1 -1 $7 $3 $2 @17 NEW_SIMPLE_ATTRIB 7 @16 GRAPHICS_OPTIONS @14 geometry color @10 mesh color @19 geometry visibility @15 mesh visibility @11 render mode @11 transparent 0 6 2 2 1 1 0 0 #
-face $8 -1 -1 $-1 $9 $10 $4 $-1 $11 forward single T -5 -5 5 5 5 5 F #
-simple-snl-attrib $-1 -1 $12 $5 $2 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @6 submap @4 SOFT 3 1 0 0 8 1 0 0 0 2 0 0 0 #
-simple-snl-attrib $-1 -1 $13 $-1 $6 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
-face $14 -1 -1 $-1 $15 $16 $4 $-1 $17 reversed single T -5 -5 -5 5 5 -5 F #
-loop $-1 -1 -1 $-1 $-1 $18 $6 T -5 -5 5 5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 0 0 5 0 0 1 1 0 0 forward_v I I I I #
-simple-snl-attrib $-1 -1 $19 $7 $2 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 -2147483648 #
-simple-snl-attrib $-1 -1 $20 $8 $6 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 1702030724 1096363974 2143521325 373514558 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $21 $-1 $9 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
-face $22 -1 -1 $-1 $23 $24 $4 $-1 $25 reversed single T -5 -5 -5 5 -5 5 F #
-loop $-1 -1 -1 $-1 $-1 $26 $9 T -5 -5 -5 5 5 -5 unknown #
-plane-surface $-1 -1 -1 $-1 0 0 -5 0 0 1 1 0 0 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $27 $28 $29 $30 forward $10 $-1 #
-simple-snl-attrib $-1 -1 $-1 $12 $2 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 344787401 #
-simple-snl-attrib $-1 -1 $31 $13 $6 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $32 $14 $9 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 389245125 2108691331 1826621792 1189841319 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $33 $-1 $15 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
-face $34 -1 -1 $-1 $35 $36 $4 $-1 $37 reversed single T -5 -5 -5 -5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $38 $15 T -5 -5 -5 5 -5 5 unknown #
-plane-surface $-1 -1 -1 $-1 0 -5 0 0 1 -0 -0 0 1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $39 $40 $41 $42 forward $16 $-1 #
-coedge $-1 -1 -1 $-1 $43 $18 $44 $45 forward $10 $-1 #
-coedge $-1 -1 -1 $-1 $18 $43 $46 $47 forward $10 $-1 #
-coedge $-1 -1 -1 $-1 $48 $49 $18 $30 reversed $50 $-1 #
-edge $51 -1 -1 $-1 $52 -5 $53 5 $29 $54 forward @7 unknown T 5 -5 5 5 5 5 #
-simple-snl-attrib $-1 -1 $55 $20 $6 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $56 $21 $9 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $57 $22 $15 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 2108691331 389245125 373514558 2143521325 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $58 $-1 $23 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
-face $59 -1 -1 $-1 $60 $61 $4 $-1 $62 reversed single T -5 5 -5 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $63 $23 T -5 -5 -5 -5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 -5 0 0 1 0 0 0 0 -1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $64 $46 $65 $66 forward $24 $-1 #
-coedge $-1 -1 -1 $-1 $67 $26 $64 $68 forward $16 $-1 #
-coedge $-1 -1 -1 $-1 $26 $67 $69 $70 forward $16 $-1 #
-coedge $-1 -1 -1 $-1 $49 $48 $26 $42 reversed $50 $-1 #
-edge $71 -1 -1 $-1 $72 -5 $73 5 $41 $74 forward @7 unknown T 5 -5 -5 5 5 -5 #
-coedge $-1 -1 -1 $-1 $28 $27 $75 $76 forward $10 $-1 #
-coedge $-1 -1 -1 $-1 $77 $78 $27 $45 reversed $61 $-1 #
-edge $79 -1 -1 $-1 $53 -5 $80 5 $44 $81 forward @7 unknown T -5 5 5 5 5 5 #
-coedge $-1 -1 -1 $-1 $38 $82 $28 $47 reversed $24 $-1 #
-edge $83 -1 -1 $-1 $84 -5 $52 5 $46 $85 forward @7 unknown T -5 -5 5 5 -5 5 #
-coedge $-1 -1 -1 $-1 $41 $29 $82 $86 forward $50 $-1 #
-coedge $-1 -1 -1 $-1 $29 $41 $77 $87 reversed $50 $-1 #
-loop $-1 -1 -1 $-1 $-1 $48 $60 T 5 -5 -5 5 5 5 unknown #
-simple-snl-attrib $-1 -1 $88 $-1 $30 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
-vertex $89 -1 -1 $-1 $30 $90 #
-vertex $91 -1 -1 $-1 $30 $92 #
-straight-curve $-1 -1 -1 $-1 5 0 5 0 1 0 I I #
-simple-snl-attrib $-1 -1 $-1 $31 $6 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1725297774 #
-simple-snl-attrib $-1 -1 $93 $32 $9 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $94 $33 $15 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $95 $34 $23 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 1826621792 2108691331 2143521325 1096363974 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $96 $-1 $35 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
-face $97 -1 -1 $-1 $-1 $50 $4 $-1 $98 reversed single T 5 -5 -5 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $77 $35 T -5 5 -5 5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 0 5 0 0 -1 0 0 0 -1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $99 $75 $78 $100 forward $36 $-1 #
-coedge $-1 -1 -1 $-1 $82 $38 $39 $68 reversed $24 $-1 #
-coedge $-1 -1 -1 $-1 $75 $99 $38 $66 reversed $36 $-1 #
-edge $101 -1 -1 $-1 $84 -5 $102 5 $65 $103 forward @7 unknown T -5 -5 -5 -5 -5 5 #
-coedge $-1 -1 -1 $-1 $40 $39 $99 $104 forward $16 $-1 #
-edge $105 -1 -1 $-1 $73 -5 $102 5 $64 $106 forward @7 unknown T -5 -5 -5 5 -5 -5 #
-coedge $-1 -1 -1 $-1 $78 $77 $40 $70 reversed $61 $-1 #
-edge $107 -1 -1 $-1 $108 -5 $72 5 $69 $109 forward @7 unknown T -5 5 -5 5 5 -5 #
-simple-snl-attrib $-1 -1 $110 $-1 $42 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
-vertex $111 -1 -1 $-1 $42 $112 #
-vertex $113 -1 -1 $-1 $86 $114 #
-straight-curve $-1 -1 -1 $-1 5 0 -5 0 -1 0 I I #
-coedge $-1 -1 -1 $-1 $63 $65 $43 $76 reversed $36 $-1 #
-edge $115 -1 -1 $-1 $80 -5 $84 5 $75 $116 forward @7 unknown T -5 -5 5 -5 5 5 #
-coedge $-1 -1 -1 $-1 $69 $44 $49 $87 forward $61 $-1 #
-coedge $-1 -1 -1 $-1 $44 $69 $63 $100 reversed $61 $-1 #
-simple-snl-attrib $-1 -1 $117 $-1 $45 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
-vertex $118 -1 -1 $-1 $45 $119 #
-straight-curve $-1 -1 -1 $-1 0 5 5 -1 0 0 I I #
-coedge $-1 -1 -1 $-1 $46 $64 $48 $86 reversed $24 $-1 #
-simple-snl-attrib $-1 -1 $120 $-1 $47 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
-vertex $121 -1 -1 $-1 $76 $122 #
-straight-curve $-1 -1 -1 $-1 0 -5 5 1 0 0 I I #
-edge $123 -1 -1 $-1 $52 -5 $73 5 $48 $124 forward @7 unknown T 5 -5 -5 5 -5 5 #
-edge $125 -1 -1 $-1 $53 -5 $72 5 $49 $126 forward @7 unknown T 5 5 -5 5 5 5 #
-simple-snl-attrib $-1 -1 $127 $51 $30 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $128 $-1 $52 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
-point $-1 -1 -1 $-1 5 -5 5 #
-simple-snl-attrib $-1 -1 $129 $-1 $53 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
-point $-1 -1 -1 $-1 5 5 5 #
-simple-snl-attrib $-1 -1 $-1 $56 $9 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 98513342 #
-simple-snl-attrib $-1 -1 $130 $57 $15 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $131 $58 $23 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $132 $59 $35 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 1189841319 1826621792 1096363974 1702030724 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $133 $-1 $60 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
-plane-surface $-1 -1 -1 $-1 5 0 0 -1 0 0 0 -0 1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $65 $63 $67 $104 reversed $36 $-1 #
-edge $134 -1 -1 $-1 $80 -5 $108 5 $78 $135 forward @7 unknown T -5 5 -5 -5 5 5 #
-simple-snl-attrib $-1 -1 $136 $-1 $66 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 9 -2147483648 -1 #
-vertex $137 -1 -1 $-1 $104 $138 #
-straight-curve $-1 -1 -1 $-1 -5 -5 0 0 0 -1 I I #
-edge $139 -1 -1 $-1 $102 -5 $108 5 $99 $140 forward @7 unknown T -5 -5 -5 -5 5 -5 #
-simple-snl-attrib $-1 -1 $141 $-1 $68 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 0 -5 -5 -1 0 0 I I #
-simple-snl-attrib $-1 -1 $142 $-1 $70 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 8 -2147483648 -1 #
-vertex $143 -1 -1 $-1 $70 $144 #
-straight-curve $-1 -1 -1 $-1 0 5 -5 1 0 0 I I #
-simple-snl-attrib $-1 -1 $145 $71 $42 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $146 $-1 $72 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
-point $-1 -1 -1 $-1 5 5 -5 #
-simple-snl-attrib $-1 -1 $147 $-1 $73 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
-point $-1 -1 -1 $-1 5 -5 -5 #
-simple-snl-attrib $-1 -1 $148 $-1 $76 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 -5 0 5 0 -1 0 I I #
-simple-snl-attrib $-1 -1 $149 $79 $45 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $150 $-1 $80 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
-point $-1 -1 -1 $-1 -5 5 5 #
-simple-snl-attrib $-1 -1 $151 $83 $47 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $152 $-1 $84 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
-point $-1 -1 -1 $-1 -5 -5 5 #
-simple-snl-attrib $-1 -1 $153 $-1 $86 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 10 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 5 -5 0 0 0 -1 I I #
-simple-snl-attrib $-1 -1 $154 $-1 $87 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 12 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 5 5 0 0 0 -1 I I #
-simple-snl-attrib $-1 -1 $155 $88 $30 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1074105041 #
-simple-snl-attrib $-1 -1 $-1 $89 $52 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 373514558 #
-simple-snl-attrib $-1 -1 $-1 $91 $53 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1702030724 #
-simple-snl-attrib $-1 -1 $-1 $94 $15 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 928964956 #
-simple-snl-attrib $-1 -1 $156 $95 $23 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $157 $96 $35 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $158 $97 $60 @17 NEW_SIMPLE_ATTRIB 1 @11 VERTEX_TYPE 0 12 4 389245125 1189841319 1702030724 373514558 1 1 1 1 0 0 0 #
-simple-snl-attrib $-1 -1 $159 $-1 $100 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 11 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 -5 5 0 0 0 -1 I I #
-simple-snl-attrib $-1 -1 $160 $101 $66 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $161 $-1 $102 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 7 -2147483648 -1 #
-point $-1 -1 -1 $-1 -5 -5 -5 #
-simple-snl-attrib $-1 -1 $162 $-1 $104 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 7 -2147483648 -1 #
-straight-curve $-1 -1 -1 $-1 -5 0 -5 0 1 0 I I #
-simple-snl-attrib $-1 -1 $163 $105 $68 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $164 $107 $70 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $165 $-1 $108 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 8 -2147483648 -1 #
-point $-1 -1 -1 $-1 -5 5 -5 #
-simple-snl-attrib $-1 -1 $166 $110 $42 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 30382983 #
-simple-snl-attrib $-1 -1 $-1 $111 $72 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1189841319 #
-simple-snl-attrib $-1 -1 $-1 $113 $73 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 389245125 #
-simple-snl-attrib $-1 -1 $167 $115 $76 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $168 $117 $45 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1956671020 #
-simple-snl-attrib $-1 -1 $-1 $118 $80 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1096363974 #
-simple-snl-attrib $-1 -1 $169 $120 $47 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 874603908 #
-simple-snl-attrib $-1 -1 $-1 $121 $84 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 2143521325 #
-simple-snl-attrib $-1 -1 $170 $123 $86 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $171 $125 $87 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-ptlist-eye-attrib $-1 -1 $-1 $127 $30 #
-simple-snl-attrib $-1 -1 $-1 $131 $23 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 257538052 #
-simple-snl-attrib $-1 -1 $172 $132 $35 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $173 $133 $60 @17 NEW_SIMPLE_ATTRIB 3 @11 MESH_SCHEME @3 map @4 SOFT 3 1 0 0 8 1 0 0 1 0 0 0 0 #
-simple-snl-attrib $-1 -1 $174 $134 $100 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $175 $136 $66 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 744042966 #
-simple-snl-attrib $-1 -1 $-1 $137 $102 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 2108691331 #
-simple-snl-attrib $-1 -1 $176 $139 $104 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 10 1 10 0 -2147483648 #
-simple-snl-attrib $-1 -1 $177 $141 $68 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 513246190 #
-simple-snl-attrib $-1 -1 $178 $142 $70 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 967558788 #
-simple-snl-attrib $-1 -1 $-1 $143 $108 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1826621792 #
-ptlist-eye-attrib $-1 -1 $-1 $145 $42 #
-simple-snl-attrib $-1 -1 $179 $148 $76 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 349161614 #
-ptlist-eye-attrib $-1 -1 $-1 $149 $45 #
-ptlist-eye-attrib $-1 -1 $-1 $151 $47 #
-simple-snl-attrib $-1 -1 $180 $153 $86 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 290350554 #
-simple-snl-attrib $-1 -1 $181 $154 $87 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1236814943 #
-simple-snl-attrib $-1 -1 $-1 $157 $35 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 2106251217 #
-simple-snl-attrib $-1 -1 $182 $158 $60 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 SOFT @4 LIMP 2 1 0 5 1 1 0 0 1 #
-simple-snl-attrib $-1 -1 $183 $159 $100 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 2063404574 #
-ptlist-eye-attrib $-1 -1 $-1 $160 $66 #
-simple-snl-attrib $-1 -1 $184 $162 $104 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 732146975 #
-ptlist-eye-attrib $-1 -1 $-1 $163 $68 #
-ptlist-eye-attrib $-1 -1 $-1 $164 $70 #
-ptlist-eye-attrib $-1 -1 $-1 $167 $76 #
-ptlist-eye-attrib $-1 -1 $-1 $170 $86 #
-ptlist-eye-attrib $-1 -1 $-1 $171 $87 #
-simple-snl-attrib $-1 -1 $-1 $173 $60 @17 NEW_SIMPLE_ATTRIB 1 @9 UNIQUE_ID 1 0 1 1109621111 #
-ptlist-eye-attrib $-1 -1 $-1 $174 $100 #
-ptlist-eye-attrib $-1 -1 $-1 $176 $104 #
-End-of-ACIS-data                     DataVersion š™™™™™ñ?         UserName             CubitVersion   10.1b            CubitRevisionDate      06/09/2005 15:42:55 MST
-   CubitBuild     93           TimeAndDate    11/02/2005 05:46:20 PM           NumMeshEntities    3  °  X      è                   NumRefEntities  	                                          NumRefEntitiesMeshed	                                          SETTING Auto Size Default         @          SETTING Auto Size Function               SETTING Auto Size When LIMP           "   SETTING Block Mixed Element Output               SETTING Block Pyramid Offset †            SETTING Block Tetrahedron Offset'            SETTING Block Triangle Offset   è            SETTING Catch Interrupt             SETTING Cleanup Angle        `f@          SETTING Continue Meshing            SETTING Corner AngleL$DTû!	@         SETTING Corner Weight         ð?          SETTING Default Block              (   SETTING Default Element Shape Preference             SETTING Default Names                 SETTING Deletions                SETTING Diagnostic                SETTING Digits  ÿÿÿÿ          SETTING Echo             SETTING Facet BBox
-   SETTING Fastq                 SETTING Fix Duplicate Names              SETTING FullHex Use               SETTING Group Imprint                SETTING HexTet Transition_type            #   SETTING Import Mesh Curve Tolerance -Cëâ6?       )   SETTING Import Mesh NodeSet Associativity             !   SETTING Import Mesh NodeSet Order            %   SETTING Import Mesh Surface Tolerance   -Cëâ6?      $   SETTING Import Mesh Vertex Tolerance-Cëâ6?          SETTING Info            SETTING Interval Weight       ð?          SETTING Keep Invalid Mesh                SETTING Laminate Tolerance        ð?         SETTING Large Angle Weight        ð?          SETTING Mapping Constraint              SETTING Match Intervals Delta                     SETTING Match Intervals Fast              SETTING Match Intervals Rounding              SETTING Maximum Intervalè            SETTING Maximum Memory On Off                 SETTING Maximum Memory Value Êš;         SETTING Measure Small Tolerance ü©ñÒMbP?          SETTING Merge Base Names              SETTING Merge Test BBox              SETTING Merge Test InternalSurf             SETTING Merge Tolerance      @@          SETTING Morph Smooth              SETTING New Ids           !   SETTING Node Coincident Tolerance   :Œ0âŽyE>          SETTING Node Constraint              SETTING NodeSet Associativity              &   SETTING NodeSet Associativity Complete                SETTING NonRegImprint                SETTING Overlap Across Bodies                SETTING Overlap Display          #   SETTING Overlap Facet BBox Absolute                    SETTING Overlap Facet BBox Angle             SETTING Overlap Group                SETTING Overlap List            SETTING Overlap Maximum Angle         @         SETTING Overlap Maximum Gap {®Gáz„?         SETTING Overlap Minimum Angle                    SETTING Overlap Minimum Gap                  SETTING Overlap Normal     any          SETTING Overlap Tolerance   ü©ñÒMbP?          SETTING Overlap Within Bodies                 SETTING Parse Filter             SETTING Paver Diagonal ScaleÍÌÌÌÌÌì?         SETTING Paver Grid Cell       @          SETTING Paver Linearsizing               SETTING Paver Smooth Method               SETTING Pick Filter              SETTING Project Smooth                SETTING Push Attribs              SETTING QTri Test             !   SETTING Quad Relative Size Metric                    SETTING Replacement Character      _         #   SETTING Scheme Auto Fuzzy Tolerance       ;@          SETTING Separate After Webcut               SETTING Shape Threshold š™™™™™É?          SETTING SideSet Associativity                 SETTING Smooth Method             !   SETTING Smooth Tolerance Surf Opt   š™™™™™©?          SETTING Smooth Tolerance Surfaceš™™™™™©?         SETTING Smooth Tolerance Sweep  ü©ñÒMbP?         SETTING Smooth Tolerance Volume š™™™™™©?         SETTING Source Surface Pattern     source         -   SETTING Source Surface Pattern Include Volume              +   SETTING Split Surface Auto Detect Triangles               SETTING Split Surface Parametric          +   SETTING Split Surface Point Angle Threshold      €F@      *   SETTING Split Surface Side Angle Threshold        ;@         SETTING Split Surface Tolerance       ð?          SETTING Step             SETTING Submap Cornerpicking            SETTING Suffix Character   @            SETTING Target Surface Pattern     target         -   SETTING Target Surface Pattern Include Volume                 SETTING Tight Curve               SETTING Tight Surface                SETTING Tight Vertex          !   SETTING Trimesher Advancing Front      not_yet          SETTING Turn Weight       ð?       )   SETTING Void Cleanup Butterfly_face_check             '   SETTING Void Cleanup Connectivity_check           #   SETTING Void Cleanup Dihedral_angle           #   SETTING Void Cleanup Distance Check          $   SETTING Void Cleanup Distance_factor      è?          SETTING Void Cleanup Face_angle          +   SETTING Void Cleanup Maximum Dihedral_angle ?Ð8Ʀñ@      '   SETTING Void Cleanup Maximum Face_angle      à`@      +   SETTING Void Cleanup Minimum Dihedral_angle ‡DçJWæ?      '   SETTING Void Cleanup Minimum Face_angle      €F@      %   SETTING Void Cleanup Minimum Jacobian                     SETTING Warning              SETTING old names                 SETTING unmerge new ids
\ No newline at end of file
Added: MOAB/trunk/test/brick_cubit10.1.cub
(Binary files differ)
Property changes on: MOAB/trunk/test/brick_cubit10.1.cub
___________________________________________________________________
   + application/octet-stream
Added: MOAB/trunk/test/brick_cubit10.2.cub
Property changes on: MOAB/trunk/test/brick_cubit10.2.cub
Added: MOAB/trunk/test/brick_cubit10.cub
Property changes on: MOAB/trunk/test/brick_cubit10.cub
