[MOAB-dev] r1169 - MOAB/trunk/tools/iMesh/SIDL
kraftche at mcs.anl.gov
Thu Jun 28 18:32:10 CDT 2007
Author: kraftche
Date: 2007-06-28 18:32:09 -0500 (Thu, 28 Jun 2007)
New Revision: 1169
Removed:
MOAB/trunk/tools/iMesh/SIDL/iBase.h
MOAB/trunk/tools/iMesh/SIDL/iMesh.h
Log:
remove redundant copies of headers
Deleted: MOAB/trunk/tools/iMesh/SIDL/iBase.h
--- MOAB/trunk/tools/iMesh/SIDL/iBase.h 2007-06-28 20:36:14 UTC (rev 1168)
+++ MOAB/trunk/tools/iMesh/SIDL/iBase.h 2007-06-28 23:32:09 UTC (rev 1169)
@@ -1,86 +0,0 @@
-#ifndef __iBase_INC__
-#define __iBase_INC__
-#include <stdlib.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- typedef size_t iBase_EntityHandle;
- typedef size_t iBase_EntitySetHandle;
- typedef size_t iBase_TagHandle;
- enum iBase_EntityType {
- iBase_VERTEX,
- iBase_EDGE,
- iBase_FACE,
- iBase_REGION,
- iBase_ALL_TYPES
- enum iBase_CreationStatus {
- iBase_NEW,
- iBase_ALREADY_EXISTED,
- iBase_CREATED_DUPLICATE,
- iBase_CREATION_FAILED
- enum iBase_ErrorActions {
- iBase_SILENT,
- iBase_WARN_ONLY,
- iBase_ABORT_ON_ERROR,
- iBase_PRINT_AND_THROW_ERROR,
- iBase_THROW_ERROR
- enum iBase_ErrorType {
- iBase_SUCCESS,
- iBase_MESH_ALREADY_LOADED,
- iBase_NO_MESH_DATA,
- iBase_FILE_NOT_FOUND,
- iBase_FILE_WRITE_ERROR,
- iBase_NIL_ARRAY,
- iBase_BAD_ARRAY_SIZE,
- iBase_BAD_ARRAY_DIMENSION,
- iBase_INVALID_ENTITY_HANDLE,
- iBase_INVALID_ENTITY_COUNT,
- iBase_INVALID_ENTITY_TYPE,
- iBase_INVALID_ENTITY_TOPOLOGY,
- iBase_BAD_TYPE_AND_TOPO,
- iBase_ENTITY_CREATION_ERROR,
- iBase_INVALID_TAG_HANDLE,
- iBase_TAG_NOT_FOUND,
- iBase_TAG_ALREADY_EXISTS,
- iBase_TAG_IN_USE,
- iBase_INVALID_ENTITYSET_HANDLE,
- iBase_INVALID_ITERATOR_HANDLE,
- iBase_INVALID_ARGUMENT,
- iBase_MEMORY_ALLOCATION_FAILED,
- iBase_NOT_SUPPORTED,
- iBase_FAILURE
- struct iBase_Error
- char description[120];
- enum iBase_ErrorType error_type;
- enum iBase_StorageOrder {
- iBase_BLOCKED,
- iBase_INTERLEAVED,
- iBase_UNDETERMINED
- enum iBase_TagValueType {
- iBase_INTEGER,
- iBase_DOUBLE,
- iBase_ENTITY_HANDLE,
- iBase_BYTES
-#ifdef __cplusplus
-#endif
-#endif
Deleted: MOAB/trunk/tools/iMesh/SIDL/iMesh.h
--- MOAB/trunk/tools/iMesh/SIDL/iMesh.h 2007-06-28 20:36:14 UTC (rev 1168)
+++ MOAB/trunk/tools/iMesh/SIDL/iMesh.h 2007-06-28 23:32:09 UTC (rev 1169)
@@ -1,624 +0,0 @@
-#ifndef IMESH_CBIND_H__
-#define IMESH_CBIND_H__
-#ifndef ITAPS
-#define ITAPS
-#endif
-#include "iBase.h"
-#include "iMesh_protos.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
- typedef void* iMesh_Instance;
- typedef void* iMesh_EntityIterator;
- typedef void* iMesh_EntityArrIterator;
- enum iMesh_EntityTopology {
- iMesh_POINT = 0, /**< a general zero-dimensional entity */
- iMesh_LINE_SEGMENT, /**< a general one-dimensional entity */
- iMesh_POLYGON, /**< a general two-dimensional element */
- iMesh_TRIANGLE, /**< a three-sided, two-dimensional element */
- iMesh_QUADRILATERAL, /**< a four-sided, two-dimensional element */
- iMesh_POLYHEDRON, /**< a general three-dimensional element */
- iMesh_TETRAHEDRON, /**< a four-sided, three-dimensional element whose
- * faces are triangles */
- iMesh_HEXAHEDRON, /**< a six-sided, three-dimensional element whose
- * faces are quadrilaterals */
- iMesh_PRISM, /**< a five-sided, three-dimensional element which
- * has three quadrilateral faces and two
- * triangular faces */
- iMesh_PYRAMID, /**< a five-sided, three-dimensional element
- * which has one quadrilateral face and four
- iMesh_SEPTAHEDRON, /**< a hexahedral entity with one collapsed edge */
- iMesh_ALL_TOPOLOGIES /**< allows the user to request information
- * about all the topology types */
- void iMesh_getErrorType(iMesh_Instance instance,
- int *error_type, int *err);
- void iMesh_getDescription(iMesh_Instance instance,
- char *descr, int *err, int descr_len);
- void iMesh_newMesh(const char *options,
- iMesh_Instance *instance, int *err, int options_len);
- void iMesh_dtor(iMesh_Instance instance, int *err);
- void iMesh_load(iMesh_Instance instance,
- const iBase_EntitySetHandle entity_set_handle,
- const char *name, const char *options,
- int *err, int name_len, int options_len);
- void iMesh_save(iMesh_Instance instance,
- int *err, const int name_len, int options_len);
- void iMesh_getRootSet(iMesh_Instance instance,
- iBase_EntitySetHandle *root_set, int *err);
- void iMesh_getGeometricDimension(iMesh_Instance instance,
- int *geom_dim, int *err);
- void iMesh_getDfltStorage(iMesh_Instance instance,
- int *order, int *err);
- void iMesh_getAdjTable (iMesh_Instance instance,
- int** adjacency_table,
- /*inout*/ int* adjacency_table_allocated,
- /*out*/ int* adjacency_table_size, int *err);
- void iMesh_getNumOfType(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_handle,
- /*in*/ const int entity_type,
- int *num_type, int *err);
- void iMesh_getNumOfTopo(iMesh_Instance instance,
- /*in*/ const int entity_topology,
- int *num_topo, int *err);
- void iMesh_areEHValid(iMesh_Instance instance, /*in*/ int doReset,
- /*out*/ int *areHandlesInvariant, int *err);
- void iMesh_getAllVtxCoords (iMesh_Instance instance,
- /*inout*/ double** coordinates,
- /*inout*/ int* coordinates_allocated,
- /*out*/ int* coordinates_size,
- /*inout*/ int** in_entity_set,
- /*inout*/ int* in_entity_set_allocated,
- /*out*/ int* in_entity_set_size,
- /*inout*/ int* storage_order, int *err);
- void iMesh_getVtxCoordIndex (iMesh_Instance instance,
- /*in*/ const int requested_entity_type,
- /*in*/ const int requested_entity_topology,
- /*in*/ const int entity_adjacency_type,
- /*inout*/ int** offset,
- /*inout*/ int* offset_allocated,
- /*out*/ int* offset_size,
- /*inout*/ int** index,
- /*inout*/ int* index_allocated,
- /*out*/ int* index_size,
- /*inout*/ int** entity_topologies,
- /*inout*/ int* entity_topologies_allocated,
- /*out*/ int* entity_topologies_size, int *err);
- void iMesh_getEntities(iMesh_Instance instance,
- const int entity_type,
- const int entity_topology,
- iBase_EntityHandle** entity_handles,
- int* entity_handles_allocated,
- int* entity_handles_size,
- int *err);
- void iMesh_getVtxArrCoords(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* vertex_handles,
- /*in*/ const int vertex_handles_size,
- /*inout*/ double** coords,
- /*inout*/ int* coords_allocated,
- /*out*/ int* coords_size, int *err);
- void iMesh_getAdjEntities(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle entity_set_handle,
- /*in*/ const int entity_type_requestor,
- /*in*/ const int entity_topology_requestor,
- /*in*/ const int entity_type_requested,
- /*inout*/ iBase_EntityHandle** adj_entity_handles,
- /*inout*/ int* adj_entity_handles_allocated,
- /*out*/ int* adj_entity_handles_size,
- /*out*/ int* in_entity_set_size, int *err);
- void iMesh_initEntArrIter(iMesh_Instance instance,
- /*in*/ const int requested_array_size,
- /*out*/ iMesh_EntityArrIterator* entArr_iterator,
- int *err);
- void iMesh_getNextEntArrIter(iMesh_Instance instance,
- /*in*/ iMesh_EntityArrIterator entArr_iterator,
- /*inout*/ iBase_EntityHandle** entity_handles,
- /*inout*/ int* entity_handles_allocated,
- /*out*/ int* entity_handles_size,
- int *has_data, int *err);
- void iMesh_resetEntArrIter(iMesh_Instance instance,
- /*in*/ iMesh_EntityArrIterator entArr_iterator, int *err);
- void iMesh_endEntArrIter(iMesh_Instance instance,
- void iMesh_getEntArrTopo(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* entity_handles,
- /*in*/ const int entity_handles_size,
- /*inout*/ int** topology,
- /*inout*/ int* topology_allocated,
- /*out*/ int* topology_size, int *err);
- void iMesh_getEntArrType(iMesh_Instance instance,
- /*inout*/ int** type,
- /*inout*/ int* type_allocated,
- /*out*/ int* type_size, int *err);
- void iMesh_getEntArrAdj(iMesh_Instance instance,
- /*inout*/ iBase_EntityHandle** adjacentEntityHandles,
- /*inout*/ int* adjacentEntityHandles_allocated,
- /*out*/ int* offset_size, int *err);
- void iMesh_createEntSet(iMesh_Instance instance,
- /*in*/ const int isList,
- /*out*/ iBase_EntitySetHandle* entity_set_created, int *err);
- void iMesh_destroyEntSet(iMesh_Instance instance,
- /*in*/ iBase_EntitySetHandle entity_set, int *err);
- void iMesh_isList(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set,
- int *is_list, int *err);
- void iMesh_getNumEntSets(iMesh_Instance instance,
- /*in*/ const int num_hops,
- int *num_sets, int *err);
- void iMesh_getEntSets(iMesh_Instance instance,
- /*out*/ iBase_EntitySetHandle** contained_set_handles,
- /*out*/ int* contained_set_handles_allocated,
- /*out*/ int* contained_set_handles_size, int *err);
- void iMesh_addEntToSet(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle entity_handle,
- /*inout*/ iBase_EntitySetHandle* entity_set, int *err);
- void iMesh_rmvEntFromSet(iMesh_Instance instance,
- void iMesh_addEntArrToSet(iMesh_Instance instance,
- void iMesh_rmvEntArrFromSet(iMesh_Instance instance,
- void iMesh_addEntSet(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle entity_set_to_add,
- /*inout*/ iBase_EntitySetHandle* entity_set_handle, int *err);
- void iMesh_rmvEntSet(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_to_remove,
- void iMesh_isEntContained(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle containing_entity_set,
- /*in*/ const iBase_EntitySetHandle contained_entity,
- int *is_contained, int *err);
- void iMesh_isEntSetContained(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle contained_entity_set,
- void iMesh_addPrntChld(iMesh_Instance instance,
- /*inout*/ iBase_EntitySetHandle* parent_entity_set,
- /*inout*/ iBase_EntitySetHandle* child_entity_set, int *err);
- void iMesh_rmvPrntChld(iMesh_Instance instance,
- void iMesh_isChildOf(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle parent_entity_set,
- /*in*/ const iBase_EntitySetHandle child_entity_set,
- int *is_child, int *err);
- void iMesh_getNumChld(iMesh_Instance instance,
- int *num_child, int *err);
- void iMesh_getNumPrnt(iMesh_Instance instance,
- int *num_parent, int *err);
- void iMesh_getChldn(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle from_entity_set,
- /*out*/ iBase_EntitySetHandle** entity_set_handles,
- /*out*/ int* entity_set_handles_allocated,
- /*out*/ int* entity_set_handles_size, int *err);
- void iMesh_getPrnts(iMesh_Instance instance,
- void iMesh_setVtxArrCoords(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* vertex_handles,
- /*in*/ const int storage_order,
- /*in*/ const double* new_coords,
- /*in*/ const int new_coords_size, int *err);
- void iMesh_createVtxArr(iMesh_Instance instance,
- /*in*/ const int num_verts,
- /*inout*/ iBase_EntityHandle** new_vertex_handles,
- /*inout*/ int* new_vertex_handles_allocated,
- /*inout*/ int* new_vertex_handles_size, int *err);
- void iMesh_createEntArr(iMesh_Instance instance,
- /*in*/ const int new_entity_topology,
- /*in*/ const iBase_EntityHandle* lower_order_entity_handles,
- /*in*/ const int lower_order_entity_handles_size,
- /*out*/ iBase_EntityHandle** new_entity_handles,
- /*out*/ int* new_entity_handles_allocated,
- /*out*/ int* new_entity_handles_size,
- /*inout*/ int** status,
- /*inout*/ int* status_allocated,
- /*out*/ int* status_size, int *err);
- void iMesh_deleteEntArr(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* entity_handles,
- /*in*/ const int entity_handles_size, int *err);
- void iMesh_createTag(iMesh_Instance instance,
- /*in*/ const char* tag_name,
- /*in*/ const int tag_size,
- /*in*/ const int tag_type,
- /*out*/ iBase_TagHandle* tag_handle,
- int *err,
- /*in*/ const int tag_name_len);
- void iMesh_destroyTag(iMesh_Instance instance,
- /*in*/ iBase_TagHandle tag_handle,
- /*in*/ const int forced, int *err);
- void iMesh_getTagName(iMesh_Instance instance,
- /*in*/ const iBase_TagHandle tag_handle,
- char *name, int *err,
- int name_len);
- void iMesh_getTagSizeValues(iMesh_Instance instance,
- int *tag_size, int *err);
- void iMesh_getTagSizeBytes(iMesh_Instance instance,
- void iMesh_getTagHandle(iMesh_Instance instance,
- iBase_TagHandle *tag_handle,
- int *err,
- int tag_name_len);
- void iMesh_getTagType(iMesh_Instance instance,
- int *tag_type, int *err);
- void iMesh_setEntSetData(iMesh_Instance instance,
- /*in*/ iBase_EntitySetHandle entity_set_handle,
- /*in*/ const char* tag_value,
- /*in*/ const int tag_value_size, int *err);
- void iMesh_setEntSetIntData(iMesh_Instance instance,
- /*in*/ const int tag_value, int *err);
- void iMesh_setEntSetDblData(iMesh_Instance instance,
- /*in*/ const double tag_value, int *err);
- void iMesh_setEntSetEHData(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle tag_value, int *err);
- void iMesh_getEntSetData(iMesh_Instance instance,
- /*inout*/ char** tag_value,
- /*inout*/ int* tag_value_allocated,
- /*inout*/ int* tag_value_size, int *err);
- void iMesh_getEntSetIntData(iMesh_Instance instance,
- int *out_data, int *err);
- void iMesh_getEntSetDblData(iMesh_Instance instance,
- double *out_data, int *err);
- void iMesh_getEntSetEHData(iMesh_Instance instance,
- iBase_EntityHandle *out_data, int *err);
- void iMesh_getAllEntSetTags(iMesh_Instance instance,
- /*out*/ iBase_TagHandle** tag_handles,
- /*out*/ int* tag_handles_allocated,
- /*out*/ int* tag_handles_size, int *err);
- void iMesh_rmvEntSetTag(iMesh_Instance instance,
- /*in*/ const iBase_TagHandle tag_handle, int *err);
- void iMesh_setVtxCoords(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle vertex_handle,
- /*in*/ const double x, /*in*/ const double y,
- /*in*/ const double z, int *err);
- void iMesh_createVtx(iMesh_Instance instance,
- /*out*/ iBase_EntityHandle* new_vertex_handle, int *err);
- void iMesh_createEnt(iMesh_Instance instance,
- /*out*/ iBase_EntityHandle* new_entity_handle,
- /*out*/ int* status, int *err);
- void iMesh_deleteEnt(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle entity_handle, int *err);
- void iMesh_getArrData(iMesh_Instance instance,
- /*inout*/ char** tag_values,
- /*inout*/int* tag_values_allocated,
- /*out*/ int* tag_values_size, int *err);
- void iMesh_getIntArrData(iMesh_Instance instance,
- /*inout*/ int** tag_values,
- /*inout*/ int* tag_values_allocated,
- void iMesh_getDblArrData(iMesh_Instance instance,
- /*inout*/ double** tag_values,
- void iMesh_getEHArrData(iMesh_Instance instance,
- /*inout*/ iBase_EntityHandle** tag_value,
- /*out*/ int* tag_value_size, int *err);
- void iMesh_setArrData(iMesh_Instance instance,
- /*in*/ const char* tag_values,
- /*in*/ const int tag_values_size, int *err);
- void iMesh_setIntArrData(iMesh_Instance instance,
- /*in*/ const int* tag_values,
- void iMesh_setDblArrData(iMesh_Instance instance,
- /*in*/ const double* tag_values,
- void iMesh_setEHArrData(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* tag_values,
- void iMesh_rmvArrTag(iMesh_Instance instance,
- void iMesh_getData(iMesh_Instance instance,
- /*inout*/ int *tag_value_allocated,
- /*out*/ int *tag_value_size, int *err);
- void iMesh_getIntData(iMesh_Instance instance,
- void iMesh_getDblData(iMesh_Instance instance,
- void iMesh_getEHData(iMesh_Instance instance,
- void iMesh_setData(iMesh_Instance instance,
- void iMesh_setIntData(iMesh_Instance instance,
- void iMesh_setDblData(iMesh_Instance instance,
- void iMesh_setEHData(iMesh_Instance instance,
- void iMesh_getAllTags(iMesh_Instance instance,
- /*inout*/ iBase_TagHandle** tag_handles,
- /*inout*/ int* tag_handles_allocated,
- void iMesh_rmvTag(iMesh_Instance instance,
- void iMesh_initEntIter(iMesh_Instance instance,
- /*out*/ iMesh_EntityIterator* entity_iterator,
- int *err);
- void iMesh_getNextEntIter(iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entity_iterator,
- /*out*/ iBase_EntityHandle* entity_handle,
- void iMesh_resetEntIter(iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entity_iterator, int *err);
- void iMesh_endEntIter(iMesh_Instance instance,
- void iMesh_getEntTopo(iMesh_Instance instance,
- int *out_topo, int *err);
- void iMesh_getEntType(iMesh_Instance instance,
- int *out_type, int *err);
- void iMesh_getVtxCoord(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle vertex_handle,
- /*out*/ double *x, /*out*/ double *y, /*out*/ double *z, int *err);
- void iMesh_getEntAdj(iMesh_Instance instance,
- /*out*/ int* adj_entity_handles_size, int *err);
- void iMesh_subtract(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_1,
- /*in*/ const iBase_EntitySetHandle entity_set_2,
- /*out*/ iBase_EntitySetHandle* result_entity_set, int *err);
- void iMesh_intersect(iMesh_Instance instance,
- void iMesh_unite(iMesh_Instance instance,
-#ifdef __cplusplus
-#endif
-#endif // ifndef IMESH_CBIND_H__
