[MOAB-dev] r1141 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Wed Jun 27 16:11:45 CDT 2007
Author: kraftche
Date: 2007-06-27 16:11:45 -0500 (Wed, 27 Jun 2007)
New Revision: 1141
Modified:
MOAB/trunk/tools/iMesh/iMesh.h
Log:
remove C-style comments in doxygen documentation
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h 2007-06-27 03:16:16 UTC (rev 1140)
+++ MOAB/trunk/tools/iMesh/iMesh.h 2007-06-27 21:11:45 UTC (rev 1141)
@@ -72,23 +72,27 @@
extern "C" {
#endif
- //! Type used to store iMesh interface handle
- /** Type used to store iMesh interface handle
+ /**\brief Type used to store iMesh interface handle
+ * Type used to store iMesh interface handle
typedef void* iMesh_Instance;
- //! Type used to store an iterator returned by iMesh
- /** Type used to store an iterator returned by iMesh
+ /**\brief Type used to store an iterator returned by iMesh
+ * Type used to store an iterator returned by iMesh
typedef void* iMesh_EntityIterator;
- //! Type used to store an array iterator returned by iMesh
- /** Type used to store an array iterator returned by iMesh
+ /**\brief Type used to store an array iterator returned by iMesh
+ * Type used to store an array iterator returned by iMesh
typedef void* iMesh_EntityArrIterator;
- //! Enumerator specifying entity topology
- /** Enumerator specifying entity topology.
+ /**\brief Enumerator specifying entity topology
+ * Enumerator specifying entity topology.
enum iMesh_EntityTopology {
iMesh_POINT = 0, /**< a general zero-dimensional entity */
@@ -112,8 +116,9 @@
* about all the topology types */
- //! Get the error type returned from the last iMesh function
- /** Get the error type returned from the last iMesh function. Value
+ /**\brief Get the error type returned from the last iMesh function
+ * Get the error type returned from the last iMesh function. Value
* returned is a member of the iBase_ErrorType enumeration.
* \param instance iMesh instance handle
* \param *error_type Error type returned from last iMesh function
@@ -123,8 +128,9 @@
/*out*/ int *error_type,
int *err);
- //! Get a description of the error returned from the last iMesh function
- /** Get a description of the error returned from the last iMesh function
+ /**\brief Get a description of the error returned from the last iMesh function
+ * Get a description of the error returned from the last iMesh function
* \param descr Pointer to a character string to be filled with a
* description of the error from the last iMesh function
@@ -136,8 +142,9 @@
int *err,
/*in*/ int descr_len);
- //! Construct a new iMesh instance
- /** Construct a new iMesh instance, using implementation-specific
+ /**\brief Construct a new iMesh instance
+ * Construct a new iMesh instance, using implementation-specific
* options
* \param options Pointer to implementation-specific options string
* \param instance Pointer to iMesh instance handle returned from function
@@ -149,16 +156,18 @@
/*out*/ int *err,
/*in*/ int options_len);
- //! Destroy an iMesh instance
- /** Destroy an iMesh instance
+ /**\brief Destroy an iMesh instance
+ * Destroy an iMesh instance
* \param instance iMesh instance to be destroyed
* \param *err Pointer to error type returned from function
void iMesh_dtor(iMesh_Instance instance,
/*out*/ int *err);
- //! Load a mesh from a file
- /** Load a mesh from a file. If entity set is specified, loaded mesh
+ /**\brief Load a mesh from a file
+ * Load a mesh from a file. If entity set is specified, loaded mesh
* is added to that set; specify zero if that is not desired.
* \param entity_set_handle Set to which loaded mesh will be added, zero
@@ -177,8 +186,9 @@
/*in*/ int name_len,
- //! Save a mesh to a file
- /** Save a mesh to a file. If entity set is specified, save only the
+ /**\brief Save a mesh to a file
+ * Save a mesh to a file. If entity set is specified, save only the
* mesh contained in that set.
* \param entity_set_handle Entity set being saved
@@ -196,8 +206,9 @@
/*in*/ const int name_len,
- //! Get handle of the root set for this instance
- /** Get handle of the root set for this instance. All mesh in
+ /**\brief Get handle of the root set for this instance
+ * Get handle of the root set for this instance. All mesh in
* this instance can be accessed from this set.
* \param root_set Pointer to set handle returned from function
@@ -207,8 +218,9 @@
/*out*/ iBase_EntitySetHandle *root_set,
/*out*/ int *err);
- //! Get the geometric dimension of mesh represented in this instance
- /** Get the geometric dimension of mesh represented in this instance
+ /**\brief Get the geometric dimension of mesh represented in this instance
+ * Get the geometric dimension of mesh represented in this instance
* \param geom_dim Pointer to dimension returned from this function
@@ -217,8 +229,9 @@
/*out*/ int *geom_dim,
/*out*/ int *err);
- //! Get the default storage order used by this implementation
- /** Get the default storage order used by this implementation. Value
+ /**\brief Get the default storage order used by this implementation
+ * Get the default storage order used by this implementation. Value
* returned is a member of the iBase_StorageOrder enumeration.
* \param order Pointer to storage order returned from function
@@ -228,8 +241,9 @@
/*out*/ int *order,
/*out*/ int *err);
- //! Get the adjacency table for this implementation
- /** Get the adjacency table for this implementation. This table
+ /**\brief Get the adjacency table for this implementation
+ * Get the adjacency table for this implementation. This table
* is a 4x4 array, with indices 0-based, where A(i,j) (i=row, j=column)
* represents the relative cost of retrieving adjacencies between
* entities of dimension i to entities of dimension j
@@ -248,8 +262,9 @@
/*out*/ int* adjacency_table_size,
/*out*/ int *err);
- //! Get the number of entities with the specified type in the instance or set
- /** Get the number of entities with the specified type in the instance
+ /**\brief Get the number of entities with the specified type in the instance or set
+ * Get the number of entities with the specified type in the instance
* or set. If entity set handle is zero, return information for instance,
* otherwise for set. Value of entity type must be from the
* iBase_EntityType enumeration. If iBase_ALL_TYPES is specified,
@@ -266,8 +281,9 @@
/*out*/ int *num_type,
/*out*/ int *err);
- //! Get the number of entities with the specified topology in the instance or set
- /** Get the number of entities with the specified topology in the instance
+ /**\brief Get the number of entities with the specified topology in the instance or set
+ * Get the number of entities with the specified topology in the instance
* otherwise for set. Value of entity topology must be from the
* iMesh_EntityTopology enumeration. If iMesh_ALL_TOPOLOGIES is specified,
@@ -284,9 +300,10 @@
/*out*/ int *num_topo,
/*out*/ int *err);
- //! Return whether entity handles have changed since last reset or since
- //! instance construction
- /** Return whether entity handles have changed since last reset or since
+ /**\brief Return whether entity handles have changed since last reset or since
+ * instance construction
+ * Return whether entity handles have changed since last reset or since
* instance construction. If non-zero value is returned, it is not
* guaranteed that a handle from before the last call to this function
* represents the same entity as the same handle value does now. If
@@ -302,8 +319,9 @@
/*out*/ int *areHandlesInvariant,
/*out*/ int *err);
- //! Return coordinates of all vertices defined in this instance or set
- /** Return coordinates of all vertices defined in this instance or set.
+ /**\brief Return coordinates of all vertices defined in this instance or set
+ * Return coordinates of all vertices defined in this instance or set.
* If non-zero set is input, return coordinates for vertices either in
* the set or contained by entities in the set. If storage order is
* a value other than iBase_UNDETERMINED, coordinates are returned with
@@ -339,8 +357,9 @@
/*out*/ int* in_entity_set_size,
/*inout*/ int* storage_order, /*out*/ int *err);
- //! Get adjacent entities as connectivity lists
- /** For a specified set handle, entity type and/or entity topology,
+ /**\brief Get adjacent entities as connectivity lists
+ * For a specified set handle, entity type and/or entity topology,
* return connectivity of adjacent entities of specified dimension.
* Connectivity is expressed as index into array of vertices returned
* by getEntities function. \em offset[i] is the index of the first
@@ -382,8 +401,9 @@
/*out*/ int* entity_topologies_size,
/*out*/ int *err);
- //! Get entities of specific type and/or topology in set or instance
- /** Get entities of specific type and/or topology in set or instance. All
+ /**\brief Get entities of specific type and/or topology in set or instance
+ * Get entities of specific type and/or topology in set or instance. All
* entities of a given type or topology are requested by specifying
* iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively. Specified type
* or topology must be a value in the iBase_EntityType or iBase_EntityTopology
@@ -408,8 +428,9 @@
/*out*/ int* entity_handles_size,
/*out*/ int *err);
- //! Get coordinates of specified vertices
- /** Get coordinates of specified vertices. If storage order is passed in
+ /**\brief Get coordinates of specified vertices
+ * Get coordinates of specified vertices. If storage order is passed in
* with a value other than iBase_UNDETERMINED, coordinates are returned
* in the specified storage order, otherwise storage order is that native
* to the implementation. Storage order of returned coordinates is also
@@ -435,8 +456,9 @@
/*out*/ int *err);
- //! Get entities adjacent to those of requested type/topology in set or instance
- /** Get entities adjacent to those of requested type/topology in set or
+ /**\brief Get entities adjacent to those of requested type/topology in set or instance
+ * Get entities adjacent to those of requested type/topology in set or
* instance. If set is specified, also returns whether each adjacent entity
* is in the set ((*in_entity_set)[i]=1 indicates that adjacent entity
* (*adj_entity_handles)[i] is in the specified set). If adjacencies for
@@ -487,9 +509,10 @@
/*out*/ int *err);
- //! Initialize an array iterator over specified entity type, topology, and
- //! size
- /** Initialize an array iterator over specified entity type, topology, and
+ /**\brief Initialize an array iterator over specified entity type, topology, and
+ * size
+ * Initialize an array iterator over specified entity type, topology, and
* size, for a specified set or instance. Iterator returned can be used
* as input to functions returning entities for the iterator. If all
* entities of a specified type and/or topology are to be iterated,
@@ -513,8 +536,9 @@
/*out*/ iMesh_EntityArrIterator* entArr_iterator,
/*out*/ int *err);
- //! Get entities contained in array iterator and increment iterator
- /** Get the entities contained in an array iterator, and increment the
+ /**\brief Get entities contained in array iterator and increment iterator
+ * Get the entities contained in an array iterator, and increment the
* iterator. Also return whether the next value of the iterator has
* any entities (if non-zero, next iterator value is the end of the
* iteration).
@@ -539,8 +563,9 @@
/*out*/ int *err);
- //! Reset the array iterator
- /** Reset the array iterator
+ /**\brief Reset the array iterator
+ * Reset the array iterator
* \param entArr_iterator Iterator to reset
@@ -550,8 +575,9 @@
/*out*/ int *err);
- //! Destroy the specified array iterator
- /** Destroy the specified array iterator
+ /**\brief Destroy the specified array iterator
+ * Destroy the specified array iterator
* \param entArr_iterator Iterator which gets destroyed
@@ -560,8 +586,9 @@
/*in*/ iMesh_EntityArrIterator entArr_iterator,
/*out*/ int *err);
- //! Get the entity topology for the specified entities
- /** Get the entity topology for the specified entities. Topologies
+ /**\brief Get the entity topology for the specified entities
+ * Get the entity topology for the specified entities. Topologies
* returned are values in the iMesh_EntityTopology enumeration.
* \param entity_handles Array of entity handles being queried
@@ -581,8 +608,9 @@
/*out*/ int *err);
- //! Get the entity type for the specified entities
- /** Get the entity type for the specified entities. Types
+ /**\brief Get the entity type for the specified entities
+ * Get the entity type for the specified entities. Types
* returned are values in the iBase_EntityType enumeration.
@@ -601,8 +629,9 @@
/*out*/ int *err);
- //! Get entities of specified type adjacent to entities
- /** Get entities of specified type adjacent to entities. Specified type
+ /**\brief Get entities of specified type adjacent to entities
+ * Get entities of specified type adjacent to entities. Specified type
* must be value in the iBase_EntityType enumeration. \em offset(i) is
* index of first entity in adjacentEntityHandles array adjacent to
* entity_handles[i].
@@ -633,8 +662,9 @@
/*out*/ int* offset_size,
/*out*/ int *err);
- //! Create an entity set
- /** Create an entity set, either ordered (isList=1) or unordered
+ /**\brief Create an entity set
+ * Create an entity set, either ordered (isList=1) or unordered
* (isList=0). Unordered entity sets can contain a given entity or
* set only once.
@@ -648,8 +678,9 @@
/*out*/ iBase_EntitySetHandle* entity_set_created,
/*out*/ int *err);
- //! Destroy an entity set
- /** Destroy an entity set
+ /**\brief Destroy an entity set
+ * Destroy an entity set
* \param entity_set Entity set to be destroyed
@@ -658,8 +689,9 @@
/*in*/ iBase_EntitySetHandle entity_set,
/*out*/ int *err);
- //! Return whether a specified set is ordered or unordered
- /** Return whether a specified set is ordered (*is_list=1) or
+ /**\brief Return whether a specified set is ordered or unordered
+ * Return whether a specified set is ordered (*is_list=1) or
* unordered (*is_list=0)
* \param entity_set Entity set being queried
@@ -671,8 +703,9 @@
/*out*/ int *is_list,
/*out*/ int *err);
- //! Get the number of entity sets contained in a set or interface
- /** Get the number of entity sets contained in a set or interface. If
+ /**\brief Get the number of entity sets contained in a set or interface
+ * Get the number of entity sets contained in a set or interface. If
* a set is input which is not the root set, num_hops indicates the
* maximum number of contained sets from entity_set_handle to one of the
* contained sets, inclusive of the contained set.
@@ -690,8 +723,9 @@
/*out*/ int *err);
- //! Get the entity sets contained in a set or interface
- /** Get the entity sets contained in a set or interface. If
+ /**\brief Get the entity sets contained in a set or interface
+ * Get the entity sets contained in a set or interface. If
@@ -715,8 +749,9 @@
/*out*/ int* contained_set_handles_size,
/*out*/ int *err);
- //! Add an entity to a set
- /** Add an entity to a set
+ /**\brief Add an entity to a set
+ * Add an entity to a set
* \param entity_handle The entity being added
* \param entity_set Pointer to the set being added to
@@ -727,9 +762,10 @@
/*inout*/ iBase_EntitySetHandle* entity_set,
/*out*/ int *err);
- //! Remove an entity from a set
- /** Remove an entity from a set
+ /**\brief Remove an entity from a set
+ * Remove an entity from a set
* \param entity_handle The entity being removed
* \param entity_set Pointer to the set being removed from
@@ -741,8 +777,9 @@
/*out*/ int *err);
- //! Add an array of entities to a set
- /** Add an array of entities to a set
+ /**\brief Add an array of entities to a set
+ * Add an array of entities to a set
* \param entity_handles Array of entities being added
* \param entity_handles_size Number of entities in entity_handles array
@@ -756,8 +793,9 @@
/*out*/ int *err);
- //! Remove an array of entities from a set
- /** Remove an array of entities from a set
+ /**\brief Remove an array of entities from a set
+ * Remove an array of entities from a set
* \param entity_handles Array of entities being remove
@@ -771,8 +809,9 @@
/*out*/ int *err);
- //! Add an entity set to a set
- /** Add an entity set to a set
+ /**\brief Add an entity set to a set
+ * Add an entity set to a set
* \param entity_set_to_add The entity set being added
* \param entity_set_handle Pointer to the set being added to
@@ -784,8 +823,9 @@
/*out*/ int *err);
- //! Remove an entity set from a set
- /** Remove an entity set from a set
+ /**\brief Remove an entity set from a set
+ * Remove an entity set from a set
* \param entity_set_to_remove The entity set being removed
* \param entity_set_handle Pointer to the set being removed from
@@ -796,8 +836,9 @@
/*inout*/ iBase_EntitySetHandle* entity_set_handle,
/*out*/ int *err);
- //! Return whether an entity is contained in another set
- /** Return whether an entity is contained (*is_contained=1) or not
+ /**\brief Return whether an entity is contained in another set
+ * Return whether an entity is contained (*is_contained=1) or not
* contained (*is_contained=0) in another set
* \param containing_entity_set Entity set being queried
@@ -812,8 +853,9 @@
/*out*/ int *is_contained,
/*out*/ int *err);
- //! Return whether an entity set is contained in another set
- /** Return whether a set is contained (*is_contained=1) or not contained
+ /**\brief Return whether an entity set is contained in another set
+ * Return whether a set is contained (*is_contained=1) or not contained
* (*is_contained=0) in another set
@@ -828,8 +870,9 @@
/*out*/ int *err);
- //! Add parent/child links between two sets
- /** Add parent/child links between two sets. Makes parent point to child
+ /**\brief Add parent/child links between two sets
+ * Add parent/child links between two sets. Makes parent point to child
* and child point to parent.
* \param parent_entity_set Pointer to parent set
@@ -841,8 +884,9 @@
/*inout*/ iBase_EntitySetHandle* child_entity_set,
/*out*/ int *err);
- //! Remove parent/child links between two sets
- /** Remove parent/child links between two sets.
+ /**\brief Remove parent/child links between two sets
+ * Remove parent/child links between two sets.
* \param child_entity_set Pointer to child set
@@ -853,8 +897,9 @@
/*out*/ int *err);
- //! Return whether two sets are related by parent/child links
- /** Return whether two sets are related (*is_child=1) or not (*is_child=0)
+ /**\brief Return whether two sets are related by parent/child links
+ * Return whether two sets are related (*is_child=1) or not (*is_child=0)
* by parent/child links
@@ -868,8 +913,9 @@
/*out*/ int *is_child,
/*out*/ int *err);
- //! Get the number of child sets linked from a specified set
- /** Get the number of child sets linked from a specified set. If num_hops
+ /**\brief Get the number of child sets linked from a specified set
+ * Get the number of child sets linked from a specified set. If num_hops
* is non-zero, this represents the maximum hops from entity_set to any
* child in the count.
@@ -885,8 +931,9 @@
/*out*/ int *num_child,
/*out*/ int *err);
- //! Get the number of parent sets linked from a specified set
- /** Get the number of parent sets linked from a specified set. If num_hops
+ /**\brief Get the number of parent sets linked from a specified set
+ * Get the number of parent sets linked from a specified set. If num_hops
* parent in the count.
@@ -902,8 +949,9 @@
/*out*/ int *num_parent,
/*out*/ int *err);
- //! Get the child sets linked from a specified set
- /** Get the child sets linked from a specified set. If num_hops
+ /**\brief Get the child sets linked from a specified set
+ * Get the child sets linked from a specified set. If num_hops
* child.
@@ -926,8 +974,9 @@
/*out*/ int* entity_set_handles_size,
/*out*/ int *err);
- //! Get the parent sets linked from a specified set
- /** Get the parent sets linked from a specified set. If num_hops
+ /**\brief Get the parent sets linked from a specified set
+ * Get the parent sets linked from a specified set. If num_hops
* parent.
@@ -950,8 +999,9 @@
/*out*/ int *err);
- //! Set coordinates for an array of vertices
- /** Set coordinates for an array of vertices. Specified storage
+ /**\brief Set coordinates for an array of vertices
+ * Set coordinates for an array of vertices. Specified storage
* order must be either iBase_INTERLEAVED or iBase_BLOCKED, and
* indicates order of x, y, and z coordinates in coordinate array.
@@ -972,8 +1022,9 @@
/*out*/ int *err);
- //! Create an array of new vertices at specified coordinates
- /** Create an array of new vertices at specified coordinates. Value of
+ /**\brief Create an array of new vertices at specified coordinates
+ * Create an array of new vertices at specified coordinates. Value of
* storage_order must be either iBase_INTERLEAVED or iBase_BLOCKED.
* \param num_verts Number of new vertices to be created
@@ -1000,8 +1051,9 @@
/*out*/ int *err);
- //! Create an array of new entities with specified lower-order topology
- /** Create an array of new entities with specified lower-order topology.
+ /**\brief Create an array of new entities with specified lower-order topology
+ * Create an array of new entities with specified lower-order topology.
* Specified new_entity_topology must be value in iMesh_EntityTopology
* enumeration. Values return in status array must be values in the
* iBase_CreationStatus enumeration.
@@ -1036,8 +1088,9 @@
/*out*/ int *err);
- //! Delete specified entities
- /** Delete specified entities
+ /**\brief Delete specified entities
+ * Delete specified entities
* \param entity_handles Array of entity handles to be deleted
* \param entity_handles_size Number of entities in array to be deleted
@@ -1049,8 +1102,9 @@
/*out*/ int *err);
- //! Create a tag with specified name, size, and type
- /** Create a tag with specified name, size, and type. Tag size is in
+ /**\brief Create a tag with specified name, size, and type
+ * Create a tag with specified name, size, and type. Tag size is in
* units of size of tag_type data types. Value input for tag type must be
* value in iBase_TagType enumeration.
@@ -1071,8 +1125,9 @@
/*in*/ const int tag_name_len);
- //! Destroy a tag
- /** Destroy a tag. If forced is non-zero and entities still have values
+ /**\brief Destroy a tag
+ * Destroy a tag. If forced is non-zero and entities still have values
* set for this tag, tag is deleted anyway and those values disappear,
* otherwise tag is not deleted.
@@ -1086,8 +1141,9 @@
/*in*/ const int forced,
/*out*/ int *err);
- //! Get the name for a given tag handle
- /** Get the name for a given tag handle
+ /**\brief Get the name for a given tag handle
+ * Get the name for a given tag handle
* \param tag_handle Tag handle being queried
* \param name Pointer to character string to store name returned from
@@ -1101,8 +1157,9 @@
/*out*/ int *err,
/*in*/ int name_len);
- //! Get size of a tag in units of numbers of tag data type
- /** Get size of a tag in units of numbers of tag data type
+ /**\brief Get size of a tag in units of numbers of tag data type
+ * Get size of a tag in units of numbers of tag data type
* \param tag_handle Handle of tag being queried
* \param tag_size Pointer to tag size returned from function
@@ -1113,8 +1170,9 @@
/*out*/ int *tag_size,
/*out*/ int *err);
- //! Get size of a tag in units of bytes
- /** Get size of a tag in units of bytes
+ /**\brief Get size of a tag in units of bytes
+ * Get size of a tag in units of bytes
@@ -1125,8 +1183,9 @@
/*out*/ int *err);
- //! Get a the handle of an existing tag with the specified name
- /** Get a the handle of an existing tag with the specified name
+ /**\brief Get a the handle of an existing tag with the specified name
+ * Get a the handle of an existing tag with the specified name
* \param tag_name Name of tag being queried
* \param tag_handle Pointer to tag handle returned from function
@@ -1139,8 +1198,9 @@
/*out*/ int *err,
int tag_name_len);
- //! Get the data type of the specified tag handle
- /** Get the data type of the specified tag handle. Tag type is a value in
+ /**\brief Get the data type of the specified tag handle
+ * Get the data type of the specified tag handle. Tag type is a value in
* the iBase_TagType enumeration.
* \param tag_handle Handle for the tag being queried
@@ -1152,8 +1212,9 @@
/*out*/ int *tag_type,
/*out*/ int *err);
- //! Set a tag value of arbitrary type on an entity set
- /** Set a tag value of arbitrary type on an entity set. Tag data is
+ /**\brief Set a tag value of arbitrary type on an entity set
+ * Set a tag value of arbitrary type on an entity set. Tag data is
* passed as char* type,
* but really represents pointer to arbitrary data.
@@ -1171,8 +1232,9 @@
/*out*/ int *err);
- //! Set a tag value of integer type on an entity set
- /** Set a tag value of integer type on an entity set.
+ /**\brief Set a tag value of integer type on an entity set
+ * Set a tag value of integer type on an entity set.
* \param entity_set Entity set on which tag is being set
* \param tag_handle Tag being set on an entity set
@@ -1186,8 +1248,9 @@
/*out*/ int *err);
- //! Set a tag value of double type on an entity set
- /** Set a tag value of double type on an entity set.
+ /**\brief Set a tag value of double type on an entity set
+ * Set a tag value of double type on an entity set.
@@ -1201,8 +1264,9 @@
/*out*/ int *err);
- //! Set a tag value of entity handle type on an entity set
- /** Set a tag value of entity handle type on an entity set.
+ /**\brief Set a tag value of entity handle type on an entity set
+ * Set a tag value of entity handle type on an entity set.
@@ -1216,8 +1280,9 @@
/*out*/ int *err);
- //! Get the value of a tag of arbitrary type on an entity set
- /** Get the value of a tag of arbitrary type on an entity set. Tag data
+ /**\brief Get the value of a tag of arbitrary type on an entity set
+ * Get the value of a tag of arbitrary type on an entity set. Tag data
* is passed back as char* type, but really represents arbitrary data.
* \param entity_set_handle Entity set on which tag is being set
@@ -1235,8 +1300,9 @@
/*inout*/ int* tag_value_size,
/*out*/ int *err);
- //! Get the value of a tag of integer type on an entity set
- /** Get the value of a tag of integer type on an entity set.
+ /**\brief Get the value of a tag of integer type on an entity set
+ * Get the value of a tag of integer type on an entity set.
@@ -1249,8 +1315,9 @@
/*out*/ int *out_data,
/*out*/ int *err);
- //! Get the value of a tag of double type on an entity set
- /** Get the value of a tag of double type on an entity set.
+ /**\brief Get the value of a tag of double type on an entity set
+ * Get the value of a tag of double type on an entity set.
@@ -1263,8 +1330,9 @@
/*out*/ double *out_data,
/*out*/ int *err);
- //! Get the value of a tag of entity handle type on an entity set
- /** Get the value of a tag of entity handle type on an entity set.
+ /**\brief Get the value of a tag of entity handle type on an entity set
+ * Get the value of a tag of entity handle type on an entity set.
@@ -1277,8 +1345,9 @@
/*out*/ iBase_EntityHandle *out_data,
/*out*/ int *err);
- //! Get all the tags associated with a specified entity set
- /** Get all the tags associated with a specified entity set
+ /**\brief Get all the tags associated with a specified entity set
+ * Get all the tags associated with a specified entity set
* \param entity_set_handle Entity being queried
* \param *tag_handles Pointer to array of tag_handles returned from
@@ -1295,8 +1364,9 @@
/*out*/ int* tag_handles_size,
/*out*/ int *err);
- //! Remove a tag value from an entity set
- /** Remove a tag value from an entity set
+ /**\brief Remove a tag value from an entity set
+ * Remove a tag value from an entity set
* \param entity_set_handle Entity set from which tag is being removed
* \param tag_handle Tag handle of tag being removed
@@ -1307,8 +1377,9 @@
/*in*/ const iBase_TagHandle tag_handle,
/*out*/ int *err);
- //! Set coordinates for a vertex
- /** Set coordinates for a vertex.
+ /**\brief Set coordinates for a vertex
+ * Set coordinates for a vertex.
* \param vertex_handle vertex handle being set
* \param x x coordinate being set
@@ -1322,8 +1393,9 @@
/*in*/ const double z,
/*out*/ int *err);
- //! Create a new vertex at specified coordinates
- /** Create a new vertex at specified coordinates.
+ /**\brief Create a new vertex at specified coordinates
+ * Create a new vertex at specified coordinates.
* \param x x coordinate of new vertex
* \param y y coordinate of new vertex
@@ -1338,8 +1410,9 @@
/*out*/ iBase_EntityHandle* new_vertex_handle,
/*out*/ int *err);
- //! Create a new entity with specified lower-order topology
- /** Create a new entity with specified lower-order topology.
+ /**\brief Create a new entity with specified lower-order topology
+ * Create a new entity with specified lower-order topology.
* enumeration. Value returned as status must be a value in the
@@ -1362,8 +1435,9 @@
/*out*/ int* status,
/*out*/ int *err);
- //! Delete specified entity
- /** Delete specified entity
+ /**\brief Delete specified entity
+ * Delete specified entity
* \param entity_handle Entity to be deleted
@@ -1372,8 +1446,9 @@
/*in*/ iBase_EntityHandle entity_handle,
/*out*/ int *err);
- //! Get tag values of arbitrary type for an array of entities
- /** Get tag values of arbitrary type for an array of entities. Tag data
+ /**\brief Get tag values of arbitrary type for an array of entities
+ * Get tag values of arbitrary type for an array of entities. Tag data
* is returned as char* type, but really represents arbitrary data.
* \param entity_handles Entity array on which tag is being set
@@ -1394,8 +1469,9 @@
/*out*/ int* tag_values_size,
/*out*/ int *err);
- //! Get tag values of integer type for an array of entities
- /** Get tag values of integer type for an array of entities.
+ /**\brief Get tag values of integer type for an array of entities
+ * Get tag values of integer type for an array of entities.
@@ -1415,8 +1491,9 @@
/*out*/ int *err);
- //! Get tag values of double type for an array of entities
- /** Get tag values of double type for an array of entities.
+ /**\brief Get tag values of double type for an array of entities
+ * Get tag values of double type for an array of entities.
@@ -1436,8 +1513,9 @@
/*out*/ int *err);
- //! Get tag values of entity handle type for an array of entities
- /** Get tag values of entity handle type for an array of entities.
+ /**\brief Get tag values of entity handle type for an array of entities
+ * Get tag values of entity handle type for an array of entities.
@@ -1457,8 +1535,9 @@
/*out*/ int* tag_value_size,
/*out*/ int *err);
- //! Set tag values of arbitrary type on an array of entities
- /** Set tag values of arbitrary type on an array of entities. Tag data is
+ /**\brief Set tag values of arbitrary type on an array of entities
+ * Set tag values of arbitrary type on an array of entities. Tag data is
* passed as char* type, but really represents pointer to arbitrary data.
@@ -1476,8 +1555,9 @@
/*in*/ const int tag_values_size,
/*out*/ int *err);
- //! Set tag values of integer type on an array of entities
- /** Set tag values of integer type on an array of entities.
+ /**\brief Set tag values of integer type on an array of entities
+ * Set tag values of integer type on an array of entities.
@@ -1494,8 +1574,9 @@
/*out*/ int *err);
- //! Set tag values of double type on an array of entities
- /** Set tag values of double type on an array of entities.
+ /**\brief Set tag values of double type on an array of entities
+ * Set tag values of double type on an array of entities.
@@ -1512,8 +1593,9 @@
/*out*/ int *err);
- //! Set tag values of entity handle type on an array of entities
- /** Set tag values of entity handle type on an array of entities.
+ /**\brief Set tag values of entity handle type on an array of entities
+ * Set tag values of entity handle type on an array of entities.
@@ -1531,8 +1613,9 @@
/*out*/ int *err);
- //! Remove a tag value from an array of entities
- /** Remove a tag value from an array of entities
+ /**\brief Remove a tag value from an array of entities
+ * Remove a tag value from an array of entities
* \param entity_handles Entity from which tag is being removed
* \param entity_handles_size Number of entities in entity array
@@ -1545,8 +1628,9 @@
/*out*/ int *err);
- /** Get the value of a tag of arbitrary type on an entity. Tag data
+ * Get the value of a tag of arbitrary type on an entity. Tag data
* \param entity_handle Entity on which tag is being set
@@ -1564,8 +1648,9 @@
/*out*/ int *tag_value_size,
/*out*/ int *err);
- /** Get the value of a tag of integer type on an entity.
+ * Get the value of a tag of integer type on an entity.
@@ -1578,8 +1663,9 @@
/*out*/ int *err);
- /** Get the value of a tag of double type on an entity.
+ * Get the value of a tag of double type on an entity.
@@ -1592,8 +1678,9 @@
/*out*/ int *err);
- /** Get the value of a tag of entity handle type on an entity.
+ * Get the value of a tag of entity handle type on an entity.
@@ -1606,8 +1693,9 @@
/*out*/ int *err);
- /** Set a tag value of arbitrary type on an entity. Tag data is
+ * Set a tag value of arbitrary type on an entity. Tag data is
@@ -1623,8 +1711,9 @@
/*in*/ const int tag_value_size,
/*out*/ int *err);
- /** Set a tag value of integer type on an entity.
+ * Set a tag value of integer type on an entity.
@@ -1637,8 +1726,9 @@
/*in*/ const int tag_value,
/*out*/ int *err);
- /** Set a tag value of double type on an entity.
+ * Set a tag value of double type on an entity.
@@ -1652,8 +1742,9 @@
/*in*/ const double tag_value,
/*out*/ int *err);
- /** Set a tag value of entity handle type on an entity.
+ * Set a tag value of entity handle type on an entity.
@@ -1666,8 +1757,9 @@
/*in*/ const iBase_EntityHandle tag_value,
/*out*/ int *err);
- //! Get all the tags associated with a specified entity handle
- /** Get all the tags associated with a specified entity handle
+ /**\brief Get all the tags associated with a specified entity handle
+ * Get all the tags associated with a specified entity handle
* \param entity_handle Entity being queried
@@ -1684,8 +1776,9 @@
/*out*/ int *err);
* \param entity_handle Entity from which tag is being removed
@@ -1696,8 +1789,9 @@
/*out*/ int *err);
- //! Initialize an iterator over specified entity type, topology, and size
- /** Initialize an iterator over specified entity type, topology, and size,
+ /**\brief Initialize an iterator over specified entity type, topology, and size
+ * Initialize an iterator over specified entity type, topology, and size,
* for a specified set or instance. Iterator returned can be used as input
* to functions returning the entity for the iterator. If all entities of
* a specified type and/or topology are to be iterated, specify
@@ -1718,8 +1812,9 @@
/*out*/ iMesh_EntityIterator* entity_iterator,
/*out*/ int *err);
- //! Get entity corresponding to an iterator and increment iterator
- /** Get the entity corresponding to an array iterator, and increment the
+ /**\brief Get entity corresponding to an iterator and increment iterator
+ * Get the entity corresponding to an array iterator, and increment the
* an entity (if non-zero, next iterator value is the end of the
* iteration).
@@ -1737,8 +1832,9 @@
/*out*/ int *has_data,
/*out*/ int *err);
- //! Reset the iterator
- /** Reset the iterator
+ /**\brief Reset the iterator
+ * Reset the iterator
* \param entity_iterator Iterator to reset
@@ -1747,8 +1843,9 @@
/*in*/ iMesh_EntityIterator entity_iterator,
/*out*/ int *err);
- //! Destroy the specified iterator
- /** Destroy the specified iterator
+ /**\brief Destroy the specified iterator
+ * Destroy the specified iterator
* \param entity_iterator Iterator which gets destroyed
@@ -1757,8 +1854,9 @@
/*out*/ int *err);
- //! Get the entity topology for the specified entity
- /** Get the entity topology for the specified entity. Topology
+ /**\brief Get the entity topology for the specified entity
+ * Get the entity topology for the specified entity. Topology
* returned is a value in the iMesh_EntityTopology enumeration.
* \param entity_handle Entity handle being queried
@@ -1770,8 +1868,9 @@
/*out*/ int *out_topo,
/*out*/ int *err);
- //! Get the entity type for the specified entity
- /** Get the entity type for the specified entity. Type returned is a value
+ /**\brief Get the entity type for the specified entity
+ * Get the entity type for the specified entity. Type returned is a value
* in the iBase_EntityType enumeration.
@@ -1783,8 +1882,9 @@
/*out*/ int *out_type,
/*out*/ int *err);
- //! Get coordinates of specified vertex
- /** Get coordinates of specified vertex.
+ /**\brief Get coordinates of specified vertex
+ * Get coordinates of specified vertex.
* \param vertex_handle Mesh vertex being queried
* \param *x Pointer to x coordinate returned from function
@@ -1797,8 +1897,9 @@
/*out*/ double *x, /*out*/ double *y, /*out*/ double *z,
/*out*/ int *err);
- //! Get entities of specified type adjacent to an entity
- /** Get entities of specified type adjacent to an entity. Specified type
+ /**\brief Get entities of specified type adjacent to an entity
+ * Get entities of specified type adjacent to an entity. Specified type
@@ -1819,8 +1920,9 @@
/*out*/ int* adj_entity_handles_size,
/*out*/ int *err);
- //! Subtract contents of one entity set from another
- /** Subtract contents of one entity set from another
+ /**\brief Subtract contents of one entity set from another
+ * Subtract contents of one entity set from another
* \param entity_set_1 Entity set from which other set is being subtracted
* \param entity_set_2 Entity set being subtracted from other set
@@ -1833,8 +1935,9 @@
/*out*/ iBase_EntitySetHandle* result_entity_set,
/*out*/ int *err);
- //! Intersect contents of one entity set with another
- /** Intersect contents of one entity set with another
+ /**\brief Intersect contents of one entity set with another
+ * Intersect contents of one entity set with another
* \param entity_set_1 Entity set being intersected with another
* \param entity_set_2 Entity set being intersected with another
@@ -1847,8 +1950,9 @@
/*out*/ int *err);
- //! Unite contents of one entity set with another
- /** Unite contents of one entity set with another
+ /**\brief Unite contents of one entity set with another
+ * Unite contents of one entity set with another
* \param entity_set_1 Entity set being united with another
* \param entity_set_2 Entity set being united with another
