[MOAB-dev] r1222 - in MOAB/trunk: . test/obb tools/dagmc
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jul 23 14:20:35 CDT 2007
Author: kraftche
Date: 2007-07-23 14:20:35 -0500 (Mon, 23 Jul 2007)
New Revision: 1222
Modified:
   MOAB/trunk/MBOrientedBoxTreeTool.cpp
   MOAB/trunk/MBOrientedBoxTreeTool.hpp
   MOAB/trunk/test/obb/obb_test.cpp
   MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
Change algorithm for closest-point and point-in-volume.
  o Old closest point function did:
      - find closest point on boundary
      - calculate distance d between input point and closest point
      - return all points within d+epsilon of input point
  o Old closest point function very susceptable to rounding error
    if input point is far away (d+epsilon == d for large values of d).
  o New closest point function just returns the closest single point
  o New addtional function to intersect sphere with triangles
  o New point-in-volume test does:
     - get closest point
     - get any triangles within epsilon of closest point by doing
        sphere-intersect-trinagles where center == closest point
        and radius == epsilon.
This method is better because
  o eliminates potential source of rounding error
  o greatly simplifies point-in-volume because the result set
    of triangles are all topologically adjacent - no need to
    search larger set of tris from old closest-point method
    for a subset that are adjacent
This method might be slower because of the second tree traversal.
However, it may not be because the closest-point query is a little
faster and the sphere-intersect-triangles query is much quicker
than either closest-point query.
Fixes bug from Paul (tube_1e-6.h5m).
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-07-20 18:24:11 UTC (rev 1221)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-07-23 19:20:35 UTC (rev 1222)
@@ -480,7 +480,107 @@
   return MB_SUCCESS;
+/********************** General Sphere/Triangel Intersection ***************/
+MBErrorCode MBOrientedBoxTreeTool::sphere_intersect_triangles(
+                                        const double* center_v,
+                                        double radius,
+                                        MBEntityHandle tree_root,
+                                        std::vector<MBEntityHandle>& facets_out,
+                                        std::vector<MBEntityHandle>* sets_out )
+  const double radsqr = radius * radius;
+  MBOrientedBox b;
+  MBErrorCode rval;
+  MBRange sets;
+  const MBCartVect center(center_v);
+  MBCartVect closest, coords[3];
+  const MBEntityHandle* conn;
+  int num_conn;
+#ifndef MB_OBB_USE_VECTOR_QUERIES
+  MBRange tris;
+  MBRange::const_iterator t;
+#else
+  std::vector<MBEntityHandle> tris;
+  std::vector<MBEntityHandle>::const_iterator t;
+#endif
+  std::vector<MBEntityHandle> stack, children;
+  stack.reserve(60);
+  stack.push_back(tree_root);
+  stack.push_back(0);
+  while (!stack.empty()) {
+    MBEntityHandle surf = stack.back(); stack.pop_back();
+    MBEntityHandle node = stack.back(); stack.pop_back();
+    if (!surf && sets_out) {
+      rval = get_moab_instance()->get_entities_by_type( node, MBENTITYSET, sets );
+      if (!sets.empty())
+        surf = sets.front();
+      // check if sphere intersects box
+    rval = box( node, b );
+    if (MB_SUCCESS != rval)
+      return rval;
+    b.closest_location_in_box( center, closest );
+    closest -= center;
+    if ((closest % closest) > radsqr)
+      continue;
+      // push child boxes on stack
+    children.clear();
+    rval = instance->get_child_meshsets( node, children );
+      return rval;
+    if (!children.empty()) {
+      assert(children.size() == 2);
+      stack.push_back( children[0] );
+      stack.push_back( surf );
+      stack.push_back( children[1] );
+      continue;
+      // if leaf, intersect sphere with triangles
+# ifdef MB_OBB_USE_TYPE_QUERIES
+    rval = get_moab_instance()->get_entities_by_type( node, MBTRI, tris );
+# else
+    rval = get_moab_instance()->get_entities_by_handle( node, tris );
+# endif
+#else
+#endif
+      return rval;
+    for (t = tris.begin(); t != tris.end(); ++t) {
+      rval = get_moab_instance()->get_connectivity( *t, conn, num_conn, true );
+        return rval;
+      if (num_conn != 3)
+        continue;
+      rval = get_moab_instance()->get_coords( conn, num_conn, coords[0].array() );
+        return rval;
+      MBGeomUtil::closest_location_on_tri( center, coords, closest );
+      if ((closest % closest) <= radsqr &&
+          std::find(facets_out.begin(),facets_out.end(),*t) == facets_out.end()) {
+        facets_out.push_back( *t );
+        if (sets_out)
+          sets_out->push_back( surf );
+  return MB_SUCCESS;
 /********************** General Ray/Tree and Ray/Triangel Intersection ***************/
@@ -843,53 +943,134 @@
 /********************** Closest Point code ***************/
+struct MBOBBTreeCPFrame {
+  MBOBBTreeCPFrame( double d, MBEntityHandle n, MBEntityHandle s )
+    : dist_sqr(d), node(n), mset(s) {}
+  double dist_sqr;
+  MBEntityHandle node;
+  MBEntityHandle mset;
 MBErrorCode MBOrientedBoxTreeTool::closest_to_location(
                                      const double* point,
                                      MBEntityHandle root,
-                                     double tolerance,
                                      double* point_out,
                                      MBEntityHandle& facet_out,
                                      MBEntityHandle* set_out )
-  std::vector<MBEntityHandle> facets(1), sets;
-  MBErrorCode rval = closest_to_location( point, root, tolerance, facets, set_out ? &sets : 0 );
-  if (MB_SUCCESS != rval)
-    return rval;
-  if (facets.empty())
-    return MB_ENTITY_NOT_FOUND;
-  facet_out = facets.front();
-  if (set_out)
-    *set_out = sets.front();
+  MBErrorCode rval;
+  const MBCartVect loc( point );
+  double smallest_dist_sqr = std::numeric_limits<double>::max();
-  const MBEntityHandle* conn;
-  int len;
-  rval = instance->get_connectivity( facet_out, conn, len, true );
-    return rval;
+  MBEntityHandle current_set = 0;
+  MBRange sets;
+  std::vector<MBEntityHandle> children(2);
+  std::vector<double> coords;
+  std::vector<MBOBBTreeCPFrame> stack;
+  stack.push_back( MBOBBTreeCPFrame(0.0, root, current_set) );
-  std::vector<MBCartVect> coords( len );
-  rval = instance->get_coords( conn, len, coords[0].array() );
-    return rval;
+  while( !stack.empty() ) {
+      // pop from top of stack
+    MBEntityHandle node = stack.back().node;
+    double dist_sqr = stack.back().dist_sqr;
+    current_set = stack.back().mset;
+    stack.pop_back();
+      // If current best result is closer than the box, skip this tree node.
+    if (dist_sqr > smallest_dist_sqr)
+      continue;
+      // Check if this node has a set associated with it
+    if (set_out && !current_set) {
+      sets.clear();
+      rval = instance->get_entities_by_type( node, MBENTITYSET, sets );
+        return rval;
+      if (!sets.empty()) {
+        if (sets.size() != 1)
+          return MB_MULTIPLE_ENTITIES_FOUND;
+        current_set = sets.front();
+      // Get child boxes
+    children.clear();
+      return rval;
+      // if not a leaf node
+      if (children.size() != 2)
+        // get boxes
+      MBOrientedBox box1, box2;
+      rval = box( children[0], box1 );
+      if (MB_SUCCESS != rval) return rval;
+      rval = box( children[1], box2 );
+        // get distance from each box
+      MBCartVect pt1, pt2;
+      box1.closest_location_in_box( loc, pt1 );
+      box2.closest_location_in_box( loc, pt2 );
+      pt1 -= loc;
+      pt2 -= loc;
+      const double dsqr1 = pt1 % pt1;
+      const double dsqr2 = pt2 % pt2;
+        // push children on tree such that closer one is on top
+      if (dsqr1 < dsqr2) {
+        stack.push_back( MBOBBTreeCPFrame(dsqr2, children[1], current_set ) );
+        stack.push_back( MBOBBTreeCPFrame(dsqr1, children[0], current_set ) );
+      else {
+    else { // LEAF NODE
+      MBRange facets;
+      rval = instance->get_entities_by_dimension( node, 2, facets );
+        return rval;
+      int len;
+      MBCartVect tmp, diff;
+      for (MBRange::iterator i = facets.begin(); i != facets.end(); ++i) {
+        rval = instance->get_connectivity( *i, conn, len, true );
+          return rval;
+        coords.resize(3*len);
+        rval = instance->get_coords( conn, len, &coords[0] );
+          return rval;
+        if (len == 3)
+          MBGeomUtil::closest_location_on_tri( loc, (MBCartVect*)(&coords[0]), tmp );
+        else
+          MBGeomUtil::closest_location_on_polygon( loc, (MBCartVect*)(&coords[0]), len, tmp );
+        diff = tmp - loc;
+        dist_sqr = diff % diff;
+        if (dist_sqr < smallest_dist_sqr) {
+          smallest_dist_sqr = dist_sqr;
+          facet_out = *i;
+          tmp.get( point_out );
+          if (set_out)
+            *set_out = current_set;
+    } // LEAF NODE
-  if (len == 3)
-    MBGeomUtil::closest_location_on_tri( *reinterpret_cast<const MBCartVect*>(point),
-                             &coords[0],
-                             *reinterpret_cast<MBCartVect*>(point_out) );
-  else
-    MBGeomUtil::closest_location_on_polygon( *reinterpret_cast<const MBCartVect*>(point),
-                                 &coords[0], len,
   return MB_SUCCESS;
-struct MBOBBTreeCPFrame {
-  MBOBBTreeCPFrame( double d, MBEntityHandle n, MBEntityHandle s )
-    : dist_sqr(d), node(n), mset(s) {}
-  double dist_sqr;
-  MBEntityHandle node;
-  MBEntityHandle mset;
 MBErrorCode MBOrientedBoxTreeTool::closest_to_location( const double* point,
Modified: MOAB/trunk/MBOrientedBoxTreeTool.hpp
--- MOAB/trunk/MBOrientedBoxTreeTool.hpp	2007-07-20 18:24:11 UTC (rev 1221)
+++ MOAB/trunk/MBOrientedBoxTreeTool.hpp	2007-07-23 19:20:35 UTC (rev 1222)
@@ -203,7 +203,6 @@
     MBErrorCode closest_to_location( const double* point,
-                                     double tolerance,
                                      double* point_out,
                                      MBEntityHandle* set_out = 0);
@@ -221,6 +220,23 @@
                                      std::vector<MBEntityHandle>* sets_out = 0 );
+    /**\brief Find facets intersected by a sphere
+     * Find facets intersected by a spherical volume.
+     *\param center     Sphere center
+     *\param radius     Sphere radius
+     *\param tree_root  Root of OBB tree
+     *\param facets_out List of triangles intersecting sphere
+     *\param sets_out   If not null, sets owning facets are appended to this
+     *                  list in an order corresponding to the entries in
+     *                  facets_out.
+    MBErrorCode sphere_intersect_triangles( const double* center,
+                                        double radius,
+                                        std::vector<MBEntityHandle>* sets_out = 0 );
     /**\brief Get oriented box at node in tree
      * Get the oriented box for a node in an oriented bounding box tree.
Modified: MOAB/trunk/test/obb/obb_test.cpp
--- MOAB/trunk/test/obb/obb_test.cpp	2007-07-20 18:24:11 UTC (rev 1221)
+++ MOAB/trunk/test/obb/obb_test.cpp	2007-07-23 19:20:35 UTC (rev 1222)
@@ -1295,7 +1295,6 @@
       // find closest point usnig tree
     rval = tool.closest_to_location( points[i].array(),
                                      root_set,
-                                     tolerance,
                                      t_result.array(),
                                      t_tri,
                                      set_ptr );
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-20 18:24:11 UTC (rev 1221)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-23 19:20:35 UTC (rev 1222)
@@ -371,164 +371,60 @@
                              double x, double y, double z,
                              int& result )
+  MBErrorCode rval;
   const double epsilon = moabMCNPTolerance;
     // Get OBB Tree for volume
   assert(volume - setOffset < rootSets.size());
   MBEntityHandle root = rootSets[volume - setOffset];
-    // Get closest triangles in volume
+    // Get closest point in triangulation
+  const MBCartVect point(x,y,z);
+  MBEntityHandle facet;
+  MBCartVect closest, diff;
+  rval = obbTree.closest_to_location( point.array(), root, closest.array(), facet );
+    // Check for on-boundary case
+  diff = closest - point;
+  if (diff%diff <= epsilon*epsilon) {
+    result = -1;
+    // Get triangles at closest point
   static std::vector<MBEntityHandle> tris, surfs;
   tris.clear();
   surfs.clear();
-  const MBCartVect point(x,y,z);
-  MBErrorCode rval = obbTree.closest_to_location( point.array(), root, epsilon, tris, &surfs );
+  rval = obbTree.sphere_intersect_triangles( closest.array(), epsilon, root, tris, &surfs );
-    // Get sense of each surface wrt volume
-  std::vector<int> senses( surfs.size() );
-  rval = surface_sense( volume, surfs.size(), &surfs[0], &senses[0] );
-  if (MB_SUCCESS != rval) return rval;
-    // Get closest point on each triangle, and group triangles
-    // by intersection type
-  std::vector<int> edge_tris, vertex_tris;
-    // Get corrected normal, closest point and topolgocal closest for each triangle
-  std::vector<MBCartVect> normals( tris.size() ), closest( tris.size() );
-  std::vector<int> topo( tris.size() );
+    // One-triangle case : determine if point is above or below triangle
-  int len;
-  MBCartVect coords[3];
-  for (unsigned i = 0; i < tris.size(); ++i) {
-      // volume tree shouldn't contain non-manifold surfaces
-    assert(senses[i]);
-    rval = moab_instance()->get_connectivity( tris[i], conn, len );
+  int len, sense;
+  MBCartVect coords[3], normal;
+  if (tris.size() == 1) {
+    rval = moab_instance()->get_connectivity( tris.front(), conn, len );
     if (MB_SUCCESS != rval || len != 3)
       return MB_FAILURE;
     rval = moab_instance()->get_coords( conn, len, coords[0].array() );
-      return rval;
-    MBGeomUtil::closest_location_on_tri( point, coords, epsilon, closest[i], topo[i] );
+    rval = surface_sense( volume, 1, &surfs.front(), &sense );
+      // get triangle normal
     coords[1] -= coords[0];
     coords[2] -= coords[0];
-    normals[i] = senses[i] * coords[1] * coords[2];
-    // If within tolerance of triangle, then return that point is on boundary
-  if ((point - closest[0]).length() < epsilon) {
-    result = -1;
+    normal = sense * coords[1] * coords[2];
+      // compare relative sense
+    result = (normal % (point - closest) < 0.0);
     return MB_SUCCESS;
-    // if only one, then return
-  if (tris.size() == 1) {
-      // Ignore the possibility of being in the plane of the
-      // triangle.  If parallel to one triangle, should have
-      // at least one other triangle.
-    result = (normals[0] % (closest[0] - point) > 0.0);
-    return MB_SUCCESS;
+    // many triangle case : determine if closest point is convexity or concavity
-    // If we found any triangle for which the closest point was in
-    // the interior, just use that one
-  std::vector<int>::iterator ii = std::find( topo.begin(), topo.end(), 6 );
-  if (ii != topo.end()) {
-    int idx = ii - topo.begin();
-    result = (normals[idx] % (closest[idx] - point) > 0.0);
-    // Otherwise if we found any triangle for which the
-    // closest point was at an edge, find it's neighbor and use the pair
-  for (ii = topo.begin(); ii != topo.end() && *ii < 3; ++ii);
-  if (ii != topo.end()) // found one
-    unsigned idx1 = ii - topo.end();
-    int idx2 = -1;
-    MBEntityHandle edge[2];
-    moab_instance()->get_connectivity( tris[idx1], conn, len, true );
-    edge[0] = conn[*ii - 3];
-    edge[1] = conn[(*ii - 2) % 3];
-      if (i == idx1)
-        continue;
-      moab_instance()->get_connectivity( tris[i], conn, len, true );
-      int j;
-      for (j = 0; j < 3; ++j)
-        if (conn[j] == edge[0])
-          if (conn[(j+1)%3] == edge[1] || conn[(j+2)%3] == edge[1])
-            break;
-      if (j < 3) {
-        idx2 = i;
-        break;
-    if (idx2 < 0) { // if no adjacent triangle
-      assert(false);
-      result = (normals[idx1] % (closest[idx1] - point) > 0.0);
-      // Check if inside or outside of both facets first.
-      // This avoids potential rounding/accuracy issues
-      // when testing for convexity/concavity if the facets
-      // are near co-planer, and handles the special case
-      // where both facets are exactly coplanar.
-    const double dot1 = normals[idx1] % (closest[idx1] - point);
-    const double dot2 = normals[idx2] % (closest[idx2] - point);
-    const bool inside1 = dot1 > -std::numeric_limits<double>::epsilon();
-    const bool inside2 = dot2 > -std::numeric_limits<double>::epsilon();
-    const bool outside1 = dot1 < std::numeric_limits<double>::epsilon();
-    const bool outside2 = dot2 < std::numeric_limits<double>::epsilon();
-    if (inside1 && inside2)
-      result = 1;
-    else if (outside1 && outside2)
-      result = 0;
-    else {
-        // Edge is at a concavity if the projection of the normal of
-        // triangle A into the plane of triangle B points into triangle
-        // B.  It is a convexity if it points out of triangle B (from the
-        // shared edge).  This test can be reduced to checking the sign of
-        // dot product of the normal of triangle A with any vector pointing
-        // into triangle B from the shared edge.
-        // Get triangle coordinates
-      moab_instance()->get_connectivity( tris[idx2], conn, len, true );
-      moab_instance()->get_coords( conn, len, coords[0].array() );
-        // Get a vector from edge end point to opposite vertex
-      const MBCartVect vect2 = coords[(topo[idx2] - 1) % 3] - coords[topo[idx2]];
-      result = (vect2 % normals[idx1] >= 0.0); // true if a concavity
-        result = inside1 || inside2;
-    // Otherwise pick a vertex that the point was closest to remove
-    // any triangles from lists that are not adjacent to that vertex.
-  assert( topo[0] < 3 ); // if here, must be closest to vertex
-  rval = moab_instance()->get_connectivity( tris[0], conn, len );
-  if (MB_SUCCESS != rval || len != 3)
-    return MB_FAILURE;
-  const MBEntityHandle closest_vert = conn[topo[0]];
-  unsigned w = 1;
-  for (unsigned r = 1; r < tris.size(); ++r) {
-    assert( topo[r] < 3 ); // if here, must be closest to vertex
-    moab_instance()->get_connectivity( tris[r], conn, len );
-    if (conn[topo[r]] == closest_vert) {
-      tris[w] = tris[r];
-      surfs[w] = surfs[r];
-      normals[w] = normals[r];
-      ++w;
-  tris.resize(w);
-  surfs.resize(w);
-  normals.resize(w);
     // use algorithm from:
     // (referance)
     // to determine inside vs. outside.
@@ -536,20 +432,40 @@
     // first find single triangle for which all other triangles are to
     // one side.
   bool some_above, some_below;
-  MBCartVect vertcoords, closestcoords;
-  moab_instance()->get_coords( &closest_vert, 1, closestcoords.array() );
     some_above = some_below = false;
+    rval = moab_instance()->get_connectivity( tris[i], conn, len );
+    if (MB_SUCCESS != rval || len != 3)
+      return MB_FAILURE;
+    rval = moab_instance()->get_coords( conn, len, coords[0].array() );
+    coords[1] -= coords[0];
+    coords[2] -= coords[0];
+    closest = coords[0];
+    const double norm_len_sqr = normal % normal;
     for (unsigned j = 0; j < tris.size(); ++j) {
       if (j == i)
         continue;
-      moab_instance()->get_connectivity( tris[j], conn, len );
+      rval = moab_instance()->get_connectivity( tris[j], conn, len );
+        return rval;
       for (int k = 0; k < len; ++k) {
-        moab_instance()->get_coords( conn+k, 1, vertcoords.array() );
-        const double dot = normals[i] % (closestcoords - vertcoords);
-        if (dot * dot / (normals[i] % normals[i]) > epsilon * epsilon) {
-          if (dot < 0.0)
+        const double dot = normal % (coords[k] - closest);
+        if (dot * dot / norm_len_sqr > epsilon * epsilon) {
+          if (dot > 0.0)
             some_above = true;
           else
             some_below = true;
@@ -560,7 +476,7 @@
       // All triangles are roughly co-planar: if we're inside of
       // one then we're inside of all.
     if (!some_above && !some_below) {
-      result = (normals[i] % (closestcoords - point)) > 0.0;
+      result = (normal % (closest - point)) > 0.0;
       return MB_SUCCESS;
       // All other triangles to one side of this triangle:
@@ -586,9 +502,6 @@
 // detemine distance to nearest surface
 MBErrorCode DagMC::closest_to_location( MBEntityHandle volume, double* coords, double& result)
-  const double epsilon = moabMCNPTolerance;
@@ -597,7 +510,7 @@
   const MBCartVect point(coords);
   MBCartVect nearest;
   MBEntityHandle facet_out;
-  MBErrorCode rval = obbTree.closest_to_location( point.array(), root, epsilon, nearest.array(), facet_out );
+  MBErrorCode rval = obbTree.closest_to_location( point.array(), root, nearest.array(), facet_out );
   // calculate distance between point and nearest facet
