[MOAB-dev] r1210 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jul 17 16:22:01 CDT 2007
Author: kraftche
Date: 2007-07-17 16:22:01 -0500 (Tue, 17 Jul 2007)
New Revision: 1210
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/Makefile.am
   MOAB/trunk/tools/dagmc/cgm2moab.cc
   MOAB/trunk/tools/dagmc/main.cc
Log:
o Change DagMC and other tools to use new method for initializing ACIS in CGM
  - now works when using libicubitNN.so w/out CGM ACIS source or headers.
o Fix build of test_geom w/ CGM support enabled
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-17 21:20:35 UTC (rev 1209)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-17 21:22:01 UTC (rev 1210)
@@ -6,9 +6,8 @@
 #include "MBGeomUtil.hpp"
 #ifdef CGM
+#include "InitCGMA.hpp"
 #include "CGMApp.hpp"
-#include "AcisQueryEngine.hpp"
-#include "AcisModifyEngine.hpp"
 #include "CubitDefines.h"
 #include "GeometryQueryTool.hpp"
 #include "CubitVector.hpp"
@@ -762,9 +761,8 @@
 #ifdef CGM
       // initialize cgm
-    CGMApp::instance()->startup( 0, NULL );
-    AcisQueryEngine::instance();
-    AcisModifyEngine::instance();
+    InitCGMA::initialize_cgma();
+    InitCGMA::initialize_engine("ACIS");
     CGMApp::instance()->attrib_manager()->set_all_auto_read_flags(true);
     CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags(true);
     CubitStatus s = GeometryQueryTool::instance()->import_solid_model( scfile.c_str(), "ACIS_SAT");
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am	2007-07-17 21:20:35 UTC (rev 1209)
+++ MOAB/trunk/tools/dagmc/Makefile.am	2007-07-17 21:22:01 UTC (rev 1210)
@@ -36,6 +36,6 @@
 TESTS = test_geom
 check_PROGRAMS = $(TESTS)
 test_geom_SOURCES = test_geom.cc
-test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la
+test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LTFLAGS)  $(CGM_LIBS_LINK)
Modified: MOAB/trunk/tools/dagmc/cgm2moab.cc
--- MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-07-17 21:20:35 UTC (rev 1209)
+++ MOAB/trunk/tools/dagmc/cgm2moab.cc	2007-07-17 21:22:01 UTC (rev 1210)
@@ -1,6 +1,3 @@
-#include "CGMApp.hpp"
 #include "GeometryQueryEngine.hpp"
 #include "ModelQueryEngine.hpp"
Modified: MOAB/trunk/tools/dagmc/main.cc
--- MOAB/trunk/tools/dagmc/main.cc	2007-07-17 21:20:35 UTC (rev 1209)
+++ MOAB/trunk/tools/dagmc/main.cc	2007-07-17 21:22:01 UTC (rev 1210)
@@ -1,6 +1,5 @@
 #include "MBCore.hpp"
 #include "cgm2moab.hpp"
@@ -114,9 +113,8 @@
     // Initialize CGM
   if (actuate_attribs) {
     CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( actuate_attribs );
     CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( actuate_attribs );
