[MOAB-dev] r1203 - in MOAB/trunk: . tools/dagmc
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jul 13 11:03:18 CDT 2007
Author: kraftche
Date: 2007-07-13 11:03:18 -0500 (Fri, 13 Jul 2007)
New Revision: 1203
Modified:
   MOAB/trunk/MBOrientedBox.cpp
   MOAB/trunk/MBOrientedBoxTreeTool.cpp
   MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
add checks and warnings for zero-facet surfaces
Modified: MOAB/trunk/MBOrientedBox.cpp
--- MOAB/trunk/MBOrientedBox.cpp	2007-07-13 15:27:21 UTC (rev 1202)
+++ MOAB/trunk/MBOrientedBox.cpp	2007-07-13 16:03:18 UTC (rev 1203)
@@ -110,9 +110,12 @@
 #if MB_ORIENTED_BOX_UNIT_VECTORS
   this->length = len;
-  axis[0] /= len[0];
-  axis[1] /= len[1];
-  axis[2] /= len[2];
+  if (len[0] > 0.0)
+    axis[0] /= len[0];
+  if (len[1] > 0.0)
+    axis[1] /= len[1];
+  if (len[2] > 0.0)
+    axis[2] /= len[2];
 #endif
 #if MB_ORIENTED_BOX_OUTER_RADIUS
@@ -371,6 +374,12 @@
                                                 CovarienceData& data,
                                                 const MBRange& vertices )
+  if (data.area <= 0.0) {
+    MBCartVect axis[3] = { MBCartVect(0.), MBCartVect(0.), MBCartVect(0.) };
+    result = MBOrientedBox( axis, MBCartVect(0.) );
+    return MB_SUCCESS;
     // get center from sum
   result.center = data.center / data.area;
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-07-13 15:27:21 UTC (rev 1202)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp	2007-07-13 16:03:18 UTC (rev 1203)
@@ -212,9 +212,15 @@
   MBOrientedBox box;
   MBErrorCode rval;
-  rval = MBOrientedBox::compute_from_2d_cells( box, instance, entities );
-  if (MB_SUCCESS != rval)
-    return rval;
+  if (entities.empty()) {
+    box = MBOrientedBox( axis, MBCartVect(0.) );
+  else {
+    rval = MBOrientedBox::compute_from_2d_cells( box, instance, entities );
+    if (MB_SUCCESS != rval)
+      return rval;
     // create an entity set for the tree node
   rval = instance->create_meshset( settings.set_options, set );
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-13 15:27:21 UTC (rev 1202)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-13 16:03:18 UTC (rev 1203)
@@ -1473,6 +1473,8 @@
     rval = moab_instance()->get_entities_by_dimension( *i, 2, tris );
       return rval;
+    if (tris.empty())
+      std::cerr << "WARNING: Surface " << get_entity_id(*i) << " has no facets." << std::endl;
     rval = obbTree.build( tris, root );
       return rval;
