[MOAB-dev] r1193 - in MOAB/trunk: . tools/dagmc
    kraftche at mcs.anl.gov
    Tue Jul 10 17:59:37 CDT 2007
Author: kraftche
Date: 2007-07-10 17:59:36 -0500 (Tue, 10 Jul 2007)
New Revision: 1193
Added:
   MOAB/trunk/tools/dagmc/test_geom.cc
Modified:
   MOAB/trunk/configure.in
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/DagMC.hpp
   MOAB/trunk/tools/dagmc/Makefile.am
Log:
o Fix building of DagMC w/out CGM
o Fix function w/ no return val if building w/out CGM
o Make DagMC construct OBB tree if one doesn't already exist,
   regardless of input file type.
o Fix broken point-in-volume test: clear static lists in each call
o Use smarter algorithm for ponit-in-volume test to avoid
  slow solid-angle algorithm when input location is closest
  to a vertex.
o Add unit tests for geometry functions in DagMC
NOTE: Unit test for DagMC::fire_ray fails due to a known issue.
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in	2007-07-10 17:31:22 UTC (rev 1192)
+++ MOAB/trunk/configure.in	2007-07-10 22:59:36 UTC (rev 1193)
@@ -664,8 +664,8 @@
   AC_SUBST(CGM_DIR)
   AC_SUBST(CGM_CONFIG_OPTIONS)
 fi
+AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
 #                           iMesh Babel
@@ -758,9 +758,6 @@
     AC_MSG_WARN([Count not find VTK.  Build will FAIL!!! Try \"--with-VTK=DIR\"])
   fi
 fi
-if test "x$CGM_MISSING" = "xyes"; then
-  AC_MSG_WARN([cgm2moab/dagmc build will fail!  CGM not found!])
-fi
 if test "x$HAVE_HDF5" = "xno"; then
   AC_MSG_WARN([
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-10 17:31:22 UTC (rev 1192)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-07-10 22:59:36 UTC (rev 1193)
@@ -366,10 +366,8 @@
 // point is inside or outside of the volume.  If the point is closest to
 // an edge joining two facets, then the point is inside the volume if
 // that edge is at a concavity wrt the volume.  If the point is closest
-// to a vertex in the facetting, then if the normals of the facets are
-// sufficiently close to each other as simple inside/outside test is
-// used for each facet.  If not, the (very) slow spherical-area method
-// is used.
+// to a vertex in the facetting, it relies on the fact that the closest
+// vertex cannot be a saddle: it must be a strict concavity or convexity.
 MBErrorCode DagMC::point_in_volume( MBEntityHandle volume,
                              double x, double y, double z,
                              int& result )
@@ -382,6 +380,8 @@
     // Get closest triangles in volume
   static std::vector<MBEntityHandle> tris, surfs;
+  tris.clear();
+  surfs.clear();
   const MBCartVect point(x,y,z);
   MBErrorCode rval = obbTree.closest_to_location( point.array(), root, epsilon, tris, &surfs );
   if (MB_SUCCESS != rval) return rval;
@@ -508,45 +508,79 @@
     return MB_SUCCESS;
-    // Otherwise test triangles about each vertex that the point was closest to
-    // First get unique list of vertices
-  std::vector<MBEntityHandle> vertices( tris.size() ), uvertices;
-  for (unsigned i = 0; i < tris.size(); ++i) {
-    assert( (unsigned)(topo[i]) < 3);
-    moab_instance()->get_connectivity( tris[1], conn, len, true );
-    vertices.push_back( conn[topo[i]] );
+    // Otherwise pick a vertex that the point was closest to remove
+    // any triangles from lists that are not adjacent to that vertex.
+  assert( topo[0] < 3 ); // if here, must be closest to vertex
+  rval = moab_instance()->get_connectivity( tris[0], conn, len );
+  if (MB_SUCCESS != rval || len != 3)
+    return MB_FAILURE;
+  const MBEntityHandle closest_vert = conn[topo[0]];
+  unsigned w = 1;
+  for (unsigned r = 1; r < tris.size(); ++r) {
+    assert( topo[r] < 3 ); // if here, must be closest to vertex
+    moab_instance()->get_connectivity( tris[r], conn, len );
+    if (conn[topo[r]] == closest_vert) {
+      tris[w] = tris[r];
+      surfs[w] = surfs[r];
+      normals[w] = normals[r];
+      ++w;
-  uvertices = vertices;
-  std::sort( uvertices.begin(), uvertices.end() );
-  uvertices.erase( std::unique( uvertices.begin(), uvertices.end() ), uvertices.end() );
+  tris.resize(w);
+  surfs.resize(w);
+  normals.resize(w);
-    // Now for each vertex, test if we are inside or outside all the triangles
-  for (unsigned i = 0; i < uvertices.size(); ++i) {
-    bool inside_all = true, outside_all = true;
+    // use algorithm from:
+    // (referance)
+    // to determine inside vs. outside.
+    // first find single triangle for which all other triangles are to
+    // one side.
+  bool some_above, some_below;
+  MBCartVect vertcoords, closestcoords;
+  moab_instance()->get_coords( &closest_vert, 1, closestcoords.array() );
+  for (unsigned i = 0; i < tris.size(); ++i) {
+    some_above = some_below = false;
     for (unsigned j = 0; j < tris.size(); ++j) {
-      if (vertices[j] != uvertices[i])
+      if (j == i)
         continue;
-      const double dot = normals[j] % (closest[j] - point);
-      if (dot < -std::numeric_limits<double>::epsilon())
-        inside_all = false;
-      if (dot > std::numeric_limits<double>::epsilon())
-        outside_all = false;
+      moab_instance()->get_connectivity( tris[j], conn, len );
+      for (int k = 0; k < len; ++k) {
+        moab_instance()->get_coords( conn+k, 1, vertcoords.array() );
+        const double dot = normals[i] % (closestcoords - vertcoords);
+        if (dot * dot / (normals[i] % normals[i]) > epsilon * epsilon) {
+          if (dot < 0.0)
+            some_above = true;
+          else
+            some_below = true;
-    if (inside_all) {
-      result = 1;
+      // All triangles are roughly co-planar: if we're inside of
+      // one then we're inside of all.
+    if (!some_above && !some_below) {
+      result = (normals[i] % (closestcoords - point)) > 0.0;
       return MB_SUCCESS;
-    else if (outside_all) {
-      result = 0;
+      // All other triangles to one side of this triangle:
+    else if (some_above != some_below) {
+        // If all other triangles are above this one (some_above == true),
+        // then the vertex is a concavity so the input point is inside.
+        // If all other triangles are below this one (some_above == false),
+        // then the vertex is a convexity and the input point must be outside.
+      result = some_above;
       return MB_SUCCESS;
-    // If this far, then closest to only vertices in the facetting
-    // and cannot determine inside/outside at any vertex.
-    // Use the (very) slow method
+    // If we got here, then something's wrong somewhere.
+    // We appear to be closest to a "saddle" vertex in the
+    // triangulation.  That shoudn't be possible (must be
+    // closer to at least one of the adjacent triagles than
+    // to the saddle vertex.)
+  assert(false /*shouldn't be here*/);
   return point_in_volume_slow( volume, x, y, z, result );
@@ -787,7 +821,8 @@
     return rval;
   // Build OBB trees for everything, but only if we only read geometry
-  if (is_geom) {
+  // Changed to build obb tree if tree does not already exist. -- JK
+  if (!have_obb_tree()) {
     rval = build_obbs(surfs, vols);
     if (MB_SUCCESS != rval) {
       std::cerr << "Failed to build obb." << std::endl;
@@ -815,6 +850,15 @@
   return MB_SUCCESS;
+bool DagMC::have_obb_tree()
+  MBRange entities;
+  MBErrorCode rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET,
+                                                           &obbTag, 0, 1,
+                                                           entities );
+  return MB_SUCCESS == rval && !entities.empty();
 MBEntityHandle DagMC::entity_by_id( int dimension, int id )
   assert(0 <= dimension && 3 >= dimension);
@@ -1319,6 +1363,8 @@
   return MB_SUCCESS;
 #endif
+#else
 #endif
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp	2007-07-10 17:31:22 UTC (rev 1192)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp	2007-07-10 22:59:36 UTC (rev 1193)
@@ -135,6 +135,8 @@
                                 double &len);
 private:
+  bool have_obb_tree();
   MBTag get_tag( const char* name, int size, MBTagType store, MBDataType type,
                  bool create_if_missing = true);
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am	2007-07-10 17:31:22 UTC (rev 1192)
+++ MOAB/trunk/tools/dagmc/Makefile.am	2007-07-10 22:59:36 UTC (rev 1193)
@@ -3,26 +3,28 @@
 @CGM_CONFIG_OPTIONS@
 DEFS = $(DEFINES)
-INCLUDES += -I$(top_srcdir) -I$(top_builddir) $(CGM_INCLUDES)
-CPPFLAGS += $(CGM_CPPFLAGS)
+INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+lib_LTLIBRARIES = libdagmc.la
+libdagmc_la_SOURCES = DagMC.cpp
+libdagmc_la_includedir = $(includedir)
+libdagmc_la_include_HEADERS = cgm2moab.hpp cubfile.h DagMC.hpp
+if HAVE_CGM
+INCLUDES += $(CGM_INCLUDES)
+CPPFLAGS += $(CGM_CPPFLAGS) -DCGM
 CXXFLAGS += $(CGM_CXXFLAGS)
+libdagmc_la_SOURCES += cgm2moab.cc
 bin_PROGRAMS = cgm2moab
 cgm2moab_SOURCES = main.cc cubfile.c
 cgm2moab_LDFLAGS = $(CGM_LIBS_LTFLAGS)
-libdagmc_la_SOURCES = \
-	cgm2moab.cc DagMC.cpp
-libMOAB_la_include_HEADERS = cgm2moab.hpp cubfile.h DagMC.hpp
-lib_LTLIBRARIES = libdagmc.la
-libMOAB_la_includedir = $(includedir)
-LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LINK)
+cgm2moab_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LINK)
 cgm2moab_DEPENDENCIES = libdagmc.la $(top_builddir)/libMOAB.la
 dist_man1_MANS = cgm2moab.man
+endif
 # Automake doesn't seem to have a directory defined for
 # platform-dependent data (or include) files. So put
@@ -31,3 +33,9 @@
 cfgdir = $(libdir)
 cfg_DATA = dagmc.make
+TESTS = test_geom
+check_PROGRAMS = $(TESTS)
+test_geom_SOURCES = test_geom.cc
+test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la
Added: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc	                        (rev 0)
+++ MOAB/trunk/tools/dagmc/test_geom.cc	2007-07-10 22:59:36 UTC (rev 1193)
@@ -0,0 +1,489 @@
+#include "MBInterface.hpp"
+#include "MBCore.hpp"
+#include "DagMC.hpp"
+#include "MBTagConventions.hpp"
+#include <vector>
+#include <iostream>
+#include <math.h>
+#include <limits>
+#define CHKERR if (MB_SUCCESS != rval) return rval
+const double ROOT2 = 1.4142135623730951;
+// Create file containing geometry for 2x2x2 cube
+// centered at origin and having a convex +Z face
+// (center of face at origin).
+MBErrorCode write_geometry( const char* output_file_name );
+MBErrorCode test_ray_fire( DagMC& );
+MBErrorCode test_point_in_volume( DagMC& );
+MBErrorCode test_measure_volume( DagMC& );
+MBErrorCode test_measure_area( DagMC& );
+MBErrorCode test_surface_sense( DagMC& );
+  MBErrorCode rval;
+  MBCore moab_instance;
+  MBInterface& moab = moab_instance;
+    // Define a 2x2x2 cube centered at orgin
+    // with concavity in +Z face.
+  const double coords[] = {
+    1, -1, -1,
+    1,  1, -1,
+   -1,  1, -1,
+   -1, -1, -1,
+    1, -1,  1,
+    1,  1,  1,
+   -1,  1,  1,
+   -1, -1,  1,
+    0,  0,  0 };
+  const int connectivity[] = {
+    0, 3, 1,  3, 2, 1, // -Z
+    0, 1, 4,  5, 4, 1, // +X
+    1, 2, 6,  6, 5, 1, // +Y
+    6, 2, 3,  7, 6, 3, // -X
+    0, 4, 3,  7, 3, 4, // -Y
+    4, 5, 8,  5, 6, 8, // +Z
+    6, 7, 8,  7, 4, 8  // +Z
+  const unsigned tris_per_surf[] = { 2, 2, 2, 2, 2, 4 };
+    // Create the geometry
+  const unsigned num_verts = sizeof(coords) / (3*sizeof(double));
+  const unsigned num_tris = sizeof(connectivity) / (3*sizeof(int));
+  const unsigned num_surfs = sizeof(tris_per_surf) / sizeof(unsigned);
+  MBEntityHandle verts[num_verts], tris[num_tris], surfs[num_surfs];
+  for (unsigned i = 0; i < num_verts; ++i) {
+    rval = moab.create_vertex( coords + 3*i, verts[i] );
+    CHKERR;
+  for (unsigned i = 0; i < num_tris; ++i) {
+    const MBEntityHandle conn[] = { verts[connectivity[3*i  ]],
+                                    verts[connectivity[3*i+1]],
+                                    verts[connectivity[3*i+2]] };
+    rval = moab.create_element( MBTRI, conn, 3, tris[i] );
+    CHKERR;
+    // create CAD topology
+  MBEntityHandle* tri_iter = tris;
+  for (unsigned i = 0; i < num_surfs; ++i) {
+    rval = moab.create_meshset( MESHSET_SET, surfs[i] );
+    CHKERR;
+    rval = moab.add_entities( surfs[i], tri_iter, tris_per_surf[i] );
+    CHKERR;
+    tri_iter += tris_per_surf[i];
+  MBTag dim_tag, id_tag, sense_tag;
+  rval = moab.tag_create( GEOM_DIMENSION_TAG_NAME,
+                          sizeof(int),
+                          MB_TAG_SPARSE,
+                          MB_TYPE_INTEGER,
+                          dim_tag, 0, true );
+  CHKERR;
+  rval = moab.tag_create( GLOBAL_ID_TAG_NAME,
+                          sizeof(int),
+                          MB_TAG_DENSE,
+                          MB_TYPE_INTEGER,
+                          id_tag, 0, true );
+  CHKERR;
+  rval = moab.tag_create( "GEOM_SENSE_2",
+                           2*sizeof(MBEntityHandle),
+                           MB_TAG_SPARSE,
+                           MB_TYPE_HANDLE,
+                           sense_tag, 0, true );
+  CHKERR;
+  std::vector<int> dims( num_surfs, 2 );
+  rval = moab.tag_set_data( dim_tag, surfs, num_surfs, &dims[0] );
+  CHKERR;
+  std::vector<int> ids( num_surfs );
+  for (size_t i = 0; i < ids.size(); ++i) ids[i] = i+1;
+  rval = moab.tag_set_data( id_tag, surfs, num_surfs, &ids[0] );
+  CHKERR;
+  MBEntityHandle volume;
+  rval = moab.create_meshset( MESHSET_SET, volume );
+  CHKERR;
+    rval = moab.add_parent_child( volume, surfs[i] );
+    CHKERR;
+  std::vector<MBEntityHandle> senses( 2*num_surfs, 0 );
+  for (size_t i = 0; i < senses.size(); i += 2)
+    senses[i] = volume;
+  rval = moab.tag_set_data( sense_tag, surfs, num_surfs, &senses[0] );
+  CHKERR;
+  const int three = 3;
+  const int one = 1;
+  rval = moab.tag_set_data( dim_tag, &volume, 1, &three );
+  CHKERR;
+  rval = moab.tag_set_data( id_tag, &volume, 1, &one );
+  CHKERR;
+  rval = moab.write_mesh( output_file_name );
+  CHKERR;
+  return MB_SUCCESS;
+static bool run_test( std::string name, int argc, char* argv[] )
+  if (argc == 1)
+    return true;
+  for (int i = 1; i < argc; ++i)
+    if (name == argv[i])
+      return true;
+  return false;
+#define RUN_TEST(A) do { \
+  if (run_test( #A, argc, argv )) { \
+    std::cout << #A << "... " << std::endl; \
+    if (MB_SUCCESS != A ( dagmc ) ) { \
+      ++errors; \
+} while(false)
+int main( int argc, char* argv[] )
+  MBErrorCode rval;
+  const char* filename = "test_geom.h5m";
+  rval = write_geometry( filename );
+  if (MB_SUCCESS != rval) {
+    remove( filename );
+    std::cerr << "Failed to create input file: " << filename << std::endl;
+    return 1;
+  DagMC& dagmc = *DagMC::instance();
+  rval = dagmc.load_file_and_init( filename, strlen(filename), 0, 0 );
+    std::cerr << "Failed to initialize DagMC." << std::endl;
+    return 2;
+  int errors = 0;
+  RUN_TEST( test_ray_fire );
+  RUN_TEST( test_point_in_volume );
+  RUN_TEST( test_measure_volume );
+  RUN_TEST( test_measure_area );
+  RUN_TEST( test_surface_sense );
+  return errors;
+MBErrorCode test_surface_sense( DagMC& dagmc )
+  MBErrorCode rval;
+  MBInterface& moab = *dagmc.moab_instance();
+  MBTag dim_tag = dagmc.geom_tag();
+  MBRange surfs, vols;
+  const int two = 2, three = 3;
+  const void* ptrs[] = { &two, &three };
+  rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, ptrs, 1, surfs );
+  CHKERR;
+  rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, ptrs+1, 1, vols );
+  CHKERR;
+  if (vols.size() != 1) {
+    std::cerr << "ERROR: Expected 1 volume in input, found " << vols.size() << std::endl;
+  if (surfs.size() != 6) {
+    std::cerr << "ERROR: Expected 6 surfaces in input, found " << surfs.size() << std::endl;
+  for (MBRange::iterator i = surfs.begin(); i != surfs.end(); ++i) {
+    int sense = 0;
+    rval = dagmc.surface_sense( vols.front(), 1, &*i, &sense );
+    if (MB_SUCCESS != rval || sense != 1) {
+      std::cerr << "ERROR: Expected 1 for surface sense, got " << sense << std::endl;
+MBErrorCode test_measure_volume( DagMC& dagmc )
+  MBErrorCode rval;
+  MBRange vols;
+  const void* ptr = &three;
+  rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, &ptr, 1, vols );
+  CHKERR;
+    // input file is 2x2x2 cube with convexity in +Z face that touches the origin.
+    // expected volume is 8 (2x2x2) less the volume of the pyrimid concavity
+  double result;
+  const double vol = 2*2*2 - 1*4./3;
+  rval = dagmc.measure_volume( vols.front(), result );
+  CHKERR;
+  if (fabs(result - vol) > std::numeric_limits<double>::epsilon()) {
+    std::cerr << "ERROR: Expected " << vol << " as measure of volume, got " << result << std::endl;
+MBErrorCode test_measure_area( DagMC& dagmc )
+  MBErrorCode rval;
+  MBRange surfs;
+  const int two = 2;
+  const void* ptr = &two;
+  rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, &ptr, 1, surfs );
+  CHKERR;
+  int ids[6];
+  rval = moab.tag_get_data( dagmc.id_tag(), surfs, ids );
+  CHKERR;
+    // expect area of 4 for all faces except face 6.
+    // face 6 should have area == 4*sqrt(2)
+  MBRange::iterator iter = surfs.begin();
+  for (unsigned i = 0; i < 6; ++i, ++iter) {
+    double expected = 4.0;
+    if (ids[i] == 6)
+      expected *= ROOT2;
+    double result;
+    rval = dagmc.measure_area( *iter, result );
+    CHKERR;
+    if (fabs(result - expected) > std::numeric_limits<double>::epsilon()) {
+      std::cerr << "ERROR: Expected area of surface " << ids[i] << " to be "
+                << expected << ".  Got " << result << std::endl;
+struct ray_fire {
+  int prev_surf;
+  double origin[3], direction[3];
+  int hit_surf;
+  double distance;
+MBErrorCode test_ray_fire( DagMC& dagmc )
+  const struct ray_fire tests[] = {
+  /* src    origin               direction                 dest dist */
+    { 1, { 0.0, 0.0, -1. }, { -1.0/ROOT2, 0.0, 1.0/ROOT2 }, 4, ROOT2 },
+    { 1, { 0.0, 0.0, -1. }, {  1.0/ROOT2, 0.0, 1.0/ROOT2 }, 2, ROOT2 },
+    { 1, { 0.0, 0.0, -1. }, {  0.0, 1.0/ROOT2, 1.0/ROOT2 }, 3, ROOT2 },
+    { 1, { 0.5, 0.5, -1. }, {  0.0, 0.0, 1.0 },             6, 3     },
+    { 2, { 1.0, 0.0, 0.5 }, { -1.0, 0.0, 0.0 },             6, 1     } };
+  MBErrorCode rval;
+  CHKERR;
+  CHKERR;
+  int ids[6];
+  CHKERR;
+  MBEntityHandle surf[6];
+  std::copy( surfs.begin(), surfs.end(), surf );
+  const int num_test = sizeof(tests) / sizeof(tests[0]);
+  for (int i = 0; i < num_test; ++i) {
+    int* ptr = std::find( ids, ids+6, tests[i].prev_surf );
+    int idx = ptr - ids;
+    if (idx >= 6) {
+      std::cerr << "Surface " << tests[i].prev_surf << " not found." << std::endl;
+    const MBEntityHandle src_surf = surf[idx];
+    ptr = std::find( ids, ids+6, tests[i].hit_surf );
+    idx = ptr - ids;
+    if (idx >= 6) {
+      std::cerr << "Surface " << tests[i].hit_surf << " not found." << std::endl;
+    const MBEntityHandle hit_surf = surf[idx];
+    double dist;
+    MBEntityHandle result;
+    rval = dagmc.ray_fire( vols.front(),
+                           src_surf,
+                           2,
+                           tests[i].direction[0],
+                           tests[i].direction[1],
+                           tests[i].direction[2],
+                           tests[i].origin[0],
+                           tests[i].origin[1],
+                           tests[i].origin[2],
+                           HUGE_VAL,
+                           dist, result );
+    if (result != hit_surf || fabs(dist - tests[i].distance) > 1e-6) {
+      MBEntityHandle *p = std::find( surf, surf+6, result );
+      idx = p - surf;
+      int id = idx > 5 ? 0 : ids[idx];
+      std::cerr << "Rayfire test failed for " << std::endl
+                << "\t ray from (" << tests[i].origin[0]
+                << ", " << tests[i].origin[1] << ", "
+                << tests[i].origin[2] << ") going ["
+                << tests[i].direction[0] << ", "
+                << tests[i].direction[1] << ", "
+                << tests[i].direction[2] << "]" << std::endl
+                << "\t Beginning on surface " << tests[i].prev_surf << std::endl
+                << "\t Expected to hit surface " << tests[i].hit_surf << " after "
+                << tests[i].distance << " units." << std::endl
+                << "\t Actually hit surface " << id << " after " << dist << " units."
+                << std::endl;
+struct PointInVol { double coords[3]; int result; };
+MBErrorCode test_point_in_volume( DagMC& dagmc )
+  const char* const NAME_ARR[] = { "Boundary", "Outside", "Inside" };
+  const char* const* names = NAME_ARR + 1;
+  const int INSIDE = 1, OUTSIDE = 0, BOUNDARY = -1;
+  const struct PointInVol tests[] = {
+    { { 0.0, 0.0, 0.5 }, OUTSIDE },
+    { { 0.0, 0.0,-0.5 }, INSIDE  },
+    { { 0.7, 0.0, 0.0 }, INSIDE  },
+    { {-0.7, 0.0, 0.0 }, INSIDE  },
+    { { 0.0,-0.7, 0.0 }, INSIDE  },
+    { { 1.1, 1.1, 1.1 }, OUTSIDE },
+    { {-1.1, 1.1, 1.1 }, OUTSIDE },
+    { {-1.1,-1.1, 1.1 }, OUTSIDE },
+    { { 1.1,-1.1, 1.1 }, OUTSIDE },
+    { { 1.1, 1.1,-1.1 }, OUTSIDE },
+    { {-1.1, 1.1,-1.1 }, OUTSIDE },
+    { {-1.1,-1.1,-1.1 }, OUTSIDE },
+    { { 1.1,-1.1,-1.1 }, OUTSIDE },
+    { { 1.0, 0.0, 0.0 }, BOUNDARY},
+    { {-1.0, 0.0, 0.0 }, BOUNDARY},
+    { { 0.0, 1.0, 0.0 }, BOUNDARY},
+    { { 0.0,-1.0, 0.0 }, BOUNDARY},
+    { { 0.0, 0.0, 0.0 }, BOUNDARY},
+    { { 0.0, 0.0,-1.0 }, BOUNDARY} };
+  MBErrorCode rval;
+  MBRange vols;
+  CHKERR;
+  const MBEntityHandle vol = vols.front();
+    int result;
+    rval = dagmc.point_in_volume( vol,
+                                  tests[i].coords[0],
+                                  tests[i].coords[1],
+                                  tests[i].coords[2],
+                                  result );
+    CHKERR;
+    if (result != tests[i].result) {
+      std::cerr << "ERROR testing point_in_volume[" << i << "]:" << std::endl
+                << "\tExpected " << names[tests[i].result]
+                << " for (" << tests[i].coords[0] << ", "
+                << tests[i].coords[1] << ", " << tests[i].coords[2]
+                << ").  Got " << names[result] << std::endl;
+      // point_in_volume_slow doesn't to boundary.
+    if (tests[i].result == BOUNDARY)
+      continue;
+    rval = dagmc.point_in_volume_slow( vol,
+                                  result );
+    CHKERR;
+      std::cerr << "ERROR testing point_in_volume_slow[" << i << "]:" << std::endl
