[MOAB-dev] r1500 - in MOAB/trunk: . refiner
pebay at mcs.anl.gov
Fri Dec 28 15:30:15 CST 2007
Author: pebay
Date: 2007-12-28 15:30:15 -0600 (Fri, 28 Dec 2007)
New Revision: 1500
Modified:
MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.cpp
MOAB/trunk/refiner/MBEntityRefiner.cpp
MOAB/trunk/refiner/MBEntityRefiner.hpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
MOAB/trunk/test_mesh_refiner.cpp
Log:
ENH: implement and test the 2-simplex refinement
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -96,5 +96,11 @@
const double* cm, void* tm,
const double* c1, const void* t1 ) const
+ (void)c0;
+ (void)t0;
+ (void)cm;
+ (void)tm;
+ (void)c1;
+ (void)t1;
Modified: MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.cpp
--- MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.cpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.cpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -24,6 +24,9 @@
double* p1, void* t1,
const double* p2, const void* t2 )
+ (void)t0;
+ (void)t1;
+ (void)t2;
double L2 = 0.;
double delta;
int i;
Modified: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -8,6 +8,7 @@
this->mesh = parentMesh;
this->edge_size_evaluator = 0;
+ this->output_functor = 0;
// By default, allow at most one subdivision per edge
this->minimum_number_of_subdivisions = 0;
this->maximum_number_of_subdivisions = 1;
@@ -18,6 +19,8 @@
if ( this->edge_size_evaluator )
delete this->edge_size_evaluator;
+ if ( this->output_functor )
+ delete this->output_functor;
/**\fn bool MBEntityRefiner::refine_entity( MBEntityHandle )
@@ -146,11 +149,11 @@
void MBEntityRefiner::update_heap_size()
unsigned long n = this->get_heap_size_bound( this->maximum_number_of_subdivisions );
- this->coord_heap.reserve( 6 * n );
+ this->coord_heap.resize( 6 * n );
unsigned long m = this->edge_size_evaluator->get_vertex_tag_size();
- this->tag_heap.reserve( m * n );
+ this->tag_heap.resize( m * n );
Modified: MOAB/trunk/refiner/MBEntityRefiner.hpp
--- MOAB/trunk/refiner/MBEntityRefiner.hpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBEntityRefiner.hpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -69,6 +69,7 @@
class MB_DLL_EXPORT MBEntityRefinerOutputFunctor
public:
+ virtual ~MBEntityRefinerOutputFunctor() { }
virtual void operator () ( const double* vcoords, const void* vtags ) = 0;
virtual void operator () ( MBEntityType etyp ) = 0;
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -6,6 +6,12 @@
#include <iostream>
#include <stack>
+// Static arrays holding parametric coordinates of element vertices
+static double MBVertexParametric[] = { 0., 0., 0. };
+static double MBEdgeParametric[] = { 0., 0., 0., 1., 0., 0. };
+static double MBTriParametric[] = { 0., 0., 0., 1., 0., 0., 0., 1., 0. };
+static double MBTetParametric[] = { 0., 0., 0., 1., 0., 0., 0., 1., 0., 0., 0., 1. };
#ifdef MB_DEBUG_TESSELLATOR
# define MB_TESSELLATOR_INCR_CASE_COUNT(cs) this->case_counts[cs]++
# define MB_TESSELLATOR_INCR_SUBCASE_COUNT(cs,sc) this->subcase_counts[cs][sc]++
@@ -36,28 +42,42 @@
return false;
std::vector<double> entity_coords;
+ std::vector<char> entity_tags;
+ int ts = this->edge_size_evaluator->get_vertex_tag_size();
entity_coords.resize( 6 * num_nodes );
+ if ( ts )
+ entity_tags.resize( num_nodes * ts );
+ MBEntityType etyp = this->mesh->type_from_handle( entity );
// Have to make num_nodes calls to get_coords() because we need xyz interleaved with rst coords.
for ( int n = 0; n < num_nodes; ++ n )
- if ( this->mesh->get_coords( &conn[n], 1, &entity_coords[3 * n + 3] ) != MB_SUCCESS )
+ if ( this->mesh->get_coords( &conn[n], 1, &entity_coords[6 * n + 3] ) != MB_SUCCESS )
return false;
+ // Still need to get tags.
- // Still need to get tags.
- switch ( this->mesh->type_from_handle( entity ) )
+ switch ( etyp )
case MBVERTEX:
- this->refine_0_simplex( &entity_coords[0], 0 ); // FIXME
+ this->assign_parametric_coordinates( 1, MBVertexParametric, &entity_coords[0] );
+ this->refine_0_simplex( &entity_coords[0], &entity_tags[0] );
rval = false;
break;
case MBEDGE:
- rval = this->refine_1_simplex( 0, &entity_coords[0], 0, &entity_coords[6], 0 ); // FIXME
+ this->assign_parametric_coordinates( 2, MBEdgeParametric, &entity_coords[0] );
+ rval = this->refine_1_simplex( this->maximum_number_of_subdivisions,
+ &entity_coords[0], &entity_tags[0], &entity_coords[6], &entity_tags[ts] );
break;
case MBTRI:
- rval = this->refine_2_simplex( 0, 0, 0, 0, 0, 0, 0, 0 ); // FIXME
+ this->assign_parametric_coordinates( 3, MBTriParametric, &entity_coords[0] );
+ rval = this->refine_2_simplex( this->maximum_number_of_subdivisions, 7,
+ &entity_coords[ 0], &entity_tags[ 0],
+ &entity_coords[ 6], &entity_tags[ ts],
+ &entity_coords[12], &entity_tags[2 * ts] );
break;
case MBQUAD:
std::cerr << "Quadrilaterals not handled yet\n";
@@ -68,6 +88,7 @@
rval = false;
break;
case MBTET:
+ this->assign_parametric_coordinates( 4, MBTetParametric, &entity_coords[0] );
rval = this->refine_3_simplex( 0, 0, 0, 0, 0, 0, 0, 0, 0 ); // FIXME
break;
case MBPYRAMID:
@@ -184,6 +205,12 @@
if ( max_depth-- > 0 )
int i;
+ midpt0c = this->heap_coord_storage();
+ midpt1c = this->heap_coord_storage();
+ midpt2c = this->heap_coord_storage();
+ midpt0t = this->heap_tag_storage();
+ midpt1t = this->heap_tag_storage();
+ midpt2t = this->heap_tag_storage();
for ( i = 0; i < 6; ++i )
midpt0c[i] = ( v0[i] + v1[i] ) / 2.;
@@ -1419,6 +1446,15 @@
return true;
+/**\brief This is used by refine_entity to assign parametric coordinates to corners of each element.
+void MBSimplexTemplateRefiner::assign_parametric_coordinates( int num_nodes, const double* src, double* tgt )
+ for ( int i = 0; i < num_nodes; ++i, src +=3, tgt += 6 )
+ for ( int j = 0; j < 3; ++j )
+ tgt[j] = src[j];
/**\brief Returns true if || a0a1 || < || b0b1 ||
* We use this to test which triangulation has the best
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -60,13 +60,14 @@
double* v1, void* t1,
double* v2, void* t2,
double* v3, void* t3 );
- static bool compare_Hopf_cross_string_dist( const double* v00, const double* v01, const double* v10, const double* v11 );
void evaluate_tags_at_facepoint( const double* c0, const void* t0,
const double* c1, const void* t1,
const double* c2, const void* t2,
const double* cm, void* tm ) const;
int best_tets( int* alternates, double*[14], int, int ) { return alternates[0]; }
+ void assign_parametric_coordinates( int num_nodes, const double* src, double* tgt );
+ static bool compare_Hopf_cross_string_dist( const double* v00, const double* v01, const double* v10, const double* v11 );
#endif // MB_SIMPLEXTEMPLATEREFINER_H
Modified: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp 2007-12-28 20:58:04 UTC (rev 1499)
+++ MOAB/trunk/test_mesh_refiner.cpp 2007-12-28 21:30:15 UTC (rev 1500)
@@ -1,25 +1,62 @@
#include "MBCore.hpp"
#include "MBEdgeSizeSimpleImplicit.hpp"
+#include "MBSimplexTemplateRefiner.hpp"
#include "MBInterface.hpp"
+#include <iostream>
+class MBTestOutputFunctor : public MBEntityRefinerOutputFunctor
+ virtual void operator () ( const double* vcoords, const void* vtags )
+ std::cout << "[ " << vcoords[0];
+ for ( int i = 1; i < 6; ++i )
+ std::cout << ", " << vcoords[i];
+ std::cout << " ]\n";
+ virtual void operator () ( MBEntityType etyp )
+ std::cout << "---------- " << etyp << "\n\n";
int TestMeshRefiner( int argc, char* argv[] )
MBInterface* iface = new MBCore;
- MBEdgeSizeSimpleImplicit eval( iface );
- double p0[6] = { 0.1, 0.0, 0.0, 0.1, 0.0, 0.0 };
- double p1[6] = { 0.6, 0.0, 0.0, 0.6, 0.0, 0.0 };
- double p2[6] = { 1.1, 0.0, 0.0, 1.1, 0.0, 0.0 };
- if ( eval.evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
+ MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit( iface );
+ double p0[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 };
+ double p1[6] = { 0.5, 0.0, 0.0, 0.5, 0.0, 0.0 };
+ double p2[6] = { 1.0, 0.0, 0.0, 1.0, 0.0, 0.0 };
+ double p3[6] = { 0.6, 2.0, 0.0, 0.6, 2.0, 0.0 };
+ if ( eval->evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
return 1;
- eval.set_ratio( 2. );
- if ( ! eval.evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
+ eval->set_ratio( 2. );
+ if ( ! eval->evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
return 1;
+ MBEntityHandle node_handles[3];
+ MBEntityHandle tri_handle;
+ iface->create_vertex( p0, node_handles[0] );
+ iface->create_vertex( p2, node_handles[1] );
+ iface->create_vertex( p3, node_handles[2] );
+ iface->create_element( MBTRI, node_handles, 3, tri_handle );
+ MBSimplexTemplateRefiner eref( iface );
+ MBTestOutputFunctor* ofunc = new MBTestOutputFunctor;
+ eref.set_edge_size_evaluator( eval );
+ eref.set_output_functor( ofunc );
+ eref.refine_entity( tri_handle );
delete iface;
return 0;
