[MOAB-dev] r1498 - MOAB/trunk/refiner
pebay at mcs.anl.gov
Fri Dec 28 14:50:43 CST 2007
Author: pebay
Date: 2007-12-28 14:50:42 -0600 (Fri, 28 Dec 2007)
New Revision: 1498
Added:
MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp
MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp
Modified:
MOAB/trunk/refiner/CMakeLists.txt
MOAB/trunk/refiner/MBMeshRefiner.hpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
Log:
ENH: added a "tag assigner" class
ENH: various minor changes
Modified: MOAB/trunk/refiner/CMakeLists.txt
--- MOAB/trunk/refiner/CMakeLists.txt 2007-12-28 04:53:50 UTC (rev 1497)
+++ MOAB/trunk/refiner/CMakeLists.txt 2007-12-28 20:50:42 UTC (rev 1498)
@@ -4,6 +4,7 @@
MBEntityRefiner.cpp
MBMeshRefiner.cpp
+ MBSimplexTemplateTagAssigner.cpp
add_library( MOABrefiner
Modified: MOAB/trunk/refiner/MBMeshRefiner.hpp
--- MOAB/trunk/refiner/MBMeshRefiner.hpp 2007-12-28 04:53:50 UTC (rev 1497)
+++ MOAB/trunk/refiner/MBMeshRefiner.hpp 2007-12-28 20:50:42 UTC (rev 1498)
@@ -18,6 +18,7 @@
* This is an class that contains the method used for mesh refinement.
* \author Philippe Pebay
+ * \author David Thompson
* \date 19 November 2007
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-28 04:53:50 UTC (rev 1497)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-28 20:50:42 UTC (rev 1498)
@@ -1441,10 +1441,11 @@
void MBSimplexTemplateRefiner::evaluate_tags_at_facepoint( const double* c0, const void* t0,
- const double* c1, const void* t1,
- const double* c2, const void* t2,
- const double* cm, void* tm ) const
+ const double* c1, const void* t1,
+ const double* c2, const void* t2,
+ const double* cm, void* tm ) const
Added: MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp (rev 0)
+++ MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp 2007-12-28 20:50:42 UTC (rev 1498)
@@ -0,0 +1,22 @@
+#include "MBSimplexTemplateTagAssigner.hpp"
+#include "MBMeshRefiner.hpp"
+/// Construct a template tag assigner.
+MBSimplexTemplateTagAssigner::MBSimplexTemplateTagAssigner( MBMeshRefiner* )
+/// Empty destructor for good form.
+MBSimplexTemplateTagAssigner::~MBSimplexTemplateTagAssigner()
+void MBSimplexTemplateTagAssigner::operator()( const void* ta, const void* tb, void* tp )
+void MBSimplexTemplateTagAssigner::operator()( const void* ta, const void* tb, const void* tc, void* tp )
Added: MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp (rev 0)
+++ MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp 2007-12-28 20:50:42 UTC (rev 1498)
@@ -0,0 +1,45 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2007 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/** \class MBSimplexTemplateTagAssigner
+ * This is an class that embodies the process of assigning tag
+ * values to new vertices based on some pre-existing neighbors in a
+ * simplicial mesh.
+ * \author Philippe Pebay
+ * \date 28 December 2007
+#ifndef MB_SIMPLEXTEMPLATETAGASSIGNER_H
+#define MB_SIMPLEXTEMPLATETAGASSIGNER_H
+class MB_DLL_EXPORT MBSimplexTemplateTagAssigner
+public:
+ MBSimplexTemplateTagAssigner( MBMeshRefiner* );
+ virtual ~MBSimplexTemplateTagAssigner();
+ virtual void operator()( const void* ta, const void* tb, void* tp );
+ virtual void operator()( const void* ta, const void* tb, const void* tc, void* tp );
+protected:
+ MBMeshRefiner* mesh_refiner;
+#endif // MB_SIMPLEXTEMPLATETAGASSIGNER_H
