[MOAB-dev] r1491 - MOAB/trunk/refiner
    dcthomp at mcs.anl.gov
    Thu Dec 27 11:13:45 CST 2007
Author: dcthomp
Date: 2007-12-27 11:13:44 -0600 (Thu, 27 Dec 2007)
New Revision: 1491
Modified:
   MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
   MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
   MOAB/trunk/refiner/MBEntityRefiner.cpp
   MOAB/trunk/refiner/MBEntityRefiner.hpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
Log:
ENH: Refiner checkpoint
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -4,6 +4,7 @@
 #include <assert.h>
+/// Construct an evaluator.
 MBEdgeSizeEvaluator::MBEdgeSizeEvaluator( MBInterface* parentMesh )
   assert( parentMesh );
@@ -12,16 +13,40 @@
   this->reset_vertex_tags();
+/// Destruction is virtual so subclasses may clean up after refinement.
 MBEdgeSizeEvaluator::~MBEdgeSizeEvaluator()
+/**\fn bool MBEdgeSizeEvaluator::evaluate_edge( \
+  *         const double* p0, const void* t0, double* p1, void* t1, const double* p2, const void* t2 )
+  *\brief Returns true if the edge \a p0 - \a p2 should be subdivided, false otherwise.
+  * The arguments \a p0, \a p1, and \a p2 are all pointers to arrays of 6 doubles each
+  * while the arguments \a t0, \a t1, and \a t2 are all pointers to arrays of tag data
+  * defined at the corresponding point. While the endpoints \a p0 and \a p2 are
+  * immutable, the mid-edge point coordinates \a p1 and tag data \a t1 may be altered by
+  * evaluate_edge(). Altered values will be ignored if evaluate_edge() returns false.
+  * Be careful to ensure that all calls to evaluate_edge() perform identical modifications
+  * given identical input values!
+  * A list of tags passed in \a t0, \a t1, and \a t2 is stored in the vertexTags member.
+  * The vertexSize member stores the total length of data associated with each pointer (in bytes).
+  * Subclasses may access vertexTags and vertexSize directly; the refiner uses public methods to
+  * populate vertexTags before evaluate_edge() is called.
+/// Clear the list of tag values that will appear past the vertex coordinates in \a p0, \a p1, and \a p2.
 void MBEdgeSizeEvaluator::reset_vertex_tags()
   this->vertexSize = 0;
   this->vertexTags.clear();
+/** Add a tag to the list of tag values that will appear past the vertex coordinates.
+  * The return value is the offset into each vertex coordinate pointer (\a p0, \a p1, \a p2) where the
+  * tag value(s) will be stored.
 int MBEdgeSizeEvaluator::add_vertex_tag( MBTag tag_handle )
   int offset = this->vertexSize; // old size is offset of tag being added
@@ -48,3 +73,27 @@
   this->vertexTags.push_back( std::pair< MBTag, int >( tag_handle, offset ) );
   return offset;
+/**\fn int MBEdgeSizeEvaluator::get_vertex_tag_size()
+  *\brief Return the number of bytes to allocate for tag data per point.
+/**\brief Given endpoint coordinates and tag values plus midpoint coordinates, compute midpoint tag values.
+  * Normally, this function will be invoked by the MBEntityRefiner before evaluate_edge is called.
+  * However, if evaluate_edge() changes the parametric coordinates of the midpoint,
+  * it should call evaluate_tags_at_midpoint() again to update any tag values;
+  * that is why this function is a member of MBEdgeSizeEvaluator and not MBEntityRefiner.
+  * @param[in] c0 Pointer to endpoint 0 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+  * @param[in] t0 Pointer to endpoint 0 tag values.
+  * @param[in] cm Pointer to midpoint coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+  * @param[out] tm Pointer to midpoint tag values.
+  * @param[in] c1 Pointer to endpoint 1 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+  * @param[in] t1 Pointer to endpoint 1 tag values.
+void MBEdgeSizeEvaluator::evaluate_tags_at_midpoint(
+  const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -35,40 +35,21 @@
 class MB_DLL_EXPORT MBEdgeSizeEvaluator
 public:
-  /// Construct an evaluator.
   MBEdgeSizeEvaluator( MBInterface* );
-  /// Destruction is virtual so subclasses may clean up after refinement.
   virtual ~MBEdgeSizeEvaluator();
-  /** \brief Returns true if the edge \a p0 - \a p2 should be subdivided, false otherwise.
-    * The arguments \a p0, \a p1, and \a p2 are all pointers to arrays of 6 doubles each
-    * while the arguments \a t0, \a t1, and \a t2 are all pointers to arrays of tag data
-    * defined at the corresponding point. While the endpoints \a p0 and \a p2 are
-    * immutable, the mid-edge point coordinates \a p1 and tag data \a t1 may be altered by
-    * evaluate_edge(). Altered values will be ignored if evaluate_edge() returns false.
-    * Be careful to ensure that all calls to evaluate_edge() perform identical modifications
-    * given identical input values!
-    * A list of tags passed in \a t0, \a t1, and \a t2 is stored in the vertexTags member.
-    * The vertexSize member stores the total length of data associated with each pointer (in bytes).
-    * Subclasses may access vertexTags and vertexSize directly; the refiner uses public methods to
-    * populate vertexTags before evaluate_edge() is called.
   virtual bool evaluate_edge(
     const double* p2, const void* t2 ) = 0;
-  /// Clear the list of tag values that will appear past the vertex coordinates in \a p0, \a p1, and \a p2.
   void reset_vertex_tags();
-  /** Add a tag to the list of tag values that will appear past the vertex coordinates.
-    * The return value is the offset into each vertex coordinate pointer (\a p0, \a p1, \a p2) where the
-    * tag value(s) will be stored.
   int add_vertex_tag( MBTag tag_handle );
-  /// Return the number of bytes to allocate for tag data per point.
   int get_vertex_tag_size() { return this->vertexSize; }
+  void evaluate_tags_at_midpoint(
+    double* cm, void* tm,
+    const double* c1, const void* t1 ) const;
 protected:
   std::vector< std::pair< MBTag, int > > vertexTags;
Modified: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -203,17 +203,3 @@
   return rval;
-/**\brief Given endpoint coordinates and tag values plus midpoint coordinates, compute midpoint tag values.
-  * @param[in] c0 Pointer to endpoint 0 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
-  * @param[in] t0 Pointer to endpoint 0 tag values.
-  * @param[in] cm Pointer to midpoint coordinates. The parametric coordinates (3) are followed by world coordinates (3).
-  * @param[out] tm Pointer to midpoint tag values.
-  * @param[in] c1 Pointer to endpoint 1 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
-  * @param[in] t1 Pointer to endpoint 1 tag values.
-void MBEntityRefiner::evaluate_tags_at_midpoint(
-  const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const
Modified: MOAB/trunk/refiner/MBEntityRefiner.hpp
--- MOAB/trunk/refiner/MBEntityRefiner.hpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBEntityRefiner.hpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -109,7 +109,6 @@
   void reset_heap_pointers();
   double* heap_coord_storage();
   void* heap_tag_storage();
-  void evaluate_tags_at_midpoint( const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const;
 #endif // MB_ENTITYREFINER_H
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -48,7 +48,7 @@
       rval = this->refine_1_simplex( 0,  &entity_coords[0], 0,  &entity_coords[6], 0 ); // FIXME
       break;
     case MBTRI:
-      rval = this->refine_2_simplex();
+      rval = this->refine_2_simplex( 0 ,   0, 0,   0, 0,   0, 0 ); // FIXME
       break;
     case MBQUAD:
       std::cerr << "Quadrilaterals not handled yet\n";
@@ -109,7 +109,7 @@
   * in space and vertices as degrees-of-freedom in a mesh (i.e. a vertex that is
   * treated as a lumped-parameter model).
-void MBSimplexTemplateRefiner::refine_0_simplex( double* v0, const void* t0 )
+void MBSimplexTemplateRefiner::refine_0_simplex( const double* v0, const void* t0 )
   (*this->output_functor)( v0, t0 );
   (*this->output_functor)( MBVERTEX );
@@ -117,7 +117,8 @@
 /**\brief Refine an edge.
-bool MBSimplexTemplateRefiner::refine_1_simplex( int max_depth, double* v0, void* t0, double* v1, void* t1 )
+bool MBSimplexTemplateRefiner::refine_1_simplex(
+  int max_depth, const double* v0, const void* t0, const double* v1, const void* t1 )
   bool edge_code = false;
@@ -134,7 +135,7 @@
     for ( i = 0; i < 6; i++ )
       midptc[i] = ( v0[i] + v1[i] ) / 2.;
-    this->evaluate_tags_at_midpoint( v0, t0, midptc, midptt, v1, t1 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v0, t0, midptc, midptt, v1, t1 );
     edge_code = this->edge_size_evaluator->evaluate_edge( v0, t0, midptc, midptt, v1, t1 );
@@ -159,8 +160,27 @@
 /**\brief Refine a triangle.
-bool MBSimplexTemplateRefiner::refine_2_simplex()
+bool MBSimplexTemplateRefiner::refine_2_simplex(
+  int max_depth, const double* v0, const void* t0, const double* v1, const void* t1, const double* v2, const void* t2 )
+  int edgeCode = 0;
+  double* midpt0c;
+  double* midpt1c;
+  double* midpt2c;
+  void* midpt0t;
+  void* midpt1t;
+  void* midpt2t;
+  if ( max_depth-- > 0 )
+    int i;
+    for ( i = 0; i < 3; ++i )
   return true;
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2007-12-27 10:02:36 UTC (rev 1490)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2007-12-27 17:13:44 UTC (rev 1491)
@@ -44,9 +44,11 @@
   static int* template_index;
   static int* templates;
-  void refine_0_simplex( double* v0, const void* t0 );
-  bool refine_1_simplex( int max_depth, double* v0, void* t0, double* v1, void* t1 );
-  bool refine_2_simplex();
+  void refine_0_simplex( const double* v0, const void* t0 );
+  bool refine_1_simplex( int max_depth,
+    const double* v0, const void* t0, const double* v1, const void* t1 );
+  bool refine_2_simplex( int max_depth,
+    const double* v0, const void* t0, const double* v1, const void* t1, const double* v2, const void* t2 );
   bool refine_3_simplex();
 #endif // MB_SIMPLEXTEMPLATEREFINER_H
