[MOAB-dev] r1489 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov
Thu Dec 27 02:30:35 CST 2007
Author: dcthomp
Date: 2007-12-27 02:30:31 -0600 (Thu, 27 Dec 2007)
New Revision: 1489
Modified:
MOAB/trunk/refiner/MBEntityRefiner.cpp
MOAB/trunk/refiner/MBEntityRefiner.hpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
Log:
ENH: Checkpoint on refiner work.
Modified: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp 2007-12-27 04:28:59 UTC (rev 1488)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp 2007-12-27 08:30:31 UTC (rev 1489)
@@ -61,6 +61,31 @@
* @retval A pointer to an edge size evaluator object or NULL.
+/**\brief Set the functor through which output entities are streamed.
+ * Any previously assigned functor will be deleted when a new functor is set.
+ * @retvalReturns true if the value was changed and false otherwise.
+bool MBEntityRefiner::set_output_functor( MBEntityRefinerOutputFunctor* func_obj )
+ if ( ! func_obj || func_obj == this->output_functor )
+ return false;
+ if ( this->output_functor )
+ delete this->output_functor;
+ this->output_functor = func_obj;
+ return true;
+/**\fn MBEntityRefinerOutputFunctor* MBEntityRefiner::get_output_functor()
+ *\brief Return the functor used to stream output.
+ * @retval A pointer to the functor. This may be NULL.
/**\brief Set the minimum number of recursive subdivisions that should occur, regardless of the edge_size_evaluator's response.
* This is useful for forcing global refinement.
@@ -164,12 +189,12 @@
* The returned pointer references enough bytes to store all the tags for a vertex as reported by the
* current edge size evaluator's MBEdgeSizeEvaluator::get_vertex_tag_size().
-char* MBEntityRefiner::heap_tag_storage()
+void* MBEntityRefiner::heap_tag_storage()
- char* rval;
+ void* rval;
if ( this->edge_size_evaluator && this->current_tag != this->tag_heap.end() )
- rval = &(*this->current_tag);
+ rval = (void*) &(*this->current_tag);
this->current_tag += this->edge_size_evaluator->get_vertex_tag_size();
else
@@ -179,3 +204,16 @@
return rval;
+/**\brief Given endpoint coordinates and tag values plus midpoint coordinates, compute midpoint tag values.
+ * @param[in] c0 Pointer to endpoint 0 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+ * @param[in] t0 Pointer to endpoint 0 tag values.
+ * @param[in] cm Pointer to midpoint coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+ * @param[out] tm Pointer to midpoint tag values.
+ * @param[in] c1 Pointer to endpoint 1 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
+ * @param[in] t1 Pointer to endpoint 1 tag values.
+void MBEntityRefiner::evaluate_tags_at_midpoint(
+ const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const
Modified: MOAB/trunk/refiner/MBEntityRefiner.hpp
--- MOAB/trunk/refiner/MBEntityRefiner.hpp 2007-12-27 04:28:59 UTC (rev 1488)
+++ MOAB/trunk/refiner/MBEntityRefiner.hpp 2007-12-27 08:30:31 UTC (rev 1489)
@@ -42,8 +42,20 @@
* \author David Thompson
* \author Philippe Pebay
- * \date 19 November 2007
+ * \date 24 December 2007
+/** \class MBEntityRefinerOutputFunctor
+ * This is an abstract class used by MBEntityRefiner to output entities that are the product of refinement.
+ * The parenthesis operator is overloaded with two forms:
+ * one used for appending a vertex to an entity,
+ * the other used to finalize the creation of the entity by specifying its type.
+ * \author David Thompson
+ * \author Philippe Pebay
+ * \date 26 December 2007
#ifndef MB_ENTITYREFINER_H
#define MB_ENTITYREFINER_H
@@ -54,6 +66,13 @@
class MBInterface;
class MBEdgeSizeEvaluator;
+class MB_DLL_EXPORT MBEntityRefinerOutputFunctor
+public:
+ virtual void operator () ( const double* vcoords, const void* vtags ) = 0;
+ virtual void operator () ( MBEntityType etyp ) = 0;
public:
@@ -66,6 +85,9 @@
virtual bool set_edge_size_evaluator( MBEdgeSizeEvaluator* );
MBEdgeSizeEvaluator* get_edge_size_evaluator() { return this->edge_size_evaluator; }
+ virtual bool set_output_functor( MBEntityRefinerOutputFunctor* func_obj );
+ MBEntityRefinerOutputFunctor* get_output_functor() { return this->output_functor; }
virtual bool set_minimum_number_of_subdivisions( int mn );
int get_minimum_number_of_subdivisions() const { return this->minimum_number_of_subdivisions; }
@@ -75,6 +97,7 @@
protected:
MBInterface* mesh;
MBEdgeSizeEvaluator* edge_size_evaluator;
+ MBEntityRefinerOutputFunctor* output_functor;
int minimum_number_of_subdivisions;
int maximum_number_of_subdivisions;
std::vector<double> coord_heap;
@@ -85,7 +108,8 @@
void update_heap_size();
void reset_heap_pointers();
double* heap_coord_storage();
- char* heap_tag_storage();
+ void* heap_tag_storage();
+ void evaluate_tags_at_midpoint( const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const;
#endif // MB_ENTITYREFINER_H
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-27 04:28:59 UTC (rev 1488)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-27 08:30:31 UTC (rev 1489)
@@ -1,5 +1,6 @@
#include "MBSimplexTemplateRefiner.hpp"
+#include "MBEdgeSizeEvaluator.hpp"
#include "MBInterface.hpp"
#include <iostream>
@@ -19,14 +20,32 @@
this->reset_heap_pointers();
bool rval = true;
+ const MBEntityHandle* conn;
+ int num_nodes;
+ if ( this->mesh->get_connectivity( entity, conn, num_nodes ) != MB_SUCCESS )
+ return false;
+ std::vector<double> entity_coords;
+ entity_coords.resize( 6 * num_nodes );
+ // Have to make num_nodes calls to get_coords() because we need xyz interleaved with rst coords.
+ for ( int n = 0; n < num_nodes; ++n )
+ if ( this->mesh->get_coords( &conn[n], 1, &entity_coords[3 * n + 3] ) != MB_SUCCESS )
+ return false;
+ // Still need to get tags.
switch ( this->mesh->type_from_handle( entity ) )
case MBVERTEX:
- this->refine_0_simplex();
+ this->refine_0_simplex( &entity_coords[0], 0 ); // FIXME
rval = false;
break;
case MBEDGE:
- rval = this->refine_1_simplex();
+ rval = this->refine_1_simplex( 0, &entity_coords[0], 0, &entity_coords[6], 0 ); // FIXME
break;
case MBTRI:
rval = this->refine_2_simplex();
@@ -90,15 +109,52 @@
* in space and vertices as degrees-of-freedom in a mesh (i.e. a vertex that is
* treated as a lumped-parameter model).
-void MBSimplexTemplateRefiner::refine_0_simplex()
+void MBSimplexTemplateRefiner::refine_0_simplex( double* v0, const void* t0 )
+ (*this->output_functor)( v0, t0 );
+ (*this->output_functor)( MBVERTEX );
/**\brief Refine an edge.
-bool MBSimplexTemplateRefiner::refine_1_simplex()
+bool MBSimplexTemplateRefiner::refine_1_simplex( int max_depth, double* v0, void* t0, double* v1, void* t1 )
- return true;
+ bool edge_code = false;
+ double* midptc;
+ void* midptt;
+ if ( max_depth-- > 0 )
+ midptc = this->heap_coord_storage();
+ midptt = this->heap_tag_storage();
+ int i;
+ // make valgrind happy
+ //vtkstd::fill( midpt0, midpt0 + 6, 0. );
+ for ( i = 0; i < 6; i++ )
+ midptc[i] = ( v0[i] + v1[i] ) / 2.;
+ this->evaluate_tags_at_midpoint( v0, t0, midptc, midptt, v1, t1 );
+ edge_code = this->edge_size_evaluator->evaluate_edge( v0, t0, midptc, midptt, v1, t1 );
+ switch ( edge_code )
+ // No edges to subdivide
+ case 0:
+ (*this->output_functor)( v1, t1 );
+ (*this->output_functor)( MBEDGE );
+ break ;
+ // One edge to subdivide
+ case 1:
+ this->refine_1_simplex( max_depth, v0, t0, midptc, midptt );
+ this->refine_1_simplex( max_depth, midptc, midptt, v1, t1 );
+ break;
+ return edge_code;
/**\brief Refine a triangle.
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-27 04:28:59 UTC (rev 1488)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-27 08:30:31 UTC (rev 1489)
@@ -44,8 +44,8 @@
static int* template_index;
static int* templates;
- void refine_0_simplex();
- bool refine_1_simplex();
+ void refine_0_simplex( double* v0, const void* t0 );
+ bool refine_1_simplex( int max_depth, double* v0, void* t0, double* v1, void* t1 );
bool refine_2_simplex();
bool refine_3_simplex();
