[MOAB-dev] r1485 - in MOAB/trunk: . cmake refiner
pebay at mcs.anl.gov
Mon Dec 24 19:21:07 CST 2007
Author: pebay
Date: 2007-12-24 19:21:07 -0600 (Mon, 24 Dec 2007)
New Revision: 1485
Added:
MOAB/trunk/refiner/CMakeLists.txt
MOAB/trunk/refiner/MBEntityRefiner.cpp
MOAB/trunk/refiner/MBEntityRefiner.hpp
MOAB/trunk/refiner/MBMeshRefiner.cpp
MOAB/trunk/refiner/MBMeshRefiner.hpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
Modified:
MOAB/trunk/CMakeLists.txt
MOAB/trunk/cmake/FindNetCDF.cmake
MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.hpp
Log:
COMP: updated CMakeLists to include MBSysUtil.cpp
ENH: refiner checkpoint
COMP: ignore Fortran NetCDF library when searching for NetCDF
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2007-12-24 23:43:55 UTC (rev 1484)
+++ MOAB/trunk/CMakeLists.txt 2007-12-25 01:21:07 UTC (rev 1485)
@@ -120,8 +120,6 @@
MBHandleUtils.cpp
MBMatrix3.cpp
MBCore.cpp
- MBEdgeSizeEvaluator.cpp
- MBEdgeSizeSimpleImplicit.cpp
MBFactory.cpp
MBGeomUtil.cpp
MBMeshSet.cpp
@@ -132,6 +130,7 @@
MBReadUtil.cpp
MBReaderWriterSet.cpp
MBSkinner.cpp
+ MBSysUtil.cpp
MBUtil.cpp
MBWriteUtil.cpp
MeshSetSequence.cpp
@@ -221,6 +220,13 @@
add_library( MOAB
${MOAB_LIB_SRCS}
+ add_subdirectory( refiner )
+ include_directories( refiner )
+ target_link_libraries( MOAB
+ MOABrefiner
if ( MOAB_USE_HDF AND HDF5_FOUND )
mhdf
Modified: MOAB/trunk/cmake/FindNetCDF.cmake
--- MOAB/trunk/cmake/FindNetCDF.cmake 2007-12-24 23:43:55 UTC (rev 1484)
+++ MOAB/trunk/cmake/FindNetCDF.cmake 2007-12-25 01:21:07 UTC (rev 1485)
@@ -54,6 +54,9 @@
set( NetCDF_LIBRARIES
${NetCDF_C_LIBRARY}
${NetCDF_CXX_LIBRARY}
+set( NetCDF_FORTRAN_LIBRARIES
${NetCDF_FORTRAN_LIBRARY}
Added: MOAB/trunk/refiner/CMakeLists.txt
--- MOAB/trunk/refiner/CMakeLists.txt (rev 0)
+++ MOAB/trunk/refiner/CMakeLists.txt 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,11 @@
+set ( MOAB_REFINER_SRCS
+ MBEdgeSizeEvaluator.cpp
+ MBEdgeSizeSimpleImplicit.cpp
+ MBEntityRefiner.cpp
+ MBMeshRefiner.cpp
+add_library( MOABrefiner
+ ${MOAB_REFINER_SRCS}
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp 2007-12-24 23:43:55 UTC (rev 1484)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -36,7 +36,7 @@
public:
/// Construct an evaluator.
- MBEdgeSizeEvaluator( MBInterface* parentMesh );
+ MBEdgeSizeEvaluator( MBInterface* );
/// Destruction is virtual so subclasses may clean up after refinement.
virtual ~MBEdgeSizeEvaluator();
Modified: MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.hpp
--- MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.hpp 2007-12-24 23:43:55 UTC (rev 1484)
+++ MOAB/trunk/refiner/MBEdgeSizeSimpleImplicit.hpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -36,7 +36,7 @@
public:
- MBEdgeSizeSimpleImplicit( MBInterface* parentMesh );
+ MBEdgeSizeSimpleImplicit( MBInterface* );
virtual ~MBEdgeSizeSimpleImplicit();
Added: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp (rev 0)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,24 @@
+#include "MBEntityRefiner.hpp"
+#include "MBInterface.hpp"
+MBEntityRefiner::MBEntityRefiner( MBInterface* parentMesh )
+ this->mesh = parentMesh;
+ this->edge_size_evaluator = 0;
+MBEntityRefiner::~MBEntityRefiner()
+bool MBEntityRefiner::set_edge_size_evaluator( MBEdgeSizeEvaluator* ese )
+ if ( ! ese ) return false;
+ this->edge_size_evaluator = ese;
+ return true;
Added: MOAB/trunk/refiner/MBEntityRefiner.hpp
--- MOAB/trunk/refiner/MBEntityRefiner.hpp (rev 0)
+++ MOAB/trunk/refiner/MBEntityRefiner.hpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,55 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2007 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/** \class MBEntityRefiner
+ * This is an abstract class that contains the method used for per-entity
+ * refinement
+ * Subclasses must implement the pure virtual refine_entity() function.
+ * \author David Thompson
+ * \author Philippe Pebay
+ * \date 19 November 2007
+#ifndef MB_ENTITYREFINER_H
+#define MB_ENTITYREFINER_H
+#include "MBTypes.h" // for MB_DLL_EXPORT
+#include <vector>
+class MBInterface;
+class MBEdgeSizeEvaluator;
+class MB_DLL_EXPORT MBEntityRefiner
+public:
+ /// Construct an entity refiner.
+ MBEntityRefiner( MBInterface* );
+ /// Destruction is virtual so subclasses may clean up after refinement.
+ virtual ~MBEntityRefiner();
+ virtual bool refine_entity( MBEntityHandle ) = 0;
+ bool set_edge_size_evaluator( MBEdgeSizeEvaluator* );
+ MBEdgeSizeEvaluator* get_edge_size_evaluator() { return this->edge_size_evaluator; };
+protected:
+ MBInterface* mesh;
+ MBEdgeSizeEvaluator* edge_size_evaluator;
+#endif // MB_ENTITYREFINER_H
Added: MOAB/trunk/refiner/MBMeshRefiner.cpp
--- MOAB/trunk/refiner/MBMeshRefiner.cpp (rev 0)
+++ MOAB/trunk/refiner/MBMeshRefiner.cpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,28 @@
+#include "MBMeshRefiner.hpp"
+MBMeshRefiner::MBMeshRefiner( MBInterface* parentMesh )
+ this->entity_refiner = 0;
+MBMeshRefiner::~MBMeshRefiner()
+bool MBMeshRefiner::set_entity_refiner( MBEntityRefiner* er )
+ if ( ! er ) return false;
+ this->entity_refiner = er;
+ return true;
+bool MBMeshRefiner::refine_mesh()
+ return false;
Added: MOAB/trunk/refiner/MBMeshRefiner.hpp
--- MOAB/trunk/refiner/MBMeshRefiner.hpp (rev 0)
+++ MOAB/trunk/refiner/MBMeshRefiner.hpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,52 @@
+/** \class MBMeshRefiner
+ * This is an class that contains the method used for mesh refinement.
+#ifndef MB_MESHREFINER_H
+#define MB_MESHREFINER_H
+#include <vector>
+class MBInterface;
+class MBEntityRefiner;
+class MB_DLL_EXPORT MBMeshRefiner
+public:
+ /// Construct a mesh refiner.
+ MBMeshRefiner( MBInterface* );
+ virtual ~MBMeshRefiner();
+ virtual bool refine_mesh();
+ bool set_entity_refiner( MBEntityRefiner* );
+ MBEntityRefiner* get_entity_refiner() { return this->entity_refiner; };
+protected:
+ MBEntityRefiner* entity_refiner;
+#endif // MB_MESHREFINER_H
Added: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp (rev 0)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-25 01:21:07 UTC (rev 1485)
@@ -0,0 +1,46 @@
+/** \class MBSimplexTemplateRefiner
+ * This is a concrete subclass of MBEntityRefiner that implements
+ * refinement using templates applied to simplices.
+ * \date 24 December 2007
+#ifndef MB_SIMPLEXTEMPLATEREFINER_H
+#define MB_SIMPLEXTEMPLATEREFINER_H
+#include "MBEntityRefiner.h"
+class MB_DLL_EXPORT MBSimplexTemplateRefiner : public MBEntityRefiner
+public:
+ /// Construct a template refiner.
+ MBSimplexTemplateRefiner();
+ virtual ~MBSimplexTemplateRefiner();
+ virtual bool refine_entity( MBEntityHandle );
+protected:
+ static int* template_index;
+ static int* templates;
+#endif // MB_SIMPLEXTEMPLATEREFINER_H
