[MOAB-dev] r1483 - in MOAB/branches/xcode_project: . MOAB MOAB/MOAB.xcodeproj MOAB/build MOAB/build/MOAB.build MOAB/build/MOAB.build/MOAB.pbxindex MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings
malkhafa at mcs.anl.gov malkhafa at mcs.anl.gov
Mon Dec 24 17:32:48 CST 2007
Author: malkhafa
Date: 2007-12-24 17:32:48 -0600 (Mon, 24 Dec 2007)
New Revision: 1483
Added:
   MOAB/branches/xcode_project/MOAB/
   MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/
   MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.mode1v3
   MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.pbxuser
   MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/project.pbxproj
   MOAB/branches/xcode_project/MOAB/build/
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/categories.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/cdecls.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/decls.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/files.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/imports.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/pbxindex.header
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/protocols.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/refs.pbxbtree
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/control
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/strings
   MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/subclasses.pbxbtree
Log:
Added: MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.mode1v3
--- MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.mode1v3	                        (rev 0)
+++ MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.mode1v3	2007-12-24 23:32:48 UTC (rev 1483)
@@ -0,0 +1,1353 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
+<plist version="1.0">
+<dict>
+	<key>ActivePerspectiveName</key>
+	<string>Project</string>
+	<key>AllowedModules</key>
+	<array>
+		<dict>
+			<key>BundleLoadPath</key>
+			<string></string>
+			<key>MaxInstances</key>
+			<string>n</string>
+			<key>Module</key>
+			<string>PBXSmartGroupTreeModule</string>
+			<key>Name</key>
+			<string>Groups and Files Outline View</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXNavigatorGroup</string>
+			<key>Name</key>
+			<string>Editor</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>XCTaskListModule</string>
+			<key>Name</key>
+			<string>Task List</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>XCDetailModule</string>
+			<key>Name</key>
+			<string>File and Smart Group Detail Viewer</string>
+		</dict>
+		<dict>
+			<string></string>
+			<string>1</string>
+			<key>Module</key>
+			<string>PBXBuildResultsModule</string>
+			<key>Name</key>
+			<string>Detailed Build Results Viewer</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXProjectFindModule</string>
+			<key>Name</key>
+			<string>Project Batch Find Tool</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>XCProjectFormatConflictsModule</string>
+			<key>Name</key>
+			<string>Project Format Conflicts List</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXBookmarksModule</string>
+			<key>Name</key>
+			<string>Bookmarks Tool</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXClassBrowserModule</string>
+			<key>Name</key>
+			<string>Class Browser</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXCVSModule</string>
+			<key>Name</key>
+			<string>Source Code Control Tool</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXDebugBreakpointsModule</string>
+			<key>Name</key>
+			<string>Debug Breakpoints Tool</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>XCDockableInspector</string>
+			<key>Name</key>
+			<string>Inspector</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXOpenQuicklyModule</string>
+			<key>Name</key>
+			<string>Open Quickly Tool</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXDebugSessionModule</string>
+			<key>Name</key>
+			<string>Debugger</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>PBXDebugCLIModule</string>
+			<key>Name</key>
+			<string>Debug Console</string>
+		</dict>
+		<dict>
+			<string></string>
+			<key>Module</key>
+			<string>XCSnapshotModule</string>
+			<key>Name</key>
+			<string>Snapshots Tool</string>
+		</dict>
+	</array>
+	<key>BundlePath</key>
+	<string>/Developer/Library/PrivateFrameworks/DevToolsInterface.framework/Resources</string>
+	<key>Description</key>
+	<string>DefaultDescriptionKey</string>
+	<key>DockingSystemVisible</key>
+	<false/>
+	<key>Extension</key>
+	<string>mode1v3</string>
+	<key>FavBarConfig</key>
+	<dict>
+		<key>PBXProjectModuleGUID</key>
+		<string>1C79F0BF0D20790D000EBABA</string>
+		<key>XCBarModuleItemNames</key>
+		<dict/>
+		<key>XCBarModuleItems</key>
+		<array/>
+	</dict>
+	<key>FirstTimeWindowDisplayed</key>
+	<false/>
+	<key>Identifier</key>
+	<string>com.apple.perspectives.project.mode1v3</string>
+	<key>MajorVersion</key>
+	<integer>33</integer>
+	<key>MinorVersion</key>
+	<integer>0</integer>
+	<key>Name</key>
+	<string>Default</string>
+	<key>Notifications</key>
+	<array/>
+	<key>OpenEditors</key>
+	<array/>
+	<key>PerspectiveWidths</key>
+	<array>
+		<integer>-1</integer>
+	</array>
+	<key>Perspectives</key>
+	<array>
+		<dict>
+			<key>ChosenToolbarItems</key>
+			<array>
+				<string>active-target-popup</string>
+				<string>active-buildstyle-popup</string>
+				<string>action</string>
+				<string>NSToolbarFlexibleSpaceItem</string>
+				<string>buildOrClean</string>
+				<string>build-and-goOrGo</string>
+				<string>com.apple.ide.PBXToolbarStopButton</string>
+				<string>get-info</string>
+				<string>toggle-editor</string>
+				<string>com.apple.pbx.toolbar.searchfield</string>
+			</array>
+			<key>ControllerClassBaseName</key>
+			<string></string>
+			<key>IconName</key>
+			<string>WindowOfProjectWithEditor</string>
+			<string>perspective.project</string>
+			<key>IsVertical</key>
+			<false/>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>BecomeActive</key>
+					<true/>
+					<key>ContentConfiguration</key>
+					<dict>
+						<key>PBXBottomSmartGroupGIDs</key>
+						<array>
+							<string>1C37FBAC04509CD000000102</string>
+							<string>1C37FAAC04509CD000000102</string>
+							<string>1C08E77C0454961000C914BD</string>
+							<string>1C37FABC05509CD000000102</string>
+							<string>1C37FABC05539CD112110102</string>
+							<string>E2644B35053B69B200211256</string>
+							<string>1C37FABC04509CD000100104</string>
+							<string>1CC0EA4004350EF90044410B</string>
+							<string>1CC0EA4004350EF90041110B</string>
+						</array>
+						<string>1CE0B1FE06471DED0097A5F4</string>
+						<key>PBXProjectModuleLabel</key>
+						<string>Files</string>
+						<key>PBXProjectStructureProvided</key>
+						<string>yes</string>
+						<key>PBXSmartGroupTreeModuleColumnData</key>
+						<dict>
+							<key>PBXSmartGroupTreeModuleColumnWidthsKey</key>
+							<array>
+								<real>186</real>
+							</array>
+							<key>PBXSmartGroupTreeModuleColumnsKey_v4</key>
+							<array>
+								<string>MainColumn</string>
+							</array>
+						</dict>
+						<key>PBXSmartGroupTreeModuleOutlineStateKey_v7</key>
+						<dict>
+							<key>PBXSmartGroupTreeModuleOutlineStateExpansionKey</key>
+							<array>
+								<string>1C79F0B30D20790B000EBABA</string>
+							</array>
+							<key>PBXSmartGroupTreeModuleOutlineStateSelectionKey</key>
+							<array>
+								<array>
+								</array>
+							</array>
+							<key>PBXSmartGroupTreeModuleOutlineStateVisibleRectKey</key>
+							<string>{{0, 0}, {186, 338}}</string>
+						</dict>
+						<key>PBXTopSmartGroupGIDs</key>
+						<array/>
+						<key>XCIncludePerspectivesSwitch</key>
+						<true/>
+						<key>XCSharingToken</key>
+						<string>com.apple.Xcode.GFSharingToken</string>
+					</dict>
+					<key>GeometryConfiguration</key>
+					<dict>
+						<key>Frame</key>
+						<string>{{0, 0}, {203, 356}}</string>
+						<key>GroupTreeTableConfiguration</key>
+						<array>
+							<real>186</real>
+						</array>
+						<key>RubberWindowFrame</key>
+						<string>375 375 690 397 0 0 1440 878 </string>
+					</dict>
+					<key>Module</key>
+					<key>Proportion</key>
+					<string>203pt</string>
+				</dict>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<string>1CE0B20306471E060097A5F4</string>
+								<string>MyNewFile14.java</string>
+								<key>PBXSplitModuleInNavigatorKey</key>
+								<dict>
+									<key>Split0</key>
+									<dict>
+										<string>1CE0B20406471E060097A5F4</string>
+									</dict>
+									<key>SplitCount</key>
+								</dict>
+								<key>StatusBarVisibility</key>
+								<true/>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 0}, {482, 0}}</string>
+							</dict>
+							<key>Module</key>
+							<string>0pt</string>
+						</dict>
+						<dict>
+							<dict>
+								<string>1CE0B20506471E060097A5F4</string>
+								<string>Detail</string>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 5}, {482, 351}}</string>
+							</dict>
+							<key>Module</key>
+							<string>351pt</string>
+						</dict>
+					</array>
+					<string>482pt</string>
+				</dict>
+			</array>
+			<key>Name</key>
+			<key>ServiceClasses</key>
+			<array>
+				<string>XCModuleDock</string>
+			</array>
+			<key>TableOfContents</key>
+			<array>
+				<string>1C79F0BD0D20790D000EBABA</string>
+				<string>1C79F0BE0D20790D000EBABA</string>
+			</array>
+			<key>ToolbarConfiguration</key>
+			<string>xcode.toolbar.config.defaultV3</string>
+		</dict>
+		<dict>
+			<string></string>
+			<string>WindowOfProject</string>
+			<string>perspective.morph</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<integer>1</integer>
+					<dict>
+						<array>
+						</array>
+						<string>11E0B1FE06471DED0097A5F4</string>
+						<dict>
+							<array>
+								<real>186</real>
+							</array>
+							<array>
+							</array>
+						</dict>
+						<dict>
+							<array>
+								<string>29B97314FDCFA39411CA2CEA</string>
+							</array>
+							<array>
+								<array>
+								</array>
+							</array>
+							<string>{{0, 0}, {186, 337}}</string>
+						</dict>
+						<array/>
+					</dict>
+					<dict>
+						<key>Frame</key>
+						<string>{{0, 0}, {203, 355}}</string>
+						<array>
+							<real>186</real>
+						</array>
+						<string>373 269 690 397 0 0 1440 878 </string>
+					</dict>
+					<key>Module</key>
+					<string>100%</string>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Morph</string>
+			<key>PreferredWidth</key>
+			<integer>300</integer>
+			<array>
+			</array>
+			<array>
+			</array>
+			<string>xcode.toolbar.config.default.shortV3</string>
+		</dict>
+	</array>
+	<key>PerspectivesBarVisible</key>
+	<false/>
+	<key>ShelfIsVisible</key>
+	<false/>
+	<key>SourceDescription</key>
+	<string>file at '/Developer/Library/PrivateFrameworks/DevToolsInterface.framework/Resources/XCPerspectivesSpecificationMode1.xcperspec'</string>
+	<key>StatusbarIsVisible</key>
+	<true/>
+	<key>TimeStamp</key>
+	<real>0.0</real>
+	<key>ToolbarDisplayMode</key>
+	<key>ToolbarIsVisible</key>
+	<true/>
+	<key>ToolbarSizeMode</key>
+	<key>Type</key>
+	<string>Perspectives</string>
+	<key>UpdateMessage</key>
+	<string>The Default Workspace in this version of Xcode now includes support to hide and show the detail view (what has been referred to as the "Metro-Morph" feature).  You must discard your current Default Workspace settings and update to the latest Default Workspace in order to gain this feature.  Do you wish to update to the latest Workspace defaults for project '%@'?</string>
+	<key>WindowJustification</key>
+	<integer>5</integer>
+	<key>WindowOrderList</key>
+	<array>
+		<string>/Users/malkhafaji/Documents/programming/MOAB/MOAB.xcodeproj</string>
+	</array>
+	<key>WindowString</key>
+	<key>WindowToolsV3</key>
+	<array>
+		<dict>
+			<string>windowTool.build</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<string>1CD0528F0623707200166675</string>
+								<string>&lt;No Editor&gt;</string>
+								<dict>
+									<key>Split0</key>
+									<dict>
+										<string>1CD052900623707200166675</string>
+									</dict>
+								</dict>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 0}, {500, 215}}</string>
+								<string>192 257 500 500 0 0 1280 1002 </string>
+							</dict>
+							<key>Module</key>
+							<string>218pt</string>
+						</dict>
+						<dict>
+							<dict>
+								<string>XCMainBuildResultsModuleGUID</string>
+								<string>Build</string>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 222}, {500, 236}}</string>
+							</dict>
+							<key>Module</key>
+							<string>236pt</string>
+						</dict>
+					</array>
+					<string>458pt</string>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Build Results</string>
+			<array>
+			</array>
+			<array>
+				<string>1C78EAA5065D492600B07095</string>
+				<string>1C78EAA6065D492600B07095</string>
+			</array>
+			<string>xcode.toolbar.config.buildV3</string>
+		</dict>
+		<dict>
+			<string>windowTool.debugger</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<key>Debugger</key>
+								<dict>
+									<key>HorizontalSplitView</key>
+									<dict>
+										<key>_collapsingFrameDimension</key>
+										<real>0.0</real>
+										<key>_indexOfCollapsedView</key>
+										<key>_percentageOfCollapsedView</key>
+										<real>0.0</real>
+										<key>isCollapsed</key>
+										<key>sizes</key>
+										<array>
+											<string>{{0, 0}, {317, 164}}</string>
+											<string>{{317, 0}, {377, 164}}</string>
+										</array>
+									</dict>
+									<key>VerticalSplitView</key>
+									<dict>
+										<real>0.0</real>
+										<real>0.0</real>
+										<key>sizes</key>
+										<array>
+											<string>{{0, 0}, {694, 164}}</string>
+											<string>{{0, 164}, {694, 216}}</string>
+										</array>
+									</dict>
+								</dict>
+								<key>LauncherConfigVersion</key>
+								<string>8</string>
+								<string>1C162984064C10D400B95A72</string>
+								<string>Debug - GLUTExamples (Underwater)</string>
+							</dict>
+							<dict>
+								<key>DebugConsoleDrawerSize</key>
+								<string>{100, 120}</string>
+								<key>DebugConsoleVisible</key>
+								<string>None</string>
+								<key>DebugConsoleWindowFrame</key>
+								<string>{{200, 200}, {500, 300}}</string>
+								<key>DebugSTDIOWindowFrame</key>
+								<key>Frame</key>
+								<string>{{0, 0}, {694, 380}}</string>
+								<string>321 238 694 422 0 0 1440 878 </string>
+							</dict>
+							<key>Module</key>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<array>
+			</array>
+			<array>
+				<string>1CD10A99069EF8BA00B06720</string>
+				<string>1C0AD2AB069F1E9B00FABCE6</string>
+				<string>1C0AD2AC069F1E9B00FABCE6</string>
+			</array>
+			<string>xcode.toolbar.config.debugV3</string>
+			<key>WindowToolGUID</key>
+			<key>WindowToolIsVisible</key>
+		</dict>
+		<dict>
+			<string>windowTool.find</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<key>Dock</key>
+							<array>
+								<dict>
+									<dict>
+										<string>1CDD528C0622207200134675</string>
+										<dict>
+											<key>Split0</key>
+											<dict>
+												<string>1CD0528D0623707200166675</string>
+											</dict>
+										</dict>
+									</dict>
+									<dict>
+										<key>Frame</key>
+										<string>{{0, 0}, {781, 167}}</string>
+										<string>62 385 781 470 0 0 1440 878 </string>
+									</dict>
+									<key>Module</key>
+									<string>781pt</string>
+								</dict>
+							</array>
+							<string>50%</string>
+						</dict>
+						<dict>
+							<dict>
+								<string>1CD0528E0623707200166675</string>
+								<string>Project Find</string>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{8, 0}, {773, 254}}</string>
+							</dict>
+							<key>Module</key>
+						</dict>
+					</array>
+					<string>428pt</string>
+				</dict>
+			</array>
+			<key>Name</key>
+			<array>
+			</array>
+			<array>
+				<string>1C530D57069F1CE1000CFCEE</string>
+				<string>1C530D58069F1CE1000CFCEE</string>
+				<string>1C530D59069F1CE1000CFCEE</string>
+				<string>1C530D5A069F1CE1000CFCEE</string>
+			</array>
+		</dict>
+		<dict>
+			<string>MENUSEPARATOR</string>
+		</dict>
+		<dict>
+			<string>windowTool.debuggerConsole</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<string>1C78EAAC065D492600B07095</string>
+								<string>Debugger Console</string>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 0}, {650, 250}}</string>
+								<string>516 632 650 250 0 0 1680 1027 </string>
+							</dict>
+							<key>Module</key>
+							<string>209pt</string>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<array>
+			</array>
+			<array>
+				<string>1C78EAAD065D492600B07095</string>
+				<string>1C78EAAE065D492600B07095</string>
+			</array>
+			<string>xcode.toolbar.config.consoleV3</string>
+			<string>650 41 650 250 0 0 1280 1002 </string>
+		</dict>
+		<dict>
+			<string>windowTool.snapshots</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<key>Module</key>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Snapshots</string>
+			<array>
+			</array>
+			<string>Yes</string>
+			<string>xcode.toolbar.config.snapshots</string>
+			<string>315 824 300 550 0 0 1440 878 </string>
+		</dict>
+		<dict>
+			<string>windowTool.scm</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<string>1C78EAB2065D492600B07095</string>
+								<dict>
+									<key>Split0</key>
+									<dict>
+										<string>1C78EAB3065D492600B07095</string>
+									</dict>
+								</dict>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 0}, {452, 0}}</string>
+								<string>743 379 452 308 0 0 1280 1002 </string>
+							</dict>
+							<key>Module</key>
+						</dict>
+						<dict>
+							<dict>
+								<string>1CD052920623707200166675</string>
+								<string>SCM</string>
+							</dict>
+							<dict>
+								<key>ConsoleFrame</key>
+								<string>{{0, 259}, {452, 0}}</string>
+								<key>Frame</key>
+								<string>{{0, 7}, {452, 259}}</string>
+								<key>TableConfiguration</key>
+								<array>
+									<string>Status</string>
+									<real>30</real>
+									<string>FileName</string>
+									<real>199</real>
+									<string>Path</string>
+									<real>197.09500122070312</real>
+								</array>
+								<key>TableFrame</key>
+								<string>{{0, 0}, {452, 250}}</string>
+							</dict>
+							<key>Module</key>
+							<string>262pt</string>
+						</dict>
+					</array>
+					<string>266pt</string>
+				</dict>
+			</array>
+			<key>Name</key>
+			<array>
+			</array>
+			<array>
+				<string>1C78EAB4065D492600B07095</string>
+				<string>1C78EAB5065D492600B07095</string>
+			</array>
+			<string>xcode.toolbar.config.scm</string>
+		</dict>
+		<dict>
+			<string>windowTool.breakpoints</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<array>
+									<string>1C77FABC04509CD000000102</string>
+								</array>
+								<string>no</string>
+								<dict>
+									<array>
+										<real>168</real>
+									</array>
+									<array>
+									</array>
+								</dict>
+								<dict>
+									<array>
+									</array>
+									<array>
+										<array>
+										</array>
+									</array>
+									<string>{{0, 0}, {168, 350}}</string>
+								</dict>
+								<array/>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{0, 0}, {185, 368}}</string>
+								<array>
+									<real>168</real>
+								</array>
+								<string>315 424 744 409 0 0 1440 878 </string>
+							</dict>
+							<key>Module</key>
+							<string>185pt</string>
+						</dict>
+						<dict>
+							<dict>
+								<string>1CA1AED706398EBD00589147</string>
+							</dict>
+							<dict>
+								<key>Frame</key>
+								<string>{{190, 0}, {554, 368}}</string>
+							</dict>
+							<key>Module</key>
+							<string>554pt</string>
+						</dict>
+					</array>
+					<string>368pt</string>
+				</dict>
+			</array>
+			<integer>3</integer>
+			<key>Name</key>
+			<string>Breakpoints</string>
+			<array>
+			</array>
+			<array>
+				<string>1CDDB66807F98D9800BB5817</string>
+				<string>1CDDB66907F98D9800BB5817</string>
+			</array>
+			<string>xcode.toolbar.config.breakpointsV3</string>
+		</dict>
+		<dict>
+			<string>windowTool.debugAnimator</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<key>Module</key>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Debug Visualizer</string>
+			<array>
+			</array>
+			<string>xcode.toolbar.config.debugAnimatorV3</string>
+			<string>100 100 700 500 0 0 1280 1002 </string>
+		</dict>
+		<dict>
+			<string>windowTool.bookmarks</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<key>Module</key>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Bookmarks</string>
+			<array>
+			</array>
+			<string>538 42 401 187 0 0 1280 1002 </string>
+		</dict>
+		<dict>
+			<string>windowTool.projectFormatConflicts</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<key>Module</key>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Project Format Conflicts</string>
+			<array>
+			</array>
+			<key>WindowContentMinSize</key>
+			<string>450 300</string>
+			<string>50 850 472 307 0 0 1440 877</string>
+		</dict>
+		<dict>
+			<string>windowTool.classBrowser</string>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<key>OptionsSetName</key>
+								<string>Hierarchy, all classes</string>
+								<string>1CA6456E063B45B4001379D8</string>
+								<string>Class Browser - NSObject</string>
+							</dict>
+							<dict>
+								<key>ClassesFrame</key>
+								<string>{{0, 0}, {374, 96}}</string>
+								<key>ClassesTreeTableConfiguration</key>
+								<array>
+									<string>PBXClassNameColumnIdentifier</string>
+									<real>208</real>
+									<string>PBXClassBookColumnIdentifier</string>
+									<real>22</real>
+								</array>
+								<key>Frame</key>
+								<string>{{0, 0}, {630, 331}}</string>
+								<key>MembersFrame</key>
+								<string>{{0, 105}, {374, 395}}</string>
+								<key>MembersTreeTableConfiguration</key>
+								<array>
+									<string>PBXMemberTypeIconColumnIdentifier</string>
+									<real>22</real>
+									<string>PBXMemberNameColumnIdentifier</string>
+									<real>216</real>
+									<string>PBXMemberTypeColumnIdentifier</string>
+									<real>97</real>
+									<string>PBXMemberBookColumnIdentifier</string>
+									<real>22</real>
+								</array>
+								<key>PBXModuleWindowStatusBarHidden2</key>
+								<string>385 179 630 352 0 0 1440 878 </string>
+							</dict>
+							<key>Module</key>
+							<string>332pt</string>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<array>
+			</array>
+			<array>
+				<string>1C0AD2AF069F1E9B00FABCE6</string>
+				<string>1C0AD2B0069F1E9B00FABCE6</string>
+			</array>
+			<string>xcode.toolbar.config.classbrowser</string>
+		</dict>
+		<dict>
+			<string>windowTool.refactoring</string>
+			<key>IncludeInToolsMenu</key>
+			<key>Layout</key>
+			<array>
+				<dict>
+					<key>Dock</key>
+					<array>
+						<dict>
+							<dict>
+								<key>Frame</key>
+								<string>{0, 0}, {500, 335}</string>
+							</dict>
+							<key>Module</key>
+							<string>XCRefactoringModule</string>
+						</dict>
+					</array>
+				</dict>
+			</array>
+			<key>Name</key>
+			<string>Refactoring</string>
+			<array>
+			</array>
+			<string>200 200 500 356 0 0 1920 1200 </string>
+		</dict>
+	</array>
+</dict>
+</plist>
Added: MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.pbxuser
--- MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.pbxuser	                        (rev 0)
+++ MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/malkhafaji.pbxuser	2007-12-24 23:32:48 UTC (rev 1483)
@@ -0,0 +1,50 @@
+// !$*UTF8*$!
+	1C79F0B50D20790B000EBABA /* Project object */ = {
+		activeArchitecture = i386;
+		activeBuildConfigurationName = Debug;
+		codeSenseManager = 1C79F0BA0D20790B000EBABA /* Code sense */;
+		ignoreBreakpointsInProjectsDict = {
+		perUserDictionary = {
+			PBXConfiguration.PBXFileTableDataSource3.PBXFileTableDataSource = {
+				PBXFileTableDataSourceColumnSortingDirectionKey = "-1";
+				PBXFileTableDataSourceColumnSortingKey = PBXFileDataSource_Filename_ColumnID;
+				PBXFileTableDataSourceColumnWidthsKey = (
+					20,
+					243,
+					20,
+					48.16259765625,
+					43,
+					43,
+					20,
+				PBXFileTableDataSourceColumnsKey = (
+					PBXFileDataSource_FiletypeID,
+					PBXFileDataSource_Filename_ColumnID,
+					PBXFileDataSource_Built_ColumnID,
+					PBXFileDataSource_ObjectSize_ColumnID,
+					PBXFileDataSource_Errors_ColumnID,
+					PBXFileDataSource_Warnings_ColumnID,
+					PBXFileDataSource_Target_ColumnID,
+			PBXPerProjectTemplateStateSaveDate = 220231947;
+			PBXWorkspaceStateSaveDate = 220231947;
+		sourceControlManager = 1C79F0B90D20790B000EBABA /* Source Control */;
+		userBuildSettings = {
+	1C79F0B90D20790B000EBABA /* Source Control */ = {
+		isa = PBXSourceControlManager;
+		fallbackIsa = XCSourceControlManager;
+		isSCMEnabled = 0;
+		scmConfiguration = {
+	1C79F0BA0D20790B000EBABA /* Code sense */ = {
+		isa = PBXCodeSenseManager;
+		indexTemplatePath = "";
Added: MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/project.pbxproj
--- MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/project.pbxproj	                        (rev 0)
+++ MOAB/branches/xcode_project/MOAB/MOAB.xcodeproj/project.pbxproj	2007-12-24 23:32:48 UTC (rev 1483)
@@ -0,0 +1,62 @@
+// !$*UTF8*$!
+	archiveVersion = 1;
+	classes = {
+	objectVersion = 42;
+	objects = {
+/* Begin PBXGroup section */
+		1C79F0B30D20790B000EBABA = {
+			isa = PBXGroup;
+			children = (
+			sourceTree = "<group>";
+/* End PBXGroup section */
+/* Begin PBXProject section */
+			isa = PBXProject;
+			buildConfigurationList = 1C79F0B80D20790B000EBABA /* Build configuration list for PBXProject "MOAB" */;
+			compatibilityVersion = "Xcode 2.4";
+			hasScannedForEncodings = 0;
+			mainGroup = 1C79F0B30D20790B000EBABA;
+			projectDirPath = "";
+			projectRoot = "";
+			targets = (
+/* End PBXProject section */
+/* Begin XCBuildConfiguration section */
+		1C79F0B60D20790B000EBABA /* Debug */ = {
+			isa = XCBuildConfiguration;
+			buildSettings = {
+				COPY_PHASE_STRIP = NO;
+			name = Debug;
+		1C79F0B70D20790B000EBABA /* Release */ = {
+			buildSettings = {
+				COPY_PHASE_STRIP = YES;
+			name = Release;
+/* End XCBuildConfiguration section */
+/* Begin XCConfigurationList section */
+		1C79F0B80D20790B000EBABA /* Build configuration list for PBXProject "MOAB" */ = {
+			isa = XCConfigurationList;
+			buildConfigurations = (
+				1C79F0B60D20790B000EBABA /* Debug */,
+				1C79F0B70D20790B000EBABA /* Release */,
+			defaultConfigurationIsVisible = 0;
+			defaultConfigurationName = Release;
+/* End XCConfigurationList section */
+	rootObject = 1C79F0B50D20790B000EBABA /* Project object */;
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/categories.pbxbtree
(Binary files differ)
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/categories.pbxbtree
___________________________________________________________________
   + application/octet-stream
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/cdecls.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/cdecls.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/decls.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/decls.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/files.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/files.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/imports.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/imports.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/pbxindex.header
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/pbxindex.header
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/protocols.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/protocols.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/refs.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/refs.pbxbtree
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/control
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/control
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/strings
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/strings.pbxstrings/strings
Added: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/subclasses.pbxbtree
Property changes on: MOAB/branches/xcode_project/MOAB/build/MOAB.build/MOAB.pbxindex/subclasses.pbxbtree
