[MOAB-dev] r1476 - MOAB/trunk/test/perf
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Dec 19 09:12:23 CST 2007
Author: tautges
Date: 2007-12-19 09:12:22 -0600 (Wed, 19 Dec 2007)
New Revision: 1476
Removed:
   MOAB/trunk/test/perf/makefile
Log:
Removing miniscule makefile.
Deleted: MOAB/trunk/test/perf/makefile
--- MOAB/trunk/test/perf/makefile	2007-12-17 14:55:32 UTC (rev 1475)
+++ MOAB/trunk/test/perf/makefile	2007-12-19 15:12:22 UTC (rev 1476)
@@ -1,83 +0,0 @@
-# * MOAB, a Mesh-Oriented datABase, is a software component for creating,
-# * storing and accessing finite element mesh data.
-# * Copyright 2004 Sandia Corporation.  Under the terms of Contract
-# * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
-# * retains certain rights in this software.
-# * This library is free software; you can redistribute it and/or
-# * modify it under the terms of the GNU Lesser General Public
-# * License as published by the Free Software Foundation; either
-# * version 2.1 of the License, or (at your option) any later version.
-MOAB_DIR = ${HOME}/MOAB
-TSTT_DIR = ${HOME}/tstt/TSTTbind
-include ${TSTT_DIR}/TSTTM/TSTTM-Defs.inc
-# define REALTFI if you want code to compute node locations using TFI, otherwise xyz is just
-# a linear interpolation of that coordinate over domain
-CXXFLAGS = -DREALTFI -g
-LDFLAGS = -g
-CUBIT = /cubit
-CUBIT_LIBS = \
-	-L$(CGM_SRC)/showviz/lib -lshowviz_geom_mesh -lshowviz_mesh -lshowviz_bc -lshowviz_geom -lshowviz \
-	-L${CGM_SRC} -lcubiti  \
-	-L/usr/local/ParaViewComplete/bin -lvtkHybrid -lvtkIO -lvtkRendering -lvtkftgl -lvtkfreetype \
-	    -lvtkImaging -lvtkGraphics -lvtkFiltering -lvtkCommon -lvtkexpat -lvtkjpeg -lvtkpng \
-	    -lvtktiff -lvtkzlib \
-	-L$(CGM_SRC)/df -lcbt_df  \
-	-L$(CGM_SRC)/mdb -lcubit_mdb \
-	-L$(CGM_SRC)/bc -lcubit_bc \
-	-L${CGM_SRC}/camal/lib/Linux -lcamal_pave -lcamal_shr -lcamal_tri \
-	-L${CGM_SRC}/cbt_mesquite -lcbt_mesquite \
-	-L${HOME}/cubit/Mesquite_Platforms/lib -lmesquite08 \
-	-L/cubit/camal/camal2.0.2/lib/Linux -lCMLTet202 \
-	-L/usr/local/gcc-3.2.3/lib -lg2c \
-	-L/cubit/lib -llpk \
-	-L/cubit/exodus/exodus-4.01/lib -lexoIIv2c401 \
-	-L/cubit/netcdf/lib -lnetcdf  \
-	-L/cubit/verdict/verdict1.1.2/lib -lverdict112
-CGM_LIBS = \
-	-L$(CGM_SRC)/geom/virtual -lcubit_virtual \
-	-L$(CGM_SRC)/geom/facet -lcubit_facet \
-	-L$(CGM_SRC)/geom/facetbool -lcubit_facetboolstub \
-	-L$(CGM_SRC)/geom -lcubit_geom \
-	-L$(CGM_SRC)/geom/Cholla -lcholla \
-	-L$(CGM_SRC)/util -lcubit_util 	\
-	-L$(CGM_SRC)/geom/ACIS -lcubit_ACIS \
-	-L/cubit/acis/acis13.2/bin/linux_so -lxstep -lxacis2k -lxcore2k -lxutil -lacisstep \
-	    -lxiges -lacisiges -lSpaAWarp -lSpaAVis -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase
-default: cubit_perf
-all: cubit_perf perf tstt_perf
-perf: perf.cpp
-	g++ $(CXXFLAGS) $(DEBUG_FLAG) -o perf -DLINUX -DREALTFI -DIS_BUILDING_MB -I ../.. perf.cpp -L ../.. -lMOAB -L/cubit/netcdf/lib -lnetcdf_c++ -lnetcdf
-cubit_perf: cubit_perf.o
-	g++ ${DEBUG_FLAG} cubit_perf.o -o cubit_perf ${CUBIT_LIBS} ${CUBIT_LIBS} ${CGM_LIBS} \
-        -L/usr/X11R6/lib -lXt -lXext -lX11
-cubit_perf.o: cubit_perf.cpp
-	g++ -c -DLINUX -DREALTFI ${DEBUG_FLAG} -I${CGM_SRC}/mdb -I${CGM_SRC}/util cubit_perf.cpp
-tstt_perf.o: tstt_perf.cpp
-	${CXX} -c ${CXXFLAGS} -DREALTFI ${TSTTM_INCLUDES} tstt_perf.cpp
-tstt_perf_binding.o: tstt_perf_binding.cpp
-	${CXX} -c ${CXXFLAGS} -DREALTFI ${TSTTM_CBIND_SERVER_INCLUDES} tstt_perf_binding.cpp
-tstt_perf: tstt_perf.o
-	$(LD)  -o $@ ${DEBUG_FLAG} tstt_perf.o -Wl,-rpath,${SIDL_MESH_DIR} -Wl,-rpath,${MOAB_DIR} -L${SIDL_MESH_DIR} -lMOABserver -L$(SIDLDIR)/lib -lsidl -L${MOAB_DIR} -lMOAB ${NETCDF_LIBS}
-tstt_perf_binding: tstt_perf_binding.o
-	$(CXX)  -o $@ ${LDFLAGS} tstt_perf_binding.o ${TSTTM_CBIND_SERVER_LIBS}
