[MOAB-dev] r1470 - MOAB/trunk
tautges at mcs.anl.gov
Fri Dec 14 14:06:45 CST 2007
Author: tautges
Date: 2007-12-14 14:06:42 -0600 (Fri, 14 Dec 2007)
New Revision: 1470
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/DualTool.hpp
Log:
Keeping track of max hex ids better.
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-12-14 19:26:27 UTC (rev 1469)
+++ MOAB/trunk/DualTool.cpp 2007-12-14 20:06:42 UTC (rev 1470)
@@ -45,7 +45,7 @@
const char *DualTool::DUAL_CURVE_TAG_NAME = "DUAL_CURVE";
//! tag name for dual cells
-const char *DualTool::IS_DUAL_CELL_TAG_NAME = "IS_DUAL_CELL";
+const char *DualTool::IS_DUAL_CELL_TAG_NAME = "__IS_DUAL_CELL";
//! tag name for dual entities
const char *DualTool::DUAL_ENTITY_TAG_NAME = "__DUAL_ENTITY";
@@ -100,6 +100,8 @@
result = mbImpl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
globalIdTag, &dum_int);
assert(MB_ALREADY_ALLOCATED == result || MB_SUCCESS == result);
+ maxHexId = -1;
DualTool::~DualTool()
@@ -135,6 +137,18 @@
if (MB_SUCCESS != result) return result;
result = mbImpl->get_entities_by_dimension(0, 3, regions);
+ // get the max global id for hexes, we'll need for modification ops
+ std::vector<int> gid_vec(regions.size());
+ result = mbImpl->tag_get_data(globalId_tag(), regions, &gid_vec[0]);
+ if (MB_SUCCESS != result) return result;
+ maxHexId = -1;
+ MBRange::iterator rit;
+ unsigned int i;
+ for (rit = regions.begin(), i = 0; rit != regions.end(); rit++, i++) {
+ if (gid_vec[i] > maxHexId && mbImpl->type_from_handle(*rit) == MBHEX)
+ maxHexId = gid_vec[i];
else {
// get entities of various dimensions adjacent to these
@@ -1496,6 +1510,11 @@
result = mbImpl->create_element(MBHEX, &verts[0], 8, new_hexes[0]); RR;
result = mbImpl->create_element(MBHEX, &tmp_verts[0], 8, new_hexes[1]); RR;
+ // set the global id tag on the new hexes
+ int new_hex_ids[2] = {++maxHexId, ++maxHexId};
+ result = mbImpl->tag_set_data(globalId_tag(), new_hexes, 2, new_hex_ids);
// by definition, quad1 is adj to new_hexes[0]
result = mbImpl->add_adjacencies(quad1, &new_hexes[0], 1, false); RR;
result = mbImpl->add_adjacencies(quad2, &new_hexes[1], 1, false); RR;
@@ -2634,6 +2653,8 @@
// ok, now have the 4 connectivity arrays for 4 quads; construct hexes
MBEntityHandle hconnect[8], new_hexes[4];
+ int new_hex_ids[4];
for (int i = 0; i < 4; i++) {
int i1 = i, i2 = (i+1)%4;
hconnect[0] = connects[0][i1];
@@ -2657,7 +2678,13 @@
+ new_hex_ids[i] = ++maxHexId;
+ result = mbImpl->tag_set_data(globalId_tag(), new_hexes, 4, new_hex_ids);
// now fixup other two hexes; start by getting hex through quads 0, 1
// make this first hex switch to the other side, to make the dual look like
Modified: MOAB/trunk/DualTool.hpp
--- MOAB/trunk/DualTool.hpp 2007-12-14 19:26:27 UTC (rev 1469)
+++ MOAB/trunk/DualTool.hpp 2007-12-14 20:06:42 UTC (rev 1470)
@@ -381,6 +381,8 @@
MBTag dualGraphicsPointTag;
MBTag categoryTag;
MBTag globalIdTag;
+ int maxHexId;
inline MBTag DualTool::dualSurface_tag() const
