[MOAB-dev] r1468 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Dec 13 16:09:27 CST 2007
Author: tautges
Date: 2007-12-13 16:09:27 -0600 (Thu, 13 Dec 2007)
New Revision: 1468
Modified:
   MOAB/trunk/DualTool.cpp
Log:
Set global ids of hexes in a face shrink after operation so the ids don't change.
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp	2007-12-12 20:27:04 UTC (rev 1467)
+++ MOAB/trunk/DualTool.cpp	2007-12-13 22:09:27 UTC (rev 1468)
@@ -2662,11 +2662,16 @@
     // now fixup other two hexes; start by getting hex through quads 0, 1
     // make this first hex switch to the other side, to make the dual look like
     // a hex push
+  int tmp_ids[2];
+  result = mbImpl->tag_get_data(globalId_tag(), hexes, 2, tmp_ids);
+  if (MB_SUCCESS != result) return result;
   result = mbImpl->delete_entities(hexes, 2);
   result = mbImpl->delete_entities(&quads[1], 1);
   for (int i = 0; i < 4; i++) {
     hconnect[i] = connects[3][i];
     hconnect[4+i] = connects[2][i];
@@ -2687,6 +2692,10 @@
   if (mtu.equivalent_entities(quads[2]))
       mbImpl->add_adjacencies(quads[2], &hexes[0], 1, false);
+    // re-set the global ids for the hexes to what they were
+  result = mbImpl->tag_set_data(globalId_tag(), hexes, 2, tmp_ids);
   if (debug_ap) ((MBCore*)mbImpl)->check_adjacencies();
     // now update the dual
